Tool/software: Linux
On the AM5728evm board, once the Wayland/weston is stopped, the second crtc and encoder is not initialized. And though we can not use HDMI connector any more.
Is there any example code to initialize them by calling drm APIs? Thanks.
root@am57xx-evm:/dev# /etc/init.d/weston stop
Stopping Weston
root@am57xx-evm:/dev# modetest
trying to open device 'i915'...failed
trying to open device 'amdgpu'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...done
Encoders:
id crtc type possible crtcs possible clones
34 39 TMDS 0x00000001 0x00000000
40 0 TMDS 0x00000002 0x00000000
Connectors:
id encoder status name size (mm) modes encoders
35 34 connected DPI-1 0x0 1 34
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
800x480 60 800 1010 1040 1056 480 502 515 525 33000 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
41 0 connected HDMI-A-1 530x300 30 40
modes:
1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: preferred, driver
1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148352 flags: phsync, pvsync; type: driver
1920x1080 50 1920 2448 2492 2640 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
1680x1050 60 1680 1728 1760 1840 1050 1053 1059 1080 119000 flags: phsync, nvsync; type: driver
1600x900 60 1600 1624 1704 1800 900 901 904 1000 108000 flags: phsync, pvsync; type: driver
1280x1024 75 1280 1296 1440 1688 1024 1025 1028 1066 135000 flags: phsync, pvsync; type: driver
1280x1024 60 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver
1440x900 60 1440 1488 1520 1600 900 903 909 926 88750 flags: phsync, nvsync; type: driver
1280x800 60 1280 1328 1360 1440 800 803 809 823 71000 flags: phsync, nvsync; type: driver
1152x864 75 1152 1216 1344 1600 864 865 868 900 108000 flags: phsync, pvsync; type: driver
1280x720 60 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver
1280x720 60 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver
1280x720 50 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type: driver
1024x768 75 1024 1040 1136 1312 768 769 772 800 78750 flags: phsync, pvsync; type: driver
1024x768 70 1024 1048 1184 1328 768 771 777 806 75000 flags: nhsync, nvsync; type: driver
1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
832x624 75 832 864 928 1152 624 625 628 667 57284 flags: nhsync, nvsync; type: driver
800x600 75 800 816 896 1056 600 601 604 625 49500 flags: phsync, pvsync; type: driver
800x600 72 800 856 976 1040 600 637 643 666 50000 flags: phsync, pvsync; type: driver
800x600 60 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
800x600 56 800 824 896 1024 600 601 603 625 36000 flags: phsync, pvsync; type: driver
720x576 50 720 732 796 864 576 581 586 625 27000 flags: nhsync, nvsync; type: driver
720x480 60 720 736 798 858 480 489 495 525 27027 flags: nhsync, nvsync; type: driver
720x480 60 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type: driver
640x480 75 640 656 720 840 480 481 484 500 31500 flags: nhsync, nvsync; type: driver
640x480 73 640 664 704 832 480 489 492 520 31500 flags: nhsync, nvsync; type: driver
640x480 67 640 704 768 864 480 483 486 525 30240 flags: nhsync, nvsync; type: driver
640x480 60 640 656 752 800 480 490 492 525 25200 flags: nhsync, nvsync; type: driver
640x480 60 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
720x400 70 720 738 846 900 400 412 414 449 28320 flags: nhsync, pvsync; type: driver
props:
1 EDID:
blobs:
value:
00ffffffffffff004c2d820c57485a5a
1e1b010380351e782a4ba1a359559b26
0e5054bfef80714f81c0810081809500
a9c0b3000101023a801871382d40582c
4500132b2100001e000000fd00384b1e
5111000a202020202020000000fc0053
3234453435300a2020202020000000ff
0048345a4a3730303736380a20200109
02010400023a80d072382d40102c4580
132b2100001e011d007251d01e206e28
5500132b2100001e011d00bc52d01e20
b8285540132b2100001e8c0ad0902040
31200c405500132b210000188c0ad08a
20e02d10103e9600132b210000180000
00000000000000000000000000000000
0000000000000000000000000000000e
2 DPMS:
flags: enum
value: 3
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
CRTCs:
id fb pos size
39 60 (0,0) (800x480)
props:
23 CTM:
flags: blob
blobs:
value:
24 GAMMA_LUT:
flags: blob
blobs:
value:
25 GAMMA_LUT_SIZE:
flags: immutable range
values: 0 4294967295
value: 256
30 background:
flags: range
values: 0 16777215
value: 0
31 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
32 trans-key:
flags: range
values: 0 16777215
value: 0
33 alpha_blender:
flags: range
values: 0 1
value: 0
37 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 1
27 zorder:
flags: range
values: 0 3
value: 0
47 0 (0,0) (0x0)
0 0 0 0 0 0 0 0 0 0 flags: ; type:
props:
23 CTM:
flags: blob
blobs:
value:
24 GAMMA_LUT:
flags: blob
blobs:
value:
25 GAMMA_LUT_SIZE:
value: 256
30 background:
flags: range
values: 0 16777215
value: 0
31 trans-key-mode:
flags: enum
value: 0
32 trans-key:
flags: range
values: 0 16777215
value: 0
33 alpha_blender:
flags: range
values: 0 1
value: 0
43 rotation:
flags: bitmask
value: 1
27 zorder:
flags: range
values: 0 3
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
36 39 60 0,0 0,0 0 0x00000003
formats: RX12 AR12 RG16 XR24 RG24 AR24 RA24 RX24 AR15 XR12 RA12 XR15
props:
6 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
37 rotation:
flags: bitmask
value: 1
27 zorder:
flags: range
values: 0 3
value: 0
38 zpos:
flags: range
values: 0 3
value: 0
28 global_alpha:
flags: range
values: 0 255
value: 255
29 pre_mult_alpha:
flags: range
values: 0 1
value: 0
42 0 0 0,0 0,0 0 0x00000003
formats: RG16 RX12 YUYV AR15 RA24 NV12 RA12 XR24 RG24 UYVY AR12 XR15 AR24 XR12 RX24
props:
6 type:
value: 1
43 rotation:
flags: bitmask
value: 1
27 zorder:
flags: range
values: 0 3
value: 0
44 zpos:
flags: range
values: 0 3
value: 0
28 global_alpha:
flags: range
values: 0 255
value: 255
29 pre_mult_alpha:
flags: range
values: 0 1
value: 0
48 0 0 0,0 0,0 0 0x00000003
props:
6 type:
value: 0
49 rotation:
flags: bitmask
value: 1
27 zorder:
flags: range
values: 0 3
value: 2
50 zpos:
flags: range
values: 0 3
value: 2
28 global_alpha:
flags: range
values: 0 255
value: 255
29 pre_mult_alpha:
flags: range
values: 0 1
value: 0
53 0 0 0,0 0,0 0 0x00000003
props:
6 type:
value: 0
54 rotation:
flags: bitmask
value: 1
27 zorder:
flags: range
values: 0 3
value: 3
55 zpos:
flags: range
values: 0 3
value: 3
28 global_alpha:
flags: range
values: 0 255
value: 255
29 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
root@am57xx-evm:
