Part Number: AM3352
Tool/software: Linux
Our USB device (based on Cypress FX2LP controller) keeps getting disconnected when connected directly to AM3352 USB bus. At first, it disconnects and reconnects successfully but after a while (a couple of minutes), the device stops accepting device address.
Moreover,
The USB device works properly when connected to the bus via a USB hub.
And, other USB devices are able to connect directly to that bus.
Below is the dmesg log:
[ 683.811927] usb 1-1: new high-speed USB device number 119 using musb-hdrc
[ 683.952183] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 683.952201] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 683.953741] usbtest 1-1:1.0: FX2 device
[ 683.953764] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 683.959870] usb 1-1: USB disconnect, device number 119
[ 684.391960] usb 1-1: new high-speed USB device number 120 using musb-hdrc
[ 684.532149] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 684.532164] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 684.533602] usbtest 1-1:1.0: FX2 device
[ 684.533649] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 686.155465] usb 1-1: USB disconnect, device number 120
[ 686.591958] usb 1-1: new high-speed USB device number 121 using musb-hdrc
[ 686.732147] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 686.732163] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 686.733646] usbtest 1-1:1.0: FX2 device
[ 686.733671] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 687.735213] usb 1-1: USB disconnect, device number 121
[ 688.171913] usb 1-1: new high-speed USB device number 122 using musb-hdrc
[ 688.312107] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 688.312125] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 688.313695] usbtest 1-1:1.0: FX2 device
[ 688.313720] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 688.799512] usb 1-1: USB disconnect, device number 122
[ 689.231978] usb 1-1: new high-speed USB device number 123 using musb-hdrc
[ 689.372156] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 689.372172] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 689.373819] usbtest 1-1:1.0: FX2 device
[ 689.373841] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 689.466926] usb 1-1: USB disconnect, device number 123
[ 689.901922] usb 1-1: new high-speed USB device number 124 using musb-hdrc
[ 690.042108] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 690.042126] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 690.043696] usbtest 1-1:1.0: FX2 device
[ 690.043720] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 690.163069] usb 1-1: USB disconnect, device number 124
[ 690.601955] usb 1-1: new high-speed USB device number 125 using musb-hdrc
[ 690.742083] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 690.742099] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 690.743557] usbtest 1-1:1.0: FX2 device
[ 690.743580] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 692.860387] usb 1-1: USB disconnect, device number 125
[ 693.301974] usb 1-1: new high-speed USB device number 126 using musb-hdrc
[ 693.442159] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 693.442175] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 693.443712] usbtest 1-1:1.0: FX2 device
[ 693.443736] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 693.688230] usb 1-1: USB disconnect, device number 126
[ 694.121960] usb 1-1: new high-speed USB device number 127 using musb-hdrc
[ 694.262208] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 694.262226] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 694.263853] usbtest 1-1:1.0: FX2 device
[ 694.263878] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 694.452772] usb 1-1: USB disconnect, device number 127
[ 694.892049] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 695.032130] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 695.032151] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 695.033787] usbtest 1-1:1.0: FX2 device
[ 695.033813] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 695.058646] usb 1-1: USB disconnect, device number 2
[ 695.492166] usb 1-1: new high-speed USB device number 3 using musb-hdrc
[ 695.632090] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 695.632108] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 695.633641] usbtest 1-1:1.0: FX2 device
[ 695.633666] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 696.347413] usb 1-1: USB disconnect, device number 3
[ 696.781917] usb 1-1: new high-speed USB device number 4 using musb-hdrc
[ 696.922504] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 696.922527] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 696.924154] usbtest 1-1:1.0: FX2 device
[ 696.924179] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 697.165271] usb 1-1: USB disconnect, device number 4
[ 697.601907] usb 1-1: new high-speed USB device number 5 using musb-hdrc
[ 697.742105] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 697.742168] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 697.743681] usbtest 1-1:1.0: FX2 device
