Part Number: AM5728
Tool/software: Linux
Hello
I'm using am5728 based on beagleboard x15.
Where we removed sata,pcie,usb2
removed tree nodes from device tree still trying to boot but module loading give this error
Is it due to usb or any disabled peripherals.
Should i've to modify udev rules for the same.
I'm not able to detect mmc2 interface where eMMC connected in 8-bit mode.
Here is full log
Starting kernel ...
** 407 printk messages dropped ** [ 1.450102] No ATAGs?
[ 1.450440] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 1.450489] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 1.451187] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 1.451217] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 1.451942] OMAP DMA hardware revision 0.0
[ 1.494873] edma 43300000.edma: memcpy is disabled
[ 1.512414] edma 43300000.edma: TI EDMA DMA engine driver
[ 1.548597] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 1.551437] evm_5v0: supplied by main_12v0
[ 1.562665] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 1.563498] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 1.564551] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 1.565701] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 1.567006] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 1.567809] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 1.568725] iommu: Adding device 58820000.ipu to group 1
[ 1.569022] iommu: Adding device 55020000.ipu to group 2
[ 1.569539] iommu: Adding device 40800000.dsp to group 0
[ 1.570394] iommu: Adding device 41000000.dsp to group 3
[ 1.576456] palmas 0-0058: Irq flag is 0x00000008
[ 1.605322] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[ 1.609591] SMPS12: supplied by regulator-dummy
[ 1.613968] SMPS3: supplied by regulator-dummy
[ 1.618223] SMPS45: supplied by regulator-dummy
[ 1.622924] SMPS6: supplied by regulator-dummy
[ 1.626759] SMPS7: supplied by regulator-dummy
[ 1.630476] SMPS8: supplied by regulator-dummy
[ 1.634016] SMPS9: supplied by regulator-dummy
[ 1.636251] LDO1: supplied by regulator-dummy
[ 1.643989] LDO2: supplied by regulator-dummy
[ 1.653776] LDO3: supplied by regulator-dummy
[ 1.654148] random: fast init done
[ 1.663833] LDO4: supplied by regulator-dummy
[ 1.673906] LDO5: supplied by regulator-dummy
[ 1.676177] LDO6: supplied by regulator-dummy
[ 1.678476] LDO7: supplied by regulator-dummy
[ 1.680739] LDO8: supplied by regulator-dummy
[ 1.683078] LDO9: supplied by regulator-dummy
[ 1.694156] LDOLN: supplied by regulator-dummy
[ 1.704143] LDOUSB: supplied by regulator-dummy
[ 1.724180] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.724825] media: Linux media interface: v0.10
[ 1.724993] Linux video capture interface: v2.00
[ 1.725448] pps_core: LinuxPPS API ver. 1 registered
[ 1.725474] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.725555] PTP clock support registered
[ 1.725705] EDAC MC: Ver: 3.0.0
[ 1.727032] dmi: Firmware registration failed.
[ 1.728518] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 1.729682] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 1.730987] Advanced Linux Sound Architecture Driver Initialized.
[ 1.734525] clocksource: Switched to clocksource arch_sys_counter
[ 1.772709] NET: Registered protocol family 2
[ 1.774733] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.775382] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 1.777076] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.777574] UDP hash table entries: 512 (order: 3, 49152 bytes)
[ 1.777918] UDP-Lite hash table entries: 512 (order: 3, 49152 bytes)
[ 1.778568] NET: Registered protocol family 1
[ 1.780149] RPC: Registered named UNIX socket transport module.
[ 1.780184] RPC: Registered udp transport module.
[ 1.780209] RPC: Registered tcp transport module.
[ 1.780233] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.783155] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.783876] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 1.789301] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.831549] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.834928] NFS: Registering the id_resolver key type
[ 1.835137] Key type id_resolver registered
[ 1.835172] Key type id_legacy registered
[ 1.835315] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.838829] cryptomgr_test (37) used greatest stack depth: 6576 bytes left
[ 1.840620] cryptomgr_test (38) used greatest stack depth: 6264 bytes left
[ 1.842588] bounce: pool size: 64 pages
[ 1.842762] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.842839] io scheduler noop registered
[ 1.842866] io scheduler deadline registered
[ 1.844061] io scheduler cfq registered (default)
[ 1.844090] io scheduler mq-deadline registered
[ 1.844117] io scheduler kyber registered
[ 1.844256] cryptomgr_test (44) used greatest stack depth: 6104 bytes left
[ 1.859641] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 1.880398] vdd_3v3: supplied by regen1
[ 1.881127] aic_dvdd_fixed: supplied by vdd_3v3
[ 1.881478] vtt_fixed: supplied by smps3
[ 1.891434] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.903501] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 43, base_baud = 3000000) is a 8250
[ 2.379519] console [ttyS2] enabled
[ 2.388247] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.397189] DSS: OMAP DSS rev 6.1
[ 2.407098] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.417301] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.429737] tpd12s015: probe of encoder failed with error -2
[ 2.438428] connector-hdmi connector: failed to find video source
[ 2.486250] brd: module loaded
[ 2.519610] loop: module loaded
[ 2.528097] libphy: Fixed MDIO Bus: probed
[ 2.594603] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.602361] libphy: 48485000.mdio: probed
[ 2.611330] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 2.621178] kworker/u4:0 (51) used greatest stack depth: 5936 bytes left
[ 2.629859] cpsw 48484000.ethernet: Detected MACID = 10:ce:a9:bc:1b:ca
[ 2.636815] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.643220] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.648622] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 2.655866] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.671197] omap_rtc 48838000.rtc: registered as rtc2
[ 2.683265] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:
tps659038_rtc as rtc1
[ 2.698985] rtc-pcf85263 0-0051: Oscillator stop detected, date/time is not reliable.
[ 2.708169] rtc-pcf85263 0-0051: No century in NVRAM - assume 2000
[ 2.717348] rtc-pcf85263 0-0051: Oscillator stop detected, date/time is not reliable.
[ 2.725913] rtc-pcf85263 0-0051: rtc core: registered rtc-pcf85263 as rtc0
[ 2.732846] rtc-pcf85263 0-0051: PCF85263 RTC (irqpin=INTB irq=167)
[ 2.740342] i2c /dev entries driver
[ 2.747087] IR NEC protocol handler initialized
[ 2.751662] IR RC5(x/sz) protocol handler initialized
[ 2.756821] IR RC6 protocol handler initialized
[ 2.761392] IR JVC protocol handler initialized
[ 2.766023] IR Sony protocol handler initialized
[ 2.770682] IR SANYO protocol handler initialized
[ 2.775484] IR Sharp protocol handler initialized
[ 2.780232] IR MCE Keyboard/mouse protocol handler initialized
[ 2.786167] IR XMP protocol handler initialized
[ 2.798937] gpio-fan gpio_fan: GPIO fan initialized
[ 2.807704] tmp102 0-0048: initialized
[ 2.827653] sdhci: Secure Digital Host Controller Interface driver
[ 2.833872] sdhci: Copyright(c) Pierre Ossman
[ 2.839467] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.850668] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 2.857443] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 2.924778] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 2.972658] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.983018] mmc0: new high speed SDHC card at address 0001
[ 2.989994] mmcblk0: mmc0:0001 SD 3.72 GiB
[ 2.994568] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.007906] mmcblk0: p1 p2
[ 3.014272] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.039220] oprofile: using timer interrupt.
[ 3.045667] NET: Registered protocol family 10
[ 3.052117] Segment Routing with IPv6
[ 3.055991] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.063146] NET: Registered protocol family 17
[ 3.068187] Key type dns_resolver registered
[ 3.072642] omap_voltage_late_init: Voltage driver support not added
[ 3.079072] Power Management for TI OMAP4+ devices.
[ 3.084315] Registering SWP/SWPB emulation handler
[ 3.144207] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.153472] dmm 4e000000.dmm: initialized all PAT entries
[ 3.161455] connector-hdmi connector: failed to find video source
[ 3.182919] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 3.190817] asoc-simple-card sound0: ASoC: no DMI vendor name!
[ 3.202741] connector-hdmi connector: failed to find video source
[ 3.210480] rtc-pcf85263 0-0051: Oscillator stop detected, date/time is not reliable.
[ 3.218433] rtc-pcf85263 0-0051: hctosys: unable to read the hardware clock
[ 3.229283] net eth0: initializing cpsw version 1.15 (0)
[ 3.355619] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_
bus:phy_addr=48485000.mdio:01, irq=POLL)
[ 3.378403] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.473330] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 5.481549] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 5.504558] Sending DHCP requests ., OK
[ 5.548775] IP-Config: Got DHCP answer from 192.168.0.1, my address is 192.168.0.9
[ 5.556523] IP-Config: Complete:
[ 5.559778] device=eth0, hwaddr=10:ce:a9:bc:1b:ca, ipaddr=192.168.0.9, mask=255.255.255.0, gw=192.168.0.1
[ 5.569881] host=192.168.0.9, domain=, nis-domain=(none)
[ 5.576173] bootserver=0.0.0.0, rootserver=192.168.0.101, rootpath= nameserver0=203.187.193.66, namese
rver1=203.187.193.68
[ 5.589500] aic_dvdd_fixed: disabling
[ 5.593657] ldousb: disabling
[ 5.597367] ALSA device list:
[ 5.600359] #0: BeagleBoard-X15
[ 5.631677] VFS: Mounted root (nfs filesystem) on device 0:14.
