Linux/TDA2SX: MMC boot issue
Part Number: TDA2SX
Tool/software: Linux
Hello all,
                 We are working on a custom board based on tda2sx.We are trying to boot from SD card and it stopping at " Waiting for root device PARTUUID=6c40cfeb-02..." . Im attaching the full log too.What could be the issue?
U-Boot 2016.05 (Jun 18 2019 - 17:49:59 +0530)
CPU  : DRA752-GP ES2.0
Model: TI DRA742
Board: DRA74x EVM REV <NULL>
DRAM:  1 GiB
NAND:  0 MiB
MMC:   Timed out in wait_for_bb: status=1000
pcf8575_i2c_write_le16 i2c write failed to addr 21
OMAP SD/MMC: 0, OMAP SD/MMC: 1
tps65903x: could not set LDO1 voltage.
*** Warning - bad CRC, using default environment
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:195/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:   Could not get PHY for ethernet@48484000: addr 2
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot:  0
=> boot
Saving Environment to MMC...
Writing to redundant MMC(0)... done
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
3310280 bytes read in 1140 ms (2.8 MiB/s)
113295 bytes read in 63 ms (1.7 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3282c8 ]
   Loading Device Tree to 8ffe1000, end 8ffffa8e ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.4.84 (zinal@FSETBLR1LX043) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Wed Jun 19 12:22:22 IST 2019
CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Machine model: TI DRA742
Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
Reserved memory: regions without no-map are not yet supported
Reserved memory: created CMA memory pool at 0x0000000094000000, size 80 MiB
Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
Reserved memory: created CMA memory pool at 0x000000009f000000, size 16 MiB
Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
Reserved memory: created DMA memory pool at 0x00000000a8000000, size 64 MiB
Reserved memory: initialized node cmem@A8000000, compatible id shared-dma-pool
cma: Reserved 24 MiB at 0x00000000be400000
Forcing write-allocate cache policy for SMP
Memory policy: Data cache writealloc
OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
DRA752 ES2.0
PERCPU: Embedded 12 pages/cpu @ef71a000 s18688 r8192 d22272 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 243456
Kernel command line: console=ttyO0,115200n8 root=PARTUUID=6c40cfeb-02 rw lpj=61475 rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 382468K/979968K available (4675K kernel code, 259K rwdata, 976K rodata, 288K init, 258K bss, 376316K reserved, 221184K cma-reserved, )
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc058d014   (5653 kB)
      .init : 0xc058e000 - 0xc05d6000   ( 288 kB)
      .data : 0xc05d6000 - 0xc0616d60   ( 260 kB)
       .bss : 0xc0618000 - 0xc0658b90   ( 259 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
        Build-time adjustment of leaf fanout to 32.
NR_IRQS:16 nr_irqs:16 16
ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
OMAP clockevent source: timer1 at 32786 Hz
Architected cp15 timer(s) running at 6.14MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
Switching to timer-based delay loop, resolution 162ns
clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
OMAP clocksource: 32k_counter at 32768 Hz
Console: colour dummy device 80x30
WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
This ensures that you still see kernel messages. Please
update your kernel commandline.
Calibrating delay loop (skipped) preset value.. 12.29 BogoMIPS (lpj=61475)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
/cpus/cpu@1 missing clock-frequency property
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x800082c0 - 0x80008320
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (24.59 BogoMIPS).
CPU: All CPU(s) started in HYP mode.
CPU: Virtualization extensions available.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
omap_hwmod: l3_main_2 using broken dt data from ocp
omap_hwmod: vpe: no dt node
------------[ cut here ]------------
WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2523 0xc0598e34()
omap_hwmod: vpe: doesn't have mpu register target base
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.84 #1
Hardware name: Generic DRA74X (Flattened Device Tree)
Backtrace:
Function entered at [<c00124a8>] from [<c0012694>]
 r7:000009db r6:60000013 r5:00000000 r4:c05fcdbc
Function entered at [<c001267c>] from [<c01d67c8>]
Function entered at [<c01d6744>] from [<c002fa6c>]
 r7:000009db r6:c04fcc24 r5:00000009 r4:ef07de60
Function entered at [<c002f9e0>] from [<c002fad0>]
 r8:c0618000 r7:00000000 r6:00000000 r5:00000000 r4:c05e6348
Function entered at [<c002fa9c>] from [<c0598e34>]
 r3:c04ff18b r2:c04fced6
Function entered at [<c0598c70>] from [<c0021988>]
 r10:00000000 r9:c05cfb64 r8:c0618000 r7:00000000 r6:c0598c70 r5:c05dcd70
 r4:c05e6348
Function entered at [<c0021948>] from [<c0599898>]
 r7:c05c1820 r6:00000000 r5:c0618000 r4:c059986c
Function entered at [<c059986c>] from [<c0009728>]
Function entered at [<c0009690>] from [<c058ed84>]
 r9:c05cfb64 r8:c0618000 r7:c05c1820 r6:0000009d r5:c0618000 r4:00000002
Function entered at [<c058ec64>] from [<c0492b0c>]
 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0492af8 r4:c0618000
Function entered at [<c0492af8>] from [<c000f188>]
 r5:c0492af8 r4:00000000
---[ end trace 3bf577f2d545868e ]---
omap_hwmod: wd_timer2: no dt node
omap_hwmod: wd_timer2: doesn't have mpu register target base
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W       4.4.84 #1
Backtrace:
 r8:c0618000 r7:00000000 r6:00000000 r5:00000000 r4:c05e1398
 r3:c04fc611 r2:c04fced6
 r4:c05e1398
---[ end trace 3bf577f2d545868f ]---
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
OMAP GPIO hardware version 0.1
irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
omap-gpmc 50000000.gpmc: GPMC revision 6.0
gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
omap-gpmc 50000000.gpmc: nand: invalid 'nand-bus-width'
omap-gpmc 50000000.gpmc: failed to probe DT children
omap-gpmc: probe of 50000000.gpmc failed with error -22
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
omap4_sram_init:Unable to allocate sram needed to handle errata I688
omap4_sram_init:Unable to get sram pool needed to handle errata I688
OMAP DMA hardware revision 0.0
omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
edma 43300000.edma: memcpy is disabled
edma 43300000.edma: TI EDMA DMA engine driver
omap-iommu 40d01000.mmu: 40d01000.mmu registered
