Linux/AM3352: USB RNDIS connection doesn't work at times
Part Number: AM3352
Tool/software: Linux
The earlier thread has got locked out due to timeout so creating a new thread here.. . Below are the two issues we face:
a) At times when the USB flash drive is connected we see the below dmesg logs and the USB flash drive doesn't get detected:
user.err kernel: [25222.819452] usb 1-1: device descriptor read/64, error -71
Mar  5 23:29:54 beaglebone user.info kernel: [25223.079452] usb 1-1: reset high-speed USB device number 55 using musb-hdrc
Mar  5 23:29:55 beaglebone user.err kernel: [25223.519758] usb 1-1: device not accepting address 55, error -71
Mar  5 23:29:55 beaglebone user.info kernel: [25223.659489] usb 1-1: reset high-speed USB device number 55 using musb-hdrc
Mar  5 23:29:55 beaglebone user.err kernel: [25224.099591] usb 1-1: device not accepting address 55, error -71
Mar  5 23:29:55 beaglebone user.info kernel: [25224.100124] usb 1-1: USB disconnect, device number 55
Mar  5 23:29:55 beaglebone user.info kernel: [25224.439405] usb 1-1: new high-speed USB device number 56 using musb-hdrc
Mar  5 23:29:56 beaglebone user.err kernel: [25224.579635] usb 1-1: device descriptor read/64, error -71
Mar  5 23:29:56 beaglebone user.err kernel: [25224.839588] usb 1-1: device descriptor read/64, error -71
Mar  5 23:29:56 beaglebone user.info kernel: [25225.099601] usb 1-1: new high-speed USB device number 57 using musb-hdrc
Mar  5 23:29:56 beaglebone user.err kernel: [25225.239588] usb 1-1: device descriptor read/64, error -71
Mar  5 23:29:56 beaglebone user.err kernel: [25225.499470] usb 1-1: device descriptor read/64, error -71
Mar  5 23:29:57 beaglebone user.info kernel: [25225.759581] usb 1-1: new high-speed USB device number 58 using musb-hdrc
Mar  5 23:29:57 beaglebone user.err kernel: [25226.199598] usb 1-1: device not accepting address 58, error -71
Mar  5 23:29:57 beaglebone user.info kernel: [25226.339621] usb 1-1: new high-speed USB device number 59 using musb-hdrc
Mar  5 23:29:58 beaglebone user.err kernel: [25226.779588] usb 1-1: device not accepting address 59, error -71
Mar  5 23:29:58 beaglebone user.err kernel: [25226.779816] usb usb1-port1: unable to enumerate USB device
2) When we plug in a USB OTG cable (with a flash drive connected to it) and within <=2 secs replace the OTG cable with a micro USB cable, the micro USB cable doesn't get detected.
Below is the dump when a USB OTG cable is connected and removed followed by a USB cable connected:
root@beaglebone:~# cat /sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0/mode
b_idle
root@xxx:~# cat /sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0/mode
a_wait_vrise
a_idle
a_idle
a_idle
b_idle
b_idle
root@xxx:~# grep DevCtl /sys/kernel/debug/musb-hdrc.0/regdump
DevCtl : 99
At this point the USB cable doesn't get detected. We need to remove and re-insert the USB cable to make it to work. When we do this (i.e remove and re-insert) we see the below logs
After re-insertion:
DevCtl : 99
DevCtl : 91
DevCtl : 89
DevCtl : 81
DevCtl : 80
DevCtl : 99
DevCtl : 99
DevCtl : 99
b_peripheral
Does the USB state machine get stuck up when a quick transition between USB flash drive and USB cable happen? Please let me know if you need more logs.
Fariya
  • Yariya,
    What kernel is used in this test? Any patches applied?
    Does it happen with multiple USB flash drives, or still with that Sandisk problematic one as referred on the previous e2e thread?
    Please try adding the following parameter in your U-Boot bootargs to see if the issue still happens.
    "usbcore.autosuspend=-1'
    The usb driver uses a 2-second timer to poll the usb status, swapping cables within 2 seconds would lead to unexpected behavior. If 2 seconds is tool long in your use case, we can make it shorter, for example, 1 second.
  • Hi Bin,
    This thread is a continuation of the early thread.. so kernel is 4.9.31 + the patch that you gave is applied. For the #1 issue, I will try with autosuspend option and let you know if it solves the issue.
    For #2 I think 2 seconds should be okay. I think we can put it is a known thing and tell people not to swap cables within 2 seconds.
    Fariya
  • Bin,
    We put up autosuspend=-1 option but we started facing USB flash drive (its a proper FAT32 formatted flash drive) detection issues more often. Below is a snippet of the log:
    [ 3087.979685] usb 1-1: reset high-speed USB device number 7 using musb-hdrc
    [ 3088.150242] sd 0:0:0:0: Device offlined - not ready after error recovery
    [ 3088.150433] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x05 driverbyte=0x00
    [ 3088.150519] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 02 00 00 00 f0 00
    [ 3088.150589] blk_update_request: I/O error, dev sda, sector 512
    [ 3088.150699] sd 0:0:0:0: rejecting I/O to offline device
    [ 3088.150751] sd 0:0:0:0: killing request
    [ 3088.150789] sd 0:0:0:0: rejecting I/O to offline device
    [ 3088.150830] sd 0:0:0:0: [sda] killing request
    [ 3088.150941] sd 0:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
    [ 3088.151005] sd 0:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 02 f0 00 00 10 00
    [ 3088.151047] blk_update_request: I/O error, dev sda, sector 752
    [ 3088.281111] sd 0:0:0:0: rejecting I/O to offline device
    [ 3122.996228] usb 1-1: USB disconnect, device number 7
    [ 3127.689884] usb 1-1: new high-speed USB device number 8 using musb-hdrc
    [ 3127.865025] usb-storage 1-1:1.0: USB Mass Storage device detected
    [ 3127.871033] scsi host0: usb-storage 1-1:1.0
    [ 3128.881886] scsi 0:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
    [ 3128.888967] sd 0:0:0:0: [sda] 3893248 512-byte logical blocks: (1.99 GB/1.86 GiB)
    [ 3128.889408] sd 0:0:0:0: [sda] Write Protect is off
    [ 3128.889468] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
    [ 3128.893610] sd 0:0:0:0: [sda] No Caching mode page found
    [ 3128.893698] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [ 3128.900459] sda: sda1
    [ 3128.908212] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [ 3129.312727] FAT-fs (sda1): bogus logical sector size 65535
    [ 3129.312815] FAT-fs (sda1): Can't find a valid FAT filesystem
    [ 3129.388566] FAT-fs (sda): invalid media value (0xf3)
    [ 3129.388651] FAT-fs (sda): Can't find a valid FAT filesystem
    Fariya
  • Fariya,
    The SCSI errors in the log are mostly caused by USB data corruption. Here are couple things please check.