[ 5.638629] devtmpfs: mounted
[ 5.646850] Freeing unused kernel memory: 4096K
[ 6.188197] systemd[1]: System time before build time, advancing clock.
[ 6.282050] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVIN
IT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy
=hybrid)
[ 6.304324] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[ 6.336731] systemd[1]: Set hostname to <am57xx-evm>.
[ 6.458469] systemd-debug-g (69) used greatest stack depth: 3520 bytes left
[ 7.159752] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.167777] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.265008] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.279203] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 7.315864] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.331209] systemd[1]: Mounting Kernel Debug File System...
[ 7.378215] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 7.416097] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.445267] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.489582] systemd[1]: Starting Load Kernel Modules...
[ OK ] Started Boot Process Profiler.
[ 7.550277] cryptodev: loading out-of-tree module taints kernel.
[ 7.571826] cryptodev: driver 1.9 loaded.
Starting Remount Root and Kernel File Systems...
[ OK ] Reached target Swap.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
Starting Create list of required st…ce nodes for the current kernel...
Mounting Temporary Directory (/tmp)...
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on udev Kernel Socket.
Mounting POSIX Message Queue File System...
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Reached target Paths.
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Remote File Systems.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
Starting udev Coldplug all Devices...
[ 8.447056] random: crng init done
[ 8.450497] random: 7 urandom warning(s) missed due to ratelimiting
Starting Create Static Device Nodes in /dev...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Mounting /media/ram...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ 9.485303] udevadm (91) used greatest stack depth: 2976 bytes left
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ 9.770893] systemd-journald[90]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ 10.844407] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 10.915111] remoteproc remoteproc0: 58820000.ipu is available
[ 10.936891] connector-hdmi connector: failed to find video source
[ 10.944791] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 10.953106] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 10.953362] remoteproc remoteproc0: powering up 58820000.ipu
[ 10.953594] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[ 10.953625] remoteproc remoteproc0: request_firmware failed: -2
[ 11.153578] remoteproc remoteproc1: 55020000.ipu is available
[ OK ] Started udev Coldplug all Devices.
[ OK [ 11.200479] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
] Reached target System Initialization.
[ 11.221822] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 11.222049] remoteproc remoteproc2: 40800000.dsp is available
[ 11.222842] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 11.223073] remoteproc remoteproc3: 41000000.dsp is available
[ 11.373494] remoteproc remoteproc1: powering up 55020000.ipu
[ OK ] Started Daily Cleanup of Temporary Directories.
[ 11.385209] remoteproc remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[ 11.410070] remoteproc remoteproc1: request_firmware failed: -2
[ 11.441341] connector-hdmi connector: failed to find video source
[ OK ] Listening on D-Bus System Message Bus Socket.[ 11.519647] remoteproc remoteproc2: Direct firmware load
for dra7-dsp1-fw.xe66 failed with error -2
[ 11.530154] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 11.530184] remoteproc remoteproc3: powering up 41000000.dsp
[ 11.530357] remoteproc remoteproc3: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[ 11.530379] remoteproc remoteproc3: request_firmware failed: -2
[ 11.654991] remoteproc remoteproc2: powering up 40800000.dsp
[ 11.655172] remoteproc remoteproc2: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[ 11.655197] remoteproc remoteproc2: request_firmware failed: -2
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ 11.859051] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
Starting sshd.socket.
[ 11.958012] omap-des 480a5000.des: will run requests pump with realtime priority
[ 12.004879] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[ 12.006782] connector-hdmi connector: failed to find video source
Starting Network Service...
[ OK ] Listening on RPCbind Server Activation Socket.
[ 12.236959] connector-hdmi connector: failed to find video source
[ 12.732167] connector-hdmi connector: failed to find video source
[ OK ] Listening on sshd.socket.
[ 12.809398] connector-hdmi connector: failed to find video source
[ OK ] Found device /dev/ttyS2.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 12.982305] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 13.019357] connector-hdmi connector: failed to find video source
[ 13.035670] vpe 489d0000.vpe: Device registered as /dev/video0
Starting rc.pvr.service...
[ OK ] Reached target Containers.
[ OK ] Started System Logging Service.
Starting Login Service...
[ 13.325303] connector-hdmi connector: failed to find video source
[ 13.370746] connector-hdmi connector: failed to find video source
[ OK ] Started Kernel Logging Service.
[[ 13.508079] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
OK ] Started Job spooling tools.
[ 13.532838] connector-hdmi connector: failed to find video source
[ OK ] Started D-Bus System Message Bus.
[ 13.743839] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.gpu on minor 0
[ 13.763057] connector-hdmi connector: failed to find video source
[ 13.774104] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 13.796210] connector-hdmi connector: failed to find video source
[ 13.811240] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 13.961957] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 13.978969] connector-hdmi connector: failed to find video source
[ 13.994823] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 13.995851] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 14.063175] connector-hdmi connector: failed to find video source
[ 14.233181] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 14.246615] connector-hdmi connector: failed to find video source
[ 14.248093] connector-hdmi connector: failed to find video source
[ 14.365193] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
[ 14.426455] connector-hdmi connector: failed to find video source
[ 14.755310] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
Starting Save/Restore Sound Card State...
Starting Print notice about GPLv3 packages...
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
Starting RPC Bind Service...
Starting TI IPC Daemon...
[ OK ] Started Network Service.
[ OK ] Started RPC Bind Service.
[ OK ] Started TI IPC Daemon.
[ 16.777692] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ OK ] Started rc.pvr.service.
[ 16.938313] EXT4-fs (mmcblk0p2): recovery complete
