Part Number: AM3352
Other Parts Discussed in Thread: TPS65218
Tool/software: Linux
Hi All,
We would debug a kernel lockup issue in AM335x Kernel 4.4.113, so we selected some Lockups&Hangs Detect options in Kernel menuconfig.
But now the kernel throw out " [ INFO: suspicious RCU usage. ] " when startup.
Will it also affect the stability of the kernel?
How can i fix this firstly.
Below is part of the log, see the appendix in detail.
[ 21.517337] ===============================
[ 21.521759] [ INFO: suspicious RCU usage. ]
[ 21.526095] 4.4.113 #4 Not tainted
[ 21.529546] -------------------------------
[ 21.533874] net/ipv4/cipso_ipv4.c:1940 suspicious rcu_dereference_protected() usage!
[ 21.541766]
[ 21.541766] other info that might help us debug this:
[ 21.541766]
[ 21.549940]
[ 21.549940] rcu_scheduler_active = 1, debug_locks = 0
[ 21.556621] 3 locks held by swapper/0/1:
[ 21.560676] #0: (net_mutex){+.+.+.}, at: [<c0964a14>] register_pernet_subsys+0x30/0x50
[ 21.569181] #1: (slock-AF_INET/1){+.....}, at: [<c0608f1c>] smack_netlabel+0x3c/0xa0
[ 21.577515] #2: (rcu_read_lock){......}, at: [<c0b0ecd4>] netlbl_sock_setattr+0x0/0x17c
[ 21.586187]
[ 21.586187] stack backtrace:
[ 21.590701] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.113 #4
[ 21.596769] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 21.602988] [<c001c5bc>] (unwind_backtrace) from [<c00163e8>] (show_stack+0x20/0x24)
[ 21.610833] [<c00163e8>] (show_stack) from [<c0692008>] (dump_stack+0xa0/0xcc)
[ 21.618148] [<c0692008>] (dump_stack) from [<c00a4360>] (lockdep_rcu_suspicious+0xe8/0x11c)
[ 21.626605] [<c00a4360>] (lockdep_rcu_suspicious) from [<c0a5d9c8>] (cipso_v4_sock_setattr+0x188/0x18c)
[ 21.636100] [<c0a5d9c8>] (cipso_v4_sock_setattr) from [<c0b0edd8>] (netlbl_sock_setattr+0x104/0x17c)
[ 21.645327] [<c0b0edd8>] (netlbl_sock_setattr) from [<c0608f70>] (smack_netlabel+0x90/0xa0)
[ 21.653777] [<c0608f70>] (smack_netlabel) from [<c060dfc8>] (smack_socket_post_create+0x68/0x6c)
[ 21.662673] [<c060dfc8>] (smack_socket_post_create) from [<c05e45cc>] (security_socket_post_create+0x70/0x90)
[ 21.672709] [<c05e45cc>] (security_socket_post_create) from [<c094f29c>] (__sock_create+0x320/0x390)
[ 21.681938] [<c094f29c>] (__sock_create) from [<c094f38c>] (sock_create_kern+0x28/0x30)
[ 21.690046] [<c094f38c>] (sock_create_kern) from [<c0a31c6c>] (inet_ctl_sock_create+0x40/0x90)
[ 21.698762] [<c0a31c6c>] (inet_ctl_sock_create) from [<c0aee568>] (sctp_ctrlsock_init+0x7c/0xb0)
[ 21.707636] [<c0aee568>] (sctp_ctrlsock_init) from [<c0963f50>] (ops_init+0xc0/0x174)
[ 21.715551] [<c0963f50>] (ops_init) from [<c0964960>] (register_pernet_operations+0x124/0x1a8)
[ 21.724251] [<c0964960>] (register_pernet_operations) from [<c0964a20>] (register_pernet_subsys+0x3c/0x50)
[ 21.734016] [<c0964a20>] (register_pernet_subsys) from [<c0fcc348>] (sctp_init+0x458/0x500)
[ 21.742465] [<c0fcc348>] (sctp_init) from [<c00098fc>] (do_one_initcall+0xd8/0x22c)
[ 21.750218] [<c00098fc>] (do_one_initcall) from [<c0f76078>] (kernel_init_freeable+0x250/0x2ec)
[ 21.759019] [<c0f76078>] (kernel_init_freeable) from [<c0b18f08>] (kernel_init+0x1c/0xf8)
[ 21.767295] [<c0b18f08>] (kernel_init) from [<c0011024>] (ret_from_fork+0x14/0x30)