    - As I mentioned in previous e2e thread, the kerenl v4.9.31+ you used is not TI released kernel, and it is not vanilla community kernel either, it looks like to be community v4.9.31 kernel plus some other patches. So I am unable to support you for this kernel. Please test with the kernel in Processor SDK v5.2.
    - If you still have such issue with kernel in Processor SDK v5.2, it likely to be hw issue, please check your board USB signal integrity.
  • Hi Bin,
    We will get back to you shortly after trying latest Linux kernel (available as part of SDK v5.2). Thanks for your support.
    Fariya
  • Hi Bin,
    We tried the latest 5.2 SDK and have used the kernel 4.14.79-gbde58ab01e (sdk-linux-am335x-evm-05.02.00.10). which comes with it.
    In continuation with previous thread http://e2e.ti.com/support/processors/f/791/t/763864?tisearch=e2e-sitesearch&keymatch=RNDIS%20issue . This kernel didn't have the patch that you had earlier shared. We applied this patch and after that specific USB flash drives (Sandisk 64GB) doesn't get detected. Please note, these flash drives were working with the unpatched USB driver. This is the same observation as earlier (on our kernel 4.9.31).
    Please find the attached musb_dspc.c
    Another question, we have observed that the USB ID pin goes high every 2 seconds even when no device (flash drive) or USB cable connected. Is this the polling the driver does every 2 seconds for device detection?
     * Texas Instruments DSPS platforms "glue layer"
     * Copyright (C) 2012, by Texas Instruments
     * Based on the am35x "glue layer" code.
     * This file is part of the Inventra Controller Driver for Linux.
     * The Inventra Controller Driver for Linux is free software; you
     * can redistribute it and/or modify it under the terms of the GNU
     * General Public License version 2 as published by the Free Software
     * Foundation.
     * The Inventra Controller Driver for Linux is distributed in
     * the hope that it will be useful, but WITHOUT ANY WARRANTY;
     * without even the implied warranty of MERCHANTABILITY or
     * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public
     * License for more details.
     * You should have received a copy of the GNU General Public License
     * along with The Inventra Controller Driver for Linux ; if not,
     * write to the Free Software Foundation, Inc., 59 Temple Place,
     * Suite 330, Boston, MA  02111-1307  USA
     * musb_dsps.c will be a common file for all the TI DSPS platforms
     * such as dm64x, dm36x, dm35x, da8x, am35x and ti81x.
     * For now only ti81x is using this and in future davinci.c, am35x.c
     * da8xx.c would be merged to this file after testing.
    #include <linux/io.h>
    #include <linux/err.h>
    #include <linux/platform_device.h>
    #include <linux/dma-mapping.h>
    #include <linux/pm_runtime.h>
    #include <linux/module.h>
    #include <linux/usb/usb_phy_generic.h>
    #include <linux/platform_data/usb-omap.h>
    #include <linux/sizes.h>
    #include <linux/of.h>
    #include <linux/of_device.h>
    #include <linux/of_address.h>
    #include <linux/of_irq.h>
    #include <linux/usb/of.h>
    #include <linux/debugfs.h>
    #include "musb_core.h"
    static const struct of_device_id musb_dsps_of_match[];
     * DSPS musb wrapper register offset.
     * FIXME: This should be expanded to have all the wrapper registers from TI DSPS
     * musb ips.
    struct dsps_musb_wrapper {
    	u16	revision;
    	u16	control;
    	u16	status;
    	u16	epintr_set;
    	u16	epintr_clear;
    	u16	epintr_status;
    	u16	coreintr_set;
    	u16	coreintr_clear;
    	u16	coreintr_status;
    	u16	phy_utmi;
    	u16	mode;
    	u16	tx_mode;
    	u16	rx_mode;
    	/* bit positions for control */
    	unsigned	reset:5;
    	/* bit positions for interrupt */
    	unsigned	usb_shift:5;
    	u32		usb_mask;
    	u32		usb_bitmap;
    	unsigned	drvvbus:5;
    	unsigned	txep_shift:5;
    	u32		txep_mask;
    	u32		txep_bitmap;
    	unsigned	rxep_shift:5;
    	u32		rxep_mask;
    	u32		rxep_bitmap;
    	/* bit positions for phy_utmi */
    	unsigned	otg_disable:5;
    	/* bit positions for mode */
    	unsigned	iddig:5;
    	unsigned	iddig_mux:5;
    	/* miscellaneous stuff */
    	unsigned	poll_timeout;
     * register shadow for suspend
    struct dsps_context {
    	u32 control;
    	u32 epintr;
    	u32 coreintr;
    	u32 phy_utmi;
    	u32 mode;
    	u32 tx_mode;
    	u32 rx_mode;
     * DSPS glue structure.
