Part Number: AM5708
Hi
I have an application running on the C6424 DSP that uses the on board EMAC. It is a specialised Ethernet stack and some audio processing. I am looking for an SOC with Arm and DSP that is compatible with multiple Ethernet interfaces . Can I access the 1G Ethernet EMAC on the AM5708 form the onboard C66 DSP ? If so where can I find the register map for the EMAC or GMAC ? If not can you recommend an alternative ?
