RTOS/AM5728: Running IPC ex02_messageq example on core DSP2
Part Number: AM5728
Tool/software: TI-RTOS
Hi Everyone,
The ex02_messageQ example I am able to run on dsp1 core which builds with CCS.
When trying to run on DSP2 with attached rsc table and config.bld remote proc is not able to load bin on DSP2, there is kernel crash.
following is the Device tree setup.
 memory@0 {
    device_type = "memory";
    reg = <0x0 0x80000000 0x0 0x80000000>;     /* DDR*/
  reserved-memory {
    #address-cells = <2>;
    #size-cells = <2>;
    ranges;
    ipu2_cma_pool: ipu2_cma@95800000 {
      compatible = "shared-dma-pool";
      reg = <0x0 0x95800000 0x0 0x3800000>;
      reusable;
      status = "okay";
    dsp1_cma_pool: dsp1_cma@99000000 {
      reg = <0x0 0x99000000 0x0 0x4000000>;  /* For DSP1 */
      reusable;
      status = "okay";
    ipu1_cma_pool: ipu1_cma@9d000000 {
      reg = <0x0 0x9d000000 0x0 0x2000000>;
      reusable;
      status = "okay";
    dsp2_cma_pool: dsp2_cma@9f000000 {/* For DSP2 */
      reg = <0x0 0x9f000000 0x0 0x800000>;
      reusable;
      status = "okay";
 * Copyright (c) 2012-2014, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== rsc_table_vayu_dsp.h ========
 *  Define the resource table entries for all DSP cores. This will be
 *  incorporated into corresponding base images, and used by the remoteproc
 *  on the host-side to allocated/reserve resources.
#ifndef _RSC_TABLE_VAYU_DSP_H_
#define _RSC_TABLE_VAYU_DSP_H_
#include "rsc_types.h"
/* DSP Memory Map */
#define L4_DRA7XX_BASE          0x4A000000
#define L4_PERIPHERAL_L4CFG     (L4_DRA7XX_BASE)
#define DSP_PERIPHERAL_L4CFG    0x4A000000
#define L4_PERIPHERAL_L4PER1    0x48000000
#define DSP_PERIPHERAL_L4PER1   0x48000000
#define L4_PERIPHERAL_L4PER2    0x48400000
#define DSP_PERIPHERAL_L4PER2   0x48400000
#define L4_PERIPHERAL_L4PER3    0x48800000
#define DSP_PERIPHERAL_L4PER3   0x48800000
#define L4_PERIPHERAL_L4EMU     0x54000000
#define DSP_PERIPHERAL_L4EMU    0x54000000
#define L3_PERIPHERAL_DMM       0x4E000000
#define DSP_PERIPHERAL_DMM      0x4E000000
#define L3_TILER_MODE_0_1       0x60000000
#define DSP_TILER_MODE_0_1      0x60000000
#define L3_TILER_MODE_2         0x70000000
#define DSP_TILER_MODE_2        0x70000000
#define L3_TILER_MODE_3         0x78000000
#define DSP_TILER_MODE_3        0x78000000
#define DSP_PERIPHERAL_MCASP    0x45C00000
#define L3_PERIPHERAL_MCASP     0x45C00000
#define DSP_MEM_TEXT            0x95000000
/* Co-locate alongside TILER region for easier flushing */
#define DSP_MEM_IOBUFS          0x80000000
#define DSP_MEM_DATA            0x95100000
#define DSP_MEM_HEAP            0x95200000
#define DSP_MEM_IPC_DATA        0x9F000000
#define DSP_MEM_IPC_VRING       0xA0000000
#define DSP_MEM_RPMSG_VRING0    0xA0000000
#define DSP_MEM_RPMSG_VRING1    0xA0004000
#define DSP_MEM_VRING_BUFS0     0xA0040000
#define DSP_MEM_VRING_BUFS1     0xA0080000
#define DSP_MEM_IPC_VRING_SIZE  SZ_1M
#define DSP_MEM_IPC_DATA_SIZE   SZ_1M
#define DSP_MEM_TEXT_SIZE       SZ_1M
#define DSP_MEM_DATA_SIZE       SZ_1M
#define DSP_MEM_HEAP_SIZE       (SZ_1M * 3)
#define DSP_MEM_IOBUFS_SIZE     (SZ_1M * 90)
#define DSP_CMEM_IOBUFS 0x85000000
#define PHYS_CMEM_IOBUFS 0xA0000000
#define DSP_CMEM_IOBUFS_SIZE (SZ_1M * 192)
 * Assign fixed RAM addresses to facilitate a fixed MMU table.
