RTOS/TDA2EXEVM: TI-RTOS/TDA2X EVM: [External ] SBL image bootup successfully, app start failure
Part Number: TDA2EXEVM
Other Parts Discussed in Thread: TDA2
Tool/software: TI-RTOS
Due to our customer complained at the time(Linux image) too long from Target_A15 boot up to HDMI display (~30 seconds).
Even though we remove all debug message, it still  can’t meet customer’s requirement.
We must revert to TI/RTOS image (BIOS), configured MAKECONFIG=tda2xx_evm_bios_all based on VSDK(v.3.6) package for TDA2XX_EVM .
As the TDS_SBL_UserGuide described that copy MLO image and AppImage into SD card (FAT32 system).
               $make -j depend
               $make -j sbl
              $make -j vision_sdk
              $make -j appimage
It seems SBL boot up successfully from MMCSD, but the app can’t start failure.
Could you help teach us how to solve the issue? Thanks.
BTW, because my build environment work on Ubuntu System,
It seems that the latest VisionSDK requires MSHIELD-DK/SECDEV package support for security protection.
It defaults image signing tool to sign SBL & AppImages on Ubuntu/Linux machine.
The parameter of “sign_rprc_image” in the build image command.
Could you help teach us how to install MSHIELD-DK package? Thanks.
 TDA2xx SBL Boot
 DPLL Configuration Completed
 Clock Domain Configuration Completed
 Module Enable Configuration Completed
 TI EVM PAD Config Completed
 DDR Config Completed
 App Image Download Begins
 SD Boot - file open completed successfully
 MPU CPU0 Image Load Completed
 IPU1 CPU0 Image Load Completed
 IPU1 CPU1 Image Load Completed
 IPU2 CPU0 and CPU1 Image Load Completed
 DSP1 Image Load Completed
 DSP2 Image Load Completed
 EVE1 Image Load Completed
 EVE2 Image Load Completed
 EVE3 Image Load Completed
 EVE4 Image Load Completed
 App Image Download Completed
 Putting MPU CPU1 in Off mode
 EVE MMU configuration completed
 PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
 SBL Initial Config Cycles - 144411  (12.32 ms)
 SOC Init Cycles - 264232  (22.54 ms)
 DDR Config Clock Cycles - 68133  (5.81 ms)
 App Image Load Cycles - 112960954  (9639.33 ms)
 Slave Core Bootup Cycles - 323075  (27.56 ms)
 SBL Boot-up Cycles - 113762140  (9707.70 ms)
 Time at which SBL started IPU1_0 - 211934  (18.8 ms)
 Jumping to MPU CPU0 App
make -fbuild_multi_core_image_gen.mk -C/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/build/rtos/makerules
make[1]: Entering directory '/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/build/rtos/makerules'
mkdir -p /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot
# Creating Vision SDK AppImage ...
# Including A15 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg.
File conversion complete!
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg.rprc
make[2]: Entering directory '/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/build/rtos/makerules'
make[2]: Nothing to be done for 'sign_rprc_image'.
make[2]: Leaving directory '/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/build/rtos/makerules'
# Including IPU1-0 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4.rprc
# Including IPU1-1 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4.
Object reference not set to an instance of an objectEncountered exception:
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4.rprc
# Including IPU2 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4.rprc
# Including DSP1 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66.rprc
# Including DSP2 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66.rprc
# Including EVE1 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.rprc
# Including EVE2 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.rprc
# Including EVE3 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.rprc
# Including EVE4 ...
mono /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//out2rprc/out2rprc.exe /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.rprc
Parsing the input object file, /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.
make -fbuild_multi_core_image_gen.mk sign_rprc_image INPUT_IMAGE=/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.rprc
make -fbuild_multi_core_image_gen.mk normal_boot
# Generating LE AppImage ...
/bin/chmod u+x /home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//multicore_image_generator/v2/MulticoreImageGen
/home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//multicore_image_generator/v2/MulticoreImageGen LE 55 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot/AppImage_LE  0 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg.rprc 2 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4.rprc 3 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4.rprc 7 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4.rprc 8 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66.rprc 9 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66.rprc 10 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.rprc 11 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.rprc 12 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.rprc 13 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.rprc
Number of Input Files 10
# Generating BE AppImage ...
/home/sam/proj/TI_VISION_SDK_V3_6/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/tools//multicore_image_generator/v2/MulticoreImageGen BE 55 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot/AppImage_BE  0 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_a15_0_release.xa15fg.rprc 2 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4.rprc 3 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_1_release.xem4.rprc 7 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4.rprc 8 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66.rprc 9 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66.rprc 10 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.rprc 11 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.rprc 12 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.rprc 13 /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.rprc
cp /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot/AppImage_LE /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot/AppImage
# AppImage is @ /home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/binaries/apps/tda2xx_evm_bios_all/vision_sdk/bin/tda2xx-evm/sbl_boot/AppImage
make[1]: Leaving directory '/home/sam/proj/TI_VISION_SDK_V3_6/vision_sdk/build/rtos/makerules'
BR,
Sam Hsieh
    If you boot from TI-RTOS Image then you have to manually start your usecase.
    It will show you the usecase menu and stop.
    Which usecase you want to run?
    Anuj
  • Hi Anuj,
    Thanks for your feedback.
    I rebuild whole AppImage without any modification,
    it just show that  Jumping to MPU CPU0 App, then system hang.
    it doesn't enter the usercase menu select.
    We plan to run the Usercase of 4CHs AVB Capture + SRV.
    But I confirmed that the pre-built image work fine on TDA2 board.
    BRs,
    Sam Hsieh
