Part Number: PROCESSOR-SDK-AM335X
I have integrated the LED_Blink skAM335x_arm_test code with UART_evmAM335x_arm_example code but after running the code led is not blinking. Please suggest me solution.
Gaurav
Gaurav
There is an integrated example of LED blink and UART already existing in the SDK as part of the RTOS template app for AM335x.
http://software-dl.ti.com/processor-sdk-rtos/esd/docs/latest/rtos/index_examples_demos.html
Please check that out.
Quite frankly, your post doesn`t provide much information other than the problem you are facing so I don`t think we can provide guidance on what is the issue with your software, Please provide some insight into how you integrated the code and if you have observed anything when debugging the code. Did you check clock, pinmux, module registers or indicate if the code hangs at some location. What platform are you running the code on TI evaluation HW or custom board design.
Rahul
