Part Number: AM5728
Other Parts Discussed in Thread: TVP5158, TVP5150
Tool/software: Linux
Hello, I am using the Linux Processor SDK for AM57x v05.02.00.10
I am developing a driver for tw2964 video decoder. As a basic example, I took the tvp5150 and tvp5158 drivers.
I connected the tw2964 to the P9 connector of the TMDSEVM572X kit. See the diagram.
TVP connects to AM5728 as follows:
tw2964 (vd1(0)) <=> am5728 (vin3a_d0)
tw2964 (vd1(1)) <=> am5728 (vin3a_d1)
tw2964 (vd1(2)) <=> am5728 (vin3a_d2)
tw2964 (vd1(3)) <=> am5728 (vin3a_d3)
tw2964 (vd1(4)) <=> am5728 (vin3a_d4)
tw2964 (vd1(5)) <=> am5728 (vin3a_d5)
tw2964 (vd1(6)) <=> am5728 (vin3a_d6)
tw2964 (vd1(7)) <=> am5728 (vin3a_d7)
tw2964 (clkp0) <=> am5728 (vin3a_clko)
Now tw2964 driver successfully works in EMBEDDED_SYNC_SINGLE_YUV422 mode for one vip (vin3a). But I need to do EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 for two separate vip.
I've read http://wiki.tiprocessors.com/index.php/Processor_SDK_VIP_Driver#Video_Input_Port. Аnd now I have serious concerns about work EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 and EMBEDDED_SYNC_4X_MULTIPLEXED_YUV422
Therefore, I had 3 questions:
1. Is the vip.c driver able to work in pixel interleaved method mode aka EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 or EMBEDDED_SYNC_4X_MULTIPLEXED_YUV422?
2. How to implement multichannel single subdevice to work with different vip in EMBEDDED_SYNC_SINGLE_YUV422 mode (some examples)?
Before I ask last questions, I will tell that do not working in EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 mode for vin3a.
[ 93.802177] tw2964: start probe [ 93.802360] tw2964 4-0029: GPIO lookup for consumer reset [ 93.802367] tw2964 4-0029: using device tree for GPIO lookup [ 93.802401] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/i2c@4807c000/tw2964@29[0]' - status (0) [ 93.802736] tw2964: tw2964_init() [ 93.802742] tw2964: tw2964_kzalloc() [ 93.802765] tw2964: tw2964_parse_dt() [ 93.802775] tw2964 4-0029: tw2964: v4l2_i2c_subdev_init() [ 93.802937] tw2964 4-0029: tw2964: read adr'0xfe' dat'0x0' [ 93.803195] tw2964 4-0029: tw2964: read adr'0xff' dat'0xe8' [ 93.803204] tw2964 4-0029: tw2964 dev_id=0x001d (0.232) chip found @ 0x29 (OMAP I2C adapter) [ 93.812281] tw2964 4-0029: tw2964 detected. [ 93.816531] tw2964 4-0029: tw2964: tw2964_detect_version() [ 93.816559] tw2964 4-0029: tw2964: v4l2_ctrl_handler_init() [ 93.816876] tw2964: read adr'0x3e' dat'0x97' [ 93.816884] tw2964 4-0029: tw2964: tw2964_read_std() [ 93.816889] tw2964: write_all_regs()-size_of_mass_regs-'120' [ 93.817042] tw2964: [#0]write_all_regs()ret'0',regs'0x1',data'0x0' [ 93.817278] tw2964: [#2]write_all_regs()ret'0',regs'0x11',data'0x0' [ 93.817386] tw2964: [#4]write_all_regs()ret'0',regs'0x21',data'0x0' [ 93.817491] tw2964: [#6]write_all_regs()ret'0',regs'0x31',data'0x0' [ 93.817609] tw2964: [#8]write_all_regs()ret'0',regs'0x2',data'0x64' [ 93.817716] tw2964: [#10]write_all_regs()ret'0',regs'0x12',data'0x64' [ 93.821152] tw2964: [#12]write_all_regs()ret'0',regs'0x22',data'0x64' [ 93.821263] tw2964: [#14]write_all_regs()ret'0',regs'0x32',data'0x64' [ 93.821370] tw2964: [#16]write_all_regs()ret'0',regs'0x3',data'0x11' [ 93.821478] tw2964: [#18]write_all_regs()ret'0',regs'0x13',data'0x11' [ 93.821583] tw2964: [#20]write_all_regs()ret'0',regs'0x23',data'0x11' [ 93.821688] tw2964: [#22]write_all_regs()ret'0',regs'0x33',data'0x11' [ 93.821792] tw2964: [#24]write_all_regs()ret'0',regs'0x4',data'0x80' [ 93.821907] tw2964: [#26]write_all_regs()ret'0',regs'0x14',data'0x80' [ 93.822012] tw2964: [#28]write_all_regs()ret'0',regs'0x24',data'0x80' [ 93.822116] tw2964: [#30]write_all_regs()ret'0',regs'0x34',data'0x80' [ 93.822220] tw2964: [#32]write_all_regs()ret'0',regs'0x5',data'0x80' [ 93.822334] tw2964: [#34]write_all_regs()ret'0',regs'0x15',data'0x80' [ 93.822440] tw2964: [#36]write_all_regs()ret'0',regs'0x25',data'0x80' [ 93.822543] tw2964: [#38]write_all_regs()ret'0',regs'0x35',data'0x80' [ 93.822646] tw2964: [#40]write_all_regs()ret'0',regs'0x6',data'0x0' [ 93.822754] tw2964: [#42]write_all_regs()ret'0',regs'0x16',data'0x0' [ 93.822859] tw2964: [#44]write_all_regs()ret'0',regs'0x26',data'0x0' [ 93.822962] tw2964: [#46]write_all_regs()ret'0',regs'0x36',data'0x0' [ 93.823066] tw2964: [#48]write_all_regs()ret'0',regs'0x7',data'0x12' [ 93.823171] tw2964: [#50]write_all_regs()ret'0',regs'0x17',data'0x12' [ 93.823276] tw2964: [#52]write_all_regs()ret'0',regs'0x27',data'0x12' [ 93.823380] tw2964: [#54]write_all_regs()ret'0',regs'0x37',data'0x12' [ 93.823515] tw2964: [#56]write_all_regs()ret'0',regs'0x8',data'0x12' [ 93.823624] tw2964: [#58]write_all_regs()ret'0',regs'0x18',data'0x12' [ 93.823728] tw2964: [#60]write_all_regs()ret'0',regs'0x28',data'0x12' [ 93.823832] tw2964: [#62]write_all_regs()ret'0',regs'0x38',data'0x12' [ 93.823945] tw2964: [#64]write_all_regs()ret'0',regs'0x9',data'0x20' [ 93.824050] tw2964: [#66]write_all_regs()ret'0',regs'0x19',data'0x20' [ 93.824153] tw2964: [#68]write_all_regs()ret'0',regs'0x29',data'0x20' [ 93.824257] tw2964: [#70]write_all_regs()ret'0',regs'0x39',data'0x20' [ 93.824364] tw2964: [#72]write_all_regs()ret'0',regs'0xa',data'0xa' [ 93.824470] tw2964: [#74]write_all_regs()ret'0',regs'0x1a',data'0xa' [ 93.824574] tw2964: [#76]write_all_regs()ret'0',regs'0x2a',data'0xa' [ 93.824679] tw2964: [#78]write_all_regs()ret'0',regs'0x3a',data'0xa' [ 93.824783] tw2964: [#80]write_all_regs()ret'0',regs'0xb',data'0xd0' [ 93.824892] tw2964: [#82]write_all_regs()ret'0',regs'0x1b',data'0xd0' [ 93.824996] tw2964: [#84]write_all_regs()ret'0',regs'0x2b',data'0xd0' [ 93.825100] tw2964: [#86]write_all_regs()ret'0',regs'0x3b',data'0xd0' [ 93.825204] tw2964: [#88]write_all_regs()ret'0',regs'0xe',data'0x7' [ 93.825309] tw2964: [#90]write_all_regs()ret'0',regs'0x1e',data'0x7' [ 93.825413] tw2964: [#92]write_all_regs()ret'0',regs'0x2e',data'0x7' [ 93.825538] tw2964: [#94]write_all_regs()ret'0',regs'0x3e',data'0x7' [ 93.825641] tw2964: [#96]write_all_regs()ret'0',regs'0xf',data'0x7f' [ 93.825745] tw2964: [#98]write_all_regs()ret'0',regs'0x1f',data'0x7f' [ 93.825850] tw2964: [#100]write_all_regs()ret'0',regs'0x2f',data'0x7f' [ 93.825960] tw2964: [#102]write_all_regs()ret'0',regs'0x3f',data'0x7f' [ 93.826068] tw2964: [#104]write_all_regs()ret'0',regs'0xa0',data'0x8' [ 93.826173] tw2964: [#106]write_all_regs()ret'0',regs'0xb0',data'0x8' [ 93.826282] tw2964: [#108]write_all_regs()ret'0',regs'0xc0',data'0x8' [ 93.826390] tw2964: [#110]write_all_regs()ret'0',regs'0xd0',data'0x8' [ 93.826494] tw2964: [#112]write_all_regs()ret'0',regs'0xa4',data'0x9c' [ 93.826599] tw2964: [#114]write_all_regs()ret'0',regs'0xb4',data'0x9c' [ 93.826722] tw2964: [#116]write_all_regs()ret'0',regs'0xc4',data'0x9c' [ 93.826827] tw2964: [#118]write_all_regs()ret'0',regs'0xd4',data'0x9c' [ 93.826831] tw2964: write_all_regs()-size_of_mass_regs-'260' [ 93.826935] tw2964: [#0]write_all_regs()ret'0',regs'0x4f',data'0x0' [ 93.827040] tw2964: [#2]write_all_regs()ret'0',regs'0x50',data'0x0' [ 93.827143] tw2964: [#4]write_all_regs()ret'0',regs'0x51',data'0x0' [ 93.827246] tw2964: [#6]write_all_regs()ret'0',regs'0x52',data'0x0' [ 93.827353] tw2964: [#8]write_all_regs()ret'0',regs'0x54',data'0x7' [ 93.827457] tw2964: [#10]write_all_regs()ret'0',regs'0x55',data'0x0' [ 93.827561] tw2964: [#12]write_all_regs()ret'0',regs'0x56',data'0x0' [ 93.827691] tw2964: [#14]write_all_regs()ret'0',regs'0x57',data'0x90' [ 93.827797] tw2964: [#16]write_all_regs()ret'0',regs'0x58',data'0x90' [ 93.827901] tw2964: [#18]write_all_regs()ret'0',regs'0x59',data'0x90' [ 93.828004] tw2964: [#20]write_all_regs()ret'0',regs'0x5a',data'0x90' [ 93.828114] tw2964: [#22]write_all_regs()ret'0',regs'0x5b',data'0x0' [ 93.828219] tw2964: [#24]write_all_regs()ret'0',regs'0x5c',data'0x0' [ 93.828324] tw2964: [#26]write_all_regs()ret'0',regs'0x5d',data'0xe0' [ 93.828427] tw2964: [#28]write_all_regs()ret'0',regs'0x5e',data'0xe0' [ 93.828536] tw2964: [#30]write_all_regs()ret'0',regs'0x5f',data'0xe0' [ 93.828645] tw2964: [#32]write_all_regs()ret'0',regs'0x60',data'0x26' [ 93.828751] tw2964: [#34]write_all_regs()ret'0',regs'0x61',data'0x1f' [ 93.828855] tw2964: [#36]write_all_regs()ret'0',regs'0x62',data'0x0' [ 93.828960] tw2964: [#38]write_all_regs()ret'0',regs'0x63',data'0x10' [ 93.829064] tw2964: [#40]write_all_regs()ret'0',regs'0x64',data'0x32' [ 93.829168] tw2964: [#42]write_all_regs()ret'0',regs'0x65',data'0x0' [ 93.829272] tw2964: [#44]write_all_regs()ret'0',regs'0x67',data'0x80' [ 93.829377] tw2964: [#46]write_all_regs()ret'0',regs'0x68',data'0x0' [ 93.829481] tw2964: [#48]write_all_regs()ret'0',regs'0x69',data'0x0' [ 93.829584] tw2964: [#50]write_all_regs()ret'0',regs'0x6a',data'0x0' [ 93.829698] tw2964: [#52]write_all_regs()ret'0',regs'0x6b',data'0x0' [ 93.829803] tw2964: [#54]write_all_regs()ret'0',regs'0x6c',data'0x0' [ 93.829908] tw2964: [#56]write_all_regs()ret'0',regs'0x6d',data'0x28' [ 93.830012] tw2964: [#58]write_all_regs()ret'0',regs'0x6e',data'0x38' [ 93.830116] tw2964: [#60]write_all_regs()ret'0',regs'0x70',data'0x8' [ 93.831468] tw2964: [#62]write_all_regs()ret'0',regs'0x71',data'0x40' [ 93.831575] tw2964: [#64]write_all_regs()ret'0',regs'0x72',data'0x28' [ 93.831679] tw2964: [#66]write_all_regs()ret'0',regs'0x73',data'0x0' [ 93.831781] tw2964: [#68]write_all_regs()ret'0',regs'0x74',data'0x0' [ 93.831885] tw2964: [#70]write_all_regs()ret'0',regs'0x75',data'0x0' [ 93.831987] tw2964: [#72]write_all_regs()ret'0',regs'0x76',data'0x0' [ 93.832090] tw2964: [#74]write_all_regs()ret'0',regs'0x7b',data'0x15' [ 93.832192] tw2964: [#76]write_all_regs()ret'0',regs'0x7c',data'0x15' [ 93.832294] tw2964: [#78]write_all_regs()ret'0',regs'0x7d',data'0xe4' [ 93.832402] tw2964: [#80]write_all_regs()ret'0',regs'0x7e',data'0xa3' [ 93.832508] tw2964: [#82]write_all_regs()ret'0',regs'0x7f',data'0x66' [ 93.832610] tw2964: [#84]write_all_regs()ret'0',regs'0x80',data'0x0' [ 93.832712] tw2964: [#86]write_all_regs()ret'0',regs'0x81',data'0x2' [ 93.832814] tw2964: [#88]write_all_regs()ret'0',regs'0x82',data'0x0' [ 93.832917] tw2964: [#90]write_all_regs()ret'0',regs'0x83',data'0xcc' [ 93.833019] tw2964: [#92]write_all_regs()ret'0',regs'0x84',data'0x0' [ 93.833121] tw2964: [#94]write_all_regs()ret'0',regs'0x85',data'0x30' [ 93.833223] tw2964: [#96]write_all_regs()ret'0',regs'0x86',data'0x44' [ 93.833325] tw2964: [#98]write_all_regs()ret'0',regs'0x87',data'0x50' [ 93.833427] tw2964: [#100]write_all_regs()ret'0',regs'0x88',data'0x42' [ 93.833529] tw2964: [#102]write_all_regs()ret'0',regs'0x89',data'0x0' [ 93.833631] tw2964: [#104]write_all_regs()ret'0',regs'0x8a',data'0xd8' [ 93.833733] tw2964: [#106]write_all_regs()ret'0',regs'0x8b',data'0xbc' [ 93.833835] tw2964: [#108]write_all_regs()ret'0',regs'0x8c',data'0xb8' [ 93.833937] tw2964: [#110]write_all_regs()ret'0',regs'0x8d',data'0x44' [ 93.834039] tw2964: [#112]write_all_regs()ret'0',regs'0x8e',data'0x36' [ 93.834141] tw2964: [#114]write_all_regs()ret'0',regs'0x8f',data'0x0' [ 93.834244] tw2964: [#116]write_all_regs()ret'0',regs'0x90',data'0x0' [ 93.834345] tw2964: [#118]write_all_regs()ret'0',regs'0x91',data'0x78' [ 93.834447] tw2964: [#120]write_all_regs()ret'0',regs'0x92',data'0x44' [ 93.834550] tw2964: [#122]write_all_regs()ret'0',regs'0x93',data'0x30' [ 93.834654] tw2964: [#124]write_all_regs()ret'0',regs'0x94',data'0x14' [ 93.834756] tw2964: [#126]write_all_regs()ret'0',regs'0x95',data'0xa5' [ 93.834859] tw2964: [#128]write_all_regs()ret'0',regs'0x96',data'0xe0' [ 93.834961] tw2964: [#130]write_all_regs()ret'0',regs'0x97',data'0x5' [ 93.835064] tw2964: [#132]write_all_regs()ret'0',regs'0x98',data'0x0' [ 93.835166] tw2964: [#134]write_all_regs()ret'0',regs'0x99',data'0x13' [ 93.835268] tw2964: [#136]write_all_regs()ret'0',regs'0x9a',data'0x1f' [ 93.835369] tw2964: [#138]write_all_regs()ret'0',regs'0x9b',data'0x44' [ 93.835471] tw2964: [#140]write_all_regs()ret'0',regs'0x9c',data'0x20' [ 93.835573] tw2964: [#142]write_all_regs()ret'0',regs'0x9e',data'0x42' [ 93.835681] tw2964: [#144]write_all_regs()ret'0',regs'0x9f',data'0x0' [ 93.835786] tw2964: [#146]write_all_regs()ret'0',regs'0xaa',data'0x0' [ 93.835888] tw2964: [#148]write_all_regs()ret'0',regs'0xab',data'0xf0' [ 93.835990] tw2964: [#150]write_all_regs()ret'0',regs'0xac',data'0xf0' [ 93.836093] tw2964: [#152]write_all_regs()ret'0',regs'0xad',data'0xf0' [ 93.836195] tw2964: [#154]write_all_regs()ret'0',regs'0xae',data'0xf0' [ 93.836296] tw2964: [#156]write_all_regs()ret'0',regs'0xaf',data'0x0' [ 93.836398] tw2964: [#158]write_all_regs()ret'0',regs'0xb0',data'0x0' [ 93.836500] tw2964: [#160]write_all_regs()ret'0',regs'0xb1',data'0x0' [ 93.836602] tw2964: [#162]write_all_regs()ret'0',regs'0xb2',data'0x0' [ 93.836704] tw2964: [#164]write_all_regs()ret'0',regs'0xb3',data'0x0' [ 93.836807] tw2964: [#166]write_all_regs()ret'0',regs'0xb4',data'0x0' [ 93.836908] tw2964: [#168]write_all_regs()ret'0',regs'0xb5',data'0x0' [ 93.837010] tw2964: [#170]write_all_regs()ret'0',regs'0xb6',data'0x0' [ 93.837112] tw2964: [#172]write_all_regs()ret'0',regs'0xb7',data'0x0' [ 93.837215] tw2964: [#174]write_all_regs()ret'0',regs'0xc8',data'0x0' [ 93.837316] tw2964: [#176]write_all_regs()ret'0',regs'0xc9',data'0x0' [ 93.837417] tw2964: [#178]write_all_regs()ret'0',regs'0xca',data'0x0' [ 93.837519] tw2964: [#180]write_all_regs()ret'0',regs'0xcb',data'0x0' [ 93.837622] tw2964: [#182]write_all_regs()ret'0',regs'0xcc',data'0x39' [ 93.837723] tw2964: [#184]write_all_regs()ret'0',regs'0xcd',data'0xe4' [ 93.837826] tw2964: [#186]write_all_regs()ret'0',regs'0xce',data'0x0' [ 93.837927] tw2964: [#188]write_all_regs()ret'0',regs'0xcf',data'0x0' [ 93.838029] tw2964: [#190]write_all_regs()ret'0',regs'0xd0',data'0x66' [ 93.838137] tw2964: [#192]write_all_regs()ret'0',regs'0xd1',data'0x66' [ 93.838241] tw2964: [#194]write_all_regs()ret'0',regs'0xd2',data'0x0' [ 93.838346] tw2964: [#196]write_all_regs()ret'0',regs'0xd3',data'0x10' [ 93.838449] tw2964: [#198]write_all_regs()ret'0',regs'0xd4',data'0x32' [ 93.838553] tw2964: [#200]write_all_regs()ret'0',regs'0xd5',data'0x54' [ 93.838656] tw2964: [#202]write_all_regs()ret'0',regs'0xd6',data'0x76' [ 93.838762] tw2964: [#204]write_all_regs()ret'0',regs'0xd7',data'0x98' [ 93.838868] tw2964: [#206]write_all_regs()ret'0',regs'0xd8',data'0xba' [ 93.838976] tw2964: [#208]write_all_regs()ret'0',regs'0xd9',data'0xdc' [ 93.839083] tw2964: [#210]write_all_regs()ret'0',regs'0xda',data'0xfe' [ 93.839190] tw2964: [#212]write_all_regs()ret'0',regs'0xdb',data'0xc2' [ 93.839293] tw2964: [#214]write_all_regs()ret'0',regs'0xdc',data'0x10' [ 93.839397] tw2964: [#216]write_all_regs()ret'0',regs'0xdd',data'0x0' [ 93.839500] tw2964: [#218]write_all_regs()ret'0',regs'0xde',data'0x0' [ 93.839604] tw2964: [#220]write_all_regs()ret'0',regs'0xdf',data'0x80' [ 93.839707] tw2964: [#222]write_all_regs()ret'0',regs'0xe0',data'0x1f' [ 93.839810] tw2964: [#224]write_all_regs()ret'0',regs'0xe1',data'0xf0' [ 93.839913] tw2964: [#226]write_all_regs()ret'0',regs'0xe2',data'0x33' [ 93.840018] tw2964: [#228]write_all_regs()ret'0',regs'0xe3',data'0x33' [ 93.840121] tw2964: [#230]write_all_regs()ret'0',regs'0xf0',data'0x23' [ 93.840226] tw2964: [#232]write_all_regs()ret'0',regs'0xf1',data'0x48' [ 93.840329] tw2964: [#234]write_all_regs()ret'0',regs'0xf2',data'0x7' [ 93.840433] tw2964: [#236]write_all_regs()ret'0',regs'0xf3',data'0x0' [ 93.840536] tw2964: [#238]write_all_regs()ret'0',regs'0xf4',data'0x1' [ 93.840640] tw2964: [#240]write_all_regs()ret'0',regs'0xf5',data'0x0' [ 93.840742] tw2964: [#242]write_all_regs()ret'0',regs'0xf6',data'0x0' [ 93.841796] tw2964: [#244]write_all_regs()ret'0',regs'0xf7',data'0x20' [ 93.841906] tw2964: [#246]write_all_regs()ret'0',regs'0xf8',data'0xc4' [ 93.842010] tw2964: [#248]write_all_regs()ret'0',regs'0xf9',data'0x40' [ 93.842114] tw2964: [#250]write_all_regs()ret'0',regs'0xfa',data'0x0' [ 93.842217] tw2964: [#252]write_all_regs()ret'0',regs'0xfb',data'0xf' [ 93.842322] tw2964: [#254]write_all_regs()ret'0',regs'0xfc',data'0xff' [ 93.842426] tw2964: [#256]write_all_regs()ret'0',regs'0xfd',data'0x0' [ 93.842529] tw2964: [#258]write_all_regs()ret'0',regs'0xfe',data'0x0' [ 93.842537] tw2964 4-0029: Selecting video route: route input=0 tw2964 input=0 [ 93.842542] tw2964 4-0029: tw2964: writing adr'0x85' dat'0x30' [ 93.842788] tw2964 4-0029: tw2964: read adr'0x85' dat'0x30' [ 93.842793] tw2964 4-0029: TW2964_REG_SHCOR960:=0x30 [ 93.842900] tw2964: write adr'0x33' dat'0x1' [ 93.843004] tw2964: write adr'0x34' dat'0x80' [ 93.843108] tw2964: write adr'0x35' dat'0x80' [ 93.843216] tw2964: write adr'0x32' dat'0x64' [ 93.843322] tw2964: write adr'0x31' dat'0x0' [ 93.843429] tw2964: write adr'0x36' dat'0x0' [ 93.843435] tw2964 4-0029: Set video std register to 1. [ 93.843537] tw2964: write adr'0x3e' dat'0x1' [ 93.843542] tw2964 4-0029: Set video std register to 1. [ 93.843646] tw2964: write adr'0x3e' dat'0x1' [ 93.843651] tw2964 4-0029: tw2964: tw2964_reset() [ 93.843662] vin3a: Port A: Using subdev tw2964 4-0029 for capture [ 93.849783] vin3a: subdev tw2964 4-0029: code: 2006 idx: 0 [ 93.859783] tw2964 4-0029: tw2964: v4l2_async_register_subdev() [ 93.859936] tw2964 4-0029: tw2964: read adr'0xfa' dat'0x0' [ 93.860087] tw2964 4-0029: tw2964: read adr'0xca' dat'0x0' [ 93.860232] tw2964 4-0029: tw2964: read adr'0xcd' dat'0xe4' [ 93.860379] tw2964 4-0029: tw2964: read adr'0xcc' dat'0x39' [ 93.860385] tw2964 4-0029: tw2964: writing adr'0xcd' dat'0xe8' [ 93.860496] tw2964 4-0029: tw2964: writing adr'0xcc' dat'0x3d' [ 93.860601] tw2964 4-0029: tw2964: writing adr'0xfa' dat'0x45' [ 93.860711] tw2964 4-0029: tw2964: writing adr'0xca' dat'0x5' [ 93.861129] tw2964 4-0029: tw2964: read adr'0xfa' dat'0x45' [ 93.861279] tw2964 4-0029: tw2964: read adr'0xca' dat'0x5' [ 93.861432] tw2964 4-0029: tw2964: read adr'0xcd' dat'0xe8' [ 93.861584] tw2964 4-0029: tw2964: read adr'0xcc' dat'0x3d' [ 93.861589] tw2964 4-0029: TW2964_REG_CLKOCTL:=0x45 [ 93.861593] tw2964 4-0029: TW2964_REG_CHMD:=0x5 [ 93.861598] tw2964 4-0029: TTW2964_REG_MAINCH:=0xe8 [ 93.861603] tw2964 4-0029: TW2964_REG_SELCH:=0x3d [ 93.861607] tw2964 4-0029: begin