Linux/AM5728: Ethernet problem
Part Number: AM5728
Other Parts Discussed in Thread: DRA752, PMP
Tool/software: Linux
SDK = ti-processor-sdk-linux-rt-am57xx-evm-05.03.00.07
u-boot = u-boot-2018.01+gitAUTOINC+313dcd69c2-ge2bc936055
kernel = linux-rt-4.14.79+gitAUTOINC+a72bf1418c-ga72bf1418c
cross compiler = arm-linux-gnueabihf-gcc
I have a AM5728 custom board.
I would like to use an ethernet drive.
But my Ethernet does not work.
The phy chip and configuration is the same as TMDXIDK5728.
Can you tell me the cause?
1. ethool eth0 /ethtool eth1
root@am57xx-evm:~# ethtool eth0
Settings for eth0:
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000000 (0)
Link detected: no
root@am57xx-evm:~# ethtool eth1
Settings for eth1:
Supports Wake-on: d
Wake-on: d
Link detected: no
2. Hardware
3.Kernel Log
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-rt47-ga72bf1418c (root@ksm-HP-ProBook-450-G5) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #6 SMP PREEMPT RT Thu Jun 20 10:33:26 KST 2019
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5728 IDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 15 pages/cpu @eed36000 s32032 r8192 d21216 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO1,115200n8 root=PARTUUID=d117f98e-6f2c-d04b-a5b2-331a19f91cb2 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1675140K/1897472K available (8192K kernel code, 358K rwdata, 2536K rodata, 2048K init, 289K bss, 33916K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc10598e0 ( 359 kB)
[ 0.000000] .bss : 0xc105b000 - 0xc10a3690 ( 290 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] No expedited grace period (rcu_normal_after_boot).
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000011] Switching to timer-based delay loop, resolution 162ns
[ 0.000334] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000337] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000763] Console: colour dummy device 80x30
[ 0.000875] WARNING: Your 'console=ttyO1' has been replaced by 'ttyS1'
[ 0.000877] This ensures that you still see kernel messages. Please
[ 0.000879] update your kernel commandline.
[ 0.000896] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000903] pid_max: default: 32768 minimum: 301
[ 0.001033] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001041] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001676] CPU: Testing write buffer coherency: ok
[ 0.001705] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001923] /cpus/cpu@0 missing clock-frequency property
[ 0.001962] /cpus/cpu@1 missing clock-frequency property
[ 0.001973] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039931] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.079930] Hierarchical SRCU implementation.
[ 0.140442] EFI services will not be available.
[ 0.160075] smp: Bringing up secondary CPUs ...
[ 0.260501] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.260504] CPU1: Spectre v2: using ICIALLU workaround
[ 0.260613] smp: Brought up 1 node, 2 CPUs
[ 0.260629] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.260637] CPU: All CPU(s) started in HYP mode.
[ 0.260644] CPU: Virtualization extensions available.
[ 0.261366] devtmpfs: initialized
[ 0.291905] random: get_random_u32 called from bucket_table_alloc+0x14c/0x288 with crng_init=0
[ 0.292183] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.292430] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.292448] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.297353] pinctrl core: initialized pinctrl subsystem
[ 0.298153] DMI not present or invalid.
[ 0.298599] NET: Registered protocol family 16
[ 0.301228] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.302152] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.411952] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.525966] OMAP GPIO hardware version 0.1
[ 0.560736] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.560748] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.561152] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.561162] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.562457] OMAP DMA hardware revision 0.0
[ 0.579111] edma 43300000.edma: memcpy is disabled
[ 0.585197] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.598036] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.603696] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.604157] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.604737] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.605284] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.605958] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.606425] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.606888] iommu: Adding device 58820000.ipu to group 1
[ 0.607088] iommu: Adding device 55020000.ipu to group 2
[ 0.607451] iommu: Adding device 40800000.dsp to group 0
[ 0.608021] iommu: Adding device 41000000.dsp to group 3
[ 0.610652] palmas 0-0058: Irq flag is 0x00000004
[ 0.643186] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.644914] SMPS12: supplied by regulator-dummy
[ 0.646828] SMPS3: supplied by VMAIN
[ 0.648567] SMPS45: supplied by regulator-dummy
[ 0.650577] SMPS6: supplied by VMAIN
[ 0.652455] SMPS7: supplied by VMAIN
[ 0.654466] SMPS8: supplied by VMAIN
[ 0.655934] SMPS9: supplied by VMAIN
[ 0.657117] LDO1: supplied by VMAIN
[ 0.661840] LDO2: supplied by VMAIN
[ 0.671706] LDO3: supplied by VMAIN
[ 0.681740] LDO4: supplied by VMAIN
[ 0.691743] LDO5: supplied by regulator-dummy
[ 0.692681] LDO6: supplied by regulator-dummy
[ 0.693607] LDO7: supplied by regulator-dummy
[ 0.694549] LDO8: supplied by regulator-dummy
[ 0.695477] LDO9: supplied by VMAIN
[ 0.702066] LDOLN: supplied by VMAIN
[ 0.711788] LDOUSB: supplied by VMAIN
[ 0.725732] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.726395] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 200 kHz
[ 0.727025] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 200 kHz
[ 0.727276] media: Linux media interface: v0.10
[ 0.727336] Linux video capture interface: v2.00
[ 0.727460] pps_core: LinuxPPS API ver. 1 registered
[ 0.727468] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.727492] PTP clock support registered
[ 0.727528] EDAC MC: Ver: 3.0.0
[ 0.727938] dmi: Firmware registration failed.