omap-iommu 40d02000.mmu: 40d02000.mmu registered
omap-iommu 58882000.mmu: 58882000.mmu registered
omap-iommu 55082000.mmu: 55082000.mmu registered
omap-iommu 41501000.mmu: 41501000.mmu registered
omap-iommu 41502000.mmu: 41502000.mmu registered
SCSI subsystem initialized
palmas 0-0058: IRQ missing: skipping irq request
omap_i2c 48070000.i2c: controller timed out
palmas: probe of 0-0058 failed with error -110
omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
Bluetooth: Core ver 2.21
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
bounce: pool size: 64 pages
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
omap_i2c 48072000.i2c: timeout waiting for bus ready
Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
console [ttyS0] enabled
4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 304, base_baud = 3000000) is a 8250
48424000.serial: ttyS8 at MMIO 0x48424000 (irq = 305, base_baud = 3000000) is a 8250
[drm] Initialized drm 1.1.0 20060810
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
[drm] Initialized vdrm 1.0.0 20110917 on minor 0
omapdss_dss 58000000.dss: master bind failed: -517
loop: module loaded
vmemexp device MAJOR num = 246
vmemexp class registered
/dev/vmemexp device registered
ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
SCSI Media Changer driver v0.25
ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi host0: ahci
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 345
davinci_mdio 48485000.mdio: davinci mdio revision 1.6
davinci_mdio 48485000.mdio: no live phy, scanning all
davinci_mdio: probe of 48485000.mdio failed with error -5
cpsw 48484000.ethernet: Detected MACID = 34:15:13:a3:6f:ce
cpsw 48484000.ethernet: cpsw: Detected MACID = 34:15:13:a3:6f:cf
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
i2c /dev entries driver
ata1: SATA link down (SStatus 0 SControl 300)
omap_i2c 48060000.i2c: timeout waiting for bus ready
Invalid product ID code
mmc0: MAN_BKOPS_EN bit is not set
mmc0: new DDR MMC card at address 0001
mmcblk0: mmc0:0001 H8G4a2 7.28 GiB
mmcblk0boot0: mmc0:0001 H8G4a2 partition 1 4.00 MiB
mmcblk0boot1: mmc0:0001 H8G4a2 partition 2 4.00 MiB
clock: dpll_abe_ck failed transition to 'locked'
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:680 0xc03a15f8()
Modules linked in:
Backtrace:
 r7:000002a8 r6:20000093 r5:00000000 r4:c05fcdbc
 r7:000002a8 r6:c054b6fc r5:00000009 r4:00000000
Function entered at [<c002f9e0>] from [<c002fb3c>]
 r8:ef781b88 r7:c05e3000 r6:c06185e0 r5:80000093 r4:ef02ca00
Function entered at [<c002fb18>] from [<c03a15f8>]
Function entered at [<c03a15cc>] from [<c03a17ac>]
 r5:80000093 r4:ef1f3500
Function entered at [<c03a1780>] from [<c0020c18>]
 r5:fffffff0 r4:c05e64b0
Function entered at [<c0020bf8>] from [<c00213f8>]
 r7:c05e3000 r6:c06185e0 r5:fffffff0 r4:c05e64b0
Function entered at [<c00211dc>] from [<c0021ad8>]
 r7:00000000 r6:a0000093 r5:c05e6510 r4:c05e64b0
Function entered at [<c0021aac>] from [<c0022a00>]
 r7:00000000 r6:00000001 r5:ef269a40 r4:00000000
Function entered at [<c00229a0>] from [<c0022a3c>]
 r7:00000000 r6:c0022a24 r5:ef26ae10 r4:ef26ae10
Function entered at [<c0022a24>] from [<c02c12b8>]
 r5:ef26ae10 r4:ef26ae74
Function entered at [<c02c127c>] from [<c02c134c>]
 r7:00000000 r6:ef26ae10 r5:ef218410 r4:ef26ae10
Function entered at [<c02c12e0>] from [<c02c208c>]
 r7:00000000 r6:c0022a24 r5:ef218410 r4:ef26ae10
Function entered at [<c02c1d38>] from [<c02c21a8>]
 r10:00000000 r9:c05d003c r8:ef781b88 r7:60000013 r6:00000004 r5:ef26ae74
 r4:ef26ae10
Function entered at [<c02c2154>] from [<c03a85f8>]
 r7:eeab7690 r6:c06105c0 r5:ef26ae10 r4:ef26ae10
Function entered at [<c03a8588>] from [<c02baae4>]
 r10:00000000 r9:c05d003c r8:c06105c0 r7:00000000 r6:c06105c0 r5:ef26ae10
 r4:c03a8588
Function entered at [<c02baa8c>] from [<c02b90c4>]
 r7:00000000 r6:c0651124 r5:00000000 r4:ef26ae10
Function entered at [<c02b8fac>] from [<c02b92b8>]
 r9:c05d003c r8:c0618000 r7:c06061d0 r6:c06105c0 r5:ef26ae44 r4:ef26ae10
Function entered at [<c02b9248>] from [<c02b77e8>]
 r7:c06061d0 r6:c02b9248 r5:c06105c0 r4:00000000
Function entered at [<c02b7774>] from [<c02b8c24>]
 r6:eeab0f80 r5:00000000 r4:c06105c0
Function entered at [<c02b8c04>] from [<c02b87e8>]
Function entered at [<c02b8714>] from [<c02b9b48>]
 r7:c05c1834 r6:00000000 r5:c0618000 r4:c06105c0
Function entered at [<c02b9aa4>] from [<c02ba9fc>]
 r5:c0618000 r4:c05b47e4
Function entered at [<c02ba9c4>] from [<c05b47fc>]
Function entered at [<c05b47e4>] from [<c0009728>]
 r9:c05d003c r8:c0618000 r7:c05c1834 r6:0000009d r5:c0618000 r4:00000007
---[ end trace 3bf577f2d5458690 ]---
omap_hwmod: atl: _wait_target_ready failed: -16
WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 0xc01f886c()
44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
Modules linked in:
Backtrace:
 r7:00000093 r6:20000193 r5:00000000 r4:c05fcdbc
 r7:00000093 r6:c051d7ff r5:00000009 r4:ef07dad0
 r8:80080003 r7:c051d744 r6:c051d69a r5:ef211450 r4:00000000
Function entered at [<c002fa9c>] from [<c01f886c>]
 r3:ef2112c0 r2:c051d7d1
Function entered at [<c01f863c>] from [<c00699f4>]
 r10:c0616928 r9:ef781b88 r8:00000000 r7:00000017 r6:ef05ac00 r5:00000000
 r4:ef2117c0
Function entered at [<c00699b4>] from [<c0069b24>]
 r10:00000000 r9:ef781b88 r8:ef008000 r7:00000017 r6:ef05ac60 r5:ef05ac60
 r4:ef05ac00
Function entered at [<c0069ae4>] from [<c006cf1c>]
 r7:00000017 r6:ef05ac60 r5:c05dd030 r4:ef05ac00
Function entered at [<c006ce6c>] from [<c0069168>]
 r7:00000017 r6:c05d23f8 r5:00000000 r4:00000000
Function entered at [<c0069148>] from [<c0069470>]
Function entered at [<c00693dc>] from [<c0009450>]
 r9:ef781b88 r8:ef07dd10 r7:fa213000 r6:ef07dc70 r5:c05d87fc r4:fa212000
Function entered at [<c0009400>] from [<c00130c0>]
Exception stack(0xef07dc70 to 0xef07dcb8)
dc60:                                     60000013 c054d130 ef07dd10 c0653bc0
dc80: c0653bc0 ef781b88 ef07dd70 c054d130 ef07dd10 ef781b88 00000000 ef07dccc
dca0: ef07dcd0 ef07dcc0 c0398254 c0496af0 60000013 ffffffff
 r7:ef07dca4 r6:ffffffff r5:60000013 r4:c0496af0
Function entered at [<c0496adc>] from [<c0398254>]
Function entered at [<c0398230>] from [<c03982bc>]
 r9:ef781b88 r8:00000000 r7:eeab7690 r6:ef07dd70 r5:00000000 r4:00000000
Function entered at [<c03982ac>] from [<c0399904>]
Function entered at [<c03998d4>] from [<c0399be4>]
 r10:00000000 r9:c05d003c r8:ef781b88 r7:eeab7690 r6:ef07dd70 r5:00000000
 r4:00000000
Function entered at [<c0399bb8>] from [<c03a8628>]
 r4:c03a8588