etx_driver_init() [ 93.861613] tw2964: Major = 239 Minor = 0 [ 93.861726] tw2964: device driver insert...Done!!! [ 93.861731] tw2964 4-0029: end etx_driver_init() [ 93.861735] tw2964 4-0029: Standard: 50 Hz [ 93.865863] tw2964 4-0029: Channel: 0 [ 93.869537] tw2964 4-0029: Input: 0 [ 93.873258] tw2964 4-0029: Standard: 50 Hz [ 93.877368] tw2964 4-0029: Channel: 0 [ 93.881071] tw2964 4-0029: Input: 0 [ 93.884747] tw2964 4-0029: tw2964: read adr'0x0' dat'0x13' [ 93.884896] tw2964 4-0029: tw2964: read adr'0x1' dat'0x0' [ 93.885041] tw2964 4-0029: tw2964: read adr'0x2' dat'0x64' [ 93.885185] tw2964 4-0029: tw2964: read adr'0x3' dat'0x11' [ 93.885339] tw2964 4-0029: tw2964: read adr'0x4' dat'0x80' [ 93.885491] tw2964 4-0029: tw2964: read adr'0x5' dat'0x80' [ 93.885632] tw2964 4-0029: tw2964: read adr'0x6' dat'0x0' [ 93.885784] tw2964 4-0029: tw2964: read adr'0x7' dat'0x12' [ 93.885928] tw2964 4-0029: tw2964: read adr'0x8' dat'0x12' [ 93.886070] tw2964 4-0029: tw2964: read adr'0x9' dat'0x20' [ 93.886211] tw2964 4-0029: tw2964: read adr'0xa' dat'0xa' [ 93.886355] tw2964 4-0029: tw2964: read adr'0xb' dat'0xd0' [ 93.886514] tw2964 4-0029: tw2964: read adr'0xc' dat'0x0' [ 93.886685] tw2964 4-0029: tw2964: read adr'0xd' dat'0x0' [ 93.886829] tw2964 4-0029: tw2964: read adr'0xe' dat'0x97' [ 93.886975] tw2964 4-0029: tw2964: read adr'0xf' dat'0x7f' [ 93.887150] tw2964 4-0029: tw2964: read adr'0x10' dat'0x87' [ 93.887293] tw2964 4-0029: tw2964: read adr'0x11' dat'0x0' [ 93.887441] tw2964 4-0029: tw2964: read adr'0x12' dat'0x64' [ 93.887588] tw2964 4-0029: tw2964: read adr'0x13' dat'0x11' [ 93.887733] tw2964 4-0029: tw2964: read adr'0x14' dat'0x80' [ 93.887879] tw2964 4-0029: tw2964: read adr'0x15' dat'0x80' [ 93.888019] tw2964 4-0029: tw2964: read adr'0x16' dat'0x0' [ 93.888162] tw2964 4-0029: tw2964: read adr'0x17' dat'0x12' [ 93.888309] tw2964 4-0029: tw2964: read adr'0x18' dat'0x12' [ 93.888450] tw2964 4-0029: tw2964: read adr'0x19' dat'0x20' [ 93.888627] tw2964 4-0029: tw2964: read adr'0x1a' dat'0xa' [ 93.888812] tw2964 4-0029: tw2964: read adr'0x1b' dat'0xd0' [ 93.889013] tw2964 4-0029: tw2964: read adr'0x1c' dat'0x50' [ 93.889185] tw2964 4-0029: tw2964: read adr'0x1d' dat'0x0' [ 93.889356] tw2964 4-0029: tw2964: read adr'0x1e' dat'0x97' [ 93.889552] tw2964 4-0029: tw2964: read adr'0x1f' dat'0x7f' [ 93.889706] tw2964 4-0029: tw2964: read adr'0x20' dat'0x87' [ 93.889863] tw2964 4-0029: tw2964: read adr'0x21' dat'0x0' [ 93.890047] tw2964 4-0029: tw2964: read adr'0x22' dat'0x64' [ 93.890228] tw2964 4-0029: tw2964: read adr'0x23' dat'0x11' [ 93.890398] tw2964 4-0029: tw2964: read adr'0x24' dat'0x80' [ 93.890556] tw2964 4-0029: tw2964: read adr'0x25' dat'0x80' [ 93.890717] tw2964 4-0029: tw2964: read adr'0x26' dat'0x0' [ 93.890895] tw2964 4-0029: tw2964: read adr'0x27' dat'0x12' [ 93.891065] tw2964 4-0029: tw2964: read adr'0x28' dat'0x12' [ 93.891244] tw2964 4-0029: tw2964: read adr'0x29' dat'0x20' [ 93.891416] tw2964 4-0029: tw2964: read adr'0x2a' dat'0xa' [ 93.891604] tw2964 4-0029: tw2964: read adr'0x2b' dat'0xd0' [ 93.891768] tw2964 4-0029: tw2964: read adr'0x2c' dat'0x50' [ 93.891931] tw2964 4-0029: tw2964: read adr'0x2d' dat'0x0' [ 93.892093] tw2964 4-0029: tw2964: read adr'0x2e' dat'0x97' [ 93.892274] tw2964 4-0029: tw2964: read adr'0x2f' dat'0x7f' [ 93.892432] tw2964 4-0029: tw2964: read adr'0x30' dat'0x87' [ 93.892591] tw2964 4-0029: tw2964: read adr'0x31' dat'0x0' [ 93.892791] tw2964 4-0029: tw2964: read adr'0x32' dat'0x64' [ 93.892952] tw2964 4-0029: tw2964: read adr'0x33' dat'0x1' [ 93.893512] tw2964 4-0029: tw2964: read adr'0x34' dat'0x80' [ 93.893672] tw2964 4-0029: tw2964: read adr'0x35' dat'0x80' [ 93.893837] tw2964 4-0029: tw2964: read adr'0x36' dat'0x0' [ 93.894002] tw2964 4-0029: tw2964: read adr'0x37' dat'0x12' [ 93.894161] tw2964 4-0029: tw2964: read adr'0x38' dat'0x12' [ 93.894356] tw2964 4-0029: tw2964: read adr'0x39' dat'0x20' [ 93.894538] tw2964 4-0029: tw2964: read adr'0x3a' dat'0xa' [ 93.894716] tw2964 4-0029: tw2964: read adr'0x3b' dat'0xd0' [ 93.894893] tw2964 4-0029: tw2964: read adr'0x3c' dat'0x50' [ 93.895053] tw2964 4-0029: tw2964: read adr'0x3d' dat'0x0' [ 93.895206] tw2964 4-0029: tw2964: read adr'0x3e' dat'0x11' [ 93.895398] tw2964 4-0029: tw2964: read adr'0x3f' dat'0x7f' [ 93.895579] tw2964 4-0029: tw2964: read adr'0x40' dat'0x0' [ 93.895735] tw2964 4-0029: tw2964: read adr'0x41' dat'0x40' [ 93.895951] tw2964 4-0029: tw2964: read adr'0x42' dat'0x90' [ 93.896116] tw2964 4-0029: tw2964: read adr'0x43' dat'0x8' [ 93.896298] tw2964 4-0029: tw2964: read adr'0x44' dat'0x0' [ 93.896468] tw2964 4-0029: tw2964: read adr'0x45' dat'0x38' [ 93.896643] tw2964 4-0029: tw2964: read adr'0x46' dat'0x80' [ 93.896802] tw2964 4-0029: tw2964: read adr'0x47' dat'0x80' [ 93.896960] tw2964 4-0029: tw2964: read adr'0x48' dat'0x80' [ 93.897115] tw2964 4-0029: tw2964: read adr'0x49' dat'0x80' [ 93.897294] tw2964 4-0029: tw2964: read adr'0x4a' dat'0xb' [ 93.897456] tw2964 4-0029: tw2964: read adr'0x4b' dat'0x30' [ 93.897626] tw2964 4-0029: tw2964: read adr'0x4c' dat'0x0' [ 93.897782] tw2964 4-0029: tw2964: read adr'0x4d' dat'0x0' [ 93.897992] tw2964 4-0029: tw2964: read adr'0x4e' dat'0x0' [ 93.898172] tw2964 4-0029: tw2964: read adr'0x4f' dat'0x0' [ 93.898355] tw2964 4-0029: tw2964: read adr'0x50' dat'0x0' [ 93.898531] tw2964 4-0029: tw2964: read adr'0x51' dat'0x0' [ 93.898746] tw2964 4-0029: tw2964: read adr'0x52' dat'0x0' [ 93.898907] tw2964 4-0029: tw2964: read adr'0x53' dat'0x0' [ 93.899056] tw2964 4-0029: tw2964: read adr'0x54' dat'0x7' [ 93.899222] tw2964 4-0029: tw2964: read adr'0x55' dat'0x0' [ 93.899379] tw2964 4-0029: tw2964: read adr'0x56' dat'0x0' [ 93.899555] tw2964 4-0029: tw2964: read adr'0x57' dat'0x90' [ 93.899712] tw2964 4-0029: tw2964: read adr'0x58' dat'0x90' [ 93.899866] tw2964 4-0029: tw2964: read adr'0x59' dat'0x90' [ 93.900010] tw2964 4-0029: tw2964: read adr'0x5a' dat'0x90' [ 93.900155] tw2964 4-0029: tw2964: read adr'0x5b' dat'0x0' [ 93.900307] tw2964 4-0029: tw2964: read adr'0x5c' dat'0x0' [ 93.900452] tw2964 