Linux/AM5728: DSP app load fails
Part Number: AM5728
Tool/software: Linux
TI,
I am working on am5728.I load the dsp app like that:
DSP1:
rm /lib/firmware/dra7-dsp1-fw.xe66
ln -s /home/root/server_dsp1.xe66 /lib/firmware/dra7-dsp1-fw.xe66
echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind
echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/bind
DSP2:
rm /lib/firmware/dra7-dsp2-fw.xe66
ln -s /home/root/server_dsp2.xe66 /lib/firmware/dra7-dsp2-fw.xe66
echo 41000000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind
echo 41000000.dsp > /sys/bus/platform/drivers/omap-rproc/bind
Now the problem is that somtimes the linux system will panic after dsp run,and the probability of this happening is low.The log below:
root@am57xx-evm:~# [ 17.645914] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 18.175945] remoteproc1: releasing 41000000.dsp
[ 18.383333] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@a0400000
[ 18.391180] remoteproc1: 41000000.dsp is available
[ 18.397963] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 18.407816] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 18.534743] remoteproc1: powering up 41000000.dsp
[ 18.543672] remoteproc1: Booting fw image dra7-dsp2-fw.xe66, size 8606848
[ 18.562811] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 18.568748] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 18.599585] remoteproc1: remote processor 41000000.dsp is now up
[ 18.606146] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 18.611677] remoteproc1: registered virtio1 (type 7)
[ 18.623170] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 18.630549] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
[ 18.639426] virtio_rpmsg_bus virtio1: msg received with no recipient
[ 19.585427] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 19.595034] virtio_rpmsg_bus virtio1: msg received with no recipient
[ 20.546383] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 20.556620] virtio_rpmsg_bus virtio1: msg received with no recipient
sizeof(off_t) = 8
[ 21.508319] Unable to handle kernel NULL pointer dereference at virtual address 00000070
[ 21.516468] pgd = c0003000
[ 21.519191] [00000070] *pgd=80000080004003, *pmd=00000000
[ 21.524626] Internal error: Oops: 205 [#1] PREEMPT ARM
[ 21.529782] Modules linked in: rpmsg_proto virtio_rpmsg_bus bc_example(O) xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 pwm_fan af_key xfrm_algo pwm_omap_dmtimer pvrsrvkm(O) omap_wdt rtc_omap m25p80 extcon_palmas omap_rng rng_core debugss_kmodule(O) omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cmemk(O)
[ 21.561992] CPU: 0 PID: 554 Comm: kworker/0:4 Tainted: G W O 4.4.19-03023-g2d41985 #1
[ 21.570810] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 21.576932] Workqueue: events mbox_rx_work
[ 21.581048] task: ee217180 ti: ee28c000 task.ti: ee28c000
[ 21.586468] PC is at lock_sock_nested+0x2c/0x8c
[ 21.591021] LR is at rpmsg_proto_cb+0x38/0x150 [rpmsg_proto]
[ 21.596702] pc : [<c056d790>] lr : [<bf14d7f8>] psr: 200f0013
[ 21.596702] sp : ee28ddb8 ip : ee28ddd0 fp : ee28ddcc
[ 21.608225] r10: 00000002 r9 : d7c40e10 r8 : 0000003d
[ 21.613468] r7 : 000001e4 r6 : ee0c5408 r5 : ee7d1f40 r4 : 00000000
[ 21.620019] r3 : 00000201 r2 : ee28c000 r1 : 00000000 r0 : 00000000
[ 21.626571] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 21.633908] Control: 30c53c7d Table: ae7c9140 DAC: fffffffd
[ 21.639675] Process kworker/0:4 (pid: 554, stack limit = 0xee28c208)
[ 21.646053] Stack: (0xee28ddb8 to 0xee28e000)
[ 21.650426] dda0: 00000000 ee7d1f40
[ 21.658636] ddc0: ee28de04 ee28ddd0 bf14d7f8 c056d770 ee28ddec ee28dde0 c001add0 ee7d1f44
[ 21.666846] dde0: ee7d1f40 d7c40e00 ee7fcd00 ee7d1f4c 00000000 bf14d7c0 ee28de74 ee28de08
[ 21.675057] de00: bf145f98 bf14d7cc 0000003d ee2171b0 00000001 bf146a78 bf146d50 bf146ab8
[ 21.683267] de20: ee10f018 024000c0 ee3aa800 ee7fcd44 ffffffff 00000200 01d79b27 00000000
[ 21.691478] de40: 00000200 c0991de0 ee2171b0 ee025644 ee28c000 c089b48c ef609600 c0991638
[ 21.699687] de60: 00000000 ee3fa600 ee28de84 ee28de78 bf024168 bf145ed0 ee28de94 ee28de88
[ 21.707896] de80: bf0337d4 bf024134 ee28deac ee28de98 bf03ee3c bf033794 ee089614 ee28c000
[ 21.716106] dea0: ee28debc ee28deb0 c055a2b4 bf03ed74 ee28dee4 ee28dec0 c055b608 c055a2a0
[ 21.724315] dec0: c068d978 00000000 ee089614 ee089614 ee3fa600 00000000 ee28df24 ee28dee8
[ 21.732524] dee0: c004756c c055b5b0 c0991638 00000008 ffffe000 c0991648 c0991638 c0991638
[ 21.740735] df00: ee3fa618 00000008 ffffe000 c0991648 c0991638 ee3fa600 ee28df64 ee28df28
[ 21.748945] df20: c00478d4 c0047440 c0991798 c0991648 c0993f40 c09db367 00000000 00000000
[ 21.757155] df40: ee2bd700 ee3fa600 c0047858 00000000 00000000 00000000 ee28dfac ee28df68
[ 21.765363] df60: c004d3cc c0047864 00000000 00000000 ee2bd700 ee3fa600 00000000 ee28df7c
[ 21.773573] df80: ee28df7c 00000000 ee28df88 ee28df88 ee2bd700 c004d2f0 00000000 00000000
[ 21.781782] dfa0: 00000000 ee28dfb0 c000f968 c004d2fc 00000000 00000000 00000000 00000000
[ 21.789991] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 21.798201] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 21.806407] Backtrace:
[ 21.808874] [<c056d764>] (lock_sock_nested) from [<bf14d7f8>] (rpmsg_proto_cb+0x38/0x150 [rpmsg_proto])
[ 21.818302] r5:ee7d1f40 r4:00000000
[ 21.821915] [<bf14d7c0>] (rpmsg_proto_cb [rpmsg_proto]) from [<bf145f98>] (rpmsg_recv_done+0xd4/0x278 [virtio_rpmsg_bus])
[ 21.832913] r10:bf14d7c0 r9:00000000 r8:ee7d1f4c r7:ee7fcd00 r6:d7c40e00 r5:ee7d1f40
[ 21.840804] r4:ee7d1f44
[ 21.843364] [<bf145ec4>] (rpmsg_recv_done [virtio_rpmsg_bus]) from [<bf024168>] (vring_interrupt+0x40/0x58 [virtio_ring])
[ 21.854362] r10:ee3fa600 r9:00000000 r8:c0991638 r7:ef609600 r6:c089b48c r5:ee28c000
[ 21.862254] r4:ee025644
[ 21.864818] [<bf024128>] (vring_interrupt [virtio_ring]) from [<bf0337d4>] (rproc_vq_interrupt+0x4c/0x70 [remoteproc])
