Tool/software: Linux
I have developed a use case for linux with following configuration
IssCapture -> Dup -> IssM2mIsp -> Display_Video
IssM2mIsp -> Alg_IssAewb
Dup -> Null (A15)
GrpxSrc -> Display_Grpx
but when I am running it it is giving me following error
#### Sensor Config time = 2131 msec ####
[HOST] [IPU2 ] 66.599127 s: SYSTEM: NOTIFY: Send Event to [IPU2][9] failed !!! (status = -14)
[HOST] [IPU2 ] 66.599249 s: Assertion @ Line: 232 in system_ipc_bios_ipc.c: (Bool)FALSE : failed !!!
Can anyone help me to resolve this issue?
I have also attached .c file please find it for reference.
Vishal
/****************************************************************************** Copyright (c) [2012 - 2017] Texas Instruments Incorporated All rights reserved not granted herein. Limited License. Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive license under copyrights and patents it now or hereafter owns or controls to make, have made, use, import, offer to sell and sell ("Utilize") this software subject to the terms herein. With respect to the foregoing patent license, such license is granted solely to the extent that any such patent is necessary to Utilize the software alone. The patent license shall not apply to any combinations which include this software, other than combinations with devices manufactured by or for TI ("TI Devices"). No hardware patent is licensed hereunder. Redistributions must preserve existing copyright notices and reproduce this license (including the above copyright notice and the disclaimer and (if applicable) source code license limitations below) in the documentation and/or other materials provided with the distribution Redistribution and use in binary form, without modification, are permitted provided that the following conditions are met: * No reverse engineering, decompilation, or disassembly of this software is permitted with respect to any software provided in binary form. * Any redistribution and use are licensed by TI for use only with TI Devices. * Nothing shall obligate TI to provide you with source code for the software licensed and provided to you in object code. If software source code is provided to you, modification and redistribution of the source code are permitted provided that the following conditions are met: * Any redistribution and use of the source code, including any resulting derivative works, are licensed by TI for use only with TI Devices. * Any redistribution and use of any object code compiled from the source code and any resulting derivative works, are licensed by TI for use only with TI Devices. Neither the name of Texas Instruments Incorporated nor the names of its suppliers may be used to endorse or promote products derived from this software without specific prior written permission. DISCLAIMER. THIS SOFTWARE IS PROVIDED BY TI AND TI�S LICENSORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL TI AND TI�S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ******************************************************************************/ /******************************************************************************* * INCLUDE FILES ******************************************************************************* */ #include "chains_issEncodeNull_Display_priv.h" #include <src/hlos/adas/include/chains.h> #include <src/hlos/common/chains_common.h> #include <src/hlos/adas/include/chains_common_iss.h> /** ******************************************************************************* * * \brief SingleCameraFrameCopyObject * * This structure contains all the LinksId's and create Params. * The same is passed to all create, start, stop functions. * ******************************************************************************* */ typedef struct { chains_issEncodeNull_DisplayObj ucObj; UInt32 displayWidth; UInt32 displayHeight; Chains_Ctrl *chainsCfg; AppCtrl_IssParams appCtrlIssPrms; } chains_issEncodeNull_DisplayAppObj; char gChains_issEncodeNull_Display_runTimeMenu[] = { "\r\n " "\r\n ====================" "\r\n Chains Run-time Menu" "\r\n ====================" "\r\n " "\r\n 0: Stop Chain" "\r\n " "\r\n p: Print Performance Statistics " "\r\n " "\r\n Enter Choice: " "\r\n " }; /** ******************************************************************************* * * \brief Set Display Create Parameters * * This function is used to set the Display params. * It is called in Create function. It is advisable to have * chains_issEncodeNull_Display_ResetLinkPrms prior to set params * so all the default params get set. * * \param pPrm [IN] DisplayLink_CreateParams * ******************************************************************************* */ Void