RTOS/AM5728: VPS loopback example issue
Part Number: AM5728
Other Parts Discussed in Thread: TVP5158
Tool/software: TI-RTOS
Hi there,
I use CCS v9 and I want to try to build vps examples using AM572xevm.
I succeeded to import CCS project from txt file at "C:\ti\pdk_am57xx_1_0_14\packages\ti\drv\vps\examples\ccsprojects\am572x\bios".
And I build the binary file and load to evm board.
It seems be go well to load program and run on the board.
However, during loop execution, the following error is displayed via UART.
LOOPBACK_APP: Sample Application - STARTS !!!
*** VPDMA Firmware Loading... ***
VPDMA Firmware already loaded !!!
VPDMA Firmware Version = 0x4d0001b8
VPDMA List Busy Status = 0x00000000
*** VPDMA Firmware Load Success ***
src/bsputils_app.c @ Line 507: Error: File io init failed!!
 Build time            : [04:22:48 Apr  6 2019]
 FVID2 Version         : [FVID_02_01_00_01]
 BSP Version           : [PDK_01_10_00_xx]
 Platform              : [EVM]
 SOC                   : [AM572X]
 SOC Revision          : [ES2.0]
 FT Revision           : [5]
 Package               : [UNKNOWN]
 Core                  : [A15]
 Board Detected        : [AM572X GP EVM]
 EEPROM Base Board Name: [AM572PM_]
 Base Board Revision   : [REV A]
 Daughter Card Revision: [REV A]
C:/ti/pdk_am57xx_1_0_14/packages/ti/drv/vps/examples/loopback/src/Loopback_main.c @ Line 2171: LOOPBACK_APP: System Init Failed!!!
How do I fix these errors?
  • The error I asked earlier was resolved when I inserted the SD card.
    But run the program as it is, the following error will be displayed.
    LOOPBACK_APP: LpbkApp_init() - DONE !!!
    Select test to run as per below table:
    0: OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> BGR888 -> DSS Video1 -> DPI1 LCD
    1: OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> ARGB32_8888 -> DSS Video1 -> DPI1 LCD
    2: OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> YUV420SP -> DSS Video1 -> DPI1 LCD
    3: OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    4: LI OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    5: SII9127 -> VIP1_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    6: SII9127 -> VIP1_S0_PORTA (1920x1080@60FPS) -> DSS Video1 -> DPI1 LCD
    7: ADV7611 -> VIP1_S0_PORTA (1920x1080@60FPS) -> DSS Video1 -> DPI1 LCD
    8: MULDESCAM1_OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    9: MULDESCAM2_OV1063x -> VIP1_S1_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    10: MULDESCAM3_OV1063x -> VIP2_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    11: MULDESCAM4_OV1063x -> VIP3_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    12: MULDESCAM5_OV1063x -> VIP2_S1_PORTB (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    13: MULDESCAM6_OV1063x -> VIP3_S1_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 LCD
    14: MULDESCAM1to4 -> VIP -> DSS Video1 -> DPI1 LCD
    15: MULDESCAM1to6 -> VIP -> DSS Video1 -> DPI1 LCD
    16: MULDESCAM1to4 -> VIP -> DSS Video1 -> DPI1 HDMI 1920x1080@60FPS
    17: MULDESCAM1(GW4200_IMX290@24FPS) -> VIP -> DSS Video1 -> DPI1 HDMI 1920x1080@60FPS
    18: MULDESCAM1to6 -> VIP -> DSS Video1 -> DPI1 HDMI 1920x1080@60FPS
    19: TVP5158 -> VIP1_S0_PORTA (PAL) -> DSS Video1 -> DPI1 LCD
    20: OV1063x -> VIP1_S0_PORTA (1280x720@30FPS) -> DSS Video1 -> DPI1 HDMI 1920x1080@60FPS
    21: Virtio: VIP1_S0_PORTA -> DSS Video1 -> DPI1 @ D1 (720x480), YUYV422I
    22: OV2659 -> VIP2_S1_PORTB (1280x720@30FPS) -> YUYV422 -> DSS Video1 -> DPI1 LCD
    23: OV1063x -> VIP2_S0_PORTA (1280x720@30FPS) -> YUYV422 -> DSS Video1 -> DPI1 LCD
    24: Auto Run
    100: EXIT
    Enter Test to Run (in UART console):
    0
    0
    LOOPBACK_APP: CAPT HANDLES 1: DISP HANDLES 1: MODE 0004 : RUN COUNT 30: OUTPUT:36 !!