[ 21.875573] [<bf033788>] (rproc_vq_interrupt [remoteproc]) from [<bf03ee3c>] (omap_rproc_mbox_callback+0xd4/0xec [omap_remoteproc])
[ 21.887453] [<bf03ed68>] (omap_rproc_mbox_callback [omap_remoteproc]) from [<c055a2b4>] (mbox_chan_received_data+0x20/0x24)
[ 21.898624] r5:ee28c000 r4:ee089614
[ 21.902228] [<c055a294>] (mbox_chan_received_data) from [<c055b608>] (mbox_rx_work+0x64/0xf0)
[ 21.910791] [<c055b5a4>] (mbox_rx_work) from [<c004756c>] (process_one_work+0x138/0x424)
[ 21.918912] r6:00000000 r5:ee3fa600 r4:ee089614
[ 21.923566] [<c0047434>] (process_one_work) from [<c00478d4>] (worker_thread+0x7c/0x648)
[ 21.931686] r10:ee3fa600 r9:c0991638 r8:c0991648 r7:ffffe000 r6:00000008 r5:ee3fa618
[ 21.939580] r4:c0991638
[ 21.942132] [<c0047858>] (worker_thread) from [<c004d3cc>] (kthread+0xdc/0xf4)
[ 21.949381] r10:00000000 r9:00000000 r8:00000000 r7:c0047858 r6:ee3fa600 r5:ee2bd700
[ 21.957271] r4:00000000
[ 21.959823] [<c004d2f0>] (kthread) from [<c000f968>] (ret_from_fork+0x14/0x2c)
[ 21.967070] r7:00000000 r6:00000000 r5:c004d2f0 r4:ee2bd700
[ 21.972779] Code: e5923004 e2833c02 e2833001 e5823004 (e5903070)
[ 21.978916] ---[ end trace cb88537fdc8fa202 ]---
[ 21.983551] Kernel panic - not syncing: Fatal exception in interrupt
[ 21.989932] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Detailed debugging information are below:
U-Boot 2016.05-00045-g2eaf7b1 (Sep 18 2018 - 10:02:57 +0800)
CPU  : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15
Board: AM572x EVM REV A.30
I2C:   ready
DRAM:  1 GiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
reading logo.yuv
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:   eth0: ethernet@48484000
Hit any key to stop autoboot:  0
Saving Environment to FAT...
writing uboot.env
FAT: Misaligned buffer address (bef1ef60)
done
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
** Invalid partition 2 **
mmc1(part 0) is current device
SD/MMC found on device 1
5270048 bytes read in 134 ms (37.5 MiB/s)
107515 bytes read in 7 ms (14.6 MiB/s)
Booting from mmc1 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x506a20 ]
   Loading Device Tree to 8ffe2000, end 8ffff3fa ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.19-03023-g2d41985 (vefone@F-VirtualMachine) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 PREEMPT Thu Nov 29 09:31:19 CST 2018
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI AM572x EVM Rev A3
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 36 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000097c00000, size 100 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@97c00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 36 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9e000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a0400000, size 100 MiB
[    0.000000] Reserved memory: initialized node dsp2_cma@a0400000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 80 MiB at 0x00000000bac00000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[    0.000000] ------------[ cut here ]------------
[    0.000000] WARNING: CPU: 0 PID: 0 at arch/arm/kernel/devtree.c:149 arm_dt_init_cpu_maps+0x104/0x144()
[    0.000000] DT /cpu 2 nodes greater than max cores 1, capping them
[    0.000000] Modules linked in:
[    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 4.4.19-03023-g2d41985 #1
[    0.000000] Hardware name: Generic DRA74X (Flattened Device Tree)
[    0.000000] Backtrace:
[    0.000000] [<c0012bfc>] (dump_backtrace) from [<c0012df8>] (show_stack+0x18/0x1c)
[    0.000000]  r7:c08ed110 r6:00000095 r5:00000009 r4:00000000
[    0.000000] [<c0012de0>] (show_stack) from [<c02aa470>] (dump_stack+0x24/0x28)
[    0.000000] [<c02aa44c>] (dump_stack) from [<c003265c>] (warn_slowpath_common+0x88/0xb4)
[    0.000000] [<c00325d4>] (warn_slowpath_common) from [<c00326c0>] (warn_slowpath_fmt+0x38/0x40)
[    0.000000]  r8:00000001 r7:c0822b50 r6:c08195a0 r5:00000000 r4:c0819638
[    0.000000] [<c003268c>] (warn_slowpath_fmt) from [<c08ed110>] (arm_dt_init_cpu_maps+0x104/0x144)
[    0.000000]  r3:00000002 r2:c0819638
[    0.000000]  r4:ef614f30
[    0.000000] [<c08ed00c>] (arm_dt_init_cpu_maps) from [<c08ec81c>] (setup_arch+0x910/0x970)
[    0.000000]  r9:00000000 r8:bfcfffff r7:c0a0a2a0 r6:c0996fb0 r5:00000000 r4:effff440
[    0.000000] [<c08ebf0c>] (setup_arch) from [<c08e9a18>] (start_kernel+0x94/0x3f0)
[    0.000000]  r10:00000000 r9:c0980040 r8:80007000 r7:00000000 r6:00000000 r5:00000001
[    0.000000]  r4:00000000
[    0.000000] [<c08e9984>] (start_kernel) from [<8000808c>] (0x8000808c)
[    0.000000]  r10:00000000 r9:412fc0f2 r8:80007000 r7:c098492c r6:c0921a1c r5:c09800b8
[    0.000000]  r4:c09de1d4
[    0.000000] ---[ end trace cb88537fdc8fa200 ]---
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] DRA752 ES2.0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 234048
[    0.000000] Kernel command line: console=ttyO2,115200n8 vt.global_cursor_default=0 consoleblank=0 coherent_pool=2M root=PARTUUID=51174523-03 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 562092K/943104K available (6699K kernel code, 376K rwdata, 2388K rodata, 596K init, 272K bss, 20564K reserved, 360448K cma-reserved, 177152K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08e800c   (9089 kB)
[    0.000000]       .init : 0xc08e9000 - 0xc097e000   ( 596 kB)
[    0.000000]       .data : 0xc097e000 - 0xc09dc068   ( 377 kB)
[    0.000000]        .bss : 0xc09de000 - 0xc0a223f8   ( 273 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] Architected cp15 timer(s) running at 6.14MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000013] Switching to timer-based delay loop, resolution 162ns
[    0.000332] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000337] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000757] Console: colour dummy device 80x30
[    0.000772] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000776] This ensures that you still see kernel messages. Please
[    0.000780] update your kernel commandline.