Sometime this RCU not come out, but the situation i described below is remained。
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.113 (mgkiller) (gcc version 6.3.0 (crosstool-NG crosstool-ng-1.22.0) ) #4 SMP PREEMPT Wed Mar 27 19:55:01 HKT 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 48 MiB at 0x9d000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon )
[ 0.000000] PERCPU: Embedded 366 pages/cpu @dc9c6000 s1468288 r8192 d22656 u1499136
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 board=eg9041 uboot_ver=V1.0.0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 406380K/524288K available (12155K kernel code, 915K rwdata, 3640K rodata, 36204K init, 9009K bss, 68756K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0f74ebc (15796 kB)
[ 0.000000] .init : 0xc0f75000 - 0xc32d0000 (36204 kB)
[ 0.000000] .data : 0xc32d0000 - 0xc33b4dcc ( 916 kB)
[ 0.000000] .bss : 0xc33b7000 - 0xc3c834ac (9010 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Running RCU self tests
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU lockdep checking is enabled.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000045] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000129] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000329] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002049] clocksource_probe: no matching clocksources found
[ 0.004788] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.004847] This ensures that you still see kernel messages. Please
[ 0.004884] update your kernel commandline.
[ 0.004922] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.004960] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.004996] ... MAX_LOCK_DEPTH: 48
[ 0.005031] ... MAX_LOCKDEP_KEYS: 8191
[ 0.005067] ... CLASSHASH_SIZE: 4096
[ 0.005103] ... MAX_LOCKDEP_ENTRIES: 32768
[ 0.005139] ... MAX_LOCKDEP_CHAINS: 65536
[ 0.005175] ... CHAINHASH_SIZE: 32768
[ 0.005211] memory used by lock dependency info: 5423 kB
[ 0.005248] per task-struct memory footprint: 2304 bytes
[ 0.005285] ------------------------
[ 0.005319] | Locking API testsuite:
[ 0.005355] ----------------------------------------------------------------------------
[ 0.005392] | spin |wlock |rlock |mutex | wsem | rsem |
[ 0.005427] --------------------------------------------------------------------------
[ 0.005534] A-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.042017] A-B-B-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.077908] A-B-B-C-C-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.115107] A-B-C-A-B-C deadlock: ok | ok | ok | ok | ok | ok |
[ 0.152535] A-B-B-C-C-D-D-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.191601] A-B-C-D-B-D-D-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.230475] A-B-C-D-B-C-D-A deadlock: ok | ok | ok | ok | ok | ok |
[ 0.269422] double unlock: ok | ok | ok | ok | ok | ok |
[ 0.304055] initialize held: ok | ok | ok | ok | ok | ok |
[ 0.338590] bad unlock order: ok | ok | ok | ok | ok | ok |
[ 0.374502] --------------------------------------------------------------------------
[ 0.374554] recursive read-lock: | ok | | ok |
[ 0.386162] recursive read-lock #2: | ok | | ok |
[ 0.397935] mixed read-write-lock: | ok | | ok |