chains_issEncodeNull_Display_SetDisplayPrms( Chains_DisplayType displayType, DisplayLink_CreateParams *pPrm_Video, DisplayLink_CreateParams *pPrm_Grpx, UInt32 displayWidth, UInt32 displayHeight, UInt32 captureWidth, UInt32 captureHeight) { UInt32 dispWidth, dispHeight; if(pPrm_Video) { /* To maintain the aspect ratio, change the display tarWidth */ dispWidth = captureWidth * displayHeight / captureHeight; dispHeight = displayHeight; if (dispWidth > displayWidth) { dispWidth = displayWidth; dispHeight = displayWidth * captureHeight / captureWidth; } pPrm_Video->rtParams.tarWidth = dispWidth; pPrm_Video->rtParams.tarHeight = dispHeight; pPrm_Video->rtParams.posX = (displayWidth - dispWidth) / 2U; pPrm_Video->rtParams.posY = (displayHeight - dispHeight) / 2U; pPrm_Video->displayId = DISPLAY_LINK_INST_DSS_VID1; } if (pPrm_Grpx) { pPrm_Grpx->displayId = DISPLAY_LINK_INST_DSS_GFX1; } } /** ******************************************************************************* * * \brief Set link Parameters * * It is called in Create function of the auto generated use-case file. * * \param pUcObj [IN] Auto-generated usecase object * \param appObj [IN] Application specific object * ******************************************************************************* */ Void chains_issEncodeNull_Display_SetAppPrms( chains_issEncodeNull_DisplayObj *pUcObj, Void *appObj) { chains_issEncodeNull_DisplayAppObj *pObj = (chains_issEncodeNull_DisplayAppObj*)appObj; AppCtrl_IssParams *pAppCtrlIssPrms; if ((strncmp(pObj->chainsCfg->sensorName, SENSOR_OMNIVISION_OV2775_TIDA1130, ISS_SENSORS_MAX_NAME) != 0) && (strncmp(pObj->chainsCfg->sensorName, SENSOR_SONY_IMX390_UB953_D3, ISS_SENSORS_MAX_NAME) != 0)) { Vps_printf("Sensor %s is not support for this usecase \n", pObj->chainsCfg->sensorName); return; } ChainsCommon_GetDisplayWidthHeight( pObj->chainsCfg->displayType, &pObj->displayWidth, &pObj->displayHeight); pAppCtrlIssPrms = &pObj->appCtrlIssPrms; AppCtrlLink_IssParams_Init(pAppCtrlIssPrms); strncpy(pAppCtrlIssPrms->issSensorInfo.sensorName, pObj->chainsCfg->sensorName, ISS_SENSORS_MAX_NAME); pAppCtrlIssPrms->issSensorInfo.numCh = 1; pAppCtrlIssPrms->issSensorInfo.ispOpMode = pObj->chainsCfg->ispOpMode; // pAppCtrlIssPrms->issSensorInfo.simcopOpMode = // ISSM2MSIMCOP_LINK_OPMODE_MAXNUM; pAppCtrlIssPrms->issCaptLinkId = pUcObj->IssCaptureLinkID; Vps_printf("1. pAppCtrlIssPrms->issIspLinkId\n"); pAppCtrlIssPrms->issIspLinkId = pUcObj->IssM2mIspLinkID; Vps_printf("2. pAppCtrlIssPrms->issIspLinkId\n"); pAppCtrlIssPrms->issAewbLinkId = pUcObj->Alg_IssAewbLinkID; //pAppCtrlIssPrms->issSimcopLinkId = pUcObj->IssM2mSimcopLinkID; System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_ISS_SENSOR_CREATE, &pAppCtrlIssPrms->issSensorInfo, sizeof(AppUtils_Obj), TRUE); memcpy(&pAppCtrlIssPrms->issCaptLinkPrms, &pUcObj->IssCapturePrm, sizeof(IssCaptureLink_CreateParams)); memcpy(&pAppCtrlIssPrms->issIspLinkPrms, &pUcObj->IssM2mIspPrm, sizeof(IssM2mIspLink_CreateParams)); #if 1 memcpy(&pAppCtrlIssPrms->issAewbLinkPrms, &pUcObj->Alg_IssAewbPrm, sizeof(AlgorithmLink_IssAewbCreateParams)); // memcpy(&pAppCtrlIssPrms->issSimcopLinkPrms, &pUcObj->IssM2mSimcopPrm, // sizeof(IssM2mSimcopLink_CreateParams)); #endif System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_INIT_ISS_PARAMS, pAppCtrlIssPrms, sizeof(AppCtrl_IssParams), TRUE); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 230\n"); memcpy(&pUcObj->IssCapturePrm, &pAppCtrlIssPrms->issCaptLinkPrms, sizeof(IssCaptureLink_CreateParams)); memcpy(&pUcObj->IssM2mIspPrm, &pAppCtrlIssPrms->issIspLinkPrms, sizeof(IssM2mIspLink_CreateParams)); #if 1 memcpy(&pUcObj->Alg_IssAewbPrm, &pAppCtrlIssPrms->issAewbLinkPrms, sizeof(AlgorithmLink_IssAewbCreateParams)); // memcpy(&pAppCtrlIssPrms->issSimcopLinkPrms, &pUcObj->IssM2mSimcopPrm, // sizeof(IssM2mSimcopLink_CreateParams)); #endif // pUcObj->IssM2mSimcopPrm.channelParams[0u].operatingMode = // ISSM2MSIMCOP_LINK_OPMODE_VTNF; pUcObj->IssM2mIspPrm.channelParams[0u]. enableOut[ISSM2MISP_LINK_OUTPUTQUE_IMAGE_RSZ_B] = 0; /* Display requires around 4 buffers for 60fps chain, so increasing simcop output buffers to 4 */ pUcObj->IssM2mIspPrm.channelParams[0].numBuffersPerCh = 4u; pUcObj->IssM2mIspPrm.allocBufferForDump = TRUE; pUcObj->IssCapturePrm.allocBufferForRawDump = TRUE; // pUcObj->IssM2mSimcopPrm.allocBufferForDump = TRUE; pUcObj->Alg_IssAewbPrm.runAewbOnlyForOneCh = TRUE; pUcObj->Alg_IssAewbPrm.chId = 0U; #if 1 /* Null link to dump bit stream data */ pUcObj->NullPrm.dumpDataType = NULL_LINK_COPY_TYPE_FILE; strncpy(pUcObj->NullPrm.nameDataFile[0], "/home/1280x720_00.h264", 260U); #endif ChainsCommon_SetGrpxSrcPrms(&pUcObj->GrpxSrcPrm, pObj->displayWidth, pObj->displayHeight); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 