4-0029: tw2964: read adr'0x5d' dat'0xe0' [ 93.900611] tw2964 4-0029: tw2964: read adr'0x5e' dat'0xe0' [ 93.900756] tw2964 4-0029: tw2964: read adr'0x5f' dat'0xe0' [ 93.900952] tw2964 4-0029: tw2964: read adr'0x60' dat'0x26' [ 93.901103] tw2964 4-0029: tw2964: read adr'0x61' dat'0x1f' [ 93.901266] tw2964 4-0029: tw2964: read adr'0x62' dat'0x0' [ 93.901430] tw2964 4-0029: tw2964: read adr'0x63' dat'0x10' [ 93.901608] tw2964 4-0029: tw2964: read adr'0x64' dat'0x32' [ 93.901761] tw2964 4-0029: tw2964: read adr'0x65' dat'0x0' [ 93.901915] tw2964 4-0029: tw2964: read adr'0x66' dat'0x0' [ 93.902067] tw2964 4-0029: tw2964: read adr'0x67' dat'0x80' [ 93.902234] tw2964 4-0029: tw2964: read adr'0x68' dat'0x0' [ 93.902350] tw2964 4-0029: width = 704, height = 280 [ 93.902391] tw2964 4-0029: tw2964: read adr'0x69' dat'0x0' [ 93.902551] tw2964 4-0029: tw2964: read adr'0x6a' dat'0x0' [ 93.902765] tw2964 4-0029: tw2964: read adr'0x6b' dat'0x0' [ 93.902912] tw2964 4-0029: tw2964: read adr'0x6c' dat'0x0' [ 93.904570] tw2964 4-0029: tw2964: read adr'0x6d' dat'0x28' [ 93.904723] tw2964 4-0029: tw2964: read adr'0x6e' dat'0x38' [ 93.905482] tw2964 4-0029: tw2964: read adr'0x6f' dat'0x0' [ 93.905633] tw2964 4-0029: tw2964: read adr'0x70' dat'0x8' [ 93.905784] tw2964 4-0029: tw2964: read adr'0x71' dat'0x40' [ 93.905941] tw2964 4-0029: tw2964: read adr'0x72' dat'0x28' [ 93.906132] tw2964 4-0029: tw2964: read adr'0x73' dat'0x0' [ 93.906310] tw2964 4-0029: tw2964: read adr'0x74' dat'0x0' [ 93.906464] tw2964 4-0029: tw2964: read adr'0x75' dat'0x0' [ 93.906619] tw2964 4-0029: tw2964: read adr'0x76' dat'0x0' [ 93.906783] tw2964 4-0029: tw2964: read adr'0x77' dat'0x0' [ 93.906934] tw2964 4-0029: tw2964: read adr'0x78' dat'0x0' [ 93.907104] tw2964 4-0029: tw2964: read adr'0x79' dat'0x0' [ 93.907258] tw2964 4-0029: tw2964: read adr'0x7a' dat'0x0' [ 93.907421] tw2964 4-0029: tw2964: read adr'0x7b' dat'0x15' [ 93.907582] tw2964 4-0029: tw2964: read adr'0x7c' dat'0x15' [ 93.907733] tw2964 4-0029: tw2964: read adr'0x7d' dat'0xe4' [ 93.907893] tw2964 4-0029: tw2964: read adr'0x7e' dat'0xa3' [ 93.908045] tw2964 4-0029: tw2964: read adr'0x7f' dat'0x66' [ 93.908254] tw2964 4-0029: tw2964: read adr'0x80' dat'0x0' [ 93.908409] tw2964 4-0029: tw2964: read adr'0x81' dat'0x2' [ 93.908578] tw2964 4-0029: tw2964: read adr'0x82' dat'0x0' [ 93.908725] tw2964 4-0029: tw2964: read adr'0x83' dat'0xcc' [ 93.908915] tw2964 4-0029: tw2964: read adr'0x84' dat'0x0' [ 93.908969] tw2964 4-0029: width = 704, height = 280 [ 93.909065] tw2964 4-0029: tw2964: read adr'0x85' dat'0x30' [ 93.909241] tw2964 4-0029: tw2964: read adr'0x86' dat'0x44' [ 93.909394] tw2964 4-0029: tw2964: read adr'0x87' dat'0x50' [ 93.909544] tw2964 4-0029: tw2964: read adr'0x88' dat'0x42' [ 93.909725] tw2964 4-0029: tw2964: read adr'0x89' dat'0x0' [ 93.909877] tw2964 4-0029: tw2964: read adr'0x8a' dat'0xd8' [ 93.910061] tw2964 4-0029: tw2964: read adr'0x8b' dat'0xbc' [ 93.910265] tw2964 4-0029: tw2964: read adr'0x8c' dat'0xb8' [ 93.910414] tw2964 4-0029: tw2964: read adr'0x8d' dat'0x44' [ 93.910560] tw2964 4-0029: tw2964: read adr'0x8e' dat'0x36' [ 93.910825] tw2964 4-0029: tw2964: read adr'0x8f' dat'0x0' [ 93.912326] tw2964 4-0029: tw2964: read adr'0x90' dat'0x0' [ 93.912473] tw2964 4-0029: tw2964: read adr'0x91' dat'0x78' [ 93.912624] tw2964 4-0029: tw2964: read adr'0x92' dat'0x44' [ 93.913186] tw2964 4-0029: tw2964: read adr'0x93' dat'0x30' [ 93.914569] tw2964 4-0029: tw2964: read adr'0x94' dat'0x14' [ 93.915228] tw2964 4-0029: tw2964: read adr'0x95' dat'0xa5' [ 93.915377] tw2964 4-0029: tw2964: read adr'0x96' dat'0xe0' [ 93.915522] tw2964 4-0029: tw2964: read adr'0x97' dat'0x5' [ 93.915662] tw2964 4-0029: tw2964: read adr'0x98' dat'0x0' [ 93.915809] tw2964 4-0029: tw2964: read adr'0x99' dat'0x13' [ 93.915952] tw2964 4-0029: tw2964: read adr'0x9a' dat'0x1f' [ 93.916098] tw2964 4-0029: tw2964: read adr'0x9b' dat'0x44' [ 93.916238] tw2964 4-0029: tw2964: read adr'0x9c' dat'0x20' [ 93.916379] tw2964 4-0029: tw2964: read adr'0x9d' dat'0x0' [ 93.916521] tw2964 4-0029: tw2964: read adr'0x9e' dat'0x42' [ 93.916665] tw2964 4-0029: tw2964: read adr'0x9f' dat'0x0' [ 93.916807] tw2964 4-0029: tw2964: read adr'0xa0' dat'0x8' [ 93.917049] tw2964 4-0029: tw2964: read adr'0xa1' dat'0x8' [ 93.917192] tw2964 4-0029: tw2964: read adr'0xa2' dat'0x8' [ 93.917334] tw2964 4-0029: tw2964: read adr'0xa3' dat'0x8' [ 93.917477] tw2964 4-0029: tw2964: read adr'0xa4' dat'0x1c' [ 93.917619] tw2964 4-0029: tw2964: read adr'0xa5' dat'0x1a' [ 93.917760] tw2964 4-0029: tw2964: read adr'0xa6' dat'0x1a' [ 93.917907] tw2964 4-0029: tw2964: read adr'0xa7' dat'0x1a' [ 93.918048] tw2964 4-0029: tw2964: read adr'0xa8' dat'0x0' [ 93.918206] tw2964 4-0029: tw2964: read adr'0xa9' dat'0x0' [ 93.918351] tw2964 4-0029: tw2964: read adr'0xaa' dat'0x0' [ 93.918497] tw2964 4-0029: tw2964: read adr'0xab' dat'0xf0' [ 93.918642] tw2964 4-0029: tw2964: read adr'0xac' dat'0xf0' [ 93.918785] tw2964 4-0029: tw2964: read adr'0xad' dat'0xf0' [ 93.918927] tw2964 4-0029: tw2964: read adr'0xae' dat'0xf0' [ 93.919072] tw2964 4-0029: tw2964: read adr'0xaf' dat'0x0' [ 93.919214] tw2964 4-0029: tw2964: read adr'0xb0' dat'0x0' [ 93.919359] tw2964 4-0029: tw2964: read adr'0xb1' dat'0x0' [ 93.919505] tw2964 4-0029: tw2964: read adr'0xb2' dat'0x0' [ 93.919648] tw2964 4-0029: tw2964: read adr'0xb3' dat'0x0' [ 93.919791] tw2964 4-0029: tw2964: read adr'0xb4' dat'0x0' [ 93.919933] tw2964 4-0029: tw2964: read adr'0xb5' dat'0x0' [ 93.920078] tw2964 4-0029: tw2964: read adr'0xb6' dat'0x0' [ 93.920220] tw2964 4-0029: tw2964: read adr'0xb7' dat'0x0' [ 93.920362] tw2964 4-0029: tw2964: read adr'0xb8' dat'0x0' [ 93.920509] tw2964 4-0029: tw2964: read adr'0xb9' dat'0x0' [ 93.920657] tw2964 4-0029: tw2964: read adr'0xba' dat'0x0' [ 93.920820] tw2964 4-0029: tw2964: read adr'0xbb' dat'0x0' [ 93.920980] tw2964 4-0029: tw2964: read adr'0xbc' dat'0x0' [ 93.921131] tw2964 4-0029: tw2964: read adr'0xbd' dat'0x0' [ 93.921276] tw2964 4-0029: tw2964: read adr'0xbe' dat'0x0' [ 