Linux/TDA2EVM5777: Kernel configuration to enable BLE USB Dongle
Part Number: TDA2EVM5777
Tool/software: Linux
I have Vision SDK version 03_03_00_00 running on TDA2x EVM.
Vision SDK Image was built keeping MAKECONFIG as 'tda2xx_evm_linux_all' in Linux+BIOS mode.
I'm running few ADAS Application on EVM and want to send the ADAS_EVENTS to a smart-phone via BLE.
I have a BLE CSR 4.0 USB Dongle which I'm planning to connect to TDA2x board through a OTG cable.
I want to know what changes are required in .../vision_sdk/build$ make kernel_menuconfig to enable the BLE USB Dongle.
I have attached the lsusb output for reference.
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          224 Wireless
  bDeviceSubClass         1 Radio Frequency
  bDeviceProtocol         1 Bluetooth
  bMaxPacketSize0        64
  idVendor           0x0a12 Cambridge Silicon Radio, Ltd
  idProduct          0x0001
  bcdDevice           88.91
  iManufacturer           0
  iProduct                2 CSR8510 A10
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          177
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       224 Wireless
      bInterfaceSubClass      1 Radio Frequency
      bInterfaceProtocol      1 Bluetooth
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0000  1x 0 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0009  1x 9 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0011  1x 17 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0019  1x 25 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0021  1x 33 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0031  1x 49 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Status:     0x0001
  Self Powered
Uday M S
  • Hi Uday,
    The Vision SDK version 03_03_00_00 release does not support or tested for  the BLE USB Dongle. Hence we would be unable to provide any suggestion to enable the required configuration to support this linux kernel build.
    Suggest to look for resources online on how this could be enabled for your use-case... some links:
    https://cateee.net/lkddb/web-lkddb/USB_BLUETOOTH_TTY.html
    https://cateee.net/lkddb/web-lkddb/BT_HCIBTUSB.html
    https://cateee.net/lkddb/web-lkddb/BT.html
    regards,
    Praveen
  • Hi Praveen,
    Thanks for the quick reply.
    1. I want to know if enabling the following in kernel_menuconfig will be of any use
    [*] Networking support ---> [CONFIG_NET]
    </M> Bluetooth subsystem support ---> [CONFIG_BT]
    <*/M> RFCOMM protocol support [CONFIG_BT_RFCOMM]
    [*] RFCOMM TTY support [CONFIG_BT_RFCOMM_TTY]
    <*/M> BNEP protocol support [CONFIG_BT_BNEP]
    [*] Multicast filter support [CONFIG_BT_BNEP_MC_FILTER]
    [*] Protocol filter support [CONFIG_BT_BNEP_PROTO_FILTER]
    <*/M> HIDP protocol support [CONFIG_BT_HIDP]
    <*/M> RF switch subsystem support ---> [CONFIG_RFKILL]
    along with Device Drivers -> USB support -> USB Serial Converter support : enable USB Generic Serial Driver, USB Serial Simple Driver, USB FTDI Single Port
    2. Also can you let me know if the newer versions of Vision SDK supports or tested for BLE USB Dongle ?
    Uday M S
  • Hi Uday,
    Regarding 1:
    We cannot comment on the setting you are trying as this has not been tried out by us. We don't see anything that is blocking from the TDA2X platform point of view. It is just the software support that need to be enabled for your use-case. We suggest you to look out for resources available online for this.
    Regarding 2:
    No, there is no plan to support or test the BLE USB dongle with newer/future version of Vision SDK.
    -Praveen