[ 16.959783] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Started Save/Restore Sound Card State.
[ 17.756211] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 17.775620] pruss 4b200000.pruss: creating PRU cores and other child platform devices
[ 17.813446] connector-hdmi connector: failed to find video source
[ 17.818977] pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 17.870887] connector-hdmi connector: failed to find video source
[ 17.901436] connector-hdmi connector: failed to find video source
[ 18.079100] connector-hdmi connector: failed to find video source
[ 18.108210] connector-hdmi connector: failed to find video source
[ 18.183230] remoteproc remoteproc4: 4b234000.pru is available
[ 18.242600] pru-rproc 4b234000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@34000 probed success
fully
[ 18.308911] usbcore: registered new interface driver usbfs
[ 18.310354] usbcore: registered new interface driver hub
[ 18.310596] usbcore: registered new device driver usb
[ 18.347717] connector-hdmi connector: failed to find video source
[ 18.367076] remoteproc remoteproc5: 4b238000.pru is available
[ 18.367253] pru-rproc 4b238000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@38000 probed success
fully
[ 18.369496] remoteproc remoteproc6: 4b2b4000.pru is available
[ 18.369700] pru-rproc 4b2b4000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@34000 probed success
fully
[ 18.377409] remoteproc remoteproc7: 4b2b8000.pru is available
[ 18.377587] pru-rproc 4b2b8000.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@38000 probed success
fully
[ 18.499751] connector-hdmi connector: failed to find video source
[ 18.558646] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 18.564296] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 18.639403] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[ 18.661757] xhci-hcd xhci-hcd.1.auto: irq 169, io mem 0x48890000
[ 18.693738] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 18.701616] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 18.715315] usb usb1: Product: xHCI Host Controller
[ 18.729416] usb usb1: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd
[ 18.737283] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 18.783327] hub 1-0:1.0: USB hub found
[ 18.801130] hub 1-0:1.0: 1 port detected
[ 18.826835] connector-hdmi connector: failed to find video source
[ 18.840194] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 18.849995] connector-hdmi connector: failed to find video source
[ 18.868791] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 18.885792] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 18.911899] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 18.936256] ------------[ cut here ]------------
[ 18.940922] WARNING: CPU: 0 PID: 55 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[ 18.950195] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during
Functional access
[ 18.961820] Modules linked in: xhci_plat_hcd(+) xhci_hcd usbcore pru_rproc pruss_intc dwc3 udc_core usb_common
pruss bc_example(O) snd_soc_omap_hdmi_audio omap_aes_driver omap_sham pruss_soc_bus pvrsrvkm(O) omap_wdt phy_omap_
usb2 ti_vpe ti_sc ti_csc ti_vpdma dwc3_omap at24 omap_des des_generic crypto_engine omap_crypto omap_remoteproc vi
rtio_rpmsg_bus rpmsg_core remoteproc sch_fq_codel cryptodev(O)
[ 18.997599] CPU: 0 PID: 55 Comm: kworker/0:2 Tainted: G O 4.14.79-gbde58ab01e #1
[ 19.006168] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 19.012303] Workqueue: pm pm_runtime_work
[ 19.016347] Backtrace:
[ 19.018828] [<c020bd08>] (dump_backtrace) from [<c020bfec>] (show_stack+0x18/0x1c)
[ 19.026441] r7:c126b8c8 r6:00000000 r5:600b0193 r4:c126b8c8
[ 19.032139] [<c020bfd4>] (show_stack) from [<c0979fe4>] (dump_stack+0xa0/0xcc)
[ 19.034658] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 19.034668] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 19.034676] usb usb2: Product: xHCI Host Controller
[ 19.034683] usb usb2: Manufacturer: Linux 4.14.79-gbde58ab01e xhci-hcd
[ 19.034691] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 19.069807] [<c0979f44>] (dump_stack) from [<c022c37c>] (__warn+0xec/0x104)
[ 19.076809] r9:c0562888 r8:00000093 r7:00000009 r6:c0bd6490 r5:00000000 r4:ee0bda40
[ 19.084597] [<c022c290>] (__warn) from [<c022c3d4>] (warn_slowpath_fmt+0x40/0x48)
[ 19.092121] r9:0000001b r8:eee418d0 r7:c0bd62e0 r6:00000000 r5:c0bd63bc r4:c0bd6460
[ 19.099910] [<c022c398>] (warn_slowpath_fmt) from [<c0562888>] (l3_interrupt_handler+0x254/0x370)
[ 19.108829] r3:eee41740 r2:c0bd6460
[ 19.112427] r4:80080003
[ 19.114986] [<c0562634>] (l3_interrupt_handler) from [<c029b310>] (__handle_irq_event_percpu+0x6c/0x138)
[ 19.124516] r10:c126cba6 r9:eee59a00 r8:00000017 r7:ee0bdb64 r6:00000000 r5:eee59a00
[ 19.132386] r4:eee41c40
[ 19.134942] [<c029b2a4>] (__handle_irq_event_percpu) from [<c029b400>] (handle_irq_event_percpu+0x24/0x60)
[ 19.144646] r10:ee0bdc28 r9:eec08400 r8:00000001 r7:00000000 r6:c120eb54 r5:eee59a00
[ 19.152518] r4:eee59a00
[ 19.155074] [<c029b3dc>] (handle_irq_event_percpu) from [<c029b47c>] (handle_irq_event+0x40/0x64)
[ 19.163993] r5:eee59a64 r4:eee59a00
[ 19.167595] [<c029b43c>] (handle_irq_event) from [<c029ee44>] (handle_fasteoi_irq+0xc0/0x174)
[ 19.176164] r7:00000000 r6:c120eb54 r5:eee59a64 r4:eee59a00
[ 19.181859] [<c029ed84>] (handle_fasteoi_irq) from [<c029a4bc>] (generic_handle_irq+0x2c/0x3c)
[ 19.190516] r7:00000000 r6:00000017 r5:00000000 r4:c10c70f4
[ 19.196211] [<c029a490>] (generic_handle_irq) from [<c029aa9c>] (__handle_domain_irq+0x84/0xf4)
[ 19.204959] [<c029aa18>] (__handle_domain_irq) from [<c0201580>] (gic_handle_irq+0x44/0x80)
[ 19.213354] r10:000002a0 r9:ee0bc000 r8:fa213000 r7:fa212000 r6:ee0bdc28 r5:fa21200c
[ 19.221225] r4:c120892c r3:ee0bdc28
[ 19.224825] [<c020153c>] (gic_handle_irq) from [<c020cd3c>] (__irq_svc+0x5c/0x94)
[ 19.232348] Exception stack(0xee0bdc28 to 0xee0bdc70)
[ 19.237430] dc20: 00000001 c16c29c0 00000000 ee5f8000 800b0113 ee25e238
[ 19.245652] dc40: ffffffff 000002a0 fffffffc 4e00ffe9 000002a0 ee0bdc8c 00000002 ee0bdc78
[ 19.253872] dc60: c028c3d0 c0995d70 200b0113 ffffffff
[ 19.258955] r9:ee0bc000 r8:fffffffc r7:ee0bdc5c r6:ffffffff r5:200b0113 r4:c0995d70
[ 19.266769] [<c0995cf8>] (_raw_spin_unlock_irqrestore) from [<bf2e5208>] (xhci_bus_suspend+0x264/0x280 [xhci_hc
d])
[ 19.277171] r5:ee25e000 r4:0a0002a0
[ 19.280834] [<bf2e4fa4>] (xhci_bus_suspend [xhci_hcd]) from [<bf299280>] (hcd_bus_suspend+0x5c/0x10c [usbcore])
[ 19.290975] r10:00000402 r9:bf2acee4 r8:00000001 r7:00000001 r6:ed68f000 r5:ee181800
[ 19.298846] r4:ee25e000
[ 19.301477] [<bf299224>] (hcd_bus_suspend [usbcore]) from [<bf2a776c>] (generic_suspend+0x54/0x58 [usbcore])
[ 19.311356] r7:00000000 r6:ed68f000 r5:ffffffff r4:ee181800
[ 19.317126] [<bf2a7718>] (generic_suspend [usbcore]) from [<bf29dc44>] (usb_suspend_both+0x188/0x1ec [usbcore])
[ 19.327342] [<bf29dabc>] (usb_suspend_both [usbcore]) from [<bf29ea20>] (usb_runtime_suspend+0x30/0x68 [usbcore
[ 19.337659] r10:c1205100 r9:00000000 r8:bf29e9f0 r7:00000000 r6:c1205100 r5:ee181800
[ 19.345530] r4:ee181870
[ 19.348129] [<bf29e9f0>] (usb_runtime_suspend [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 19.357484] r5:ee181924 r4:ee181870