    struct dsps_glue {
    	struct device *dev;
    	struct platform_device *musb;	/* child musb pdev */
    	const struct dsps_musb_wrapper *wrp; /* wrapper register offsets */
    	int vbus_irq;			/* optional vbus irq */
    	struct timer_list timer;	/* otg_workaround timer */
    	unsigned long last_timer;    /* last timer data for each instance */
    	bool sw_babble_enabled;
    	void __iomem *usbss_base;
    	struct dsps_context context;
    	struct debugfs_regset32 regset;
    	struct dentry *dbgfs_root;
    static const struct debugfs_reg32 dsps_musb_regs[] = {
    	{ "revision",		0x00 },
    	{ "control",		0x14 },
    	{ "status",		0x18 },
    	{ "eoi",		0x24 },
    	{ "intr0_stat",		0x30 },
    	{ "intr1_stat",		0x34 },
    	{ "intr0_set",		0x38 },
    	{ "intr1_set",		0x3c },
    	{ "txmode",		0x70 },
    	{ "rxmode",		0x74 },
    	{ "autoreq",		0xd0 },
    	{ "srpfixtime",		0xd4 },
    	{ "tdown",		0xd8 },
    	{ "phy_utmi",		0xe0 },
    	{ "mode",		0xe8 },
    static void dsps_mod_timer(struct dsps_glue *glue, int wait_ms)
    	int wait;
    	if (wait_ms < 0)
    		wait = msecs_to_jiffies(glue->wrp->poll_timeout);
    	else
    		wait = msecs_to_jiffies(wait_ms);
    	mod_timer(&glue->timer, jiffies + wait);
     * If no vbus irq from the PMIC is configured, we need to poll VBUS status.
    static void dsps_mod_timer_optional(struct dsps_glue *glue)
    	if (glue->vbus_irq)
    		return;
    	dsps_mod_timer(glue, -1);
    /* USBSS  / USB AM335x */
    #define USBSS_IRQ_STATUS	0x28
    #define USBSS_IRQ_ENABLER	0x2c
    #define USBSS_IRQ_CLEARR	0x30
    #define USBSS_IRQ_PD_COMP	(1 << 2)
     * dsps_musb_enable - enable interrupts
    static void dsps_musb_enable(struct musb *musb)
    	struct device *dev = musb->controller;
    	struct platform_device *pdev = to_platform_device(dev->parent);
    	struct dsps_glue *glue = platform_get_drvdata(pdev);
    	const struct dsps_musb_wrapper *wrp = glue->wrp;
    	void __iomem *reg_base = musb->ctrl_base;
    	u32 epmask, coremask;
    	/* Workaround: setup IRQs through both register sets. */
    	epmask = ((musb->epmask & wrp->txep_mask) << wrp->txep_shift) |
    	       ((musb->epmask & wrp->rxep_mask) << wrp->rxep_shift);
    	coremask = (wrp->usb_bitmap & ~MUSB_INTR_SOF);
    	musb_writel(reg_base, wrp->epintr_set, epmask);
    	musb_writel(reg_base, wrp->coreintr_set, coremask);
    	/* start polling for ID change in dual-role idle mode */
    	if (musb->xceiv->otg->state == OTG_STATE_B_IDLE &&
    			musb->port_mode == MUSB_PORT_MODE_DUAL_ROLE)
     * dsps_musb_disable - disable HDRC and flush interrupts
    static void dsps_musb_disable(struct musb *musb)
    	musb_writel(reg_base, wrp->coreintr_clear, wrp->usb_bitmap);
    	musb_writel(reg_base, wrp->epintr_clear,
    			 wrp->txep_bitmap | wrp->rxep_bitmap);
    	del_timer_sync(&glue->timer);
    /* Caller must take musb->lock */
    static int dsps_check_status(struct musb *musb, void *unused)
    	void __iomem *mregs = musb->mregs;
    	struct dsps_glue *glue = dev_get_drvdata(dev->parent);
    	u8 devctl;
    	int skip_session = 0;
    	if (glue->vbus_irq)
    		del_timer(&glue->timer);
    	 * We poll because DSPS IP's won't expose several OTG-critical
    	 * status change events (from the transceiver) otherwise.
    	devctl = musb_readb(mregs, MUSB_DEVCTL);
    	dev_dbg(musb->controller, "Poll devctl %02x (%s)\n", devctl,
    				usb_otg_state_string(musb->xceiv->otg->state));
    	switch (musb->xceiv->otg->state) {
    	case OTG_STATE_A_WAIT_VRISE:
    		if (musb->port_mode == MUSB_PORT_MODE_HOST) {
    			musb->xceiv->otg->state = OTG_STATE_A_WAIT_BCON;
    			dsps_mod_timer_optional(glue);
    			break;
    		/* fall through */
    	case OTG_STATE_A_WAIT_BCON:
    		/* keep VBUS on for host-only mode */
    			break;
    		musb_writeb(musb->mregs, MUSB_DEVCTL, 0);
    		skip_session = 1;
    		/* fall */
    	case OTG_STATE_A_IDLE:
    	case OTG_STATE_B_IDLE:
    		if (!glue->vbus_irq) {
    			if (devctl & MUSB_DEVCTL_BDEVICE) {
    				musb->xceiv->otg->state = OTG_STATE_B_IDLE;
    				MUSB_DEV_MODE(musb);
    			} else {
    				musb->xceiv->otg->state = OTG_STATE_A_IDLE;
    				MUSB_HST_MODE(musb);
    			if (!(devctl & MUSB_DEVCTL_SESSION) && !skip_session)
    				musb_writeb(mregs, MUSB_DEVCTL,
    					    MUSB_DEVCTL_SESSION);
    		break;
    	case OTG_STATE_A_WAIT_VFALL:
    		musb->xceiv->otg->state = OTG_STATE_A_WAIT_VRISE;
    		musb_writel(musb->ctrl_base, wrp->coreintr_set,
    			    MUSB_INTR_VBUSERROR << wrp->usb_shift);
    		break;
    	default:
    		break;
    	return 0;
    static void otg_timer(unsigned long _musb)
    	struct musb *musb = (void *)_musb;
    	unsigned long flags;
    	int err;
    	err = pm_runtime_get(dev);
    	if ((err != -EINPROGRESS) && err < 0) {
    		dev_err(dev, "Poll could not pm_runtime_get: %i\n", err);
    		pm_runtime_put_noidle(dev);
    		return;
    	spin_lock_irqsave(&musb->lock, flags);
    	err = musb_queue_resume_work(musb, dsps_check_status, NULL);