---[ end trace 3bf577f2d5458691 ]---
Modules linked in:
Backtrace:
 r7:00000093 r6:c051d7ff r5:00000009 r4:ef07db58
 r10:c0616928 r9:eeab7740 r8:00000000 r7:00000017 r6:ef05ac00 r5:00000000
 r4:ef2117c0
 r10:ef781e34 r9:eeab7740 r8:ef008000 r7:00000017 r6:ef05ac60 r5:ef05ac60
 r4:ef05ac00
 r9:eeab7740 r8:ef781b88 r7:fa213000 r6:ef07dcf8 r5:c05d87fc r4:fa212000
Exception stack(0xef07dcf8 to 0xef07dd40)
dce0:                                                       ef781b88 c054d130
dd00: 00000000 00000000 00000000 00000003 ef07dd70 eeab7690 ef781b88 eeab7740
dd20: ef781e34 ef07dd5c ef07dd48 ef07dd48 c0399be4 c03998d8 20000013 ffffffff
 r7:ef07dd2c r6:ffffffff r5:20000013 r4:c03998d8
 r4:c03a8588
---[ end trace 3bf577f2d5458692 ]---
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
omap_voltage_late_init: Voltage driver support not added
Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
Power Management for TI OMAP4+ devices.
Registering SWP/SWPB emulation handler
dmm 4e000000.dmm: initialized all PAT entries
hctosys: unable to open rtc device (rtc0)
evm_1v8: disabling
aic_dvdd: disabling
vmmcwl_fixed: disabling
pbias_mmc_omap5: disabling
Murugan S
  • Hi Murugan,
    can you enable additional mmc debug info as described in this document and see if it give some directions where the problem might be:
    Also can you make sure you have modified the device tree according to your board layout. In particular the voltage supply, you may refer to this part of dra7-evm.dts for an example:
    &mmc1 {
            status = "okay";
            vmmc-supply = <&evm_3v3_sd>;
            vmmc_aux-supply = <&ldo1_reg>;
    Yordan
  • Hi Yordan,
                                I enabled the mmc debug in menuconfig but could see any additional prints.Regarding the power supply,we are using tps659039.Im not sure if my configuration is correct.I'm attaching my dts file.Please have a look.
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    /dts-v1/;
    #include "dra74x.dtsi"
    #include "dra7-evm-common.dtsi"
    	model = "TI DRA742";
    	compatible = "ti,dra7-evm", "ti,dra742", "ti,dra74", "ti,dra7";
    	memory {
    		device_type = "memory";
    		reg = <0x0 0x80000000 0x0 0x40000000>; /* 1536 MB to 1024MB ITS */
    	reserved_mem: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		ipu2_cma_pool: ipu2_cma@95800000 {
    			compatible = "shared-dma-pool";
    			reg = <0x0 0x95800000 0x0 0x3800000>;
    			reusable;
    			status = "okay";
    		dsp1_cma_pool: dsp1_cma@99000000 {
    			reg = <0x0 0x99000000 0x0 0x4000000>;
    			reusable;
    			status = "okay";
    		ipu1_cma_pool: ipu1_cma@9d000000 {
    			reg = <0x0 0x9d000000 0x0 0x2000000>;
    			reusable;
    			status = "okay";
    		dsp2_cma_pool: dsp2_cma@9f000000 {
    			reg = <0x0 0x9f000000 0x0 0x800000>;
    			reusable;
    			status = "okay";
    	aliases {
    		i2c7 = &disp_ser;
    	evm_1v8_sw: fixedregulator-evm_1v8 {
    		compatible = "regulator-fixed";
    		regulator-name = "evm_1v8";
    		vin-supply = <&smps9_reg>;
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    	evm_3v3_sd: fixedregulator-sd {
    		regulator-name = "evm_3v3_sd";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		enable-active-high;
    		gpio = <&pcf_gpio_21 5 GPIO_ACTIVE_HIGH>;
    	/*evm_3v3_sw: fixedregulator-evm_3v3_sw {*/
    	evm_3v3_sw: fixedregulator-evm_3v3 {
    		regulator-name = "evm_3v3_sw";
    		vin-supply = <&sysen1>;
    	aic_dvdd: fixedregulator-aic_dvdd {
    		/* TPS77018DBVT */
    		regulator-name = "aic_dvdd";
    		vin-supply = <&evm_3v3_sw>;
    	vmmcwl_fixed: fixedregulator-mmcwl {
    		regulator-name = "vmmcwl_fixed";
    		gpio = <&gpio5 8 0>;	/* gpio5_8 */
    		startup-delay-us = <70000>;
    		enable-active-high;
    	vtt_fixed: fixedregulator-vtt {
    		regulator-name = "vtt_fixed";
    		regulator-min-microvolt = <1350000>;
    		regulator-max-microvolt = <1350000>;
    		regulator-always-on;
    		regulator-boot-on;
    		enable-active-high;
    	/*	vin-supply = <&sysen2>;*/
    		gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
            extcon_usb: extcon_usb1 {
                    compatible = "linux,extcon-usb-gpio";
                    id-gpio = <&gpio5 8 GPIO_ACTIVE_HIGH>;
    	extcon_usb2: extcon_usb2 {
    		id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
    &tpd12s015 {
    	compatible = "ti,dra7evm-tpd12s015";
    	pinctrl-names = "i2c", "ddc";
    	pinctrl-0 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_i2c>;
    	pinctrl-1 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_ddc>;
    	gpios = <&pcf_hdmi 4 GPIO_ACTIVE_HIGH>,	/* P4, CT CP HPD */
    		<&pcf_hdmi 5 GPIO_ACTIVE_HIGH>,	/* P5, LS OE */
    		<&gpio7 12 GPIO_ACTIVE_HIGH>;	/* gpio7_12/sp1_cs2, HPD */
    	ddc-i2c-bus = <&i2c2>;
    	mcasp-gpio = <&mcasp8>;
    &dra7_pmx_core {
    	hdmi_i2c_sel_pin: pinmux_hdmi_i2c_sel_pin {
    		pinctrl-single,pins = <
    			/* this pin is used as a GPIO via mcasp */
    			0x2fc   (PIN_OUTPUT | MUX_MODE1) /* mcasp8_axr2 */
    	hdmi_i2c_pins_i2c: pinmux_hdmi_i2c_pins_default {
    			0x408   (PIN_INPUT | MUX_MODE0) /* i2c2_sda.i2c2_sda */
    			0x40c   (PIN_INPUT | MUX_MODE0) /* i2c2_scl.i2c2_scl */
    	hdmi_i2c_pins_ddc: pinmux_hdmi_i2c_pins_ddc {
    			0x408   (PIN_INPUT | MUX_MODE1) /* i2c2_sda.hdmi1_ddc_scl */
    			0x40c   (PIN_INPUT | MUX_MODE1) /* i2c2_scl.hdmi1_ddc_sda */
    	dcan1_pins_default: dcan1_pins_default {
    			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */
    			0x418   (PULL_UP | MUX_MODE1) /* wakeup0.dcan1_rx */
    	dcan1_pins_sleep: dcan1_pins_sleep {
    			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
    			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
    	/* mmc1_pins_default: pinmux_mmc1_default_pins { */ /*ITS */
    	mmc1_pins_default: mmc1_pins_default {
    			0x354 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
            /* ITS start */
            mmc1_pins_hs: pinmux_mmc1_hs_pins {
    	/* mmc1_pins_hs: pinmux_mmc1_hs_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_clk.clk */
    	/*		0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_cmd.cmd */
    	/*		0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_dat0.dat0 */
    	/*		0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_dat1.dat1 */
    	/*		0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_dat2.dat2 */
    	/*		0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)*/	/* mmc1_dat3.dat3 */
            mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
    	/* mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
    	/*	pinctrl-single,pins = <
    	/* 		0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_clk.clk */
    	/* 		0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_cmd.cmd */
    	/* 		0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat0.dat0 */
    	/* 		0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat1.dat1 */
    	/* 		0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat2.dat2 */
    	/* 		0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat3.dat3 */
            mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
                            0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_clk.mmc1_clk */
                            0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_cmd.mmc1_cmd */
                            0x35C (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_dat0.mmc1_dat0 */
                            0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_dat1.mmc1_dat1 */
                            0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_dat2.mmc1_dat2 */
                            0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE15 | MUX_MODE0)       /* mmc1_dat3.mmc1_dat3 */
    	/*mmc1_pins_sdr50: pinmux_mmc1_sdr50_pins {
    	/*		0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_clk.clk */
    	/*		0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_cmd.cmd */
    	/*		0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat0.dat0 */
    	/*		0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat1.dat1 */
    	/*		0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat2.dat2 */
    	/*		0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE10 | MUX_MODE0)	/* mmc1_dat3.dat3 */
            mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
                            0x354   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_clk.mmc1_clk */
                            0x358   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_cmd.mmc1_cmd */
                            0x35C   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_dat0.mmc1_dat0 */
                            0x360   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_dat1.mmc1_dat1 */
                            0x364   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_dat2.mmc1_dat2 */
                            0x368   (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE14 | MUX_MODE0)     /* mmc1_dat3.mmc1_dat3 */
    	/*mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
    	/*		0x354 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.clk */
    	/*		0x358 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.cmd */
    	/*		0x35c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.dat0 */
    	/*		0x360 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.dat1 */
    	/*		0x364 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.dat2 */
    	/*		0x368 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.dat3 */
            /* ITS end */
    	mmc1_pins_sdr104: pinmux_mmc1_sdr104_pins {
    	mmc2_pins_default: mmc2_pins_default {
    			0x9c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MUX_MODE1)	/* gpmc_a22.mmc2_dat7 */
    	mmc2_pins_hs: mmc2_pins_hs {
    	mmc2_pins_ddr_1_8v: pinmux_mmc2_ddr_1_8v_pins {
    			0x9c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
    	mmc2_pins_hs200_1_8v: mmc2_pins_hs200_1_8v {
    	mmc4_pins_default: mmc4_pins_default {
    			0x3e8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
    			0x3ec (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3f0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
    			0x3f4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
    			0x3f8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
    			0x3fC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	mmc4_pins_hs: mmc4_pins_hs {
    	mmc4_pins_sdr12: mmc4_pins_sdr12 {
    			0x3eC (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
    			0x3fc (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    	mmc4_pins_sdr25: mmc4_pins_sdr25 {
    &dra7_iodelay_core {
    	/* ITS Start */
            mmc1_iodelay_sdr104_conf: mmc1_iodelay_sdr104_conf {
                            0x620 (A_DELAY(560) | G_DELAY(365))     /* CFG_MMC1_CLK_OUT */
                            0x62C (A_DELAY(0)   | G_DELAY(0))       /* CFG_MMC1_CMD_OUT */
                            0x638 (A_DELAY(29)  | G_DELAY(0))       /* CFG_MMC1_DAT0_OUT */
                            0x644 (A_DELAY(0)   | G_DELAY(0))       /* CFG_MMC1_DAT1_OUT */
                            0x650 (A_DELAY(47)  | G_DELAY(0))       /* CFG_MMC1_DAT2_OUT */
                            0x65C (A_DELAY(30)  | G_DELAY(0))       /* CFG_MMC1_DAT3_OUT */
                            0x628 (A_DELAY(125) | G_DELAY(0))       /* CFG_MMC1_CMD_OEN */
                            0x634 (A_DELAY(43)  | G_DELAY(0))       /* CFG_MMC1_DAT0_OEN */
                            0x640 (A_DELAY(433) | G_DELAY(0))       /* CFG_MMC1_DAT1_OEN */
                            0x64C (A_DELAY(287) | G_DELAY(0))       /* CFG_MMC1_DAT2_OEN */
                            0x658 (A_DELAY(351) | G_DELAY(0))       /* CFG_MMC1_DAT3_OEN */
            mmc2_iodelay_hs200_1_8v_conf: mmc2_iodelay_hs200_1_8v_conf {
                            0x194 (A_DELAY(150) | G_DELAY(95))      /* CFG_GPMC_A19_OUT */
                            0x1AC (A_DELAY(250) | G_DELAY(0))       /* CFG_GPMC_A20_OUT */
                            0x1B8 (A_DELAY(125) | G_DELAY(0))       /* CFG_GPMC_A21_OUT */
                            0x1C4 (A_DELAY(100) | G_DELAY(0))       /* CFG_GPMC_A22_OUT */
                            0x1D0 (A_DELAY(870) | G_DELAY(415))     /* CFG_GPMC_A23_OUT */
                            0x1DC (A_DELAY(30)  | G_DELAY(0))       /* CFG_GPMC_A24_OUT */
                            0x1E8 (A_DELAY(200) | G_DELAY(0))       /* CFG_GPMC_A25_OUT */
                            0x1F4 (A_DELAY(200) | G_DELAY(0))       /* CFG_GPMC_A26_OUT */
                            0x200 (A_DELAY(0)   | G_DELAY(0))       /* CFG_GPMC_A27_OUT */
                            0x368 (A_DELAY(240) | G_DELAY(0))       /* CFG_GPMC_CS1_OUT */
                            0x190 (A_DELAY(695) | G_DELAY(0))       /* CFG_GPMC_A19_OEN */
                            0x1A8 (A_DELAY(924) | G_DELAY(0))       /* CFG_GPMC_A20_OEN */