//BWC
#define VAYU_DSP_2
/* See CMA BASE addresses in Linux side: arch/arm/mach-omap2/remoteproc.c */
#if defined (VAYU_DSP_1)
#define PHYS_MEM_IPC_VRING      0x99000000
#elif defined (VAYU_DSP_2)
#define PHYS_MEM_IPC_VRING      0x9F000000
#endif
/* Need to be identical to that of IPU */
#define PHYS_MEM_IOBUFS         0xBA300000
 * Sizes of the virtqueues (expressed in number of buffers supported,
 * and must be power of 2)
#define DSP_RPMSG_VQ0_SIZE      256
#define DSP_RPMSG_VQ1_SIZE      256
/* flip up bits whose indices represent features we support */
#define RPMSG_DSP_C0_FEATURES         1
struct my_resource_table {
    struct resource_table base;
    UInt32 offset[19];  /* Should match 'num' in actual definition */
    /* rpmsg vdev entry */
    struct fw_rsc_vdev rpmsg_vdev;
    struct fw_rsc_vdev_vring rpmsg_vring0;
    struct fw_rsc_vdev_vring rpmsg_vring1;
    /* text carveout entry */
    struct fw_rsc_carveout text_cout;
    /* data carveout entry */
    struct fw_rsc_carveout data_cout;
    /* heap carveout entry */
    struct fw_rsc_carveout heap_cout;
    /* ipcdata carveout entry */
    struct fw_rsc_carveout ipcdata_cout;
    /* trace entry */
    struct fw_rsc_trace trace;
    /* devmem entry */
    struct fw_rsc_devmem devmem0;
    /* devmem entry */
    struct fw_rsc_devmem devmem1;
    /* devmem entry */
    struct fw_rsc_devmem devmem2;
    /* devmem entry */
    struct fw_rsc_devmem devmem3;
    /* devmem entry */
    struct fw_rsc_devmem devmem4;
    /* devmem entry */
    struct fw_rsc_devmem devmem5;
    /* devmem entry */
    struct fw_rsc_devmem devmem6;
    /* devmem entry */
    struct fw_rsc_devmem devmem7;
    /* devmem entry */
    struct fw_rsc_devmem devmem8;
    /* devmem entry */
    struct fw_rsc_devmem devmem9;
    /* devmem entry */
    struct fw_rsc_devmem devmem10;
    /* devmem entry */
    struct fw_rsc_devmem devmem11;
    /* devmem entry */
    struct fw_rsc_devmem devmem12;
//BWC added extern declaration
extern char ti_trace_SysMin_Module_State_0_outbuf__A;
#define TRACEBUFADDR (UInt32)&ti_trace_SysMin_Module_State_0_outbuf__A
#pragma DATA_SECTION(ti_ipc_remoteproc_ResourceTable, ".resource_table")
#pragma DATA_ALIGN(ti_ipc_remoteproc_ResourceTable, 4096)
struct my_resource_table ti_ipc_remoteproc_ResourceTable = {
    1,      /* we're the first version that implements this */
    19,     /* number of entries in the table */
    0, 0,   /* reserved, must be zero */
    /* offsets to entries */
        offsetof(struct my_resource_table, rpmsg_vdev),
        offsetof(struct my_resource_table, text_cout),
        offsetof(struct my_resource_table, data_cout),
        offsetof(struct my_resource_table, heap_cout),
        offsetof(struct my_resource_table, ipcdata_cout),
        offsetof(struct my_resource_table, trace),
        offsetof(struct my_resource_table, devmem0),
        offsetof(struct my_resource_table, devmem1),
        offsetof(struct my_resource_table, devmem2),
        offsetof(struct my_resource_table, devmem3),
        offsetof(struct my_resource_table, devmem4),
        offsetof(struct my_resource_table, devmem5),
        offsetof(struct my_resource_table, devmem6),
        offsetof(struct my_resource_table, devmem7),