    	if (err < 0)
    		dev_err(dev, "%s resume work: %i\n", __func__, err);
    	spin_unlock_irqrestore(&musb->lock, flags);
    	pm_runtime_mark_last_busy(dev);
    	pm_runtime_put_autosuspend(dev);
    static void dsps_musb_clear_ep_rxintr(struct musb *musb, int epnum)
    	u32 epintr;
    	struct dsps_glue *glue = dev_get_drvdata(musb->controller->parent);
    	/* musb->lock might already been held */
    	epintr = (1 << epnum) << wrp->rxep_shift;
    	musb_writel(musb->ctrl_base, wrp->epintr_status, epintr);
    static irqreturn_t dsps_interrupt(int irq, void *hci)
    	struct musb  *musb = hci;
    	irqreturn_t ret = IRQ_NONE;
    	u32 epintr, usbintr;
    	/* Get endpoint interrupts */
    	epintr = musb_readl(reg_base, wrp->epintr_status);
    	musb->int_rx = (epintr & wrp->rxep_bitmap) >> wrp->rxep_shift;
    	musb->int_tx = (epintr & wrp->txep_bitmap) >> wrp->txep_shift;
    	if (epintr)
    		musb_writel(reg_base, wrp->epintr_status, epintr);
    	/* Get usb core interrupts */
    	usbintr = musb_readl(reg_base, wrp->coreintr_status);
    	if (!usbintr && !epintr)
    		goto out;
    	musb->int_usb =	(usbintr & wrp->usb_bitmap) >> wrp->usb_shift;
    	if (usbintr)
    		musb_writel(reg_base, wrp->coreintr_status, usbintr);
    	dev_dbg(musb->controller, "usbintr (%x) epintr(%x)\n",
    			usbintr, epintr);
    	if (usbintr & ((1 << wrp->drvvbus) << wrp->usb_shift)) {
    		int drvvbus = musb_readl(reg_base, wrp->status);
    		u8 devctl = musb_readb(mregs, MUSB_DEVCTL);
    		int err;
    		err = musb->int_usb & MUSB_INTR_VBUSERROR;
    		if (err) {
    			 * The Mentor core doesn't debounce VBUS as needed
    			 * to cope with device connect current spikes. This
    			 * means it's not uncommon for bus-powered devices
    			 * to get VBUS errors during enumeration.
    			 * This is a workaround, but newer RTL from Mentor
    			 * seems to allow a better one: "re"-starting sessions
    			 * without waiting for VBUS to stop registering in
    			 * devctl.
    			musb->int_usb &= ~MUSB_INTR_VBUSERROR;
    			musb->xceiv->otg->state = OTG_STATE_A_WAIT_VFALL;
    			WARNING("VBUS error workaround (delay coming)\n");
    		} else if (drvvbus) {
    			musb->xceiv->otg->default_a = 1;
    		} else {
    			musb->is_active = 0;
    			musb->xceiv->otg->default_a = 0;
    		/* NOTE: this must complete power-on within 100 ms. */
    		dev_dbg(musb->controller, "VBUS %s (%s)%s, devctl %02x\n",
    				drvvbus ? "on" : "off",
    				usb_otg_state_string(musb->xceiv->otg->state),
    				err ? " ERROR" : "",
    				devctl);
    		ret = IRQ_HANDLED;
    	if (musb->int_tx || musb->int_rx || musb->int_usb)
    		ret |= musb_interrupt(musb);
    	/* Poll for ID change and connect */
    		break;
    	default:
    		break;
    out:
    	return ret;
    static int dsps_musb_dbg_init(struct musb *musb, struct dsps_glue *glue)
    	struct dentry *root;
    	struct dentry *file;
    	char buf[128];
    	sprintf(buf, "%s.dsps", dev_name(musb->controller));
    	root = debugfs_create_dir(buf, NULL);
    	if (!root)
    		return -ENOMEM;
    	glue->dbgfs_root = root;
    	glue->regset.regs = dsps_musb_regs;
    	glue->regset.nregs = ARRAY_SIZE(dsps_musb_regs);
    	glue->regset.base = musb->ctrl_base;
    	file = debugfs_create_regset32("regdump", S_IRUGO, root, &glue->regset);
    	if (!file) {
    		debugfs_remove_recursive(root);
    		return -ENOMEM;
    	return 0;
    static int dsps_musb_init(struct musb *musb)
    	struct platform_device *parent = to_platform_device(dev->parent);
    	void __iomem *reg_base;
    	struct resource *r;
    	u32 rev, val;
    	int ret;
    	r = platform_get_resource_byname(parent, IORESOURCE_MEM, "control");
    	reg_base = devm_ioremap_resource(dev, r);
    	if (IS_ERR(reg_base))
    		return PTR_ERR(reg_base);
    	musb->ctrl_base = reg_base;
    	/* NOP driver needs change if supporting dual instance */
    	musb->xceiv = devm_usb_get_phy_by_phandle(dev->parent, "phys", 0);
    	if (IS_ERR(musb->xceiv))
    		return PTR_ERR(musb->xceiv);
    	musb->phy = devm_phy_get(dev->parent, "usb2-phy");
    	/* Returns zero if e.g. not clocked */
    	rev = musb_readl(reg_base, wrp->revision);
    	if (!rev)
    		return -ENODEV;
    	usb_phy_init(musb->xceiv);
    	if (IS_ERR(musb->phy))  {
    		musb->phy = NULL;
    	} else {
    		ret = phy_init(musb->phy);
    		if (ret < 0)
    			return ret;
    		ret = phy_power_on(musb->phy);
    		if (ret) {
    			phy_exit(musb->phy);
    			return ret;
    	setup_timer(&glue->timer, otg_timer, (unsigned long) musb);
    	/* Reset the musb */
    	musb_writel(reg_base, wrp->control, (1 << wrp->reset));
    	musb->isr = dsps_interrupt;
    	/* reset the otgdisable bit, needed for host mode to work */
    	val = musb_readl(reg_base, wrp->phy_utmi);
    	val &= ~(1 << wrp->otg_disable);
    	musb_writel(musb->ctrl_base, wrp->phy_utmi, val);
    	 *  Check whether the dsps version has babble control enabled.
    	 * In latest silicon revision the babble control logic is enabled.
