Other Parts Discussed in Thread: TLV62084
Hi
As referenced to previous post link "https://e2e.ti.com/support/processors/f/791/t/790414 "
Due to some debugging constraints i m not using "TPS65911" module for powering 66AK2G12 .CAN i power up device different core voltages (e.g. 3.3V, 1.8V,1.35V, and CVDD 1.0V) simultaneously by using separate LDO's
Sir . NOW I found that in TI evaluation board for K2G_ICE (industrial communication engine) separate devices are used to power up SoC (66AK2G12) instead of single module.
schematic diagram attached.P04_K2G_PowerSupply1.pdf
HOW in evaluation board control the timing of power-up sequence described in device datasheet Section 5.9.1 .by using separate device for each core voltages...?
BEST REGARDS THANKS