[ 0.409889] mixed write-read-lock: | ok | | ok |
[ 0.421648] --------------------------------------------------------------------------
[ 0.421776] hard-irqs-on + irq-safe-A/12: ok | ok | ok |
[ 0.439140] soft-irqs-on + irq-safe-A/12: ok | ok | ok |
[ 0.456595] hard-irqs-on + irq-safe-A/21: ok | ok | ok |
[ 0.474025] soft-irqs-on + irq-safe-A/21: ok | ok | ok |
[ 0.491671] sirq-safe-A => hirqs-on/12: ok | ok | ok |
[ 0.509236] sirq-safe-A => hirqs-on/21: ok | ok | ok |
[ 0.526678] hard-safe-A + irqs-on/12: ok | ok | ok |
[ 0.544040] soft-safe-A + irqs-on/12: ok | ok | ok |
[ 0.561525] hard-safe-A + irqs-on/21: ok | ok | ok |
[ 0.579165] soft-safe-A + irqs-on/21: ok | ok | ok |
[ 0.596633] hard-safe-A + unsafe-B #1/123: ok | ok | ok |
[ 0.614744] soft-safe-A + unsafe-B #1/123: ok | ok | ok |
[ 0.632867] hard-safe-A + unsafe-B #1/132: ok | ok | ok |
[ 0.650967] soft-safe-A + unsafe-B #1/132: ok | ok | ok |
[ 0.669085] hard-safe-A + unsafe-B #1/213: ok | ok | ok |
[ 0.687260] soft-safe-A + unsafe-B #1/213: ok | ok | ok |
[ 0.705613] hard-safe-A + unsafe-B #1/231: ok | ok | ok |
[ 0.723945] soft-safe-A + unsafe-B #1/231: ok | ok | ok |
[ 0.741974] hard-safe-A + unsafe-B #1/312: ok | ok | ok |
[ 0.759750] soft-safe-A + unsafe-B #1/312: ok | ok | ok |
[ 0.777629] hard-safe-A + unsafe-B #1/321: ok | ok | ok |
[ 0.795933] soft-safe-A + unsafe-B #1/321: ok | ok | ok |
[ 0.813935] hard-safe-A + unsafe-B #2/123: ok | ok | ok |
[ 0.831839] soft-safe-A + unsafe-B #2/123: ok | ok | ok |
[ 0.850033] hard-safe-A + unsafe-B #2/132: ok | ok | ok |
[ 0.867856] soft-safe-A + unsafe-B #2/132: ok | ok | ok |
[ 0.885893] hard-safe-A + unsafe-B #2/213: ok | ok | ok |
[ 0.903956] soft-safe-A + unsafe-B #2/213: ok | ok | ok |
[ 0.921999] hard-safe-A + unsafe-B #2/231: ok | ok | ok |
[ 0.939979] soft-safe-A + unsafe-B #2/231: ok | ok | ok |
[ 0.957928] hard-safe-A + unsafe-B #2/312: ok | ok | ok |
[ 0.975920] soft-safe-A + unsafe-B #2/312: ok | ok | ok |
[ 0.993994] hard-safe-A + unsafe-B #2/321: ok | ok | ok |
[ 1.011987] soft-safe-A + unsafe-B #2/321: ok | ok | ok |
[ 1.029946] hard-irq lock-inversion/123: ok | ok | ok |
[ 1.047875] soft-irq lock-inversion/123: ok | ok | ok |
[ 1.065953] hard-irq lock-inversion/132: ok | ok | ok |
[ 1.083979] soft-irq lock-inversion/132: ok | ok | ok |
[ 1.102052] hard-irq lock-inversion/213: ok | ok | ok |
[ 1.119953] soft-irq lock-inversion/213: ok | ok | ok |
[ 1.138015] hard-irq lock-inversion/231: ok | ok | ok |
[ 1.155831] soft-irq lock-inversion/231: ok | ok | ok |
[ 1.174017] hard-irq lock-inversion/312: ok | ok | ok |
[ 1.191866] soft-irq lock-inversion/312: ok | ok | ok |
[ 1.209941] hard-irq lock-inversion/321: ok | ok | ok |
[ 1.227942] soft-irq lock-inversion/321: ok | ok | ok |
[ 1.245902] hard-irq read-recursion/123: ok |
[ 1.251937] soft-irq read-recursion/123: ok |
[ 1.258021] hard-irq read-recursion/132: ok |
[ 1.264062] soft-irq read-recursion/132: ok |
[ 1.270151] hard-irq read-recursion/213: ok |
[ 1.276188] soft-irq read-recursion/213: ok |
[ 1.282269] hard-irq read-recursion/231: ok |
[ 1.288303] soft-irq read-recursion/231: ok |
[ 1.294388] hard-irq read-recursion/312: ok |
[ 1.300419] soft-irq read-recursion/312: ok |
[ 1.306511] hard-irq read-recursion/321: ok |