    	 * If MUSB_BABBLE_CTL returns 0x4 then we have the babble control
    	 * logic enabled.
    	val = musb_readb(musb->mregs, MUSB_BABBLE_CTL);
    	if (val & MUSB_BABBLE_RCV_DISABLE) {
    		glue->sw_babble_enabled = true;
    		val |= MUSB_BABBLE_SW_SESSION_CTRL;
    		musb_writeb(musb->mregs, MUSB_BABBLE_CTL, val);
    	return dsps_musb_dbg_init(musb, glue);
    static int dsps_musb_exit(struct musb *musb)
    	usb_phy_shutdown(musb->xceiv);
    	phy_power_off(musb->phy);
    	debugfs_remove_recursive(glue->dbgfs_root);
    	return 0;
    static int dsps_musb_set_mode(struct musb *musb, u8 mode)
    	void __iomem *ctrl_base = musb->ctrl_base;
    	u32 reg;
    	reg = musb_readl(ctrl_base, wrp->mode);
    	switch (mode) {
    	case MUSB_HOST:
    		reg &= ~(1 << wrp->iddig);
    		 * if we're setting mode to host-only or device-only, we're
    		 * going to ignore whatever the PHY sends us and just force
    		 * ID pin status by SW
    		reg |= (1 << wrp->iddig_mux);
    		musb_writel(ctrl_base, wrp->mode, reg);
    		musb_writel(ctrl_base, wrp->phy_utmi, 0x02);
    		break;
    	case MUSB_PERIPHERAL:
    		reg |= (1 << wrp->iddig);
    		break;
    	case MUSB_OTG:
    		break;
    	default:
    		dev_err(glue->dev, "unsupported mode %d\n", mode);
    		return -EINVAL;
    	return 0;
    static bool dsps_sw_babble_control(struct musb *musb)
    	u8 babble_ctl;
    	bool session_restart =  false;
    	babble_ctl = musb_readb(musb->mregs, MUSB_BABBLE_CTL);
    	dev_dbg(musb->controller, "babble: MUSB_BABBLE_CTL value %x\n",
    		babble_ctl);
    	 * check line monitor flag to check whether babble is
    	 * due to noise
    	dev_dbg(musb->controller, "STUCK_J is %s\n",
    		babble_ctl & MUSB_BABBLE_STUCK_J ? "set" : "reset");
    	if (babble_ctl & MUSB_BABBLE_STUCK_J) {
    		int timeout = 10;
    		 * babble is due to noise, then set transmit idle (d7 bit)
    		 * to resume normal operation
    		babble_ctl |= MUSB_BABBLE_FORCE_TXIDLE;
    		musb_writeb(musb->mregs, MUSB_BABBLE_CTL, babble_ctl);
    		/* wait till line monitor flag cleared */
    		dev_dbg(musb->controller, "Set TXIDLE, wait J to clear\n");
    		do {
    			udelay(1);
    		} while ((babble_ctl & MUSB_BABBLE_STUCK_J) && timeout--);
    		/* check whether stuck_at_j bit cleared */
    			 * real babble condition has occurred
    			 * restart the controller to start the
    			 * session again
    			dev_dbg(musb->controller, "J not cleared, misc (%x)\n",
    				babble_ctl);
    			session_restart = true;
    	} else {
    	return session_restart;
    static int dsps_musb_recover(struct musb *musb)
    	int session_restart = 0;
    	if (glue->sw_babble_enabled)
    		session_restart = dsps_sw_babble_control(musb);
    	else
    		session_restart = 1;
    	return session_restart ? 0 : -EPIPE;
    /* Similar to am35x, dm81xx support only 32-bit read operation */
    static void dsps_read_fifo32(struct musb_hw_ep *hw_ep, u16 len, u8 *dst)
    	void __iomem *fifo = hw_ep->fifo;
    	if (len >= 4) {
    		ioread32_rep(fifo, dst, len >> 2);
    		dst += len & ~0x03;
    		len &= 0x03;
    	/* Read any remaining 1 to 3 bytes */
    	if (len > 0) {
    		u32 val = musb_readl(fifo, 0);
    		memcpy(dst, &val, len);
    #ifdef CONFIG_USB_TI_CPPI41_DMA
    static void dsps_dma_controller_callback(struct dma_controller *c)
    	struct musb *musb = c->musb;
    	void __iomem *usbss_base = glue->usbss_base;
    	u32 status;
    	status = musb_readl(usbss_base, USBSS_IRQ_STATUS);
    	if (status & USBSS_IRQ_PD_COMP)
    		musb_writel(usbss_base, USBSS_IRQ_STATUS, USBSS_IRQ_PD_COMP);
    static struct dma_controller *
    dsps_dma_controller_create(struct musb *musb, void __iomem *base)
    	struct dma_controller *controller;
    	controller = cppi41_dma_controller_create(musb, base);
    	if (IS_ERR_OR_NULL(controller))
    		return controller;
    	musb_writel(usbss_base, USBSS_IRQ_ENABLER, USBSS_IRQ_PD_COMP);
    	controller->dma_callback = dsps_dma_controller_callback;
    	return controller;
    #ifdef CONFIG_PM_SLEEP
    static void dsps_dma_controller_suspend(struct dsps_glue *glue)
    	musb_writel(usbss_base, USBSS_IRQ_CLEARR, USBSS_IRQ_PD_COMP);
    static void dsps_dma_controller_resume(struct dsps_glue *glue)
    #endif
    #else /* CONFIG_USB_TI_CPPI41_DMA */
    static void dsps_dma_controller_suspend(struct dsps_glue *glue) {}
    static void dsps_dma_controller_resume(struct dsps_glue *glue) {}
    #endif
    #endif /* CONFIG_USB_TI_CPPI41_DMA */
    static struct musb_platform_ops dsps_ops = {
    	.quirks		= MUSB_DMA_CPPI41 | MUSB_INDEXED_EP,
    	.init		= dsps_musb_init,
    	.exit		= dsps_musb_exit,
    	.dma_init	= dsps_dma_controller_create,
    	.dma_exit	= cppi41_dma_controller_destroy,
    #endif
    	.enable		= dsps_musb_enable,
    	.disable	= dsps_musb_disable,