[ 0.728515] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.728916] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.729466] Advanced Linux Sound Architecture Driver Initialized.
[ 0.730564] clocksource: Switched to clocksource arch_sys_counter
[ 0.743849] NET: Registered protocol family 2
[ 0.744699] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.744784] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.745040] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.745172] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.745225] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.745504] NET: Registered protocol family 1
[ 0.745987] RPC: Registered named UNIX socket transport module.
[ 0.746000] RPC: Registered udp transport module.
[ 0.746009] RPC: Registered tcp transport module.
[ 0.746019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.747392] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.747723] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.749582] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.757909] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.758808] NFS: Registering the id_resolver key type
[ 0.758841] Key type id_resolver registered
[ 0.758850] Key type id_legacy registered
[ 0.758923] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.761011] bounce: pool size: 64 pages
[ 0.761065] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.761078] io scheduler noop registered
[ 0.761088] io scheduler deadline registered
[ 0.761246] io scheduler cfq registered (default)
[ 0.761258] io scheduler mq-deadline registered
[ 0.761268] io scheduler kyber registered
[ 0.767923] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.772459] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[ 0.773016] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.773053] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.773078] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.770793] dra7-pcie 51000000.pcie: phy link never came up
[ 1.771033] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.771052] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.771063] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.771074] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.771480] PCI: bus0: Fast back to back transfers disabled
[ 1.771625] PCI: bus1: Fast back to back transfers enabled
[ 1.771670] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.771689] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.772347] pcieport 0000:00:00.0: Signaling PME with IRQ 173
[ 1.772642] pcieport 0000:00:00.0: AER enabled with IRQ 173
[ 1.778517] V3_3D: supplied by smps9
[ 1.778849] vtt_fixed: supplied by V3_3D
[ 1.853754] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.858431] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
[ 1.860193] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
[ 2.945282] console [ttyS1] enabled
[ 2.950544] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
[ 2.962058] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.989646] brd: module loaded
[ 3.004784] loop: module loaded
[ 3.014630] m25p80 spi0.0: unrecognized JEDEC id bytes: ff, ff, ff
[ 3.021831] libphy: Fixed MDIO Bus: probed
[ 3.080594] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 3.088289] davinci_mdio 48485000.mdio: no live phy, scanning all
[ 3.095559] davinci_mdio: probe of 48485000.mdio failed with error -5
[ 3.103208] cpsw 48484000.ethernet: Detected MACID = 94:e3:6d:4a:fe:f2
[ 3.109853] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 3.116239] cpsw 48484000.ethernet: ALE Table size 1024
[ 3.121504] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 3.128538] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 3.136902] cpsw 48484000.ethernet: cpsw: Detected MACID = 94:e3:6d:4a:fe:f3
[ 3.146237] i2c /dev entries driver
[ 3.151555] IR NEC protocol handler initialized
[ 3.156110] IR RC5(x/sz) protocol handler initialized
[ 3.161187] IR RC6 protocol handler initialized
[ 3.165740] IR JVC protocol handler initialized
[ 3.170291] IR Sony protocol handler initialized
[ 3.174930] IR SANYO protocol handler initialized
[ 3.179656] IR Sharp protocol handler initialized
[ 3.184383] IR MCE Keyboard/mouse protocol handler initialized
[ 3.190243] IR XMP protocol handler initialized
[ 3.200447] sdhci: Secure Digital Host Controller Interface driver
[ 3.206661] sdhci: Copyright(c) Pierre Ossman
[ 3.211890] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.219222] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 3.225346] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 3.231998] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 3.291968] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 3.299728] sdhci-omap 480b4000.mmc: 480b4000.mmc supply vqmmc not found, using dummy regulator
[ 3.360657] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.379934] NET: Registered protocol family 10
[ 3.385802] Segment Routing with IPv6
[ 3.389579] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.396236] NET: Registered protocol family 17
[ 3.401191] Key type dns_resolver registered
[ 3.405625] omap_voltage_late_init: Voltage driver support not added
[ 3.412011] Power Management for TI OMAP4+ devices.