[    0.000789] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000798] pid_max: default: 32768 minimum: 301
[    0.000862] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000870] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001278] Initializing cgroup subsys io
[    0.001292] Initializing cgroup subsys memory
[    0.001310] Initializing cgroup subsys devices
[    0.001320] Initializing cgroup subsys freezer
[    0.001328] Initializing cgroup subsys perf_event
[    0.001337] Initializing cgroup subsys pids
[    0.001355] CPU: Testing write buffer coherency: ok
[    0.001498] Setting up static identity map for 0x80008240 - 0x80008298
[    0.002138] devtmpfs: initialized
[    0.025049] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.025646] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.184534] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.191685] pinctrl core: initialized pinctrl subsystem
[    0.192341] NET: Registered protocol family 16
[    0.193938] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.219950] cpuidle: using governor ladder
[    0.249965] cpuidle: using governor menu
[    0.256577] OMAP GPIO hardware version 0.1
[    0.261535] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.261878] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.280829] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.280837] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.281189] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.281196] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.281543] OMAP DMA hardware revision 0.0
[    0.313061] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.313879] edma 43300000.edma: memcpy is disabled
[    0.317463] edma 43300000.edma: TI EDMA DMA engine driver
[    0.320193] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.320312] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.320415] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.320523] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.320721] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.320849] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.322634] SCSI subsystem initialized
[    0.322925] usbcore: registered new interface driver usbfs
[    0.322971] usbcore: registered new interface driver hub
[    0.323017] usbcore: registered new device driver usb
[    0.323789] palmas 0-0058: Irq flag is 0x00000008
[    0.341459] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[    0.344847] smps3: ramp_delay not set
[    0.422003] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.422049] omap_i2c 48060000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default, deferring probe
[    0.422475] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 100 kHz
[    0.423040] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 100 kHz
[    0.423195] pps_core: LinuxPPS API ver. 1 registered
[    0.423201] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.423221] PTP clock support registered
[    0.423261] EDAC MC: Ver: 3.0.0
[    0.423832] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.424059] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.424283] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.424505] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.425338] clocksource: Switched to clocksource arch_sys_counter
[    0.432703] NET: Registered protocol family 2
[    0.433099] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.433158] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.433255] TCP: Hash tables configured (established 8192 bind 8192)
[    0.433301] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.433323] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.433415] NET: Registered protocol family 1
[    0.433581] RPC: Registered named UNIX socket transport module.
[    0.433588] RPC: Registered udp transport module.
[    0.433592] RPC: Registered tcp transport module.
[    0.433596] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.434350] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.436028] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.441837] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.442335] NFS: Registering the id_resolver key type
[    0.442365] Key type id_resolver registered
[    0.442370] Key type id_legacy registered
[    0.442431] ntfs: driver 2.1.32 [Flags: R/O].
[    0.444138] bounce: pool size: 64 pages
[    0.444258] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.444269] io scheduler noop registered
[    0.444278] io scheduler deadline registered
[    0.444385] io scheduler cfq registered (default)
[    0.448317] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.451677] backlight supply power not found, using dummy regulator
[    0.491617] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.493967] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[    0.494502] console [ttyS2] disabled
[    0.494531] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 300, base_baud = 3000000) is a 8250
[    1.504332] console [ttyS2] enabled
[    1.508837] [drm] Initialized drm 1.1.0 20060810
[    1.514528] OMAP DSS rev 6.1
[    1.518447] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    1.531465] loop: module loaded
[    1.535459] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    1.542211] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.550787] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    1.560771] scsi host0: ahci
[    1.563861] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 347
[    1.575137] libphy: Fixed MDIO Bus: probed
[    1.625356] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.631479] davinci_mdio 48485000.mdio: detected phy mask fffffffe
[    1.639680] libphy: 48485000.mdio: probed
[    1.643710] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.653769] cpsw 48484000.ethernet: Detected MACID = 34:03:de:ec:79:b4
[    1.915362] ata1: SATA link down (SStatus 0 SControl 300)
[    2.069382] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.074905] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.082884] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.091651] xhci-hcd xhci-hcd.0.auto: irq 433, io mem 0x48890000
[    2.098189] hub 1-0:1.0: USB hub found
[    2.101972] hub 1-0:1.0: 1 port detected
[    2.106164] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.111680] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.119439] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.128031] hub 2-0:1.0: USB hub found
[    2.131810] hub 2-0:1.0: 1 port detected
[    2.136044] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.141563] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    2.149545] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.158324] xhci-hcd xhci-hcd.1.auto: irq 434, io mem 0x488d0000
[    2.164827] hub 3-0:1.0: USB hub found
[    2.168635] hub 3-0:1.0: 1 port detected
[    2.172795] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.178334] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    2.186091] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.194662] hub 4-0:1.0: USB hub found
[    2.198467] hub 4-0:1.0: 1 port detected
[    2.202756] usbcore: registered new interface driver usb-storage
[    2.209077] mousedev: PS/2 mouse device common for all mice
[    2.229004] rtc-ds1307 3-0068: rtc core: registered ds1340 as rtc0
[    2.235241] i2c /dev entries driver
[    2.256331] thermal thermal_zone5: failed to read out thermal zone (-19)
[    2.263079] sbs-battery 4-000b: bq20z75: battery gas gauge device registered
[    2.272828] tmp102 3-0049: initialized
[    2.279216] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    2.284069] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[    2.290572] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[    2.297076] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[    2.303488] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[    2.309896] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[    2.316321] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[    2.322580] vdd_3v3: supplied by regen1
[    2.367496] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    2.380694] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    2.436917] ledtrig-cpu: registered to indicate activity on CPUs
[    2.444006] NET: Registered protocol family 10
[    2.465999] sit: IPv6 over IPv4 tunneling driver
[    2.471042] NET: Registered protocol family 17
[    2.485489] Key type dns_resolver registered
[    2.489894] omap_voltage_late_init: Voltage driver support not added
[    2.505724] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.511930] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.535705] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.541910] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.566904] Power Management for TI OMAP4+ devices.
[    2.734593] powerdomain: iva_pwrdm: waited too long to complete transition
[    2.904160] powerdomain: iva_pwrdm: waited too long to complete transition
[    3.265792] dmm 4e000000.dmm: initialized all PAT entries
[    3.285841] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.292479] [drm] No driver support for vblank timestamp query.
[    3.317231] [drm] Enabling DMM ywrap scrolling
[    3.356834] Console: switching to colour frame buffer device 80x30
[    3.364958] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    3.415353] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    3.455583] input: adp5588-keys as /devices/platform/44000000.ocp/48060000.i2c/i2c-2/2-0034/input/input0
[    3.475439] onlly_adp5588_keys 2-0034: irq request success
[    3.487009] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    3.505756] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[    3.513669] rtc-ds1307 3-0068: setting system clock to 2018-05-30 15:10:36 UTC (1527693036)
[    3.539293] aic_dvdd_fixed: disabling
[    3.542971] vmmcwl_fixed: disabling
[    3.555908] Waiting for root device PARTUUID=51174523-03...