[ 1.312538] soft-irq read-recursion/321: ok |
[ 1.318633] --------------------------------------------------------------------------
[ 1.318682] | Wound/wait tests |
[ 1.318719] ---------------------
[ 1.318755] ww api failures: ok | ok | ok |
[ 1.336710] ww contexts mixing: ok | ok |
[ 1.348460] finishing ww context: ok | ok | ok | ok |
[ 1.371935] locking mismatches: ok | ok | ok |
[ 1.390037] EDEADLK handling: ok | ok | ok | ok | ok | ok | ok | ok | ok | ok |
[ 1.450154] spinlock nest unlocked: ok |
[ 1.455970] -----------------------------------------------------
[ 1.456016] |block | try |context|
[ 1.456053] -----------------------------------------------------
[ 1.456090] context: ok | ok | ok |
[ 1.474097] try: ok | ok | ok |
[ 1.491848] block: ok | ok | ok |
[ 1.509570] spinlock: ok | ok | ok |
[ 1.528328] -------------------------------------------------------
[ 1.528378] Good, all 253 testcases passed! |
[ 1.528414] ---------------------------------
[ 1.528683] Calibrating delay loop... 286.46 BogoMIPS (lpj=572928)
[ 1.561895] pid_max: default: 32768 minimum: 301
[ 1.564559] Security Framework initialized
[ 1.564624] Yama: becoming mindful.
[ 1.565162] Smack: Initializing.
[ 1.565206] Smack: Netfilter enabled.
[ 1.565335] AppArmor: AppArmor disabled by boot time parameter
[ 1.566747] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.566812] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.589122] Initializing cgroup subsys io
[ 1.589631] Initializing cgroup subsys memory
[ 1.590282] Initializing cgroup subsys devices
[ 1.590728] Initializing cgroup subsys freezer
[ 1.591150] Initializing cgroup subsys net_cls
[ 1.591311] Initializing cgroup subsys perf_event
[ 1.591468] Initializing cgroup subsys pids
[ 1.592418] CPU: Testing write buffer coherency: ok
[ 1.593167] ftrace: allocating 33507 entries in 99 pages
[ 1.939005] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 1.939439] Setting up static identity map for 0x80008280 - 0x800082e0
[ 2.002314] Brought up 1 CPUs
[ 2.002397] SMP: Total of 1 processors activated (286.46 BogoMIPS).
[ 2.002435] CPU: All CPU(s) started in SVC mode.
[ 2.337527] evm: security.selinux
[ 2.337602] evm: security.SMACK64
[ 2.337637] evm: security.SMACK64EXEC
[ 2.337852] evm: security.SMACK64TRANSMUTE
[ 2.337893] evm: security.SMACK64MMAP
[ 2.337925] evm: security.capability
[ 2.343539] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.792178] omap_hwmod: debugss: _wait_target_disable failed
[ 2.860333] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 2.860624] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 2.883089] xor: measuring software checksum speed
[ 2.921900] arm4regs : 348.000 MB/sec
[ 2.961889] 8regs : 312.000 MB/sec
[ 3.001902] 32regs : 311.000 MB/sec
[ 3.041895] neon : 475.000 MB/sec
[ 3.041940] xor: using function: neon (475.000 MB/sec)
[ 3.042108] pinctrl core: initialized pinctrl subsystem
[ 3.073386] NET: Registered protocol family 16
[ 3.117468] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 3.138807] cpuidle: using governor ladder
[ 3.150789] cpuidle: using governor menu
[ 3.248723] OMAP GPIO hardware version 0.1
[ 3.463180] No ATAGs?
[ 3.463299] hw-breakpoint: debug architecture 0x4 unsupported.
