Part Number: PROCESSOR-SDK-TDAX
Tool/software: TI-RTOS
I'm testing with below environment but facing the problem what capturing is not working. (sometimes it is working, 10 tries, 7 failed, 3 succeed)
1. TDA2X EVM board
2. Using HDMI input 720p@60hz as capture source. (EDID information in EEPROM was updated)
3. Input width of capture is 1280 and height is 720.
Output width of VIP is 1280 and height is 720.
4. Crop functionality is enabled. (Enabled to check the cropping functionality)
crop.x = 0, crop.y=0, width=1280, height=720
5. The data format of VIP is SYSTEM_DF_BGR24_888.
I tried to compare the VIP registers and I found one difference between them.
VIP_OUTPUT_PORT_A_SRC0_SIZE
When working, this register has 0x050002D0.
When not working, it has 0x05010056
I'm suspecting that VIP doesn't capture the whole image.
I attached the full dump of the VIP registers.
Please let me know a solution to fix this issue.
Thanks in advance,
Ray
521177 21 R VIP1_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP1_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1B5C0 R VIP1_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080002 R VIP1_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00010000 R VIP1_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP1_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x04FF02CF R VIP1_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x04FF0167 R VIP1_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000800 R VIP1_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x0010000C R VIP1_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000001 R VIP1_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000800 R VIP1_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x0010000C R VIP1_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000001 R VIP1_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON34 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON58 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x0000C000 R VIP1_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00008000 R VIP1_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x0000C000 R VIP1_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP2_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1C4C0 R VIP2_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080000 R VIP2_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP2_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x00100000 R VIP2_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON34 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON58 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP3_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1C4C0 R VIP3_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080000 R VIP3_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP3_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x00100000 R VIP3_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON34 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON58 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP1_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP1_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000001 R VIP1_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000001 R VIP1_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP1_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x80000081 R VIP1_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP2_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP2_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP2_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP3_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP3_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP3_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP1_Slice0_csc_VIP_CSC00 0x0000000B 0x000004A8 R VIP1_Slice0_csc_VIP_CSC01 0x0000000B 0x04A8072C R VIP1_Slice0_csc_VIP_CSC02 0x0000000B 0x1DDE1F26 R VIP1_Slice0_csc_VIP_CSC03 0x0000000B 0x087304A8 R VIP1_Slice0_csc_VIP_CSC04 0x0000000B 0x0C200000 R VIP1_Slice0_csc_VIP_CSC05 0x0000000B 0x0B7C0134 R VIP1_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_MAIN 0x0000000B 0x00000001 R VIP1_Slice0_parser_VIP_PORT_A 0x0000000B 0x0040B904 R VIP1_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x050002D0 R VIP1_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP1_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFD R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFD R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x05010056 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x05008000 R VIP1_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x02D00000 R VIP1_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP1_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP1_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP2_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP2_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP2_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP2_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP3_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP3_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP3_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP3_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP1_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP1_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP1_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP1_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP1_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP1_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP1_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP1_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP1_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP1_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP2_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP2_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP2_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP2_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP2_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP2_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP2_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP2_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP2_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP2_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP3_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP3_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP3_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP3_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP3_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP3_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP3_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP3_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP3_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP3_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000
521177 21 R VIP1_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP1_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1B5C0 R VIP1_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080002 R VIP1_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00010000 R VIP1_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP1_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x04FF02CF R VIP1_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x04FF0167 R VIP1_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000800 R VIP1_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x0010000C R VIP1_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000001 R VIP1_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000800 R VIP1_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x0010000C R VIP1_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000001 R VIP1_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON34 0x0000000B 0x00005305 R VIP1_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON58 0x0000000B 0x00005305 R VIP1_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP1_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x00008000 R VIP1_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x00008000 R VIP1_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP1_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP2_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1C4C0 R VIP2_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080000 R VIP2_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP2_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x00100000 R VIP2_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON34 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON58 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP2_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP2_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PID 0x0000000B 0x4D0001B8 R VIP3_VPDMA_VIP_LIST_ADDR 0x0000000B 0x9FD1C4C0 R VIP3_VPDMA_VIP_LIST_ATTR 0x0000000B 0x00080000 R VIP3_VPDMA_VIP_LIST_STAT_SYNC 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_BG_RGB 0x0000000B 0x000000FF R VIP3_VPDMA_VIP_BG_YUV 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_VPDMA_SETUP 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE1 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE2 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_MAX_SIZE3 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT0_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL1_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL2_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL2_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL3_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL3_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL4_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL4_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL5_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CHANNEL5_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_CLIENT1_INT_STAT 0x0000000B 0x00100000 R VIP3_VPDMA_VIP_INT1_CLIENT1_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_LIST0_INT_STAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_INT1_LIST0_INT_MASK 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON0 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON1 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON2 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON3 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON4 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON5 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON6 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON7 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON8 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON9 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON10 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON11 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON12 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON13 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON14 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON15 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON16 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON17 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON18 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON19 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON20 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON21 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON22 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON23 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON24 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON25 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON26 