TDA2EVM5777: TIDL: Semantic Segmentation, Video Frame is reversing, Cannot Obtain smooth video output
Part Number: TDA2EVM5777
Other Parts Discussed in Thread: INA226
    I am newbie in using this board, I have successfully converted my own dataset video into binary  file and obtained the result output in both TIDL_OD and TIDL_semantic Segementation. However, the only problem I am dealing with right is the back and forth of frames on the output result which I believe should give me smooth flow of 3fps atleast.Can anyone tell me how to fix this problem? Thank you.
With best regards,
Owais
  • Is the dtections are back and forth or the display is back and forth?
  • Hi Kumar, Thank you for your response. The detections are quite on the objects, however the problem is with video reading, I believe or may be the speed. The video frames are repeating back and forth and are displayed in a way that the person is walking forward, steps back and then move forward.Video is attached for better understanding. Thank you.
  • +Anuj
    This looks to be a Disply sync issue.
    Anuj Would help you on this
  • Hi Kumar,
    Can you raise the issue to Anuj or possibly some other guy who can help me figure out this thing as early as possible. I will be waiting for you response. Thank you.
    Owais
  • HI,
    Are you getting the same response in TIDL_OD usecase as well.
    Can you share your log of usecase after pressing 'p'.
    Anuj
  • Hi Anuj,
    Yes the response in TIDL_OD is same but more slower than segmentation. Here are the statistics of Semantic Segmentation:
    [IPU1-1] 1112.022570 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-1] 1112.022723 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 643328 B (628 KB)
    [HOST ] 1111.639480 s: IPC_IN_2 : Create in progress !!!
    [HOST ] 1111.639815 s: IPC_IN_2 : Create Done !!!
    [HOST ] 1111.639907 s: ALGORITHM: Create in progress (algId = 13) !!!
    [HOST ] 1111.641493 s: UTILS: DMA: Allocated CH (TCC) = 1 (1)
    [HOST ] 1111.641523 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 1 (0x43305620)
    [HOST ] 1111.641523 s: ALGORITHM: Create Done (algId = 13) !!!
    [HOST ] 1111.642377 s: IPC_IN_0 : Create in progress !!!
    [HOST ] 1111.642652 s: IPC_IN_0 : Create Done !!!
    [HOST ] 1111.642865 s: ALGORITHM: Create in progress (algId = 13) !!!
    [HOST ] 1111.644482 s: UTILS: DMA: Allocated CH (TCC) = 2 (2)
    [HOST ] 1111.644482 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 2 (0x43305640)
    [HOST ] 1111.644512 s: ALGORITHM: Create Done (algId = 13) !!!
    [HOST ] 1111.644573 s: IPC_OUT_4 : Create in progress !!!
    [HOST ] 1111.644604 s: IPC_OUT_4 : Create Done !!!
    [HOST ] 1112.023089 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [HOST ] 1112.023089 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6219336 B (6073 KB)
    [DSP1 ] 1112.023211 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [DSP1 ] 1112.023241 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP1 ] 1112.023272 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514544 B (502 KB)
    [DSP2 ] 1112.023394 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [DSP2 ] 1112.023424 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP2 ] 1112.023455 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514544 B (502 KB)
    [EVE1 ] 1111.637833 s: ALGORITHM: Create Done (algId = 14) !!!
    [EVE1 ] 1111.638626 s: IPC_OUT_0 : Create in progress !!!
    [EVE1 ] 1111.639083 s: IPC_OUT_0 : Create Done !!!
    [EVE1 ] 1112.023760 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE1 ] 1112.024034 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [EVE1 ] 1112.024522 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [EVE2 ] 1112.025346 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE2 ] 1112.025620 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [EVE2 ] 1112.026108 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [EVE3 ] 1112.026932 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE3 ] 1112.027206 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [EVE3 ] 1112.027664 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [EVE4 ] 1112.028518 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [EVE4 ] 1112.028792 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [EVE4 ] 1112.029250 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [IPU2 ] 1112.029951 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU2 ] 1112.030104 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250104 B (244 KB)
    [IPU1-0] 1146.425150 s:
    [IPU1-0] 1146.425242 s: CPU [IPU1-0 ] Statistics,
    [IPU1-0] 1146.425303 s: *************************
    [IPU1-0] 1146.425364 s:
    [IPU1-0] 1146.425425 s: LOAD: CPU: 10.2% HWI: 1.4%, SWI:0.7%, Low Power: 86.3%
    [IPU1-0] 1146.425577 s:
    [IPU1-0] 1146.425608 s: LOAD: TSK: DUP0 : 0.1%
    [IPU1-0] 1146.425730 s: LOAD: TSK: IPC_IN_0 : 0.1%
    [IPU1-0] 1146.425821 s: LOAD: TSK: IPC_OUT_0 : 0.2%
    [IPU1-0] 1146.425913 s: LOAD: TSK: IPC_OUT_1 : 0.2%
    [IPU1-0] 1146.426066 s: LOAD: TSK: NULL_SRC0 : 0.9%
    [IPU1-0] 1146.426188 s: LOAD: TSK: DISPLAY0 : 0.2%
    [IPU1-0] 1146.426279 s: LOAD: TSK: DEC0 : 0.2%
    [IPU1-0] 1146.426401 s: LOAD: TSK: GrpxSrc0 : 0.2%
    [IPU1-0] 1146.426523 s: LOAD: TSK: STAT_COLL : 3.6%
    [IPU1-0] 1146.426615 s: LOAD: TSK: DEC_PROCESS_TSK_0 : 17.5%
    [IPU1-0] 1146.426706 s: LOAD: TSK: MISC : -15.-1%
    [IPU1-0] 1146.426798 s:
    [IPU1-0] 1146.426828 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.426920 s:
    [IPU1-0] 1146.426981 s: SYSTEM: Sempahores Objects, 163 of 1050 free
    [IPU1-0] 1146.427072 s: SYSTEM: Task Objects , 16 of 100 free
    [IPU1-0] 1146.427164 s: SYSTEM: Clock Objects , 93 of 100 free
    [IPU1-0] 1146.427255 s: SYSTEM: Hwi Objects , 89 of 100 free
    [IPU1-0] 1146.427347 s:
    [IPU1-0] 1146.427377 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 246248 B (240 KB)
    [IPU1-0] 1146.427560 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1-0] 1146.427713 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x89d03000, Total size = 366989312 B (349 MB), Free size = 133486592 B (127 MB)
    [IPU1-0] 1146.427865 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfb00000, Total size = 127360 B (0 MB), Free size = 92800 B (0 MB)
    [IPU1-0] 1146.428048 s:
    [IPU1-0] 1146.428109 s:
    [IPU1-0] 1146.428140 s: CPU [IPU1-1 ] Statistics,
    [IPU1-0] 1146.428201 s: *************************
    [IPU1-0] 1146.428262 s:
    [IPU1-0] 1146.428323 s: LOAD: CPU: 1.4% HWI: 0.7%, SWI:0.5%, Low Power: 85.1%
    [IPU1-0] 1146.428445 s:
    [IPU1-0] 1146.428567 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.428658 s:
    [IPU1-0] 1146.428689 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.428780 s:
    [IPU1-0] 1146.428811 s: SYSTEM: Sempahores Objects, 435 of 1050 free
    [IPU1-0] 1146.428902 s: SYSTEM: Task Objects , 38 of 100 free
    [IPU1-0] 1146.429024 s: SYSTEM: Clock Objects , 99 of 100 free
    [IPU1-0] 1146.429116 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.429177 s:
    [IPU1-0] 1146.429238 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 643328 B (628 KB)
    [IPU1-0] 1146.429390 s:
    [IPU1-0] 1146.429451 s:
    [IPU1-0] 1146.429482 s: CPU [HOST ] Statistics,
    [IPU1-0] 1146.429543 s: *************************
    [IPU1-0] 1146.429604 s:
    [IPU1-0] 1146.429634 s: LOAD: CPU: 19.3% HWI: 0.1%, SWI:0.1%, Low Power: 80.1%
    [IPU1-0] 1146.429787 s:
    [IPU1-0] 1146.429909 s: LOAD: TSK: MISC : 19.1%
    [IPU1-0] 1146.430183 s:
    [IPU1-0] 1146.430244 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.430336 s:
    [IPU1-0] 1146.430366 s: SYSTEM: Sempahores Objects, 423 of 1050 free
    [IPU1-0] 1146.430458 s: SYSTEM: Task Objects , 38 of 100 free
    [IPU1-0] 1146.430549 s: SYSTEM: Clock Objects , 87 of 100 free
    [IPU1-0] 1146.430641 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.430732 s:
    [IPU1-0] 1146.430763 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6219336 B (6073 KB)
    [IPU1-0] 1146.430915 s:
    [IPU1-0] 1146.431007 s:
    [IPU1-0] 1146.431037 s: CPU [DSP1 ] Statistics,
    [IPU1-0] 1146.431098 s: *************************
    [IPU1-0] 1146.431159 s:
    [IPU1-0] 1146.431220 s: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%, Low Power: 98.2%
    [IPU1-0] 1146.431373 s:
    [IPU1-0] 1146.431403 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.431495 s:
    [IPU1-0] 1146.431556 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.431617 s:
    [IPU1-0] 1146.431678 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.431769 s: SYSTEM: Task Objects , 91 of 100 free
    [IPU1-0] 1146.431830 s: SYSTEM: Clock Objects , 99 of 100 free
    [IPU1-0] 1146.431952 s: SYSTEM: Hwi Objects , 100 of 100 free
    [IPU1-0] 1146.432044 s:
    [IPU1-0] 1146.432074 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0] 1146.432257 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514544 B (502 KB)
