Linux/TDA2EVM5777: Unable to login as root user in TDA2xx
Part Number: TDA2EVM5777
Tool/software: Linux
I am just building the examples given get idea and hands on experience. Everything is building fine and whwnever I am trying to log in,  it is showing Login incorrect.
I am using SD card for boot.
Here is my Boot log-
    2.730302] EXT4-fs (mmcblk1p2): couldn't mount as ext3 due to feature incompatibilities
[    2.741731] EXT4-fs (mmcblk1p2): couldn't mount as ext2 due to feature incompatibilities
[    3.056589] EXT4-fs (mmcblk1p2): recovery complete
[    3.062309] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.070486] VFS: Mounted root (ext4 filesystem) on device 179:50.
[    3.082381] devtmpfs: mounted
[    3.085598] Freeing unused kernel memory: 336K
[    3.090094] This architecture does not have kernel memory protection.
[    3.208542] systemd[1]: System time before build time, advancing clock.
[    3.240281] random: systemd: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
[    3.249707] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceed.
[    3.263562] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bi.
[    3.284807] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[    3.296539] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCR)
[    3.315075] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[    3.340815] systemd[1]: Set hostname to <dra7xx-evm>.
[    3.396044] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.418664] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.428941] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.443317] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.454957] systemd-sysv-generator[93]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove ex.
[    3.471449] systemd-sysv-generator[93]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remov.
[    3.493167] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/alsa-state.service is marked executable. Please remove execu.
[    3.509398] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/alsa-state.service is marked world-writable. Please remove w.
[    3.531095] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.541602] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/run-postinsts.service is marked executable. Please remove ex.
[    3.558088] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/run-postinsts.service is marked world-writable. Please remov.
[    3.580522] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/busybox-syslog.service is marked executable. Please remove e.
[    3.597169] systemd-sysv-generator[93]: Configuration file /lib/systemd/system/busybox-syslog.service is marked world-writable. Please remo.
[    3.668560] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    3.678079] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    3.687943] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    3.893525] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bi.
[    3.908110] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability pe.
[    3.929533] systemd[1]: Configuration file /lib/systemd/system/var-lib-machines.mount is marked executable. Please remove executable permis.
[    3.944675] systemd[1]: Configuration file /lib/systemd/system/var-lib-machines.mount is marked world-writable. Please remove world writabi.
[    3.964871] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits.
[    3.979217] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability perm.
[    3.998246] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked executable. Please remove executable permission bits..
[    4.012558] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked world-writable. Please remove world writability permi.
[    4.031831] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked executable. Please remove executable permission bits. Proc.
[    4.045680] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked world-writable. Please remove world writability permission.
[    4.064386] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits.
[    4.078732] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability perm.
[    4.098033] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permi.
[    4.113250] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writab.
[    4.133680] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable perm.
[    4.148986] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writa.
[    4.170483] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bit.
[    4.184923] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability per.
[    4.207245] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked executable. Please remove executable permission bits..
[    4.221504] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permi.
[    4.241412] systemd[1]: Configuration file /lib/systemd/system/alsa-state.service is marked executable. Please remove executable permission.
[    4.256197] systemd[1]: Configuration file /lib/systemd/system/alsa-state.service is marked world-writable. Please remove world writability.
[    4.272522] systemd[1]: Configuration file /lib/systemd/system/alsa-restore.service is marked executable. Please remove executable permissi.
[    4.287475] systemd[1]: Configuration file /lib/systemd/system/alsa-restore.service is marked world-writable. Please remove world writabili.
[    4.307396] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits..
[    4.321652] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permi.
[    4.340725] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked executable. Please remove executable permission bits.
[    4.355070] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability perm.
[    4.374788] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable .
[    4.390461] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world w.
[    4.411142] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executabl.
[    4.426962] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world.
[    4.447705] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked executable. Please remove executable permission b.
[    4.462302] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability p.
[    4.482241] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission b.
[    4.496840] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability p.
[    4.515963] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permissi.
[    4.530911] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writabili.
[    4.551178] systemd[1]: Configuration file /lib/systemd/system/reboot.target is marked executable. Please remove executable permission bits.
[    4.565516] systemd[1]: Configuration file /lib/systemd/system/reboot.target is marked world-writable. Please remove world writability perm.
[    4.586355] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked executable. Please remove exe.
[    4.602699] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove.
[    4.624109] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked executable. Please remove executable permission b.
[    4.638710] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability p.
[    4.658961] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked executable. Please remove executable permission bit.
[    4.673387] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability per.
[    4.692767] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked executable. Please remove executable permission .
[    4.707454] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability .
[    4.729306] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked executable. Please remove executable permission bits..
[    4.743563] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permi.
[    4.763584] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permiss.
[    4.778841] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writabil.
[    4.799259] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked executable. Please remove executable permission b.
[    4.813860] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability p.
[    4.833269] systemd[1]: Configuration file /lib/systemd/system/network.target is marked executable. Please remove executable permission bit.
[    4.847694] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability per.
[    4.866655] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked executable. Please remove executable permission.
[    4.881430] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability.
[    4.900861] systemd[1]: Configuration file /etc/systemd/system/getty.target.wants/../../../../lib/systemd/system/getty@.service is marked e.
[    4.919647] systemd[1]: Configuration file /etc/systemd/system/getty.target.wants/../../../../lib/systemd/system/getty@.service is marked w.
[    4.943692] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permiss.
[    4.958728] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writabil.
[    4.975275] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits..
[    4.989524] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permi.
[    5.008543] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked executable. Please remove executable permission bits. .
[    5.022709] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permis.
[    5.041728] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked executable. Please remove executable permis.
[    5.056854] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writabi.
[    5.077134] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked executable. Please remove executable permis.
[    5.092257] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writabi.
[    5.112035] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked executable. Please remove executable permission bits. P.
