Part Number: AM3352
Other Parts Discussed in Thread: TPS65217
Tool/software: Linux
Hi
i'm using am3352 capture usb webcam picture.
when i used kernel 4.1.6 , i got more problem (DMA busy , usb frozen....).
and find some post like below:
but the problems are not fixed .so i change kernel version to 4.14.79
and now i get new problem ....
my usb driver is not boot
when kernel 4.1.6 booting i can see below message:
[ 5.482285] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191
[ 7.303449] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 7.384778] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 7.419812] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.437326] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.454815] usb usb1: Product: MUSB HDRC host driver
[ 7.459825] usb usb1: Manufacturer: Linux 4.1.6-g52c4aa7 musb-hcd
[ 7.475727] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 7.487646] hub 1-0:1.0: USB hub found
[ 7.494793] hub 1-0:1.0: 1 port detected
udevadm settle - timeout of 3 seconds reached, the event queue contains:
/sys/devices/platform/ocp/47400000.usb/47401400.usb [ 7.529951] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
(1073)
/sys/devices/platform/ocp/47400000.usb/47401c00.usb (1078)
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto (1158)
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/usb1 (1159)
/sys/devices/platform/ocp/47400000.usb/47401400.usb/musb-hdrc.0.auto/usb1/1-0:1.0 (1160)
[ 7.665914] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 7.682403] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.696812] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.704089] usb usb2: Product: MUSB HDRC host driver
[ 7.720821] usb usb2: Manufacturer: Linux 4.1.6-g52c4aa7 musb-hcd
[ 7.734712] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 7.745350] hub 2-0:1.0: USB hub found
[ 7.755759] hub 2-0:1.0: 1 port detected
but change to 4.14.79 this message is gone
CCCCCCCC
U-Boot SPL 2015.07-svn271 (Apr 13 2017 - 13:28:03)
board/ti/am335x/board.c:am33xx_spl_board_init[278] ==>
Incorrect magic number (0xffffffff) in EEPROM
Could not get board ID.
board/ti/am335x/board.c:am33xx_spl_board_init[421] <==
arch/arm/cpu/armv7/omap-common/boot-common.c:spl_board_init[147] <==
common/spl/spl.c:board_init_r[202]
arch/arm/cpu/armv7/omap-common/boot-common.c:spl_boot_device[96] ==>boot=5
common/spl/spl.c:board_init_r[208] boot_device=5
common/spl/spl.c:board_init_r[231] before spl_nand_load_image()
common/spl/spl_nand.c:spl_nand_load_image[33] ==>
common/spl/spl_nand.c:spl_nand_load_image[38]
common/spl/spl_nand.c:spl_nand_load_image[130] load u-boot header
common/spl/spl_nand.c:spl_nand_load_image[137] load u-boot
common/spl/spl_nand.c:spl_nand_load_image[143] <==
common/spl/spl.c:board_init_r[292] Jumping to U-Boot
U-Boot 2015.07-svn271 (Apr 13 2017 - 13:28:03 +0800)
Watchdog enabled
I2C: ready
DRAM: 512 MiB
board/ti/am335x/board.c:board_init[560] ==>
NAND:
Read NAND flash ID 0 --> 0x2C
Read NAND flash ID 1 --> 0xDA
Read NAND flash ID 2 --> 0x90
Read NAND flash ID 3 --> 0x95
Read NAND flash ID 4 --> 0x6
Read NAND flash ID 5 --> 0x0
Read NAND flash ID 6 --> 0x0
Read NAND flash ID 7 --> 0x0
256 MiB
common/board_r.c:initr_mmc[403] ==>
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
board/ti/am335x/board.c:board_late_init[577] ==>
Net: board/ti/am335x/board.c:board_eth_init[671] ==>
<ethaddr> not set. Validating first E-fuse MAC
board/ti/am335x/board.c:board_eth_init[697] set am335x mac address==>
eeprom_mac_flag = 1
<eth1addr> not set. Validating first E-fuse MAC
Could not get board ID.(board_eth_init)
drivers/net/cpsw.c:cpsw_register[962] ==>
drivers/net/cpsw.c:cpsw_mdio_init[529] ==>
drivers/net/cpsw.c:cpsw_phy_init[936] ==>
cpsw, usb_ether
Hit any key to stop autoboot: 0
WARNING: Could not determine device tree to use
Card did not respond to voltage select!
Booting from nand ...
NAND read: device 0 offset 0x80000, size 0x40000
262144 bytes read: OK
NAND read: device 0 offset 0x200000, size 0x800000
8388608 bytes read: OK
Kernel image @ 0x82000000 [ 0x000000 - 0x3c1200 ]
Loading Device Tree to 8fff4000, end 8ffff4f2 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-ge669d52447 (wei@wei-VirtualBox) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Wed May 8 09:46:52 CST 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black_____Willh
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9d000000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048 rootfstype=ubifs rootwait=1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 456936K/524288K available (8192K kernel code, 321K rwdata, 2516K rodata, 1024K init, 269K bss, 18200K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB)
[ 0.000000] .data : 0xc0d00000 - 0xc0d50740 ( 322 kB)
[ 0.000000] .bss : 0xc0d50740 - 0xc0d93e8c ( 270 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000037] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000048] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000196] timer_probe: no matching timers found
[ 0.000404] Console: colour dummy device 80x30
[ 0.000431] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000439] This ensures that you still see kernel messages. Please
[ 0.000445] update your kernel commandline.
