Linux/AM5718: Kernel panic
Part Number: AM5718
Other Parts Discussed in Thread: DRA722, TMP102, AM3352
Tool/software: Linux
We are developing a custom board with am5718 using ti-processor-sdk-linux-am57xx-evm-05.02.00.10 and able to enter into the root with a bootable sd card with a kernal getting crashed and the related log is attached below.
Please have thorough glance at the highlighted log and suggest us how to resolve individual errors in a detailed manner separately
Starting Medha kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.79-gbde58ab01e (toradex@medha) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #10 SMP PREEMPT Wed Ma9
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: TI AM5718 IDK
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[    0.000000] DRA722 ES2.0
[    0.000000] percpu: Embedded 15 pages/cpu @ef64b000 s31372 r8192 d21876 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 210496
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=860c842a-02 rw rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 644592K/848896K available (8192K kernel code, 347K rwdata, 2564K rodata, 2048K init, 282K bss, 24080K reserved, 180224)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0a00000   (10208 kB)
[    0.000000]       .init : 0xc0e00000 - 0xc1000000   (2048 kB)
[    0.000000]       .data : 0xc1000000 - 0xc1056e98   ( 348 kB)
[    0.000000]        .bss : 0xc1058000 - 0xc109ebe0   ( 283 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000016] Switching to timer-based delay loop, resolution 162ns
[    0.000356] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000365] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000787] Console: colour dummy device 80x30
[    0.000804] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000811] This ensures that you still see kernel messages. Please
[    0.000817] update your kernel commandline.
[    0.000838] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000853] pid_max: default: 32768 minimum: 301
[    0.000958] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000971] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001496] CPU: Testing write buffer coherency: ok
[    0.001533] CPU0: Spectre v2: using ICIALLU workaround
[    0.001723] /cpus/cpu@0 missing clock-frequency property
[    0.001737] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.039863] Setting up static identity map for 0x80200000 - 0x80200060
[    0.059871] Hierarchical SRCU implementation.
[    0.080054] EFI services will not be available.
[    0.099929] smp: Bringing up secondary CPUs ...
[    0.099939] smp: Brought up 1 node, 1 CPU
[    0.099948] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[    0.099956] CPU: All CPU(s) started in HYP mode.
[    0.099962] CPU: Virtualization extensions available.
[    0.100372] devtmpfs: initialized
[    0.117396] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[    0.120068] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.120259] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.120275] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.123867] pinctrl core: initialized pinctrl subsystem
[    0.124347] DMI not present or invalid.
[    0.124591] NET: Registered protocol family 16
[    0.130829] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.131681] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.233482] omap_hwmod: dcan1: _wait_target_disable failed
[    0.332216] cpuidle: using governor ladder
[    0.332248] cpuidle: using governor menu
[    0.339965] OMAP GPIO hardware version 0.1
[    0.341917] omap_gpio 48059000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio4_pins_default, deferring pe
[    0.342285] omap_gpio 4805b000.gpio: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/gpio5_pins_default, deferring pe
[    0.365759] No ATAGs?
[    0.365804] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.365818] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.366184] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.366195] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.366736] OMAP DMA hardware revision 0.0
[    0.402369] edma 43300000.edma: memcpy is disabled
[    0.405627] edma 43300000.edma: TI EDMA DMA engine driver
[    0.412466] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.413267] evm_5v0: supplied by evm_12v0
[    0.413544] evm_3v6: supplied by evm_5v0
[    0.413815] vsys_3v3: supplied by evm_12v0
[    0.414081] evm_3v3: supplied by vsys_3v3
[    0.414361] evm_3v3_sd: supplied by evm_3v3
[    0.415494] V3_3D: supplied by VMAIN
[    0.415918] vtt_fixed: supplied by V3_3D
[    0.418340] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.418540] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.418792] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.419031] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.421979] palmas 0-0058: IRQ missing: skipping irq request
[    0.450775] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[    0.452134] SMPS1: supplied by evm_3v3_sd
[    0.453726] SMPS2: supplied by evm_3v3_sd
[    0.455315] SMPS3: supplied by evm_3v3_sd
[    0.456884] SMPS4: supplied by evm_3v3_sd
[    0.458299] SMPS5: supplied by evm_3v3_sd
[    0.459482] SMPS12: supplied by evm_3v3_sd
[    0.460457] LDO1: supplied by evm_3v3_sd
[    0.460964] ldo1: Bringing 3000000uV into 3300000-3300000uV
[    0.471408] LDO2: supplied by evm_3v3_sd
[    0.472550] LDO3: supplied by evm_3v3_sd
[    0.481168] LDO4: supplied by evm_3v3_sd
[    0.490575] random: fast init done
[    0.491189] LDO5: supplied by evm_3v3_sd
[    0.502154] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.502359] media: Linux media interface: v0.10
[    0.502396] Linux video capture interface: v2.00
[    0.502474] pps_core: LinuxPPS API ver. 1 registered
[    0.502483] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.502506] PTP clock support registered
[    0.502537] EDAC MC: Ver: 3.0.0
[    0.510653] dmi: Firmware registration failed.
[    0.511077] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.511277] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.511619] Advanced Linux Sound Architecture Driver Initialized.
[    0.520726] clocksource: Switched to clocksource arch_sys_counter
[    0.528177] missing cooling_device property
[    0.528190] failed to build thermal zone board_thermal: -2
[    0.528321] NET: Registered protocol family 2
[    0.528854] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.528918] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.529044] TCP: Hash tables configured (established 8192 bind 8192)
[    0.529108] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.529142] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.529260] NET: Registered protocol family 1
[    0.549617] RPC: Registered named UNIX socket transport module.
[    0.549627] RPC: Registered udp transport module.
[    0.549635] RPC: Registered tcp transport module.
[    0.549642] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.550543] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    0.550667] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.551730] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.555921] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.566466] NFS: Registering the id_resolver key type
[    0.566493] Key type id_resolver registered
[    0.566501] Key type id_legacy registered
[    0.566538] ntfs: driver 2.1.32 [Flags: R/O].
[    0.568172] bounce: pool size: 64 pages
[    0.568216] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.568226] io scheduler noop registered
[    0.568235] io scheduler deadline registered
[    0.568335] io scheduler cfq registered (default)
[    0.568345] io scheduler mq-deadline registered
[    0.568353] io scheduler kyber registered
[    0.572895] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.573045] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[    0.573116] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[    0.573127] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[    0.587029] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.589521] vdd_3v3: supplied by ldo1
[    0.589782] aic_dvdd_fixed: supplied by vdd_3v3
[    0.632297] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.634994] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 43, base_baud = 3000000) is a 8250
[    1.629677] console [ttyS0] enabled
[    1.634094] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 44, base_baud = 3000000) is a 8250
[    1.643705] 48420000.serial: ttyS6 at MMIO 0x48420000 (irq = 45, base_baud = 3000000) is a 8250
[    1.653289] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 46, base_baud = 3000000) is a 8250
[    1.663926] omap_rng 48090000.rng: Random Number Generator ver. 20
[    1.671013] DSS: OMAP DSS rev 6.1
[    1.675493] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    1.695146] brd: module loaded
[    1.703608] loop: module loaded
[    1.709646] libphy: Fixed MDIO Bus: probed
[    1.770748] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.778441] davinci_mdio 48485000.mdio: no live phy, scanning all
[    1.785708] davinci_mdio: probe of 48485000.mdio failed with error -5
[    1.792814] cpsw 48484000.ethernet: No slave[1] phy_id, phy-handle, or fixed-link property
[    1.801182] cpsw 48484000.ethernet: Detected MACID = 98:5d:ad:9a:2e:1a
[    1.807796] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[    1.814218] cpsw 48484000.ethernet: ALE Table size 1024
[    1.819475] cpsw 48484000.ethernet: device node lookup for pps timer failed
[    1.826520] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.835005] i2c /dev entries driver
[    1.839249] IR NEC protocol handler initialized
[    1.843827] IR RC5(x/sz) protocol handler initialized
[    1.848952] IR RC6 protocol handler initialized
[    1.853516] IR JVC protocol handler initialized
[    1.858064] IR Sony protocol handler initialized
[    1.862712] IR SANYO protocol handler initialized
[    1.867433] IR Sharp protocol handler initialized
[    1.872168] IR MCE Keyboard/mouse protocol handler initialized
[    1.878023] IR XMP protocol handler initialized
[    1.884699] tmp102 0-0049: initialized
[    1.890965] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[    1.898655] sdhci: Secure Digital Host Controller Interface driver
[    1.904880] sdhci: Copyright(c) Pierre Ossman
[    1.909772] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.916332] sdhci-omap 4809c000.mmc: Got CD GPIO
[    1.921228] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
[    1.930312] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[    1.936831] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[    1.943254] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[    1.949636] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[    1.956055] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[    1.962452] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[    1.968571] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[    1.974703] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    2.040923] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    2.048448] sdhci-omap 480b4000.mmc: 480b4000.mmc supply vqmmc not found, using dummy regulator
[    2.067652] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[    2.074354] sdhci-omap 480b4000.mmc: no pinctrl state for hs mode
[    2.080501] sdhci-omap 480b4000.mmc: no pinctrl state for hs mode
[    2.086680] sdhci-omap 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[    2.106439] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.114584] mmc0: new SDHC card at address 0001
[    2.119403] mmcblk0: mmc0:0001 ASTC 14.6 GiB
[    2.125832]  mmcblk0: p1 p2
[    2.150756] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    2.158528] ledtrig-cpu: registered to indicate activity on CPUs
[    2.172954] NET: Registered protocol family 10
[    2.178266] Segment Routing with IPv6
[    2.182149] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.191744] NET: Registered protocol family 17
[    2.196428] Key type dns_resolver registered
[    2.200846] omap_voltage_late_init: Voltage driver support not added
[    2.207228] Power Management for TI OMAP4+ devices.