    [IPU1-0] 1146.432410 s:
    [IPU1-0] 1146.432440 s:
    [IPU1-0] 1146.432501 s: CPU [DSP2 ] Statistics,
    [IPU1-0] 1146.432562 s: *************************
    [IPU1-0] 1146.432623 s:
    [IPU1-0] 1146.432654 s: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%, Low Power: 98.5%
    [IPU1-0] 1146.432806 s:
    [IPU1-0] 1146.432867 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.432959 s:
    [IPU1-0] 1146.433020 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.433111 s:
    [IPU1-0] 1146.433142 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.433264 s: SYSTEM: Task Objects , 91 of 100 free
    [IPU1-0] 1146.433416 s: SYSTEM: Clock Objects , 99 of 100 free
    [IPU1-0] 1146.433538 s: SYSTEM: Hwi Objects , 100 of 100 free
    [IPU1-0] 1146.433660 s:
    [IPU1-0] 1146.433721 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1-0] 1146.434057 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 514544 B (502 KB)
    [IPU1-0] 1146.434240 s:
    [IPU1-0] 1146.434270 s:
    [IPU1-0] 1146.434331 s: CPU [EVE1 ] Statistics,
    [IPU1-0] 1146.434392 s: *************************
    [IPU1-0] 1146.434453 s:
    [IPU1-0] 1146.434514 s: LOAD: CPU: 82.5% HWI: 0.3%, SWI:0.2%, Low Power: 16.2%
    [IPU1-0] 1146.434667 s:
    [IPU1-0] 1146.434728 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 81.8%
    [IPU1-0] 1146.434850 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.435185 s:
    [IPU1-0] 1146.435277 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.435399 s:
    [IPU1-0] 1146.435429 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.435551 s: SYSTEM: Task Objects , 92 of 100 free
    [IPU1-0] 1146.435643 s: SYSTEM: Clock Objects , 97 of 100 free
    [IPU1-0] 1146.435734 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.435826 s:
    [IPU1-0] 1146.435887 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [IPU1-0] 1146.436100 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [IPU1-0] 1146.436283 s:
    [IPU1-0] 1146.436344 s:
    [IPU1-0] 1146.436405 s: CPU [EVE2 ] Statistics,
    [IPU1-0] 1146.436497 s: *************************
    [IPU1-0] 1146.436558 s:
    [IPU1-0] 1146.436619 s: LOAD: CPU: 82.7% HWI: 0.4%, SWI:0.2%, Low Power: 15.1%
    [IPU1-0] 1146.436771 s:
    [IPU1-0] 1146.436832 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 81.9%
    [IPU1-0] 1146.436985 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.437076 s:
    [IPU1-0] 1146.437137 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.437229 s:
    [IPU1-0] 1146.437290 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.437381 s: SYSTEM: Task Objects , 92 of 100 free
    [IPU1-0] 1146.437503 s: SYSTEM: Clock Objects , 97 of 100 free
    [IPU1-0] 1146.437595 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.437686 s:
    [IPU1-0] 1146.437747 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [IPU1-0] 1146.437991 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [IPU1-0] 1146.438235 s:
    [IPU1-0] 1146.438327 s:
    [IPU1-0] 1146.438357 s: CPU [EVE3 ] Statistics,
    [IPU1-0] 1146.438449 s: *************************
    [IPU1-0] 1146.438510 s:
    [IPU1-0] 1146.438601 s: LOAD: CPU: 82.3% HWI: 0.3%, SWI:0.2%, Low Power: 15.7%
    [IPU1-0] 1146.438723 s:
    [IPU1-0] 1146.438784 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 81.6%
    [IPU1-0] 1146.438906 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.439089 s:
    [IPU1-0] 1146.439150 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.439242 s:
    [IPU1-0] 1146.439303 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.439394 s: SYSTEM: Task Objects , 92 of 100 free
    [IPU1-0] 1146.439486 s: SYSTEM: Clock Objects , 97 of 100 free
    [IPU1-0] 1146.439547 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.439638 s:
    [IPU1-0] 1146.439699 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [IPU1-0] 1146.439852 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [IPU1-0] 1146.440279 s:
    [IPU1-0] 1146.440340 s:
    [IPU1-0] 1146.440401 s: CPU [EVE4 ] Statistics,
    [IPU1-0] 1146.440462 s: *************************
    [IPU1-0] 1146.440523 s:
    [IPU1-0] 1146.440553 s: LOAD: CPU: 82.5% HWI: 0.4%, SWI:0.2%, Low Power: 15.9%
    [IPU1-0] 1146.440706 s:
    [IPU1-0] 1146.440767 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 81.7%
    [IPU1-0] 1146.440889 s: LOAD: TSK: MISC : 0.2%
    [IPU1-0] 1146.441011 s:
    [IPU1-0] 1146.441041 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.441163 s:
    [IPU1-0] 1146.441194 s: SYSTEM: Sempahores Objects, 449 of 1050 free
    [IPU1-0] 1146.441285 s: SYSTEM: Task Objects , 92 of 100 free
    [IPU1-0] 1146.441377 s: SYSTEM: Clock Objects , 97 of 100 free
    [IPU1-0] 1146.441499 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.441590 s:
    [IPU1-0] 1146.441621 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [IPU1-0] 1146.441804 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 235632 B (230 KB)
    [IPU1-0] 1146.441987 s:
    [IPU1-0] 1146.442048 s:
    [IPU1-0] 1146.442078 s: CPU [IPU2 ] Statistics,
    [IPU1-0] 1146.442170 s: *************************
    [IPU1-0] 1146.442231 s:
    [IPU1-0] 1146.442261 s: LOAD: CPU: 0.9% HWI: 0.5%, SWI:0.3%, Low Power: 96.9%
    [IPU1-0] 1146.442444 s:
    [IPU1-0] 1146.442566 s: LOAD: TSK: MISC : 0.1%
    [IPU1-0] 1146.442658 s:
    [IPU1-0] 1146.442688 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-0] 1146.442780 s:
    [IPU1-0] 1146.442841 s: SYSTEM: Sempahores Objects, 442 of 1050 free
    [IPU1-0] 1146.442963 s: SYSTEM: Task Objects , 39 of 100 free
    [IPU1-0] 1146.443085 s: SYSTEM: Clock Objects , 99 of 100 free
    [IPU1-0] 1146.443176 s: SYSTEM: Hwi Objects , 99 of 100 free
    [IPU1-0] 1146.443268 s:
    [IPU1-0] 1146.443298 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 250104 B (244 KB)
    [IPU1-0] 1146.443481 s:
    [IPU1-0] 1146.443847 s:
    [IPU1-0] 1146.443908 s: UTILS_PRCM_STATS: Current Temperature,
    [IPU1-0] 1146.444030 s:
    [IPU1-0] 1146.444091 s: Voltage Rail || Curr Temp Min - Max
    [IPU1-0] 1146.444183 s: ---------------------------------------------------------
    [IPU1-0] 1146.444305 s: PMHAL_PRCM_VD_MPU || [57.600 , 58. 0]
    [IPU1-0] 1146.444396 s: PMHAL_PRCM_VD_CORE || [56.800 , 57.200]
    [IPU1-0] 1146.444519 s: PMHAL_PRCM_VD_IVAHD || [57.200 , 57.600]
    [IPU1-0] 1146.444641 s: PMHAL_PRCM_VD_DSPEVE || [55.600 , 56.200]
    [IPU1-0] 1146.444763 s: PMHAL_PRCM_VD_GPU || [56.800 , 57.200]
    [IPU1-0] 1146.444885 s:
    [IPU1-0] 1146.444915 s: ============================================================================
    [IPU1-0] 1146.445312 s: Name | Bus (mV) | Res (mOhm) | Shunt (uV) | Current (mA) | Power (mW)
    [IPU1-0] 1146.445525 s: ----------------------------------------------------------------------------
    [IPU1-0] 1146.450893 s: UTILS_PRCM_STATS: Reading the regulator data failed
    [IPU1-0] 1146.451015 s: UTILS_PRCM_STATS: PM INA226 Power Read Failed !!
    [IPU1-0] 1146.451473 s:
    [IPU1-0] 1146.451534 s: Statistics Collector,
    [IPU1-0] 1146.451595 s:
    [IPU1-0] 1146.451625 s: STATISTIC Avg Data Peak Data
    [IPU1-0] 1146.451717 s: COLLECTOR MB/s MB/s
    [IPU1-0] 1146.451839 s: --------------------------------------------------
    [IPU1-0] 1146.451991 s: SCI_EMIF1 RD+WR | 1456.839323 2354.908801
    [IPU1-0] 1146.452144 s: SCI_EMIF2 RD+WR | 0.000000 0.000000
    [IPU1-0] 1146.452266 s: SCI_EMIF1 RD ONLY | 959.021302 1817.088813
    [IPU1-0] 1146.452388 s: SCI_EMIF1 WR ONLY | 498.171086 1050.471440
    [IPU1-0] 1146.452510 s: SCI_EMIF2 RD ONLY | 0.000000 0.000000
    [IPU1-0] 1146.452632 s: SCI_EMIF2 WR ONLY | 0.000000 0.000000
    [IPU1-0] 1146.452723 s: SCI_MA_MPU_P1 | 61.288773 439.724910
    [IPU1-0] 1146.452845 s: SCI_MA_MPU_P2 | 0.000000 0.000000
    [IPU1-0] 1146.453028 s: SCI_DSS | 104.162180 210.471095
    [IPU1-0] 1146.453150 s: SCI_IPU1 | 8.108492 28.892982
    [IPU1-0] 1146.453272 s: SCI_VIP1_P1 | 0.000000 0.000000
    [IPU1-0] 1146.453394 s: SCI_VIP1_P2 | 0.000000 0.000000
    [IPU1-0] 1146.453516 s: SCI_VPE_P1 | 0.000000 0.000000
    [IPU1-0] 1146.453608 s: SCI_VPE_P2 | 0.000000 0.000000
    [IPU1-0] 1146.453730 s: SCI_DSP1_MDMA | 0.071889 0.888888
    [IPU1-0] 1146.453852 s: SCI_DSP1_EDMA | 0.000000 0.000000
    [IPU1-0] 1146.454004 s: SCI_DSP2_MDMA | 0.071889 0.888888
    [IPU1-0] 1146.454157 s: SCI_DSP2_EDMA | 0.000000 0.000000
    [IPU1-0] 1146.454279 s: SCI_EVE1_TC0 | 305.677637 1375.709573
    [IPU1-0] 1146.454431 s: SCI_EVE1_TC1 | 566.666269 1384.028788
    [IPU1-0] 1146.454553 s: SCI_EVE2_TC0 | 306.652289 1429.610619
    [IPU1-0] 1146.454675 s: SCI_EVE2_TC1 | 565.393966 1462.944489
    [IPU1-0] 1146.454797 s: SCI_EDMA_TC0_RD | 0.000000 0.000000
    [IPU1-0] 1146.454919 s: SCI_EDMA_TC0_WR | 0.000000 0.000000
    [IPU1-0] 1146.455285 s: SCI_EDMA_TC1_RD | 9.582287 159.164541
    [IPU1-0] 1146.455529 s: SCI_EDMA_TC1_WR | 9.585713 159.164541
    [IPU1-0] 1146.455804 s: SCI_VIP2_P1 | 0.000000 0.000000
    [IPU1-0] 1146.455987 s: SCI_VIP2_P2 | 0.000000 0.000000