        offsetof(struct my_resource_table, devmem8),
        offsetof(struct my_resource_table, devmem9),
        offsetof(struct my_resource_table, devmem10),
        offsetof(struct my_resource_table, devmem11),
        offsetof(struct my_resource_table, devmem12),
        TYPE_VDEV, VIRTIO_ID_RPMSG, 0,
        RPMSG_DSP_C0_FEATURES, 0, 0, 0, 2, { 0, 0 },
        /* no config data */
    /* the two vrings */
    { DSP_MEM_RPMSG_VRING0, 4096, DSP_RPMSG_VQ0_SIZE, 1, 0 },
    { DSP_MEM_RPMSG_VRING1, 4096, DSP_RPMSG_VQ1_SIZE, 2, 0 },
        TYPE_CARVEOUT,
        DSP_MEM_TEXT, 0,
        DSP_MEM_TEXT_SIZE, 0, 0, "DSP_MEM_TEXT",
        TYPE_CARVEOUT,
        DSP_MEM_DATA, 0,
        DSP_MEM_DATA_SIZE, 0, 0, "DSP_MEM_DATA",
        TYPE_CARVEOUT,
        DSP_MEM_HEAP, 0,
        DSP_MEM_HEAP_SIZE, 0, 0, "DSP_MEM_HEAP",
        TYPE_CARVEOUT,
        DSP_MEM_IPC_DATA, 0,
        DSP_MEM_IPC_DATA_SIZE, 0, 0, "DSP_MEM_IPC_DATA",
        TYPE_TRACE, TRACEBUFADDR, 0x8000, 0, "trace:dsp",
        TYPE_DEVMEM,
       DSP_MEM_IPC_VRING, PHYS_MEM_IPC_VRING,
       DSP_MEM_IPC_VRING_SIZE, 0, 0, "DSP_MEM_IPC_VRING",
        TYPE_DEVMEM,
        DSP_MEM_IOBUFS, PHYS_MEM_IOBUFS,
        DSP_MEM_IOBUFS_SIZE, 0, 0, "DSP_MEM_IOBUFS",
        TYPE_DEVMEM,
        DSP_TILER_MODE_0_1, L3_TILER_MODE_0_1,
        SZ_256M, 0, 0, "DSP_TILER_MODE_0_1",
        TYPE_DEVMEM,
        DSP_TILER_MODE_2, L3_TILER_MODE_2,
        SZ_128M, 0, 0, "DSP_TILER_MODE_2",
        TYPE_DEVMEM,
        DSP_TILER_MODE_3, L3_TILER_MODE_3,
        SZ_128M, 0, 0, "DSP_TILER_MODE_3",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_L4CFG, L4_PERIPHERAL_L4CFG,
        SZ_16M, 0, 0, "DSP_PERIPHERAL_L4CFG",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_L4PER1, L4_PERIPHERAL_L4PER1,
        SZ_2M, 0, 0, "DSP_PERIPHERAL_L4PER1",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_L4PER2, L4_PERIPHERAL_L4PER2,
        SZ_4M, 0, 0, "DSP_PERIPHERAL_L4PER2",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_L4PER3, L4_PERIPHERAL_L4PER3,
        SZ_8M, 0, 0, "DSP_PERIPHERAL_L4PER3",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_L4EMU, L4_PERIPHERAL_L4EMU,
        SZ_16M, 0, 0, "DSP_PERIPHERAL_L4EMU",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_DMM, L3_PERIPHERAL_DMM,
        SZ_1M, 0, 0, "DSP_PERIPHERAL_DMM",
       TYPE_DEVMEM,
       DSP_CMEM_IOBUFS, PHYS_CMEM_IOBUFS,
       DSP_CMEM_IOBUFS_SIZE, 0, 0, "DSP_CMEM_IOBUFS",
        TYPE_DEVMEM,
        DSP_PERIPHERAL_MCASP, L3_PERIPHERAL_MCASP,
        SZ_4M, 0, 0, "DSP_PERIPHERAL_MCASP",
#endif /* _RSC_TABLE_VAYU_DSP_H_ */
 * Copyright (c) 2013-2015, Texas Instruments Incorporated
 * are met:
 *  ======== config.bld ========
var Build = xdc.useModule('xdc.bld.BuildEnvironment');
/*  Memory Map for ti.platforms.evmDRA7XX:dsp1 and ti.platforms.evmDRA7XX:dsp2
 *  --- External Memory ---
 *  Virtual     Physical        Size            Comment
 *  9500_4000   ????_????    10_0000  (  ~1 MB) EXT_CODE
 *  9510_0000   ????_????    10_0000  (   1 MB) EXT_DATA
 *  9520_0000   ????_????    30_0000  (   3 MB) EXT_HEAP
 *  9F00_0000   9F00_0000     6_0000  ( 384 kB) TRACE_BUF
 *  9F06_0000   9F06_0000     1_0000  (  64 kB) EXC_DATA
 *  9F07_0000   9F07_0000     2_0000  ( 128 kB) PM_DATA (Power mgmt)