    	.set_mode	= dsps_musb_set_mode,
    	.recover	= dsps_musb_recover,
    	.clear_ep_rxintr = dsps_musb_clear_ep_rxintr,
    static u64 musb_dmamask = DMA_BIT_MASK(32);
    static int get_int_prop(struct device_node *dn, const char *s)
    	int ret;
    	u32 val;
    	ret = of_property_read_u32(dn, s, &val);
    	if (ret)
    		return 0;
    	return val;
    static int get_musb_port_mode(struct device *dev)
    	enum usb_dr_mode mode;
    	mode = usb_get_dr_mode(dev);
    	switch (mode) {
    	case USB_DR_MODE_HOST:
    		return MUSB_PORT_MODE_HOST;
    	case USB_DR_MODE_PERIPHERAL:
    		return MUSB_PORT_MODE_GADGET;
    	case USB_DR_MODE_UNKNOWN:
    	case USB_DR_MODE_OTG:
    	default:
    		return MUSB_PORT_MODE_DUAL_ROLE;
    static int dsps_create_musb_pdev(struct dsps_glue *glue,
    		struct platform_device *parent)
    	struct musb_hdrc_platform_data pdata;
    	struct resource	resources[2];
    	struct resource	*res;
    	struct device *dev = &parent->dev;
    	struct musb_hdrc_config	*config;
    	struct device_node *dn = parent->dev.of_node;
    	int ret, val;
    	memset(resources, 0, sizeof(resources));
    	res = platform_get_resource_byname(parent, IORESOURCE_MEM, "mc");
    	if (!res) {
    		dev_err(dev, "failed to get memory.\n");
    		return -EINVAL;
    	resources[0] = *res;
    	res = platform_get_resource_byname(parent, IORESOURCE_IRQ, "mc");
    	if (!res) {
    		dev_err(dev, "failed to get irq.\n");
    		return -EINVAL;
    	resources[1] = *res;
    	/* allocate the child platform device */
    	musb = platform_device_alloc("musb-hdrc",
    			(resources[0].start & 0xFFF) == 0x400 ? 0 : 1);
    	if (!musb) {
    		dev_err(dev, "failed to allocate musb device\n");
    		return -ENOMEM;
    	musb->dev.parent		= dev;
    	musb->dev.dma_mask		= &musb_dmamask;
    	musb->dev.coherent_dma_mask	= musb_dmamask;
    	glue->musb = musb;
    	ret = platform_device_add_resources(musb, resources,
    			ARRAY_SIZE(resources));
    	if (ret) {
    		dev_err(dev, "failed to add resources\n");
    		goto err;
    	config = devm_kzalloc(&parent->dev, sizeof(*config), GFP_KERNEL);
    	if (!config) {
    		ret = -ENOMEM;
    		goto err;
    	pdata.config = config;
    	pdata.platform_ops = &dsps_ops;
    	config->num_eps = get_int_prop(dn, "mentor,num-eps");
    	config->ram_bits = get_int_prop(dn, "mentor,ram-bits");
    	config->host_port_deassert_reset_at_resume = 1;
    	pdata.mode = get_musb_port_mode(dev);
    	/* DT keeps this entry in mA, musb expects it as per USB spec */
    	pdata.power = get_int_prop(dn, "mentor,power") / 2;
    	ret = of_property_read_u32(dn, "mentor,multipoint", &val);
    	if (!ret && val)
    		config->multipoint = true;
    	config->maximum_speed = usb_get_maximum_speed(&parent->dev);
    	switch (config->maximum_speed) {
    	case USB_SPEED_LOW:
    	case USB_SPEED_FULL:
    		break;
    	case USB_SPEED_SUPER:
    		dev_warn(dev, "ignore incorrect maximum_speed "
    				"(super-speed) setting in dts");
    		/* fall through */
    	default:
    		config->maximum_speed = USB_SPEED_HIGH;
    	ret = platform_device_add_data(musb, &pdata, sizeof(pdata));
    	if (ret) {
    		dev_err(dev, "failed to add platform_data\n");
    		goto err;
    	ret = platform_device_add(musb);
    	if (ret) {
    		dev_err(dev, "failed to register musb device\n");
    		goto err;
    	return 0;
    err:
    	platform_device_put(musb);
    	return ret;
    static irqreturn_t dsps_vbus_threaded_irq(int irq, void *priv)
    	struct dsps_glue *glue = priv;
    	struct musb *musb = platform_get_drvdata(glue->musb);
    	if (!musb)
    		return IRQ_NONE;
    	dev_dbg(glue->dev, "VBUS interrupt\n");
    	dsps_mod_timer(glue, 0);
    	return IRQ_HANDLED;
    static int dsps_setup_optional_vbus_irq(struct platform_device *pdev,
    	int error;
    	glue->vbus_irq = platform_get_irq_byname(pdev, "vbus");
    	if (glue->vbus_irq == -EPROBE_DEFER)
    		return -EPROBE_DEFER;
    	if (glue->vbus_irq <= 0) {
    		glue->vbus_irq = 0;
    		return 0;
    	error = devm_request_threaded_irq(glue->dev, glue->vbus_irq,
    					  NULL, dsps_vbus_threaded_irq,
    					  IRQF_ONESHOT,
    					  "vbus", glue);
    	if (error) {
    		glue->vbus_irq = 0;
    		return error;
    	dev_dbg(glue->dev, "VBUS irq %i configured\n", glue->vbus_irq);
    	return 0;
    static int dsps_probe(struct platform_device *pdev)
    	const struct of_device_id *match;
    	struct dsps_glue *glue;
    	int ret;
    	if (!strcmp(pdev->name, "musb-hdrc"))
    		return -ENODEV;
    	match = of_match_node(musb_dsps_of_match, pdev->dev.of_node);
    	if (!match) {
    		dev_err(&pdev->dev, "fail to get matching of_match struct\n");
    		return -EINVAL;
    	wrp = match->data;
    	if (of_device_is_compatible(pdev->dev.of_node, "ti,musb-dm816"))