[    3.946701] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.954770] mmc0: new SDHC card at address e624
[    3.959551] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[    3.968734]  mmcblk0: p1
[    4.008989] mmc1: MAN_BKOPS_EN bit is not set
[    4.016568] mmc1: new DDR MMC card at address 0001
[    4.021554] mmcblk1: mmc1:0001 Q2J54A 3.59 GiB
[    4.026201] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 16.0 MiB
[    4.032224] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 16.0 MiB
[    4.038970]  mmcblk1: p1 p2 p3
[    4.122359] EXT4-fs (mmcblk1p3): recovery complete
[    4.127367] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[    4.135517] VFS: Mounted root (ext4 filesystem) on device 179:19.
[    4.142317] devtmpfs: mounted
[    4.145504] Freeing unused kernel memory: 596K (c08e9000 - c097e000)
[    4.151878] This architecture does not have kernel memory protection.
[    4.252086] random: systemd: uninitialized urandom read (16 bytes read, 35 bits of entropy available)
[    4.262962] random: systemd: uninitialized urandom read (16 bytes read, 35 bits of entropy available)
[    4.273327] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    4.291678] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.08!
[    4.315719] systemd[1]: Set hostname to <am57xx-evm>.
[    4.338644] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 36 bits of entropy available)
[    4.356890] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 36 bits of entropy available)
[    4.367800] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 36 bits of entropy available)
[    4.382114] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 37 bits of entropy available)
[    4.426936] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.436730] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.446356] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.456105] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.867003] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.885630] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.906359] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    4.930671] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.955523] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.975483] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.995544] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.015642] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    5.035593] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    5.065809] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.086467] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    5.107392] systemd[1]: Mounting Temporary Directory...
[    5.136091] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.167238] systemd[1]: Starting Journal Service...
[    5.197285] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.233361] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[    5.247629] systemd[1]: Mounting POSIX Message Queue File System...
[    5.288893] systemd[1]: Starting Load Kernel Modules...
[    5.327519] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    5.361200] CMEMK module: reference Linux version 4.4.19
[    5.368443] systemd[1]: Starting Setup Virtual Console...
[    5.374663] allocated heap buffer 0xa6800000 of size 0x6400000
[    5.389564] allocated heap buffer 0x40500000 of size 0x100000
[    5.397067] cmemk initialized
[    5.408205] systemd[1]: Mounting Debug File System...
[    5.446165] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    5.466191] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    5.495842] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.515476] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.535471] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    5.559458] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    5.585560] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    5.605497] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    5.625613] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Remount Root and Kernel File Systems.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Setup Virtual Console.
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Starting udev Coldplug all Devices...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[    6.300705] systemd-journald[104]: Received request to flush runtime journal from PID 1
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Flush Journal to Persistent Storage.
[    6.746548] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@97c00000
[    6.829623]  remoteproc0: 40800000.dsp is available
[    6.834523]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Load/Save Random Seed...
[    6.918899]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[  OK  ] Started udev Coldplug all Devices.
[    6.982749]  remoteproc0: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[    6.994797] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@a0400000
[    7.026268]  remoteproc0: failed to load dra7-dsp1-fw.xe66
[  OK  ] Started Create Volatile Files and Directories.
[    7.031975]  remoteproc1: 41000000.dsp is available
[[;32m  OK  ] Started Load/Save Random Seed.
[    7.095502]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[    7.104502]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[[;32m  OK  ] Found device /dev/ttyS2.
[    7.192887]  remoteproc1: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[    7.254925]  remoteproc1: failed to load dra7-dsp2-fw.xe66
[    7.263337] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    7.390751] m25p80 spi1.1: unrecognized JEDEC id bytes: 00,  0,  0
[    7.427941] m25p80 spi32766.0: found n25q256a, expected s25fl256s1
         tSarting Update UTMP about System Boot/Shutdown...
[    7.510995] m25p80 spi32766.0: n25q256a (32768 Kbytes)
         tSarting Network Time Synchronization...
[    7.555095] 8 ofpart partitions found on MTD device spi32766.0
[    7.579469] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc1
[    7.631086] Creating 8 MTD partitions on "spi32766.0":
[    7.705371] 0x000000000000-0x000000020000 : "QSPI.SPL"
[[;32m  OK  ] Started Network Time Synchronization.
[    7.780666] 0x000000020000-0x000000040000 : "QSPI.SPL.backup1"
[    7.824497] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    7.855961] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    7.888071] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    7.966137] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[[;32m  OK  ] Started Update UTMP about System Boot/Shutdow.
[    8.047929] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    8.116669] 0x0000009e0000-0x000002000000 : "QSPI.user-data"
         Starting Synchronize System and HW clocks...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Synchronize System and HW clocks.
[    8.242089] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    8.396372] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[    8.434132] EXT4-fs (mmcblk1p2): recovery complete
[    8.453624] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.467308] FAT-fs (mmcblk1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[  OK  ] Reached target System Initialization.
         Starting Console System Startup Logging...
[    8.538326] FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[    8.593429] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[    8.632387] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Login Service...
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Service...
         Starting uim-sysfs.service...
         Starting runXorg...
[    9.077843] NET: Registered protocol family 15
[  OK  ] Started System Logging Service.
         Starting Print notice about GPLv3 packages...
Start to run Xinit service
         Starting Permit User Sessions...
[  OK  ] Started Kernel Logging Service.
[    9.249261] net eth0: initializing cpsw version 1.15 (0)
[    9.254603] net eth0: initialized cpsw ale version 1.4
[  OK  ] Started Network Service.
[  OK  ] Started Console System Startup Logging.
[    9.323234] net eth0: ALE Table size 1024
[  OK  ] Started runXorg.
[  OK  ] Started Permit User Sessions.
[    9.474426] Initializing XFRM netlink socket
[    9.527649] net eth0: phy found : id is : 0x221622
X.Org X Server 1.18.0
Release Date: 2015-11-09
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-34-generic x86_64
Current Operating System: Linux am57xx-evm 4.4.19-03023-g2d41985 #1 PREEMPT Thu Nov 29 09:31:19 CST 2018 armv7l
Build Date: 15 November 2018  11:27:40AM
Current version of pixman: 0.32.8
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed May 30 15:10:42 2018
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    9.630912] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    9.876775] random: nonblocking pool is initialized
NOTICE: This file system contains the following GPLv3 packages:
        binutils
        dosfstools
        gdbc6x
        gdbserver
        parted
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Started uim-sysfs.service.
[  OK  ] Started Login Service.
         Starting rc.pvr.service...
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight...htness of backlight:backlight...
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
         Starting runXorg...
[  OK  ] Reached target Network.
         Starting Network Name Resolution...
Start to run Xorg service
[   12.081109] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Started Network Name Resolution.
/sbin/ldconfig: /lib/libstdc++.so.6.0.21-gdb.py is not an ELF file - it has the wrong magic bytes at the start.