    [IPU1-0] 1146.456139 s: SCI_VIP3_P1 | 0.000000 0.000000
    [IPU1-0] 1146.456261 s: SCI_VIP3_P2 | 0.000000 0.000000
    [IPU1-0] 1146.456383 s: SCI_EVE3_TC0 | 306.896866 1419.514691
    [IPU1-0] 1146.456505 s: SCI_EVE3_TC1 | 564.116870 1407.782487
    [IPU1-0] 1146.456658 s: SCI_EVE4_TC0 | 305.107962 1348.916413
    [IPU1-0] 1146.456810 s: SCI_EVE4_TC1 | 561.784150 1400.273531
    [IPU1-0] 1146.456963 s: SCI_IVA | 72.388267 1367.690490
    [IPU1-0] 1146.457115 s: SCI_GPU_P1 | 0.000000 0.000000
    [IPU1-0] 1146.457237 s: SCI_GPU_P2 | 0.000000 0.000000
    [IPU1-0] 1146.457359 s: SCI_GMAC_SW | 0.000000 0.000000
    [IPU1-0] 1146.457481 s: SCI_OCMC_RAM1 | 560.110195 1408.982007
    [IPU1-0] 1146.457603 s: SCI_OCMC_RAM2 | 557.734300 1402.051488
    [IPU1-0] 1146.457756 s: SCI_OCMC_RAM3 | 1123.034851 2221.667989
    [IPU1-0] 1146.557982 s:
    [IPU1-0] 1146.558043 s:
    [IPU1-0] 1146.558165 s:
    [IPU1-0] 1146.558226 s: ### CPU [IPU1-0], LinkID [ 57],
    [IPU1-0] 1146.558317 s:
    [IPU1-0] 1146.558348 s: [ NULL_SRC ] Link Statistics,
    [IPU1-0] 1146.558409 s: ******************************
    [IPU1-0] 1146.558500 s:
    [IPU1-0] 1146.558531 s: Elapsed time = 34429 msec
    [IPU1-0] 1146.558592 s:
    [IPU1-0] 1146.558653 s: New data Recv = 12.5 fps
    [IPU1-0] 1146.558714 s: Get Full Buf Cb = 12.5 fps
    [IPU1-0] 1146.558805 s: Put Empty Buf Cb = 12.5 fps
    [IPU1-0] 1146.558866 s: Driver/Notify Cb = 12.2 fps
    [IPU1-0] 1146.558988 s:
    [IPU1-0] 1146.559019 s: Input Statistics,
    [IPU1-0] 1146.559080 s:
    [IPU1-0] 1146.559110 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1146.559202 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1146.559293 s: --------------------------------------------------
    [IPU1-0] 1146.559385 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1146.559507 s:
    [IPU1-0] 1146.559568 s: Output Statistics,
    [IPU1-0] 1146.559629 s:
    [IPU1-0] 1146.559659 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1146.559751 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1146.559812 s: ---------------------------------------------
    [IPU1-0] 1146.559903 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1146.560239 s:
    [IPU1-0] 1146.560300 s: [ NULL_SRC ] LATENCY,
    [IPU1-0] 1146.560361 s: ********************
    [IPU1-0] 1146.560422 s:
    [IPU1-0] 1146.560574 s:
    [IPU1-0] 1146.560635 s: ### CPU [IPU1-0], LinkID [ 82],
    [IPU1-0] 1146.560696 s:
    [IPU1-0] 1146.560757 s: [ DECODE ] Link Statistics,
    [IPU1-0] 1146.560818 s: ******************************
    [IPU1-0] 1146.560879 s:
    [IPU1-0] 1146.560910 s: Elapsed time = 34414 msec
    [IPU1-0] 1146.561001 s:
    [IPU1-0] 1146.561062 s: New data Recv = 12.5 fps
    [IPU1-0] 1146.561123 s: Release data Recv = 12.5 fps
    [IPU1-0] 1146.561215 s: Get Full Buf Cb = 24.11 fps
    [IPU1-0] 1146.561276 s: Put Empty Buf Cb = 12.5 fps
    [IPU1-0] 1146.561367 s:
    [IPU1-0] 1146.561398 s: Input Statistics,
    [IPU1-0] 1146.561459 s:
    [IPU1-0] 1146.561489 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1146.561581 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1146.561672 s: --------------------------------------------------
    [IPU1-0] 1146.561733 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1146.561886 s:
    [IPU1-0] 1146.561916 s: Output Statistics,
    [IPU1-0] 1146.561977 s:
    [IPU1-0] 1146.562038 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1146.562099 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1146.562191 s: ---------------------------------------------
    [IPU1-0] 1146.562252 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1146.562374 s:
    [IPU1-0] 1146.562435 s: [ DECODE ] LATENCY,
    [IPU1-0] 1146.562496 s: ********************
    [IPU1-0] 1146.562526 s: Local Link Latency : Avg = 4856 us, Min = 3782 us, Max = 5825 us,
    [IPU1-0] 1146.562648 s: Source to Link Latency : Avg = 4984 us, Min = 3934 us, Max = 5917 us,
    [IPU1-0] 1146.562831 s:
    [IPU1-0] 1146.562923 s: CPU [ IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1-0] 1146.563136 s:
    [IPU1-0] 1146.563167 s: ### CPU [IPU1-0], LinkID [ 1],
    [IPU1-0] 1146.563258 s:
    [IPU1-0] 1146.563289 s: [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0] 1146.563380 s: ******************************
    [IPU1-0] 1146.563441 s:
    [IPU1-0] 1146.563472 s: Elapsed time = 34412 msec
    [IPU1-0] 1146.563533 s:
    [IPU1-0] 1146.563594 s: New data Recv = 12.5 fps
    [IPU1-0] 1146.563655 s: Release data Recv = 12.5 fps
    [IPU1-0] 1146.563746 s: Driver/Notify Cb = 45.39 fps
    [IPU1-0] 1146.563807 s:
    [IPU1-0] 1146.563868 s: Input Statistics,
    [IPU1-0] 1146.563899 s:
    [IPU1-0] 1146.563960 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1146.564051 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1146.564143 s: --------------------------------------------------
    [IPU1-0] 1146.564204 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1146.564356 s:
    [IPU1-0] 1146.564387 s: Output Statistics,
    [IPU1-0] 1146.564448 s:
    [IPU1-0] 1146.564478 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1146.564570 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1146.564631 s: ---------------------------------------------
    [IPU1-0] 1146.564722 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1146.564844 s:
    [IPU1-0] 1146.564875 s: [ IPC_OUT_1 ] LATENCY,
    [IPU1-0] 1146.565149 s: ********************
    [IPU1-0] 1146.565210 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 92 us,
    [IPU1-0] 1146.565332 s: Source to Link Latency : Avg = 5315 us, Min = 4301 us, Max = 6253 us,
    [IPU1-0] 1146.565454 s:
    [IPU1-0] 1147.065241 s:
    [IPU1-0] 1147.065302 s: ### CPU [ HOST], LinkID [ 11],
    [IPU1-0] 1147.065393 s:
    [IPU1-0] 1147.065424 s: [ IPC_IN_1 ] Link Statistics,
    [IPU1-0] 1147.065485 s: ******************************
    [IPU1-0] 1147.065546 s:
    [IPU1-0] 1147.065607 s: Elapsed time = 34914 msec
    [IPU1-0] 1147.065668 s:
    [IPU1-0] 1147.065698 s: Get Full Buf Cb = 12.5 fps
    [IPU1-0] 1147.065790 s: Put Empty Buf Cb = 12.5 fps
    [IPU1-0] 1147.065851 s: Driver/Notify Cb = 45.36 fps
    [IPU1-0] 1147.065942 s:
    [IPU1-0] 1147.066003 s: Input Statistics,
    [IPU1-0] 1147.066064 s:
    [IPU1-0] 1147.066125 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.066186 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.066278 s: --------------------------------------------------
    [IPU1-0] 1147.066369 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1147.066491 s:
    [IPU1-0] 1147.066522 s: Output Statistics,
    [IPU1-0] 1147.066583 s:
    [IPU1-0] 1147.066674 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.066766 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.066827 s: ---------------------------------------------
    [IPU1-0] 1147.066918 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1147.067040 s:
    [IPU1-0] 1147.067101 s: [ IPC_IN_1 ] LATENCY,
    [IPU1-0] 1147.067162 s: ********************
    [IPU1-0] 1147.067223 s: Local Link Latency : Avg = 5 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1147.067345 s: Source to Link Latency : Avg = 5380 us, Min = 4362 us, Max = 6314 us,
    [IPU1-0] 1147.067437 s:
    [IPU1-0] 1147.067559 s:
    [IPU1-0] 1147.067589 s: ### CPU [ HOST], LinkID [ 49],
    [IPU1-0] 1147.067681 s:
    [IPU1-0] 1147.067711 s: [ ALG_TIDLPREPROC ] Link Statistics,
    [IPU1-0] 1147.067803 s: ******************************
    [IPU1-0] 1147.067864 s:
    [IPU1-0] 1147.067894 s: Elapsed time = 34916 msec
    [IPU1-0] 1147.067986 s:
    [IPU1-0] 1147.068047 s: New data Recv = 12.5 fps
    [IPU1-0] 1147.068108 s:
    [IPU1-0] 1147.068169 s: Input Statistics,
    [IPU1-0] 1147.068230 s:
    [IPU1-0] 1147.068260 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.068321 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.068413 s: --------------------------------------------------
    [IPU1-0] 1147.068504 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1147.068626 s:
    [IPU1-0] 1147.068657 s: Output Statistics,
    [IPU1-0] 1147.068718 s:
    [IPU1-0] 1147.068779 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.068870 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.068931 s: ---------------------------------------------
    [IPU1-0] 1147.069053 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1147.069206 s:
    [IPU1-0] 1147.069236 s: [ ALG_TIDLPREPROC ] LATENCY,
    [IPU1-0] 1147.069297 s: ********************
    [IPU1-0] 1147.069358 s: Local Link Latency : Avg = 358 us, Min = 244 us, Max = 1433 us,
    [IPU1-0] 1147.069511 s: Source to Link Latency : Avg = 19846 us, Min = 18636 us, Max = 21656 us,
    [IPU1-0] 1147.069633 s:
    [IPU1-0] 1147.069785 s:
    [IPU1-0] 1147.069846 s: ### CPU [ HOST], LinkID [ 3],
    [IPU1-0] 1147.069907 s:
    [IPU1-0] 1147.070182 s: [ IPC_OUT_3 ] Link Statistics,
    [IPU1-0] 1147.070304 s: ******************************