    		dsps_ops.read_fifo = dsps_read_fifo32;
    	/* allocate glue */
    	glue = devm_kzalloc(&pdev->dev, sizeof(*glue), GFP_KERNEL);
    	if (!glue)
    		return -ENOMEM;
    	glue->dev = &pdev->dev;
    	glue->wrp = wrp;
    	glue->usbss_base = of_iomap(pdev->dev.parent->of_node, 0);
    	if (!glue->usbss_base)
    		return -ENXIO;
    	if (usb_get_dr_mode(&pdev->dev) == USB_DR_MODE_PERIPHERAL) {
    		ret = dsps_setup_optional_vbus_irq(pdev, glue);
    		if (ret)
    			goto err_iounmap;
    	platform_set_drvdata(pdev, glue);
    	pm_runtime_enable(&pdev->dev);
    	ret = dsps_create_musb_pdev(glue, pdev);
    	if (ret)
    		goto err;
    	return 0;
    err:
    	pm_runtime_disable(&pdev->dev);
    err_iounmap:
    	iounmap(glue->usbss_base);
    	return ret;
    static int dsps_remove(struct platform_device *pdev)
    	platform_device_unregister(glue->musb);
    	return 0;
    static const struct dsps_musb_wrapper am33xx_driver_data = {
    	.revision		= 0x00,
    	.control		= 0x14,
    	.status			= 0x18,
    	.epintr_set		= 0x38,
    	.epintr_clear		= 0x40,
    	.epintr_status		= 0x30,
    	.coreintr_set		= 0x3c,
    	.coreintr_clear		= 0x44,
    	.coreintr_status	= 0x34,
    	.phy_utmi		= 0xe0,
    	.mode			= 0xe8,
    	.tx_mode		= 0x70,
    	.rx_mode		= 0x74,
    	.reset			= 0,
    	.otg_disable		= 21,
    	.iddig			= 8,
    	.iddig_mux		= 7,
    	.usb_shift		= 0,
    	.usb_mask		= 0x1ff,
    	.usb_bitmap		= (0x1ff << 0),
    	.drvvbus		= 8,
    	.txep_shift		= 0,
    	.txep_mask		= 0xffff,
    	.txep_bitmap		= (0xffff << 0),
    	.rxep_shift		= 16,
    	.rxep_mask		= 0xfffe,
    	.rxep_bitmap		= (0xfffe << 16),
    	.poll_timeout		= 2000, /* ms */
    static const struct of_device_id musb_dsps_of_match[] = {
    	{ .compatible = "ti,musb-am33xx",
    		.data = &am33xx_driver_data, },
    	{ .compatible = "ti,musb-dm816",
    MODULE_DEVICE_TABLE(of, musb_dsps_of_match);
    static int dsps_suspend(struct device *dev)
    	struct dsps_glue *glue = dev_get_drvdata(dev);
    	void __iomem *mbase;
    	int ret;
    	if (!musb)
    		/* This can happen if the musb device is in -EPROBE_DEFER */
    		return 0;
    	ret = pm_runtime_get_sync(dev);
    	if (ret < 0) {
    		return ret;
    	mbase = musb->ctrl_base;
    	glue->context.control = musb_readl(mbase, wrp->control);
    	glue->context.epintr = musb_readl(mbase, wrp->epintr_set);
    	glue->context.coreintr = musb_readl(mbase, wrp->coreintr_set);
    	glue->context.phy_utmi = musb_readl(mbase, wrp->phy_utmi);
    	glue->context.mode = musb_readl(mbase, wrp->mode);
    	glue->context.tx_mode = musb_readl(mbase, wrp->tx_mode);
    	glue->context.rx_mode = musb_readl(mbase, wrp->rx_mode);
    	dsps_dma_controller_suspend(glue);
    	return 0;
    static int dsps_resume(struct device *dev)
    	if (!musb)
    		return 0;
    	dsps_dma_controller_resume(glue);
    	musb_writel(mbase, wrp->control, glue->context.control);
    	musb_writel(mbase, wrp->epintr_set, glue->context.epintr);
    	musb_writel(mbase, wrp->coreintr_set, glue->context.coreintr);
    	musb_writel(mbase, wrp->phy_utmi, glue->context.phy_utmi);
    	musb_writel(mbase, wrp->mode, glue->context.mode);
    	musb_writel(mbase, wrp->tx_mode, glue->context.tx_mode);
    	musb_writel(mbase, wrp->rx_mode, glue->context.rx_mode);
    	pm_runtime_put(dev);
    	return 0;
    #endif
    static SIMPLE_DEV_PM_OPS(dsps_pm_ops, dsps_suspend, dsps_resume);
    static struct platform_driver dsps_usbss_driver = {
    	.probe		= dsps_probe,
    	.remove         = dsps_remove,
    	.driver         = {
    		.name   = "musb-dsps",
    		.pm	= &dsps_pm_ops,
    		.of_match_table	= musb_dsps_of_match,
    MODULE_DESCRIPTION("TI DSPS MUSB Glue Layer");
    MODULE_AUTHOR("Ravi B <ravibabu@ti.com>");
    MODULE_AUTHOR("Ajay Kumar Gupta <ajay.gupta@ti.com>");
    MODULE_LICENSE("GPL v2");
    module_platform_driver(dsps_usbss_driver);
    Dheeraj
  • Hi Bin,
    I hope you have read the below thread.
    5415.musb_dsps.c
  • Hi Fariya and Dheeraj,
    Sorry for my late response, I was out of office last week and just got back.
    The file musb_dsps.c you attached looks clean. Please then apply the following two patches I provided before.
    marc.info/
    This fixes the usb phy driver bug during init, you would need it regardless.
    e2e.ti.com/.../2842347
    This patch increases the detecting timeout from 2sec to 10sec, since we know this problematic thumb drive would take about 2+sec to enumerate.
    If with these two patches on the SDK 5.2 kernel, the thumb drive still fails to enumerate, please use the scope to capture DRVBUS, VBUS, and D+ lines near AM335x.
    Regarding the ID pin goes high in every 2 seconds, yes, that is due to the PHY is sourcing current on the ID pin trying to detect if the pin is grounded or not.
