Linux/TDA2EXEVM: I want to input 2 h264 video, can i do?
Part Number: TDA2EXEVM
Tool/software: Linux
hi,my chain is :
NullSource (A15) -> Decode -> Dup_dec
Dup_dec -> VPE -> Select -> Display
Dup_dec -> Encode -> Null (A15)
NullSource Link :
Void chains_lvdsMultiCam_nullSrc_vpeEncNull_display_SetNullSrcPrms(
    Chains_lvdsVipMultiCam_vpeEncNull_displayAppObj* pObj,
    NullSrcLink_CreateParams* pPrm) {
    UInt32 chId;
    System_LinkChInfo* pChInfo;
    pPrm->outQueInfo.numCh = MAX_NUMBER_OF_CHANNELS;
    pPrm->timerPeriodMilliSecs = 100;
    for (chId = 0; chId < pPrm->outQueInfo.numCh; chId++) {
        pPrm->channelParams[chId].numBuffers = 4;
        pChInfo = &pPrm->outQueInfo.chInfo[chId];
        pChInfo->flags = System_Link_Ch_Info_Set_Flag_Data_Format(pChInfo->flags,
                         SYSTEM_DF_YUV420SP_UV);
        pChInfo->flags = System_Link_Ch_Info_Set_Flag_Scan_Format(pChInfo->flags,
                         SYSTEM_SF_PROGRESSIVE);
        pChInfo->flags = System_Link_Ch_Info_Set_Flag_Buf_Type(pChInfo->flags,
                         /*SYSTEM_BUFFER_TYPE_VIDEO_FRAME*/
                         SYSTEM_BUFFER_TYPE_BITSTREAM);
        pChInfo->width = ENCDEC_FRAME_WIDTH;//pObj->displayWidth;
        pChInfo->height = ENCDEC_FRAME_HEIGHT;//pObj->displayHeight;
        pChInfo->startX = 0;
        pChInfo->startY = 0;
        pChInfo->pitch[0] = SystemUtils_align(pChInfo->width, 32);
        pChInfo->pitch[1] = SystemUtils_align(pChInfo->width, 32);
        pPrm->channelParams[chId].fileReadMode = NULLSRC_LINK_FILEREAD_RUN_TIME;
        //strncpy(pPrm->channelParams[chId].nameDataFile, "/home/1920x1080_00.h264", 260);
        //strncpy(pPrm->channelParams[chId].nameIndexFile, "/home/1920x1080_00.hdr", 260);
    strncpy(pPrm->channelParams[0].nameDataFile, "/home/1920x1080_00.h264", 260);
    strncpy(pPrm->channelParams[0].nameIndexFile, "/home/1920x1080_00.hdr", 260);
    strncpy(pPrm->channelParams[1].nameDataFile, "/home/1920x1080_01.h264", 260);
    strncpy(pPrm->channelParams[1].nameIndexFile, "/home/1920x1080_01.hdr", 260);
    //strncpy(pPrm->channelParams[2].nameDataFile, "/home/1920x1080_02.h264", 260);
    //strncpy(pPrm->channelParams[2].nameIndexFile, "/home/1920x1080_02.hdr", 260);
    pPrm->dataRxMode = NULLSRC_LINK_DATA_RX_MODE_FILE;
nullSrcLink_tsk.c
/* Only one channel is supported as of now */
    //OSA_assert(pPrm->outQueInfo.numCh == 1U);
my output video is:
there is a error like below:
[HOST] [IPU2 ] 71.909321 s: DEC_LINK: Sequence called number 471
[HOST] [IPU2 ] 71.934331 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 71.934453 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 71.934575 s: DEC_LINK: Sequence called number 472
[HOST] [IPU2 ] 71.975568 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 71.975690 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 71.975812 s: DEC_LINK: Sequence called number 473
[HOST] [IPU2 ] 71.977215 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 71.977337 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 71.977459 s: DEC_LINK: Sequence called number 474
[HOST] [IPU2 ] 72.047520 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 72.047611 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 72.047733 s: DEC_LINK: Sequence called number 475
[HOST] [IPU2 ] 72.072927 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 72.073049 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 72.073140 s: DEC_LINK: Sequence called number 476
[HOST] [IPU2 ] 72.112914 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 72.113036 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 72.113158 s: DEC_LINK: Sequence called number 477
[HOST] [IPU2 ] 72.114500 s: DECODE: ERROR: ALGPROCESS FAILED (status=0x00001421) !!!