[ 697.743705] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 698.267044] usb 1-1: USB disconnect, device number 5
[ 698.701912] usb 1-1: new high-speed USB device number 6 using musb-hdrc
[ 699.122151] usb 1-1: new high-speed USB device number 7 using musb-hdrc
[ 699.262093] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 699.262110] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 699.263732] usbtest 1-1:1.0: FX2 device
[ 699.263754] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 699.889653] usb 1-1: USB disconnect, device number 7
[ 700.322001] usb 1-1: new high-speed USB device number 8 using musb-hdrc
[ 700.462117] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 700.462134] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 700.463727] usbtest 1-1:1.0: FX2 device
[ 700.463751] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 701.563592] usb 1-1: USB disconnect, device number 8
[ 702.001926] usb 1-1: new high-speed USB device number 9 using musb-hdrc
[ 702.142108] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 702.142124] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 702.143731] usbtest 1-1:1.0: FX2 device
[ 702.143755] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 702.538328] usb 1-1: USB disconnect, device number 9
[ 702.972290] usb 1-1: new high-speed USB device number 10 using musb-hdrc
[ 703.112108] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 703.112127] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 703.112978] usbtest 1-1:1.0: FX2 device
[ 703.112999] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 703.970272] usb 1-1: USB disconnect, device number 10
[ 704.411965] usb 1-1: new high-speed USB device number 11 using musb-hdrc
[ 704.552159] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 704.552175] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 704.553717] usbtest 1-1:1.0: FX2 device
[ 704.553741] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 704.799817] usb 1-1: USB disconnect, device number 11
[ 705.231965] usb 1-1: new high-speed USB device number 12 using musb-hdrc
[ 705.651952] usb 1-1: new high-speed USB device number 13 using musb-hdrc
[ 705.792134] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 705.792150] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 705.793764] usbtest 1-1:1.0: FX2 device
[ 705.793789] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 707.237052] usb 1-1: USB disconnect, device number 13
[ 707.671910] usb 1-1: new high-speed USB device number 14 using musb-hdrc
[ 707.812328] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 707.812345] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 707.813885] usbtest 1-1:1.0: FX2 device
[ 707.813908] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 708.348295] usb 1-1: USB disconnect, device number 14
[ 708.781903] usb 1-1: new high-speed USB device number 15 using musb-hdrc
[ 708.922172] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 708.922189] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 708.923705] usbtest 1-1:1.0: FX2 device
[ 708.923729] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 710.152554] usb 1-1: USB disconnect, device number 15
[ 710.591907] usb 1-1: new high-speed USB device number 16 using musb-hdrc
[ 716.131971] usb 1-1: device not accepting address 16, error -110
[ 716.471906] usb 1-1: new high-speed USB device number 18 using musb-hdrc
[ 717.031907] usb 1-1: new high-speed USB device number 20 using musb-hdrc
[ 717.172216] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 717.172239] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 717.173905] usbtest 1-1:1.0: FX2 device
[ 717.173930] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 718.470296] usb 1-1: USB disconnect, device number 20
[ 718.911908] usb 1-1: new high-speed USB device number 21 using musb-hdrc
[ 719.052110] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 719.052129] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 719.053628] usbtest 1-1:1.0: FX2 device
[ 719.053651] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 720.269968] usb 1-1: USB disconnect, device number 21
[ 720.711909] usb 1-1: new high-speed USB device number 22 using musb-hdrc
[ 720.852165] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 720.852184] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 720.853718] usbtest 1-1:1.0: FX2 device
[ 720.853742] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 721.317798] usb 1-1: USB disconnect, device number 22
[ 721.751913] usb 1-1: new high-speed USB device number 23 using musb-hdrc
[ 721.892323] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 721.892340] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 721.893889] usbtest 1-1:1.0: FX2 device
[ 721.893912] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 723.645055] usb 1-1: USB disconnect, device number 23
[ 724.081908] usb 1-1: new high-speed USB device number 24 using musb-hdrc
[ 724.222132] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 724.222156] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 724.223791] usbtest 1-1:1.0: FX2 device
[ 724.223816] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 726.837220] usb 1-1: USB disconnect, device number 24
[ 727.271921] usb 1-1: new high-speed USB device number 25 using musb-hdrc
[ 727.691902] usb 1-1: new high-speed USB device number 26 using musb-hdrc
[ 727.832322] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 727.832338] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 727.833969] usbtest 1-1:1.0: FX2 device
[ 727.833993] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 728.451418] usb 1-1: USB disconnect, device number 26
[ 728.891955] usb 1-1: new high-speed USB device number 27 using musb-hdrc
[ 729.032084] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 729.032100] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 729.033614] usbtest 1-1:1.0: FX2 device
[ 729.033638] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 731.462442] usb 1-1: USB disconnect, device number 27
[ 731.902127] usb 1-1: new high-speed USB device number 28 using musb-hdrc
[ 732.042091] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 732.042108] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 732.043631] usbtest 1-1:1.0: FX2 device
[ 732.043654] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 735.495688] usb 1-1: USB disconnect, device number 28
[ 735.931955] usb 1-1: new high-speed USB device number 29 using musb-hdrc
[ 736.072101] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 736.072118] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 736.073652] usbtest 1-1:1.0: FX2 device
[ 736.073675] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 737.265978] usb 1-1: USB disconnect, device number 29
[ 737.701916] usb 1-1: new high-speed USB device number 30 using musb-hdrc
[ 743.241921] usb 1-1: device not accepting address 30, error -110
[ 743.281994] udevd[836]: worker [917] /devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/usb1/1-1/1-1:1.0 timeout; kill it
[ 743.295805] udevd[836]: seq 1294 '/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/usb1/1-1/1-1:1.0' killed
[ 743.308513] udevd[836]: worker [917] terminated by signal 9 (Killed)
[ 743.308568] udevd[836]: worker [917] failed while handling '/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/usb1/1-1/1-1:1.0'
[ 743.581911] usb 1-1: new high-speed USB device number 32 using musb-hdrc
[ 743.722094] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 743.722111] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 743.722971] usbtest 1-1:1.0: FX2 device
[ 743.722990] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 745.216816] usb 1-1: USB disconnect, device number 32
[ 745.652157] usb 1-1: new high-speed USB device number 33 using musb-hdrc
[ 745.792098] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 745.792115] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 745.793764] usbtest 1-1:1.0: FX2 device
[ 745.793788] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 746.764053] usb 1-1: USB disconnect, device number 33
[ 747.201959] usb 1-1: new high-speed USB device number 34 using musb-hdrc
[ 747.342169] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 747.342189] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 747.343791] usbtest 1-1:1.0: FX2 device
[ 747.343815] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 747.454768] usb 1-1: USB disconnect, device number 34
[ 747.891959] usb 1-1: new high-speed USB device number 35 using musb-hdrc
[ 748.451922] usb 1-1: new high-speed USB device number 37 using musb-hdrc
[ 748.592124] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 748.592145] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 748.593826] usbtest 1-1:1.0: FX2 device
[ 748.593852] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 749.607802] usb 1-1: USB disconnect, device number 37
[ 750.041910] usb 1-1: new high-speed USB device number 38 using musb-hdrc
[ 750.182116] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 750.182134] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 750.183738] usbtest 1-1:1.0: FX2 device
[ 750.183763] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 750.714985] usb 1-1: USB disconnect, device number 38
[ 751.152131] usb 1-1: new high-speed USB device number 39 using musb-hdrc
[ 751.292096] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 751.292113] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 751.293705] usbtest 1-1:1.0: FX2 device
[ 751.293728] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 751.858548] usb 1-1: USB disconnect, device number 39
[ 752.291961] usb 1-1: new high-speed USB device number 40 using musb-hdrc
[ 752.432138] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 752.432157] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 752.433791] usbtest 1-1:1.0: FX2 device
[ 752.433813] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 752.952301] usb 1-1: USB disconnect, device number 40
[ 753.391956] usb 1-1: new high-speed USB device number 41 using musb-hdrc
[ 753.532203] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 753.532225] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 753.533971] usbtest 1-1:1.0: FX2 device
[ 753.533996] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 753.963144] usb 1-1: USB disconnect, device number 41