[ 3.417242] Registering SWP/SWPB emulation handler
[ 3.423835] mmc1: new DDR MMC card at address 0001
[ 3.429209] mmcblk1: mmc1:0001 R1J56L 13.8 GiB
[ 3.440657] mmcblk1boot0: mmc1:0001 R1J56L partition 1 16.0 MiB
[ 3.446900] mmcblk1boot1: mmc1:0001 R1J56L partition 2 16.0 MiB
[ 3.453117] mmcblk1rpmb: mmc1:0001 R1J56L partition 3 128 KiB
[ 3.463189] mmcblk1: p1 p2
[ 3.467105] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.475606] dmm 4e000000.dmm: initialized all PAT entries
[ 3.482243] hctosys: unable to open rtc device (rtc0)
[ 3.488711] ALSA device list:
[ 3.491698] No soundcards found.
[ 3.504581] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.512769] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 3.523162] devtmpfs: mounted
[ 3.529068] Freeing unused kernel memory: 2048K
[ 3.678278] systemd[1]: System time before build time, advancing clock.
[ 3.707195] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN)
[ 3.728646] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[ 3.761163] systemd[1]: Set hostname to <am57xx-evm>.
[ 3.771127] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.777808] systemd[1]: Initializing machine ID from random generator.
[ 3.937379] systemd-gpt-auto-generator[106]: Failed to dissect: Input/output error
[ 3.946470] systemd[102]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with error code 1.
[ 4.155528] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.162470] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.200755] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.219232] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 4.251191] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.294367] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.330986] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Journal Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Swap.
[ OK ] Created slice System Slice.
Starting Load Kernel Modules...
[ 4.640322] usbcore: registered new interface driver usbfs
[ 4.645957] usbcore: registered new interface driver hub
[ 4.651452] usbcore: registered new device driver usb
Starting Journal Service...
[ 4.660518] usbcore: registered new interface driver usbserial
[ 4.673899] usbcore: registered new interface driver ftdi_sio
[ 4.679779] usbserial: USB Serial support registered for FTDI USB Serial Device
Starting Remount Root and Kernel File Systems...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.741655] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
Mounting Temporary Directory (/tmp)...
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Slices.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on udev Control Socket.
Starting Create list of required st��…ce nodes for the current kernel...
Mounting POSIX Message Queue File System...
Mounting Kernel Debug File System...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
Starting Create System Users...
Starting Rebuild Hardware Database...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Create System Users.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
[ 5.648767] systemd-journald[113]: Received request to flush runtime journal from PID 1
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Journal Catalog...
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Opkg first boot configure...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting udev Coldplug all Devices...
[ OK ] Started Rebuild Dynamic Linker Cache.
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Started Opkg first boot configure.
[ 9.089510] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 9.120098] remoteproc remoteproc0: 58820000.ipu is available
[ 9.135245] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[ 9.165748] remoteproc remoteproc1: 55020000.ipu is available
[ 9.188968] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 9.245734] remoteproc remoteproc2: 40800000.dsp is available
[ 9.271032] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 9.305461] remoteproc remoteproc0: powering up 58820000.ipu
[ 9.305478] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6731716
[ 9.305854] remoteproc remoteproc1: powering up 55020000.ipu
[ 9.305877] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220
[ 9.335683] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 9.340735] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 9.432957] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 9.433026] remoteproc remoteproc0: registered virtio0 (type 7)
[ 9.433032] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 9.554175] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
[ OK ] Started udev Coldplug all Devices.
[ 9.699430] remoteproc remoteproc3: 41000000.dsp is available
[ OK ] Reached target System Initialization.
