I am a relative newbie to Linux. Sorry if I am missing something simple. I am trying to run through the basics on eval board for the DM365. I am running Ubuntu 9.04 Linux on a VMware partition. I currently have two issues.
1. I have created the shared drive ans am exporting it. I can see the drive frow a windows PC and can browse into it. I then go to the console for the EVM and set the enviroment variables. then saveenv and boot. During the boot It is going to my dhcp server and trying to execute RPCs. rather than going to the address that I set as the nfxhost. Here is the log:
DM365 EVM :>printenv
bootdelay=4
baudrate=115200
bootfile="uImage"
ethaddr=00:0e:99:02:c9:e8
bootcmd=nboot 0x80700000 0 0x400000;bootm
serverip=172.16.3.203
nfshost=10.1.80.29
bootargs=console=ttyS0,115200n8 nointrdrw ip=dhcp root=/dev/nfs nfsroot=$(nfshost):$(rootpath),nolock mem=76M video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,4050K dm365_imp.oper_mode=0 davinci_capture.device_type=4
stdin=serial
stdout=serial
stderr=serial
ver=U-Boot 1.3.4 (Mar 2 2009 - 11:50:39)
rootpath=/home/keith/workdir/filesys
Environment size: 493/262140 bytes
DM365 EVM :>savenv
Unknown command 'savenv' - try 'help'
DM365 EVM :>saveenv
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x380000 -- 100% complete.
Writing to Nand... done
DM365 EVM :>boot
Loading from NAND 1GiB 3,3V 8-bit, offset 0x400000
Image Name: Linux-2.6.18_pro500-davinci_evm-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2026248 Bytes = 1.9 MB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux....................................................................................................................................... done, booting the kernel.
Linux version 2.6.18_pro500-davinci_evm-arm_v5t_le (a0850430@gtlnxlsf02.gt.design.ti.com) (gcc version 4.2.0 20070126 (prerelease) (MontaVista 4.2.0-3.0.0.0702771 2007-03-10)) #1 PREEMPT Mon Mar 2 12:24:32 EST 2009
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: DaVinci DM365 EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci DM0365 variant 0x0
PLL0: fixedrate: 24000000, commonrate: 121500000, vpssrate: 243000000
PLL0: vencrate: 27000000, ddrrate: 243000000, mmcsdrate: 121500000
PLL1: armrate: 297000000, voicerate: 99000000, vencrate: 74250000
MUX: initialized SPI0_SCLK
MUX: initialized SPI0_SDO)
MUX: initialized SPI0_SDI
MUX: initialized SPI0_SDENA0
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists. Total pages: 19456
Kernel command line: console=ttyS0,115200n8 nointrdrw ip=dhcp root=/dev/nfs nfsroot=$(nfshost):$(rootpath),nolock mem=76M video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,4050K dm365_imp.oper_mode=0 davinci_capture.device_type=4
PID hash table entries: 512 (order: 9, 2048 bytes)
Clock event device timer0_0 configured with caps set: 03
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 72588KB available (3497K code, 712K data, 168K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
DaVinci: 104 gpio irqs
DM365 IPIPE initialized in Continuous mode
Generic PHY: Registered new driver
ch0 default output "COMPOSITE", mode "NTSC"
VPBE Encoder Initialized
LogicPD encoder initialized
Avnetlcd encoder initialized
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 3.1 (2006/08/19) Phillip Lougher
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
yaffs Mar 2 2009 12:21:46 Installing.
SGI XFS with no debug enabled
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
davincifb davincifb.0: bad fbdev param 3
davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
davincifb davincifb.0: dm_osd0_fb: 720x576x16@0,0 with framebuffer size 4050KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1020KB
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_per_pixel: 4
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 4
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 4
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 4
davincifb davincifb.0: dm_osd1_fb: 720x480x4@0,0 with framebuffer size 675KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1020KB
DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec
davinci_ldc initialized
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfac20000 (irq = 40) is a 16550A
serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfad06000 (irq = 41) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
netconsole: not configured, aborting
Davinci EMAC MII Bus: probed
MAC address is 00:0e:99:02:c9:e8
TI DaVinci EMAC Linux version updated 4.0
Linux video capture interface: v2.00
starting ccdc_reset...<7>
End of ccdc_reset...<5>vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = MT9T001
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = MT9P031
TVP514X : nummber of channels = 1
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = TVP514X
Trying to register davinci display video device.
layer=c40ed400,layer->video_dev=c40ed560
layer=c40ed200,layer->video_dev=c40ed360
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
vpfe ccdc capture vpfe ccdc capture.1: vpif_register_decoder: decoder = TVP7002
i2c /dev entries driver
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron NAND 1GiB 3,3V 8-bit)
2 NAND chips detected
Creating 5 MTD partitions on "nand_davinci.0":
0x00000000-0x00360000 : "bootloader"
0x00360000-0x003a0000 : "params"
0x003a0000-0x007a0000 : "kernel"
0x007a0000-0x207a0000 : "filesystem1"
0x207a0000-0x307a0000 : "filesystem2"
nand_davinci nand_davinci.0: hardware revision: 2.3
dm_spi.0: davinci SPI Controller driver at 0xc5066000 (irq = 42) use_dma=0
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
musb_hdrc: version 6.0, cppi-dma, host, debug=0
MUX: initialized GPIO33
musb_hdrc musb_hdrc: No DMA interrupt line
musb_hdrc: USB Host mode controller at c5068000 using DMA, IRQ 12
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
davinci-mmc davinci-mmc.0: Supporting 4-bit mode
davinci-mmc davinci-mmc.0: Using DMA mode
davinci-mmc davinci-mmc.1: Supporting 4-bit mode
davinci-mmc davinci-mmc.1: Using DMA mode
Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
ASoC version 0.13.1
AIC3X Audio Codec 0.1
asoc: aic3x <-> davinci-i2s mapping ok
ALSA device list:
#0: DaVinci DM365 EVM (aic3x)
IPv4 over IPv4 tunneling driver
TCP bic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
Sending DHCP requests .., OK
IP-Config: Got DHCP answer from 10.1.80.1, my address is 10.1.80.21
IP-Config: Complete:
device=eth0, addr=10.1.80.21, mask=255.255.255.0, gw=10.1.80.1,
host=new-host-2, domain=VennelDN, nis-domain=(none),
bootserver=10.1.80.1, rootserver=10.1.80.1, rootpath=
Looking up port of RPC 100003/2 on 10.1.80.1
portmap: server 10.1.80.1 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 10.1.80.1
Root-NFS: Unable to get mountd port number from server, using default
mount: server 10.1.80.1 not responding, timed out
Root-NFS: Server returned error -5 while mounting /tftpboot/$(nfshost):$(rootpath)
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
* Hardware crypto devices
* Library routines
CRC-CCITT functions (CRC_CCITT) [M/y/?] m
CRC16 functions (CRC16) [N/m/y/?] n
CRC32 functions (CRC32) [Y/?] y
CRC32c (Castagnoli, et al) Cyclic Redundancy-Check (LIBCRC32C) [M/y/?] m
# configuration written to .config
python /home/keith/workdir/lsp/ti-davinci/linux-2.6.18_pro500/scripts/kconfig/checksetflags -z -v --config-file .config --flag-file /home/keith/workdir/lsp/ti-davinci/linux-2.6.18_pro500/scripts/kconfig/baseconfig
python: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
make[1]: *** [checksetconfig] Error 127
make: *** [checksetconfig] Error 2
keith@Keith-Ubuntu:~/workdir/lsp/ti-davinci/linux-2.6.18_pro500$ make menuconfig