[ 754.401994] usb 1-1: new high-speed USB device number 42 using musb-hdrc
[ 754.542108] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 754.542131] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 754.543782] usbtest 1-1:1.0: FX2 device
[ 754.543807] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 756.442275] usb 1-1: USB disconnect, device number 42
[ 756.882067] usb 1-1: new high-speed USB device number 43 using musb-hdrc
[ 757.022194] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 757.022212] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 757.023062] usbtest 1-1:1.0: FX2 device
[ 757.023084] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 759.283310] usb 1-1: USB disconnect, device number 43
[ 759.721913] usb 1-1: new high-speed USB device number 44 using musb-hdrc
[ 759.862111] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 759.862128] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 759.863796] usbtest 1-1:1.0: FX2 device
[ 759.863821] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 760.425402] usb 1-1: USB disconnect, device number 44
[ 760.861911] usb 1-1: new high-speed USB device number 45 using musb-hdrc
[ 761.002313] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 761.002332] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 761.003178] usbtest 1-1:1.0: FX2 device
[ 761.003199] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 765.700061] usb 1-1: USB disconnect, device number 45
[ 766.141909] usb 1-1: new high-speed USB device number 46 using musb-hdrc
[ 766.282187] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 766.282205] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 766.283792] usbtest 1-1:1.0: FX2 device
[ 766.283817] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 766.440882] usb 1-1: USB disconnect, device number 46
[ 766.882158] usb 1-1: new high-speed USB device number 47 using musb-hdrc
[ 767.022103] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 767.022121] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 767.023880] usbtest 1-1:1.0: FX2 device
[ 767.023904] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 767.243519] usb 1-1: USB disconnect, device number 47
[ 767.681920] usb 1-1: new high-speed USB device number 48 using musb-hdrc
[ 767.822186] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 767.822203] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 767.823812] usbtest 1-1:1.0: FX2 device
[ 767.823836] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 768.471149] usb 1-1: USB disconnect, device number 48
[ 768.911913] usb 1-1: new high-speed USB device number 49 using musb-hdrc
[ 769.052111] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 769.052129] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 769.053805] usbtest 1-1:1.0: FX2 device
[ 769.053828] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 769.721543] usb 1-1: USB disconnect, device number 49
[ 770.161908] usb 1-1: new high-speed USB device number 50 using musb-hdrc
[ 770.302177] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 770.302193] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 770.303888] usbtest 1-1:1.0: FX2 device
[ 770.303911] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 770.518388] usb 1-1: USB disconnect, device number 50
[ 770.952140] usb 1-1: new high-speed USB device number 51 using musb-hdrc
[ 771.092101] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 771.092119] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 771.092956] usbtest 1-1:1.0: FX2 device
[ 771.092976] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 772.279346] usb 1-1: USB disconnect, device number 51
[ 772.712200] usb 1-1: new high-speed USB device number 52 using musb-hdrc
[ 772.852101] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 772.852120] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 772.853801] usbtest 1-1:1.0: FX2 device
[ 772.853825] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 774.253182] usb 1-1: USB disconnect, device number 52
[ 774.692271] usb 1-1: new high-speed USB device number 53 using musb-hdrc
[ 774.832088] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 774.832107] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 774.833772] usbtest 1-1:1.0: FX2 device
[ 774.833796] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 778.749942] usb 1-1: USB disconnect, device number 53
[ 779.191910] usb 1-1: new high-speed USB device number 54 using musb-hdrc
[ 784.731917] usb 1-1: device not accepting address 54, error -110
[ 785.071962] usb 1-1: new high-speed USB device number 56 using musb-hdrc
[ 785.212151] usb 1-1: New USB device found, idVendor=04b4, idProduct=8613
[ 785.212168] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 785.213868] usbtest 1-1:1.0: FX2 device
[ 785.213891] usbtest 1-1:1.0: high-speed {control bulk-in bulk-out} tests (+alt)
[ 787.181174] usb 1-1: USB disconnect, device number 56
Below attached is the USB monitor log captured which can be analysed using VUSB-Analyzer.
Let me know if more information is needed.
Also, apologies if I have posted this in the wrong forum. Let me know so that I'll reassign it.
Thanks and Regards.