[ 9.739213] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 9.751918] remoteproc remoteproc1: registered virtio1 (type 7)
[ 9.767201] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 9.769795] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ OK ] Started Daily rotation of log files.
[ 9.803395] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Network Service...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ 10.022259] remoteproc remoteproc2: powering up 40800000.dsp
[ OK [ 10.036212] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 20430560
] Reached target Timers.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 10.085200] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 10.111387] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 10.120161] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 10.244109] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.265172] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 10.281663] omap-des 480a5000.des: will run requests pump with realtime priority
[ 10.364101] remoteproc remoteproc2: registered virtio2 (type 7)
[ 10.370061] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 10.397810] remoteproc remoteproc3: powering up 41000000.dsp
[ OK ] Listening on dropbear.socket.
[ 10.397826] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20430560
[ 10.405179] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 10.405217] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 10.405252] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ OK ] Reached target Sockets.
[ 10.533600] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 10.533695] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
[ 10.533803] remoteproc remoteproc3: registered virtio3 (type 7)
[ 10.533810] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[ 10.566960] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
[ OK ] Reached target Basic System.
[ OK ] Reached target Containers.
[ 10.695542] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc0
[ 10.711380] omap_rtc 48838000.rtc: registered as rtc1
[ 10.754377] omap_gpio 48057000.gpio: Could not set line 16 debounce to 20000 microseconds (-22)
Starting TI IPC Daemon...
Starting RPC Bind Service...
[ 11.199986] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 11.249702] vpe 489d0000.vpe: Device registered as /dev/video0
[ 11.281454] vip 48990000.vip: loading firmware vpdma-1b8.bin
[ 11.310673] vip 48990000.vip: VPDMA firmware loaded
Starting Avahi mDNS/DNS-SD Stack...
Starting uim-sysfs.service...
Starting Login Service...
Starting TI MultiCore Tools Daemon...
[ OK ] Started System Logging Service.
Starting Print notice about GPLv3 packages...
[ 12.321012] SCSI subsystem initialized
[ OK ] Started Periodic Command Scheduler.
[ 12.567316] CAN device driver interface
[ 12.587543] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 12.628616] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ OK ] Started Job spooling tools.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Kernel Logging Service.
[ 12.834776] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 12.852564] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 12.891246] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ OK ] Started D-Bus System Message Bus.
[ 13.081733] scsi host0: ahci
[ 13.121392] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 84
[ 13.144321] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 13.161417] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 13.290496] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=92)
[ 13.350377] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 13.378950] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 13.463083] ata1: SATA link down (SStatus 0 SControl 300)
[ OK ] Started Network Service.
[ OK ] Started TI IPC Daemon.
[ OK ] Started RPC Bind Service.
[FAILED] Failed to start TI MultiCore Tools Daemon.
See 'systemctl status ti-mct-daemon.service' for details.
[ OK ] Found device /dev/ttyS2.
[ 13.691293] net eth1: initializing cpsw version 1.15 (0)
[ 13.704210] libphy: PHY 48485000.mdio:01 not found
[ 13.769370] net eth1: phy "48485000.mdio:01" not found on slave 1, err -19
[ OK ] Found device /dev/ttyS1.
[ 13.829440] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 14.081255] net eth0: initializing cpsw version 1.15 (0)
[ 14.089611] libphy: PHY 48485000.mdio:00 not found
[ 14.152189] net eth0: phy "48485000.mdio:00" not found on slave 0, err -19
[ 14.219904] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Wait for Network to be Configured...
[ OK ] Reached target Network.
Starting Permit User Sessions...
[ OK ] Started Redis In-Memory Data Store.
Starting Enable and configure wl18xx bluetooth stack...
Starting Network Name Resolution...
Starting Lightning Fast Webserver With Light System Requirements...
Starting Simple Network Management Protocol (SNMP) Daemon....
[ OK ] Started Network Name Resolution.
[ 17.216885] NET: Registered protocol family 44
[ OK ] Started Permit User Sessions.
[ 17.460738] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
[ 17.492225] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4
[ 17.500211] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
[ 17.534352] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9
[ 17.653620] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ OK ] Started Enable and configure wl18xx bluetooth[ 17.687976] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
stack.
[ OK ] Started Lightning Fast Webserver With Light S[ 17.727986] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
ystem Requirements.
