RTOS/TDA2EXEVM: error: symbol "atan2" redefined
Part Number: TDA2EXEVM
Tool/software: TI-RTOS
I want to build the opencvcanny use case which based on VSDK v3.6 using "tda2xx_evm_bios_all" configuration with ENABLE_OPENCV=yes option.
SDK version: v0306
Config: tda2xx_evm_bios_all
Platform: TDA2XX_EVM / rtos
But it outputs the following library linking error when run "make vision_sdk" command.
I know that both libraries (libm.lib and rts6600_elf.lib) default support from SDK.
Why does it result in the error of redefinition (atan2)?
Could you help teach me how to solve the problem? Thanks.
BRs,
Sam Hsieh
error: symbol "atan2" redefined: first defined in
   "/home/sam/test/TI_SDK_VISION_V03_06/ti_components/open_compute/opencl_rtos_
   am57xx_01_01_10_00/packages/ti/opencl/usr/share/ti/opencl/libm.lib<e_atan2.o
   >"; redefined in
   "/home/sam/test/TI_SDK_VISION_V03_06/ti_components/cg_tools/linux/ti-cgt-c60
   00_8.2.4/lib/rts6600_elf.lib<atan2.obj>"
error: symbol "cosh" redefined: first defined in
   am57xx_01_01_10_00/packages/ti/opencl/usr/share/ti/opencl/libm.lib<e_cosh.o>
   "; redefined in
   00_8.2.4/lib/rts6600_elf.lib<cosh.obj>"
