I am using Dm357 platform,nandflash size is 128MB,when I am using Dm357 Nandflashwrite program burning,the program can't run,why?
whether I need to modify the program?
My board information as follows:
cpu:dm357
ddr:128MB
flash:128MB
cpu:dm357
ddr:128MB
flash:128MB
I am not too familiar with DM357 nandflashwrite program but we normally provide similar utilities in other platforms. The main point here is that the utilities we provide work with our EVMs; it would be impossible to add support for all NAND devices out there or ones that may be coming out in the future. If you are using the same NAND part as our EVM, then I would expect the utility to work; if you are using a different NAND part then you may need to modify the utility to suit your particular NAND device.
