RTOS/TDA3XEVM: How to change the CPU frequency of DSP
Part Number: TDA3XEVM
Tool/software: TI-RTOS
Hi  :
   SDK Version : PROCESSOR_SDK_VISION_03_04_00_00
   CCS Version  : CCS8
    Question:
    Can you tell us how to Change and  Check "DSP(C66x) operating frequency" with "CCS " & SBL(qspi).
    If you are using CCS you need to call gel APIs to change and check frequency.
    If you are using SBL you can call PM APIs to set various OPPs.
    Can you specify what exactly are you using?
    Rishabh
  • Rishabh Thank you for your reply
    I know the frequency can change in the gel ,but i can not find the exactly file
    Can you tell me how to use gelAPIS and PMAPIS ?
    I try to use CCS Scipt M4 To check DSP frequency ,but  useless
    the image is CCS  windows about gel file uder :
  • I Find the gel and change the fre , Provide everyone with reference
    I trying to find SBL Change dsp fre now
    On TDA3, DSP and EVE clocks can be derived from different DPLLs.
    Hence you might not see change in frequency of a particular DPLL while changing the OPP.
    You need to build SBL for a different OPP.
    Please see chapter 9 of SBL user guide: processors.wiki.ti.com/images/b/b7/TDA_SBL_UserGuide.pdf
    Rishabh