[HOST] [IPU2 ] 72.114622 s: DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x1421
[HOST] [IPU2 ] 72.114713 s: DEC_LINK: Sequence called number 478
then, I press "p", show like below:
[HOST] [HOST  ]    421.221100 s:  [ NULL_SRC ] Link Statistics,
 [HOST] [HOST  ]    421.221100 s:  ******************************
 [HOST] [HOST  ]    421.221100 s:  Elapsed time       = 90122 msec
 [HOST] [HOST  ]    421.221130 s:  New data Recv      =  30.30 fps
 [HOST] [HOST  ]    421.221130 s:  Get Full Buf Cb    =  29.51 fps
 [HOST] [HOST  ]    421.221130 s:  Put Empty Buf Cb   =  51.75 fps
 [HOST] [HOST  ]    421.221130 s:  Driver/Notify Cb   =  30.30 fps
 [HOST] [HOST  ]    421.221161 s:  Input Statistics,
 [HOST] [HOST  ]    421.221161 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [HOST  ]    421.221161 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [HOST  ]    421.221161 s:  --------------------------------------------------
 [HOST] [HOST  ]    421.221191 s:   0 |  30.30      0.78      0. 0          29.51
 [HOST] [HOST  ]    421.221191 s:   1 |  30.30      8. 7      0. 0          22.22
 [HOST] [HOST  ]    421.221191 s:  Output Statistics,
 [HOST] [HOST  ]    421.221222 s:
 [HOST] [HOST  ]    421.221222 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [HOST  ]    421.221222 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [HOST  ]    421.221222 s:  ---------------------------------------------
 [HOST] [HOST  ]    421.221222 s:   0 |  0     29.51     0. 0      0. 0
 [HOST] [HOST  ]    421.221252 s:   1 |  0     22.22     0. 0      0. 0
 [HOST] [HOST  ]    421.221283 s:
 [HOST] [HOST  ]    421.221283 s:  [ IPC_OUT_0 ] Link Statistics,
 [HOST] [HOST  ]    421.221283 s:  ******************************
 [HOST] [HOST  ]    421.221313 s:
 [HOST] [HOST  ]    421.221313 s:  Elapsed time       = 90121 msec
 [HOST] [HOST  ]    421.221313 s:  New data Recv      =  29.51 fps
 [HOST] [HOST  ]    421.221313 s:  Release data Recv  =  51.75 fps
 [HOST] [HOST  ]    421.221344 s:  Driver/Notify Cb   =  51.75 fps
 [HOST] [HOST  ]    421.221344 s:  Input Statistics,
 [HOST] [HOST  ]    421.221344 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [HOST  ]    421.221374 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [HOST  ]    421.221374 s:  --------------------------------------------------
 [HOST] [HOST  ]    421.221374 s:   0 |  25.93      0. 0      0. 0          25.93
 [HOST] [HOST  ]    421.221374 s:   1 |  25.80      0. 0      0. 0          25.80
 [HOST] [HOST  ]    421.221405 s:
 [HOST] [HOST  ]    421.221405 s:  Output Statistics,
 [HOST] [HOST  ]    421.221405 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [HOST  ]    421.221405 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [HOST  ]    421.221405 s:  ---------------------------------------------
 [HOST] [HOST  ]    421.221435 s:   0 |  0     25.93     0. 0      0. 0
 [HOST] [HOST  ]    421.221435 s:   1 |  0     25.80     0. 0      0. 0
 [HOST] [HOST  ]    421.221435 s:  [ IPC_OUT_0 ] LATENCY,
 [HOST] [HOST  ]    421.221466 s:  ********************
 [HOST] [HOST  ]    421.221466 s:  Local Link Latency     : Avg =      1 us, Min =      0 us, Max =     31 us,
 [HOST] [HOST  ]    421.221496 s:  Source to Link Latency : Avg =    795 us, Min =      0 us, Max = 203990 us,