                            0x1B4 (A_DELAY(719) | G_DELAY(0))       /* CFG_GPMC_A21_OEN */
                            0x1C0 (A_DELAY(824) | G_DELAY(0))       /* CFG_GPMC_A22_OEN */
                            0x1D8 (A_DELAY(877) | G_DELAY(0))       /* CFG_GPMC_A24_OEN */
                            0x1E4 (A_DELAY(446) | G_DELAY(0))       /* CFG_GPMC_A25_OEN */
                            0x1F0 (A_DELAY(847) | G_DELAY(0))       /* CFG_GPMC_A26_OEN */
                            0x1FC (A_DELAY(586) | G_DELAY(0))       /* CFG_GPMC_A27_OEN */
                            0x364 (A_DELAY(1039) | G_DELAY(0))      /* CFG_GPMC_CS1_OEN */
    	/* ITS end */
    	mmc1_iodelay_ddr50_rev11_conf: mmc1_iodelay_ddr50_rev11_conf {
    			0x618 (A_DELAY(572) | G_DELAY(540))	/* CFG_MMC1_CLK_IN */
    			0x624 (A_DELAY(0) | G_DELAY(600))	/* CFG_MMC1_CMD_IN */
    			0x630 (A_DELAY(403) | G_DELAY(120))	/* CFG_MMC1_DAT0_IN */
    			0x63c (A_DELAY(23) | G_DELAY(60))	/* CFG_MMC1_DAT1_IN */
    			0x648 (A_DELAY(25) | G_DELAY(60))	/* CFG_MMC1_DAT2_IN */
    			0x654 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_IN */
    			0x620 (A_DELAY(1525) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
    			0x628 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OEN */
    			0x62c (A_DELAY(55) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
    			0x634 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OEN */
    			0x638 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OUT */
    			0x640 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT1_OEN */
    			0x64c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
    			0x650 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OUT */
    			0x658 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OEN */
    			0x65c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
    	mmc1_iodelay_ddr50_rev20_conf: mmc1_iodelay_ddr50_rev20_conf {
    			0x618 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CLK_IN */
    			0x620 (A_DELAY(1271) | G_DELAY(0))	/* CFG_MMC1_CLK_OUT */
    			0x624 (A_DELAY(229) | G_DELAY(0))	/* CFG_MMC1_CMD_IN */
    			0x630 (A_DELAY(850) | G_DELAY(0))	/* CFG_MMC1_DAT0_IN */
    			0x638 (A_DELAY(20) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
    			0x63C (A_DELAY(468) | G_DELAY(0))	/* CFG_MMC1_DAT1_IN */
    			0x648 (A_DELAY(466) | G_DELAY(0))	/* CFG_MMC1_DAT2_IN */
    			0x64C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
    			0x654 (A_DELAY(399) | G_DELAY(0))	/* CFG_MMC1_DAT3_IN */
    			0x65C (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
    	mmc1_iodelay_sdr104_rev11_conf: mmc1_iodelay_sdr104_rev11_conf {
    			0x620 (A_DELAY(1063) | G_DELAY(17))	/* CFG_MMC1_CLK_OUT */
    			0x62c (A_DELAY(23) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
    			0x644 (A_DELAY(2) | G_DELAY(0))		/* CFG_MMC1_DAT1_OUT */
    	mmc1_iodelay_sdr104_rev20_conf: mmc1_iodelay_sdr104_rev20_conf {
    			0x620 (A_DELAY(600) | G_DELAY(400))	/* CFG_MMC1_CLK_OUT */
    			0x62c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OUT */
    			0x638 (A_DELAY(30) | G_DELAY(0))	/* CFG_MMC1_DAT0_OUT */
    	mmc2_iodelay_hs200_1_8v_rev11_conf: mmc2_iodelay_hs200_1_8v_rev11_conf {
    			0x190 (A_DELAY(621) | G_DELAY(600))	/* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(300) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(739) | G_DELAY(600))	/* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(812) | G_DELAY(600))	/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(240) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(954) | G_DELAY(600))	/* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(60)  | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(1340)| G_DELAY(420))	/* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(935) | G_DELAY(600))	/* CFG_GPMC_A24_OEN */
    			0x1dc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OUT */
    			0x1e4 (A_DELAY(525) | G_DELAY(600))	/* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(767) | G_DELAY(600))	/* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(225) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(565) | G_DELAY(600))	/* CFG_GPMC_A27_OEN */
    			0x200 (A_DELAY(60) | G_DELAY(0))	/* CFG_GPMC_A27_OUT */
    			0x364 (A_DELAY(969) | G_DELAY(600))	/* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(180) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
    	mmc2_iodelay_hs200_1_8v_rev20_conf: mmc2_iodelay_hs200_1_8v_rev20_conf {
    			0x190 (A_DELAY(274) | G_DELAY(0))       /* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(162) | G_DELAY(0))       /* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(401) | G_DELAY(0))       /* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(73) | G_DELAY(0))        /* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(465) | G_DELAY(0))       /* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(115) | G_DELAY(0))       /* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(633) | G_DELAY(0))       /* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(47) | G_DELAY(0))        /* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(935) | G_DELAY(280))     /* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(621) | G_DELAY(0))       /* CFG_GPMC_A24_OEN */
    			0x1e4 (A_DELAY(183) | G_DELAY(0))       /* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(467) | G_DELAY(0))       /* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(0) | G_DELAY(0))         /* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(262) | G_DELAY(0))       /* CFG_GPMC_A27_OEN */
    			0x200 (A_DELAY(46) | G_DELAY(0))        /* CFG_GPMC_A27_OUT */
    			0x364 (A_DELAY(684) | G_DELAY(0))       /* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(76) | G_DELAY(0))        /* CFG_GPMC_CS1_OUT */
    	mmc2_iodelay_ddr_1_8v_rev11_conf: mmc2_iodelay_ddr_1_8v_rev11_conf {
    			0x18c (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_IN */
    			0x1a4 (A_DELAY(274) | G_DELAY(240))	/* CFG_GPMC_A20_IN */
    			0x1b0 (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A21_IN */
    			0x1bc (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A22_IN */
    			0x1c8 (A_DELAY(514) | G_DELAY(360))	/* CFG_GPMC_A23_IN */
    			0x1d4 (A_DELAY(187) | G_DELAY(120))	/* CFG_GPMC_A24_IN */
    			0x1e0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_IN */
    			0x1ec (A_DELAY(0) | G_DELAY(60))	/* CFG_GPMC_A26_IN */