[    2.212352] Registering SWP/SWPB emulation handler
[    2.229654] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.237391] dmm 4e000000.dmm: initialized all PAT entries
[    2.244039] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.250745] mmc1: new MMC card at address 0001
[    2.255505] [drm] No driver support for vblank timestamp query.
[    2.261497] mmcblk1: mmc1:0001 P1XXXX 3.60 GiB
[    2.261668] mmcblk1boot0: mmc1:0001 P1XXXX partition 1 16.0 MiB
[    2.261822] mmcblk1boot1: mmc1:0001 P1XXXX partition 2 16.0 MiB
[    2.261966] mmcblk1rpmb: mmc1:0001 P1XXXX partition 3 128 KiB
[    2.266971]  mmcblk1: p1 p2
[    2.289504] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    2.296856] pinctrl-single 4a003400.pinmux: pin PIN109 already requested by 48484000.ethernet; cannot claim for 48059000.gpio
[    2.308258] pinctrl-single 4a003400.pinmux: pin-109 (48059000.gpio) status -22
[    2.315549] pinctrl-single 4a003400.pinmux: could not request pin 109 (PIN109) from group gpio4_pins_default  on device pinctrl-single
[    2.327703] omap_gpio 48059000.gpio: Error applying setting, reverse things back
[    2.335154] omap_gpio: probe of 48059000.gpio failed with error -22
[    2.341806] pinctrl-single 4a003400.pinmux: pin PIN148 already requested by 48484000.ethernet; cannot claim for 4805b000.gpio
[    2.353181] pinctrl-single 4a003400.pinmux: pin-148 (4805b000.gpio) status -22
[    2.360437] pinctrl-single 4a003400.pinmux: could not request pin 148 (PIN148) from group gpio5_pins_default  on device pinctrl-single
[    2.372587] omap_gpio 4805b000.gpio: Error applying setting, reverse things back
[    2.380026] omap_gpio: probe of 4805b000.gpio failed with error -22
[    2.386958] hctosys: unable to open rtc device (rtc0)
[    2.393935] ldo2: disabling
[    2.397174] ldo4: disabling
[    2.400252] ALSA device list:
[    2.403251]   No soundcards found.
[    2.780260] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
[    2.785651] EXT4-fs (mmcblk0p2): recovery complete
[    2.879419] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.887600] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.898116] devtmpfs: mounted
[    2.903495] Freeing unused kernel memory: 2048K
[    3.453930] systemd[1]: System time before build time, advancing clock.
[    3.542750] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GC)
[    3.563974] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[    3.615565] systemd[1]: Set hostname to <am57xx-evm>.
[    4.258944] random: systemd: uninitialized urandom read (16 bytes read)
[    4.265835] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.300896] random: systemd: uninitialized urandom read (16 bytes read)
[    4.307749] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.340866] random: systemd: uninitialized urandom read (16 bytes read)
[    4.349249] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    4.383662] systemd[1]: Mounting Kernel Debug File System...
[    4.395247] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.433028] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    4.466237] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Load Kernel Modules...
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[    4.610635] cmemk: loading out-of-tree module taints kernel.
[    4.617088] CMEMK module: reference Linux version 4.14.79
[    4.623189] cmemk initialized
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    4.647730] cryptodev: driver 1.9 loaded.
         Mounting POSIX Message Queue File System...
[  OK  ] Listening on udev Kernel Socket.
[    4.703461] usbcore: registered new interface driver usbfs
[    4.709023] usbcore: registered new interface driver hub
[    4.714475] usbcore: registered new device driver usb
[  OK  ] Listening on udev Control Socket.
[    4.728649] usbcore: registered new interface driver usbserial
[    4.751736] usbcore: registered new interface driver ftdi_sio
[    4.757555] usbserial: USB Serial support registered for FTDI USB Serial Device
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on Network Service Netlink Socket.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    4.873139] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[  OK  ] Reached target Paths.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target Swap.
         Mounting Temporary Directory (/tmp)...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Journal Service...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Journal Service.
         Starting Rebuild Hardware Database...
         Starting Flush Journal to Persistent Storage...
         Starting Create System Users...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Create System Users.
[  OK  ] Started Apply Kernel Variables.
[    5.579394] systemd-journald[78]: Received request to flush runtime journal from PID 1
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Rebuild Dynamic Linker Cache...
         Starting Rebuild Journal Catalog...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Rebuild Dynamic Linker Cache.
[  OK  ] Started Rebuild Hardware Database.
         Starting udev Coldplug all Devices...
         Starting Update is Completed...
[  OK  ] Started Update is Completed.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
         Starting Network Service...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Print notice about GPLv3 packages...
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting RPC Bind Service...
[    9.655471] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Reached target Containers.
[    9.730847] omap-des 480a5000.des: will run requests pump with realtime priority
         Starting Avahi mDNS/DNS-SD Stack...
         Starting TI IPC Daemon...
[    9.845194] random: crng init done
         Starting TI MultiCore Tools Daemon...
[    9.879445] random: 7 urandom warning(s) missed due to ratelimiting
[    9.937901] rtc-ds1307 0-0068: registered as rtc0
[  OK  ] Started D-Bus System Message Bus.
[   10.301231] CAN device driver interface
[   10.345844] omap_hwmod: rtcss: _wait_target_disable failed
[   10.351362] omap_hwmod: rtcss: _wait_target_ready failed: -16
[   10.559258] omap_rtc 48838000.rtc: use pm_runtime_put_sync_suspend() in driver?