[  OK  ] Started rc.pvr.service.
         Starting telnetd.service...
         Starting tiipclad-daemon.service...
[  OK  ] Started telnetd.service.
[  OK  ] Started tiipclad-daemon.service.
         Starting thttpd.service...
[  OK  ] Started thttpd.service.
         Starting gdbserverproxy.service...
[  OK  ] Started gdbserverproxy.service.
         Starting thermal-zone-init.service...
[  OK  ] Started thermal-zone-init.service.
libpng warning: iCCP: known incorrect sRGB profile
[   15.080498]  remoteproc0: releasing 40800000.dsp
[   15.289531] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@97c00000
[   15.297394]  remoteproc0: 40800000.dsp is available
[   15.302307]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[   15.313882]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   15.460436]  remoteproc0: registered virtio0 (type 7)
[   15.476826]  remoteproc0: powering up 40800000.dsp
[   15.500423]  remoteproc0: Booting fw image dra7-dsp1-fw.xe66, size 10130648
[   15.514724] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   15.520639] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   15.564229]  remoteproc0: remote processor 40800000.dsp is now up
[   15.573391] virtio_rpmsg_bus virtio0: rpmsg host is online
[   15.582032] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
[   15.598569] NET: Registered protocol family 41
[   15.904809] virtio_rpmsg_bus virtio0: msg received with no recipient
[   16.865758] virtio_rpmsg_bus virtio0: msg received with no recipient
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am57xx-evm ttyS2
Arago 2016.08 am57xx-evm ttyS2
am57xx-evm login: root (automatic login)
root@am57xx-evm:~# [   17.826711] virtio_rpmsg_bus virtio0: msg received with no recipient
[   18.347230]  remoteproc1: releasing 41000000.dsp
[   18.554838] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@a0400000
[   18.562682]  remoteproc1: 41000000.dsp is available
[   18.570787]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[   18.580577]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   18.707037]  remoteproc1: powering up 41000000.dsp
[   18.711859]  remoteproc1: Booting fw image dra7-dsp2-fw.xe66, size 8606848
[   18.736334] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   18.742270] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   18.776182]  remoteproc1: remote processor 41000000.dsp is now up
[   18.782641] virtio_rpmsg_bus virtio1: rpmsg host is online
[   18.790137]  remoteproc1: registered virtio1 (type 7)
[   18.804253] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
[   18.812442] virtio_rpmsg_bus virtio1: msg received with no recipient
[   18.825178] virtio_rpmsg_bus virtio0: msg received with no recipient
[   19.766242] virtio_rpmsg_bus virtio0: msg received with no recipient
[   19.772655] virtio_rpmsg_bus virtio1: msg received with no recipient
[   20.727197] virtio_rpmsg_bus virtio0: msg received with no recipient
[   20.733591] virtio_rpmsg_bus virtio1: msg received with no recipient
sizeof(off_t) = 8
try to create share memory: /opt/AMPipe, ikey=11
OTSBase*_V20190104_01listen thread start.
DSPComT thread start...[   21.727867] virtio_rpmsg_bus virtio0: msg received with no recipient
DSPComM thread start...
DSPComM thread start message loop.
I2C:   ready
DRAM:  1 GiB
reading uboot.env
reading logo.yuv
Found 0 device(s).
writing uboot.env
done
reading boot.scr
reading uEnv.txt
5270048 bytes read in 133 ms (37.8 MiB/s)
Starting kernel ...
[    0.000339] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000345] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000773] Console: colour dummy device 80x30
[    0.000788] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[    0.000792] This ensures that you still see kernel messages. Please
[    0.000796] update your kernel commandline.
[    0.000805] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000814] pid_max: default: 32768 minimum: 301
[    0.000879] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000887] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001294] Initializing cgroup subsys io
[    0.001308] Initializing cgroup subsys memory
[    0.001326] Initializing cgroup subsys devices
[    0.001335] Initializing cgroup subsys freezer
[    0.001343] Initializing cgroup subsys perf_event
[    0.001352] Initializing cgroup subsys pids
[    0.001370] CPU: Testing write buffer coherency: ok
[    0.001512] Setting up static identity map for 0x80008240 - 0x80008298
[    0.002157] devtmpfs: initialized
[    0.024900] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.025500] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.184332] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.191432] pinctrl core: initialized pinctrl subsystem
[    0.192088] NET: Registered protocol family 16
[    0.193693] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.219951] cpuidle: using governor ladder
[    0.249967] cpuidle: using governor menu
[    0.256569] OMAP GPIO hardware version 0.1
[    0.261882] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.280838] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.281196] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.281202] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.281550] OMAP DMA hardware revision 0.0
[    0.313245] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[    0.314065] edma 43300000.edma: memcpy is disabled
[    0.317606] edma 43300000.edma: TI EDMA DMA engine driver
[    0.320327] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.320447] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.320549] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.320656] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.320851] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.320980] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.322776] SCSI subsystem initialized
[    0.323066] usbcore: registered new interface driver usbfs
[    0.323113] usbcore: registered new interface driver hub
[    0.323159] usbcore: registered new device driver usb
[    0.323926] palmas 0-0058: Irq flag is 0x00000008
[    0.341652] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[    0.345029] smps3: ramp_delay not set
[    0.422196] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.422242] omap_i2c 48060000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default, deferring probe
[    0.422665] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 100 kHz
[    0.423227] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 100 kHz
[    0.423379] pps_core: LinuxPPS API ver. 1 registered
[    0.423385] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.423405] PTP clock support registered
[    0.423444] EDAC MC: Ver: 3.0.0
[    0.424010] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[    0.424240] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[    0.424466] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.424691] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.425522] clocksource: Switched to clocksource arch_sys_counter
[    0.432848] NET: Registered protocol family 2
[    0.433245] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.433304] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.433400] TCP: Hash tables configured (established 8192 bind 8192)
[    0.433446] UDP hash table entries: 512 (order: 1, 8192 bytes)
[    0.433468] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[    0.433558] NET: Registered protocol family 1
[    0.433728] RPC: Registered named UNIX socket transport module.
[    0.433735] RPC: Registered udp transport module.
[    0.433739] RPC: Registered tcp transport module.
[    0.433743] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.434497] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.436166] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.441898] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.442396] NFS: Registering the id_resolver key type
[    0.442417] Key type id_resolver registered
[    0.442423] Key type id_legacy registered
[    0.442484] ntfs: driver 2.1.32 [Flags: R/O].