    			0x1f8 (A_DELAY(121) | G_DELAY(60))	/* CFG_GPMC_A27_IN */
    			0x360 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_IN */
    			0x190 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(174) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(168) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(136) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(879) | G_DELAY(0))	/* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OEN */
    			0x1e4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(34) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A27_OEN */
    			0x364 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(11) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
    	mmc2_iodelay_ddr_1_8v_rev20_conf: mmc2_iodelay_ddr_1_8v_rev20_conf {
    			0x18c (A_DELAY(270) | G_DELAY(0))	/* CFG_GPMC_A19_IN */
    			0x1a4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_IN */
    			0x1b0 (A_DELAY(170) | G_DELAY(0))	/* CFG_GPMC_A21_IN */
    			0x1bc (A_DELAY(758) | G_DELAY(0))	/* CFG_GPMC_A22_IN */
    			0x1c8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_IN */
    			0x1d4 (A_DELAY(81) | G_DELAY(0))	/* CFG_GPMC_A24_IN */
    			0x1e0 (A_DELAY(286) | G_DELAY(0))	/* CFG_GPMC_A25_IN */
    			0x1ec (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_IN */
    			0x1f8 (A_DELAY(123) | G_DELAY(0))	/* CFG_GPMC_A27_IN */
    			0x360 (A_DELAY(346) | G_DELAY(0))	/* CFG_GPMC_CS1_IN */
    			0x194 (A_DELAY(55) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1ac (A_DELAY(422) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(642) | G_DELAY(0))	/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OUT */
    			0x1c4 (A_DELAY(128) | G_DELAY(0))	/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A23_OUT */
    			0x1dc (A_DELAY(395) | G_DELAY(0))	/* CFG_GPMC_A24_OUT */
    			0x1f0 (A_DELAY(623) | G_DELAY(0))	/* CFG_GPMC_A26_OEN */
    			0x1fc (A_DELAY(54) | G_DELAY(0))	/* CFG_GPMC_A27_OEN */
    			0x368 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OUT */
    	mmc4_iodelay_ds_rev11_conf: mmc4_iodelay_ds_rev11_conf {
    			0x840 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_IN */
    			0x848 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(96) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x850 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OEN */
    			0x854 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART1_RTSN_OUT */
    			0x870 (A_DELAY(582) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x874 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OEN */
    			0x878 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_CTSN_OUT */
    			0x87c (A_DELAY(391) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x880 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OEN */
    			0x884 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RTSN_OUT */
    			0x888 (A_DELAY(561) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x88c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OEN */
    			0x890 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_RXD_OUT */
    			0x894 (A_DELAY(588) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    			0x898 (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OEN */
    			0x89c (A_DELAY(0) | G_DELAY(0))		/* CFG_UART2_TXD_OUT */
    	mmc4_iodelay_ds_rev20_conf: mmc4_iodelay_ds_rev20_conf {
    			0x84c (A_DELAY(307) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(785) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(613) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(683) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(835) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    	mmc4_iodelay_sdr12_hs_sdr25_rev11_conf: mmc4_iodelay_sdr12_hs_sdr25_rev11_conf {
    			0x848 (A_DELAY(2651) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(1572) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(1913) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(1721) | G_DELAY(0))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(1891) | G_DELAY(0))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(1919) | G_DELAY(0))	/* CFG_UART2_TXD_IN */
    	mmc4_iodelay_sdr12_hs_sdr25_rev20_conf: mmc4_iodelay_sdr12_hs_sdr25_rev20_conf {
    			0x848 (A_DELAY(1147) | G_DELAY(0))	/* CFG_UART1_CTSN_OUT */
    			0x84c (A_DELAY(1834) | G_DELAY(0))	/* CFG_UART1_RTSN_IN */
    			0x870 (A_DELAY(2165) | G_DELAY(0))	/* CFG_UART2_CTSN_IN */
    			0x87c (A_DELAY(1929) | G_DELAY(64))	/* CFG_UART2_RTSN_IN */
    			0x888 (A_DELAY(1935) | G_DELAY(128))	/* CFG_UART2_RXD_IN */
    			0x894 (A_DELAY(2172) | G_DELAY(44))	/* CFG_UART2_TXD_IN */
    &i2c1 {
    	status = "okay";
    	clock-frequency = <400000>;
    /* PMIC node for ITS FS:NIRAJ */
            tps659039: tps659039@58 {
                    compatible = "ti,tps659038";
                    reg = <0x58>;
                    interrupts = <GIC_SPI 2 IRQ_TYPE_NONE>;  /* IRQ_SYS_1N */
                    interrupt-controller;
                    #interrupt-cells = <2>;
                    ti,system-power-controller;
                    tps659039_pmic {
                            compatible = "ti,tps659038-pmic";
                            tps659039_regulators: regulators {
                                    smps123_reg: smps123 {
                                            /* VDD_MPU_1V15 */
                                            regulator-name = "smps123";
                                            regulator-min-microvolt = <1100000>;
                                            regulator-max-microvolt = <1200000>;
                                            regulator-boot-on;
    				smps45_reg: smps45 {
                                            /* VDD_DSPEVE_1V06 */
                                            regulator-name = "smps45";
                                            regulator-min-microvolt = <1020000>;
                                            regulator-boot-on;
    				smps6_reg: smps6 {
                                            /* VDD_GPU_1V06 */
                                            regulator-name = "smps6";
                                            regulator-boot-on;
    				smps8_reg: smps8 {
                                            /* VDD_IVA_1V06 */
                                            regulator-name = "smps8";
                                            regulator-boot-on;
    				smps7_reg: smps7 {