93.921433] tw2964 4-0029: tw2964: read adr'0xbf' dat'0x0' [ 93.921579] tw2964 4-0029: tw2964: read adr'0xc0' dat'0x0' [ 93.921725] tw2964 4-0029: tw2964: read adr'0xc1' dat'0x0' [ 93.921873] tw2964 4-0029: tw2964: read adr'0xc2' dat'0x0' [ 93.922016] tw2964 4-0029: tw2964: read adr'0xc3' dat'0x0' [ 93.922163] tw2964 4-0029: tw2964: read adr'0xc4' dat'0x0' [ 93.922304] tw2964 4-0029: tw2964: read adr'0xc5' dat'0x0' [ 93.922448] tw2964 4-0029: tw2964: read adr'0xc6' dat'0x0' [ 93.922591] tw2964 4-0029: tw2964: read adr'0xc7' dat'0x0' [ 93.922737] tw2964 4-0029: tw2964: read adr'0xc8' dat'0x88' [ 93.922884] tw2964 4-0029: tw2964: read adr'0xc9' dat'0x88' [ 93.923026] tw2964 4-0029: tw2964: read adr'0xca' dat'0x5' [ 93.923172] tw2964 4-0029: tw2964: read adr'0xcb' dat'0x0' [ 93.923313] tw2964 4-0029: tw2964: read adr'0xcc' dat'0x3d' [ 93.923459] tw2964 4-0029: tw2964: read adr'0xcd' dat'0xe8' [ 93.923612] tw2964 4-0029: tw2964: read adr'0xce' dat'0x0' [ 93.923759] tw2964 4-0029: tw2964: read adr'0xcf' dat'0x0' [ 93.923905] tw2964 4-0029: tw2964: read adr'0xd0' dat'0x66' [ 93.924050] tw2964 4-0029: tw2964: read adr'0xd1' dat'0x66' [ 93.924194] tw2964 4-0029: tw2964: read adr'0xd2' dat'0x0' [ 93.924336] tw2964 4-0029: tw2964: read adr'0xd3' dat'0x10' [ 93.924478] tw2964 4-0029: tw2964: read adr'0xd4' dat'0x32' [ 93.924619] tw2964 4-0029: tw2964: read adr'0xd5' dat'0x54' [ 93.924760] tw2964 4-0029: tw2964: read adr'0xd6' dat'0x76' [ 93.924905] tw2964 4-0029: tw2964: read adr'0xd7' dat'0x98' [ 93.925048] tw2964 4-0029: tw2964: read adr'0xd8' dat'0xba' [ 93.925197] tw2964 4-0029: tw2964: read adr'0xd9' dat'0xdc' [ 93.925339] tw2964 4-0029: tw2964: read adr'0xda' dat'0xfe' [ 93.925483] tw2964 4-0029: tw2964: read adr'0xdb' dat'0xc2' [ 93.925625] tw2964 4-0029: tw2964: read adr'0xdc' dat'0x10' [ 93.925771] tw2964 4-0029: tw2964: read adr'0xdd' dat'0x0' [ 93.925914] tw2964 4-0029: tw2964: read adr'0xde' dat'0x0' [ 93.926060] tw2964 4-0029: tw2964: read adr'0xdf' dat'0x80' [ 93.926216] tw2964 4-0029: tw2964: read adr'0xe0' dat'0x1f' [ 93.926361] tw2964 4-0029: tw2964: read adr'0xe1' dat'0xf0' [ 93.926503] tw2964 4-0029: tw2964: read adr'0xe2' dat'0x33' [ 93.926645] tw2964 4-0029: tw2964: read adr'0xe3' dat'0x33' [ 93.926786] tw2964 4-0029: tw2964: read adr'0xe4' dat'0x0' [ 93.926927] tw2964 4-0029: tw2964: read adr'0xe5' dat'0x0' [ 93.927068] tw2964 4-0029: tw2964: read adr'0xe6' dat'0x0' [ 93.927211] tw2964 4-0029: tw2964: read adr'0xe7' dat'0x0' [ 93.927359] tw2964 4-0029: tw2964: read adr'0xe8' dat'0x0' [ 93.927500] tw2964 4-0029: tw2964: read adr'0xe9' dat'0x0' [ 93.927645] tw2964 4-0029: tw2964: read adr'0xea' dat'0x0' [ 93.927789] tw2964 4-0029: tw2964: read adr'0xeb' dat'0x0' [ 93.927931] tw2964 4-0029: tw2964: read adr'0xec' dat'0x0' [ 93.928077] tw2964 4-0029: tw2964: read adr'0xed' dat'0x0' [ 93.928219] tw2964 4-0029: tw2964: read adr'0xee' dat'0x0' [ 93.928365] tw2964 4-0029: tw2964: read adr'0xef' dat'0x0' [ 93.928506] tw2964 4-0029: tw2964: read adr'0xf0' dat'0x23' [ 93.928647] tw2964 4-0029: tw2964: read adr'0xf1' dat'0x48' [ 93.928789] tw2964 4-0029: tw2964: read adr'0xf2' dat'0x7' [ 93.928931] tw2964 4-0029: tw2964: read adr'0xf3' dat'0x0' [ 93.929089] tw2964 4-0029: tw2964: read adr'0xf4' dat'0x1' [ 93.929236] tw2964 4-0029: tw2964: read adr'0xf5' dat'0x0' [ 93.929379] tw2964 4-0029: tw2964: read adr'0xf6' dat'0x0' [ 93.929526] tw2964 4-0029: tw2964: read adr'0xf7' dat'0x20' [ 93.929667] tw2964 4-0029: tw2964: read adr'0xf8' dat'0xc4' [ 93.929808] tw2964 4-0029: tw2964: read adr'0xf9' dat'0x40' [ 93.929951] tw2964 4-0029: tw2964: read adr'0xfa' dat'0x45' [ 93.930097] tw2964 4-0029: tw2964: read adr'0xfb' dat'0xf' [ 93.930244] tw2964 4-0029: tw2964: read adr'0xfc' dat'0xff' [ 93.930385] tw2964 4-0029: tw2964: read adr'0xfd' dat'0x1' [ 93.930527] tw2964 4-0029: tw2964: read adr'0xfe' dat'0x0' [ 93.930669] tw2964 4-0029: tw2964: read adr'0xff' dat'0xe8'
[ 93.843657] vin3a: vip_async_bound [ 93.843662] vin3a: Port A: Using subdev tw2964 4-0029 for capture [ 93.849783] vin3a: subdev tw2964 4-0029: code: 2006 idx: 0 [ 93.849788] vin3a: matched fourcc: UYVY: code: 2006 idx: 0 [ 93.849792] vin3a: matched fourcc: YUYV: code: 2006 idx: 1 [ 93.849796] vin3a: matched fourcc: VYUY: code: 2006 idx: 2 [ 93.849799] vin3a: matched fourcc: YVYU: code: 2006 idx: 3 [ 93.849954] vin3a-0: device registered as video1 [ 93.855023] vin3a: vip_create_streams[channel-0]: bus_type = V4L2_MBUS_BT656 [ 93.855123] vin3a-0: device registered as video2 [ 93.859759] vin3a: vip_create_streams[channel-1]: bus_type = V4L2_MBUS_BT656 [ 93.859776] vin3a: vip_async_complete [ 93.902336] vin3a-0: vip_open [ 93.902356] vin3a: vip_init_port: g_mbus_fmt subdev mbus_code: 2006 fourcc:UYVY size: 704x280 [ 93.902366] vin3a: calc_format_size: fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 93.902388] vin3a-0: init_stream fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 93.902395] vin3a-0: init_stream vpdma data type: 0x27 [ 93.902413] vin3a-0: vip_init_stream: stream instance 0xc0bb1438edfb6000 [ 93.902652] vin3a-0: vip_release [ 93.902659] vin3a-0: vip_release_stream: stream instance 0x00000010edfb6000 [ 93.902664] vin3a: vip_release_port: port instance 0xeda74c00edaa1410 [ 93.908956] vin3a-0: vip_open [ 93.909143] vin3a: vip_init_port: g_mbus_fmt subdev mbus_code: 2006 fourcc:UYVY size: 704x280 [ 93.909153] vin3a: calc_format_size: fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 93.909158] vin3a-0: init_stream fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 93.909162] vin3a-0: init_stream vpdma data type: 0x27 [ 93.909167] vin3a-0: vip_init_stream: stream instance 0xc0bb1438edfb5000 [ 93.909879] vin3a-0: vip_release [ 93.909885] vin3a-0: vip_release_stream: stream instance 0x00000010edfb5000 [ 93.909907] vin3a: vip_release_port: port instance 0xed9d4300edaa1410
cat /proc/interrupts | grep vi
102: 0 0 CBAR 352 Level vin3
103: 0 0 CBAR 393 Level vin4
PS. 10 minutes later, one frame of the distorted video and 1 interrupt appeared on the screen.