 [HOST] [IPU2  ]    421.220764 s:
 [HOST] [IPU2  ]    421.220856 s:
 [HOST] [IPU2  ]    421.222290 s:
 [HOST] [IPU2  ]    421.222351 s:  [ IPC_IN_0 ] Link Statistics,
 [HOST] [IPU2  ]    421.222412 s:  ******************************
 [HOST] [IPU2  ]    421.222503 s:
 [HOST] [IPU2  ]    421.222564 s:  Elapsed time       = 90119 msec
 [HOST] [IPU2  ]    421.222656 s:
 [HOST] [IPU2  ]    421.222686 s:  Get Full Buf Cb    =  64.10 fps
 [HOST] [IPU2  ]    421.222778 s:  Put Empty Buf Cb   =  51.75 fps
 [HOST] [IPU2  ]    421.222869 s:  Driver/Notify Cb   =  62.85 fps
 [HOST] [IPU2  ]    421.222961 s:
 [HOST] [IPU2  ]    421.222991 s:  Input Statistics,
 [HOST] [IPU2  ]    421.223052 s:
 [HOST] [IPU2  ]    421.223083 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.223174 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.223266 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.223357 s:   0 |  25.93      0. 0      0. 0          25.93
 [HOST] [IPU2  ]    421.223479 s:   1 |  25.81      0. 0      0. 0          25.81
 [HOST] [IPU2  ]    421.223662 s:
 [HOST] [IPU2  ]    421.223693 s:  Output Statistics,
 [HOST] [IPU2  ]    421.223754 s:
 [HOST] [IPU2  ]    421.223784 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [IPU2  ]    421.223876 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [IPU2  ]    421.223967 s:  ---------------------------------------------
 [HOST] [IPU2  ]    421.224028 s:   0 |  0     25.93     0. 0      0. 0
 [HOST] [IPU2  ]    421.224150 s:   1 |  0     25.81     0. 0      0. 0
 [HOST] [IPU2  ]    421.224303 s:
 [HOST] [IPU2  ]    421.224364 s:  [ IPC_IN_0 ] LATENCY,
 [HOST] [IPU2  ]    421.224425 s:  ********************
 [HOST] [IPU2  ]    421.224486 s:  Local Link Latency     : Avg =     18 us, Min =      0 us, Max =    152 us,
 [HOST] [IPU2  ]    421.224608 s:  Source to Link Latency : Avg =   1057 us, Min =    183 us, Max = 204203 us,
 [HOST] [IPU2  ]    421.224821 s:
 [HOST] [IPU2  ]    421.224882 s:  [ IPC_IN_0 ] Detailed IPC Latency Statistics [ HOST -> IPU2 ] ,
 [HOST] [IPU2  ]    421.224974 s:  ***************************************************************
 [HOST] [IPU2  ]    421.225065 s:  IPC One-way Buffer Passing Latency   (usecs) : Avg =    276, Min =    152, Max =    519
 [HOST] [IPU2  ]    421.225187 s:  IPC One-way Notify Interrupt Latency (usecs) : Avg =    215, Min =     91, Max =    489
 [HOST] [IPU2  ]    421.226011 s:
 [HOST] [IPU2  ]    421.226072 s:  [ DECODE ] Link Statistics,
 [HOST] [IPU2  ]    421.226133 s:  ******************************
 [HOST] [IPU2  ]    421.226194 s:
 [HOST] [IPU2  ]    421.226255 s:  Elapsed time       = 90119 msec
 [HOST] [IPU2  ]    421.226316 s:
 [HOST] [IPU2  ]    421.226377 s:  New data Recv      =  64.10 fps
 [HOST] [IPU2  ]    421.226438 s:  Release data Recv  =  51.75 fps
 [HOST] [IPU2  ]    421.226590 s:  Get Full Buf Cb    = 103.49 fps
 [HOST] [IPU2  ]    421.226651 s:  Put Empty Buf Cb   =  51.75 fps
 [HOST] [IPU2  ]    421.226743 s:
 [HOST] [IPU2  ]    421.226773 s:  Input Statistics,
 [HOST] [IPU2  ]    421.226834 s:
 [HOST] [IPU2  ]    421.226865 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.226956 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.227048 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.227139 s:   0 |  25.93      0. 0      0. 0          25.93