[ 19.361084] [<c068366c>] (__rpm_callback) from [<c06838b8>] (rpm_callback+0x28/0x88)
[ 19.368868] r10:c1205100 r9:00000000 r8:00000008 r7:00000000 r6:c1205100 r5:bf29e9f0
[ 19.376738] r4:ee181870
[ 19.379291] [<c0683890>] (rpm_callback) from [<c0683b80>] (rpm_suspend+0x120/0x4e0)
[ 19.386989] r7:00000000 r6:c1205100 r5:bf29e9f0 r4:ee181870
[ 19.392684] [<c0683a60>] (rpm_suspend) from [<c068491c>] (__pm_runtime_suspend+0x64/0x88)
[ 19.400905] r10:00000001 r9:00000000 r8:bf29ea74 r7:600b0113 r6:ee181924 r5:00000008
[ 19.408776] r4:ee181870
[ 19.411372] [<c06848b8>] (__pm_runtime_suspend) from [<bf29eaa0>] (usb_runtime_idle+0x2c/0x34 [usbcore])
[ 19.420901] r7:00000000 r6:00000002 r5:ee181924 r4:ee181870
[ 19.426635] [<bf29ea74>] (usb_runtime_idle [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 19.435728] r5:ee181924 r4:ee181870
[ 19.439327] [<c068366c>] (__rpm_callback) from [<c06839f8>] (rpm_idle+0xe0/0x148)
[ 19.446850] r10:00000001 r9:00000000 r8:ee1819ec r7:00000000 r6:00000002 r5:00000000
[ 19.454721] r4:ee181870
[ 19.457275] [<c0683918>] (rpm_idle) from [<c0684380>] (pm_runtime_work+0x88/0x98)
[ 19.464798] r9:00000000 r8:00000000 r7:ef4d4800 r6:ef4cf100 r5:ee181924 r4:ee1819c4
[ 19.472593] [<c06842f8>] (pm_runtime_work) from [<c024818c>] (process_one_work+0x1e0/0x498)
[ 19.480987] r5:ee098400 r4:ee1819c4
[ 19.484587] [<c0247fac>] (process_one_work) from [<c02484a0>] (worker_thread+0x5c/0x54c)
[ 19.492722] r10:c1205100 r9:00000008 r8:ffffe000 r7:ef4cf13c r6:ee098418 r5:ef4cf100
[ 19.500592] r4:ee098400
[ 19.503147] [<c0248444>] (worker_thread) from [<c024f7bc>] (kthread+0x16c/0x170)
[ 19.510586] r10:eec97e6c r9:c0248444 r8:ee098400 r7:ee0bc000 r6:00000000 r5:ee099280
[ 19.518457] r4:eeded980
[ 19.521012] [<c024f650>] (kthread) from [<c0207eac>] (ret_from_fork+0x14/0x28)
[ 19.528275] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024f650
[ 19.536145] r4:ee099280
[ 19.538697] ---[ end trace 9f8961d6fe60419f ]---
[ 19.545180] hub 2-0:1.0: USB hub found
[ 19.545500] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[ 19.545512] pgd = c0003000
[ 19.545519] [00000000] *pgd=80000080004003, *pmd=00000000
[ 19.545535] Internal error: : 1211 [#1] PREEMPT SMP ARM
[ 19.545540] Modules linked in: xhci_plat_hcd(+) xhci_hcd usbcore pru_rproc pruss_intc dwc3 udc_core usb_common
[ 19.545650] CPU: 0 PID: 55 Comm: kworker/0:2 Tainted: G W O 4.14.79-gbde58ab01e #1
[ 19.545654] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 19.545663] Workqueue: pm pm_runtime_work
[ 19.545671] task: ee5f8000 task.stack: ee0bc000
[ 19.545697] PC is at xhci_hub_status_data+0xa0/0x1fc [xhci_hcd]
[ 19.545706] LR is at put_lock_stats.constprop.22+0x14/0x40
[ 19.545711] pc : [<bf2e4e48>] lr : [<c0289718>] psr: 000f0093
[ 19.545715] sp : ee0bdc98 ip : ee0bdc18 fp : ee0bdce4
[ 19.545720] r10: ee25e6e4 r9 : bf2acee4 r8 : ee25e000
[ 19.545725] r7 : 00000000 r6 : ee25e000 r5 : 00000001 r4 : ee0bdcea
[ 19.545729] r3 : fa890420 r2 : 00000000 r1 : 00000000 r0 : 000f0013
[ 19.545734] Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 19.545739] Control: 30c5387d Table: ae20fd80 DAC: fffffffd
[ 19.545744] Process kworker/0:2 (pid: 55, stack limit = 0xee0bc210)
[ 19.545749] Stack: (0xee0bdc98 to 0xee0be000)
[ 19.545753] dc80: ee25e000 ee0bdcea
[ 19.545759] dca0: 000f0013 ee25e238 000006e4 00000001 00000000 ed9880c0 00000001 ee25e000
[ 19.545764] dcc0: ee181800 00000000 00000001 00000001 bf2acee4 00000402 ee0bdd0c ee0bdce8
[ 19.545770] dce0: bf299310 bf2e4db4 ee008000 00000006 ee181800 ffffffff ed68f000 00000000
[ 19.545776] dd00: ee0bdd1c ee0bdd10 bf2a776c bf299230 ee0bdd5c ee0bdd20 bf29dc44 bf2a7724
[ 19.545782] dd20: ee0bdd4c 00000400 c028c508 c028c384 ee181924 ee181870 ee181800 c1205100
[ 19.545788] dd40: 00000000 bf29e9f0 00000000 c1205100 ee0bdd74 ee0bdd60 bf29ea20 bf29dac8
[ 19.545793] dd60: ee181870 ee181924 ee0bddac ee0bdd78 c0683734 bf29e9fc c0288c94 c0288b80
[ 19.545799] dd80: ee181870 ee181870 bf29e9f0 c1205100 00000000 00000008 00000000 c1205100
[ 19.545805] dda0: ee0bddcc ee0bddb0 c06838b8 c0683678 ee181870 bf29e9f0 c1205100 00000000
[ 19.545811] ddc0: ee0bde24 ee0bddd0 c0683b80 c068389c c068490c c027a5bc ffffe000 00000008
[ 19.545816] dde0: 00000000 00000001 ee0bde24 ee0bddf8 c0995b38 c028a1c0 00000001 ee181870
[ 19.545821] de00: 00000008 ee181924 600b0113 bf29ea74 00000000 00000001 ee0bde44 ee0bde28
[ 19.545827] de20: c068491c c0683a6c ee181870 ee181924 00000002 00000000 ee0bde5c ee0bde48
[ 19.545833] de40: bf29eaa0 c06848c4 ee181870 ee181924 ee0bde94 ee0bde60 c0683734 bf29ea80
[ 19.545839] de60: c068271c c0288c54 ee181870 ee181870 00000000 00000002 00000000 ee1819ec
[ 19.545844] de80: 00000000 00000001 ee0bdebc ee0bde98 c06839f8 c0683678 ee1819c4 ee181924
[ 19.545849] dea0: ef4cf100 ef4d4800 00000000 00000000 ee0bded4 ee0bdec0 c0684380 c0683924
[ 19.545855] dec0: ee1819c4 ee098400 ee0bdf34 ee0bded8 c024818c c0684304 00000001 00000000
[ 19.545861] dee0: c0248118 ef4cf100 ef4cf13c 00000000 c1a00018 c16f6fe0 00000000 c0bf5ef0
[ 19.545867] df00: 00000000 00000000 00000001 ee098400 ef4cf100 ee098418 ef4cf13c ffffe000
[ 19.545873] df20: 00000008 c1205100 ee0bdf74 ee0bdf38 c02484a0 c0247fb8 ee099280 c0baa328
[ 19.545878] df40: c126cac9 ef4cf100 c0248444 eeded980 ee099280 00000000 ee0bc000 ee098400
[ 19.545883] df60: c0248444 eec97e6c ee0bdfac ee0bdf78 c024f7bc c0248450 eeded9c0 eeded9c0
[ 19.545889] df80: 00000000 ee099280 c024f650 00000000 00000000 00000000 00000000 00000000
[ 19.545894] dfa0: 00000000 ee0bdfb0 c0207eac c024f65c 00000000 00000000 00000000 00000000
[ 19.545899] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 19.545904] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 19.545907] Backtrace:
[ 19.545992] [<bf2e4da8>] (xhci_hub_status_data [xhci_hcd]) from [<bf299310>] (hcd_bus_suspend+0xec/0x10c [usbco
re])
[ 19.546000] r10:00000402 r9:bf2acee4 r8:00000001 r7:00000001 r6:00000000 r5:ee181800
[ 19.546004] r4:ee25e000
[ 19.546085] [<bf299224>] (hcd_bus_suspend [usbcore]) from [<bf2a776c>] (generic_suspend+0x54/0x58 [usbcore])
[ 19.546090] r7:00000000 r6:ed68f000 r5:ffffffff r4:ee181800
[ 19.546169] [<bf2a7718>] (generic_suspend [usbcore]) from [<bf29dc44>] (usb_suspend_both+0x188/0x1ec [usbcore])
[ 19.546249] [<bf29dabc>] (usb_suspend_both [usbcore]) from [<bf29ea20>] (usb_runtime_suspend+0x30/0x68 [usbcore
[ 19.546255] r10:c1205100 r9:00000000 r8:bf29e9f0 r7:00000000 r6:c1205100 r5:ee181800
[ 19.546259] r4:ee181870
[ 19.546303] [<bf29e9f0>] (usb_runtime_suspend [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 19.546307] r5:ee181924 r4:ee181870
[ 19.546314] [<c068366c>] (__rpm_callback) from [<c06838b8>] (rpm_callback+0x28/0x88)
[ 19.546320] r10:c1205100 r9:00000000 r8:00000008 r7:00000000 r6:c1205100 r5:bf29e9f0
[ 19.546324] r4:ee181870
[ 19.546330] [<c0683890>] (rpm_callback) from [<c0683b80>] (rpm_suspend+0x120/0x4e0)
[ 19.546335] r7:00000000 r6:c1205100 r5:bf29e9f0 r4:ee181870
[ 19.546343] [<c0683a60>] (rpm_suspend) from [<c068491c>] (__pm_runtime_suspend+0x64/0x88)
[ 19.546349] r10:00000001 r9:00000000 r8:bf29ea74 r7:600b0113 r6:ee181924 r5:00000008
[ 19.546352] r4:ee181870
[ 19.546395] [<c06848b8>] (__pm_runtime_suspend) from [<bf29eaa0>] (usb_runtime_idle+0x2c/0x34 [usbcore])
[ 19.546400] r7:00000000 r6:00000002 r5:ee181924 r4:ee181870