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[   10.666811] ------------[ cut here ]------------
[   10.675589] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   10.684937] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   10.696548] Modules linked in: ti_vpe(+) ti_sc ti_csc ti_vpdma dwc3_omap(+) c_can_platform(+) c_can rtc_omap(+) can_dev rtc_ds1307 omap_de)
[   10.725546] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G           O    4.14.79-gbde58ab01e #10
[   10.734455] Hardware name: Generic DRA72X (Flattened Device Tree)
[   10.740572] Backtrace:
[   10.743038] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   10.750642]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   10.756331] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   10.763587] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   10.770578]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a38
[   10.776262] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   10.783779]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   10.791557] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   10.800466]  r3:ef1c5680 r2:c0bd48bc
[   10.804054]  r4:80080003
[   10.806603] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   10.816124]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b5c r6:00000000 r5:ef1c4200
[   10.823986]  r4:ef1c5b80
[   10.826533] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   10.836228]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   10.844090]  r4:ef1c4200
[   10.846636] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   10.855544]  r5:ef1c4264 r4:ef1c4200
[   10.859138] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   10.867699]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   10.873385] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   10.882034]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   10.887720] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   10.896458] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   10.904846]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c18 r5:fa21200c r4:c1004000
[   10.912625] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   10.920139] Exception stack(0xedc19c18 to 0xedc19c60)
[   10.925210] 9c00:                                                       edc7be10 600f0113
[   10.933424] 9c20: fa838000 83e70b13 edc7be10 ef20c610 ef20c600 fffffffe bf118078 00000004
[   10.941637] 9c40: 00000000 edc19c7c edc19c58 edc19c68 bf1153d4 c0215f44 a0010013 ffffffff
[   10.949850]  r9:edc18000 r8:bf118078 r7:edc19c4c r6:ffffffff r5:a0010013 r4:c0215f44
[   10.957641] [<bf1153a4>] (am3352_rtc_unlock [rtc_omap]) from [<bf116004>] (omap_rtc_probe+0x120/0x528 [rtc_omap])
[   10.967945]  r5:ef20c610 r4:edc7be10
[   10.971544] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   10.980804]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   10.988584] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   10.997494]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   11.003179] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   11.011654]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   11.019516]  r4:ef20c610 r3:00000000
[   11.023111] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   11.031322]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   11.037008] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   11.045046]  r6:c10327b0 r5:edc80980 r4:bf118078
[   11.049683] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   11.057723] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   11.065761]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   11.071447] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   11.080530]  r5:00000000 r4:c10327b0
[   11.084127] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   11.094780]  r5:00000000 r4:ffffe000
[   11.098376] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   11.107988] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   11.116113]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   11.122847] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   11.130884]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   11.136571] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   11.144435]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   11.152296]  r4:00000000
[   11.154844] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   11.163054]  r6:00000000 r5:00000001 r4:00000000
[   11.167689] ---[ end trace 28edebdc9ffed6b7 ]---
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
         Starting Login Service...
         Starting uim-sysfs.service...
[   11.191078] net eth0: initializing cpsw version 1.15 (0)
[   11.198407] libphy: PHY 48485000.mdio:09 not found
[  OK  ] Started Network Service.
[   11.281427] net eth0: phy "48485000.mdio:09" not found on slave 0, err -19
[  OK  ] Started RPC Bind Service.
[   11.361022] libphy: PHY  not found
[  OK  ] Started TI IPC Daemon.
[  OK  ] Started TI MultiCore Tools Daemon.
[   11.397164] net eth0: phy "" not found on slave 1, err -19
[   11.430515] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Started Login Service.
[  OK  ] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
         Starting Permit User Sessions...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting Simple Network Management Protocol (SNMP) Daemon....
[  OK  ] Started Redis In-Memory Data Store.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[   12.590936] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[   12.942310] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[   13.189694] EXT4-fs (mmcblk1p2): recovery complete
[   13.209574] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[   14.580422] SCSI subsystem initialized
[  OK  ] Started uim-sysfs.service.
         Starting rc.pvr.service...
[   14.905495] ------------[ cut here ]------------
[   14.910151] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   14.919498] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   14.931110] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   14.971313] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   14.980222] Hardware name: Generic DRA72X (Flattened Device Tree)
[   14.986340] Backtrace:
[   14.988805] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   14.996409]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   15.002098] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   15.009354] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   15.016345]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a50
[   15.022030] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   15.029546]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   15.037323] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   15.046232]  r3:ef1c5680 r2:c0bd48bc
[   15.049820]  r4:80080003
[   15.052367] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   15.061890]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b74 r6:00000000 r5:ef1c4200
[   15.069751]  r4:ef1c5b80
[   15.072297] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   15.081993]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   15.089854]  r4:ef1c4200
[   15.092400] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   15.101309]  r5:ef1c4264 r4:ef1c4200
[   15.104904] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   15.113465]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   15.119152] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   15.127800]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   15.133486] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   15.142223] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   15.150611]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c30 r5:fa21200c r4:c1004000
[   15.158389] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   15.165902] Exception stack(0xedc19c30 to 0xedc19c78)
[   15.170975] 9c20:                                     edc7be10 600f0113 fa838000 95a4f1e0
[   15.179188] 9c40: edc7be10 ef20c610 ef20c600 fffffffe bf118078 00000004 00000000 edc19cb4
[   15.187400] 9c60: edc19c58 edc19c80 bf11600c c0215f44 a0010013 ffffffff
[   15.194044]  r9:edc18000 r8:bf118078 r7:edc19c64 r6:ffffffff r5:a0010013 r4:c0215f44
[   15.201833] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   15.211093]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   15.218873] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   15.227783]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   15.233468] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   15.241944]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   15.249805]  r4:ef20c610 r3:00000000
[   15.253399] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   15.261612]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   15.267298] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   15.275335]  r6:c10327b0 r5:edc80980 r4:bf118078
[   15.279973] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   15.288012] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   15.296048]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   15.301734] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   15.310816]  r5:00000000 r4:c10327b0
[   15.314414] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   15.325066]  r5:00000000 r4:ffffe000
[   15.328663] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   15.338274] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   15.346399]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   15.353134] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   15.361171]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   15.366857] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   15.374722]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   15.382582]  r4:00000000
[   15.385129] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   15.393340]  r6:00000000 r5:00000001 r4:00000000
[   15.397975] ---[ end trace 28edebdc9ffed6b8 ]---
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
[   17.300017] ------------[ cut here ]------------
[   17.304670] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   17.314019] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Read): Data Access in User mode during Functional access
[   17.325631] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   17.365833] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   17.374741] Hardware name: Generic DRA72X (Flattened Device Tree)
[   17.380859] Backtrace:
[   17.383325] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   17.390928]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   17.396617] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   17.403874] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   17.410866]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a50
[   17.416551] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   17.424067]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000002 r5:c0bd4818 r4:c0bd48bc
[   17.431845] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   17.440754]  r3:ef1c5680 r2:c0bd48bc
[   17.444343]  r4:80080003
[   17.446890] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   17.456412]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b74 r6:00000000 r5:ef1c4200
[   17.464273]  r4:ef1c5b80
[   17.466820] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   17.476516]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   17.484377]  r4:ef1c4200
[   17.486923] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   17.495832]  r5:ef1c4264 r4:ef1c4200
[   17.499426] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   17.507986]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   17.513672] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   17.522321]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   17.528006] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   17.536744] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   17.545131]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c30 r5:fa21200c r4:c1004000
[   17.552909] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   17.560421] Exception stack(0xedc19c30 to 0xedc19c78)