[ 0.000474] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089154] pid_max: default: 32768 minimum: 301
[ 0.089352] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089367] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090177] CPU: Testing write buffer coherency: ok
[ 0.090243] CPU0: Spectre v2: using BPIALL workaround
[ 0.090933] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.091087] Hierarchical SRCU implementation.
[ 0.091437] EFI services will not be available.
[ 0.092899] devtmpfs: initialized
[ 0.100478] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[ 0.100961] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.101253] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.101276] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.104922] pinctrl core: initialized pinctrl subsystem
[ 0.105675] DMI not present or invalid.
[ 0.106084] NET: Registered protocol family 16
[ 0.108366] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.117800] omap_hwmod: tptc0 using broken dt data from edma
[ 0.117942] omap_hwmod: tptc1 using broken dt data from edma
[ 0.118064] omap_hwmod: tptc2 using broken dt data from edma
[ 0.122641] omap_hwmod: debugss: _wait_target_disable failed
[ 0.175501] cpuidle: using governor ladder
[ 0.175538] cpuidle: using governor menu
[ 0.179201] OMAP GPIO hardware version 0.1
[ 0.187746] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/nandflash_pins_default, deferring probe
[ 0.189750] No ATAGs?
[ 0.189764] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.198832] edma 49000000.edma: Legacy memcpy is enabled, things might not work
[ 0.202971] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.206233] usbcore: registered new interface driver usbfs
[ 0.206295] usbcore: registered new interface driver hub
[ 0.206469] usbcore: registered new device driver usb
[ 0.206727] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.206865] media: Linux media interface: v0.10
[ 0.206910] Linux video capture interface: v2.00
[ 0.207025] pps_core: LinuxPPS API ver. 1 registered
[ 0.207035] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.207058] PTP clock support registered
[ 0.207093] EDAC MC: Ver: 3.0.0
[ 0.207549] dmi: Firmware registration failed.
[ 0.208086] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.208420] Advanced Linux Sound Architecture Driver Initialized.
[ 0.209762] clocksource: Switched to clocksource timer1
[ 0.218058] NET: Registered protocol family 2
[ 0.218816] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.218871] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.218920] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.219022] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.219044] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.219409] NET: Registered protocol family 1
[ 0.219902] RPC: Registered named UNIX socket transport module.
[ 0.219917] RPC: Registered udp transport module.
[ 0.219924] RPC: Registered tcp transport module.
[ 0.219931] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.220808] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.220926] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.221849] audit: initializing netlink subsys (disabled)
[ 0.222548] audit: type=2000 audit(0.210:1): state=initialized audit_enabled=0 res=1
[ 0.222654] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.227011] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.227891] NFS: Registering the id_resolver key type
[ 0.227939] Key type id_resolver registered
[ 0.227946] Key type id_legacy registered
[ 0.227999] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.230253] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.230274] io scheduler noop registered
[ 0.230283] io scheduler deadline registered
[ 0.230512] io scheduler cfq registered (default)
[ 0.230524] io scheduler mq-deadline registered
[ 0.230532] io scheduler kyber registered
[ 0.231397] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.231761] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.283577] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.286746] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 27, base_baud = 3000000) is a 8250
[ 0.986336] console [ttyS0] enabled
[ 0.990998] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 28, base_baud = 3000000) is a 8250
[ 1.000836] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 29, base_baud = 3000000) is a 8250
[ 1.011340] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.029513] brd: module loaded
[ 1.039345] loop: module loaded
[ 1.044919] libphy: Fixed MDIO Bus: probed
[ 1.119846] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.127547] davinci_mdio 4a101000.mdio: detected phy mask fffffff6
[ 1.135817] libphy: 4a101000.mdio: probed
[ 1.139964] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver RTL8211E Gigabit Ethernet
[ 1.149578] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver RTL8211E Gigabit Ethernet
[ 1.160355] cpsw 4a100000.ethernet: Detected MACID = 98:5d:ad:ba:98:1f
[ 1.167018] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 1.173504] cpsw 4a100000.ethernet: ALE Table size 1024
[ 1.178796] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[ 1.186839] cpsw 4a100000.ethernet: cpsw: Detected MACID = 98:5d:ad:ba:98:21
[ 1.195223] i2c /dev entries driver
[ 1.199159] IR NEC protocol handler initialized
[ 1.203777] IR RC5(x/sz) protocol handler initialized
[ 1.208849] IR RC6 protocol handler initialized
[ 1.213411] IR JVC protocol handler initialized
[ 1.217959] IR Sony protocol handler initialized
[ 1.222606] IR SANYO protocol handler initialized
[ 1.227328] IR Sharp protocol handler initialized
[ 1.232062] IR MCE Keyboard/mouse protocol handler initialized
[ 1.237917] IR XMP protocol handler initialized
[ 1.243573] cpu cpu0: OPP-v2 not supported, cpufreq-dt will attempt to use legacy tables.