    [IPU1-0] 1147.070365 s:
    [IPU1-0] 1147.070395 s: Elapsed time = 34665 msec
    [IPU1-0] 1147.070487 s:
    [IPU1-0] 1147.070517 s: New data Recv = 3.2 fps
    [IPU1-0] 1147.070609 s: Release data Recv = 3.0 fps
    [IPU1-0] 1147.070670 s: Driver/Notify Cb = 36.34 fps
    [IPU1-0] 1147.070761 s:
    [IPU1-0] 1147.070792 s: Input Statistics,
    [IPU1-0] 1147.070853 s:
    [IPU1-0] 1147.070914 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.071005 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.071097 s: --------------------------------------------------
    [IPU1-0] 1147.071188 s: 0 | 3. 2 0. 0 0. 0 3. 2
    [IPU1-0] 1147.071310 s:
    [IPU1-0] 1147.071341 s: Output Statistics,
    [IPU1-0] 1147.071402 s:
    [IPU1-0] 1147.071432 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.071524 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.071585 s: ---------------------------------------------
    [IPU1-0] 1147.071676 s: 0 | 0 3. 2 0. 0 0. 0
    [IPU1-0] 1147.071798 s:
    [IPU1-0] 1147.071859 s: [ IPC_OUT_3 ] LATENCY,
    [IPU1-0] 1147.071920 s: ********************
    [IPU1-0] 1147.072195 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1147.072347 s: Source to Link Latency : Avg = 20048 us, Min = 18788 us, Max = 21594 us,
    [IPU1-0] 1147.072469 s:
    [IPU1-0] 1147.572134 s:
    [IPU1-0] 1147.572195 s: ### CPU [ EVE4], LinkID [ 10],
    [IPU1-0] 1147.572286 s:
    [IPU1-0] 1147.572317 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1147.572378 s: ******************************
    [IPU1-0] 1147.572439 s:
    [IPU1-0] 1147.572469 s: Elapsed time = 35167 msec
    [IPU1-0] 1147.572561 s:
    [IPU1-0] 1147.572591 s: Get Full Buf Cb = 6.2 fps
    [IPU1-0] 1147.572683 s: Put Empty Buf Cb = 3.1 fps
    [IPU1-0] 1147.572744 s: Driver/Notify Cb = 6.31 fps
    [IPU1-0] 1147.572835 s:
    [IPU1-0] 1147.572866 s: Input Statistics,
    [IPU1-0] 1147.572927 s:
    [IPU1-0] 1147.572957 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.573079 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.573171 s: --------------------------------------------------
    [IPU1-0] 1147.573232 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1147.573354 s:
    [IPU1-0] 1147.573415 s: Output Statistics,
    [IPU1-0] 1147.573445 s:
    [IPU1-0] 1147.573506 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.573567 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.573659 s: ---------------------------------------------
    [IPU1-0] 1147.573720 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1147.573842 s:
    [IPU1-0] 1147.573872 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1147.573933 s: ********************
    [IPU1-0] 1147.574025 s: Local Link Latency : Avg = 31 us, Min = 0 us, Max = 92 us,
    [IPU1-0] 1147.574147 s: Source to Link Latency : Avg = 20335 us, Min = 19063 us, Max = 21869 us,
    [IPU1-0] 1147.574269 s:
    [IPU1-0] 1147.574361 s:
    [IPU1-0] 1147.574422 s: ### CPU [ EVE4], LinkID [ 49],
    [IPU1-0] 1147.574574 s:
    [IPU1-0] 1147.574605 s: [ ALG_TIDL ] Link Statistics,
    [IPU1-0] 1147.574666 s: ******************************
    [IPU1-0] 1147.574727 s:
    [IPU1-0] 1147.574788 s: Elapsed time = 35169 msec
    [IPU1-0] 1147.574849 s:
    [IPU1-0] 1147.574879 s: New data Recv = 6.2 fps
    [IPU1-0] 1147.574971 s:
    [IPU1-0] 1147.575520 s: Input Statistics,
    [IPU1-0] 1147.575581 s:
    [IPU1-0] 1147.575642 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.575703 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.575794 s: --------------------------------------------------
    [IPU1-0] 1147.575886 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1147.576282 s:
    [IPU1-0] 1147.576343 s: Output Statistics,
    [IPU1-0] 1147.576374 s:
    [IPU1-0] 1147.576435 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.576496 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.576587 s: ---------------------------------------------
    [IPU1-0] 1147.576648 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1147.576770 s:
    [IPU1-0] 1147.577014 s: [ ALG_TIDL ] LATENCY,
    [IPU1-0] 1147.577106 s: ********************
    [IPU1-0] 1147.577167 s: Local Link Latency : Avg = 275337 us, Min = 274325 us, Max = 276734 us,
    [IPU1-0] 1147.577289 s: Source to Link Latency : Avg = 295835 us, Min = 294150 us, Max = 297779 us,
    [IPU1-0] 1147.577411 s:
    [IPU1-0] 1147.577716 s:
    [IPU1-0] 1147.577777 s: ### CPU [ EVE4], LinkID [ 0],
    [IPU1-0] 1147.578448 s:
    [IPU1-0] 1147.578539 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1147.578600 s: ******************************
    [IPU1-0] 1147.578692 s:
    [IPU1-0] 1147.578753 s: Elapsed time = 34897 msec
    [IPU1-0] 1147.578844 s:
    [IPU1-0] 1147.578905 s: New data Recv = 3.3 fps
    [IPU1-0] 1147.579119 s: Release data Recv = 3.3 fps
    [IPU1-0] 1147.579210 s: Driver/Notify Cb = 6.36 fps
    [IPU1-0] 1147.579332 s:
    [IPU1-0] 1147.579363 s: Input Statistics,
    [IPU1-0] 1147.579424 s:
    [IPU1-0] 1147.579485 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1147.579576 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1147.579668 s: --------------------------------------------------
    [IPU1-0] 1147.579790 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1147.579942 s:
    [IPU1-0] 1147.580339 s: Output Statistics,
    [IPU1-0] 1147.580430 s:
    [IPU1-0] 1147.580461 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1147.580552 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1147.580674 s: ---------------------------------------------
    [IPU1-0] 1147.580766 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1147.580888 s:
    [IPU1-0] 1147.580949 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1147.581101 s: ********************
    [IPU1-0] 1147.581193 s: Local Link Latency : Avg = 24 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1147.581345 s: Source to Link Latency : Avg = 296101 us, Min = 294394 us, Max = 298054 us,
    [IPU1-0] 1147.581467 s:
    [IPU1-0] 1148.081284 s:
    [IPU1-0] 1148.081345 s: ### CPU [ HOST], LinkID [ 15],
    [IPU1-0] 1148.081437 s:
    [IPU1-0] 1148.081498 s: [ IPC_IN_5 ] Link Statistics,
    [IPU1-0] 1148.081559 s: ******************************
    [IPU1-0] 1148.081620 s:
    [IPU1-0] 1148.081681 s: Elapsed time = 35400 msec
    [IPU1-0] 1148.081742 s:
    [IPU1-0] 1148.081803 s: Get Full Buf Cb = 12.6 fps
    [IPU1-0] 1148.081894 s: Put Empty Buf Cb = 3.2 fps
    [IPU1-0] 1148.081955 s: Driver/Notify Cb = 36.32 fps
    [IPU1-0] 1148.082077 s:
    [IPU1-0] 1148.082108 s: Input Statistics,
    [IPU1-0] 1148.082169 s:
    [IPU1-0] 1148.082199 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1148.082291 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1148.082382 s: --------------------------------------------------
    [IPU1-0] 1148.082474 s: 0 | 3. 2 0. 0 0. 0 3. 2
    [IPU1-0] 1148.082596 s:
    [IPU1-0] 1148.082626 s: Output Statistics,
    [IPU1-0] 1148.082687 s:
    [IPU1-0] 1148.082718 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1148.082809 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1148.082901 s: ---------------------------------------------
    [IPU1-0] 1148.082962 s: 0 | 0 3. 2 0. 0 0. 0
    [IPU1-0] 1148.083114 s:
    [IPU1-0] 1148.083145 s: [ IPC_IN_5 ] LATENCY,
    [IPU1-0] 1148.083206 s: ********************
    [IPU1-0] 1148.083267 s: Local Link Latency : Avg = 4 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1148.083389 s: Source to Link Latency : Avg = 296212 us, Min = 294516 us, Max = 298145 us,
    [IPU1-0] 1148.083511 s:
    [IPU1-0] 1148.083633 s:
    [IPU1-0] 1148.083663 s: ### CPU [ HOST], LinkID [ 2],
    [IPU1-0] 1148.083755 s:
    [IPU1-0] 1148.083785 s: [ IPC_OUT_2 ] Link Statistics,
    [IPU1-0] 1148.083877 s: ******************************
    [IPU1-0] 1148.083938 s:
    [IPU1-0] 1148.083968 s: Elapsed time = 35765 msec
    [IPU1-0] 1148.084060 s:
    [IPU1-0] 1148.084121 s: New data Recv = 3.1 fps
    [IPU1-0] 1148.084182 s: Release data Recv = 2.99 fps
    [IPU1-0] 1148.084273 s: Driver/Notify Cb = 36.32 fps
    [IPU1-0] 1148.084334 s:
    [IPU1-0] 1148.084395 s: Input Statistics,
    [IPU1-0] 1148.084456 s:
    [IPU1-0] 1148.084487 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1148.084578 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1148.084670 s: --------------------------------------------------
    [IPU1-0] 1148.084761 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1148.084883 s:
    [IPU1-0] 1148.084914 s: Output Statistics,
    [IPU1-0] 1148.085249 s:
    [IPU1-0] 1148.085280 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1148.085371 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1148.085432 s: ---------------------------------------------
    [IPU1-0] 1148.085524 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1148.085707 s:
    [IPU1-0] 1148.085768 s: [ IPC_OUT_2 ] LATENCY,
    [IPU1-0] 1148.085829 s: ********************