[   17.565494] 9c20:                                     edc7be10 600f0113 00000001 fa838000
[   17.573708] 9c40: edc7be10 ef20c610 ef20c600 00000040 bf118078 00000004 00000000 edc19cb4
[   17.581921] 9c60: edc19c70 edc19c80 c0215f80 bf11633c 20010013 ffffffff
[   17.588564]  r9:edc18000 r8:bf118078 r7:edc19c64 r6:ffffffff r5:20010013 r4:bf11633c
[   17.596354] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   17.605613]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   17.613391] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   17.622301]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   17.627987] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   17.636462]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   17.644324]  r4:ef20c610 r3:00000000
[   17.647919] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   17.656132]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   17.661817] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   17.669854]  r6:c10327b0 r5:edc80980 r4:bf118078
[   17.674492] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   17.682531] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   17.690569]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   17.696254] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   17.705336]  r5:00000000 r4:c10327b0
[   17.708935] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   17.719588]  r5:00000000 r4:ffffe000
[   17.723186] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   17.732797] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   17.740923]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   17.747656] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   17.755694]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   17.761379] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   17.769244]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   17.777105]  r4:00000000
[   17.779653] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   17.787864]  r6:00000000 r5:00000001 r4:00000000
[   17.792500] ---[ end trace 28edebdc9ffed6ba ]---
[   17.797430] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   17.804771] pgd = ee7ea100
[   17.807487] [00000000] *pgd=ae7ef003, *pmd=be076003
[   18.529438] ------------[ cut here ]------------
[   18.534092] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   18.543439] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   18.555051] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   18.595251] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   18.604160] Hardware name: Generic DRA72X (Flattened Device Tree)
[   18.610277] Backtrace:
[   18.612743] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   18.620346]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   18.626035] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   18.633291] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   18.640282]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a50
[   18.645968] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   18.653483]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   18.661261] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   18.670171]  r3:ef1c5680 r2:c0bd48bc
[   18.673759]  r4:80080003
[   18.676306] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   18.685828]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b74 r6:00000000 r5:ef1c4200
[   18.693689]  r4:ef1c5b80
[   18.696235] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   18.705931]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   18.713792]  r4:ef1c4200
[   18.716338] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   18.725247]  r5:ef1c4264 r4:ef1c4200
[   18.728840] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   18.737400]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   18.743086] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   18.751734]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   18.757419] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   18.766157] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   18.774545]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c30 r5:fa21200c r4:c1004000
[   18.782322] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   18.789835] Exception stack(0xedc19c30 to 0xedc19c78)
[   18.794908] 9c20:                                     edc7be10 600f0113 00000000 fa838000
[   18.803120] 9c40: edc7be10 ef20c610 ef20c600 00000000 bf118078 00000004 00000000 edc19cb4
[   18.811332] 9c60: edc19c70 edc19c80 c0215f80 bf116034 a0010013 ffffffff
[   18.817976]  r9:edc18000 r8:bf118078 r7:edc19c64 r6:ffffffff r5:a0010013 r4:bf116034
[   18.825765] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   18.835026]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   18.842805] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   18.851715]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   18.857400] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   18.865875]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   18.873737]  r4:ef20c610 r3:00000000
[   18.877331] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   18.885543]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   18.891229] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   18.899266]  r6:c10327b0 r5:edc80980 r4:bf118078
[   18.903902] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   18.911942] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   18.919979]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   18.925664] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   18.934746]  r5:00000000 r4:c10327b0
[   18.938344] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   18.948996]  r5:00000000 r4:ffffe000
[   18.952593] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   18.962204] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   18.970330]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   18.977063] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   18.985101]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   18.990788] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   18.998653]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   19.006514]  r4:00000000
[   19.009061] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   19.017273]  r6:00000000 r5:00000001 r4:00000000
[   19.021908] ---[ end trace 28edebdc9ffed6bb ]---
[   19.026673] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   19.034014] pgd = ee652600
[   19.036730] [00000000] *pgd=ae645003, *pmd=00000000
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am57xx-evm ttyS0
Arago 2018.10 am57xx-evm ttyS0
am57xx-evm login: [   19.250066] systemd[1]: systemd-journald.service: Failed with result 'core-dump'.
[   19.283196] systemd[1]: Started Matrix GUI.
[   19.321662] systemd[1]: busybox-klogd.service: Main process exited, code=dumped, status=7/BUS
[   19.348898] systemd[1]: busybox-klogd.service: Unit entered failed state.
[   19.380878] systemd[1]: busybox-klogd.service: Failed with result 'core-dump'.
[   19.414314] systemd[1]: systemd-journald.service: Service has no hold-off time, scheduling restart.
[   19.451622] systemd[1]: Stopped Flush Journal to Persistent Storage.
[   19.458054] systemd[1]: Stopping Flush Journal to Persistent Storage...
[   19.500892] systemd[1]: Stopped Journal Service.
[   19.513966] systemd[1]: Starting Journal Service...
[   19.575596] systemd-journald[491]: File /run/log/journal/e54fdb331def4e96ae890a3acbb544d9/system.journal corrupted or uncleanly shut down,.
[   20.600788] ------------[ cut here ]------------
[   20.605445] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   20.614792] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Read): Data Access in User mode during Functional access
[   20.626405] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   20.666606] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   20.675515] Hardware name: Generic DRA72X (Flattened Device Tree)
[   20.681632] Backtrace:
[   20.684097] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   20.691701]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   20.697390] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   20.704645] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   20.711637]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a50
[   20.717322] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   20.724837]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000002 r5:c0bd4818 r4:c0bd48bc
[   20.732615] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   20.741524]  r3:ef1c5680 r2:c0bd48bc
[   20.745112]  r4:80080003
[   20.747661] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   20.757182]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b74 r6:00000000 r5:ef1c4200
[   20.765044]  r4:ef1c5b80
[   20.767590] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   20.777287]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   20.785148]  r4:ef1c4200
[   20.787694] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   20.796602]  r5:ef1c4264 r4:ef1c4200
[   20.800196] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   20.808757]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   20.814443] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   20.823090]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   20.828775] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   20.837513] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   20.845900]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c30 r5:fa21200c r4:c1004000
[   20.853678] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   20.861192] Exception stack(0xedc19c30 to 0xedc19c78)
[   20.866266] 9c20:                                     00000001 00000000 00000000 fa838000
[   20.874479] 9c40: edc7be10 ef20c610 ef20c600 00000000 bf118078 00000004 00000000 edc19cb4
[   20.882691] 9c60: edc19c70 edc19c80 c0215f80 bf116074 60010013 ffffffff
[   20.889334]  r9:edc18000 r8:bf118078 r7:edc19c64 r6:ffffffff r5:60010013 r4:bf116074
[   20.897124] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   20.906384]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   20.914163] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   20.923072]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   20.928757] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   20.937231]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   20.945093]  r4:ef20c610 r3:00000000
[   20.948688] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   20.956900]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   20.962587] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   20.970623]  r6:c10327b0 r5:edc80980 r4:bf118078
[   20.975261] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   20.983301] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   20.991339]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   20.997023] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   21.006106]  r5:00000000 r4:c10327b0
[   21.009704] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   21.020357]  r5:00000000 r4:ffffe000
[   21.023953] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   21.033564] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   21.041690]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   21.048423] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   21.056460]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   21.062146] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   21.070011]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   21.077872]  r4:00000000
[   21.080421] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   21.088631]  r6:00000000 r5:00000001 r4:00000000
[   21.093266] ---[ end trace 28edebdc9ffed6bc ]---
[   21.098009] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   21.105352] pgd = ee675440
[   21.108067] [00000000] *pgd=add39003, *pmd=00000000
[   21.341828] systemd-journald[497]: File /run/log/journal/e54fdb331def4e96ae890a3acbb544d9/system.journal corrupted or uncleanly shut down,.
[   21.948634] systemd-coredump[478]: MESSAGE=Process 78 (systemd-journal) of user 0 dumped core.