 [HOST] [IPU2  ]    421.227292 s:   1 |  25.81      0. 0      0. 0          25.81
 [HOST] [IPU2  ]    421.227444 s:  Num frames inside the codec for chId: 0 = 4
 [HOST] [IPU2  ]    421.227536 s:  Num process reqest count for chId: 0 = 3601
 [HOST] [IPU2  ]    421.227627 s:  Num process complete count for chId: 0 = 3600
 [HOST] [IPU2  ]    421.227719 s:  Num frames inside the codec for chId: 1 = 3
 [HOST] [IPU2  ]    421.227810 s:  Num process reqest count for chId: 1 = 3867
 [HOST] [IPU2  ]    421.227902 s:  Num process complete count for chId: 1 = 3867
 [HOST] [IPU2  ]    421.227993 s:
 [HOST] [IPU2  ]    421.228054 s:  [ DECODE ] LATENCY,
 [HOST] [IPU2  ]    421.228115 s:  ********************
 [HOST] [IPU2  ]    421.228176 s:  Local Link Latency     : Avg =  25162 us, Min =  11224 us, Max =  77564 us,
 [HOST] [IPU2  ]    421.228298 s:  Source to Link Latency : Avg = 131918 us, Min =  11956 us, Max = 318551 us,
 [HOST] [IPU2  ]    421.228420 s:
 [HOST] [IPU2  ]    421.228481 s:  HDVICP-ID: 0
 [HOST] [IPU2  ]    421.228542 s: All percentage figures are based of totalElapsedTime
 [HOST] [IPU2  ]    421.228634 s:
 [HOST] [IPU2  ] 		 totalAcquire2Wait :1 %
 [HOST] [IPU2  ] 		 totalWait2Isr :94 %
 [HOST] [IPU2  ] 		 totalIsr2Done :0 %
 [HOST] [IPU2  ] 		 totalWait2Done :94 %
 [HOST] [IPU2  ] 		 totalDone2Release :0 %
 [HOST] [IPU2  ] 		 totalAcquire2Release :97 %
 [HOST] [IPU2  ] 		 totalRelease2AcquireDelay :2 %
 [HOST] [IPU2  ] 		 totalElapsedTime in msec :  144949
 [HOST] [IPU2  ] 		 numAccessCnt:   11349
 [HOST] [IPU2  ]    421.229030 s:  IVA-FPS :      78
 [HOST] [IPU2  ]    421.229091 s:  Average time spent per frame in microsec:   12004
 [HOST] [IPU2  ]    421.229183 s:
 [HOST] [HOST  ]    421.239187 s:
 [HOST] [HOST  ]    421.239217 s:  [ IPC_IN_0 ] Link Statistics,
 [HOST] [HOST  ]    421.239217 s:  ******************************
 [HOST] [HOST  ]    421.239217 s:  Elapsed time       = 90118 msec
 [HOST] [HOST  ]    421.239248 s:
 [HOST] [HOST  ]    421.239248 s:  Get Full Buf Cb    =  27.69 fps
 [HOST] [HOST  ]    421.239248 s:  Put Empty Buf Cb   =  27.69 fps
 [HOST] [HOST  ]    421.239248 s:  Driver/Notify Cb   =  27.69 fps
 [HOST] [HOST  ]    421.239248 s:  Input Statistics,
 [HOST] [HOST  ]    421.239278 s:
 [HOST] [HOST  ]    421.239278 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [HOST  ]    421.239278 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [HOST  ]    421.239278 s:  --------------------------------------------------
 [HOST] [HOST  ]    421.239278 s:   0 |  13.84      0. 0      0. 0          13.84
 [HOST] [HOST  ]    421.239309 s:   1 |  13.84      0. 0      0. 0          13.84
 [HOST] [HOST  ]    421.239309 s:  Output Statistics,
 [HOST] [HOST  ]    421.239309 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [HOST  ]    421.239339 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [HOST  ]    421.239339 s:  ---------------------------------------------
 [HOST] [HOST  ]    421.239339 s:   0 |  0     13.84     0. 0      0. 0
 [HOST] [HOST  ]    421.239339 s:   1 |  0     13.84     0. 0      0. 0
 [HOST] [HOST  ]    421.239370 s:
 [HOST] [HOST  ]    421.239370 s:  [ IPC_IN_0 ] LATENCY,