    [IPU1-0] 1148.085890 s: Local Link Latency : Avg = 0 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1148.086042 s: Source to Link Latency : Avg = 19652 us, Min = 18666 us, Max = 21289 us,
    [IPU1-0] 1148.086164 s:
    [IPU1-0] 1148.586103 s:
    [IPU1-0] 1148.586195 s: ### CPU [ EVE3], LinkID [ 10],
    [IPU1-0] 1148.586256 s:
    [IPU1-0] 1148.586317 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1148.586378 s: ******************************
    [IPU1-0] 1148.586439 s:
    [IPU1-0] 1148.586469 s: Elapsed time = 36268 msec
    [IPU1-0] 1148.586561 s:
    [IPU1-0] 1148.586591 s: Get Full Buf Cb = 6.3 fps
    [IPU1-0] 1148.586683 s: Put Empty Buf Cb = 3.0 fps
    [IPU1-0] 1148.586744 s: Driver/Notify Cb = 6.34 fps
    [IPU1-0] 1148.586835 s:
    [IPU1-0] 1148.586866 s: Input Statistics,
    [IPU1-0] 1148.586927 s:
    [IPU1-0] 1148.586957 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1148.587079 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1148.587171 s: --------------------------------------------------
    [IPU1-0] 1148.587262 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1148.587384 s:
    [IPU1-0] 1148.587415 s: Output Statistics,
    [IPU1-0] 1148.587476 s:
    [IPU1-0] 1148.587506 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1148.587598 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1148.587659 s: ---------------------------------------------
    [IPU1-0] 1148.587750 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1148.587964 s:
    [IPU1-0] 1148.588025 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1148.588086 s: ********************
    [IPU1-0] 1148.588147 s: Local Link Latency : Avg = 32 us, Min = 0 us, Max = 61 us,
    [IPU1-0] 1148.588269 s: Source to Link Latency : Avg = 19937 us, Min = 18910 us, Max = 21564 us,
    [IPU1-0] 1148.588391 s:
    [IPU1-0] 1148.588513 s:
    [IPU1-0] 1148.588543 s: ### CPU [ EVE3], LinkID [ 49],
    [IPU1-0] 1148.588635 s:
    [IPU1-0] 1148.588665 s: [ ALG_TIDL ] Link Statistics,
    [IPU1-0] 1148.588726 s: ******************************
    [IPU1-0] 1148.588787 s:
    [IPU1-0] 1148.588848 s: Elapsed time = 36269 msec
    [IPU1-0] 1148.588909 s:
    [IPU1-0] 1148.588940 s: New data Recv = 6.3 fps
    [IPU1-0] 1148.589031 s:
    [IPU1-0] 1148.589092 s: Input Statistics,
    [IPU1-0] 1148.589153 s:
    [IPU1-0] 1148.589184 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1148.589275 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1148.589336 s: --------------------------------------------------
    [IPU1-0] 1148.589428 s: 0 | 3. 3 0. 0 0. 0 3. 0
    [IPU1-0] 1148.589550 s:
    [IPU1-0] 1148.589580 s: Output Statistics,
    [IPU1-0] 1148.589641 s:
    [IPU1-0] 1148.589672 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1148.589763 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1148.589824 s: ---------------------------------------------
    [IPU1-0] 1148.589916 s: 0 | 0 3. 0 0. 0 0. 0
    [IPU1-0] 1148.590282 s:
    [IPU1-0] 1148.590312 s: [ ALG_TIDL ] LATENCY,
    [IPU1-0] 1148.590373 s: ********************
    [IPU1-0] 1148.590434 s: Local Link Latency : Avg = 275116 us, Min = 272585 us, Max = 276307 us,
    [IPU1-0] 1148.590617 s: Source to Link Latency : Avg = 295218 us, Min = 292259 us, Max = 297200 us,
    [IPU1-0] 1148.590770 s:
    [IPU1-0] 1148.590861 s:
    [IPU1-0] 1148.590922 s: ### CPU [ EVE3], LinkID [ 0],
    [IPU1-0] 1148.591014 s:
    [IPU1-0] 1148.591075 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1148.591136 s: ******************************
    [IPU1-0] 1148.591197 s:
    [IPU1-0] 1148.591258 s: Elapsed time = 35999 msec
    [IPU1-0] 1148.591319 s:
    [IPU1-0] 1148.591349 s: New data Recv = 3.2 fps
    [IPU1-0] 1148.591441 s: Release data Recv = 3.2 fps
    [IPU1-0] 1148.591502 s: Driver/Notify Cb = 6.36 fps
    [IPU1-0] 1148.591593 s:
    [IPU1-0] 1148.591624 s: Input Statistics,
    [IPU1-0] 1148.591685 s:
    [IPU1-0] 1148.591715 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1148.591776 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1148.591868 s: --------------------------------------------------
    [IPU1-0] 1148.591959 s: 0 | 3. 2 0. 0 0. 0 3. 2
    [IPU1-0] 1148.592112 s:
    [IPU1-0] 1148.592142 s: Output Statistics,
    [IPU1-0] 1148.592203 s:
    [IPU1-0] 1148.592234 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1148.592325 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1148.592386 s: ---------------------------------------------
    [IPU1-0] 1148.592478 s: 0 | 0 3. 2 0. 0 0. 0
    [IPU1-0] 1148.592600 s:
    [IPU1-0] 1148.592631 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1148.592692 s: ********************
    [IPU1-0] 1148.592753 s: Local Link Latency : Avg = 23 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1148.592875 s: Source to Link Latency : Avg = 295490 us, Min = 292655 us, Max = 297474 us,
    [IPU1-0] 1148.593027 s:
    [IPU1-0] 1149.093149 s:
    [IPU1-0] 1149.093241 s: ### CPU [ HOST], LinkID [ 14],
    [IPU1-0] 1149.093332 s:
    [IPU1-0] 1149.093393 s: [ IPC_IN_4 ] Link Statistics,
    [IPU1-0] 1149.093485 s: ******************************
    [IPU1-0] 1149.093546 s:
    [IPU1-0] 1149.093607 s: Elapsed time = 36501 msec
    [IPU1-0] 1149.093668 s:
    [IPU1-0] 1149.093729 s: Get Full Buf Cb = 12.5 fps
    [IPU1-0] 1149.093790 s: Put Empty Buf Cb = 3.1 fps
    [IPU1-0] 1149.093881 s: Driver/Notify Cb = 36.30 fps
    [IPU1-0] 1149.093942 s:
    [IPU1-0] 1149.094003 s: Input Statistics,
    [IPU1-0] 1149.094095 s:
    [IPU1-0] 1149.094125 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1149.094217 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1149.094308 s: --------------------------------------------------
    [IPU1-0] 1149.094400 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1149.094522 s:
    [IPU1-0] 1149.094583 s: Output Statistics,
    [IPU1-0] 1149.094644 s:
    [IPU1-0] 1149.094674 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1149.094766 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1149.094827 s: ---------------------------------------------
    [IPU1-0] 1149.094918 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1149.095071 s:
    [IPU1-0] 1149.095101 s: [ IPC_IN_4 ] LATENCY,
    [IPU1-0] 1149.095162 s: ********************
    [IPU1-0] 1149.095223 s: Local Link Latency : Avg = 5 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1149.095437 s: Source to Link Latency : Avg = 295610 us, Min = 292808 us, Max = 297566 us,
    [IPU1-0] 1149.095559 s:
    [IPU1-0] 1149.095681 s:
    [IPU1-0] 1149.095742 s: ### CPU [ HOST], LinkID [ 1],
    [IPU1-0] 1149.095803 s:
    [IPU1-0] 1149.095864 s: [ IPC_OUT_1 ] Link Statistics,
    [IPU1-0] 1149.095925 s: ******************************
    [IPU1-0] 1149.095986 s:
    [IPU1-0] 1149.096260 s: Elapsed time = 36857 msec
    [IPU1-0] 1149.096382 s:
    [IPU1-0] 1149.096413 s: New data Recv = 3.3 fps
    [IPU1-0] 1149.096504 s: Release data Recv = 3.1 fps
    [IPU1-0] 1149.096565 s: Driver/Notify Cb = 36.35 fps
    [IPU1-0] 1149.096657 s:
    [IPU1-0] 1149.096718 s: Input Statistics,
    [IPU1-0] 1149.096779 s:
    [IPU1-0] 1149.096809 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1149.096901 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1149.096992 s: --------------------------------------------------
    [IPU1-0] 1149.097114 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1149.097297 s:
    [IPU1-0] 1149.097328 s: Output Statistics,
    [IPU1-0] 1149.097389 s:
    [IPU1-0] 1149.097419 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1149.097511 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1149.097602 s: ---------------------------------------------
    [IPU1-0] 1149.097694 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1149.097816 s:
    [IPU1-0] 1149.097846 s: [ IPC_OUT_1 ] LATENCY,
    [IPU1-0] 1149.097938 s: ********************
    [IPU1-0] 1149.097999 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1149.098151 s: Source to Link Latency : Avg = 20032 us, Min = 18789 us, Max = 21656 us,
    [IPU1-0] 1149.098273 s:
    [IPU1-0] 1149.598182 s:
    [IPU1-0] 1149.598273 s: ### CPU [ EVE2], LinkID [ 10],
    [IPU1-0] 1149.598365 s:
    [IPU1-0] 1149.598395 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1149.598487 s: ******************************
    [IPU1-0] 1149.598548 s:
    [IPU1-0] 1149.598578 s: Elapsed time = 37360 msec
    [IPU1-0] 1149.598670 s:
    [IPU1-0] 1149.598731 s: Get Full Buf Cb = 6.2 fps
    [IPU1-0] 1149.598792 s: Put Empty Buf Cb = 2.99 fps
    [IPU1-0] 1149.598883 s: Driver/Notify Cb = 6.34 fps
    [IPU1-0] 1149.598975 s:
    [IPU1-0] 1149.599005 s: Input Statistics,
    [IPU1-0] 1149.599097 s:
    [IPU1-0] 1149.599158 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1149.599249 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1149.599341 s: --------------------------------------------------
    [IPU1-0] 1149.599432 s: 0 | 3. 2 0. 0 0. 0 3. 2
    [IPU1-0] 1149.599615 s:
    [IPU1-0] 1149.599676 s: Output Statistics,