[ 19.546444] [<bf29ea74>] (usb_runtime_idle [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 19.546448] r5:ee181924 r4:ee181870
[ 19.546455] [<c068366c>] (__rpm_callback) from [<c06839f8>] (rpm_idle+0xe0/0x148)
[ 19.546460] r10:00000001 r9:00000000 r8:ee1819ec r7:00000000 r6:00000002 r5:00000000
[ 19.546464] r4:ee181870
[ 19.546471] [<c0683918>] (rpm_idle) from [<c0684380>] (pm_runtime_work+0x88/0x98)
[ 19.546477] r9:00000000 r8:00000000 r7:ef4d4800 r6:ef4cf100 r5:ee181924 r4:ee1819c4
[ 19.546485] [<c06842f8>] (pm_runtime_work) from [<c024818c>] (process_one_work+0x1e0/0x498)
[ 19.546490] r5:ee098400 r4:ee1819c4
[ 19.546498] [<c0247fac>] (process_one_work) from [<c02484a0>] (worker_thread+0x5c/0x54c)
[ 19.546503] r10:c1205100 r9:00000008 r8:ffffe000 r7:ef4cf13c r6:ee098418 r5:ef4cf100
[ 19.546507] r4:ee098400
[ 19.546514] [<c0248444>] (worker_thread) from [<c024f7bc>] (kthread+0x16c/0x170)
[ 19.546520] r10:eec97e6c r9:c0248444 r8:ee098400 r7:ee0bc000 r6:00000000 r5:ee099280
[ 19.546524] r4:eeded980
[ 19.546532] [<c024f650>] (kthread) from [<c0207eac>] (ret_from_fork+0x14/0x28)
[ 19.546538] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024f650
[ 19.546541] r4:ee099280
[ 19.546548] Code: e5931000 f57ff04f e3710001 0a000054 (e28aab02)
[ 19.546565] ---[ end trace 9f8961d6fe6041a0 ]---
[ 19.546571] Kernel panic - not syncing: Fatal exception
[ 19.548954] CPU1: stopping
[ 19.548960] CPU: 1 PID: 133 Comm: systemd-udevd Tainted: G D W O 4.14.79-gbde58ab01e #1
[ 19.548964] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 19.548966] Backtrace:
[ 19.548978] [<c020bd08>] (dump_backtrace) from [<c020bfec>] (show_stack+0x18/0x1c)
[ 19.548984] r7:c126b8c8 r6:00000000 r5:60000193 r4:c126b8c8
[ 19.548992] [<c020bfd4>] (show_stack) from [<c0979fe4>] (dump_stack+0xa0/0xcc)
[ 19.548999] [<c0979f44>] (dump_stack) from [<c020e888>] (handle_IPI+0x1dc/0x1f0)
[ 19.549005] r9:ed879620 r8:00000001 r7:00000000 r6:00000004 r5:c10c70f4 r4:c10c70f4
[ 19.549012] [<c020e6ac>] (handle_IPI) from [<c02015b8>] (gic_handle_irq+0x7c/0x80)
[ 19.549017] r9:ed878000 r8:fa213000 r7:fa212000 r6:ed879620 r5:fa21200c r4:c120892c
[ 19.549024] [<c020153c>] (gic_handle_irq) from [<c020cd3c>] (__irq_svc+0x5c/0x94)
[ 19.549028] Exception stack(0xed879620 to 0xed879668)
[ 19.549033] 9620: c0298afc 2e578000 00000000 20000113 00000000 0000002a 00000000 c19c370c
[ 19.549039] 9640: c19c3280 00000000 c19c2970 ed8796cc ed879660 ed879670 c028c604 c0298b04
[ 19.549042] 9660: 60000113 ffffffff
[ 19.549048] r9:ed878000 r8:c19c3280 r7:ed879654 r6:ffffffff r5:60000113 r4:c0298b04
[ 19.549057] [<c0298744>] (console_unlock) from [<c0298cf4>] (vprintk_emit+0xd4/0x128)
[ 19.549062] r10:ed8797ec r9:00000021 r8:00000006 r7:ed879720 r6:0000001a r5:00000000
[ 19.549065] r4:60000113
[ 19.549074] [<c0298c20>] (vprintk_emit) from [<c0673c54>] (dev_vprintk_emit+0x10c/0x1c8)
[ 19.549080] r10:ed8797ec r9:c0bf46bc r8:00000006 r7:bf2acfac r6:ed879720 r5:ed49ec20
[ 19.549083] r4:0000000e
[ 19.549089] [<c0673b48>] (dev_vprintk_emit) from [<c0673d38>] (dev_printk_emit+0x28/0x30)
[ 19.549095] r10:00000000 r9:ed49ec00 r8:ed49ec20 r7:ed855bc8 r6:00009068 r5:ee186870
[ 19.549098] r4:ed49ec20
[ 19.549104] [<c0673d14>] (dev_printk_emit) from [<c0673dd8>] (__dev_printk+0x54/0x94)
[ 19.549108] r3:bf2ac580 r2:c0bf46bc
[ 19.549115] [<c0673d84>] (__dev_printk) from [<c0674208>] (_dev_info+0x40/0x48)
[ 19.549165] [<c06741cc>] (_dev_info) from [<bf295440>] (hub_probe+0xb4/0x98c [usbcore])
[ 19.549169] r3:ffffff81 r2:ed8556c0 r1:bf2ac3f0
[ 19.549250] [<bf29538c>] (hub_probe [usbcore]) from [<bf29e864>] (usb_probe_interface+0xe4/0x270 [usbcore])
[ 19.549255] r10:00000000 r9:bf2aa710 r8:ed49ec00 r7:ee186800 r6:bf2b0160 r5:ee186870
[ 19.549259] r4:ed49ec20
[ 19.549304] [<bf29e780>] (usb_probe_interface [usbcore]) from [<c0678760>] (driver_probe_device.part.1+0x2b4/0x
3c0)
[ 19.549310] r10:c19fffac r9:00000000 r8:00000023 r7:00000000 r6:bf2b0160 r5:c19fffa8
[ 19.549313] r4:ed49ec20
[ 19.549321] [<c06784ac>] (driver_probe_device.part.1) from [<c0678a28>] (__device_attach_driver+0xb0/0x12c)
[ 19.549326] r10:c19fff64 r9:bf2b0328 r8:00000000 r7:ed879958 r6:00000001 r5:bf2b0160
[ 19.549330] r4:ed49ec20
[ 19.549337] [<c0678978>] (__device_attach_driver) from [<c06767d0>] (bus_for_each_drv+0x4c/0x9c)
[ 19.549342] r7:00000001 r6:c0678978 r5:ed879958 r4:00000000
[ 19.549349] [<c0676784>] (bus_for_each_drv) from [<c0678418>] (__device_attach+0xbc/0x138)
[ 19.549353] r6:ed49ec20 r5:ed49ec54 r4:ed49ec20
[ 19.549360] [<c067835c>] (__device_attach) from [<c0678bd8>] (device_initial_probe+0x14/0x18)
[ 19.549365] r7:ee186870 r6:ed49ec20 r5:bf2b0340 r4:ed49ec28
[ 19.549372] [<c0678bc4>] (device_initial_probe) from [<c0677814>] (bus_probe_device+0x90/0x98)
[ 19.549379] [<c0677784>] (bus_probe_device) from [<c06758b4>] (device_add+0x3c4/0x5a8)
[ 19.549384] r7:ee186870 r6:00000000 r5:ed49ec20 r4:ed49ec28
[ 19.549426] [<c06754f0>] (device_add) from [<bf29c72c>] (usb_set_configuration+0x49c/0x814 [usbcore])
[ 19.549432] r10:ed99984c r9:ed999850 r8:ee186870 r7:ed999850 r6:ee186800 r5:bf2accf0
[ 19.549435] r4:ed49ec00
[ 19.549514] [<bf29c290>] (usb_set_configuration [usbcore]) from [<bf2a797c>] (generic_probe+0x34/0x80 [usbcore]
[ 19.549519] r10:c19fffac r9:00000000 r8:00000023 r7:00000000 r6:bf2b0ef0 r5:00000001
[ 19.549523] r4:ee186800
[ 19.549602] [<bf2a7948>] (generic_probe [usbcore]) from [<bf29e768>] (usb_probe_device+0x2c/0x44 [usbcore])
[ 19.549605] r5:bf2b0ef0 r4:ee186800
[ 19.549649] [<bf29e73c>] (usb_probe_device [usbcore]) from [<c0678760>] (driver_probe_device.part.1+0x2b4/0x3c0
[ 19.549654] r5:c19fffa8 r4:ee186870
[ 19.549661] [<c06784ac>] (driver_probe_device.part.1) from [<c0678a28>] (__device_attach_driver+0xb0/0x12c)
[ 19.549666] r10:c19fff64 r9:bf2b0000 r8:00000000 r7:ed879b40 r6:00000001 r5:bf2b0ef0
[ 19.549669] r4:ee186870
[ 19.549677] [<c0678978>] (__device_attach_driver) from [<c06767d0>] (bus_for_each_drv+0x4c/0x9c)
[ 19.549681] r7:00000001 r6:c0678978 r5:ed879b40 r4:00000000
[ 19.549688] [<c0676784>] (bus_for_each_drv) from [<c0678418>] (__device_attach+0xbc/0x138)
[ 19.549693] r6:ee186870 r5:ee1868a4 r4:ee186870
[ 19.549700] [<c067835c>] (__device_attach) from [<c0678bd8>] (device_initial_probe+0x14/0x18)
[ 19.549704] r7:ed49f010 r6:ee186870 r5:bf2b0340 r4:ee186878
[ 19.549711] [<c0678bc4>] (device_initial_probe) from [<c0677814>] (bus_probe_device+0x90/0x98)
[ 19.549718] [<c0677784>] (bus_probe_device) from [<c06758b4>] (device_add+0x3c4/0x5a8)
[ 19.549723] r7:ed49f010 r6:00000000 r5:ee186870 r4:ee186878
[ 19.549765] [<c06754f0>] (device_add) from [<bf293358>] (usb_new_device+0x258/0x420 [usbcore])
[ 19.549771] r10:ed49f010 r9:00000001 r8:ee186800 r7:000000a9 r6:ed8554c0 r5:ee186870
[ 19.549774] r4:ee186800
[ 19.549853] [<bf293100>] (usb_new_device [usbcore]) from [<bf297710>] (usb_add_hcd+0x560/0x7f8 [usbcore])
[ 19.549858] r10:ed49f010 r9:00000001 r8:ee186800 r7:000000a9 r6:00000000 r5:ed748124
[ 19.549861] r4:ed748000
[ 19.549910] [<bf2971b0>] (usb_add_hcd [usbcore]) from [<bf2f97a0>] (xhci_plat_probe+0x5a0/0x808 [xhci_plat_hcd]
[ 19.549915] r10:fffffffe r9:ee25e000 r8:ee25e000 r7:000000a9 r6:ed49f010 r5:ed49f000
[ 19.549919] r4:ed8b2810
[ 19.549929] [<bf2f9200>] (xhci_plat_probe [xhci_plat_hcd]) from [<c067a520>] (platform_drv_probe+0x58/0xb4)