 [HOST] [HOST  ]    421.239370 s:  ********************
 [HOST] [HOST  ]    421.239370 s:  Local Link Latency     : Avg =      8 us, Min =      0 us, Max =     31 us,
 [HOST] [HOST  ]    421.239370 s:  Source to Link Latency : Avg = 405843 us, Min =  76923 us, Max = 606631 us,
 [HOST] [HOST  ]    421.239400 s:
 [HOST] [HOST  ]    421.239400 s:  [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> HOST ] ,
 [HOST] [HOST  ]    421.239400 s:  ***************************************************************
 [HOST] [HOST  ]    421.239400 s:  IPC One-way Buffer Passing Latency   (usecs) : Avg =    258, Min =    183, Max =   7473
 [HOST] [HOST  ]    421.239431 s:  IPC One-way Notify Interrupt Latency (usecs) : Avg =    187, Min =    122, Max =   7381
 [HOST] [IPU2  ]    421.232233 s:
 [HOST] [IPU2  ]    421.232324 s:  [ ENCODE ] Link Statistics,
 [HOST] [IPU2  ]    421.232385 s:  ******************************
 [HOST] [IPU2  ]    421.232446 s:
 [HOST] [IPU2  ]    421.232507 s:  Elapsed time       = 90119 msec
 [HOST] [IPU2  ]    421.232599 s:
 [HOST] [IPU2  ]    421.232660 s:  New data Recv      =  51.75 fps
 [HOST] [IPU2  ]    421.232721 s:  Release data Recv  =  27.69 fps
 [HOST] [IPU2  ]    421.232812 s:  Get Full Buf Cb    =  79.45 fps
 [HOST] [IPU2  ]    421.232904 s:  Put Empty Buf Cb   =  51.76 fps
 [HOST] [IPU2  ]    421.232965 s:
 [HOST] [IPU2  ]    421.233026 s:  Input Statistics,
 [HOST] [IPU2  ]    421.233087 s:
 [HOST] [IPU2  ]    421.233117 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.233209 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.233270 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.233361 s:   0 |  25.93      0. 0      0. 0          13.81
 [HOST] [IPU2  ]    421.233544 s:   1 |  25.82      0. 0      0. 0          13.87
 [HOST] [IPU2  ]    421.233697 s:  ENCODE: Num process reqest count for chId: 0 = 1981
 [HOST] [IPU2  ]    421.233788 s:  ENCODE: Num process complete count for chId: 0 = 1979
 [HOST] [IPU2  ]    421.233880 s:  ENCODE: Num process reqest count for chId: 1 = 1909
 [HOST] [IPU2  ]    421.233971 s:  ENCODE: Num process complete count for chId: 1 = 1904
 [HOST] [IPU2  ]    421.234063 s:
 [HOST] [IPU2  ]    421.234093 s:  [ ENCODE ] LATENCY,
 [HOST] [IPU2  ]    421.234154 s:  ********************
 [HOST] [IPU2  ]    421.234215 s:  Local Link Latency     : Avg = 264337 us, Min =  49320 us, Max = 405996 us,
 [HOST] [IPU2  ]    421.234337 s:  Source to Link Latency : Avg = 405262 us, Min =  76526 us, Max = 606143 us,
 [HOST] [IPU2  ]    421.234459 s:
 [HOST] [IPU2  ]    421.234551 s:  HDVICP-ID: 0
 [HOST] [IPU2  ]    421.234612 s: All percentage figures are based of totalElapsedTime
 [HOST] [IPU2  ]    421.234703 s:
 [HOST] [IPU2  ] 		 totalElapsedTime in msec :  144963
 [HOST] [IPU2  ] 		 numAccessCnt:   11350
 [HOST] [IPU2  ]    421.235008 s:  IVA-FPS :      78
 [HOST] [IPU2  ]    421.235069 s:  Average time spent per frame in microsec:   12005
 [HOST] [IPU2  ]    421.235161 s:
 [HOST] [IPU2  ]    421.235557 s:
 [HOST] [IPU2  ]    421.235618 s:  [ IPC_OUT_0 ] Link Statistics,
 [HOST] [IPU2  ]    421.235679 s:  ******************************
 [HOST] [IPU2  ]    421.235740 s:
 [HOST] [IPU2  ]    421.235801 s:  Elapsed time       = 90118 msec