268\n"); chains_issEncodeNull_Display_SetDisplayPrms( pObj->chainsCfg->displayType, &pUcObj->Display_VideoPrm, &pUcObj->Display_GrpxPrm, pObj->displayWidth, pObj->displayHeight, pObj->displayWidth, pObj->displayHeight); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 275\n"); ChainsCommon_StartDisplayCtrl( pObj->chainsCfg->displayType, pObj->displayWidth, pObj->displayHeight); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 281\n"); } /** ******************************************************************************* * * \brief Start the capture display Links * * Function sends a control command to capture and display link to * to Start all the required links . Links are started in reverce * order as information of next link is required to connect. * System_linkStart is called with LinkId to start the links. * * \param pObj [IN] chains_issEncodeNull_DisplayAppObj * * \return SYSTEM_LINK_STATUS_SOK on success * ******************************************************************************* */ Void chains_issEncodeNull_Display_StartApp(chains_issEncodeNull_DisplayAppObj *pObj) { ChainsCommon_statCollectorReset(); ChainsCommon_memPrintHeapStatus(); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 305\n"); System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_ISS_SENSOR_START, &pObj->appCtrlIssPrms.issSensorInfo, sizeof(AppUtils_Obj), TRUE); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 305\n"); /* Sets Default ISP/SIMCOP Config from DCC */ System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_ISS_DEFAULT_CONFIG, &pObj->appCtrlIssPrms.issSensorInfo, sizeof(AppUtils_Obj), TRUE); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 317\n"); ChainsCommon_ReadAndParseDcc(&pObj->appCtrlIssPrms); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 319\n"); System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_SET_BOARD_MUXES, &pObj->appCtrlIssPrms.issSensorInfo, sizeof(AppUtils_Obj), TRUE); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 325\n"); chains_issEncodeNull_Display_Start(&pObj->ucObj); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 327\n"); ChainsCommon_prfLoadCalcEnable(TRUE, FALSE, FALSE); Vps_printf("1. pAppCtrlIssPrms->issIspLinkId 329\n"); } /** ******************************************************************************* * * \brief Delete the capture display Links * * Function sends a control command to capture and display link to * to delete all the prior created links * System_linkDelete is called with LinkId to delete the links. * * \param pObj [IN] chains_issEncodeNull_DisplayAppObj * ******************************************************************************* */ Void chains_issEncodeNull_Display_StopAndDeleteApp(chains_issEncodeNull_DisplayAppObj *pObj) { chains_issEncodeNull_Display_Stop(&pObj->ucObj); chains_issEncodeNull_Display_Delete(&pObj->ucObj); ChainsCommon_StopDisplayCtrl(); System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_ISS_SENSOR_STOP_AND_DELETE, &pObj->appCtrlIssPrms.issSensorInfo, sizeof(AppUtils_Obj), TRUE); /* Print the HWI, SWI and all tasks load */ /* Reset the accumulated timer ticks */ ChainsCommon_prfLoadCalcEnable(FALSE, TRUE, TRUE); } /** ******************************************************************************* * * \brief Single Channel Capture Display usecase function * * This functions executes the create, start functions * * Further in a while loop displays run time menu and waits * for user inputs to print the statistics or to end the demo. * * Once the user inputs end of demo stop and delete * functions are executed. * * \param chainsCfg [IN] Chains_Ctrl * ******************************************************************************* */ Void Chains_issEncodeNull_Display(Chains_Ctrl *chainsCfg) { char ch; UInt32 done = FALSE; chains_issEncodeNull_DisplayAppObj chainsObj; Vps_printf(" Entered Chains_issEncodeNull_Display \n"); chainsObj.chainsCfg = chainsCfg; /* Initialize Video Sensor, so that Algorithm can use Params from Vid Sensor layer */ chains_issEncodeNull_Display_Create(&chainsObj.ucObj, &chainsObj); chains_issEncodeNull_Display_StartApp(&chainsObj); System_linkControl(SYSTEM_LINK_ID_APP_CTRL, APP_CTRL_LINK_CMD_ENABLE_CSI_OUTPUT, NULL, 0, TRUE); while(!done) { Vps_printf(gChains_issEncodeNull_Display_runTimeMenu); ch = Chains_readChar(); switch(ch) { case '0': done = TRUE; break; case 'p': case 'P': ChainsCommon_PrintStatistics(); chains_issEncodeNull_Display_printStatistics(&chainsObj.ucObj); break; default: Vps_printf("\nUnsupported option '%c'. Please try again\n", ch); break; } } chains_issEncodeNull_Display_StopAndDeleteApp(&chainsObj); }