[    5.126146] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permiss.
[    5.144934] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked executable. Please remove executabl.
[    5.160758] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world.
[    5.181289] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked executable. Please remove execut.
[    5.197373] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove wo.
[    5.218115] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked executable. Please remove executable.
[    5.233849] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world .
[    5.254322] systemd[1]: Configuration file /lib/systemd/system/busybox-syslog.service is marked executable. Please remove executable permis.
[    5.269444] systemd[1]: Configuration file /lib/systemd/system/busybox-syslog.service is marked world-writable. Please remove world writabi.
[    5.286028] systemd[1]: Configuration file /lib/systemd/system/busybox-klogd.service is marked executable. Please remove executable permiss.
[    5.301063] systemd[1]: Configuration file /lib/systemd/system/busybox-klogd.service is marked world-writable. Please remove world writabil.
[    5.320952] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable perm.
[    5.336249] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writa.
[    5.356654] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.network1.busname is marked executable. Please remove executa.
[    5.372649] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.network1.busname is marked world-writable. Please remove wor.
[    5.393528] systemd[1]: Configuration file /lib/systemd/system/busnames.target is marked executable. Please remove executable permission bi.
[    5.408042] systemd[1]: Configuration file /lib/systemd/system/busnames.target is marked world-writable. Please remove world writability pe.
[    5.427889] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.login1.busname is marked executable. Please remove executabl.
[    5.443711] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.login1.busname is marked world-writable. Please remove world.
[    5.464489] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.hostname1.busname is marked executable. Please remove execut.
[    5.480593] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.hostname1.busname is marked world-writable. Please remove wo.
[    5.501367] systemd[1]: Configuration file /etc/systemd/system/systemd-hostnamed.service is marked executable. Please remove executable per.
[    5.516752] systemd[1]: Configuration file /etc/systemd/system/systemd-hostnamed.service is marked world-writable. Please remove world writ.
[    5.537347] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.resolve1.busname is marked executable. Please remove executa.
[    5.553340] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.resolve1.busname is marked world-writable. Please remove wor.
[    5.574404] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.locale1.busname is marked executable. Please remove executab.
[    5.590313] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.locale1.busname is marked world-writable. Please remove worl.
[    5.611005] systemd[1]: Configuration file /lib/systemd/system/systemd-localed.service is marked executable. Please remove executable permi.
[    5.626217] systemd[1]: Configuration file /lib/systemd/system/systemd-localed.service is marked world-writable. Please remove world writab.
[    5.646229] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.timedate1.busname is marked executable. Please remove execut.
[    5.662313] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.timedate1.busname is marked world-writable. Please remove wo.
[    5.682902] systemd[1]: Configuration file /lib/systemd/system/systemd-timedated.service is marked executable. Please remove executable per.
[    5.698286] systemd[1]: Configuration file /lib/systemd/system/systemd-timedated.service is marked world-writable. Please remove world writ.
[    5.718338] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.systemd1.busname is marked executable. Please remove executa.
[    5.734333] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.systemd1.busname is marked world-writable. Please remove wor.
[    5.754964] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.machine1.busname is marked executable. Please remove executa.
[    5.770959] systemd[1]: Configuration file /lib/systemd/system/org.freedesktop.machine1.busname is marked world-writable. Please remove wor.
[    5.791715] systemd[1]: Configuration file /lib/systemd/system/systemd-machined.service is marked executable. Please remove executable perm.
[    5.807017] systemd[1]: Configuration file /lib/systemd/system/systemd-machined.service is marked world-writable. Please remove world writa.
[    5.827471] systemd[1]: Configuration file /lib/systemd/system/machine.slice is marked executable. Please remove executable permission bits.
[    5.841827] systemd[1]: Configuration file /lib/systemd/system/machine.slice is marked world-writable. Please remove world writability perm.
[    5.860979] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked executable. Please remove executable perm.
[    5.876278] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writa.
[    5.898558] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked executable. Please remove executable permission bits.
[    5.912897] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability perm.
[    5.933025] systemd[1]: Configuration file /lib/systemd/system/systemd-reboot.service is marked executable. Please remove executable permis.
[    5.948148] systemd[1]: Configuration file /lib/systemd/system/systemd-reboot.service is marked world-writable. Please remove world writabi.
[    5.968245] systemd[1]: Configuration file /lib/systemd/system/final.target is marked executable. Please remove executable permission bits..
[    5.982496] systemd[1]: Configuration file /lib/systemd/system/final.target is marked world-writable. Please remove world writability permi.
[    6.001360] systemd[1]: Configuration file /lib/systemd/system/poweroff.target is marked executable. Please remove executable permission bi.
[    6.015915] systemd[1]: Configuration file /lib/systemd/system/poweroff.target is marked world-writable. Please remove world writability pe.
[    6.036135] systemd[1]: Configuration file /lib/systemd/system/systemd-poweroff.service is marked executable. Please remove executable perm.
[    6.051436] systemd[1]: Configuration file /lib/systemd/system/systemd-poweroff.service is marked world-writable. Please remove world writa.
[    6.072784] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked executable. Please remove executabl.
[    6.088608] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world.
[    6.109309] systemd[1]: Configuration file /lib/systemd/system/systemd-firstboot.service is marked executable. Please remove executable per.
[    6.124694] systemd[1]: Configuration file /lib/systemd/system/systemd-firstboot.service is marked world-writable. Please remove world writ.
[    6.144906] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable .
[    6.160552] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world w.
[    6.180974] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove executable permiss.
[    6.196008] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writabil.
[    6.212440] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable p.
[    6.227998] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world wr.
[    6.248146] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable .
[    6.263792] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world w.
[    6.284055] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permis.
[    6.299394] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writabi.
[    6.319504] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked executable. Please remove executable.
[    6.335237] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world .
[    6.355978] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked executable. Please remove executable permissio.
[    6.370839] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writabilit.
[    6.390418] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked executable. Please remove executable permission b.