[   21.980806] systemd-coredump[478]: Coredump diverted to /var/lib/systemd/coredump/core.systemd-journal.0.ae3a0a1fc80247d8800d31fbe5c728c2.z
[   22.598306] ------------[ cut here ]------------
[   22.602963] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   22.612310] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   22.623922] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   22.664124] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   22.673033] Hardware name: Generic DRA72X (Flattened Device Tree)
[   22.679151] Backtrace:
[   22.681616] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   22.689220]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   22.694908] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   22.702164] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   22.709156]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a50
[   22.714840] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   22.722355]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   22.730133] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   22.739041]  r3:ef1c5680 r2:c0bd48bc
[   22.742629]  r4:80080003
[   22.745177] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   22.754699]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b74 r6:00000000 r5:ef1c4200
[   22.762560]  r4:ef1c5b80
[   22.765107] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   22.774803]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   22.782666]  r4:ef1c4200
[   22.785212] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   22.794121]  r5:ef1c4264 r4:ef1c4200
[   22.797715] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   22.806275]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   22.811961] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   22.820608]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   22.826293] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   22.835030] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   22.843418]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c30 r5:fa21200c r4:c1004000
[   22.851196] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   22.858710] Exception stack(0xedc19c30 to 0xedc19c78)
[   22.863783] 9c20:                                     edc7be10 00000000 00000000 bf1153e8
[   22.871996] 9c40: edc7be10 ef20c610 ef20c600 00000000 00000001 bf118280 00000000 edc19cb4
[   22.880208] 9c60: edc19c70 edc19c80 bf1160b0 bf1153e8 60010013 ffffffff
[   22.886851]  r9:edc18000 r8:00000001 r7:edc19c64 r6:ffffffff r5:60010013 r4:bf1153e8
[   22.894641] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   22.903902]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   22.911680] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   22.920590]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   22.926275] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   22.934750]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   22.942611]  r4:ef20c610 r3:00000000
[   22.946206] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   22.954417]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   22.960104] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   22.968141]  r6:c10327b0 r5:edc80980 r4:bf118078
[   22.972779] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   22.980818] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   22.988857]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   22.994542] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   23.003625]  r5:00000000 r4:c10327b0
[   23.007223] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   23.017877]  r5:00000000 r4:ffffe000
[   23.021474] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   23.031085] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   23.039211]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   23.045944] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   23.053982]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   23.059667] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   23.067532]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   23.075393]  r4:00000000
[   23.077941] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   23.086152]  r6:00000000 r5:00000001 r4:00000000
[   23.090787] ---[ end trace 28edebdc9ffed6bd ]---
[   23.511904] systemd-coredump[496]: MESSAGE=Process 491 (systemd-journal) of user 0 dumped core.
[   23.520656] systemd-coredump[496]: Coredump diverted to /var/lib/systemd/coredump/core.systemd-journal.0.ae3a0a1fc80247d8800d31fbe5c728c2.z
[   24.434656] ------------[ cut here ]------------
[   24.439312] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   24.448660] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   24.460273] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   24.500472] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   24.509380] Hardware name: Generic DRA72X (Flattened Device Tree)
[   24.515496] Backtrace:
[   24.517962] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   24.525565]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   24.531253] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   24.538510] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   24.545502]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a38
[   24.551187] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   24.558702]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   24.566479] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   24.575388]  r3:ef1c5680 r2:c0bd48bc
[   24.578976]  r4:80080003
[   24.581524] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   24.591045]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b5c r6:00000000 r5:ef1c4200
[   24.598907]  r4:ef1c5b80
[   24.601454] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   24.611150]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   24.619011]  r4:ef1c4200
[   24.621556] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   24.630465]  r5:ef1c4264 r4:ef1c4200
[   24.634059] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   24.642619]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   24.648306] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   24.656953]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   24.662637] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   24.671375] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   24.679762]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c18 r5:fa21200c r4:c1004000
[   24.687540] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   24.695053] Exception stack(0xedc19c18 to 0xedc19c60)
[   24.700126] 9c00:                                                       edc7be10 00000000
[   24.708340] 9c20: 00000000 fa838000 00000000 edc7be10 ef20c600 00000000 00000001 bf118280
[   24.716553] 9c40: 00000000 edc19c7c edc19c58 edc19c68 bf115414 c0215f44 a0010013 ffffffff
[   24.724767]  r9:edc18000 r8:00000001 r7:edc19c4c r6:ffffffff r5:a0010013 r4:c0215f44
[   24.732558] [<bf1153e8>] (am3352_rtc_lock [rtc_omap]) from [<bf1160b0>] (omap_rtc_probe+0x1cc/0x528 [rtc_omap])
[   24.742689]  r5:ef20c610 r4:edc7be10
[   24.746288] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   24.755548]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   24.763327] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   24.772237]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   24.777921] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   24.786396]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   24.794259]  r4:ef20c610 r3:00000000
[   24.797852] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   24.806064]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   24.811751] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   24.819787]  r6:c10327b0 r5:edc80980 r4:bf118078
[   24.824425] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   24.832464] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   24.840502]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   24.846187] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   24.855270]  r5:00000000 r4:c10327b0
[   24.858866] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   24.869519]  r5:00000000 r4:ffffe000