[ 19.549934] r10:c19fffac r9:00000000 r8:00000021 r7:fffffdfb r6:bf2fb014 r5:ffffffed
[ 19.549938] r4:ed49f010
[ 19.549945] [<c067a4c8>] (platform_drv_probe) from [<c0678760>] (driver_probe_device.part.1+0x2b4/0x3c0)
[ 19.549949] r7:00000000 r6:bf2fb014 r5:c19fffa8 r4:ed49f010
[ 19.549957] [<c06784ac>] (driver_probe_device.part.1) from [<c0678954>] (__driver_attach+0xe8/0x10c)
[ 19.549962] r10:ed6e6db0 r9:bf2fb188 r8:00000001 r7:eda7fd80 r6:bf2fb014 r5:ed49f010
[ 19.549965] r4:ed49f044
[ 19.549973] [<c067886c>] (__driver_attach) from [<c0676710>] (bus_for_each_dev+0x54/0xa4)
[ 19.549977] r7:eda7fd80 r6:c067886c r5:bf2fb014 r4:00000000
[ 19.549984] [<c06766bc>] (bus_for_each_dev) from [<c0678080>] (driver_attach+0x24/0x28)
[ 19.549988] r6:00000000 r5:c1241ee0 r4:bf2fb014
[ 19.549995] [<c067805c>] (driver_attach) from [<c0677a40>] (bus_add_driver+0x100/0x234)
[ 19.550003] [<c0677940>] (bus_add_driver) from [<c067946c>] (driver_register+0x80/0xfc)
[ 19.550008] r7:ed740000 r6:bf2fe000 r5:00000000 r4:bf2fb014
[ 19.550014] [<c06793ec>] (driver_register) from [<c067a478>] (__platform_driver_register+0x48/0x50)
[ 19.550018] r5:00000000 r4:c1241ee0
[ 19.550027] [<c067a430>] (__platform_driver_register) from [<bf2fe034>] (xhci_plat_init+0x34/0x1000 [xhci_plat_
hcd])
[ 19.550031] r5:00000000 r4:ffffe000
[ 19.550040] [<bf2fe000>] (xhci_plat_init [xhci_plat_hcd]) from [<c0201b9c>] (do_one_initcall+0x4c/0x174)
[ 19.550048] [<c0201b50>] (do_one_initcall) from [<c02d2e44>] (do_init_module+0x68/0x20c)
[ 19.550052] r8:00000001 r7:ed740000 r6:ed6e6d80 r5:00000001 r4:bf2fb140
[ 19.550058] [<c02d2ddc>] (do_init_module) from [<c02d1cb8>] (load_module+0x204c/0x25f0)
[ 19.550062] r7:bf2fb140 r6:ed6e6d80 r5:00000001 r4:ed879f40
[ 19.550068] [<c02cfc6c>] (load_module) from [<c02d246c>] (SyS_finit_module+0xa4/0xbc)
[ 19.550074] r10:0000017b r9:ed878000 r8:c0207fc4 r7:0000017b r6:b6efa0c4 r5:00000010
[ 19.550077] r4:00000000
[ 19.550084] [<c02d23c8>] (SyS_finit_module) from [<c0207e00>] (ret_fast_syscall+0x0/0x28)
[ 19.550088] r6:00000000 r5:00000001 r4:00000000
[ 20.933342] ---[ end Kernel panic - not syncing: Fatal exception
[ 20.939425] ------------[ cut here ]------------
[ 20.944071] WARNING: CPU: 0 PID: 55 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[ 20.953333] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Read): Data Access in User mode during
Functional access
[ 20.964946] Modules linked in: xhci_plat_hcd(+) xhci_hcd usbcore pru_rproc pruss_intc dwc3 udc_core usb_common
[ 21.000571] CPU: 0 PID: 55 Comm: kworker/0:2 Tainted: G D W O 4.14.79-gbde58ab01e #1
[ 21.009132] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 21.015254] Workqueue: pm pm_runtime_work
[ 21.019286] Backtrace:
[ 21.021752] [<c020bd08>] (dump_backtrace) from [<c020bfec>] (show_stack+0x18/0x1c)
[ 21.029356] r7:c126b8c8 r6:00000000 r5:600f0193 r4:c126b8c8
[ 21.035042] [<c020bfd4>] (show_stack) from [<c0979fe4>] (dump_stack+0xa0/0xcc)
[ 21.042302] [<c0979f44>] (dump_stack) from [<c022c37c>] (__warn+0xec/0x104)
[ 21.049296] r9:c0562888 r8:00000093 r7:00000009 r6:c0bd6490 r5:00000000 r4:ee0bd7b8
[ 21.057076] [<c022c290>] (__warn) from [<c022c3d4>] (warn_slowpath_fmt+0x40/0x48)
[ 21.064594] r9:0000001b r8:eee418d0 r7:c0bd62e0 r6:00000002 r5:c0bd63bc r4:c0bd6460
[ 21.072374] [<c022c398>] (warn_slowpath_fmt) from [<c0562888>] (l3_interrupt_handler+0x254/0x370)
[ 21.081286] r3:eee41740 r2:c0bd6460
[ 21.084876] r4:80080003
[ 21.087426] [<c0562634>] (l3_interrupt_handler) from [<c029b310>] (__handle_irq_event_percpu+0x6c/0x138)
[ 21.096950] r10:c126cba6 r9:eee59a00 r8:00000017 r7:ee0bd8dc r6:00000000 r5:eee59a00
[ 21.104814] r4:eee41c40
[ 21.107363] [<c029b2a4>] (__handle_irq_event_percpu) from [<c029b400>] (handle_irq_event_percpu+0x24/0x60)
[ 21.117061] r10:ee0bd9a0 r9:eec08400 r8:00000001 r7:ee0bdac8 r6:c120eb54 r5:eee59a00
[ 21.124925] r4:eee59a00
[ 21.127473] [<c029b3dc>] (handle_irq_event_percpu) from [<c029b47c>] (handle_irq_event+0x40/0x64)
[ 21.136385] r5:eee59a64 r4:eee59a00
[ 21.139979] [<c029b43c>] (handle_irq_event) from [<c029ee44>] (handle_fasteoi_irq+0xc0/0x174)
[ 21.148542] r7:ee0bdac8 r6:c120eb54 r5:eee59a64 r4:eee59a00
[ 21.154228] [<c029ed84>] (handle_fasteoi_irq) from [<c029a4bc>] (generic_handle_irq+0x2c/0x3c)
[ 21.162879] r7:ee0bdac8 r6:00000017 r5:00000000 r4:c10c70f4
[ 21.168567] [<c029a490>] (generic_handle_irq) from [<c029aa9c>] (__handle_domain_irq+0x84/0xf4)
[ 21.177306] [<c029aa18>] (__handle_domain_irq) from [<c0201580>] (gic_handle_irq+0x44/0x80)
[ 21.185696] r10:ffffe000 r9:ee0bc000 r8:fa213000 r7:fa212000 r6:ee0bd9a0 r5:fa21200c
[ 21.193559] r4:c120892c r3:ee0bd9a0
[ 21.197152] [<c020153c>] (gic_handle_irq) from [<c020cd3c>] (__irq_svc+0x5c/0x94)
[ 21.204668] Exception stack(0xee0bd9a0 to 0xee0bd9e8)
[ 21.209743] d9a0: c02016a4 c0bbc410 c1277bc0 00000000 00000002 ee0bc000 c0232628 00000000
[ 21.217959] d9c0: 00000001 eec08400 ffffe000 ee0bda54 ee0bd9e0 ee0bd9f0 c028c604 c02016a8
[ 21.226171] d9e0: 600f0113 ffffffff
[ 21.229677] r9:ee0bc000 r8:00000001 r7:ee0bd9d4 r6:ffffffff r5:600f0113 r4:c02016a8
[ 21.237457] [<c02015c0>] (__do_softirq) from [<c0232628>] (irq_exit+0xe0/0x124)
[ 21.244800] r10:ee0bdac8 r9:eec08400 r8:00000001 r7:00000000 r6:00000013 r5:00000000
[ 21.252663] r4:c1277bc0
[ 21.255211] [<c0232548>] (irq_exit) from [<c029aaa0>] (__handle_domain_irq+0x88/0xf4)
[ 21.263075] r5:00000000 r4:c10c70f4
[ 21.266668] [<c029aa18>] (__handle_domain_irq) from [<c0201580>] (gic_handle_irq+0x44/0x80)
[ 21.275058] r10:00001211 r9:ee0bc000 r8:fa213000 r7:fa212000 r6:ee0bdac8 r5:fa21200c
[ 21.282923] r4:c120892c r3:ee0bdac8
[ 21.286515] [<c020153c>] (gic_handle_irq) from [<c020cd3c>] (__irq_svc+0x5c/0x94)
[ 21.294030] Exception stack(0xee0bdac8 to 0xee0bdb10)
[ 21.299105] dac0: c022c668 00000000 00000001 00000000 c1277760 00000000
[ 21.307320] dae0: ee0bdc48 00000000 ee5f8000 ffffe000 00001211 ee0bdb34 ee0bdb08 ee0bdb18
[ 21.315532] db00: c028c604 c022c66c 600f0113 ffffffff
[ 21.320607] r9:ee0bc000 r8:ee5f8000 r7:ee0bdafc r6:ffffffff r5:600f0113 r4:c022c66c
[ 21.328387] [<c022c458>] (panic) from [<c020c270>] (die+0x280/0x344)
[ 21.334770] r3:00000001 r2:00000001 r1:ee5f8000 r0:c0ba1798
[ 21.340454] r7:0000000b
[ 21.343000] [<c020bff0>] (die) from [<c020c354>] (arm_notify_die+0x20/0x60)
[ 21.349994] r10:ee25e6e4 r9:ee0bc000 r8:ee0bdc48 r7:00000000 r6:00000007 r5:00001211
[ 21.357857] r4:c120e3e8
[ 21.360404] [<c020c334>] (arm_notify_die) from [<c0201404>] (do_DataAbort+0xb4/0xb8)
[ 21.368183] [<c0201350>] (do_DataAbort) from [<c020ccb4>] (__dabt_svc+0x54/0x80)
[ 21.375611] Exception stack(0xee0bdc48 to 0xee0bdc90)
[ 21.380686] dc40: 000f0013 00000000 00000000 fa890420 ee0bdcea 00000001
[ 21.388901] dc60: ee25e000 00000000 ee25e000 bf2acee4 ee25e6e4 ee0bdce4 ee0bdc18 ee0bdc98
[ 21.397115] dc80: c0289718 bf2e4e48 000f0093 ffffffff
[ 21.402189] r8:ee25e000 r7:ee0bdc7c r6:ffffffff r5:000f0093 r4:bf2e4e48
[ 21.408977] [<bf2e4da8>] (xhci_hub_status_data [xhci_hcd]) from [<bf299310>] (hcd_bus_suspend+0xec/0x10c [usbco
re])
[ 21.419460] r10:00000402 r9:bf2acee4 r8:00000001 r7:00000001 r6:00000000 r5:ee181800
[ 21.427323] r4:ee25e000
[ 21.429943] [<bf299224>] (hcd_bus_suspend [usbcore]) from [<bf2a776c>] (generic_suspend+0x54/0x58 [usbcore])