[    6.405018] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability p.
[    6.424275] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked executable. Please remove executable permis.
[    6.439398] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writabi.
[    6.459145] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked executable. Please remove executable p.
[    6.474704] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world wr.
[    6.494809] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable .
[    6.510454] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world w.
[    6.530659] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked executable. Please remove executable.
[    6.546394] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world .
[    6.566930] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable p.
[    6.582490] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world wr.
[    6.603545] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable p.
[    6.619103] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world wr.
[    6.639429] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked executable. Please remove e.
[    6.655946] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remo.
[    6.677126] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executabl.
[    6.692947] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world.
[    6.713669] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove execut.
[    6.729754] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove wo.
[    6.750904] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove exe.
[    6.767246] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove.
[    6.788403] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked executable. Please remove executable permission b.
[    6.803217] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability p.
[    6.822326] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove execu.
[    6.838495] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove w.
[    6.859623] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove execut.
[    6.875704] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove wo.
[    6.896491] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable p.
[    6.912049] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world wr.
[    6.932581] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked executable. Please remove executable permi.
[    6.947792] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writab.
[    6.968010] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked executable. Please remove executable per.
[    6.983394] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writ.
[    7.003577] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked executable. Please remove executable permissio.
[    7.018459] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writabilit.
[    7.038312] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable per.
[    7.053695] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writ.
[    7.074321] systemd[1]: Configuration file /lib/systemd/system/run-postinsts.service is marked executable. Please remove executable permiss.
[    7.089357] systemd[1]: Configuration file /lib/systemd/system/run-postinsts.service is marked world-writable. Please remove world writabil.
[    7.105635] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. .
[    7.119795] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permis.
[    7.138758] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked executable. Please remove executable permission .
[    7.153444] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability .
[    7.172793] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked executable. Please remove executable permission bits.
[    7.187130] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability perm.
[    7.206270] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked executable. Please remove executable.
[    7.222006] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world .
[    7.242445] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked executable. Please remove executab.
[    7.258353] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove worl.
[    7.279385] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked executable. Please remove executable permission bit.
[    7.293811] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability per.
[    7.314760] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked executable. Please remove executable permis.
[    7.329886] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writabi.
[    7.349970] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked executable. Please remove executable permi.
[    7.365182] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writab.
[    7.385184] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked executable. Please remove executable permi.
[    7.400395] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writab.
[    7.420295] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked executable. Please remove executable permission bi.
[    7.434807] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability pe.
[    7.454893] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked executable. Please remove executable permission bits. Pr.
[    7.468883] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permissi.
[    7.487626] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable pe.
[    7.503102] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world wri.
[    7.523686] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked executable. Please remove executable per.
[    7.539070] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writ.
[    7.559038] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked executable. Please remove executable perm.
[    7.574335] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writa.
[    7.594324] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked executable. Please remove executable permission b.
[    7.608924] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability p.
[    7.627978] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked executable. Please remove executable permissio.
[    7.642858] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writabilit.
[    7.662157] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bi.
[    7.676668] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability pe.
[    7.698612] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[    7.706394] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[    7.714107] systemd[1]: sysinit.target: Found dependency on basic.target/start
[    7.721377] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[    7.728821] systemd[1]: sysinit.target: Found dependency on dropbear.socket/stop
[    7.736248] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[    7.743703] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[    7.753155] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    7.778843] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.808228] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.837152] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.857215] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.887229] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.907264] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    7.937169] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.967169] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    7.987193] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    8.018131] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    8.047720] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    8.107365] systemd[1]: Starting Load Kernel Modules...
[    8.127214] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    8.147829] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    8.207249] systemd[1]: Mounting Debug File System...
[    8.229610] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    8.262656] systemd[1]: Mounting Temporary Directory...
[    8.289327] systemd[1]: Mounting POSIX Message Queue File System...
[    8.317243] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    8.347825] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    8.407343] systemd[1]: Starting Setup Virtual Console...
[    8.439646] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    8.497369] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.515263] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    8.527343] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    8.559585] systemd[1]: Starting Journal Service...
[    8.585003] systemd-journald[161]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission .
[    8.601821] systemd-journald[161]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability .
[    8.635397] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    8.667302] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    8.697324] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    8.727427] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Setup Virtual Console.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting udev Coldplug all Devices...
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[    9.362744] systemd-journald[161]: Received request to flush runtime journal from PID 1
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Coldplug all Devices.
[    9.675023] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    9.697332]  remoteproc0: 55020000.ipu is available
[    9.702235]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[  OK  ] Reached target Local File Systems.
[    9.759900]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    9.776512] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    9.800883]  remoteproc1: 40800000.dsp is available
         Starting Create Volatile Files and Directories...
[    9.820019]  remoteproc0: registered virtio0 (type 7)
[    9.833016]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[    9.857632]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
         Starting Load/Save Random Seed...
[    9.884774] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[  OK  ] Started Create Volatile Files and Directories.[    9.913292]  remoteproc2: 41000000.dsp is available
[    9.920903]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[  OK  ] Started Load/Save Random Seed.
[    9.937860]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    9.977802] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[  OK  ] Found device /dev/ttyS0.
[   10.027194] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[   10.120517] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[   10.339564]  remoteproc1: registered virtio1 (type 7)
[  OK  ] Started Network Time Synchronization.[   10.399592] SCSI subsystem initialized
         Starting Synchronize System and HW clocks...[   10.454818] CAN device driver interface
[   10.491564] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[  OK  ] Reached target System Time Synchronized.
[   10.526621] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=358)
[   10.544632] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[   10.560440]  remoteproc2: registered virtio2 (type 7)
[  OK  ] Started Synchronize System and HW clocks.
[   10.580262] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[   10.639037] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[   10.657255] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   10.699807] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[  OK  ] Reached target System Initialization.