[ 17.774041] xhci-hcd xhci-hcd.0.auto: irq 181, io mem 0x48890000
[ 17.798420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 17.830003] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 17.858383] usb usb1: Product: xHCI Host Controller
[ 17.881312] usb usb1: Manufacturer: Linux 4.14.79-rt47-ga72bf1418c xhci-hcd
[ 17.906396] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 17.923514] hub 1-0:1.0: USB hub found
[ 17.939401] hub 1-0:1.0: 1 port detected
[ 17.950194] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 17.955763] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 17.968217] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ OK ] Started Simple Network Management Protocol (S[ 17.975097] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
NMP) Daemon..
[ 17.990042] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 17.997003] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 18.004344] usb usb2: Product: xHCI Host Controller
[ 18.010171] usb usb2: Manufacturer: Linux 4.14.79-rt47-ga72bf1418c xhci-hcd
[ 18.022653] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 18.038196] hub 2-0:1.0: USB hub found
[ 18.042661] hub 2-0:1.0: 1 port detected
[ OK ] Started uim-sysfs.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
binutils-dev
binutils
bison-dev
bison
cifs-utils
cpio
cpp-symlinks
cpp
dosfstools
elfutils-dev
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gettext
glmark2
gstreamer1.0-libav
gzip
hidapi
libasm1
libcairo-perf-utils
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm4
libgettextlib
libgettextsrc
libgmp10
libidn11
libmavconn
libmpc3
libmpfr4
libreadline-dev
libreadline7
libunistring2
m4-dev
m4
make
mavlink
mavros-extras
mavros-msgs
mavros
nettle
parted
python3-pycairo
socketcan-interface
swig-dev
swig
which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
Starting rc.pvr.service...
[ OK ] Stopped Redis In-Memory Data Store.
[ 20.328261] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Serial Getty on ttyS1.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ 21.608912] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[FAILED] Failed to start Redis In-Memory Data Store.
See 'systemctl status redis.service' for details.
[ OK ] Started weston.service.
Starting telnetd.service...
Starting Matrix GUI...
[ OK ] Started telnetd.service.
[ OK ] Started Matrix GUI.
Starting thttpd.service...
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am57xx-evm ttyS1
Arago 2018.10 am57xx-evm ttyS1
am57xx-evm login: root
root@am57xx-evm:~#
  • Please complete this checklist and post the results here: processors.wiki.ti.com/.../5x_CPSW
  • Hi, Biser Gatchev-XID
    1. uname -a
    Linux am57xx-evm 4.14.79-rt47-ga72bf1418c #6 SMP PREEMPT RT Thu Jun 20 10:33:26 KST 2019 armv7l GNU/Linux
    2. File System, TI SDK
    tisdk-rootfs-image-am57xx-evm.tar.xz
    3.device tree
     * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    /dts-v1/;
    #include "dra74x.dtsi"
    #include "am572x-idk-common.dtsi"
    #include "am57xx-idk-common.dtsi"
    #include "dra74x-mmc-iodelay.dtsi"
    	model = "TI AM5728 IDK";
    	compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74",
    		     "ti,dra7";
    &mmc1 {
    	pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50", "sdr104";
    	pinctrl-0 = <&mmc1_pins_default>;
    	pinctrl-1 = <&mmc1_pins_hs>;
    	pinctrl-2 = <&mmc1_pins_sdr12>;
    	pinctrl-3 = <&mmc1_pins_sdr25>;
    	pinctrl-4 = <&mmc1_pins_sdr50>;
    	pinctrl-5 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr_rev20_conf>;
    	pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>;
    &mmc2 {
    	pinctrl-names = "default", "hs", "ddr_1_8v";
    	pinctrl-0 = <&mmc2_pins_default>;
    	pinctrl-1 = <&mmc2_pins_hs>;
    	pinctrl-2 = <&mmc2_pins_ddr_rev20>;
    &pruss2_mdio {
    	reset-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>,
    		      <&gpio5 9 GPIO_ACTIVE_LOW>;
    	reset-delay-us = <2>;	/* PHY datasheet states 1uS min */
    #include "am57xx-evm-cmem.dtsi"
    4.Log
    U-Boot SPL 2018.01-00569-g7d9bc2b3c2-dirty (Jun 20 2019 - 10:56:46)
    DRA752-GP ES2.0
    Trying to boot from MMC2_2
    no pinctrl state for default mode
    U-Boot 2018.01-00569-g7d9bc2b3c2-dirty (Jun 20 2019 - 10:56:46 +0900)
    CPU : DRA752-GP ES2.0
    Model: TI AM5728 IDK
    Board: AM572x IDK REV
    DRAM: 2 GiB
    MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    SCSI: SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net: Could not get PHY for ethernet@48484000: addr 0
    eth0: ethernet@48484000
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc1(part 0) is current device
    SD/MMC found on device 1
    ** File not found boot.scr **
    ** Unrecognized filesystem type **
    MMC read: dev # 1, block # 5376, count 33945 ... 33945 blocks read: OK
    MMC read: dev # 1, block # 4864, count 512 ... 512 blocks read: OK
    Loading Device Tree to 8ffe4000, end 8ffff165 ... OK
    Using machid 0xfe6 from environment
    Starting kernel ...