  • Hi Bin,
    I applied two patches still I am observing same behavior, I will update the captured scope results.
    Dheeraj
  • Dheeraj, did you get a chance to capture the pin probes?
  • Hi Bin,
    Sorry for the delay,   Below attachments related one is USB detected(connected 2GB) and USB not detected(64GB connected).
    not_working.zipworking.zip
  • Dheeraj,
    Thanks for the captures.
    Can you also please capture the working case, which is without my initial patch, with the "not detected" thumb drive? I remembered you have provided similar capture before, but that was only probing DRVVBUS and VBUS lines, no D+, I'd like to see all the 3 signals in working case to compare with the non-working case.
  • Hi Bin,
    Sorry for the delay, please find the required capture.
  • Hi Bin,
    Gentle remainder, could you please let me know if any other information required.
  • Hi Bin,
    Did you get a chance to look at this issue.
    Dheeraj
  • Hi Dheeraj,
    Sorry for my late response.
    From those scope captures I asked before, I'd like to check the timing between DRVVBUS, VBUS and D+ lines. But in the last capture you did in April 8, only D+ pulled high, the rising of DRVVBUS and VBUS is already out of the picture. Are you able to capture one to show all the rise/fall transitions of all the 3 signals?
  • Hi, I haven’t heard back from you, I’m assuming you were able to resolve your issue. If not, just post a reply below (or create a new thread if the thread has locked due to time-out). thanks.
  • The issue isn't resolved yet. Will get back to you,
  • Hi Bin,
    DRVVBUS and VBUS always high. When ever I connected USBDRIVE D+ pulled high. (This test without patch)
  • Dheeraj,
    This issue has been last for so long that I lost tracking on what we have been done to debug the issue. I think it would make more sense if I could see the problem on my bench and directly debug it. So is it possible for you to contact the TI FAE in your local area who can ship the thumb drive to me?
  • We will try to ship the pen drive to you. Will keep you updated on this.
  • Hi Fariya,
    I received the Sandisk thumb drive and tested in TI kernel ti2018.05 (which is in Processor SDK Linux v5.2 or v5.3) and the community kernel v4.9.30 with the following patch I shared before on AM335x GP EVM, but I was unable to replicate the issue a). With kernel v4.9.30, I plugged/unplugged the thumb drive with the otg cable 50 times and plugged/unplugged the thumb drive itself for 50 times, all enumerated properly.
    Have you tried the same test on the AM335x GP EVM? or you only see the issue on your custom board?
    diff --git a/drivers/usb/musb/musb_dsps.c b/drivers/usb/musb/musb_dsps.c
    index 9f125e179acd..88d31d14c6db 100644
    --- a/drivers/usb/musb/musb_dsps.c
    +++ b/drivers/usb/musb/musb_dsps.c
    @@ -209,9 +209,14 @@ static int dsps_check_status(struct musb *musb, void *unused)
    -               mod_timer(&glue->timer, jiffies +
    -                               msecs_to_jiffies(wrp->poll_timeout));
    -               break;
    +               if (musb->port_mode == MUSB_PORT_MODE_HOST) {
    +                       musb->xceiv->otg->state = OTG_STATE_A_WAIT_BCON;
    +                       mod_timer(&glue->timer, jiffies +
    +                                       msecs_to_jiffies(wrp->poll_timeout));
    +                       break;
    +               /* fall through */
                    skip_session = 1;
  • Hi Bin,
    Thanks. The patch which needs to be applied is below (and not the one you applied):
    From 08649a65dfbe86afa2c7549ef97ed20cc559e6fc Mon Sep 17 00:00:00 2001
    Date: Tue, 27 Nov 2018 14:36:49 -0600
    Subject: [PATCH] usb: musb: dsps: fix otg state machine
    Due to lack of ID pin interrupt event on AM335x devices, the musb dsps
    driver uses polling to detect usb device attach for dual-role port.
    But in the case if a micro-A cable adapter is attached without a USB device
    attached to the cable, the musb state machine gets stuck in a_wait_vrise
    state waiting for the MUSB_CONNECT interrupt which won't happen due to the
    usb device is not attached. The state is stuck in a_wait_vrise even after
    the micro-A cable is detached, which could cause VBUS retention if then the
    dual-role port is attached to a host port.
    To fix the problem, make a_wait_vrise as a transient state, then move the
    state to either a_wait_bcon for host port or a_idle state for dual-role
    port, if no usb device is attached to the port.
    Signed-off-by: Bin Liu <b-liu@ti.com>
     drivers/usb/musb/musb_dsps.c | 9 +++++++--
     1 file changed, 7 insertions(+), 2 deletions(-)
    index dbb482b7e0ba..0c50f38ae4ef 100644
    @@ -242,8 +242,13 @@ static int dsps_check_status(struct musb *musb, void *unused)
    -		dsps_mod_timer_optional(glue);
    -		break;
    +			dsps_mod_timer_optional(glue);
    +			break;
    2.17.1
    After applying this patch, the Sandisk pen drive doesn't get detected. As mentioned earlier we are using our custom board for this test.
    Fariya
  • Hi Fariya,
    Sorry, that was a copy&paste error in my post above. I have corrected it with the patch I applied for v4.9.30 kernel, which is similar to the patch for v4.14 you applied.
    I am trying to figure why I don't see the issue but it happens to you with the same thumb drive. Do you have access to an AM335x GP EVM to see if you can reproduce the issue with the EVM?
    I will review your board schematics again to see if I can spot anything there.
  • Hi Fariya,
    If seems your board has been revised since the last review. Can you please send me the latest schematics?
  • Hi Fariya,
    I received your schematics. Thanks.
    We asked to replace R158 with 0 ohm on the USB ID line before, please correct it.
    Just for experiment, please
    - add 120uF cap on VBUS line;
    - replace R159 with 0 ohm on the VBUS line;
    and test the thumb drive again.
    Can you test the same on an AM335x GP EVM? I am unable to reproduce the issue with the Sandisk thumb drive you sent to me.
  • Hi Bin,
    We will perform experiment what ever you suggested and will get back to you. We don't have EVM to test.
    Dheeraj