                                            /* VDD_CORE_1V15 */
                                            regulator-name = "smps7";
                                            regulator-boot-on;
    				smps9_reg: smps9 {
                                            /* VDDS_1V8 */
                                            regulator-name = "smps9";
                                            regulator-boot-on;
                                    ldo1_reg: ldo1 {
                                            /* MMC1_3V3  */
                                            regulator-name = "ldo1";
                                            regulator-boot-on;
                                            regulator-allow-bypass;
    				 ldo2_reg: ldo2 {
                                            /* VDSHV5_3V3 */
                                            regulator-name = "ldo2";
                                            regulator-boot-on;
                                    ldo3_reg: ldo3 {
                                            /* VDDA_1V8_PHY */
                                            regulator-name = "ldo3";
                                            regulator-boot-on;
                                    ldo9_reg: ldo9 {
                                            /* VDD_RTC_1V05 */
                                            regulator-name = "ldo9";
                                            regulator-min-microvolt = <10200000>;
                                            regulator-max-microvolt = <12000000>;
                                            regulator-boot-on;
    				ldoln_reg: ldoln {
                                            /* VDDA_1V8_LDOLN */
                                            regulator-name = "ldoln";
                                            regulator-boot-on;
    				ldousb_reg: ldousb {
                                            /* VUSB_3V3_SOC */
                                            regulator-name = "ldousb";
                                            regulator-boot-on;
    				/* REGEN1 is unused */
    				regen2: regen2 {
    					/* Needed for PMIC internal resources */
    					regulator-name = "regen2";
    					regulator-boot-on;
    				/* REGEN3 is unused */
    				sysen1: sysen1 {
    					/* PMIC_REGEN_3V3 */
    					regulator-name = "sysen1";
    					regulator-boot-on;
    				sysen2: sysen2 {
    					/* PMIC_REGEN_DDR */
    					regulator-name = "sysen2";
    					regulator-boot-on;
                    tps659039_power_button {
                            compatible = "ti,palmas-pwrbutton";
                            interrupt-parent = <&tps659039>;
                            interrupts = <1 IRQ_TYPE_NONE>;
                            wakeup-source;
                            ti,palmas-long-press-seconds = <6>;
    	pcf_lcd: gpio@20 {
    		compatible = "nxp,pcf8575";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupt-parent = <&gpio6>;
    		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    	pcf_gpio_21: gpio@21 {
    		compatible = "ti,pcf8575";
    		reg = <0x21>;
    		lines-initial-states = <0x1408>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	tlv320aic3106: tlv320aic3106@19 {
    		#sound-dai-cells = <0>;
    		compatible = "ti,tlv320aic3106";
    		reg = <0x19>;
    	        adc-settle-ms = <40>;
    		ai3x-micbias-vg = <1>;
    		status = "okay";
    		AVDD-supply = <&evm_3v3_sw>;
    		IOVDD-supply = <&evm_3v3_sw>;
    		DRVDD-supply = <&evm_3v3_sw>;
    		DVDD-supply = <&aic_dvdd>;
    	tlv320adc3101: tlv320aic3101@1b {
                   compatible = "ti,tlv320adc3101";
                   reg = <0x1b>;
                   adc3101-micbias-vg = <3>;               /* 3.3V */
    	       gpio-reset = <&gpio5 11 GPIO_ACTIVE_LOW>;
                   status = "okay";
    		/* RTC-MCP7940N */
    	mcp7940x:mcp7940x@6f {
    		compatible = "microchip,mcp7940x";
    		reg = <0x6f>;
    i2c_p3_exp: &i2c2 {
    	status = "okay";
    	pcf_hdmi: gpio@26 {
    		reg = <0x26>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		vin6_brdmux: p1 {
    			/* vin6_sel_s0: high: VIN6, low: audio */
    			gpio-hog;
    			gpios = <1 GPIO_ACTIVE_HIGH>;
    			output-low;
    			line-name = "vin6_sel_s0";
    	ov10633@37 {
    		compatible = "ovti,ov10633";
    		reg = <0x37>;
    		mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
    		port {
    			onboardLI: endpoint {
    				remote-endpoint = <&vin1a>;
    				hsync-active = <1>;
    				vsync-active = <1>;
    				pclk-sample = <0>;
    	disp_ser: serializer@1b {
    		compatible = "ti,ds90uh925q";
    		reg = <0x1b>;
    		#address-cells = <1>;
    		#size-cells = <0>;
    		status = "disabled";
    &mmc1 {
    	status = "okay";
    	vmmc-supply = <&evm_3v3_sw>;
    	/*vmmc-supply = <&evm_3v3_sd>;*/
    	bus-width = <4>;
    	 * SDCD signal is not being used here - using the fact that GPIO mode
    	 * is always hardwired.
    	/* ITS cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; */
    	ti,non-removable; /* ITS */
    	max-frequency = <192000000>;
            pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
            pinctrl-0 = <&mmc1_pins_default>;
            pinctrl-1 = <&mmc1_pins_hs>;
            pinctrl-2 = <&mmc1_pins_sdr12>;
            pinctrl-3 = <&mmc1_pins_sdr25>;
            pinctrl-4 = <&mmc1_pins_sdr50>;
            pinctrl-5 = <&mmc1_pins_ddr50>;
            pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_conf>;
    /* ITS
    	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50-rev11", "sdr104-rev11", "ddr50", "sdr104";
    	pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev11_conf>;
    	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev11_conf>;
    	pinctrl-7 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_rev20_conf>;
    	pinctrl-8 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
    &mmc2 {
    	status = "okay";
    	bus-width = <8>;
    	pinctrl-names = "default", "hs", "ddr_1_8v-rev11", "ddr_1_8v", "hs200_1_8v-rev11", "hs200_1_8v";
    	pinctrl-0 = <&mmc2_pins_default>;
    	pinctrl-1 = <&mmc2_pins_hs>;
            pinctrl-2 = <&mmc2_pins_ddr_1_8v>;
            pinctrl-3 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_conf>;
    /* ITS
    	pinctrl-2 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev11_conf>;
    	pinctrl-3 = <&mmc2_pins_ddr_1_8v &mmc2_iodelay_ddr_1_8v_rev20_conf>;
    	pinctrl-4 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev11_conf>;