When trying to start the second channel (the first is already running)
gst-launch-1.0 v4l2src device=/dev/video2 io-mode=4 ! 'video/x-raw,format=(string)YUY2, width=(int)704, height=(int)280' ! vpe num-input-buffers=8 ! queue ! waylandsink use-drm=true
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video2' is busy
Additional debug info:
../../../gst-plugins-good-1.12.2/sys/v4l2/gstv4l2object.c(3595): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Call to S_FMT failed for YUYV @ 704x280: Device or resource busy
Execution ended after 0:00:00.015667890
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
gstreamer_2.log - log after second gst-launch
Same experiment for yavta
root@am57xx-evm:~# echo '\n' | yavta -c100 -p -F/home/root/1.yuv --skip 2 -t 1/30 -f YUYV -s 704x280 /dev/video1
Device /dev/video1 opened.
Device `vip' on `platform:vip2:vin3a:stream0' is a video output (without mplanes) device.
Video format set: YUYV (56595559) 704x280 (stride 1408) field none buffer size 394240
Video format: YUYV (56595559) 704x280 (stride 1408) field none buffer size 394240
Current frame rate: 1/30
Setting frame rate to: 1/30
Frame rate set: 1/30
8 buffers requested.
length: 394240 offset: 0 timestamp type/source: mono/EoF
Buffer 0/0 mapped at address 0xb6d55000.
length: 394240 offset: 397312 timestamp type/source: mono/EoF
Buffer 1/0 mapped at address 0xb6cf4000.
length: 394240 offset: 794624 timestamp type/source: mono/EoF
Buffer 2/0 mapped at address 0xb6c93000.
length: 394240 offset: 1191936 timestamp type/source: mono/EoF
Buffer 3/0 mapped at address 0xb6c32000.
length: 394240 offset: 1589248 timestamp type/source: mono/EoF
Buffer 4/0 mapped at address 0xb6bd1000.
length: 394240 offset: 1986560 timestamp type/source: mono/EoF
Buffer 5/0 mapped at address 0xb6b70000.
length: 394240 offset: 2383872 timestamp type/source: mono/EoF
Buffer 6/0 mapped at address 0xb6b0f000.
length: 394240 offset: 2781184 timestamp type/source: mono/EoF
Buffer 7/0 mapped at address 0xb6aae000.
Press enter to start capture
[ 213.203392] vin3a-0: vip_open [ 213.203414] tw2964 4-0029: width = 704, height = 280 [ 213.203422] vin3a: vip_init_port: g_mbus_fmt subdev mbus_code: 2006 fourcc:UYVY size: 704x280 [ 213.203433] vin3a: calc_format_size: fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 213.203439] vin3a-0: init_stream fourcc:UYVY size: 704x280 bpl:1408 img_size:394240 [ 213.203444] vin3a-0: init_stream vpdma data type: 0x27 [ 213.203450] vin3a-0: vip_init_stream: stream instance 0xc0bb1438ecd04000 [ 213.203634] vin3a-0: s_fmt input fourcc:YUYV size: 704x280 bpl:0 img_size:0 [ 213.203641] vin3a-0: try_fmt fourcc:YUYV size: 704x280 [ 213.203650] vin3a-0: try_fmt loop:0 fourcc:YUYV size: 704x280 [ 213.203656] vin3a-0: try_fmt loop:0 found new larger: 704x280 [ 213.203662] vin3a-0: try_fmt loop:0 found at least larger: 704x280 [ 213.203667] vin3a-0: try_fmt loop:0 found new best: 704x280 [ 213.203672] vin3a-0: try_fmt loop:0 found direct match: 704x280 [ 213.203678] vin3a: calc_format_size: fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 213.203684] vin3a-0: s_fmt try_fmt fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 213.203690] vin3a-0: s_fmt fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 213.203695] vin3a-0: s_fmt pix_to_mbus mbus_code: 2006 size: 704x280 [ 213.203703] tw2964 4-0029: width = 704, height = 280 [ 213.203709] vin3a-0: s_fmt subdev fmt mbus_code: 2006 size: 704x280 [ 213.203714] vin3a-0: s_fmt vpdma data type: 0x07 [ 213.203770] vin3a-0: g_fmt fourcc:YUYV code: 2006 size: 704x280 bpl:1408 img_size:394240 [ 213.203775] vin3a-0: g_fmt vpdma data type: 0x07 [ 213.203934] vin3a-0: get 8 buffer(s) of size 394240 each. [ 213.207641] vin3: vip_set_slice_path: [ 213.207650] vin3: vip_set_slice_path: DATA_PATH_SELECT(0000010C): 80008000 [ 213.207654] vin3: vip_set_slice_path: [ 213.207660] vin3: vip_set_slice_path: DATA_PATH_SELECT(0000010C): 40008000 [ 213.207932] vin3: vip_setup_parser: EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 [ 213.207937] vin3: vip_setup_parser: VIP_PIXCLK_EDGE_POLARITY=0 [ 213.208124] tw2964 4-0029: tw2964: read adr'0x65' dat'0x0' [ 213.208132] tw2964 4-0029: tw2964: writing adr'0x65' dat'0x0' [ 213.208246] vin3a-0: vip_load_vpdma_list_fifo: start_dma vb2 buf idx:0 [ 213.209369] vin3a-0: vip_load_vpdma_list_fifo: start_dma vb2 buf idx:1
root@am57xx-evm:~# echo '\n' | yavta -c100 -p -F/home/root/1.yuv --skip 2 -t 1/30 -f YUYV -s 704x280 /dev/video2
Device /dev/video2 opened.
Buffer 0/0 mapped at address 0xb6e33000.
Buffer 1/0 mapped at address 0xb6dd2000.
Buffer 2/0 mapped at address 0xb6d71000.
Buffer 3/0 mapped at address 0xb6d10000.
Buffer 4/0 mapped at address 0xb6caf000.
Buffer 5/0 mapped at address 0xb6c4e000.
Buffer 6/0 mapped at address 0xb6bed000.
Buffer 7/0 mapped at address 0xb6b8c000.
Unable to start streaming: Device or resource busy (16).
8 buffers released.