var evmDRA7XX_ExtMemMapDsp = {
    EXT_CODE: {
        base: 0x95000000,
        len:  0x00100000,
        space: "code",
        access: "RWX"
    EXT_DATA: {
        base: 0x95100000,
        len:  0x00100000,
        space: "data",
        access: "RW"
    EXT_HEAP: {
        base: 0x95200000,
        len:  0x00300000,
        space: "data",
        access: "RW"
    TRACE_BUF: {
        base: 0x9F000000,
        len:  0x00060000,
        space: "data",
        access: "RW"
    EXC_DATA: {
        base: 0x9F060000,
        len:  0x00010000,
        space: "data",
        access: "RW"
    PM_DATA: {
        base: 0x9F070000,
        len:  0x00020000,
        space: "data",
        access: "RWX"  /* should this have execute perm? */
Build.platformTable["ti.platforms.evmDRA7XX:dsp1"] = {
    externalMemoryMap: [
        [ "EXT_CODE", evmDRA7XX_ExtMemMapDsp.EXT_CODE ],
        [ "EXT_DATA", evmDRA7XX_ExtMemMapDsp.EXT_DATA ],
        [ "EXT_HEAP", evmDRA7XX_ExtMemMapDsp.EXT_HEAP ],
        [ "TRACE_BUF", evmDRA7XX_ExtMemMapDsp.TRACE_BUF ],
        [ "EXC_DATA", evmDRA7XX_ExtMemMapDsp.EXC_DATA ],
        [ "PM_DATA", evmDRA7XX_ExtMemMapDsp.PM_DATA ],
    codeMemory: "EXT_CODE",
    dataMemory: "EXT_DATA",
    stackMemory: "EXT_DATA",
Build.platformTable["ti.platforms.evmDRA7XX:dsp2"] =
	Build.platformTable["ti.platforms.evmDRA7XX:dsp1"];
/*  Memory Map for ti.platforms.evmDRA7XX:ipu2
 *  0000_4000   ????_????    5F_C000  (  ~6 MB) EXT_CODE
 *  8000_0000   ????_????    60_0000  (   6 MB) EXT_DATA
 *  8060_0000   ????_????   960_0000  (  86 MB) EXT_HEAP
var evmDRA7XX_ExtMemMapIpu2 = {
    EXT_CODE: {
        base: 0x00004000,
        len:  0x005FC000,
        space: "code",
        access: "RWX"
    EXT_DATA: {
        base: 0x80000000,
        len:  0x00600000,
        space: "data",
        access: "RW"
    EXT_HEAP: {
        base: 0x80600000,
        len:  0x09600000,
        space: "data",
        access: "RW"
    TRACE_BUF: {
        base: 0x9F000000,
        len:  0x00060000,
        space: "data",
        access: "RW"
    EXC_DATA: {
        base: 0x9F060000,
        len:  0x00010000,
        space: "data",
        access: "RW"
    PM_DATA: {
        base: 0x9F070000,
        len:  0x00020000,
        space: "data",
Build.platformTable["ti.platforms.evmDRA7XX:ipu2"] = {
        [ "EXT_CODE", evmDRA7XX_ExtMemMapIpu2.EXT_CODE ],
        [ "EXT_DATA", evmDRA7XX_ExtMemMapIpu2.EXT_DATA ],
        [ "EXT_HEAP", evmDRA7XX_ExtMemMapIpu2.EXT_HEAP ],
        [ "TRACE_BUF", evmDRA7XX_ExtMemMapIpu2.TRACE_BUF ],
        [ "EXC_DATA", evmDRA7XX_ExtMemMapIpu2.EXC_DATA ],
        [ "PM_DATA", evmDRA7XX_ExtMemMapIpu2.PM_DATA ]
/*  Memory Map for ti.platforms.evmDRA7XX:ipu1
 *  0000_4000   ????_????     F_C000  (  ~1 MB) EXT_CODE
 *  8000_0000   ????_????    20_0000  (   2 MB) EXT_DATA
 *  8020_0000   ????_????    30_0000  (   3 MB) EXT_HEAP
var evmDRA7XX_ExtMemMapIpu1 = {
    EXT_CODE: {
        base: 0x00004000,
        len:  0x000FC000,
        space: "code",
        access: "RWX"
    EXT_DATA: {
        base: 0x80000000,
        len:  0x00200000,
        space: "data",
        access: "RW"
    EXT_HEAP: {
        base: 0x80200000,
        len:  0x00300000,
        space: "data",