[   24.873116] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   24.882727] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   24.890852]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   24.897585] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   24.905623]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   24.911308] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   24.919172]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   24.927034]  r4:00000000
[   24.929581] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   24.937792]  r6:00000000 r5:00000001 r4:00000000
[   24.942426] ---[ end trace 28edebdc9ffed6be ]---
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        binutils-dev
        binutils
        bison-dev
        bison
        cifs-utils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils-dev
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbc6x
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        hidapi
        libasm1
        libcairo-perf-utils
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm4
        libgettextlib
        libgettextsrc
        libgmp10
        libidn11
        libmavconn
        libmpc3
        libmpfr4
        libreadline-dev
        libreadline7
        libunistring2
        m4-dev
        m4
        make
        mavlink
        mavros-extras
        mavros-msgs
        mavros
        nettle
        parted
        python3-pycairo
        socketcan-interface
        swig-dev
        swig
        which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[   25.700746] ------------[ cut here ]------------
[   25.705400] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   25.714747] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Idle): Data Access in User mode during Functional access
[   25.726358] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   25.766559] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   25.775468] Hardware name: Generic DRA72X (Flattened Device Tree)
[   25.781585] Backtrace:
[   25.784051] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   25.791654]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   25.797342] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   25.804598] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   25.811590]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19a38
[   25.817273] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   25.824789]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000000 r5:c0bd4818 r4:c0bd48bc
[   25.832567] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   25.841476]  r3:ef1c5680 r2:c0bd48bc
[   25.845065]  r4:80080003
[   25.847613] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   25.857135]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc19b5c r6:00000000 r5:ef1c4200
[   25.864995]  r4:ef1c5b80
[   25.867542] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   25.877238]  r10:00000000 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   25.885098]  r4:ef1c4200
[   25.887644] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   25.896553]  r5:ef1c4264 r4:ef1c4200
[   25.900146] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   25.908706]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   25.914392] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   25.923040]  r7:00000000 r6:00000000 r5:00000017 r4:c0e64b3c
[   25.928726] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   25.937464] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   25.945852]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19c18 r5:fa21200c r4:c1004000
[   25.953630] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   25.961143] Exception stack(0xedc19c18 to 0xedc19c60)
[   25.966215] 9c00:                                                       ef20c610 00000001
[   25.974429] 9c20: 00000000 fa838000 ef20c610 ef20c610 ef20c600 00000000 00000001 bf118280
[   25.982642] 9c40: 00000000 edc19c7c edc19c80 edc19c68 c0663dbc c06638bc 20010013 ffffffff
[   25.990855]  r9:edc18000 r8:00000001 r7:edc19c4c r6:ffffffff r5:20010013 r4:c06638bc
[   25.998644] [<c0663d70>] (device_init_wakeup) from [<bf1160bc>] (omap_rtc_probe+0x1d8/0x528 [rtc_omap])
[   26.008076]  r5:ef20c610 r4:edc7be10
[   26.011676] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   26.020937]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   26.028715] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   26.037625]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   26.043309] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   26.051783]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   26.059644]  r4:ef20c610 r3:00000000
[   26.063239] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   26.071451]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   26.077137] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   26.085174]  r6:c10327b0 r5:edc80980 r4:bf118078
[   26.089812] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   26.097850] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   26.105888]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   26.111574] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   26.120656]  r5:00000000 r4:c10327b0
[   26.124253] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   26.134906]  r5:00000000 r4:ffffe000
[   26.138502] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   26.148113] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   26.156239]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   26.162971] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   26.171009]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   26.176695] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   26.184560]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   26.192421]  r4:00000000
[   26.194968] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   26.203180]  r6:00000000 r5:00000001 r4:00000000
[   26.207816] ---[ end trace 28edebdc9ffed6bf ]---
[   26.740913] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   26.748259] pgd = ee7f0380
[   26.750976] [00000000] *pgd=ae7d7003, *pmd=00000000
[   26.755886] Internal error: : 1211 [#1] PREEMPT SMP ARM
[   26.761133] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   26.801331] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G        W  O    4.14.79-gbde58ab01e #10
[   26.810239] Hardware name: Generic DRA72X (Flattened Device Tree)
[   26.816357] task: edc13600 task.stack: edc18000
[   26.820915] PC is at omap_rtc_read_time+0x5c/0xe8 [rtc_omap]
[   26.826602] LR is at __rtc_read_time+0x4c/0xc0
[   26.831063] pc : [<bf115294>]    lr : [<c0707710>]    psr: 40010093
[   26.837355] sp : edc19b40  ip : edc19b68  fp : edc19b64
[   26.842601] r10: 00000000  r9 : bf118280  r8 : c0c348e4
[   26.847848] r7 : edc7be10  r6 : edc19bc0  r5 : 000346dc  r4 : 00000032
[   26.854403] r3 : 00000000  r2 : 00000000  r1 : edc19bc0  r0 : 000346dc
[   26.860958] Flags: nZcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   26.868211] Control: 30c5387d  Table: ae7f0380  DAC: fffffffd
[   26.873980] Process systemd-udevd (pid: 198, stack limit = 0xedc18210)
[   26.880534] Stack: (0xedc19b40 to 0xedc1a000)
[   26.884910] 9b40: edd90400 edc19bc0 edd90400 edc19bc0 bf118000 bf118280 edc19b84 edc19b68
[   26.893123] 9b60: c0707710 bf115244 00000000 edd905ac edd90400 edc19bc0 edc19ba4 edc19b88
[   26.901337] 9b80: c07077b8 c07076d0 edc19c40 ef20c610 edd90400 00000000 edc19c34 edc19ba8
[   26.909550] 9ba0: c070807c c0707790 000081b4 edfcdd00 00000000 bf118000 bf118280 00000000
[   26.917763] 9bc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   26.925976] 9be0: 00000000 edfcdd00 edc19c14 edc19bf8 c0499968 c0499868 c0a1fa40 c0a2f9c0
[   26.934189] 9c00: 00000000 c0a2f9c0 edc19c3c edd90400 ef20c610 ef20c600 00000000 bf118000
[   26.942403] 9c20: bf118280 00000000 edc19c7c edc19c38 c0706ee0 c0708068 c0520970 c05239ec
[   26.950616] 9c40: c0a2f744 ef20c600 00000000 edfcdd00 ef20c610 ef20c600 edc19c7c edc19c68
[   26.958828] 9c60: c0520cc8 c05207cc edc7be10 edc7be10 edc19cb4 edc19c80 bf1162a8 c0706ebc
[   26.967042] 9c80: 00000000 ee7eac00 edc7be10 ef20c610 ef20c610 ffffffed bf118078 fffffdfb
[   26.975254] 9ca0: bf118078 00000004 edc19cd4 edc19cb8 c0655658 bf115ef0 ef20c610 c10953ec
[   26.983466] 9cc0: c10953f0 00000000 edc19d04 edc19cd8 c0653b78 c065560c 00000000 ef20c610
[   26.991680] 9ce0: bf118078 ef20c644 00000000 00000001 00000000 edc7d724 edc19d24 edc19d08