 [HOST] [IPU2  ]    421.235862 s:
 [HOST] [IPU2  ]    421.235893 s:  New data Recv      =  27.69 fps
 [HOST] [IPU2  ]    421.235984 s:  Release data Recv  =  27.69 fps
 [HOST] [IPU2  ]    421.236076 s:  Driver/Notify Cb   =  61.3 fps
 [HOST] [IPU2  ]    421.236137 s:
 [HOST] [IPU2  ]    421.236198 s:  Input Statistics,
 [HOST] [IPU2  ]    421.236228 s:
 [HOST] [IPU2  ]    421.236289 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.236350 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.236442 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.236564 s:   0 |  13.84      0. 0      0. 0          13.84
 [HOST] [IPU2  ]    421.236686 s:   1 |  13.84      0. 0      0. 0          13.84
 [HOST] [IPU2  ]    421.236838 s:
 [HOST] [IPU2  ]    421.236869 s:  Output Statistics,
 [HOST] [IPU2  ]    421.236930 s:
 [HOST] [IPU2  ]    421.236960 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [IPU2  ]    421.237052 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [IPU2  ]    421.237143 s:  ---------------------------------------------
 [HOST] [IPU2  ]    421.237204 s:   0 |  0     13.84     0. 0      0. 0
 [HOST] [IPU2  ]    421.237357 s:   1 |  0     13.84     0. 0      0. 0
 [HOST] [IPU2  ]    421.237479 s:
 [HOST] [IPU2  ]    421.237540 s:  [ IPC_OUT_0 ] LATENCY,
 [HOST] [IPU2  ]    421.237601 s:  ********************
 [HOST] [IPU2  ]    421.237662 s:  Local Link Latency     : Avg =     10 us, Min =      0 us, Max =     92 us,
 [HOST] [IPU2  ]    421.237784 s:  Source to Link Latency : Avg = 405614 us, Min =  76679 us, Max = 606448 us,
 [HOST] [IPU2  ]    421.237936 s:
 [HOST] [IPU2  ]    421.240224 s:
 [HOST] [IPU2  ]    421.240926 s:  [ VPE ] Link Statistics,
 [HOST] [IPU2  ]    421.241017 s:  ******************************
 [HOST] [IPU2  ]    421.241078 s:
 [HOST] [IPU2  ]    421.241109 s:  Elapsed time       = 90110 msec
 [HOST] [IPU2  ]    421.241200 s:
 [HOST] [IPU2  ]    421.241231 s:  New data Recv      =  51.73 fps
 [HOST] [IPU2  ]    421.241322 s:  Get Full Buf Cb    =  51.39 fps
 [HOST] [IPU2  ]    421.241414 s:  Put Empty Buf Cb   =  51.39 fps
 [HOST] [IPU2  ]    421.241475 s:  Driver/Notify Cb   =  51.73 fps
 [HOST] [IPU2  ]    421.241627 s:
 [HOST] [IPU2  ]    421.241658 s:  Input Statistics,
 [HOST] [IPU2  ]    421.241719 s:
 [HOST] [IPU2  ]    421.241780 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.241841 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.241932 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.242024 s:   0 |  25.92      0. 0      0. 0          25.57
 [HOST] [IPU2  ]    421.242176 s:   1 |  25.81      0. 0      0. 0          25.81
 [HOST] [IPU2  ]    421.242329 s:
 [HOST] [IPU2  ]    421.242359 s:  Output Statistics,
 [HOST] [IPU2  ]    421.242420 s:
 [HOST] [IPU2  ]    421.242451 s:  CH | Out | Out     | Out Drop | Out User Drop
 [HOST] [IPU2  ]    421.242573 s:     | ID  | FPS     | FPS      | FPS
 [HOST] [IPU2  ]    421.242664 s:  ---------------------------------------------
 [HOST] [IPU2  ]    421.242756 s:   0 |  0     25.57     0.34      0. 0
 [HOST] [IPU2  ]    421.242878 s:   1 |  0     25.81     0. 0      0. 0
 [HOST] [IPU2  ]    421.243030 s:
 [HOST] [IPU2  ]    421.243061 s:  [ VPE ] LATENCY,
 [HOST] [IPU2  ]    421.243122 s:  ********************
