Part Number: AM4379
According to the BOM, the 24 MHz crystal (ref. Y1) used in this board is
Suntsu Inc SCM18B-24.000MHz TR
Is it possibile to have its datasheet?
Thanks in advance.
Part Number: AM4379
Thanks in advance.
Hi Andrea,
According to Suntsu the part number in the BOM is a legacy part number. The data sheet for the new part number is attached.
Regards, BillSUNTSU-SXT324.pdf
Hi Bill,
thanks a lot for your prompt response. The coding rules of the new crystal are different so I'm not sure about how to decode the old part number. Do you confirm that the old crystal's load capacitance is 18pF?
If CL=18pF, I have two further questions:
Thank you.
Hi Andrea,
Most likely the specification for the new crystal part number do not match the specification of the old part number. I don't have the original data sheet so I can't compare. We will have to find a new crystal the next time we need to build the board. You should find a crystal that matches the specification listed in the data manual.
Regards, Bill
Hi Bill,
what about Rbias?
What criteria do you recommend in order to determine if it should be used or not?
Hi Andrea,
As stated, the bias resistor is generally not needed by crystals available today. If it is needed, that information us usually found in the crystal datasheet. Adding the footprint for the resistor will ensure that you have the option in case the crystal you choose needs the resistor. If the resistor is not needed, you can remove the pads in later revisions.
Regards, Bill
