TDA2SX: TIDL conversion
Part Number: TDA2SX
Other Parts Discussed in Thread: TDA2
Hi everyone, I have one model which I want to convert to be able to use it on TDA2.  Model is trained in Caffe framework. Model is trained for pedestrian detection and output is represented by 100 bounding boxes where every bounding box is described by 7 attributes:
1. BBox index
2. label ID
3. confidence
4. x1/width
5. y1/height
6. x2/width
7. y2.height
I did conversion with tidl_model_import.out application, model is tested with eve_test_dl_algo.out.exe application and as a result stats_tool_out.bin file is generated. What I noticed is that not all information about bounding boxes are populated. Instead of 100 bbox information, I got a lot less. For other bounding boxes, all attributes are populated with zeros instead of BBox index which have value -1.
Can this be sign of not good conversion process?
Output file is in attachment.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/stats_5F00_tool_5F00_out.7z
Thanks in advance,
Sasa