    [IPU1-0] 1149.599737 s:
    [IPU1-0] 1149.599798 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1149.599859 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1149.599951 s: ---------------------------------------------
    [IPU1-0] 1149.600073 s: 0 | 0 3. 2 0. 0 0. 0
    [IPU1-0] 1149.600225 s:
    [IPU1-0] 1149.600256 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1149.600317 s: ********************
    [IPU1-0] 1149.600378 s: Local Link Latency : Avg = 32 us, Min = 30 us, Max = 61 us,
    [IPU1-0] 1149.600530 s: Source to Link Latency : Avg = 20312 us, Min = 19094 us, Max = 21991 us,
    [IPU1-0] 1149.600683 s:
    [IPU1-0] 1149.600835 s:
    [IPU1-0] 1149.600866 s: ### CPU [ EVE2], LinkID [ 49],
    [IPU1-0] 1149.600957 s:
    [IPU1-0] 1149.601323 s: [ ALG_TIDL ] Link Statistics,
    [IPU1-0] 1149.601415 s: ******************************
    [IPU1-0] 1149.601506 s:
    [IPU1-0] 1149.601567 s: Elapsed time = 37361 msec
    [IPU1-0] 1149.601628 s:
    [IPU1-0] 1149.601689 s: New data Recv = 6.2 fps
    [IPU1-0] 1149.601781 s:
    [IPU1-0] 1149.601811 s: Input Statistics,
    [IPU1-0] 1149.601872 s:
    [IPU1-0] 1149.601933 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1149.602025 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1149.602147 s: --------------------------------------------------
    [IPU1-0] 1149.602238 s: 0 | 3. 2 0. 0 0. 0 2.99
    [IPU1-0] 1149.602391 s:
    [IPU1-0] 1149.602452 s: Output Statistics,
    [IPU1-0] 1149.602513 s:
    [IPU1-0] 1149.602543 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1149.602635 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1149.602726 s: ---------------------------------------------
    [IPU1-0] 1149.602818 s: 0 | 0 2.99 0. 0 0. 0
    [IPU1-0] 1149.602940 s:
    [IPU1-0] 1149.602970 s: [ ALG_TIDL ] LATENCY,
    [IPU1-0] 1149.603062 s: ********************
    [IPU1-0] 1149.603153 s: Local Link Latency : Avg = 276317 us, Min = 268377 us, Max = 277771 us,
    [IPU1-0] 1149.603306 s: Source to Link Latency : Avg = 296795 us, Min = 287654 us, Max = 299335 us,
    [IPU1-0] 1149.603428 s:
    [IPU1-0] 1149.603641 s:
    [IPU1-0] 1149.603702 s: ### CPU [ EVE2], LinkID [ 0],
    [IPU1-0] 1149.603794 s:
    [IPU1-0] 1149.603824 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1149.603916 s: ******************************
    [IPU1-0] 1149.604129 s:
    [IPU1-0] 1149.604190 s: Elapsed time = 37096 msec
    [IPU1-0] 1149.604282 s:
    [IPU1-0] 1149.604312 s: New data Recv = 3.1 fps
    [IPU1-0] 1149.604404 s: Release data Recv = 3.1 fps
    [IPU1-0] 1149.604495 s: Driver/Notify Cb = 6.36 fps
    [IPU1-0] 1149.604587 s:
    [IPU1-0] 1149.604617 s: Input Statistics,
    [IPU1-0] 1149.604678 s:
    [IPU1-0] 1149.604739 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1149.604831 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1149.604922 s: --------------------------------------------------
    [IPU1-0] 1149.605014 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1149.605166 s:
    [IPU1-0] 1149.605227 s: Output Statistics,
    [IPU1-0] 1149.605288 s:
    [IPU1-0] 1149.605319 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1149.605410 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1149.605502 s: ---------------------------------------------
    [IPU1-0] 1149.605593 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1149.605715 s:
    [IPU1-0] 1149.605776 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1149.605868 s: ********************
    [IPU1-0] 1149.605929 s: Local Link Latency : Avg = 25 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1149.606325 s: Source to Link Latency : Avg = 297066 us, Min = 287989 us, Max = 299609 us,
    [IPU1-0] 1149.606478 s:
    [IPU1-0] 1150.106478 s:
    [IPU1-0] 1150.106569 s: ### CPU [ HOST], LinkID [ 13],
    [IPU1-0] 1150.106661 s:
    [IPU1-0] 1150.106722 s: [ IPC_IN_3 ] Link Statistics,
    [IPU1-0] 1150.106783 s: ******************************
    [IPU1-0] 1150.106874 s:
    [IPU1-0] 1150.106905 s: Elapsed time = 37599 msec
    [IPU1-0] 1150.106996 s:
    [IPU1-0] 1150.107088 s: Get Full Buf Cb = 12.4 fps
    [IPU1-0] 1150.107179 s: Put Empty Buf Cb = 3.3 fps
    [IPU1-0] 1150.107271 s: Driver/Notify Cb = 36.33 fps
    [IPU1-0] 1150.107362 s:
    [IPU1-0] 1150.107393 s: Input Statistics,
    [IPU1-0] 1150.107454 s:
    [IPU1-0] 1150.107484 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1150.107606 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1150.107698 s: --------------------------------------------------
    [IPU1-0] 1150.107820 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1150.107972 s:
    [IPU1-0] 1150.108003 s: Output Statistics,
    [IPU1-0] 1150.108094 s:
    [IPU1-0] 1150.108155 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1150.108247 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1150.108338 s: ---------------------------------------------
    [IPU1-0] 1150.108430 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1150.108552 s:
    [IPU1-0] 1150.108582 s: [ IPC_IN_3 ] LATENCY,
    [IPU1-0] 1150.108674 s: ********************
    [IPU1-0] 1150.108735 s: Local Link Latency : Avg = 5 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1150.108857 s: Source to Link Latency : Avg = 297167 us, Min = 288111 us, Max = 299731 us,
    [IPU1-0] 1150.109009 s:
    [IPU1-0] 1150.109192 s:
    [IPU1-0] 1150.109253 s: ### CPU [ HOST], LinkID [ 0],
    [IPU1-0] 1150.109345 s:
    [IPU1-0] 1150.109375 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1150.109467 s: ******************************
    [IPU1-0] 1150.109528 s:
    [IPU1-0] 1150.109589 s: Elapsed time = 37942 msec
    [IPU1-0] 1150.109650 s:
    [IPU1-0] 1150.109711 s: New data Recv = 3.3 fps
    [IPU1-0] 1150.109772 s: Release data Recv = 3.0 fps
    [IPU1-0] 1150.109863 s: Driver/Notify Cb = 36.31 fps
    [IPU1-0] 1150.109955 s:
    [IPU1-0] 1150.110016 s: Input Statistics,
    [IPU1-0] 1150.110107 s:
    [IPU1-0] 1150.110168 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1150.110260 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1150.110351 s: --------------------------------------------------
    [IPU1-0] 1150.110443 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1150.110595 s:
    [IPU1-0] 1150.110656 s: Output Statistics,
    [IPU1-0] 1150.110717 s:
    [IPU1-0] 1150.110778 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1150.110870 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1150.110992 s: ---------------------------------------------
    [IPU1-0] 1150.111358 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1150.111480 s:
    [IPU1-0] 1150.111541 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1150.111602 s: ********************
    [IPU1-0] 1150.111663 s: Local Link Latency : Avg = 0 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1150.111816 s: Source to Link Latency : Avg = 19675 us, Min = 18697 us, Max = 21198 us,
    [IPU1-0] 1150.111938 s:
    [IPU1-0] 1150.611206 s:
    [IPU1-0] 1150.611297 s: ### CPU [ EVE1], LinkID [ 10],
    [IPU1-0] 1150.611389 s:
    [IPU1-0] 1150.611450 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1150.611541 s: ******************************
    [IPU1-0] 1150.611602 s:
    [IPU1-0] 1150.611663 s: Elapsed time = 38444 msec
    [IPU1-0] 1150.611724 s:
    [IPU1-0] 1150.611785 s: Get Full Buf Cb = 6.0 fps
    [IPU1-0] 1150.611877 s: Put Empty Buf Cb = 2.99 fps
    [IPU1-0] 1150.611968 s: Driver/Notify Cb = 6.32 fps
    [IPU1-0] 1150.612304 s:
    [IPU1-0] 1150.612365 s: Input Statistics,
    [IPU1-0] 1150.612395 s:
    [IPU1-0] 1150.612456 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1150.612517 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1150.612609 s: --------------------------------------------------
    [IPU1-0] 1150.612700 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1150.612822 s:
    [IPU1-0] 1150.612883 s: Output Statistics,
    [IPU1-0] 1150.612944 s:
    [IPU1-0] 1150.612975 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1150.613097 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1150.613219 s: ---------------------------------------------
    [IPU1-0] 1150.613341 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1150.613493 s:
    [IPU1-0] 1150.613524 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1150.613615 s: ********************
    [IPU1-0] 1150.613707 s: Local Link Latency : Avg = 31 us, Min = 30 us, Max = 61 us,
    [IPU1-0] 1150.613859 s: Source to Link Latency : Avg = 19952 us, Min = 18971 us, Max = 21533 us,
    [IPU1-0] 1150.614164 s:
    [IPU1-0] 1150.614774 s:
    [IPU1-0] 1150.614835 s: ### CPU [ EVE1], LinkID [ 49],
    [IPU1-0] 1150.614927 s:
    [IPU1-0] 1150.614957 s: [ ALG_TIDL ] Link Statistics,
    [IPU1-0] 1150.615140 s: ******************************
    [IPU1-0] 1150.615201 s:
    [IPU1-0] 1150.615262 s: Elapsed time = 38447 msec
    [IPU1-0] 1150.615323 s:
    [IPU1-0] 1150.615384 s: New data Recv = 6.3 fps