[ 21.439814] r7:00000000 r6:ed68f000 r5:ffffffff r4:ee181800
[ 21.445573] [<bf2a7718>] (generic_suspend [usbcore]) from [<bf29dc44>] (usb_suspend_both+0x188/0x1ec [usbcore])
[ 21.455780] [<bf29dabc>] (usb_suspend_both [usbcore]) from [<bf29ea20>] (usb_runtime_suspend+0x30/0x68 [usbcore
[ 21.466089] r10:c1205100 r9:00000000 r8:bf29e9f0 r7:00000000 r6:c1205100 r5:ee181800
[ 21.473952] r4:ee181870
[ 21.476537] [<bf29e9f0>] (usb_runtime_suspend [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 21.485884] r5:ee181924 r4:ee181870
[ 21.489478] [<c068366c>] (__rpm_callback) from [<c06838b8>] (rpm_callback+0x28/0x88)
[ 21.497257] r10:c1205100 r9:00000000 r8:00000008 r7:00000000 r6:c1205100 r5:bf29e9f0
[ 21.505121] r4:ee181870
[ 21.507668] [<c0683890>] (rpm_callback) from [<c0683b80>] (rpm_suspend+0x120/0x4e0)
[ 21.515359] r7:00000000 r6:c1205100 r5:bf29e9f0 r4:ee181870
[ 21.521046] [<c0683a60>] (rpm_suspend) from [<c068491c>] (__pm_runtime_suspend+0x64/0x88)
[ 21.529260] r10:00000001 r9:00000000 r8:bf29ea74 r7:600b0113 r6:ee181924 r5:00000008
[ 21.537124] r4:ee181870
[ 21.539708] [<c06848b8>] (__pm_runtime_suspend) from [<bf29eaa0>] (usb_runtime_idle+0x2c/0x34 [usbcore])
[ 21.549230] r7:00000000 r6:00000002 r5:ee181924 r4:ee181870
[ 21.554954] [<bf29ea74>] (usb_runtime_idle [usbcore]) from [<c0683734>] (__rpm_callback+0xc8/0x224)
[ 21.564040] r5:ee181924 r4:ee181870
[ 21.567633] [<c068366c>] (__rpm_callback) from [<c06839f8>] (rpm_idle+0xe0/0x148)
[ 21.575150] r10:00000001 r9:00000000 r8:ee1819ec r7:00000000 r6:00000002 r5:00000000
[ 21.583014] r4:ee181870
[ 21.585561] [<c0683918>] (rpm_idle) from [<c0684380>] (pm_runtime_work+0x88/0x98)
[ 21.593077] r9:00000000 r8:00000000 r7:ef4d4800 r6:ef4cf100 r5:ee181924 r4:ee1819c4
[ 21.600857] [<c06842f8>] (pm_runtime_work) from [<c024818c>] (process_one_work+0x1e0/0x498)
[ 21.609244] r5:ee098400 r4:ee1819c4
[ 21.612838] [<c0247fac>] (process_one_work) from [<c02484a0>] (worker_thread+0x5c/0x54c)
[ 21.620965] r10:c1205100 r9:00000008 r8:ffffe000 r7:ef4cf13c r6:ee098418 r5:ef4cf100
[ 21.628829] r4:ee098400
[ 21.631376] [<c0248444>] (worker_thread) from [<c024f7bc>] (kthread+0x16c/0x170)
[ 21.638806] r10:eec97e6c r9:c0248444 r8:ee098400 r7:ee0bc000 r6:00000000 r5:ee099280
[ 21.646670] r4:eeded980
[ 21.649217] [<c024f650>] (kthread) from [<c0207eac>] (ret_from_fork+0x14/0x28)
[ 21.656473] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024f650
[ 21.664336] r4:ee099280
[ 21.666880] ---[ end trace 9f8961d6fe6041a1 ]---
Here is my device tree
* Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/dts-v1/;
#include "dra74x.dtsi"
#include "am57xx-commercial-grade.dtsi"
#include "dra74x-mmc-iodelay.dtsi"
#include "dra74-ipu-dsp-common.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/rtc/nxp,pcf85263.h>
compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7";
/* /delete-node/ rtc@48838000;
aliases {
rtc0 = &pcf85263;
rtc1 = &tps659038_rtc;
rtc2 = &rtc;
display0 = &hdmi0;
sound0 = &sound0;
/* sound1 = &hdmi;*/
chosen {
stdout-path = &uart3;
memory@0 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x40000000>;
memory@80000000 {
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ipu2_memory_region: ipu2-memory@95800000 {
compatible = "shared-dma-pool";
reg = <0x0 0x95800000 0x0 0x3800000>;
reusable;
status = "okay";
dsp1_memory_region: dsp1-memory@99000000 {
reg = <0x0 0x99000000 0x0 0x4000000>;
reusable;
status = "okay";
ipu1_memory_region: ipu1-memory@9d000000 {
reg = <0x0 0x9d000000 0x0 0x2000000>;
reusable;
status = "okay";
dsp2_memory_region: dsp2-memory@9f000000 {
reg = <0x0 0x9f000000 0x0 0x800000>;
reusable;
status = "okay";
main_12v0: fixedregulator-main_12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "main_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
evm_5v0: fixedregulator-evm_5v0 {
/* Output of TPS54531D */
regulator-name = "evm_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&main_12v0>;
regulator-boot-on;
vdd_3v3: fixedregulator-vdd_3v3 {
regulator-name = "vdd_3v3";
vin-supply = <®en1>;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
aic_dvdd: fixedregulator-aic_dvdd {
regulator-name = "aic_dvdd_fixed";
vin-supply = <&vdd_3v3>;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vtt_fixed: fixedregulator-vtt {
/* TPS51200 */
regulator-name = "vtt_fixed";
vin-supply = <&smps3_reg>;
regulator-boot-on;
enable-active-high;
gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
leds {
compatible = "gpio-leds";
led0 {
label = "beagle-x15:usr0";
gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
default-state = "on";
led1 {
label = "beagle-x15:usr1";
gpios = <&gpio3 8 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "cpu0";
led2 {
label = "beagle-x15:usr2";
gpios = <&gpio3 10 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "cpu1";
led3 {
label = "beagle-x15:usr3";
gpios = <&gpio3 7 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "disk-activity";
default-state = "off";
led4 {
label = "beagle-x15:usr4";
gpios = <&gpio7 1 GPIO_ACTIVE_HIGH>;
/* linux,default-trigger = "disk-activity";*/
gpio_fan: gpio_fan {
/* Based on 5v 500mA AFB02505HHB */
compatible = "gpio-fan";
gpios = <&tps659038_gpio 2 GPIO_ACTIVE_HIGH>;
gpio-fan,speed-map = <0 0>,
<13000 1>;
#cooling-cells = <2>;
hdmi0: connector {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&tpd12s015_out>;
tpd12s015: encoder {
compatible = "ti,tpd12s015";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tpd12s015_in: endpoint {
remote-endpoint = <&hdmi_out>;
port@1 {
reg = <1>;
tpd12s015_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
sound0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "BeagleBoard-X15";
simple-audio-card,widgets =
"Line", "Line Out",
"Line", "Line In";
simple-audio-card,routing =
"Line Out", "LLOUT",
"Line Out", "RLOUT",
"MIC2L", "Line In",
"MIC2R", "Line In";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound0_master>;
simple-audio-card,frame-master = <&sound0_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp3>;
sound0_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3104>;
clocks = <&clkout2_clk>;
&i2c1 {
status = "okay";
clock-frequency = <400000>;
tps659038: tps659038@58 {
compatible = "ti,tps659038";
reg = <0x58>;
interrupt-parent = <&gpio1>;
interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
#interrupt-cells = <2>;
interrupt-controller;
ti,system-power-controller;
/* ti,palmas-override-powerhold;*/
tps659038_pmic {
compatible = "ti,tps659038-pmic";
regulators {
smps12_reg: smps12 {
/* VDD_MPU */
regulator-name = "smps12";
regulator-min-microvolt = < 850000>;
regulator-max-microvolt = <1250000>;
regulator-boot-on;
smps3_reg: smps3 {
/* VDD_DDR */
regulator-name = "smps3";
regulator-min-microvolt = <1350000>;
regulator-max-microvolt = <1350000>;
regulator-boot-on;
smps45_reg: smps45 {
/* VDD_DSPEVE, VDD_IVA, VDD_GPU */
regulator-name = "smps45";
regulator-boot-on;
smps6_reg: smps6 {
/* VDD_CORE */
regulator-name = "smps6";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
/* SMPS7 unused */
smps8_reg: smps8 {
/* VDD_1V8 */
regulator-name = "smps8";
regulator-boot-on;
/* SMPS9 unused */
ldo1_reg: ldo1 {
/* VDD_SD / VDDSHV8 */
regulator-name = "ldo1";
regulator-boot-on;
ldo2_reg: ldo2 {
/* VDD_SHV5 */
