RTOS/AM5728: IPC example
Part Number: AM5728
Tool/software: TI-RTOS
We have AM5728 based EVM (version 3).
We are able to run ex02_messageq example on EVM and could see prints on target.
App_exec: message received, sending message 13
App_exec: message received, sending message 14
App_exec: message received, sending message 15
We want to send pcm files from  DSP to Cortex A-15 .
For this we want to use AM57x ARM-DSP IPC communication example.
Please Help where we need to do modification in code that a file can be sent instead of message.
    I am not familiar with pcm files, but if you are looking to send large amounts of data, you may want to take a look at the Big Data IPC example. This example is ideal for high performance computing applications and data intensive applications which require passing of big data buffers between cores.
    Details on the example, including building and running, can be found in the Processor SDK Software Developer's Guide linked below.
    software-dl.ti.com/.../index_examples_demos.html
    Hope this helps.
    Sahin