[   10.736267] scsi host0: ahci
[   10.746131] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[   10.792774] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
[  OK  ] Reached target Timers.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Login Service...
         Starting rc.pvr.service...
[  OK  ] Started System Logging Service.
[  OK  ] Started D-Bus System Message Bus.
[   11.123107] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[   11.127071] ata1: SATA link down (SStatus 0 SControl 300)
         Starting Network Service...
         Starting Save/Restore Sound Card State...
[   11.278742] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
         Starting Permit User Sessions...[   11.300998] net eth1: initializing cpsw version 1.15 (0)
[   11.321713] net eth0: initialized cpsw ale version 1.4
[  OK  ] Started Kernel Logging Service.
[   11.349366] net eth0: ALE Table size 1024
[  OK  ] Started Network Service.
[   11.423247] net eth1: phy found : id is : 0x20005c7a
[  OK  ] Started rc.pvr.service.
[   11.452279] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started Permit User Sessions.
[   11.498960] net eth0: initializing cpsw version 1.15 (0)
[   11.570301]  remoteproc0: powering up 55020000.ipu
[   11.593514]  remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 472424
[   11.596580] net eth0: phy found : id is : 0x20005c7a
[   11.601879] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.637445] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[   11.658286]  remoteproc0: remote processor 55020000.ipu is now up
[   11.666711] virtio_rpmsg_bus virtio0: rpmsg host is online
[   11.675922]  remoteproc1: powering up 40800000.dsp
[   11.696935]  remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 6967019
[   11.717312] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[   11.723201] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   11.729122] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   11.796443]  remoteproc1: remote processor 40800000.dsp is now up
[   11.812240] virtio_rpmsg_bus virtio1: rpmsg host is online
[   11.825621]  remoteproc2: powering up 41000000.dsp
[   11.851062]  remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 6967019
[   11.871023] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[   11.876910] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   11.882829] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   11.943872] ------------[ cut here ]------------
[   11.943987]  remoteproc2: remote processor 41000000.dsp is now up
[   11.954637] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[   11.963980] 44000000.ocp:L3 Custom Error: MASTER DSP1_MDMA TARGET L4_PER3_P3 (Read): Data Access in User mode during Functional access
[   11.976114] Modules linked in: dwc3(+) udc_core virtio_rpmsg_bus(+) bc_example(O) pvrsrvkm(O) ahci_platform libahci_platform libahci extconl
[   12.005616] CPU: 0 PID: 1 Comm: systemd Tainted: G           O    4.4.84-00032-g0f6b93d-dirty #1
[   12.014434] Hardware name: Generic DRA74X (Flattened Device Tree)
[   12.020548] Backtrace:
[   12.023015] [<c00131d4>] (dump_backtrace) from [<c00133d0>] (show_stack+0x18/0x1c)
[   12.030611]  r7:c02de608 r6:200f0193 r5:00000000 r4:c094d810
[   12.036320] [<c00133b8>] (show_stack) from [<c02b21a8>] (dump_stack+0x8c/0xa0)
[   12.043572] [<c02b211c>] (dump_stack) from [<c0035340>] (warn_slowpath_common+0x88/0xb8)
[   12.051691]  r7:c02de608 r6:00000093 r5:00000009 r4:ef063bb8
[   12.057395] [<c00352b8>] (warn_slowpath_common) from [<c00353a8>] (warn_slowpath_fmt+0x38/0x40)
[   12.066124]  r8:00000017 r7:c0841d80 r6:00000002 r5:c08419b8 r4:c0841a5c
[   12.072885] [<c0035374>] (warn_slowpath_fmt) from [<c02de608>] (l3_interrupt_handler+0x25c/0x368)
[   12.081789]  r3:ef201b80 r2:c0841a5c
[   12.085386]  r4:80080003
[   12.087934] [<c02de3ac>] (l3_interrupt_handler) from [<c0080c28>] (handle_irq_event_percpu+0xb4/0x160)
[   12.097274]  r10:c097d38b r9:ef1f1300 r8:00000017 r7:00000000 r6:00000000 r5:ef1f1360
[   12.105165]  r4:ef210080
[   12.107712] [<c0080b74>] (handle_irq_event_percpu) from [<c0080d14>] (handle_irq_event+0x40/0x64)
[   12.116616]  r10:ef063f5c r9:ed41c240 r8:ef008000 r7:00000000 r6:c0935e44 r5:ef1f1360
[   12.124502]  r4:ef1f1300
[   12.127049] [<c0080cd4>] (handle_irq_event) from [<c0084058>] (handle_fasteoi_irq+0xc0/0x194)
[   12.135604]  r7:00000000 r6:c0935e44 r5:ef1f1360 r4:ef1f1300
[   12.141310] [<c0083f98>] (handle_fasteoi_irq) from [<c0080254>] (generic_handle_irq+0x2c/0x3c)
[   12.149952]  r7:00000000 r6:00000000 r5:00000017 r4:c092b424
[   12.155659] [<c0080228>] (generic_handle_irq) from [<c008052c>] (__handle_domain_irq+0x64/0xbc)
[   12.164393] [<c00804c8>] (__handle_domain_irq) from [<c000948c>] (gic_handle_irq+0x40/0x7c)
[   12.172773]  r9:ed41c240 r8:fa213000 r7:fa212000 r6:ef063d78 r5:fa21200c r4:c09308ec
[   12.180580] [<c000944c>] (gic_handle_irq) from [<c0013ec0>] (__irq_svc+0x40/0x74)
[   12.188092] Exception stack(0xef063d78 to 0xef063dc0)
[   12.193159] 3d60:                                                       ed98e5d8 00000000