    [IPU1-0] 1150.615445 s:
    [IPU1-0] 1150.615476 s: Input Statistics,
    [IPU1-0] 1150.615537 s:
    [IPU1-0] 1150.615567 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1150.615659 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1150.615750 s: --------------------------------------------------
    [IPU1-0] 1150.615842 s: 0 | 3. 1 0. 0 0. 0 3. 1
    [IPU1-0] 1150.615964 s:
    [IPU1-0] 1150.615994 s: Output Statistics,
    [IPU1-0] 1150.616086 s:
    [IPU1-0] 1150.616116 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1150.616208 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1150.616269 s: ---------------------------------------------
    [IPU1-0] 1150.616360 s: 0 | 0 3. 1 0. 0 0. 0
    [IPU1-0] 1150.616482 s:
    [IPU1-0] 1150.616513 s: [ ALG_TIDL ] LATENCY,
    [IPU1-0] 1150.616574 s: ********************
    [IPU1-0] 1150.616635 s: Local Link Latency : Avg = 276035 us, Min = 262215 us, Max = 277435 us,
    [IPU1-0] 1150.616757 s: Source to Link Latency : Avg = 296151 us, Min = 282987 us, Max = 298329 us,
    [IPU1-0] 1150.616879 s:
    [IPU1-0] 1150.617001 s:
    [IPU1-0] 1150.617306 s: ### CPU [ EVE1], LinkID [ 0],
    [IPU1-0] 1150.617397 s:
    [IPU1-0] 1150.617458 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1150.617519 s: ******************************
    [IPU1-0] 1150.617580 s:
    [IPU1-0] 1150.617611 s: Elapsed time = 38187 msec
    [IPU1-0] 1150.617702 s:
    [IPU1-0] 1150.617733 s: New data Recv = 3.3 fps
    [IPU1-0] 1150.617824 s: Release data Recv = 3.3 fps
    [IPU1-0] 1150.617885 s: Driver/Notify Cb = 6.36 fps
    [IPU1-0] 1150.617977 s:
    [IPU1-0] 1150.618007 s: Input Statistics,
    [IPU1-0] 1150.618099 s:
    [IPU1-0] 1150.618129 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1150.618221 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1150.618312 s: --------------------------------------------------
    [IPU1-0] 1150.618404 s: 0 | 3. 3 0. 0 0. 0 3. 3
    [IPU1-0] 1150.618526 s:
    [IPU1-0] 1150.618556 s: Output Statistics,
    [IPU1-0] 1150.618617 s:
    [IPU1-0] 1150.618678 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1150.618739 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1150.618831 s: ---------------------------------------------
    [IPU1-0] 1150.618922 s: 0 | 0 3. 3 0. 0 0. 0
    [IPU1-0] 1150.619014 s:
    [IPU1-0] 1150.619075 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1150.619166 s: ********************
    [IPU1-0] 1150.619227 s: Local Link Latency : Avg = 25 us, Min = 0 us, Max = 92 us,
    [IPU1-0] 1150.619319 s: Source to Link Latency : Avg = 296418 us, Min = 283292 us, Max = 298603 us,
    [IPU1-0] 1150.619441 s:
    [IPU1-0] 1151.119197 s:
    [IPU1-0] 1151.119258 s: ### CPU [ HOST], LinkID [ 12],
    [IPU1-0] 1151.119349 s:
    [IPU1-0] 1151.119380 s: [ IPC_IN_2 ] Link Statistics,
    [IPU1-0] 1151.119441 s: ******************************
    [IPU1-0] 1151.119502 s:
    [IPU1-0] 1151.119563 s: Elapsed time = 38689 msec
    [IPU1-0] 1151.119624 s:
    [IPU1-0] 1151.119685 s: Get Full Buf Cb = 12.7 fps
    [IPU1-0] 1151.119746 s: Put Empty Buf Cb = 3.2 fps
    [IPU1-0] 1151.119837 s: Driver/Notify Cb = 36.34 fps
    [IPU1-0] 1151.120020 s:
    [IPU1-0] 1151.120081 s: Input Statistics,
    [IPU1-0] 1151.120142 s:
    [IPU1-0] 1151.120203 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1151.120264 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1151.120356 s: --------------------------------------------------
    [IPU1-0] 1151.120447 s: 0 | 3. 2 0. 0 0. 0 3. 2
    [IPU1-0] 1151.120569 s:
    [IPU1-0] 1151.120630 s: Output Statistics,
    [IPU1-0] 1151.120661 s:
    [IPU1-0] 1151.120722 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1151.120783 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1151.120874 s: ---------------------------------------------
    [IPU1-0] 1151.120966 s: 0 | 0 3. 2 0. 0 0. 0
    [IPU1-0] 1151.121088 s:
    [IPU1-0] 1151.121149 s: [ IPC_IN_2 ] LATENCY,
    [IPU1-0] 1151.121210 s: ********************
    [IPU1-0] 1151.121271 s: Local Link Latency : Avg = 4 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1151.121423 s: Source to Link Latency : Avg = 296540 us, Min = 283414 us, Max = 298725 us,
    [IPU1-0] 1151.121576 s:
    [IPU1-0] 1151.121698 s:
    [IPU1-0] 1151.121759 s: ### CPU [ HOST], LinkID [ 50],
    [IPU1-0] 1151.121820 s:
    [IPU1-0] 1151.121850 s: [ ALG_TIDLPOSTPROC ] Link Statistics,
    [IPU1-0] 1151.121942 s: ******************************
    [IPU1-0] 1151.122003 s:
    [IPU1-0] 1151.122064 s: Elapsed time = 38691 msec
    [IPU1-0] 1151.122369 s:
    [IPU1-0] 1151.122430 s: New data Recv = 12.6 fps
    [IPU1-0] 1151.122521 s:
    [IPU1-0] 1151.122552 s: Input Statistics,
    [IPU1-0] 1151.122613 s:
    [IPU1-0] 1151.122643 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1151.122735 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1151.122796 s: --------------------------------------------------
    [IPU1-0] 1151.122887 s: 0 | 12. 6 0. 0 0. 0 12. 6
    [IPU1-0] 1151.123009 s:
    [IPU1-0] 1151.123101 s: Output Statistics,
    [IPU1-0] 1151.123162 s:
    [IPU1-0] 1151.123223 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1151.123284 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1151.123375 s: ---------------------------------------------
    [IPU1-0] 1151.123467 s: 0 | 0 12. 6 0. 0 0. 0
    [IPU1-0] 1151.123589 s:
    [IPU1-0] 1151.123619 s: [ ALG_TIDLPOSTPROC ] LATENCY,
    [IPU1-0] 1151.123680 s: ********************
    [IPU1-0] 1151.123741 s: Local Link Latency : Avg = 606 us, Min = 549 us, Max = 1739 us,
    [IPU1-0] 1151.123863 s: Source to Link Latency : Avg = 296997 us, Min = 284024 us, Max = 300372 us,
    [IPU1-0] 1151.123985 s:
    [IPU1-0] 1151.623223 s:
    [IPU1-0] 1151.623284 s: ### CPU [IPU1-0], LinkID [ 0],
    [IPU1-0] 1151.623375 s:
    [IPU1-0] 1151.623436 s: [ IPC_OUT_0 ] Link Statistics,
    [IPU1-0] 1151.623497 s: ******************************
    [IPU1-0] 1151.623558 s:
    [IPU1-0] 1151.623619 s: Elapsed time = 39472 msec
    [IPU1-0] 1151.623680 s:
    [IPU1-0] 1151.623741 s: New data Recv = 12.5 fps
    [IPU1-0] 1151.623802 s: Release data Recv = 11.98 fps
    [IPU1-0] 1151.623894 s: Driver/Notify Cb = 45.32 fps
    [IPU1-0] 1151.623955 s:
    [IPU1-0] 1151.624016 s: Input Statistics,
    [IPU1-0] 1151.624046 s:
    [IPU1-0] 1151.624138 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1151.624229 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1151.624321 s: --------------------------------------------------
    [IPU1-0] 1151.624382 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1151.624534 s:
    [IPU1-0] 1151.624565 s: Output Statistics,
    [IPU1-0] 1151.624626 s:
    [IPU1-0] 1151.624656 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1151.624748 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1151.624809 s: ---------------------------------------------
    [IPU1-0] 1151.624900 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1151.625022 s:
    [IPU1-0] 1151.625053 s: [ IPC_OUT_0 ] LATENCY,
    [IPU1-0] 1151.625144 s: ********************
    [IPU1-0] 1151.625205 s: Local Link Latency : Avg = 6 us, Min = 0 us, Max = 61 us,
    [IPU1-0] 1151.625327 s: Source to Link Latency : Avg = 5155 us, Min = 4179 us, Max = 6100 us,
    [IPU1-0] 1151.625449 s:
    [IPU1-0] 1152.125205 s:
    [IPU1-0] 1152.125297 s: ### CPU [ HOST], LinkID [ 10],
    [IPU1-0] 1152.125388 s:
    [IPU1-0] 1152.125419 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1152.125480 s: ******************************
    [IPU1-0] 1152.125541 s:
    [IPU1-0] 1152.125571 s: Elapsed time = 39974 msec
    [IPU1-0] 1152.125663 s:
    [IPU1-0] 1152.125693 s: Get Full Buf Cb = 24.4 fps
    [IPU1-0] 1152.125785 s: Put Empty Buf Cb = 11.98 fps
    [IPU1-0] 1152.125846 s: Driver/Notify Cb = 45.37 fps
    [IPU1-0] 1152.125937 s:
    [IPU1-0] 1152.125968 s: Input Statistics,
    [IPU1-0] 1152.126029 s:
    [IPU1-0] 1152.126059 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.126181 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.126242 s: --------------------------------------------------
    [IPU1-0] 1152.126334 s: 0 | 12. 5 0. 0 0. 0 12. 5
    [IPU1-0] 1152.126456 s:
    [IPU1-0] 1152.126517 s: Output Statistics,
    [IPU1-0] 1152.126547 s:
    [IPU1-0] 1152.126608 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1152.126669 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1152.126761 s: ---------------------------------------------
    [IPU1-0] 1152.126822 s: 0 | 0 12. 5 0. 0 0. 0
    [IPU1-0] 1152.126944 s:
    [IPU1-0] 1152.126974 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1152.127035 s: ********************
    [IPU1-0] 1152.127340 s: Local Link Latency : Avg = 4 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1152.127462 s: Source to Link Latency : Avg = 5246 us, Min = 4270 us, Max = 6192 us,
    [IPU1-0] 1152.127584 s:
    [IPU1-0] 1152.127645 s: CPU [ HOST], LinkID [ 38], Link Statistics not available !