[ 357.042092] vin3a-0: vip_open [ 357.042109] vin3a: calc_format_size: fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 357.042117] vin3a-0: init_stream fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 357.042123] vin3a-0: init_stream vpdma data type: 0x07 [ 357.042132] vin3a-0: vip_init_stream: stream instance 0xc0bb1438ecd06000 [ 357.042338] vin3a-0: s_fmt input fourcc:YUYV size: 704x280 bpl:0 img_size:0 [ 357.042347] vin3a-0: try_fmt fourcc:YUYV size: 704x280 [ 357.042358] vin3a-0: try_fmt loop:0 fourcc:YUYV size: 704x280 [ 357.042365] vin3a-0: try_fmt loop:0 found new larger: 704x280 [ 357.042371] vin3a-0: try_fmt loop:0 found at least larger: 704x280 [ 357.042377] vin3a-0: try_fmt loop:0 found new best: 704x280 [ 357.042383] vin3a-0: try_fmt loop:0 found direct match: 704x280 [ 357.042390] vin3a: calc_format_size: fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 357.042397] vin3a-0: s_fmt try_fmt fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 357.042404] vin3a-0: s_fmt fourcc:YUYV size: 704x280 bpl:1408 img_size:394240 [ 357.042412] vin3a-0: s_fmt pix_to_mbus mbus_code: 2006 size: 704x280 [ 357.042423] tw2964 4-0029: width = 704, height = 280 [ 357.042429] vin3a-0: s_fmt subdev fmt mbus_code: 2006 size: 704x280 [ 357.042435] vin3a-0: s_fmt vpdma data type: 0x07 [ 357.042503] vin3a-0: g_fmt fourcc:YUYV code: 2006 size: 704x280 bpl:1408 img_size:394240 [ 357.042508] vin3a-0: g_fmt vpdma data type: 0x07 [ 357.042694] vin3a-0: get 8 buffer(s) of size 394240 each. [ 357.046848] vin3: vip_set_slice_path: [ 357.046858] vin3: vip_set_slice_path: DATA_PATH_SELECT(0000010C): 80008000 [ 357.046863] vin3: vip_set_slice_path: [ 357.046870] vin3: vip_set_slice_path: DATA_PATH_SELECT(0000010C): 40008000 [ 357.047147] vin3: vip_setup_parser: EMBEDDED_SYNC_2X_MULTIPLEXED_YUV422 [ 357.047153] vin3: vip_setup_parser: VIP_PIXCLK_EDGE_POLARITY=0 [ 357.047356] tw2964 4-0029: tw2964: read adr'0x65' dat'0x0' [ 357.047364] tw2964 4-0029: tw2964: writing adr'0x65' dat'0x0' [ 357.047484] vin3a-0: vip_load_vpdma_list_fifo: start_dma vb2 buf idx:0 [ 357.607609] vin3a-0: Timed out loading VPDMA list fifo [ 357.612795] ------------[ cut here ]------------ [ 357.617446] WARNING: CPU: 0 PID: 1269 at drivers/media/v4l2-core/videobuf2-core.c:1347 vb2_start_streaming+0xdc/0x158 [ 357.628278] Modules linked in: tw2964(O) sha512_generic sha512_arm sha256_generic sha1_generic sha1_arm_neon sha1_arm md5 cbc aes_arm_bs crypto_simd cryptd xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo bc_example(O) pru_rproc xhci_plat_hcd xhci_hcd pruss_intc rpmsg_rpc rpmsg_proto dwc3 udc_core pruss snd_soc_simple_card snd_soc_simple_card_utils snd_soc_omap_hdmi_audio pvrsrvkm(O) omap_aes_driver ahci_platform libahci_platform pruss_soc_bus libahci omap_sham libata omap_wdt scsi_mod phy_omap_usb2 ti_vip(O) ti_vpe ti_sc ti_csc ti_vpdma dwc3_omap rtc_omap extcon_palmas rtc_palmas pixcir_i2c_ts v4l2_fwnode snd_soc_tlv320aic3x at24 omap_des rtc_ds1307 des_generic crypto_engine omap_crypto omap_remoteproc virtio_rpmsg_bus rpmsg_core remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio [ 357.700108] usbserial usbcore usb_common gdbserverproxy(O) cryptodev(O) cmemk(O) [ 357.707960] CPU: 0 PID: 1269 Comm: yavta Tainted: G O 4.14.79-gbde58ab01e #1 [ 357.716176] Hardware name: Generic DRA74X (Flattened Device Tree) [ 357.722294] Backtrace: [ 357.724762] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c) [ 357.732366] r7:00000009 r6:60050013 r5:00000000 r4:c1053d90 [ 357.738056] [<c020b7a8>] (show_stack) from [<c0932528>] (dump_stack+0x90/0xa4) [ 357.745314] [<c0932498>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104) [ 357.752307] r7:00000009 r6:c0c0f3d4 r5:00000000 r4:00000000 [ 357.757993] [<c022b8e0>] (__warn) from [<c022ba9c>] (warn_slowpath_null+0x28/0x30) [ 357.765597] r9:00000000 r8:00000012 r7:c0719424 r6:ecd06ae8 r5:ecd0688c r4:fffffff0 [ 357.773379] [<c022ba74>] (warn_slowpath_null) from [<c072d94c>] (vb2_start_streaming+0xdc/0x158) [ 357.782208] [<c072d870>] (vb2_start_streaming) from [<c072f7a8>] (vb2_core_streamon+0x130/0x178) [ 357.791031] r7:c0719424 r6:eda6a800 r5:00000000 r4:ecd0688c [ 357.796719] [<c072f678>] (vb2_core_streamon) from [<c0731fec>] (vb2_streamon+0x38/0x58) [ 357.804756] r5:ed9b6e40 r4:00000001 [ 357.808348] [<c0731fb4>] (vb2_streamon) from [<c0732050>] (vb2_ioctl_streamon+0x44/0x48) [ 357.816480] [<c073200c>] (vb2_ioctl_streamon) from [<c0719448>] (v4l_streamon+0x24/0x28) [ 357.824604] r5:40045612 r4:c073200c [ 357.828200] [<c0719424>] (v4l_streamon) from [<c071bdd4>] (__video_do_ioctl+0x30c/0x314) [ 357.836324] r5:40045612 r4:00000001 [ 357.839920] [<c071bac8>] (__video_do_ioctl) from [<c071b688>] (video_usercopy+0x78/0x49c) [ 357.848132] r10:00000000 r9:00000000 r8:edc7be28 r7:00000000 r6:00000004 r5:00000001 [ 357.855995] r4:40045612 [ 357.858544] [<c071b610>] (video_usercopy) from [<c071bac4>] (video_ioctl2+0x18/0x1c) [ 357.866321] r10:ec242b90 r9:edc7a000 r8:ed210974 r7:be9bc604 r6:40045612 r5:ed9b6e40 [ 357.874183] r4:eda6a800 [ 357.876730] [<c071baac>] (video_ioctl2) from [<c0717d0c>] (v4l2_ioctl+0x84/0xe0) [ 357.884164] [<c0717c88>] (v4l2_ioctl) from [<c034ed3c>] (do_vfs_ioctl+0xa8/0x790) [ 357.891680] r9:edc7a000 r8:00000003 r7:40045612 r6:00000003 r5:ed9b6e40 r4:be9bc604 [ 357.899461] [<c034ec94>] (do_vfs_ioctl) from [<c034f460>] (SyS_ioctl+0x3c/0x60) [ 357.906803] r10:00000036 r9:edc7a000 r8:be9bc604 r7:40045612 r6:00000003 r5:ed9b6e40 [ 357.914665] r4:ed9b6e40 [ 357.917213] [<c034f424>] (SyS_ioctl) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c) [ 357.924817] r9:edc7a000 r8:c0207e44 r7:00000036 r6:00000001 r5:00000000 r4:00000008 [ 357.933837] ---[ end trace f15c45b46cdb50b2 ]--- [ 357.939747] vin3a-0: vip_release [ 357.939757] vin3a-0: vip_release_stream: stream instance 0x00000008ecd06000
I studied the following links but did not find solutions in them:
https://e2e.ti.com/support/processors/f/791/p/640197/2368318?pi320966=3#pi320966=1
https://e2e.ti.com/support/processors/f/791/t/555591?AM572x-VIN4a-V4L2-interface-with-TVP5158-analog-video-decoder
https://e2e.ti.com/support/processors/f/791/p/758945/2811324?tisearch=e2e-sitesearch&keymatch=PCM1774
Therefore, I had a third question.
3. How to make vip.c work simultaneously for different video channels?
PS. link to tvp5158 driver (http://review.omapzoom.org/#/c/37708/)