    saveRaw(0, 0x81700000, "D:\\loopbackOption0Inst0Ch0Str0_bgr888_prog_packed_1920_1080.tigf", 9331200, 32, false);
    src/bsp_board.c @ Line 490: Invalid device driver ID - devDrvId: 4611 drvInstId: 0!!
    src/bsp_board.c @ Line 524: Invalid device driver ID - devDrvId: 4611 drvInstId: 0!!
    src/bsp_board.c @ Line 557: Invalid device driver ID!!
    ov1063x/src/bspdrv_ov1063xApi.c @ Line 301: Invalid I2C instance ID
    7793: Assertion @ Line: 2587 in C:/ti/pdk_am57xx_1_0_14/packages/ti/drv/vps/examples/loopback/src/Loopback_test.c: instObj->decHandle != NULL : failed !!!
    The case of if I choiced "1",
    1
    1
    LOOPBACK_APP: CAPT HANDLES 1: DISP HANDLES 1: MODE 0004 : RUN COUNT 30: OUTPUT:23 !!
    saveRaw(0, 0x81700000, "D:\\loopbackOption1Inst0Ch0Str0_argb8888_prog_packed_1920_1080.tigf", 12441600, 32, false);
    50469: Assertion @ Line: 2587 in C:/ti/pdk_am57xx_1_0_14/packages/ti/drv/vps/examples/loopback/src/Loopback_test.c: instObj->decHandle != NULL : failed !!!
    How can I fix this errors?
    There is no CCS project for AM572x GP EVM, all the CCS projects are for IDK571/2/4 loopback with ARM/DSP/M4. You can't directly use IDK CCS project for GP EVM.
    Please look at http://software-dl.ti.com/processor-sdk-rtos/esd/docs/latest/rtos/index_device_drv.html#vps-drivers: Those GP EVM examples are built by make. Please make sure the loopback example using make worked as expected.
    Then, if you want to create CCS project for GP EVM, please look at FAQ section.
    Regards, Eric
  • I tried to make, but I always get errors as below.
    c:\ti\pdk_am57xx_1_0_14\packages>pdksetupenv.bat
    Environment Configuration:
    SDK_INSTALL_PATH : __SDK__INSTALL_DIR__
    GMAKE_INSTALL_PATH : __SDK__INSTALL_DIR__/xdctools_3_51_01_18_core
    RULES_MAKE : __SDK__INSTALL_DIR__/pdk_am57xx_1_0_14/packages/Rules.make
    c:\ti\pdk_am57xx_1_0_14\packages>make vps
    makefile:16: __SDK__INSTALL_DIR__/pdk_am57xx_1_0_14/packages/Rules.make: No such file or directory
    make: *** No rule to make target  `__SDK__INSTALL_DIR__/pdk_am57xx_1_0_14/packages/Rules.make' . Stop.
    How can I fix this make errors?
    Sorry, I could to build by make.
    C:\ti\pdk_am57xx_1_0_14\packages>gmake vps
    So, I tried to load and execute on evm below files from CCS .
    C:\ti\pdk_am57xx_1_0_14\packages\ti\binary\vps_examples_loopbackBareMetal\bin\evmAM572x\vps_examples_loopbackBareMetal_ipu1_0_release.xem4
    But I got same erros again.
     Platform              : [EVM]
     SOC                   : [AM572X]
     FT Revision           : [5]
     Package               : [UNKNOWN]
     Core                  : [A15]
    How can I fix these errors?
    Best Reards,
    I thought the code has a bug running on IPU core, but it should work on A15 or C66x, did you try those cores or your goal is to run on IPU?
    Regards, Eric
  • Hi Eric,
    I don’t need to run on IPU.
    I think that is fine run on A15 or C66x.
    But, I tried to load binary file to A15, I got errors as below.
    I only got ”vps_examples_loopbackBareMetal_ipu1_0_release.xem4.map” and ”vps_examples_loopbackBareMetal_ipu1_0_release.xem4” at "vps_examples_loopbackBareMetal" directory, by "make vps" command.
    I could build vps example for A15, and I tried to load evm module.
    But, I still got same errors as I ran on IPU.
    The same thing happens with any other vps sample.
    DISP_DSS_APP: Sample Application - STARTS !!!