 [HOST] [IPU2  ]    421.243213 s:  Local Link Latency     : Avg =   8472 us, Min =   8418 us, Max =   9181 us,
 [HOST] [IPU2  ]    421.243335 s:  Source to Link Latency : Avg = 141196 us, Min =  22631 us, Max = 327335 us,
 [HOST] [IPU2  ]    421.243457 s:
 [HOST] [IPU2  ]    421.244921 s:
 [HOST] [IPU2  ]    421.245013 s:  [ DISPLAY ] Link Statistics,
 [HOST] [IPU2  ]    421.245074 s:  ******************************
 [HOST] [IPU2  ]    421.245135 s:
 [HOST] [IPU2  ]    421.245196 s:  Elapsed time       = 90112 msec
 [HOST] [IPU2  ]    421.245257 s:
 [HOST] [IPU2  ]    421.245318 s:  New data Recv      =  25.57 fps
 [HOST] [IPU2  ]    421.245409 s:  Driver/Notify Cb   =  60.2 fps
 [HOST] [IPU2  ]    421.245470 s:
 [HOST] [IPU2  ]    421.245562 s:  Input Statistics,
 [HOST] [IPU2  ]    421.245623 s:
 [HOST] [IPU2  ]    421.245653 s:  CH | In Recv | In Drop | In User Drop | In Process
 [HOST] [IPU2  ]    421.245745 s:     | FPS     | FPS     | FPS          | FPS
 [HOST] [IPU2  ]    421.245836 s:  --------------------------------------------------
 [HOST] [IPU2  ]    421.245928 s:   0 |  25.57      0. 0      0. 0          25.57
 [HOST] [IPU2  ]    421.246202 s:
 [HOST] [IPU2  ]    421.246263 s:  [ DISPLAY ] LATENCY,
 [HOST] [IPU2  ]    421.246324 s:  ********************
 [HOST] [IPU2  ]    421.246385 s:  Local Link Latency     : Avg =     46 us, Min =     30 us, Max =    458 us,
 [HOST] [IPU2  ]    421.246507 s:  Source to Link Latency : Avg = 141353 us, Min =  22875 us, Max = 327334 us,
 [HOST] [IPU2  ]    421.246660 s:
 [HOST] [IPU2  ]    421.246721 s:
 [HOST] [IPU2  ]    421.246782 s:  [ DISPLAY  VID1 ] Additional Statistics,
 [HOST] [IPU2  ]    421.246843 s:  ************************************
 [HOST] [IPU2  ]    421.246934 s:  Driver Queued    =   3552 frames
 [HOST] [IPU2  ]    421.246995 s:  Driver De-Queued =   3551 frames
 [HOST] [IPU2  ]    421.247087 s:  Driver Displayed =   8701 frames
 [HOST] [IPU2  ]    421.247178 s:  Driver Repeated  =   5150 frames
 [HOST] [IPU2  ]    421.247239 s:
 [HOST] [IPU2  ]    421.247300 s:  ##### DSS DISPC Underflow Count  =      0 #####
 [HOST] [IPU2  ]    421.247392 s:
 [HOST] [IPU2  ]    421.249344 s:  DECODE OUT  BufExt Q Status
 [HOST] [IPU2  ]    421.249710 s:  Empty Q 0 -> count 0, wrPtr 147, rdPtr 147
 [HOST] [IPU2  ]    421.249954 s:  Empty Q 1 -> count 0, wrPtr 27, rdPtr 27
 [HOST] [IPU2  ]    421.250076 s:  Full Q -> count 0, wrPtr 193, rdPtr 193
 [HOST] [IPU2  ]    421.250259 s:  ENCODE Out  BufExt Q Status
 [HOST] [IPU2  ]    421.250594 s:  Empty Q 0 -> count 0, wrPtr 51, rdPtr 51
 [HOST] [IPU2  ]    421.250686 s:  Full Q -> count 0, wrPtr 43, rdPtr 43
 [HOST] [IPU2  ]    421.254041 s:  [VPE OUT0] Buffer Q Status,
 [HOST] [IPU2  ]    421.254102 s:  Empty Q : Elements in Q =   0, Write Idx =   0, Read Idx =   0
 [HOST] [IPU2  ]    421.254224 s:  Full  Q : Elements in Q =   0, Write Idx = 145, Read Idx = 145
 [HOST] [IPU2  ]    421.254346 s:  [VPE OUT1] Buffer Q Status,
 [HOST] [IPU2  ]    421.254407 s:  Empty Q : Elements in Q =   0, Write Idx =   0, Read Idx =   0
 [HOST] [IPU2  ]    421.254559 s:  Full  Q : Elements in Q =   0, Write Idx =   0, Read Idx =   0
 [HOST] [HOST  ]    421.256206 s:
 [HOST] [HOST  ]
Why?  I want to input  2  h264  video, can i do?
