hi
./encode -v 444.mpeg4 -t 300
question:
how i can mpeg4 and g711 transform avi ?can you supply to give you some support and related company ?
hi
question:
Are you trying to create an AVI file from two elementary streams (MPEG4 and G711)? If so you can try FFMPEG or MENCODER open source applications.
hi, I have the same proplem :i wana create an AVI file from two elementary streams.I have tried FFMPEG ,but FFMPEG doesn't support g711 format, any other solutions ? Thanks.
so I found this player ( http://mpeg4ip.sourceforge.net/features/index.php ) that appears to support g.711, but bear in mind that I have not personally use this or that it will be portable to AMR9; therefore, you will have to do some research yourself.
so ,I return to this question ,I am designing a DVR on DM355,but i don't know how to make video and audio synchronous when playback forward the recorded files , because the video files and audio files is separate.