    Build time : [10:50:50 Jun 18 2019]
    Platform : [EVM]
    SOC : [AM572X]
    FT Revision : [5]
    Package : [UNKNOWN]
    Core : [A15]
    src/DisplayDssWb_main.c @ Line 306: DISP_DSS_APP: System Init Failed!!!
    I hope to solve it.
    The above error disappeared when I inserted the SD card to evm.
    However, when I proceeded, new problems occurred.
    24: Auto Run
    100: EXIT
    1
    1
    29463: Assertion @ Line: 2587 in src/Loopback_test.c: instObj->decHandle != NULL : failed !!!
    How does LOOPBACK_APP work in the first place?
    Is it not to display the image from the camera on the LCD?
    What is an SD Card Needed for?
    These are my questions. We will also seek to resolve this occurring error.
    I am checking with our test team and will update here.
    Regards, Eric
    I tested the vps_examples_loopback_a15_0_release and vps_examples_loopbackBareMetal_a15_0_release on AM572x GP EVM A15 core, there is no problem, I used test case 24 (auto run). The cases 1-22 were skipped, the case 23 was actually ran, I was able to see what captured by camera displayed on LCD and SD card was used to save the capture.
    UART log:
    VPDMA Firmware Address = 0xa0011fc0
    VPDMA Load Address = 0x4897d004
    VPDMA Load Address = 0x4899d004
    VPDMA Load Address = 0x489bd004
    VPDMA Load Address = 0x489dd004
    Build time : [10:29:27 Jun 19 2019]
    Platform : [EVM]
    SOC : [AM572X]
    FT Revision : [3]
    Package : [UNKNOWN]
    Core : [A15]
    23: OV1063x -> VIP2_S0_PORTA (1280x720@30FPS) -> YUYV422 -> DS S Video1 -> DPI1 LCD
    24: Auto Run
    100: EXIT
    23
    saveRaw(0, 0x81700000, "D:\\loopbackOption23Inst4Ch0Str0_bgr888_prog_packed_1920_1080.tigf", 9331200, 32, false);
    LOOPBACK_APP: VIP 4: VID SENSOR 1203 (0x30): a635:0000:7fa2
    LOOPBACK_APP: Capture create complete!!
    Display Create Status: VENC Standard: CUSTOM, Width: 800, Height: 480
    Display Create Status: Minimum Number of Buffers to Prime: 1
    LOOPBACK_APP: Display create complete!!
    LOOPBACK_APP: Starting loopback ... !!!
    LOOPBACK_APP: Loopback in progress ... DO NOT HALT !!!
    LOOPBACK_APP: Stopping loopback ... DONE !!!
    Execution Statistics
    Execution time : 50.997 s
    Total field Count : 0 (0 fields/sec)
    Avg CPU Load : 0 %
    Capture Instance 4 Statistics
    Capture Inst 4 Status: Number of request queued : 903
    Capture Inst 4 Status: Number of request dequeued: 898
    Capture Inst 4 Status: Overflow Count : 0
    CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat F id Desc
    (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Re peat Error
    04.0.00 | 903 898 898 898 0 17 17 0 1280/1280 720/720 0 0 0 0
    Display Instance 0 Statistics
    Display Inst 0 Status: Number of request queued : 899
    Display Inst 0 Status: Number of request dequeued: 898
    Display Inst 0 Status: Displayed frame count : 1784
    Display Inst 0 Status: Frame repeat count : 886
    Dispaly Controller Error Status
    LCD1 SyncLost count : 0
    LCD2 SyncLost2 count : 0
    LCD3 SyncLost3 count : 0
    TV SyncLost count : 0
    OCP Error count : 0
    LOOPBACK_APP: Display delete complete!!
    LOOPBACK_APP: Capture delete complete!!
    120934: LOAD: CPU: 1%, HWI: 0%, SWI:0%
    Regards, Eric
  • Also attached the binary for you to check if your HW problem:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/vps_5F00_examples_5F00_loopback_5F00_a15_5F00_0_5F00_release.xa15fg
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/vps_5F00_examples_5F00_loopbackBareMetal_5F00_a15_5F00_0_5F00_release.xa15fg
    Regards, Eric
    Thank you for your testing.
    I formatted SD card on FAT32, so it could run program well.
    I could see captured by camera displayed on LCD case 23.
    Thank you very much for your advice.
