AM3352: Random processor failures
Part Number: AM3352
Other Parts Discussed in Thread: TPS65217
Hello:
We are experiencing random processor failures using AM3352BZCZD80.
It is being powered by the recommended  PMIC TPS65217.  These failures seem to occur upon startup and they seem to never recover.
The PMIC output VLOD4 PIN 43 3.3 V and all other outputs get pulled down to zero when these failures occur. This output supplies many of the voltage supply rails of the processor.
When we uncouple the load to this particular output (VLOD4) by removing a series zero Ohm resistor, the PMIC then becomes active again with all voltage rails supplying the correct voltages.
We have theorized that something has shorted in the processor. We have virtually no way to forensically investigate these processors.
What we are looking for is some insight into why this is happening, and if there are some design considerations that we need to address.
Thank You
Andy