regulator-name = "ldo2";
regulator-boot-on;
ldo3_reg: ldo3 {
/* VDDA_1V8_PHYA */
regulator-name = "ldo3";
regulator-boot-on;
ldo4_reg: ldo4 {
/* VDDA_1V8_PHYB */
regulator-name = "ldo4";
regulator-boot-on;
ldo9_reg: ldo9 {
/* VDD_RTC */
regulator-name = "ldo9";
regulator-min-microvolt = <1050000>;
regulator-max-microvolt = <1050000>;
regulator-boot-on;
ldoln_reg: ldoln {
/* VDDA_1V8_PLL */
regulator-name = "ldoln";
regulator-boot-on;
ldousb_reg: ldousb {
/* VDDA_3V_USB: VDDA_USBHS33 */
regulator-name = "ldousb";
regulator-boot-on;
regen1: regen1 {
/* VDD_3V3_ON */
regulator-name = "regen1";
regulator-boot-on;
tps659038_rtc: tps659038_rtc {
compatible = "ti,palmas-rtc";
interrupt-parent = <&tps659038>;
interrupts = <8 IRQ_TYPE_EDGE_FALLING>;
wakeup-source;
tps659038_pwr_button: tps659038_pwr_button {
compatible = "ti,palmas-pwrbutton";
interrupts = <1 IRQ_TYPE_EDGE_FALLING>;
wakeup-source;
ti,palmas-long-press-seconds = <12>;
tps659038_gpio: tps659038_gpio {
compatible = "ti,palmas-gpio";
gpio-controller;
#gpio-cells = <2>;
tmp102: tmp102@48 {
compatible = "ti,tmp102";
reg = <0x48>;
interrupt-parent = <&gpio7>;
#thermal-sensor-cells = <1>;
tlv320aic3104: tlv320aic3104@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3104";
reg = <0x18>;
assigned-clocks = <&clkoutmux2_clk_mux>;
assigned-clock-parents = <&sys_clk2_dclk_div>;
status = "okay";
adc-settle-ms = <40>;
AVDD-supply = <&vdd_3v3>;
IOVDD-supply = <&vdd_3v3>;
DRVDD-supply = <&vdd_3v3>;
DVDD-supply = <&aic_dvdd>;
eeprom: eeprom@50 {
compatible = "atmel,24c32";
reg = <0x50>;
pcf85263: pcf85263@51 {
compatible = "nxp,pcf85263";
reg = <0x51>;
interrupt-parent = <&gpio3>;
interrupts = <27 IRQ_TYPE_LEVEL_LOW>;
interrupt-names = "INTB";
quartz-load-capacitance = <PCF85263_QUARTZCAP_7pF>;
quartz-drive-strength = <PCF85263_QUARTZDRIVE_LOW>;
&gpio7 {
ti,no-reset-on-init;
ti,no-idle-on-init;
&cpu0 {
vdd-supply = <&smps12_reg>;
voltage-tolerance = <1>;
&uart3 {
status = "okay";
interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x3f8>;
&davinci_mdio {
phy0: ethernet-phy@1 {
reg = <1>;
phy1: ethernet-phy@2 {
reg = <2>;
&mac {
status = "okay";
slaves = <1>;
/* dual_emac;*/
&cpsw_emac0 {
phy-handle = <&phy0>;
phy-mode = "rgmii";
/* dual_emac_res_vlan = <1>;*/
&cpsw_emac1 {
phy-handle = <&phy1>;
phy-mode = "rgmii";
dual_emac_res_vlan = <2>;
&dra7_pmx_core {
sd_pins_default: sd_pins_default {
pinctrl-single,pins = <
/*DRA7XX_CORE_IOPAD(0x376c, PIN_INPUT | MUX_MODE14)*/ /* mmc1sdcd.gpio219 */
DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */
DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */
DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */
DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */
DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */
DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */
emmc_pins_default: emmc_pins_default {
DRA7XX_CORE_IOPAD(0x349c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */
DRA7XX_CORE_IOPAD(0x34b0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
DRA7XX_CORE_IOPAD(0x34a0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
DRA7XX_CORE_IOPAD(0x34a4, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
DRA7XX_CORE_IOPAD(0x34a8, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
DRA7XX_CORE_IOPAD(0x34ac, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
DRA7XX_CORE_IOPAD(0x348c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
DRA7XX_CORE_IOPAD(0x3490, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
DRA7XX_CORE_IOPAD(0x3494, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
DRA7XX_CORE_IOPAD(0x3498, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
&mmc1 {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&sd_pins_default>;
bus-width = <4>;
broken-cd;
/* cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;*/ /* gpio 219 */
&mmc2 {
status = "okay";
pinctrl-0 = <&emmc_pins_default>;
vmmc-supply = <&vdd_3v3>;
vqmmc-supply = <&vdd_3v3>;
bus-width = <8>;
non-removable;
no-1-8-v;
&sata {
status = "disabled";
&pcie1_rc {
&pcie1_ep {
&sata {
&usb2_phy1 {
phy-supply = <&ldousb_reg>;
&usb2_phy2 {
&usb1 {
dr_mode = "host";
&usb2 {
&omap_dwc3_2 {
extcon = <&extcon_usb2>;
&usb2 {*/
* Stand alone usage is peripheral only.
* However, with some resistor modifications
* this port can be used via expansion connectors
* as "host" or "dual-role". If so, provide
* the necessary dr_mode override in the expansion
* board's DT.
/* dr_mode = "peripheral";
&cpu_trips {
cpu_alert1: cpu_alert1 {
temperature = <50000>; /* millicelsius */
hysteresis = <2000>; /* millicelsius */
type = "active";
&cpu_cooling_maps {
map1 {
trip = <&cpu_alert1>;
cooling-device = <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
&thermal_zones {
board_thermal: board_thermal {
polling-delay-passive = <1250>; /* milliseconds */
polling-delay = <1500>; /* milliseconds */
/* sensor ID */
thermal-sensors = <&tmp102 0>;
board_trips: trips {
board_alert0: board_alert {
temperature = <40000>; /* millicelsius */
type = "active";
board_crit: board_crit {
temperature = <105000>; /* millicelsius */
hysteresis = <0>; /* millicelsius */
type = "critical";
board_cooling_maps: cooling-maps {
map0 {
trip = <&board_alert0>;
cooling-device =
&gpu {
status = "ok";
&dss {
status = "ok";
vdda_video-supply = <&ldoln_reg>;
&bb2d {
status = "okay";
&hdmi {
status = "ok";
vdda-supply = <&ldo4_reg>;
port {
hdmi_out: endpoint {
remote-endpoint = <&tpd12s015_in>;
&pcie1_rc {
&pcie1_ep {
&mcasp3 {
assigned-clocks = <&mcasp3_ahclkx_mux>;
assigned-clock-parents = <&sys_clkin2>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializers */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 2 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
&pruss_soc_bus1 {
status = "okay";
pruss1: pruss@0 {
status = "okay";
&pruss_soc_bus2 {
status = "okay";
pruss2: pruss@0 {
status = "okay";
&ipu2 {
status = "okay";
memory-region = <&ipu2_memory_region>;
&ipu1 {
status = "okay";
memory-region = <&ipu1_memory_region>;
&dsp1 {
status = "okay";
memory-region = <&dsp1_memory_region>;
&dsp2 {
status = "okay";
memory-region = <&dsp2_memory_region>;
* Copyright (C) 2014-2017 Texas Instruments Incorporated - http://www.ti.com/
#include "am57xx-beagle-x15-common.dtsi"
model = "TI AM5728 BeagleBoard-X15 rev C";
&ocp {
&mmc1 {
pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_hs>;
pinctrl-2 = <&mmc1_pins_sdr12>;
pinctrl-3 = <&mmc1_pins_sdr25>;
pinctrl-4 = <&mmc1_pins_sdr50>;
pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr_rev20_conf>;
pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
vqmmc-supply = <&ldo1_reg>;
&mmc2 {
pinctrl-names = "default", "hs", "ddr_1_8v";
pinctrl-0 = <&mmc2_pins_default>;
pinctrl-1 = <&mmc2_pins_hs>;
pinctrl-2 = <&mmc2_pins_ddr_rev20>;
&dra7_pmx_core {
touchscreen_pins_ds: pinmux_touchscreen_pins_ds {
DRA7XX_CORE_IOPAD(0x3554, PIN_INPUT | MUX_MODE15) /* vin2a_clk0.gpio3_28 */
DRA7XX_CORE_IOPAD(0x3558, PIN_OUTPUT | MUX_MODE15) /* vin2a_clk0.gpio3_29 */
&i2c3 {
status = "okay";
clock-frequency = <100000>;
gt928@5d {
compatible = "goodix,gt928";
reg = <0x5d>;
pinctrl-0 = <&touchscreen_pins_ds>;
interrupts = <6 0>;
irq-gpios = <&gpio3 6 0>;
reset-gpios = <&gpio2 30 0>;
touchscreen-size-x = <1280>;
touchscreen-size-y = <800>;
#include "am57xx-evm-cmem.dtsi"