[ 1.252394] sdhci: Secure Digital Host Controller Interface driver
[ 1.258605] sdhci: Copyright(c) Pierre Ossman
[ 1.263562] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.320418] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.329991] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.341196] NET: Registered protocol family 10
[ 1.347051] Segment Routing with IPv6
[ 1.350948] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.357596] NET: Registered protocol family 17
[ 1.362446] Key type dns_resolver registered
[ 1.366967] omap_voltage_late_init: Voltage driver support not added
[ 1.378872] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.384226] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.392089] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.398474] nand: Micron MT29F2G08ABAEAWP
[ 1.402637] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.410299] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.415873] 11 ofpart partitions found on MTD device omap2-nand.0
[ 1.422018] Creating 11 MTD partitions on "omap2-nand.0":
[ 1.427451] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.433790] 0x000000020000-0x000000040000 : "NAND.SPL.backup1"
[ 1.440648] 0x000000040000-0x000000060000 : "NAND.SPL.backup2"
[ 1.447389] 0x000000060000-0x000000080000 : "NAND.SPL.backup3"
[ 1.454291] 0x000000080000-0x0000000c0000 : "NAND.u-boot-spl-os"
[ 1.461402] 0x0000000c0000-0x0000001c0000 : "NAND.u-boot"
[ 1.468537] 0x0000001c0000-0x0000001e0000 : "NAND.u-boot-env"
[ 1.475274] 0x0000001e0000-0x000000200000 : "NAND.u-boot-env.backup1"
[ 1.482697] 0x000000200000-0x000000a00000 : "NAND.kernel"
[ 1.496448] 0x000000a00000-0x00000e400000 : "NAND.file-system"
[ 1.707047] 0x00000e400000-0x00000fd00000 : "jffs2"
[ 1.764374] random: fast init done
[ 1.768532] vdd_1v8: Bringing 3300000uV into 1800000-1800000uV
[ 1.778064] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.783543] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.790733] ubi0: attaching mtd9
[ 2.880506] ubi0: scanning is finished
[ 2.893408] ubi0: attached mtd9 (name "NAND.file-system", size 218 MiB)
[ 2.900159] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.907064] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 2.913810] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.920815] ubi0: good PEBs: 1744, bad PEBs: 0, corrupted PEBs: 0
[ 2.926934] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.934207] ubi0: max/mean erase counter: 7/3, WL threshold: 4096, image sequence number: 1590725337
[ 2.943392] ubi0: available PEBs: 0, total reserved PEBs: 1744, PEBs reserved for bad PEB handling: 40
[ 2.952763] ubi0: background thread "ubi_bgt0d" started, PID 45
[ 2.959543] input: gpio_buttons@0 as /devices/platform/gpio_buttons@0/input/input0
[ 2.967672] hctosys: unable to open rtc device (rtc0)
[ 2.973314] vmmcsd_fixed: disabling
[ 2.976835] ALSA device list:
[ 2.979901] No soundcards found.
[ 2.989882] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 46
[ 3.024633] UBIFS (ubi0:0): recovery needed
[ 3.129497] UBIFS (ubi0:0): recovery completed
[ 3.134155] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 3.141612] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.151590] UBIFS (ubi0:0): FS size: 199225344 bytes (189 MiB, 1569 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.162343] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 3.168205] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID EABEA964-0FD9-430F-A00C-CD5D95DBC728, small LPT model
[ 3.180524] VFS: Mounted root (ubifs filesystem) on device 0:14.
[ 3.187442] devtmpfs: mounted
[ 3.191929] Freeing unused kernel memory: 1024K
INIT: version 2.88 booting
Error opening /dev/fb0: No such file or directory
Starting udev
[ 4.097079] udevd[80]: starting version 182
[ 5.554970] random: dd: uninitialized urandom read (512 bytes read)
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1729: No soundcards found...
hwclock: can't open '/dev/misc/rtc': No such file or directory
Sun Oct 4 07:10:38 UTC 2015
INIT: Entering runlevel: 5
Configuring network interfaces... [ 8.222719] net eth0: initializing cpsw version 1.12 (0)
[ 8.244446] RTL8211E Gigabit Ethernet 4a101000.mdio:03: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=4a101000.mdio:03, irq=POLL)
[ 8.267361] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting system message bus: [ 8.421176] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 8.465503] random: dbus-daemon: uninitialized urandom read (12 bytes read)
dbus.
Starting telnet daemon.
Starting rpcbind daemon...done.
starting statd: done
Starting syslogd/klogd: done
grep: /var/lib/opkg/info/*.control: No such file or directory
check upgrade
/home/auto.sh: line 2: /home/root/auto.sh: No such file or directory
eGate login: [ 9.281373] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 9.289478] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
how should i do ?