        access: "RW"
    TRACE_BUF: {
        base: 0x9F000000,
        len:  0x00060000,
        space: "data",
        access: "RW"
    EXC_DATA: {
        base: 0x9F060000,
        len:  0x00010000,
        space: "data",
        access: "RW"
    PM_DATA: {
        base: 0x9F070000,
        len:  0x00020000,
        space: "data",
Build.platformTable["ti.platforms.evmDRA7XX:ipu1"] = {
        [ "EXT_CODE", evmDRA7XX_ExtMemMapIpu1.EXT_CODE ],
        [ "EXT_DATA", evmDRA7XX_ExtMemMapIpu1.EXT_DATA ],
        [ "EXT_HEAP", evmDRA7XX_ExtMemMapIpu1.EXT_HEAP ],
        [ "TRACE_BUF", evmDRA7XX_ExtMemMapIpu1.TRACE_BUF ],
        [ "EXC_DATA", evmDRA7XX_ExtMemMapIpu1.EXC_DATA ],
        [ "PM_DATA", evmDRA7XX_ExtMemMapIpu1.PM_DATA ]
Please give some pointer to resolve this.
Thanks & Regards,
Snehal
  • Hi, Snehal,
    The prebuilt ex02_messageq example supports running on DSP2. Please read the IPC Quick Start Guide on the section of "Running IPC Linux examples".
    software-dl.ti.com/.../Foundational_Components_IPC.html
    The prebuilt images are located in /usr/bin/ipc/examples/ex02_messageq/debug folder.
    You can also refer to the config.bld in rtos_pdk/ipc/examples/DRA7xx_linus_efl/ex02_messageq/dsp2 folder and rtos_pdk/ipc/package/ti/ipc/remoteproc/rsc_table_vayu_dsp.h to see how it is configured
    Rex
  • Hi Rex,
    We have tried to run prebuild images for dsp2 which is working fine and compile using a makefile form ti/ipc_3_47_01_00/examples/DRA7XX_linux_elf/ex02_messageq/
    But when I try to run this ex02_messageq example build using CCS while binding it giving the kernel crash.
    root@Allaska:~# ./dsp2.sh
    root@Allaska:~# [ 3592.216411] INFO: rcu_preempt self-detected stall on CPU
    [ 3592.221769] 1-...: (1 GPs behind) idle=46b/2/0 softirq=72422/72423 fqs=992
    [ 3592.228846] (t=2100 jiffies g=40102 c=40101 q=181477)
    [ 3595.675964] INFO: rcu_sched detected stalls on CPUs/tasks:
    [ 3595.681516] 1-...: (1 GPs behind) idle=46b/2/0 softirq=71972/72423 fqs=1000
    [ 3595.688717]
    I have compared resource table and a config file with prebuild example source code, other than heap memory size allocation there is no such change.
    Could you give some pointer what I am missing?
    Snehal
  • Hi, Snehal,
    I'll have someone knows better on CCS build to work with you.
    Rex
  • Hello Snehal,
    Please make sure your project's platform is defined correctly under Project Properties > General > Products > Platform. It should be set to ti.platforms.evmDRA7XX:dsp2
    Are you adding rsc_table_vayu_dsp.c to your project? I do not think this is required as IPC automatically generates one. Can you try with  rsc_table_vayu_dsp.c excluded from the build?
    If you do plan on making changes to the resource table, then you will need to add rsc_table_vayu_dsp.c  to your project and add the following to the cfg file:
    /* Override the default resource table with my own */
    var Resource = xdc.useModule('ti.ipc.remoteproc.Resource');
    Resource.customTable = true;
    Also, please check the makefile in ~\ipc\examples\DRA7XX_linux_elf\ex02_messageq\dsp2 for any compiler and linker flags you may need to add to your project, e.g "CFLAGS, LDFLAGS."
    Sahin