[ 3.746410] raid6: neonx2 gen() 537 MB/s
[ 3.813891] raid6: neonx2 xor() 333 MB/s
[ 3.813938] raid6: using algorithm neonx2 gen() 537 MB/s
[ 3.813974] raid6: .... xor() 333 MB/s, rmw enabled
[ 3.814010] raid6: using intx1 recovery algorithm
[ 3.988547] edma 49000000.edma: TI EDMA DMA engine driver
[ 4.005517] SCSI subsystem initialized
[ 4.011907] usbcore: registered new interface driver usbfs
[ 4.013063] usbcore: registered new interface driver hub
[ 4.014949] usbcore: registered new device driver usb
[ 4.030779] i2c-gpio ocp:i2c@3: using pins 0 (SDA) and 1 (SCL)
[ 4.034294] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferring probe
[ 4.034923] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c2_pins, deferring probe
[ 4.036721] pps_core: LinuxPPS API ver. 1 registered
[ 4.036768] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.037158] PTP clock support registered
[ 4.051940] Advanced Linux Sound Architecture Driver Initialized.
[ 4.069660] NetLabel: Initializing
[ 4.070073] NetLabel: domain hash size = 128
[ 4.070107] NetLabel: protocols = UNLABELED CIPSOv4
[ 4.071146] NetLabel: unlabeled traffic allowed by default
[ 4.074478] clocksource: Switched to clocksource timer1
[ 7.002232] NET: Registered protocol family 2
[ 7.016255] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 7.016628] TCP bind hash table entries: 4096 (order: 5, 180224 bytes)
[ 7.023884] TCP: Hash tables configured (established 4096 bind 4096)
[ 7.024678] UDP hash table entries: 256 (order: 2, 24576 bytes)
[ 7.025609] UDP-Lite hash table entries: 256 (order: 2, 24576 bytes)
[ 7.031189] NET: Registered protocol family 1
[ 7.045624] RPC: Registered named UNIX socket transport module.
[ 7.045943] RPC: Registered udp transport module.
[ 7.045999] RPC: Registered tcp transport module.
[ 7.046046] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 11.655006] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 11.696999] audit: initializing netlink subsys (disabled)
[ 11.698556] audit: type=2000 audit(11.100:1): initialized
[ 11.937283] zbud: loaded
[ 11.951542] VFS: Disk quotas dquot_6.6.0
[ 11.956815] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 12.032546] NFS: Registering the id_resolver key type
[ 12.034629] Key type id_resolver registered
[ 12.034707] Key type id_legacy registered
[ 12.034938] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 12.038725] fuse init (API version 7.23)
[ 12.045640] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 12.271893] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 12.280684] io scheduler noop registered
[ 12.280816] io scheduler deadline registered
[ 12.283280] io scheduler cfq registered (default)
[ 12.294226] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 12.312435] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 12.385178] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 13.968015] console [ttyS0] enabled
[ 13.987361] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 159, base_baud = 3000000) is a 8250
[ 14.011715] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 160, base_baud = 3000000) is a 8250
[ 14.047033] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 14.246854] brd: module loaded
[ 14.342350] vcan: Virtual CAN interface driver
[ 14.347119] CAN device driver interface
[ 14.368582] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=165)
[ 15.608567] dummy phy addr is 0x3, we always return 0x221430!
[ 19.315944] libphy: 4a101000.mdio: probed
[ 19.321220] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown
[ 19.330597] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
[ 19.339338] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver unknown
[ 19.348044] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver Micrel KSZ886X or KSZ8895
[ 19.357829] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver unknown
[ 19.366022] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[ 19.374211] davinci_mdio 4a101000.mdio: phy[6]: device 4a101000.mdio:06, driver unknown
[ 19.382399] davinci_mdio 4a101000.mdio: phy[7]: device 4a101000.mdio:07, driver unknown
[ 19.390586] davinci_mdio 4a101000.mdio: phy[8]: device 4a101000.mdio:08, driver unknown