[   12.201368] 3d80: ed98e5d8 ef062000 ed98e5d8 ed98e628 00080040 00080060 ed98e5d8 ed41c240
[   12.209576] 3da0: ef063f5c ef063dd4 ef063dd8 ef063dc8 c01361b0 c0088c90 a00f0013 ffffffff
[   12.217781]  r9:ed41c240 r8:ed98e5d8 r7:ef063dac r6:ffffffff r5:a00f0013 r4:c0088c90
[   12.225589] [<c0088c78>] (__rcu_read_lock) from [<c01361b0>] (dput+0x2c/0x290)
[   12.232841] [<c0136184>] (dput) from [<c0129ad8>] (terminate_walk+0x48/0xbc)
[   12.239915]  r10:ef063f5c r9:ed41c240 r8:ed98e5d8 r7:fffffffe r6:ef063eb0 r5:ef063eb0
[   12.247802]  r4:00000000 r3:00000103
[   12.251401] [<c0129a90>] (terminate_walk) from [<c012d77c>] (path_openat+0x438/0xfb0)
[   12.259258]  r7:fffffffe r6:ef063eb0 r5:ef063e78 r4:00024800
[   12.264964] [<c012d344>] (path_openat) from [<c012f484>] (do_filp_open+0x6c/0xd0)
[   12.272473]  r10:00000000 r9:ef062000 r8:c000fc84 r7:00000003 r6:ef063f5c r5:ef063eb0
[   12.280364]  r4:00000026
[   12.282912] [<c012f418>] (do_filp_open) from [<c01201c8>] (do_sys_open+0x11c/0x1e0)
[   12.290594]  r7:fffff000 r6:ec9b4000 r5:ffffff9c r4:00000026
[   12.296300] [<c01200ac>] (do_sys_open) from [<c01202c4>] (SyS_openat+0x14/0x18)
[   12.303635]  r9:ef062000 r8:c000fc84 r7:00000142 r6:00000000 r5:006a3e98 r4:00656120
[   12.311442] [<c01202b0>] (SyS_openat) from [<c000fae0>] (ret_fast_syscall+0x0/0x34)
[   12.319126] ---[ end trace f1b52824e07c5ceb ]---
[   12.364314] virtio_rpmsg_bus virtio2: rpmsg host is online
[   12.686265] usbcore: registered new interface driver usbfs
[   12.692872] usbcore: registered new interface driver hub
[   12.699636] usbcore: registered new device driver usb
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Sound Card.
[   12.744298] dwc3 48890000.usb: otg: primary host xhci-hcd.0.auto registered
[   12.751498] dwc3 48890000.usb: otg: shared host xhci-hcd.0.auto registered
[   12.760709] dwc3 48890000.usb: otg: can't start till gadget registers
[   12.767334] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   12.772854] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[   12.781024] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[   12.789849] xhci-hcd xhci-hcd.1.auto: irq 499, io mem 0x488d0000
[  OK  ] Started Getty on tty1.[   12.798496] hub 1-0:1.0: USB hub found
[   12.805775] hub 1-0:1.0: 1 port detected
[   12.810111] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   12.815664] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[   12.825218] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[  OK  ] Started Serial Getty on ttyS0.[   12.834831] hub 2-0:1.0: USB hub found
[   12.842614] hub 2-0:1.0: 1 port detected
         Starting weston.service...
[  OK  ] Reached target Network.
         Starting Network Name Resolution...
[  OK  ] Started weston.service.
[  OK  ] Started Login Service.
[  OK  ] Started Network Name Resolution.
         Starting tiipclad-daemon.service...
         Starting telnetd.service...
[  OK  ] Started tiipclad-daemon.service.
[  OK  ] Started telnetd.service.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: root
Login incorrect
dra7xx-evm login:
Please help me to overcome this problem.
Thank you.
  • Hi Salman,
    it looks like some problem with permissions of the files on the rootfs - systemd complains about files having executable and write permissions.
    Can you repeat steps in chapter "2.4.2.1.4 Download and untar file system" from VisionSDK_Linux_UserGuide.pdf and recreate the SD card?
    Yordan
  • Hi Yordan,
    Thank you for your prompt response.
    "2.4.2.1.4 Download and untar file system" resolved my issue and I am able to login as root.
    Now I am stuck due to following problem:
    Boot log :
    root@dra7xx-evm:~# cd /opt/vision_sdk/
    root@dra7xx-evm:/opt/vision_sdk# ls
    FragShader.fsh car.pod load_ocl_kos.sh setupUltrasonicPinMux.sh
    FragShader3Dsfm.fsh cmemk.ko memcache_load.sh tda2exEnableAVB.sh
    VertShader.vsh disableDssInterruptsOnA15.sh memcache_unload.sh ub964Init.sh
    VertShader3Dsfm.vsh enableImx290.sh models vision_sdk_load.sh
    VipClockInversion.sh enableIpu2CCSConectivity.sh opencl_env.sh vision_sdk_ov490_pinmux.sh
    apps.out hdmiReceiverConfig.sh ov106x3Config.sh vision_sdk_unload.sh
    bin jeep2.bmp pvrscope
    root@dra7xx-evm:/opt/vision_sdk# source [ 41.606941] random: nonblocking pool is initialized
    root@dra7xx-evm:/opt/vision_sdk# source ./vision_sdk_load.sh
    [ 60.158857] DMA: Module install successful, device major num = 242
    [ 60.165339] DRV: Module install successful
    [ 60.184654] CMEMK module: reference Linux version 4.4.84
    [ 60.190751] cmemk initialized
    ./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
    updated value is
    COMMANDS
    ### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
    No address check done, may generate:
    - bus error (invalid or not accessible <physical address>,
    - platform crash/hang (bad <value>).
    Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
    Dump a range of OMAP memory addresses, from <start address> to <end address>.
    Note all addresses within given range must be valid and accessible.
