Part Number: DRA750
Tool/software: Linux
I am following below steps but I get errors:
1. follow section 2.4; make linux; make linux_install (still I don't get EGL under targetfs)
2. Select make config in Rules.make
TDA2XX
MAKECONFIG=tda2xx_evm_linux_all
3. Build the sdk dependency
$>make -s -j depend
4. Build sdk
$>make -s -j
/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build$ make -s -j
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignLUT_tda2xx.oe66' given more than once in the same rule
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/rtos/makerules/rules_66.mk:185: target '/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignExt_tda2xx.oe66' given more than once in the same rule
# Invoking configuro...
# Configuro done!
# Making tda2xx-evm:arp32_1:release:vision_sdk_lib...
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F...
# Configuro done!
# Configuro done!
# Configuro done!
# Making tda2xx-evm:c66xdsp_2:release:vision_sdk_lib...
# Configuro done!
# Making tda2xx-evm:arp32_4:release:vision_sdk_lib...
# Making tda2xx-evm:arp32_2:release:vision_sdk_lib...
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66...
# Making tda2xx-evm:c66xdsp_1:release:vision_sdk_lib...
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F...
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F...
# Configuro done!
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66...
# Making tda2xx-evm:arp32_3:release:vision_sdk_lib...
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F...
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 7: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 8: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 13: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd", line 14: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 7: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 8: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 13: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd", line 14: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 7: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 8: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 13: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd", line 14: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 7: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 8: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 13: warning:
no matching section
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd", line 14: warning:
no matching section
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66 created.
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66 created.
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F created.
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
Parsing the input object file, /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F created.
Parsing the input object file, /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F created.
Parsing the input object file, /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.
File conversion complete!
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F created.
Parsing the input object file, /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.
Converting binary file [/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/AppImage] to C array ... Done. (1824188 bytes)
# Configuro done!
# Configuro done!
# Making tda2xx-evm:ipu1_0:release:vision_sdk_lib...
# Making tda2xx-evm:ipu2:release:vision_sdk_lib...
# Compiling tda2xx-evm:ipu2:release:vision_sdk: src/eve_firmware.c
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4...
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4 created.
# Linking into /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4...
# /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4 created.
'/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu2/release/vision_sdk_configuro/osa_mem_map.h' -> '/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/hlos/osa/include/osa_mem_map.h'
In file included from /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/posix_types.h:4:0,
from /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/types.h:13,
from /home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/vdrm_controller/v_controller_if.h:6,
from dispDistSrcLink_tsk.c:81:
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/stddef.h:1:28: fatal error: linux/compiler.h: No such file or directory
compilation terminated.
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/hlos/makerules/linux/common_footer_a15.mk:81: recipe for target 'depend' failed
make[6]: *** [depend] Error 1
Makefile:16: recipe for target 'links_a15_dispDistSrc' failed
make[5]: *** [links_a15_dispDistSrc] Error 2
make[5]: *** Waiting for unfinished jobs....
In file included from sgxRenderKmsCube.h:65:0,
from sgxRenderKmsCube.c:62:
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/hlos/system/system_gl_egl_utils.h:76:21: fatal error: EGL/egl.h: No such file or directory
In file included from esTransform.c:103:0:
esUtil.h:105:23: fatal error: GLES2/gl2.h: No such file or directory
In file included from sgxFrmcpyLink_priv.h:99:0,
from sgxFrmcpyLink_tsk.c:86:
In file included from sgxRender1x1.h:65:0,
from sgxRender1x1.c:62:
In file included from sgxRender3x3.h:72:0,
from sgxRender3x3.c:62:
from sgxFrmcpyLink_drv.c:80:
In file included from sgxRender2x4.h:72:0,
from sgxRender2x4.c:62:
In file included from sgxRender2x2.h:71:0,
from sgxRender2x2.c:62:
Makefile:16: recipe for target 'links_a15_sgxFrmcpy' failed
make[5]: *** [links_a15_sgxFrmcpy] Error 2
In file included from system_gl_egl_utils.c:69:0:
system_gbm_allocator.c:74:17: fatal error: drm.h: No such file or directory
Makefile:16: recipe for target 'system' failed
make[5]: *** [system] Error 2
# osa: tda2xx-evm: Compiling osa_mem.c
# osa: tda2xx-evm: Compiling osa_remote_log_server.c
# osa: tda2xx-evm: Compiling osa_remote_log_client.c
# osa: tda2xx-evm: Creating archive osa.a
MAKEFILE.MK:16: recipe for target 'vision_sdk_linux_lib' failed
make[4]: *** [vision_sdk_linux_lib] Error 2
Makefile:233: recipe for target 'links_fw_libs_hlos' failed
make[3]: *** [links_fw_libs_hlos] Error 2
Makefile:68: recipe for target 'apps_hlos' failed
make[2]: *** [apps_hlos] Error 2
Makefile:38: recipe for target 'apps' failed
make[1]: *** [apps] Error 2
Makefile:12: recipe for target 'vision_sdk' failed
make: *** [vision_sdk] Error 2
Any help is appreciated. Thanks!