[    0.444181] bounce: pool size: 64 pages
[    0.444299] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.444310] io scheduler noop registered
[    0.444320] io scheduler deadline registered
[    0.444428] io scheduler cfq registered (default)
[    0.448350] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.451713] backlight supply power not found, using dummy regulator
[    0.491710] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.494059] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[    0.494593] console [ttyS2] disabled
[    0.494621] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 300, base_baud = 3000000) is a 8250
[    1.504400] console [ttyS2] enabled
[    1.508900] [drm] Initialized drm 1.1.0 20060810
[    1.514602] OMAP DSS rev 6.1
[    1.518527] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    1.531543] loop: module loaded
[    1.535539] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    1.542286] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.550861] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    1.560833] scsi host0: ahci
[    1.563922] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 347
[    1.575205] libphy: Fixed MDIO Bus: probed
[    1.625537] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.631657] davinci_mdio 48485000.mdio: detected phy mask fffffffe
[    1.640135] libphy: 48485000.mdio: probed
[    1.644163] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.654224] cpsw 48484000.ethernet: Detected MACID = 34:03:de:ec:79:b4
[    1.915545] ata1: SATA link down (SStatus 0 SControl 300)
[    2.069571] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.075095] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.083075] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.091840] xhci-hcd xhci-hcd.0.auto: irq 433, io mem 0x48890000
[    2.098386] hub 1-0:1.0: USB hub found
[    2.102170] hub 1-0:1.0: 1 port detected
[    2.106366] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.111883] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.119646] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.128239] hub 2-0:1.0: USB hub found
[    2.132020] hub 2-0:1.0: 1 port detected
[    2.136259] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.141777] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    2.149755] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010
[    2.158532] xhci-hcd xhci-hcd.1.auto: irq 434, io mem 0x488d0000
[    2.165036] hub 3-0:1.0: USB hub found
[    2.168841] hub 3-0:1.0: 1 port detected
[    2.173002] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.178542] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    2.186298] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.194868] hub 4-0:1.0: USB hub found
[    2.198671] hub 4-0:1.0: 1 port detected
[    2.202955] usbcore: registered new interface driver usb-storage
[    2.209276] mousedev: PS/2 mouse device common for all mice
[    2.229190] rtc-ds1307 3-0068: rtc core: registered ds1340 as rtc0
[    2.235426] i2c /dev entries driver
[    2.256510] thermal thermal_zone5: failed to read out thermal zone (-19)
[    2.263258] sbs-battery 4-000b: bq20z75: battery gas gauge device registered
[    2.273007] tmp102 3-0049: initialized
[    2.279425] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    2.284259] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[    2.290781] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[    2.297275] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[    2.303673] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[    2.310100] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[    2.316508] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[    2.322784] vdd_3v3: supplied by regen1
[    2.367597] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    2.380984] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    2.437098] ledtrig-cpu: registered to indicate activity on CPUs
[    2.444184] NET: Registered protocol family 10
[    2.466188] sit: IPv6 over IPv4 tunneling driver
[    2.471231] NET: Registered protocol family 17
[    2.485672] Key type dns_resolver registered
[    2.490071] omap_voltage_late_init: Voltage driver support not added
[    2.505921] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.512127] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.535885] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.542090] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.567096] Power Management for TI OMAP4+ devices.
[    2.737364] powerdomain: iva_pwrdm: waited too long to complete transition
[    2.909484] powerdomain: iva_pwrdm: waited too long to complete transition
[    3.275955] dmm 4e000000.dmm: initialized all PAT entries
[    3.296014] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.302653] [drm] No driver support for vblank timestamp query.
[    3.327401] [drm] Enabling DMM ywrap scrolling
[    3.367014] Console: switching to colour frame buffer device 80x30
[    3.375132] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    3.425536] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[    3.465764] input: adp5588-keys as /devices/platform/44000000.ocp/48060000.i2c/i2c-2/2-0034/input/input0
[    3.485620] onlly_adp5588_keys 2-0034: irq request success
[    3.497192] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    3.515941] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[    3.523854] rtc-ds1307 3-0068: setting system clock to 2018-05-30 15:11:41 UTC (1527693101)
[    3.549453] aic_dvdd_fixed: disabling
[    3.553130] vmmcwl_fixed: disabling
[    3.566303] Waiting for root device PARTUUID=51174523-03...
[    3.956881] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.964950] mmc0: new SDHC card at address e624
[    3.969731] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[    3.978916]  mmcblk0: p1
[    4.019179] mmc1: MAN_BKOPS_EN bit is not set
[    4.026774] mmc1: new DDR MMC card at address 0001
[    4.031762] mmcblk1: mmc1:0001 Q2J54A 3.59 GiB
[    4.036402] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 16.0 MiB
[    4.042423] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 16.0 MiB
[    4.049219]  mmcblk1: p1 p2 p3
[    4.137237] EXT4-fs (mmcblk1p3): recovery complete
[    4.142213] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[    4.150364] VFS: Mounted root (ext4 filesystem) on device 179:19.
[    4.157178] devtmpfs: mounted
[    4.160358] Freeing unused kernel memory: 596K (c08e9000 - c097e000)
[    4.166761] This architecture does not have kernel memory protection.
[    4.266543] random: systemd: uninitialized urandom read (16 bytes read, 35 bits of entropy available)
[    4.277691] random: systemd: uninitialized urandom read (16 bytes read, 35 bits of entropy available)
[    4.288077] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    4.306401] systemd[1]: Detected architecture arm.
[    4.325935] systemd[1]: Set hostname to <am57xx-evm>.
[    4.348983] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 36 bits of entropy available)
[    4.368025] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 37 bits of entropy available)
[    4.379058] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 37 bits of entropy available)
[    4.393385] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 37 bits of entropy available)
[    4.438674] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.448485] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.458018] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.467854] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available)
[    4.878110] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.895784] systemd[1]: Listening on udev Control Socket.
[    4.916489] systemd[1]: Reached target Remote File Systems.
[    4.935763] systemd[1]: Listening on Journal Socket.
[    4.955789] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.991879] systemd[1]: Created slice System Slice.
[    5.017570] systemd[1]: Mounting Temporary Directory...
[    5.046402] systemd[1]: Created slice system-getty.slice.
[    5.066477] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.087423] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.127281] systemd[1]: Starting Setup Virtual Console...
[    5.158907] systemd[1]: Starting Load Kernel Modules...
[    5.187420] systemd[1]: Mounting Debug File System...
[    5.216010] systemd[1]: Listening on Network Service Netlink Socket.
[    5.227035] CMEMK module: reference Linux version 4.4.19
[    5.236042] systemd[1]: Reached target Swap.
[    5.240732] allocated heap buffer 0xa6800000 of size 0x6400000
[    5.246924] allocated heap buffer 0x40500000 of size 0x100000
[    5.256329] cmemk initialized
[    5.266212] systemd[1]: Created slice User and Session Slice.
[    5.287427] systemd[1]: Mounting POSIX Message Queue File System...
[    5.316013] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.335691] systemd[1]: Reached target Paths.
[    5.355771] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.375667] systemd[1]: Reached target Slices.
[    5.395715] systemd[1]: Listening on udev Kernel Socket.
[    5.416532] systemd[1]: Listening on Syslog Socket.
[    5.437269] systemd[1]: Starting Journal Service...
[    5.467431] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.503597] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[    5.527065] systemd[1]: Mounted Debug File System.
[    5.566128] systemd[1]: Mounted POSIX Message Queue File System.
[    5.585760] systemd[1]: Mounted Temporary Directory.
