DM355 - Filesystem partition
We need to create four filesystem partition in nand flash. In the davinci-dm355-evm.c two partitions are provided (filesystem1 and filesystem2). How to add support additional two partitions?. Is there any documentation available for this?.
Thanks in advance
Sarokbt
  • Unfortunately, I do not believe there is any documentation.  NAND flash partitions are typically defined in the NAND driver source code; you should have the kernel source code as a result of installing our DVSDK software for our DM355 EVM (assuming this is what you are using)