    ### WARNING ###: use the following I2C [read | write] commands at your own risk!
    - I2C bus error (invalid or not accessible <physical address>,
    Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    root@dra7xx-evm:/opt/vision_sdk# ./apps.out
    [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb699e000 of size 0x00100000
    [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa3d9e000 of size 0x12c00000
    [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa3cde000 of size 0x00040000
    [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3d1e000 of size 0x00080000
    [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
    [HOST] OSA: IPU1-0 Remote Log Shared Memory @ 0xa0200000
    [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
    [HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
    [HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280
    [HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20
    [HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0
    [HOST] OSA: EVE3 Remote Log Shared Memory @ 0xa0314c60
    [HOST] OSA: EVE4 Remote Log Shared Memory @ 0xa033c500
    [HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
    [HOST] [HOST ] 77.333312 s: SYSTEM: System A15 Init in progress !!!
    [HOST] [DSP1 ] 14.623040 s: ***** DSP1 Firmware build time 11:14:02 Mar 13 2019
    [HOST] [DSP1 ] 14.623101 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
    [HOST] [DSP1 ] 14.623345 s: SYSTEM: System Common Init in progress !!!
    [HOST] [DSP1 ] 14.623589 s: UTILS: CIO: Init Done !!!
    [HOST] [DSP1 ] 14.623619 s: SYSTEM: IPC init in progress !!!
    [HOST] [DSP1 ] 14.623650 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 15.624229 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 16.624260 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 17.624290 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 18.624321 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 19.624321 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 20.624351 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 21.624382 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 22.624412 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 23.624443 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 24.624473 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 25.624504 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 26.624534 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 27.624534 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 28.624565 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 29.624595 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 30.624626 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 31.624656 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 32.624687 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 33.624717 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 34.624748 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 35.624778 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 36.624778 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 37.624809 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 38.624839 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 39.624870 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 40.624900 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 41.624931 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 42.624961 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 43.624992 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 44.625022 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 45.625022 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 46.625053 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 47.625083 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 48.625114 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 49.625144 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 50.625175 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 51.625205 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 52.625236 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 53.625236 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 54.625266 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 55.625297 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 56.625327 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 57.625358 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 58.625388 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 59.625419 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 60.625449 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 61.625480 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 62.625480 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 63.625510 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 64.625541 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 65.625571 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 66.625602 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 67.625632 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 68.625663 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 69.625693 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 70.625724 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 71.625724 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 72.625754 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 73.625785 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 74.625815 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 75.625846 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 76.625876 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP1 ] 77.625907 s: SYSTEM: Attaching to [IPU1-0] ...
    [HOST] [DSP2 ] 14.756877 s: ***** DSP2 Firmware build time 11:14:02 Mar 13 2019
    [HOST] [DSP2 ] 14.756938 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
    [HOST] [DSP2 ] 14.757213 s: SYSTEM: System Common Init in progress !!!
    [HOST] [DSP2 ] 14.757457 s: UTILS: CIO: Init Done !!!
    and is going on.
    Please help me to solve this. Thank you.
    Salman
  • Hi Salman,
    did you made any changes in apps/configs/tda2xx_evm_linux_all/cfg.mk?
    Also can you try clean build:
    rm -rf vision_sdk/binaries
    make clean
    make linux_clean
    make linux
    make linux_install
    make -s -j depend
    make -s -j
    Yordan
  • Hi Yordan,
    Yes i did tried clean build but still same issue.