[    5.605887] systemd[1]: Started Journal Service.
[    6.267624] systemd-journald[134]: Received request to flush runtime journal from PID 1
[  OK  ] Started Load/Save Random Seed.
[    6.775412] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@97c00000
[    6.858622]  remoteproc0: 40800000.dsp is available
[    6.863522]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    6.928063]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    6.985890]  remoteproc0: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[    6.994104]  remoteproc0: failed to load dra7-dsp1-fw.xe66
[    7.006881] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@a0400000
[    7.014681]  remoteproc1: 41000000.dsp is available
[    7.085469]  remoteproc1: Note: remoteproc is still under development and considered experimental.
         Starting Update UTMP about System Boot/Shutdown...
[    7.133716]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
         Starting Network Time Synchronization...
[  OK  ] Found device /dev/ttyS2.
[    7.184251]  remoteproc1: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[    7.245615]  remoteproc1: failed to load dra7-dsp2-fw.xe66
[  OK  ] Started Network Time Synchronization.
[    7.314407] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[    7.479567] m25p80 spi1.1: unrecognized JEDEC id bytes: 00,  0,  0
[    7.555880] m25p80 spi32766.0: found n25q256a, expected s25fl256s1
[    7.603501] m25p80 spi32766.0: n25q256a (32768 Kbytes)
[    7.623661] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc1
[    7.660413] 8 ofpart partitions found on MTD device spi32766.0
[    7.725360] Creating 8 MTD partitions on "spi32766.0":
[    7.821428] 0x000000000000-0x000000020000 : "QSPI.SPL"
[    7.882506] 0x000000020000-0x000000040000 : "QSPI.SPL.backup1"
[    7.950075] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    8.006440] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    8.100687] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    8.151070] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
         Starting runXorg...
[    8.241603] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    8.297334] 0x0000009e0000-0x000002000000 : "QSPI.user-data"
[    8.373732] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    8.384512] EXT4-fs (mmcblk1p2): recovery complete
[    8.390202] FAT-fs (mmcblk1p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[    8.426667] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.534415] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
         Starting Login Service...[    8.573578] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    8.669486] FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[    8.815865] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    8.913320] net eth0: initializing cpsw version 1.15 (0)
[    8.923707] NET: Registered protocol family 15
[    9.011095] net eth0: initialized cpsw ale version 1.4
(==) Log file: "/var/log/Xorg.0.log", Time: Wed May 30 15:11:47 2018
   9.091369] net eth0: ALE Table size 1024
=(=) Using system config directory "/usr/share/X11/xorg.conf.d"
[    9.475738] random: nonblocking pool is initialized
[    9.494300] Initializing XFRM netlink socket
[    9.849410] net eth0: phy found : id is : 0x221622
[    9.969554] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
        binutils
        dosfstools
        gdbc6x
        gdbserver
        parted
         Starting runXorg...
[   12.165770] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[   14.909314]  remoteproc0: releasing 40800000.dsp
[   15.118265] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@97c00000
[   15.126199]  remoteproc0: 40800000.dsp is available
[   15.131113]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[   15.142688]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   15.289438]  remoteproc0: registered virtio0 (type 7)
[   15.304967]  remoteproc0: powering up 40800000.dsp
[   15.327295]  remoteproc0: Booting fw image dra7-dsp1-fw.xe66, size 10130648
[   15.341183] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   15.347106] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   15.379745]  remoteproc0: remote processor 40800000.dsp is now up
[   15.387425] virtio_rpmsg_bus virtio0: rpmsg host is online
[   15.397401] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
[   15.410606] NET: Registered protocol family 41
[   15.724022] virtio_rpmsg_bus virtio0: msg received with no recipient
[   16.684971] virtio_rpmsg_bus virtio0: msg received with no recipient
 _____                    _____           _         _
              |___|                    |___|
root@am57xx-evm:~# [   17.645914] virtio_rpmsg_bus virtio0: msg received with no recipient
[   18.175945]  remoteproc1: releasing 41000000.dsp
[   18.383333] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@a0400000
[   18.391180]  remoteproc1: 41000000.dsp is available
[   18.397963]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[   18.407816]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[   18.534743]  remoteproc1: powering up 41000000.dsp
[   18.543672]  remoteproc1: Booting fw image dra7-dsp2-fw.xe66, size 8606848
[   18.562811] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   18.568748] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   18.599585]  remoteproc1: remote processor 41000000.dsp is now up
[   18.606146] virtio_rpmsg_bus virtio1: rpmsg host is online
[   18.611677]  remoteproc1: registered virtio1 (type 7)
[   18.623170] virtio_rpmsg_bus virtio0: msg received with no recipient
[   18.630549] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
[   18.639426] virtio_rpmsg_bus virtio1: msg received with no recipient
[   19.585427] virtio_rpmsg_bus virtio0: msg received with no recipient
[   19.595034] virtio_rpmsg_bus virtio1: msg received with no recipient
[   20.546383] virtio_rpmsg_bus virtio0: msg received with no recipient
[   20.556620] virtio_rpmsg_bus virtio1: msg received with no recipient
sizeof(off_t) = 8
[   21.508319] Unable to handle kernel NULL pointer dereference at virtual address 00000070
[   21.516468] pgd = c0003000
[   21.519191] [00000070] *pgd=80000080004003, *pmd=00000000
[   21.524626] Internal error: Oops: 205 [#1] PREEMPT ARM
