DM365 LCD_OE
PINMUX1=0x145555 ;
     * Setup clocking / DACs
    VDAC_CONFIG         = 0x081141EF;   // Take DACs out of power down mode, enable HD component out
    VPSS_CLKCTL         = 0x00000018;   // Enable DAC and VENC clock
    VPSS_VPBE_CLK_CTRL  = 0x00000011;   // Select enc_clk*1, turn on VPBE clk
VENC_CLKCTL         = 0x00000011;   // Enable venc & digital LCD clock
    VENC_XHINTVL        = 0x00000000;   // Extend standard 720P horizontal timing
     *  Setup VENC
    VENC_VMOD   = 0x01C3;   // 720P(0x01c3)
    VENC_VDPRO  = 0x0100;   // 0x0100; Colorbars not normal display mode
    VENC_DACTST = 0x0000;   // Power on DACs
    VENC_DACSEL = 0x0543;   // Component out on DACs
PINMUX
    /* Enable LCD outputs for test */
    VPSS_MISR_CTRL = 0x0003;
VENC_VIOCTL    = 0x2000;
VENC_SYNCCTL   = 0x0003;
VENC_LCDOUT    = 0x000;//0x0001;
VENC_DCLKCTL   = 0x8800;
VENC_DCLKPTN0  = 0x0001;
I can't observe the LCD_OE signal on the PIN(LCD_OE/GIO82)  and GIO91/COUT6(G3)/PWM1 when I set VENC_LCDOUT    = 0x000 or 0x0001 through oscillograph
I can observe the VS & HS on the PIN  through oscillograph. The analog video out is OK on the tv.
The board was designed by Beijing AVSolution Technology Co.,Ltd.