[   26.999892] 9d00: c0653cf0 c065396c 00000000 bf118078 c0653c44 00000000 edc19d4c edc19d28
[   27.008105] 9d20: c0651ee0 c0653c50 ef05f658 ef2078b4 ef05f66c bf118078 edc80980 c10327b0
[   27.016318] 9d40: edc19d5c edc19d50 c065351c c0651e98 edc19d84 edc19d60 c0653038 c0653504
[   27.024530] 9d60: bf117520 edc19d70 bf118078 00000000 bf11b000 edc7bd00 edc19d9c edc19d88
[   27.032744] 9d80: c0654660 c0652eb4 c10327b0 00000000 edc19db4 edc19da0 c06555b0 c06545ec
[   27.040956] 9da0: ffffe000 00000000 edc19dc4 edc19db8 bf11b01c c0655574 edc19e34 edc19dc8
[   27.049169] 9dc0: c02019fc bf11b00c ffffe000 edc7d780 efd16194 ef001e40 ffffe000 0001f6f4
[   27.057382] 9de0: 00000000 edc7d724 edc19e24 edc19df8 c032a43c c032a03c 00000001 f1dc9000
[   27.065595] 9e00: 00000001 00000005 edc7d780 f1dc9000 bf1180c0 bf1180c0 00000001 edc7d700
[   27.073807] 9e20: edc7bd00 00000001 edc19e5c edc19e38 c02b1a80 c02019bc edc19e5c edc19e48
[   27.082020] 9e40: edc19f40 00000001 edc7d700 bf1180c0 edc19f1c edc19e60 c02b092c c02b1a24
[   27.090234] 9e60: bf1180cc 00007fff bf1180c0 c02ad9c8 00000000 c0bb405c c0bb4034 bf1181d4
[   27.098446] 9e80: c0bb4184 c0c32d84 bf1181f0 c0a04590 bf1181c0 00000000 bf118108 bf1180c0
[   27.106659] 9ea0: ee732180 edc19f34 edc19eec edc19eb8 c0342440 00000000 00000000 00000000
[   27.114872] 9ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   27.123085] 9ee0: 00000000 00000000 00000000 00000000 7fffffff 00000000 00000007 b6ee40c4
[   27.131299] 9f00: 0000017b c0207e44 edc18000 0000017b edc19fa4 edc19f20 c02b10c8 c02aea2c
[   27.139511] 9f20: 7fffffff 00000000 00000003 00000000 00000000 f1dc9000 0000475c 00000000
[   27.147724] 9f40: f1dcaadb f1dc9000 0000475c f1dcd39c f1dcd2c0 f1dcc360 00004000 00004480
[   27.155936] 9f60: 00000000 00000000 00000000 00002168 00000015 00000016 0000000f 0000000c
[   27.164149] 9f80: 0000000a 00000000 00000000 00000000 00000001 00000000 00000000 edc19fa8
[   27.172362] 9fa0: c0207c40 c02b1030 00000000 00000001 00000007 b6ee40c4 00000000 004c6320
[   27.180575] 9fc0: 00000000 00000001 00000000 0000017b 00000000 0049fdec 00000000 004c6588
[   27.188789] 9fe0: bedfc980 bedfc970 b6edcc58 b6e16a82 60010030 00000007 00000000 00000000
[   27.196998] Backtrace:
[   27.199469] [<bf115238>] (omap_rtc_read_time [rtc_omap]) from [<c0707710>] (__rtc_read_time+0x4c/0xc0)
[   27.208818]  r9:bf118280 r8:bf118000 r7:edc19bc0 r6:edd90400 r5:edc19bc0 r4:edd90400
[   27.216597] [<c07076c4>] (__rtc_read_time) from [<c07077b8>] (rtc_read_time+0x34/0x48)
[   27.224547]  r7:edc19bc0 r6:edd90400 r5:edd905ac r4:00000000
[   27.230235] [<c0707784>] (rtc_read_time) from [<c070807c>] (__rtc_read_alarm+0x20/0x3f8)
[   27.238360]  r7:00000000 r6:edd90400 r5:ef20c610 r4:edc19c40
[   27.244046] [<c070805c>] (__rtc_read_alarm) from [<c0706ee0>] (__rtc_register_device+0x30/0x104)
[   27.252869]  r10:00000000 r9:bf118280 r8:bf118000 r7:00000000 r6:ef20c600 r5:ef20c610
[   27.260730]  r4:edd90400
[   27.263281] [<c0706eb0>] (__rtc_register_device) from [<bf1162a8>] (omap_rtc_probe+0x3c4/0x528 [rtc_omap])
[   27.272974]  r4:edc7be10
[   27.275526] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   27.284787]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   27.292566] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   27.301476]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   27.307161] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   27.315636]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   27.323498]  r4:ef20c610 r3:00000000
[   27.327093] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   27.335304]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   27.340991] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   27.349028]  r6:c10327b0 r5:edc80980 r4:bf118078
[   27.353665] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   27.361704] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   27.369742]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   27.375428] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   27.384510]  r5:00000000 r4:c10327b0
[   27.388106] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   27.398759]  r5:00000000 r4:ffffe000
[   27.402356] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   27.411970] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   27.420095]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   27.426828] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   27.434866]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   27.440552] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   27.448416]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   27.456278]  r4:00000000
[   27.458825] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   27.467037]  r6:00000000 r5:00000001 r4:00000000
[   27.471675] Code: f57ff04f e3130001 e1a00005 1afffff4 (e5973004)
[   27.477798] ---[ end trace 28edebdc9ffed6c0 ]---
[   27.482480] ------------[ cut here ]------------
[   27.487124] WARNING: CPU: 0 PID: 198 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x370
[   27.496471] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER3_P3 (Read): Data Access in User mode during Functional access
[   27.508081] Modules linked in: pvrsrvkm(O) ahci_platform(+) omap_aes_driver(+) libahci_platform libahci omap_sham(+) libata omap_wdt(+) sc)
[   27.548267] CPU: 0 PID: 198 Comm: systemd-udevd Tainted: G      D W  O    4.14.79-gbde58ab01e #10
[   27.557175] Hardware name: Generic DRA72X (Flattened Device Tree)
[   27.563291] Backtrace:
[   27.565754] [<c020b4dc>] (dump_backtrace) from [<c020b7c0>] (show_stack+0x18/0x1c)
[   27.573357]  r7:00000009 r6:60010193 r5:00000000 r4:c1053d10
[   27.579044] [<c020b7a8>] (show_stack) from [<c0931328>] (dump_stack+0x90/0xa4)
[   27.586300] [<c0931298>] (dump_stack) from [<c022b9cc>] (__warn+0xec/0x104)
[   27.593292]  r7:00000009 r6:c0bd48ec r5:00000000 r4:edc19680
[   27.598977] [<c022b8e0>] (__warn) from [<c022ba24>] (warn_slowpath_fmt+0x40/0x48)
[   27.606493]  r9:0000001b r8:ef1c5810 r7:c0bd4758 r6:00000002 r5:c0bd4818 r4:c0bd48bc
[   27.614271] [<c022b9e8>] (warn_slowpath_fmt) from [<c051bd20>] (l3_interrupt_handler+0x254/0x370)
[   27.623179]  r3:ef1c5680 r2:c0bd48bc
[   27.626767]  r4:80080003
[   27.629313] [<c051bacc>] (l3_interrupt_handler) from [<c027f5a4>] (__handle_irq_event_percpu+0x6c/0x134)
[   27.638834]  r10:c105570d r9:ef1c4200 r8:00000017 r7:edc197a4 r6:00000000 r5:ef1c4200
[   27.646695]  r4:ef1c5b80
[   27.649242] [<c027f538>] (__handle_irq_event_percpu) from [<c027f690>] (handle_irq_event_percpu+0x24/0x60)
[   27.658938]  r10:edc13600 r9:edc18000 r8:ef008000 r7:00000000 r6:c10093ac r5:ef1c4200
[   27.666799]  r4:ef1c4200
[   27.669346] [<c027f66c>] (handle_irq_event_percpu) from [<c027f70c>] (handle_irq_event+0x40/0x64)
[   27.678254]  r5:ef1c4264 r4:ef1c4200
[   27.681849] [<c027f6cc>] (handle_irq_event) from [<c0283020>] (handle_fasteoi_irq+0xac/0x160)
[   27.690410]  r7:00000000 r6:c10093ac r5:ef1c4264 r4:ef1c4200
[   27.696096] [<c0282f74>] (handle_fasteoi_irq) from [<c027e7f4>] (generic_handle_irq+0x2c/0x3c)
[   27.704745]  r7:00000000 r6:edc19970 r5:00000017 r4:c0e64b3c
[   27.710430] [<c027e7c8>] (generic_handle_irq) from [<c027ed7c>] (__handle_domain_irq+0x64/0xbc)
[   27.719168] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   27.727556]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19860 r5:fa21200c r4:c1004000
[   27.735333] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   27.742846] Exception stack(0xedc19860 to 0xedc198a8)
[   27.747920] 9860: c1059040 c1059040 00000000 00000000 00000202 00000013 00000000 ffffe000
[   27.756133] 9880: ef008000 edc18000 edc13600 edc1990c edc19910 edc198b0 c0230a1c c0201550
[   27.764343] 98a0: 60010113 ffffffff
[   27.767847]  r9:edc18000 r8:ef008000 r7:edc19894 r6:ffffffff r5:60010113 r4:c0201550
[   27.775628] [<c02014b0>] (__do_softirq) from [<c0230a1c>] (irq_exit+0xe0/0x158)
[   27.782969]  r10:edc13600 r9:edc18000 r8:ef008000 r7:00000000 r6:00000000 r5:00000013
[   27.790830]  r4:c0e64b3c
[   27.793375] [<c023093c>] (irq_exit) from [<c027ed80>] (__handle_domain_irq+0x68/0xbc)
[   27.801239] [<c027ed18>] (__handle_domain_irq) from [<c0201474>] (gic_handle_irq+0x44/0x80)
[   27.809627]  r9:edc18000 r8:fa213000 r7:fa212000 r6:edc19970 r5:fa21200c r4:c1004000
[   27.817404] [<c0201430>] (gic_handle_irq) from [<c020c378>] (__irq_svc+0x58/0x8c)