    Yes i have made changes in apps/configs/tda2xx_evm_linux_all/cfg.mk file.
    I have attached cfg.mk file.
    I have seen  this thread. But the mentioned patch is already applied in vision_sdk 3.5. I did verified it.
    For more information and reference output of  make showconfig shown:
    salman@salman-HP-Compaq-6200-Pro-SFF-PC:~/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/build$ make showconfig
    make -C /home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/configs -f build_makeconfig.mk showconfig
    make[1]: Entering directory '/home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/configs'
    # Build Config is [ tda2xx_evm_linux_all ]
    # Build Config file is @ /home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/configs/tda2xx_evm_linux_all/cfg.mk
    # Build Config .h file is @ /home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all/system_cfg.h
    # Build CPUs is @ ipu1_0 ipu2 a15_0 dsp1 dsp2 eve1 eve2 eve3 eve4
    # CPUs included in application,
    # PROC_IPU1_0_INCLUDE=yes
    # PROC_IPU1_1_INCLUDE=ys
    # PROC_IPU2_INCLUDE=yes
    # PROC_DSP1_INCLUDE=yes
    # PROC_DSP2_INCLUDE=yes
    # PROC_EVE1_INCLUDE=yes
    # PROC_EVE2_INCLUDE=yes
    # PROC_EVE3_INCLUDE=yes
    # PROC_EVE4_INCLUDE=yes
    # PROC_A15_0_INCLUDE=yes
    # Platform config,
    # VSDK_BOARD_TYPE=TDA2XX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_RVP TDA2XX_RVP]
    # PLATFORM=tda2xx-evm
    # DUAL_A15_SMP_BIOS=no
    # IPU1_SMP_BIOS=no
    # DDR_MEM=DDR_MEM_1024M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M]
    # EMIFMODE=SINGLE_EMIF_512MB [options: SINGLE_EMIF_512MB SINGLE_EMIF_1GB ref build_pdk.mk]
    # NDK_PROC_TO_USE=a15_0 [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
    # NSP_TFDTP_INCLUDE=no [options: yes no]
    # TDA2EX_ETHSRV_BOARD=no [options: yes no]
    # FATFS_PROC_TO_USE=none [options: ipu1_0 none]
    # RADAR_BOARD=none [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX_RADAR_RVP none]
    # Build config,
    # BUILD_OS=Linux [options: Windows_NT Linux]
    # BUILD_DEPENDENCY_ALWAYS=no
    # BUILD_ALGORITHMS=no
    # BUILD_INFOADAS=no
    # PROFILE=release [options: debug release]
    # KW_BUILD=no
    # CPLUSPLUS_BUILD=no
    # IPU_PRIMARY_CORE=ipu2 [options: ipu1_0 ipu2]
    # IPU_SECONDARY_CORE=ipu1_0 [options: ipu1_0 ipu2]
    # A15_TARGET_OS=Linux [options: Bios Linux Qnx]
    # BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe]
    # Safety Module config,
    # RTI_INCLUDE=no
    # ECC_FFI_INCLUDE=no
    # DCC_ESM_INCLUDE=no
    # Video Module config,
    # IVAHD_INCLUDE=yes
    # VPE_INCLUDE=yes
    # CAL_INCLUDE=no
    # ISS_INCLUDE=no
    # ISS_ENABLE_DEBUG_TAPS=no
    # WDR_LDC_INCLUDE=no
    # DSS_INCLUDE=yes
    # Open Compute config,
    # OPENCL_INCLUDE=no
    # TARGET_ROOTDIR=/home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/../ti_components/os_tools/linux/targetfs
    # ENABLE_OPENCV=no
    # ENABLE_OPENCV_TESTS=no
    # OPENVX_INCLUDE=no
    # Log config,
    # ENABLE_UART_LOG=yes
    # ENABLE_NETWORK_LOG=no
    # ENABLE_CCS_LOG=no
    # CIO_REDIRECT=yes
    # IPC config,
    # WORKQ_INCLUDE=no
    # IPC_LIB_INCLUDE=no
    # AUTOSAR_APP=no
    # Surround View config,
    # SRV_FAST_BOOT_INCLUDE=no
    # Other Module config,
    # AVB_INCLUDE=no
    # DCAN_INCLUDE=no
    # RADAR_ONLY=no
    # CPU_IDLE_ENABLED=yes
    # FAST_BOOT_INCLUDE=no
    # DATA_VIS_INCLUDE=no
    # HS_DEVICE=no
    # ULTRASONIC_INCLUDE=no
    # PGA450=
    # PGA460=
    # ENABLE_ALL_DEPTH=
    # Linux config,
    # DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config
    # DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig
    # DEFAULT_DTB=dra7-evm-infoadas.dtb dra7-evm-infoadas-lcd-lg.dtb
    # CMEM_INCLUDE=yes
    # IPUMM_INCLUDE=no
    # IPU1_EVELOADER_INCLUDE=yes
    # ROBUST_RVC_INCLUDE=no
    # BUILD_ADAM_CAR=no
    # Alg plugins included in build,
    # ALG_autocalibration ALG_dmaSwMs ALG_framecopy ALG_sparseopticalflow ALG_structurefrommotion ALG_surroundview
    # Use-cases included in build,
    # UC_srv_calibration UC_network_rx_tx UC_null_src_display UC_lvds_vip_multi_cam_3d_perception UC_lvds_vip_multi_cam_3d_srv UC_lvds_vip_multi_cam_2mp_3d_srv UC_lvds_vip_multi_cam_3d_adaptive_srv UC_lvds_vip_multi_cam_view_sgx_display UC_lvds_vip_multi_cam_vpe_enc_null UC_null_src_decode_display UC_disp_dist_src_display UC_ov490_vip_multi_cam_3d_srv UC_vip_single_cam_connectorLinksA15_sgx_display UC_vip_single_cam_enc_dec_sgx_display UC_vip_single_cam_framecopy_sgx_display UC_vip_single_cam_framecopyEve_sgx_display UC_vip_single_cam_sgx_display
    make -s -fbuild_makeconfig.mk check_cpu_include
    make[2]: Entering directory '/home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/configs'
    # CPUs that are NOT required but included in config [ tda2xx_evm_linux_all ],
    # CPUs that are required but not included in config [ tda2xx_evm_linux_all ],
    # Edit /home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/build/configs/tda2xx_evm_linux_all/cfg.mk to include or exclude CPUs in an application
    make[2]: Leaving directory '/home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/configs'
    make[1]: Leaving directory '/home/salman/vision3.5/PROCESSOR_SDK_VISION_03_05_00_00/vision_sdk/apps/configs'
    Thank you.
    Salman
    # This file defines the modules included in $(MAKECONFIG) config
    # Modules are split into,
    # - Use-cases specified in uc_cfg.mk
    # - Other system config/feature, specified in this file
    # Any specific overrides are also specified in this file
    # Example, for TDA3x SoC EVE2/3/4 are not present and hence force marked as <blank>, i.e disabled
    # Additional config options
    # CPUs to included in build
    # IPU1 (core 0 & 1 are) not supported when IPU_PRIMARY_CORE=ipu2
    # Supported values: DDR_MEM_1024M
    # Supported values: ipu1_0 ipu1_1 ipu2 a15_0 none
    # Used to control building of algorithm source.
    # By default algorithm source not included in Vision SDK
    BUILD_ALGORITHMS=no
    # Applies profile to all cores
    # Supported profiles: release debug
    #PROFILE=debug
    PROFILE ?= release
    PROFILE_ipu1_0 ?= $(PROFILE)
    PROFILE_ipu1_1 ?= $(PROFILE)
    PROFILE_ipu2 ?= $(PROFILE)
    PROFILE_c66xdsp_1 ?= $(PROFILE)
    PROFILE_c66xdsp_2 ?= $(PROFILE)
    PROFILE_arp32_1 ?= $(PROFILE)
    PROFILE_arp32_2 ?= $(PROFILE)
    PROFILE_arp32_3 ?= $(PROFILE)
    PROFILE_arp32_4 ?= $(PROFILE)
    PROFILE_a15_0 ?= $(PROFILE)