[ 19.398772] davinci_mdio 4a101000.mdio: phy[9]: device 4a101000.mdio:09, driver unknown
[ 19.406958] davinci_mdio 4a101000.mdio: phy[10]: device 4a101000.mdio:0a, driver unknown
[ 19.415717] davinci_mdio 4a101000.mdio: phy[11]: device 4a101000.mdio:0b, driver unknown
[ 19.424038] davinci_mdio 4a101000.mdio: phy[12]: device 4a101000.mdio:0c, driver unknown
[ 19.432321] davinci_mdio 4a101000.mdio: phy[13]: device 4a101000.mdio:0d, driver unknown
[ 19.440597] davinci_mdio 4a101000.mdio: phy[14]: device 4a101000.mdio:0e, driver unknown
[ 19.448873] davinci_mdio 4a101000.mdio: phy[15]: device 4a101000.mdio:0f, driver unknown
[ 19.457148] davinci_mdio 4a101000.mdio: phy[16]: device 4a101000.mdio:10, driver unknown
[ 19.465423] davinci_mdio 4a101000.mdio: phy[17]: device 4a101000.mdio:11, driver unknown
[ 19.473991] davinci_mdio 4a101000.mdio: phy[18]: device 4a101000.mdio:12, driver unknown
[ 19.482296] davinci_mdio 4a101000.mdio: phy[19]: device 4a101000.mdio:13, driver unknown
[ 19.490576] davinci_mdio 4a101000.mdio: phy[20]: device 4a101000.mdio:14, driver unknown
[ 19.498852] davinci_mdio 4a101000.mdio: phy[21]: device 4a101000.mdio:15, driver unknown
[ 19.507129] davinci_mdio 4a101000.mdio: phy[22]: device 4a101000.mdio:16, driver unknown
[ 19.515405] davinci_mdio 4a101000.mdio: phy[23]: device 4a101000.mdio:17, driver unknown
[ 19.523681] davinci_mdio 4a101000.mdio: phy[24]: device 4a101000.mdio:18, driver unknown
[ 19.531955] davinci_mdio 4a101000.mdio: phy[25]: device 4a101000.mdio:19, driver unknown
[ 19.540229] davinci_mdio 4a101000.mdio: phy[26]: device 4a101000.mdio:1a, driver unknown
[ 19.548504] davinci_mdio 4a101000.mdio: phy[27]: device 4a101000.mdio:1b, driver unknown
[ 19.556779] davinci_mdio 4a101000.mdio: phy[28]: device 4a101000.mdio:1c, driver unknown
[ 19.565054] davinci_mdio 4a101000.mdio: phy[29]: device 4a101000.mdio:1d, driver unknown
[ 19.573331] davinci_mdio 4a101000.mdio: phy[30]: device 4a101000.mdio:1e, driver unknown
[ 19.581604] davinci_mdio 4a101000.mdio: phy[31]: device 4a101000.mdio:1f, driver unknown
[ 19.616755] cpsw 4a100000.ethernet: Detected MACID = 58:7a:62:c6:f6:4b
[ 19.642921] cpsw 4a100000.ethernet: cpts: overflow check period 5250
[ 19.665027] PPP generic driver version 2.4.2
[ 19.673570] PPP BSD Compression module registered
[ 19.678666] PPP Deflate Compression module registered
[ 19.684059] PPP MPPE Compression module registered
[ 19.689126] NET: Registered protocol family 24
[ 19.695068] usbcore: registered new interface driver cdc_ether
[ 19.702273] usbcore: registered new interface driver cdc_eem
[ 19.708940] usbcore: registered new interface driver rndis_host
[ 19.716419] usbcore: registered new interface driver cdc_ncm
[ 19.723184] usbcore: registered new interface driver qmi_wwan
[ 19.730247] usbcore: registered new interface driver cdc_mbim
[ 19.742564] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 19.749677] ehci-pci: EHCI PCI platform driver
[ 19.755475] ehci-platform: EHCI generic platform driver
[ 19.763532] ehci-omap: OMAP-EHCI Host Controller driver
[ 19.771347] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 19.778654] ohci-pci: OHCI PCI platform driver
[ 19.784281] ohci-platform: OHCI generic platform driver
[ 19.796635] usbcore: registered new interface driver cdc_wdm
[ 19.803741] usbcore: registered new interface driver usb-storage
[ 19.811688] usbcore: registered new interface driver usbserial
[ 19.818395] usbcore: registered new interface driver usbserial_generic
[ 19.827879] usbserial: USB Serial support registered for generic
[ 19.834919] usbcore: registered new interface driver ftdi_sio
[ 19.841597] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 19.850081] usbcore: registered new interface driver ipw
[ 19.856278] usbserial: USB Serial support registered for IPWireless converter
[ 19.864342] usbcore: registered new interface driver sierra
[ 19.870877] usbserial: USB Serial support registered for Sierra USB modem
[ 19.900276] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 19.928553] ### usb_create_hcd: musb_hc_driver musb=dc2fe010
[ 19.937166] musb-hdrc musb-hdrc.0.auto: use_dma=1.