[   21.529782] Modules linked in: rpmsg_proto virtio_rpmsg_bus bc_example(O) xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 pwm_fan af_key xfrm_algo pwm_omap_dmtimer pvrsrvkm(O) omap_wdt rtc_omap m25p80 extcon_palmas omap_rng rng_core debugss_kmodule(O) omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel uio_module_drv(O) uio gdbserverproxy(O) cmemk(O)
[   21.561992] CPU: 0 PID: 554 Comm: kworker/0:4 Tainted: G        W  O    4.4.19-03023-g2d41985 #1
[   21.570810] Hardware name: Generic DRA74X (Flattened Device Tree)
[   21.576932] Workqueue: events mbox_rx_work
[   21.581048] task: ee217180 ti: ee28c000 task.ti: ee28c000
[   21.586468] PC is at lock_sock_nested+0x2c/0x8c
[   21.591021] LR is at rpmsg_proto_cb+0x38/0x150 [rpmsg_proto]
[   21.596702] pc : [<c056d790>]    lr : [<bf14d7f8>]    psr: 200f0013
[   21.596702] sp : ee28ddb8  ip : ee28ddd0  fp : ee28ddcc
[   21.608225] r10: 00000002  r9 : d7c40e10  r8 : 0000003d
[   21.613468] r7 : 000001e4  r6 : ee0c5408  r5 : ee7d1f40  r4 : 00000000
[   21.620019] r3 : 00000201  r2 : ee28c000  r1 : 00000000  r0 : 00000000
[   21.626571] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[   21.633908] Control: 30c53c7d  Table: ae7c9140  DAC: fffffffd
[   21.639675] Process kworker/0:4 (pid: 554, stack limit = 0xee28c208)
[   21.646053] Stack: (0xee28ddb8 to 0xee28e000)
[   21.650426] dda0:                                                       00000000 ee7d1f40
[   21.658636] ddc0: ee28de04 ee28ddd0 bf14d7f8 c056d770 ee28ddec ee28dde0 c001add0 ee7d1f44
[   21.666846] dde0: ee7d1f40 d7c40e00 ee7fcd00 ee7d1f4c 00000000 bf14d7c0 ee28de74 ee28de08
[   21.675057] de00: bf145f98 bf14d7cc 0000003d ee2171b0 00000001 bf146a78 bf146d50 bf146ab8
[   21.683267] de20: ee10f018 024000c0 ee3aa800 ee7fcd44 ffffffff 00000200 01d79b27 00000000
[   21.691478] de40: 00000200 c0991de0 ee2171b0 ee025644 ee28c000 c089b48c ef609600 c0991638
[   21.699687] de60: 00000000 ee3fa600 ee28de84 ee28de78 bf024168 bf145ed0 ee28de94 ee28de88
[   21.707896] de80: bf0337d4 bf024134 ee28deac ee28de98 bf03ee3c bf033794 ee089614 ee28c000
[   21.716106] dea0: ee28debc ee28deb0 c055a2b4 bf03ed74 ee28dee4 ee28dec0 c055b608 c055a2a0
[   21.724315] dec0: c068d978 00000000 ee089614 ee089614 ee3fa600 00000000 ee28df24 ee28dee8
[   21.732524] dee0: c004756c c055b5b0 c0991638 00000008 ffffe000 c0991648 c0991638 c0991638
[   21.740735] df00: ee3fa618 00000008 ffffe000 c0991648 c0991638 ee3fa600 ee28df64 ee28df28
[   21.748945] df20: c00478d4 c0047440 c0991798 c0991648 c0993f40 c09db367 00000000 00000000
[   21.757155] df40: ee2bd700 ee3fa600 c0047858 00000000 00000000 00000000 ee28dfac ee28df68
[   21.765363] df60: c004d3cc c0047864 00000000 00000000 ee2bd700 ee3fa600 00000000 ee28df7c
[   21.773573] df80: ee28df7c 00000000 ee28df88 ee28df88 ee2bd700 c004d2f0 00000000 00000000
[   21.781782] dfa0: 00000000 ee28dfb0 c000f968 c004d2fc 00000000 00000000 00000000 00000000
[   21.789991] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   21.798201] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[   21.806407] Backtrace:
[   21.808874] [<c056d764>] (lock_sock_nested) from [<bf14d7f8>] (rpmsg_proto_cb+0x38/0x150 [rpmsg_proto])
[   21.818302]  r5:ee7d1f40 r4:00000000
[   21.821915] [<bf14d7c0>] (rpmsg_proto_cb [rpmsg_proto]) from [<bf145f98>] (rpmsg_recv_done+0xd4/0x278 [virtio_rpmsg_bus])
[   21.832913]  r10:bf14d7c0 r9:00000000 r8:ee7d1f4c r7:ee7fcd00 r6:d7c40e00 r5:ee7d1f40
[   21.840804]  r4:ee7d1f44
[   21.843364] [<bf145ec4>] (rpmsg_recv_done [virtio_rpmsg_bus]) from [<bf024168>] (vring_interrupt+0x40/0x58 [virtio_ring])
[   21.854362]  r10:ee3fa600 r9:00000000 r8:c0991638 r7:ef609600 r6:c089b48c r5:ee28c000
[   21.862254]  r4:ee025644
[   21.864818] [<bf024128>] (vring_interrupt [virtio_ring]) from [<bf0337d4>] (rproc_vq_interrupt+0x4c/0x70 [remoteproc])
[   21.875573] [<bf033788>] (rproc_vq_interrupt [remoteproc]) from [<bf03ee3c>] (omap_rproc_mbox_callback+0xd4/0xec [omap_remoteproc])
[   21.887453] [<bf03ed68>] (omap_rproc_mbox_callback [omap_remoteproc]) from [<c055a2b4>] (mbox_chan_received_data+0x20/0x24)
[   21.898624]  r5:ee28c000 r4:ee089614
[   21.902228] [<c055a294>] (mbox_chan_received_data) from [<c055b608>] (mbox_rx_work+0x64/0xf0)
[   21.910791] [<c055b5a4>] (mbox_rx_work) from [<c004756c>] (process_one_work+0x138/0x424)
[   21.918912]  r6:00000000 r5:ee3fa600 r4:ee089614
[   21.923566] [<c0047434>] (process_one_work) from [<c00478d4>] (worker_thread+0x7c/0x648)
[   21.931686]  r10:ee3fa600 r9:c0991638 r8:c0991648 r7:ffffe000 r6:00000008 r5:ee3fa618
[   21.939580]  r4:c0991638
[   21.942132] [<c0047858>] (worker_thread) from [<c004d3cc>] (kthread+0xdc/0xf4)
[   21.949381]  r10:00000000 r9:00000000 r8:00000000 r7:c0047858 r6:ee3fa600 r5:ee2bd700
[   21.957271]  r4:00000000
[   21.959823] [<c004d2f0>] (kthread) from [<c000f968>] (ret_from_fork+0x14/0x2c)
[   21.967070]  r7:00000000 r6:00000000 r5:c004d2f0 r4:ee2bd700
[   21.972779] Code: e5923004 e2833c02 e2833001 e5823004 (e5903070)
[   21.978916] ---[ end trace cb88537fdc8fa202 ]---
[   21.983551] Kernel panic - not syncing: Fatal exception in interrupt
[   21.989932] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Q: What the reason it will be?
BR,
vefone
  • Hi, Vefone,
    This is a duplicate to the other thread, e2e.ti.com/.../780240
    We can move to this thread and work on this one.
    The same question I have to the other thread is could you reproduce the issue using ex02_messageq example on TI AM5728 GP EVM?
    It will be easier for us to look into the problem.
    Rex
    Rex,it is all well when using ex02_messageq example from TI.
    It seems that there is mailbox error when the error happen,and I do not know how to debug.
    Br,
    vefone
  • Hi, Vefone,
    I started the test by rebooting EVM with /lib/firmware/ipc/tisdk_platform_DRA7xx_dspX/messageq_single.xe66 loaded to DSPx (1, 2). It ran overnight without any issue. It takes about 1 min per reboot, so it ran more than 1440 reboots.
    The intermittent issue is very hard to debug. From your logs:
    sizeof(off_t) = 8
    You can try to find out why rpmsg get a msg with no recipient. Also, you can try to interpret the Oops dump.
       https://opensourceforu.com/2011/01/understanding-a-kernel-oops/
    It shows you have a user space error and trying to read which causes a protection fault. I believe the read is accessing the NULL pointer which may be caused by no recipient in the msg. I am just guessing from the logs, but you should dig in to find where the issue is.
    Rex