    # For TDA2xx & TDA2Ex - vision SDK can run on either IPU1 or IPU2 subsystem
    # For TDA3xx - We have only IPU1 and hence IPU1 is the only option
    # Select IPU primary core from the available IPU1 & IPU2 subsytems
    # Supported values: ipu1_0 ipu2
    # Set A15_TARGET_OS
    # A15 can run Linux or Bios
    #                 A15_TARGET_OS support
    #   Platform        BIOS        Linux
    #   TDA2XX_EVM      yes         yes
    #   TDA3XX_EVM      yes         no
    #   TDA2EX_EVM      yes         yes
    # Supported values: Bios Linux
    A15_TARGET_OS=Linux
    # Both IVAHD_INCLUDE & IPUMM_INCLUDE should not be set to "yes"
    # Only one should be enabled to avoid IVA-HD resource conflict
    IPUMM_INCLUDE=no
    IVAHD_INCLUDE=yes
    VPE_INCLUDE=yes
    DSS_INCLUDE=yes
    AVB_INCLUDE=no
    # Enable below macro to enable DCAN integration into Vision SDK.
    DCAN_INCLUDE=no
    # Enable below macro to view the bandwidth used by different IPs in the device
    # as a graphical plot on the display screen.
    DATA_VIS_INCLUDE=no
    # Enable below macro to enable OPENVX into Vision SDK
    OPENVX_INCLUDE=no
    CIO_REDIRECT=yes
    HS_DEVICE=no
    #Enable/Disable early use-cases (yes/no)
    EARLY_USECASE_ENABLE=no
    #OPENVX doesn't work with early-boot late-attach. Disable if EARLY_USECASE=yes
    ifeq ($(EARLY_USECASE_ENABLE),yes)
    OPENVX_INCLUDE=no
    endif
    DEFAULT_UBOOT_CONFIG  := dra7xx_evm_vision_config
    DEFAULT_KERNEL_CONFIG := ti_sdk_dra7x_release_defconfig
    # For TDA2x
    DEFAULT_DTB := dra7-evm-infoadas.dtb dra7-evm-infoadas-lcd-lg.dtb
    CMEM_INCLUDE=yes
    include $($(MAKEAPPNAME)_PATH)/configs/$(MAKECONFIG)/uc_cfg.mk
  • Hi Salman,
    can you try the configuration proposed here:
    e2e.ti.com/.../2867222
    also in the last post of the same thread check the modification in ipu entries in the .dts file.
    Yordan
  • HI Yordan,
    I followed the steps.
    But now I am getting error while building  make -s -j as
    MAKEFILE.MK:31: recipe for target 'apps' failed
    make[4]: *** [apps] Error 2
    MAKEFILE.MK:298: recipe for target 'apps' failed
    make[3]: *** [apps] Error 2
    Makefile:171: recipe for target 'apps_exe' failed
    make[2]: *** [apps_exe] Error 2
    Makefile:36: recipe for target 'apps' failed
    make[1]: *** [apps] Error 2
    Makefile:12: recipe for target 'vision_sdk' failed
    For reference I have attached error.log(which is output of make -s -j) and make showconfig output(in make_showconfig.txt).
    Thank you.4401.error.log
    # PROC_IPU1_1_INCLUDE=no
    # Platform config,
    # IPU1_SMP_BIOS=no
    # NDK_PROC_TO_USE=none [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
    # Build config,
    # BUILD_INFOADAS=no
    # KW_BUILD=no
    # RTI_INCLUDE=no
    # IVAHD_INCLUDE=yes
    # VPE_INCLUDE=yes
    # CAL_INCLUDE=no
    # ISS_INCLUDE=no
    # DSS_INCLUDE=yes
    # OPENCL_INCLUDE=no
    # ENABLE_OPENCV=no
    # OPENVX_INCLUDE=no
    # Log config,
    # ENABLE_CCS_LOG=no
    # CIO_REDIRECT=yes
    # IPC config,
    # WORKQ_INCLUDE=no
    # AUTOSAR_APP=no
    # AVB_INCLUDE=no
    # DCAN_INCLUDE=no
    # RADAR_ONLY=no
    # HS_DEVICE=no
    # PGA450=
    # PGA460=
    # ENABLE_ALL_DEPTH=
    # Linux config,
    # CMEM_INCLUDE=yes
    # IPUMM_INCLUDE=no
    # BUILD_ADAM_CAR=no
    # UC_srv_calibration UC_null_src_display UC_lvds_vip_multi_cam_3d_perception UC_lvds_vip_multi_cam_3d_srv UC_lvds_vip_multi_cam_2mp_3d_srv UC_lvds_vip_multi_cam_3d_adaptive_srv UC_lvds_vip_multi_cam_view_sgx_display UC_lvds_vip_multi_cam_vpe_enc_null UC_null_src_decode_display UC_disp_dist_src_display UC_ov490_vip_multi_cam_3d_srv UC_vip_single_cam_connectorLinksA15_sgx_display UC_vip_single_cam_enc_dec_sgx_display UC_vip_single_cam_framecopy_sgx_display UC_vip_single_cam_framecopyEve_sgx_display UC_vip_single_cam_sgx_display
  • Hi Salman,
    did you run "make -s -j depend" before "make -s -j"? Can you try with removing "binaries" directory:
    make clean
    make linux_clean
    make linux
    make linux_install
    make -s -j depend
    make -s -j
    Yordan
  • Hello Yordan,
    Thank you for your kind reply. I followed your steps but still I got linking error.
    I solved this problem and now have successfully build and tested it.
    Following steps I have followed :
    1. Make changes in vision_sdk/apps/configs/tda2xx_evm_linux_all/cfg.mk
    PROC_IPU2_INCLUDE=no
    IPU_PRIMARY_CORE=ipu1_0
    IPU_SECONDARY_CORE=ipu2
    2. Make changes in PROCESSOR_SDK_VISION_03_05_00_00/ti_components/os_tools/linux/kernel/omap/arch/arm/boot/dts/dra7-evm-infoadas.dts
    &ipu1 {
         timers= <&timer9> , <&timer11>;
        /delete-property/ watchdog-timers;
    &ipu2 {
    &dsp1 {
    &dsp2 {
    3. From vision_sdk/build folder, run these commands
            make linux_clean
            make clean
            rm -rf ../binaries
            rm -rf ../links_fw/include/config
            make linux
            make linux_install
            make -s -j depend
            make -s -j
    And it solved my problem. Thanks a lot for your timely support.
    Salman.