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON27 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON28 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON29 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON30 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON31 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON32 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON33 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON34 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON35 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON36 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON37 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON38 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON39 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON40 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON41 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON42 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON43 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON44 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON45 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON46 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON47 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON48 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON49 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON50 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON51 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON52 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON53 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON54 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON55 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON56 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON57 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON58 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON59 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON60 0x0000000B 0x00000000 R VIP3_VPDMA_VIP_PERF_MON61 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_LO_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_LO_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_UP_Y_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_UP_UV_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VPI_CTL_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP0_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_ANC_A_CSTAT 0x0000000B 0x00000000 R VIP3_VPDMA_VIP1_ANC_B_CSTAT 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP1_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP1_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000001 R VIP1_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000001 R VIP1_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP1_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP1_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP1_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x80000081 R VIP1_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP2_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP2_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP2_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP2_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x00000000 R VIP2_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_PID 0x0000000B 0x4F020800 R VIP3_top_level_VIP_SYSCONFIG 0x0000000B 0x00000028 R VIP3_top_level_VIP_INTC_INTR0_STATUS_RAW0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_RAW1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_ENA0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_STATUS_ENA1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_SET0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_SET1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_CLR0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR0_ENA_CLR1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_RAW0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_RAW1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_ENA0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_STATUS_ENA1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_SET0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_SET1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_CLR0 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_INTR1_ENA_CLR1 0x0000000B 0x00000000 R VIP3_top_level_VIP_INTC_EOI 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_CLKEN 0x0000000B 0x00030001 R VIP3_top_level_VIP_CLKC_RST 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_VIP0DPS 0x0000000B 0x00000000 R VIP3_top_level_VIP_CLKC_VIP1DPS 0x0000000B 0x00000000 R VIP1_Slice0_csc_VIP_CSC00 0x0000000B 0x000004A8 R VIP1_Slice0_csc_VIP_CSC01 0x0000000B 0x04A8072C R VIP1_Slice0_csc_VIP_CSC02 0x0000000B 0x1DDE1F26 R VIP1_Slice0_csc_VIP_CSC03 0x0000000B 0x087304A8 R VIP1_Slice0_csc_VIP_CSC04 0x0000000B 0x0C200000 R VIP1_Slice0_csc_VIP_CSC05 0x0000000B 0x0B7C0134 R VIP1_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP1_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP2_Slice0_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP2_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP3_Slice0_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC00 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC01 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC02 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC03 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC04 0x0000000B 0x00000000 R VIP3_Slice1_csc_VIP_CSC05 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_MAIN 0x0000000B 0x00000001 R VIP1_Slice0_parser_VIP_PORT_A 0x0000000B 0x0040B904 R VIP1_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x050002D0 R VIP1_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP1_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFC R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFC R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x050002D0 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x05008000 R VIP1_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x02D00000 R VIP1_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP1_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP1_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP1_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP1_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP2_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP2_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP2_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP2_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP2_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP2_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP3_Slice0_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP3_Slice0_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP3_Slice0_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_MAIN 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_FIQ_MASK 0x0000000B 0x003FFEDF R VIP3_Slice1_parser_VIP_FIQ_CLEAR 0x0000000B 0x003FFEDF R VIP3_Slice1_parser_VIP_FIQ_STATUS 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_ENC_FID 0x0000000B 0xFFFFFFFF R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_A_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC0_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC1_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC2_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC3_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC4_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC5_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC6_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC7_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC8_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC9_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC10_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC11_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC12_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC13_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC14_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_OUTPUT_PORT_B_SRC15_SIZE 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_A_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_PORT_B_VDET_VEC 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_HORZ_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_VERT_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_ANC_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_HORZ_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_CROP_VERT_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA6_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA7_PORT_B 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA8_PORT_A 0x0000000B 0x00000000 R VIP3_Slice1_parser_VIP_XTRA9_PORT_B 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP1_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP1_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP1_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP1_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP1_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP1_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP1_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP1_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP1_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP1_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP1_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP1_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP2_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP2_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP2_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP2_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP2_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP2_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP2_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP2_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP2_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP2_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP2_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP2_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP3_Slice0_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP3_Slice0_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP3_Slice0_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP3_Slice0_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP3_Slice0_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP3_Slice0_sc_VIP_CFG_SC25 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC0 0x0000000B 0x00004000 R VIP3_Slice1_sc_VIP_CFG_SC1 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC2 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC3 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC4 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC5 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC6 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC8 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC9 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC10 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC11 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC12 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC13 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC18 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC19 0x0000000B 0xFC000000 R VIP3_Slice1_sc_VIP_CFG_SC20 0x0000000B 0x0C840800 R VIP3_Slice1_sc_VIP_CFG_SC21 0x0000000B 0x00100010 R VIP3_Slice1_sc_VIP_CFG_SC22 0x0000000B 0x00000190 R VIP3_Slice1_sc_VIP_CFG_SC24 0x0000000B 0x00000000 R VIP3_Slice1_sc_VIP_CFG_SC25 0x0000000B 0x00000000