[ 19.943146] musb-hdrc musb-hdrc.0.auto: Failed to request rx1.
[ 19.951515] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517
[ 19.972378] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 19.994807] ### usb_create_hcd: musb_hc_nodma_driver musb=dc2fe010
[ 20.003529] musb-hdrc musb-hdrc.1.auto: use_dma=0.
[ 20.012478] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 20.022582] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 20.039177] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 20.046231] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.053643] usb usb1: Product: MUSB HDRC host driver
[ 20.058778] usb usb1: Manufacturer: Linux 4.4.113 musb-hcd-nodma
[ 20.064955] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 20.091602] hub 1-0:1.0: USB hub found
[ 20.097331] hub 1-0:1.0: 1 port detected
[ 20.323109] omap_rtc 44e3e000.rtc: already running
[ 20.334868] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 20.346464] i2c /dev entries driver
[ 20.409405] i2c i2c-3: sendbytes: NAK bailout.
[ 20.442139] i2c i2c-3: sendbytes: NAK bailout.
[ 20.472327] i2c i2c-3: sendbytes: NAK bailout.
[ 20.526352] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 20.582118] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 20.600643] cpuidle: enable-method property 'ti,am3352' found operations
[ 20.664220] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 20.678820] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 20.693137] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 20.714388] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 20.763174] hub 1-1:1.0: USB hub found
[ 20.772988] mmc0: MAN_BKOPS_EN bit is not set
[ 20.783059] hub 1-1:1.0: 7 ports detected
[ 20.795074] mmc0: new high speed MMC card at address 0001
[ 20.880676] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 20.886916] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 20.921108] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 20.967629] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 20.974104] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 21.083319] mmcblk0: p1 p2 p3
[ 21.148108] ksz886x: probe dev ok.
[ 21.202848] Dummypcm probe...
[ 21.206327] usb 1-1.2: new full-speed USB device number 3 using musb-hdrc
[ 21.260818] davinci_evm sound: dummypcm-hifi <-> 4803c000.mcasp mapping ok
[ 21.296930] Netfilter messages via NETLINK v0.30.
[ 21.302645] nf_conntrack version 0.5.0 (7117 buckets, 28468 max)
[ 21.319800] ctnetlink v0.93: registering with nfnetlink.
[ 21.333370] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 21.341521] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523
[ 21.348662] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 21.356748] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
[ 21.364259] usb 1-1.2: Product: USB2.0-Serial
[ 21.380604] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 21.395850] arp_tables: (C) 2002 David S. Miller
[ 21.412147] Initializing XFRM netlink socket
[ 21.423602] NET: Registered protocol family 17
[ 21.431174] NET: Registered protocol family 15
[ 21.437683] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 21.452420] can: controller area network core (rev 20120528 abi 9)
[ 21.460129] NET: Registered protocol family 29
[ 21.465157] can: raw protocol (rev 20120528)
[ 21.470661] can: broadcast manager protocol (rev 20120528 t)
[ 21.476748] can: netlink gateway (rev 20130117) max_hops=1
[ 21.488836] 8021q: 802.1Q VLAN Support v1.8
[ 21.495471] sctp: Hash tables configured (established 85 bind 64)
[ 21.506465] usb 1-1.3: new full-speed USB device number 4 using musb-hdrc
[ 21.515785]
[ 21.541766]
[ 21.541766]
[ 21.549940]
[ 21.586187]
[ 21.776264] Key type dns_resolver registered
[ 21.780814] mpls_gso: MPLS GSO support
[ 21.785051] omap_voltage_late_init: Voltage driver support not added
[ 21.798797] ThumbEE CPU extension supported.