    	pinctrl-5 = <&mmc2_pins_hs200_1_8v &mmc2_iodelay_hs200_1_8v_rev20_conf>;
    &mmc4 {
    	status = "okay";
    	vmmc-supply = <&vmmcwl_fixed>;
    	bus-width = <4>;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	ti,non-removable;
    	pinctrl-names = "default-rev11", "default", "hs-rev11", "hs", "sdr12-rev11", "sdr12", "sdr25-rev11", "sdr25";
    	pinctrl-0 = <&mmc4_pins_default &mmc4_iodelay_ds_rev11_conf>;
    	pinctrl-1 = <&mmc4_pins_default &mmc4_iodelay_ds_rev20_conf>;
    	pinctrl-2 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-3 = <&mmc4_pins_hs &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	pinctrl-4 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-5 = <&mmc4_pins_sdr12 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	pinctrl-6 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev11_conf>;
    	pinctrl-7 = <&mmc4_pins_sdr25 &mmc4_iodelay_sdr12_hs_sdr25_rev20_conf>;
    	#size-cells = <0>;
    	wlcore: wlcore@2 {
    		compatible = "ti,wl1835";
    		reg = <2>;
    		interrupt-parent = <&gpio5>;
    		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
    &oppdm_mpu {
    	vdd-supply = <&smps123_reg>;
    &oppdm_dspeve {
    	vdd-supply = <&smps45_reg>;
    &oppdm_gpu {
    	vdd-supply = <&smps6_reg>;
    &oppdm_ivahd {
    	vdd-supply = <&smps8_reg>;
    &oppdm_core {
    	vdd-supply = <&smps7_reg>;
    &omap_dwc3_2 {
    	extcon = <&extcon_usb2>;
    &elm {
    	status = "okay";
    &gpmc {
    	status = "okay";
    	ranges = <0 0 0x08000000 0x01000000>;	/* minimum GPMC partition = 16MB */
    	nand@0,0 {
    		compatible = "ti,omap2-nand";
    		reg = <0 0 4>;		/* device IO registers */
    		interrupt-parent = <&gpmc>;
    		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
    			     <1 IRQ_TYPE_NONE>; /* termcount */
    		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 pin */
    		ti,nand-ecc-opt = "bch8";
    		ti,elm-id = <&elm>;
    		nand-bus-width = <16>;
    		gpmc,device-width = <2>;
    		gpmc,sync-clk-ps = <0>;
    		gpmc,cs-on-ns = <0>;
    		gpmc,cs-rd-off-ns = <80>;
    		gpmc,cs-wr-off-ns = <80>;
    		gpmc,adv-on-ns = <0>;
    		gpmc,adv-rd-off-ns = <60>;
    		gpmc,adv-wr-off-ns = <60>;
    		gpmc,we-on-ns = <10>;
    		gpmc,we-off-ns = <50>;
    		gpmc,oe-on-ns = <4>;
    		gpmc,oe-off-ns = <40>;
    		gpmc,access-ns = <40>;
    		gpmc,wr-access-ns = <80>;
    		gpmc,rd-cycle-ns = <80>;
    		gpmc,wr-cycle-ns = <80>;
    		gpmc,bus-turnaround-ns = <0>;
    		gpmc,cycle2cycle-delay-ns = <0>;
    		gpmc,clk-activation-ns = <0>;
    		gpmc,wr-data-mux-bus-ns = <0>;
    		/* MTD partition table */
    		/* All SPL-* partitions are sized to minimal length
    		 * which can be independently programmable. For
    		 * NAND flash this is equal to size of erase-block */
    		#size-cells = <1>;
    		partition@0 {
    			label = "NAND.SPL";
    			reg = <0x00000000 0x000020000>;
    		partition@1 {
    			label = "NAND.SPL.backup1";
    			reg = <0x00020000 0x00020000>;
    		partition@2 {
    			label = "NAND.SPL.backup2";
    			reg = <0x00040000 0x00020000>;
    		partition@3 {
    			label = "NAND.SPL.backup3";
    			reg = <0x00060000 0x00020000>;
    		partition@4 {
    			label = "NAND.u-boot-spl-os";
    			reg = <0x00080000 0x00040000>;
    		partition@5 {
    			label = "NAND.u-boot";
    			reg = <0x000c0000 0x00100000>;
    		partition@6 {
    			label = "NAND.u-boot-env";
    			reg = <0x001c0000 0x00020000>;
    		partition@7 {
    			label = "NAND.u-boot-env.backup1";
    			reg = <0x001e0000 0x00020000>;
    		partition@8 {
    			label = "NAND.kernel";
    			reg = <0x00200000 0x00800000>;
    		partition@9 {
    			label = "NAND.file-system";
    			reg = <0x00a00000 0x0f600000>;
    &usb2_phy1 {
    	phy-supply = <&ldousb_reg>;
    &usb2_phy2 {
    &gpio7 {
    	ti,no-reset-on-init;
    	ti,no-idle-on-init;
    &mac {
    	status = "okay";
    	dual_emac;
    &cpsw_emac0 {
    	phy_id = <&davinci_mdio>, <2>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <1>;
    &cpsw_emac1 {
    	phy_id = <&davinci_mdio>, <3>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <2>;
    &mailbox5 {
    	status = "okay";
    	mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
    		status = "okay";
    	mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
    		status = "okay";
    &mailbox6 {
    	status = "okay";
    	mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
    		status = "okay";
    	mbox_dsp2_ipc3x: mbox_dsp2_ipc3x {
    		status = "okay";
    &mmu0_dsp1 {
    	status = "okay";
    &mmu1_dsp1 {
    	status = "okay";
    &mmu0_dsp2 {
    	status = "okay";
    &mmu1_dsp2 {
    	status = "okay";
    &mmu_ipu1 {
    	status = "okay";
    &mmu_ipu2 {
    	status = "okay";
    &ipu2 {
    	status = "okay";
    	memory-region = <&ipu2_cma_pool>;
    	mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
    	timers = <&timer3>;
    	watchdog-timers = <&timer4>, <&timer9>;
    &ipu1 {
    	status = "okay";
    	memory-region = <&ipu1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
    	timers = <&timer11>;
    	watchdog-timers = <&timer7>, <&timer8>;
    &dcan1 {
    	status = "ok";
    	pinctrl-names = "default", "sleep", "active";
    	pinctrl-0 = <&dcan1_pins_sleep>;
    	pinctrl-1 = <&dcan1_pins_sleep>;
    	pinctrl-2 = <&dcan1_pins_default>;
    &dsp1 {
    	status = "okay";
    	memory-region = <&dsp1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
    	timers = <&timer5>;
    	watchdog-timers = <&timer10>;
    &dsp2 {
    	status = "okay";
    	memory-region = <&dsp2_cma_pool>;
    	mboxes = <&mailbox6 &mbox_dsp2_ipc3x>;
    	timers = <&timer6>;
    	watchdog-timers = <&timer13>;
    &dss {
    	status = "okay";
    	vdda_video-supply = <&ldoln_reg>;
    	ports {
    		#size-cells = <0>;
    		port@lcd3 {
    			reg = <2>;
    			dpi_out3: endpoint {
    				data-lines = <24>;
    &hdmi {
    	vdda-supply = <&ldo3_reg>;
    &mcasp8 {
    	/* not used for audio. only the AXR2 pin is used as GPIO */
    	status = "okay";
    video_in: &vin2a {
    	status = "okay";
    	endpoint@0 {
    		slave-mode;
    		remote-endpoint = <&onboardLI>;
    &bb2d {
    	status = "okay";
    Murugan S
    For MMC_DEBUG logs to show up, you have to increase the loglevel, try appending loglevel=9 to kernel bootargs and try.
    Does this board have both eMMC and SD card slot?
    Is the file system on SD card or eMMC?
    Vishal
  • Any update on the logs?