    [IPU1-0] 1152.127798 s:
    [IPU1-0] 1152.127859 s: ### CPU [ HOST], LinkID [ 34],
    [IPU1-0] 1152.127920 s:
    [IPU1-0] 1152.127950 s: [ SYNC_0 ] Link Statistics,
    [IPU1-0] 1152.128042 s: ******************************
    [IPU1-0] 1152.128133 s:
    [IPU1-0] 1152.128194 s: Elapsed time = 40054 msec
    [IPU1-0] 1152.128255 s:
    [IPU1-0] 1152.128286 s: New data Recv = 54.30 fps
    [IPU1-0] 1152.128377 s: Get Full Buf Cb = 11.95 fps
    [IPU1-0] 1152.128438 s: Put Empty Buf Cb = 11.95 fps
    [IPU1-0] 1152.128530 s: Driver/Notify Cb = 30.28 fps
    [IPU1-0] 1152.128591 s:
    [IPU1-0] 1152.128652 s: Input Statistics,
    [IPU1-0] 1152.128682 s:
    [IPU1-0] 1152.128743 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.128804 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.128896 s: --------------------------------------------------
    [IPU1-0] 1152.128957 s: 0 | 12. 3 0. 0 0. 0 11.95
    [IPU1-0] 1152.129109 s: 1 | 11.95 0. 0 0. 0 11.95
    [IPU1-0] 1152.129262 s:
    [IPU1-0] 1152.129292 s: Output Statistics,
    [IPU1-0] 1152.129353 s:
    [IPU1-0] 1152.129384 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1152.129445 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1152.129536 s: ---------------------------------------------
    [IPU1-0] 1152.129597 s: 0 | 0 11.95 0. 0 0. 0
    [IPU1-0] 1152.129720 s:
    [IPU1-0] 1152.129750 s: [ SYNC_0 ] LATENCY,
    [IPU1-0] 1152.129811 s: ********************
    [IPU1-0] 1152.129872 s: Local Link Latency : Avg = 145878 us, Min = 0 us, Max = 294607 us,
    [IPU1-0] 1152.129994 s: Source to Link Latency : Avg = 297019 us, Min = 284054 us, Max = 300402 us,
    [IPU1-0] 1152.130116 s:
    [IPU1-0] 1152.130269 s:
    [IPU1-0] 1152.130299 s: ### CPU [ HOST], LinkID [ 51],
    [IPU1-0] 1152.130360 s:
    [IPU1-0] 1152.130421 s: [ ALG_TIDLPOSTPROC ] Link Statistics,
    [IPU1-0] 1152.130513 s: ******************************
    [IPU1-0] 1152.130574 s:
    [IPU1-0] 1152.130604 s: Elapsed time = 39700 msec
    [IPU1-0] 1152.130696 s:
    [IPU1-0] 1152.130757 s: New data Recv = 12.6 fps
    [IPU1-0] 1152.130818 s:
    [IPU1-0] 1152.130879 s: Input Statistics,
    [IPU1-0] 1152.130940 s:
    [IPU1-0] 1152.130970 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.131062 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.131184 s: --------------------------------------------------
    [IPU1-0] 1152.131275 s: 0 | 12. 6 0. 0 0. 0 12. 6
    [IPU1-0] 1152.131428 s:
    [IPU1-0] 1152.131458 s: Output Statistics,
    [IPU1-0] 1152.131519 s:
    [IPU1-0] 1152.131550 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1152.131641 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1152.131733 s: ---------------------------------------------
    [IPU1-0] 1152.131824 s: 0 | 0 12. 6 0. 0 0. 0
    [IPU1-0] 1152.131946 s:
    [IPU1-0] 1152.131977 s: [ ALG_TIDLPOSTPROC ] LATENCY,
    [IPU1-0] 1152.132068 s: ********************
    [IPU1-0] 1152.132312 s: Local Link Latency : Avg = 841 us, Min = 701 us, Max = 1921 us,
    [IPU1-0] 1152.132434 s: Source to Link Latency : Avg = 297885 us, Min = 284878 us, Max = 301287 us,
    [IPU1-0] 1152.132556 s:
    [IPU1-0] 1152.132678 s:
    [IPU1-0] 1152.132739 s: ### CPU [ HOST], LinkID [ 4],
    [IPU1-0] 1152.132800 s:
    [IPU1-0] 1152.132861 s: [ IPC_OUT_4 ] Link Statistics,
    [IPU1-0] 1152.132922 s: ******************************
    [IPU1-0] 1152.132983 s:
    [IPU1-0] 1152.133014 s: Elapsed time = 39701 msec
    [IPU1-0] 1152.133105 s:
    [IPU1-0] 1152.133166 s: New data Recv = 12.6 fps
    [IPU1-0] 1152.133258 s: Release data Recv = 12.1 fps
    [IPU1-0] 1152.133319 s: Driver/Notify Cb = 45.33 fps
    [IPU1-0] 1152.133410 s:
    [IPU1-0] 1152.133441 s: Input Statistics,
    [IPU1-0] 1152.133502 s:
    [IPU1-0] 1152.133532 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.133624 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.133685 s: --------------------------------------------------
    [IPU1-0] 1152.133776 s: 0 | 12. 6 0. 0 0. 0 12. 6
    [IPU1-0] 1152.133898 s:
    [IPU1-0] 1152.133959 s: Output Statistics,
    [IPU1-0] 1152.133990 s:
    [IPU1-0] 1152.134051 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1152.134142 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1152.134203 s: ---------------------------------------------
    [IPU1-0] 1152.134295 s: 0 | 0 12. 6 0. 0 0. 0
    [IPU1-0] 1152.134417 s:
    [IPU1-0] 1152.134478 s: [ IPC_OUT_4 ] LATENCY,
    [IPU1-0] 1152.134539 s: ********************
    [IPU1-0] 1152.134600 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max = 31 us,
    [IPU1-0] 1152.134691 s: Source to Link Latency : Avg = 297897 us, Min = 284908 us, Max = 301317 us,
    [IPU1-0] 1152.134813 s:
    [IPU1-0] 1152.634569 s:
    [IPU1-0] 1152.634661 s: ### CPU [IPU1-0], LinkID [ 10],
    [IPU1-0] 1152.634722 s:
    [IPU1-0] 1152.634783 s: [ IPC_IN_0 ] Link Statistics,
    [IPU1-0] 1152.634844 s: ******************************
    [IPU1-0] 1152.634905 s:
    [IPU1-0] 1152.634935 s: Elapsed time = 40203 msec
    [IPU1-0] 1152.635027 s:
    [IPU1-0] 1152.635057 s: Get Full Buf Cb = 12.6 fps
    [IPU1-0] 1152.635179 s: Put Empty Buf Cb = 12.1 fps
    [IPU1-0] 1152.635271 s: Driver/Notify Cb = 45.36 fps
    [IPU1-0] 1152.635332 s:
    [IPU1-0] 1152.635393 s: Input Statistics,
    [IPU1-0] 1152.635423 s:
    [IPU1-0] 1152.635484 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.635545 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.635637 s: --------------------------------------------------
    [IPU1-0] 1152.635972 s: 0 | 12. 6 0. 0 0. 0 12. 6
    [IPU1-0] 1152.636155 s:
    [IPU1-0] 1152.636186 s: Output Statistics,
    [IPU1-0] 1152.636247 s:
    [IPU1-0] 1152.636277 s: CH | Out | Out | Out Drop | Out User Drop
    [IPU1-0] 1152.636369 s: | ID | FPS | FPS | FPS
    [IPU1-0] 1152.636430 s: ---------------------------------------------
    [IPU1-0] 1152.636521 s: 0 | 0 12. 6 0. 0 0. 0
    [IPU1-0] 1152.636643 s:
    [IPU1-0] 1152.636674 s: [ IPC_IN_0 ] LATENCY,
    [IPU1-0] 1152.636735 s: ********************
    [IPU1-0] 1152.636796 s: Local Link Latency : Avg = 22 us, Min = 0 us, Max = 122 us,
    [IPU1-0] 1152.636918 s: Source to Link Latency : Avg = 298071 us, Min = 285091 us, Max = 301470 us,
    [IPU1-0] 1152.637009 s:
    [IPU1-0] 1152.637406 s:
    [IPU1-0] 1152.637467 s: ### CPU [IPU1-0], LinkID [ 73],
    [IPU1-0] 1152.637528 s:
    [IPU1-0] 1152.637558 s: [ DISPLAY ] Link Statistics,
    [IPU1-0] 1152.637650 s: ******************************
    [IPU1-0] 1152.637711 s:
    [IPU1-0] 1152.637741 s: Elapsed time = 40205 msec
    [IPU1-0] 1152.637802 s:
    [IPU1-0] 1152.637863 s: New data Recv = 12.3 fps
    [IPU1-0] 1152.637924 s: Driver/Notify Cb = 60.4 fps
    [IPU1-0] 1152.637985 s:
    [IPU1-0] 1152.638046 s: Input Statistics,
    [IPU1-0] 1152.638107 s:
    [IPU1-0] 1152.638168 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.638260 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.638595 s: --------------------------------------------------
    [IPU1-0] 1152.638717 s: 0 | 12. 6 0. 0 0. 0 12. 6
    [IPU1-0] 1152.638839 s:
    [IPU1-0] 1152.638900 s: [ DISPLAY ] LATENCY,
    [IPU1-0] 1152.638931 s: ********************
    [IPU1-0] 1152.638992 s: Local Link Latency : Avg = 44 us, Min = 30 us, Max = 122 us,
    [IPU1-0] 1152.639175 s: Source to Link Latency : Avg = 298302 us, Min = 285366 us, Max = 301744 us,
    [IPU1-0] 1152.639480 s:
    [IPU1-0] 1152.639541 s: Display UnderFlow Count = 0
    [IPU1-0] 1152.639602 s:
    [IPU1-0] 1152.639693 s: CPU [ IPU1-0], LinkID [ 23], Link Statistics not available !
    [IPU1-0] 1152.639846 s:
    [IPU1-0] 1152.639907 s: ### CPU [IPU1-0], LinkID [ 74],
    [IPU1-0] 1152.639968 s:
    [IPU1-0] 1152.639998 s: [ DISPLAY ] Link Statistics,
    [IPU1-0] 1152.640090 s: ******************************
    [IPU1-0] 1152.640364 s:
    [IPU1-0] 1152.640425 s: Elapsed time = 40599 msec
    [IPU1-0] 1152.640517 s:
    [IPU1-0] 1152.640547 s: Driver/Notify Cb = 60.2 fps
    [IPU1-0] 1152.640639 s:
    [IPU1-0] 1152.640669 s: Input Statistics,
    [IPU1-0] 1152.640852 s:
    [IPU1-0] 1152.640913 s: CH | In Recv | In Drop | In User Drop | In Process
    [IPU1-0] 1152.641005 s: | FPS | FPS | FPS | FPS
    [IPU1-0] 1152.641066 s: --------------------------------------------------
    [IPU1-0] 1152.641737 s: 0 | 0. 2 0. 0 0. 0 0. 2
    [IPU1-0] 1152.641920 s:
    [IPU1-0] 1152.641981 s: [ DISPLAY ] LATENCY,
    [IPU1-0] 1152.642042 s: ********************
    [IPU1-0] 1152.642408 s: Local Link Latency : Avg = 31 us, Min = 31 us, Max = 31 us,
    [IPU1-0] 1152.642560 s: Source to Link Latency : Avg = 19764 us, Min = 19764 us, Max = 19764 us,
    [IPU1-0] 1152.642713 s:
    [IPU1-0] 1152.642743 s: Display UnderFlow Count = 0
    [IPU1-0] 1152.642835 s:
    [IPU1-0] 1153.142408 s:
  • Moreover, the inData and inHeader file obtained from CDDS were renamed to inData_semSeg and inHeader_semSeg respectively in order to check whether my data has some problem or not. Those obtained files didn't work at all. Am I doing something terribly wrong?
  • Hi Anuj,
    Do know where exactly the problem is ? I will be waiting for you response. Thank you.
    With best regards,
    H.M. Owais
    Usecase logs seems proper to me.
    Can you check whether you are observing same issue with TIDL_OD usecase or any other camera input usecase.
    Anuj
  • Hi, I have fixed the problem, thank you
    With best regards,
    H.M. Owais