[ 21.803404] Registering SWP/SWPB emulation handler
[ 21.814481] registered taskstats version 1
[ 21.819490] zswap: loaded using pool lzo/zbud
[ 21.852961] Btrfs loaded
[ 21.880769] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523
[ 21.894084] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 21.910041] usb 1-1.3: Product: USB2.0-Serial
[ 22.014486] usb 1-1.4: new full-speed USB device number 5 using musb-hdrc
[ 22.124954] Key type encrypted registered
[ 22.130597] evm: HMAC attrs: 0x1
[ 22.136814] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523
[ 22.146726] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 22.161982] usb 1-1.4: Product: USB2.0-Serial
[ 22.247248] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
[ 22.262157] usb 1-1.5: new full-speed USB device number 6 using musb-hdrc
[ 22.330981] lm75 2-0049: hwmon0: sensor 'lm75a'
[ 22.337357] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 22.344313] ### usb_create_hcd: musb_hc_driver musb=dc756010
[ 22.351752] musb-hdrc musb-hdrc.0.auto: use_dma=1.
[ 22.367862] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 22.379831] musb-hdrc: MHDRC RTL version 2.0
[ 22.384815] musb-hdrc: setup fifo_mode 4
[ 22.389465] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
[ 22.396590] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 22.402026] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 22.410528] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 22.416572] usb 1-1.5: Product: USB2.0-Serial
[ 22.421332] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 22.439149] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 22.448482] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 22.455957] usb usb2: Product: MUSB HDRC host driver
[ 22.461090] usb usb2: Manufacturer: Linux 4.4.113 musb-hcd
[ 22.467145] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 22.476921] hub 2-0:1.0: USB hub found
[ 22.481141] hub 2-0:1.0: 1 port detected
[ 22.498602] core: _opp_supported_by_regulators: OPP minuV: 1176000 maxuV: 1224000, not supported by regulator
[ 22.509100] cpu cpu0: _opp_add: OPP not supported by regulators (720000000)
[ 22.518398] core: _opp_supported_by_regulators: OPP minuV: 1234800 maxuV: 1285200, not supported by regulator
[ 22.528774] cpu cpu0: _opp_add: OPP not supported by regulators (800000000)
[ 22.537479] core: _opp_supported_by_regulators: OPP minuV: 1298500 maxuV: 1351500, not supported by regulator
[ 22.547783] usb 1-1.6: new full-speed USB device number 7 using musb-hdrc
[ 22.554806] cpu cpu0: _opp_add: OPP not supported by regulators (1000000000)
[ 22.571617] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 22.580457] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:06:31 UTC (946685191)
[ 22.590186] of_cfs_init
[ 22.593088] of_cfs_init: OK
[ 22.626860] PM: Hibernation image not present or could not be loaded.
[ 22.633949] ALSA device list:
[ 22.636963] #0: TI DUMMYPCM
[ 22.667384] usb 1-1.6: New USB device found, idVendor=1a86, idProduct=7523
[ 22.681779] usb 1-1.6: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 22.693768] usb 1-1.6: Product: USB2.0-Serial
[ 22.772873] Freeing unused kernel memory: 36204K
[ 22.802313] usb 1-1.7: new full-speed USB device number 8 using musb-hdrc
[ 22.874033] usb 2-1: new high-speed USB device number 2 using musb-hdrc
ROS system init ...
[ 22.923937] usb 1-1.7: New USB device found, idVendor=1a86, idProduct=7523
[ 22.938271] usb 1-1.7: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 22.954056] usb 1-1.7: Product: USB2.0-Serial
[ 23.075053] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 23.090225] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 23.102141] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 23.116686] hub 2-1:1.0: USB hub found
[ 23.126236] hub 2-1:1.0: 7 ports detected
mkdir: can't create directory '/etc/ppp': File exists
[ 30.955246] EXT4-fs (mmcblk0p2): recovery complete
[ 30.961284] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 31.214771] random: nonblocking pool is initialized
[ 31.239919] EXT4-fs (mmcblk0p3): recovery complete
[ 31.246133] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 32.157128] zl380tw: disagrees about version of symbol module_layout
[ 32.165241] zl380tw: disagrees about version of symbol module_layout
modprobe: 'zl380tw.ko': invalid module format
[ 32.216516] usbcore: registered new interface driver cdc_acm
[ 32.238136] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