[   27.824917] Exception stack(0xedc19970 to 0xedc199b8)
[   27.829989] 9960:                                     edc13b58 00000000 0000040a 0000040b
[   27.838202] 9980: edc13600 0000000b edc13b58 ffffe000 edc18000 bf000000 edc13600 edc199cc
[   27.846415] 99a0: edc199d0 edc199c0 c022f3b0 c094a000 60010113 ffffffff
[   27.853058]  r9:edc18000 r8:edc18000 r7:edc199a4 r6:ffffffff r5:60010113 r4:c094a000
[   27.860838] [<c0949fd8>] (_raw_spin_unlock_irq) from [<c022f3b0>] (do_exit+0xcc/0xa70)
[   27.868791] [<c022f2e4>] (do_exit) from [<c020bb04>] (die+0x340/0x37c)
[   27.875344]  r7:0000000b
[   27.877889] [<c020b7c4>] (die) from [<c020bb60>] (arm_notify_die+0x20/0x58)
[   27.884881]  r10:00000000 r9:edc18000 r8:edc19af0 r7:00000000 r6:00000007 r5:00001211
[   27.892742]  r4:c1008cdc
[   27.895287] [<c020bb40>] (arm_notify_die) from [<c02012f8>] (do_DataAbort+0xb4/0xb8)
[   27.903064] [<c0201244>] (do_DataAbort) from [<c020c2f0>] (__dabt_svc+0x50/0x80)
[   27.910489] Exception stack(0xedc19af0 to 0xedc19b38)
[   27.915561] 9ae0:                                     000346dc edc19bc0 00000000 00000000
[   27.923773] 9b00: 00000032 000346dc edc19bc0 edc7be10 c0c348e4 bf118280 00000000 edc19b64
[   27.931985] 9b20: edc19b68 edc19b40 c0707710 bf115294 40010093 ffffffff
[   27.938627]  r8:c0c348e4 r7:edc19b24 r6:ffffffff r5:40010093 r4:bf115294
[   27.945365] [<bf115238>] (omap_rtc_read_time [rtc_omap]) from [<c0707710>] (__rtc_read_time+0x4c/0xc0)
[   27.954711]  r9:bf118280 r8:bf118000 r7:edc19bc0 r6:edd90400 r5:edc19bc0 r4:edd90400
[   27.962489] [<c07076c4>] (__rtc_read_time) from [<c07077b8>] (rtc_read_time+0x34/0x48)
[   27.970439]  r7:edc19bc0 r6:edd90400 r5:edd905ac r4:00000000
[   27.976125] [<c0707784>] (rtc_read_time) from [<c070807c>] (__rtc_read_alarm+0x20/0x3f8)
[   27.984249]  r7:00000000 r6:edd90400 r5:ef20c610 r4:edc19c40
[   27.989933] [<c070805c>] (__rtc_read_alarm) from [<c0706ee0>] (__rtc_register_device+0x30/0x104)
[   27.998756]  r10:00000000 r9:bf118280 r8:bf118000 r7:00000000 r6:ef20c600 r5:ef20c610
[   28.006617]  r4:edd90400
[   28.009165] [<c0706eb0>] (__rtc_register_device) from [<bf1162a8>] (omap_rtc_probe+0x3c4/0x528 [rtc_omap])
[   28.018858]  r4:edc7be10
[   28.021408] [<bf115ee4>] (omap_rtc_probe [rtc_omap]) from [<c0655658>] (platform_drv_probe+0x58/0xb4)
[   28.030668]  r9:00000004 r8:bf118078 r7:fffffdfb r6:bf118078 r5:ffffffed r4:ef20c610
[   28.038447] [<c0655600>] (platform_drv_probe) from [<c0653b78>] (driver_probe_device+0x218/0x2e4)
[   28.047356]  r7:00000000 r6:c10953f0 r5:c10953ec r4:ef20c610
[   28.053041] [<c0653960>] (driver_probe_device) from [<c0653cf0>] (__driver_attach+0xac/0xb0)
[   28.061515]  r10:edc7d724 r9:00000000 r8:00000001 r7:00000000 r6:ef20c644 r5:bf118078
[   28.069376]  r4:ef20c610 r3:00000000
[   28.072969] [<c0653c44>] (__driver_attach) from [<c0651ee0>] (bus_for_each_dev+0x54/0xa4)
[   28.081181]  r7:00000000 r6:c0653c44 r5:bf118078 r4:00000000
[   28.086866] [<c0651e8c>] (bus_for_each_dev) from [<c065351c>] (driver_attach+0x24/0x28)
[   28.094903]  r6:c10327b0 r5:edc80980 r4:bf118078
[   28.099541] [<c06534f8>] (driver_attach) from [<c0653038>] (bus_add_driver+0x190/0x214)
[   28.107580] [<c0652ea8>] (bus_add_driver) from [<c0654660>] (driver_register+0x80/0xfc)
[   28.115617]  r7:edc7bd00 r6:bf11b000 r5:00000000 r4:bf118078
[   28.121303] [<c06545e0>] (driver_register) from [<c06555b0>] (__platform_driver_register+0x48/0x50)
[   28.130385]  r5:00000000 r4:c10327b0
[   28.133981] [<c0655568>] (__platform_driver_register) from [<bf11b01c>] (omap_rtc_driver_init+0x1c/0x1000 [rtc_omap])
[   28.144633]  r5:00000000 r4:ffffe000
[   28.148228] [<bf11b000>] (omap_rtc_driver_init [rtc_omap]) from [<c02019fc>] (do_one_initcall+0x4c/0x170)
[   28.157839] [<c02019b0>] (do_one_initcall) from [<c02b1a80>] (do_init_module+0x68/0x1f8)
[   28.165965]  r8:00000001 r7:edc7bd00 r6:edc7d700 r5:00000001 r4:bf1180c0
[   28.172698] [<c02b1a18>] (do_init_module) from [<c02b092c>] (load_module+0x1f0c/0x24ac)
[   28.180735]  r7:bf1180c0 r6:edc7d700 r5:00000001 r4:edc19f40
[   28.186422] [<c02aea20>] (load_module) from [<c02b10c8>] (SyS_finit_module+0xa4/0xbc)
[   28.194287]  r10:0000017b r9:edc18000 r8:c0207e44 r7:0000017b r6:b6ee40c4 r5:00000007
[   28.202148]  r4:00000000
[   28.204695] [<c02b1024>] (SyS_finit_module) from [<c0207c40>] (ret_fast_syscall+0x0/0x4c)
[   28.212905]  r6:00000000 r5:00000001 r4:00000000
[   28.217540] ---[ end trace 28edebdc9ffed6c1 ]---
 _____                    _____           _         _
              |___|                    |___|
am57xx-evm login: root
root@am57xx-evm:~#
root@am57xx-evm:~# [   94.571033] rtc-ds1307 0-0068: write secs=29, mins=35, hours=3, mday=16, mon=11, year=118, wday=0
[   94.579954] rtc-ds1307 0-0068: write: 29 35 03 01 16 12 18
[   94.588859] rtc-ds1307 0-0068: read: 30 35 03 01 16 12 18
[   94.595527] rtc-ds1307 0-0068: read secs=30, mins=35, hours=3, mday=16, mon=11, year=118, wday=0
[  133.169796] NET: Registered protocol family 15
[  133.441619] Initializing XFRM netlink socket
[  193.123000] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound@0[0]'
[  193.150752] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound@0[0]'
[  193.171379] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[  193.179192] asoc-simple-card sound@0: ASoC: no DMI vendor name!
[  193.202326] extcon-usb-gpio extcon_usb1: GPIO lookup for consumer id
[  193.208715] extcon-usb-gpio extcon_usb1: using device tree for GPIO lookup
[  193.231370] extcon-usb-gpio extcon_usb1: lookup for GPIO id failed
[  193.237588] extcon-usb-gpio extcon_usb1: GPIO lookup for consumer vbus
[  193.267238] extcon-usb-gpio extcon_usb1: using device tree for GPIO lookup
[  193.280792] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/extcon_usb1[0]'
[  193.289709] of_get_named_gpiod_flags: can't parse 'vbus-gpio' property of node '/extcon_usb1[0]'
[  193.320741] extcon-usb-gpio extcon_usb1: using lookup tables for GPIO lookup
[  193.327825] extcon-usb-gpio extcon_usb1: lookup for GPIO vbus failed
[  193.351164] extcon-usb-gpio extcon_usb2: GPIO lookup for consumer id
[  193.357553] extcon-usb-gpio extcon_usb2: using device tree for GPIO lookup
[  193.385715] extcon-usb-gpio extcon_usb2: lookup for GPIO id failed
[  193.398878] extcon-usb-gpio extcon_usb2: GPIO lookup for consumer vbus
[  193.410921] extcon-usb-gpio extcon_usb2: using device tree for GPIO lookup
[  193.417837] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/extcon_usb2[0]'
[  193.450745] of_get_named_gpiod_flags: can't parse 'vbus-gpio' property of node '/extcon_usb2[0]'
[  193.459573] extcon-usb-gpio extcon_usb2: using lookup tables for GPIO lookup
[  193.480760] extcon-usb-gpio extcon_usb2: lookup for GPIO vbus failed
root@am57xx-evm:~# [  889.935926] Unable to handle kernel paging request at virtual address 36000460
[  889.943190] Unable to handle kernel paging request at virtual address 08800123
[  889.950443] Unable to handle kernel paging request at virtual address 08800123
[  889.957695] Unable to handle kernel paging request at virtual address 08800123
[  889.964947] Unable to handle kernel paging request at virtual address 08800123
[  889.972198] Unable to handle kernel paging request at virtual address 08800123
[  889.979450] Unable to handle kernel paging request at virtual address 08800123
[  889.986702] Unable to handle kernel paging request at virtual address 08800123
[  889.993954] Unable to handle kernel paging request at virtual address 08800123
[  890.001206] Unable to handle kernel paging request at virtual address 08800123
[  890.008457] Unable to handle kernel paging request at virtual address 08800123
[  890.015709] Unable to handle kernel paging request at virtual address 08800123
[  890.022961] Unable to handle kernel paging request at virtual address 08800123
[  890.030212] Unable to handle kernel paging request at virtual address 08800123
[  890.037463] Unable to handle kernel paging request at virtual address 08800123
[  890.044714] Unable to handle kernel paging request at virtual address 08800123
[  890.051965] Unable to handle kernel paging request at virtual address 08800123
[  890.059217] Unable to handle kernel paging request at virtual address 08800123
[  890.066468] Unable to handle kernel paging request at virtual address 08800123
BR
Prasad