    [ 0.000000] Linux version 4.14.79-rt47-ga72bf1418c (root@ksm-HP-ProBook-450-G5) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #6 9
    [ 0.000000] Memory: 1675140K/1897472K available (8192K kernel code, 358K rwdata, 2536K rodata, 2048K init, 289K bss, 33916K reserved, 188)
    [ 0.000332] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [ 0.000335] OMAP clocksource: 32k_counter at 32768 Hz
    [ 0.000767] Console: colour dummy device 80x30
    [ 0.000883] WARNING: Your 'console=ttyO1' has been replaced by 'ttyS1'
    [ 0.000885] This ensures that you still see kernel messages. Please
    [ 0.000887] update your kernel commandline.
    [ 0.000904] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [ 0.000911] pid_max: default: 32768 minimum: 301
    [ 0.001043] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001051] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001682] CPU: Testing write buffer coherency: ok
    [ 0.001711] CPU0: Spectre v2: using ICIALLU workaround
    [ 0.001928] /cpus/cpu@0 missing clock-frequency property
    [ 0.001967] /cpus/cpu@1 missing clock-frequency property
    [ 0.001977] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [ 0.039934] Setting up static identity map for 0x80200000 - 0x80200060
    [ 0.140445] EFI services will not be available.
    [ 0.160074] smp: Bringing up secondary CPUs ...
    [ 0.260503] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [ 0.260506] CPU1: Spectre v2: using ICIALLU workaround
    [ 0.260616] smp: Brought up 1 node, 2 CPUs
    [ 0.260632] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [ 0.260640] CPU: All CPU(s) started in HYP mode.
    [ 0.260646] CPU: Virtualization extensions available.
    [ 0.261371] devtmpfs: initialized
    [ 0.292146] random: get_random_u32 called from bucket_table_alloc+0x14c/0x288 with crng_init=0
    [ 0.292425] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [ 0.292674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.292694] futex hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.296698] pinctrl core: initialized pinctrl subsystem
    [ 0.297494] DMI not present or invalid.
    [ 0.297943] NET: Registered protocol family 16
    [ 0.300624] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.301541] omap_hwmod: l3_main_2 using broken dt data from ocp
    [ 0.411334] omap_hwmod: dcan1: _wait_target_disable failed
    [ 0.525250] OMAP GPIO hardware version 0.1
    [ 0.559906] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [ 0.559918] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [ 0.560319] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [ 0.560330] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [ 0.561687] OMAP DMA hardware revision 0.0
    [ 0.578288] edma 43300000.edma: memcpy is disabled
    [ 0.584373] edma 43300000.edma: TI EDMA DMA engine driver
    [ 0.597178] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [ 0.602839] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [ 0.603303] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [ 0.603881] omap-iommu 58882000.mmu: 58882000.mmu registered
    [ 0.604427] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.605100] omap-iommu 41501000.mmu: 41501000.mmu registered
    [ 0.605569] omap-iommu 41502000.mmu: 41502000.mmu registered
    [ 0.606043] iommu: Adding device 58820000.ipu to group 1
    [ 0.606245] iommu: Adding device 55020000.ipu to group 2
    [ 0.606607] iommu: Adding device 40800000.dsp to group 0
    [ 0.607179] iommu: Adding device 41000000.dsp to group 3
    [ 0.609826] palmas 0-0058: Irq flag is 0x00000004
    [ 0.633336] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
    [ 0.635183] SMPS12: supplied by regulator-dummy
    [ 0.637191] SMPS3: supplied by VMAIN
    [ 0.639050] SMPS45: supplied by regulator-dummy
    [ 0.641259] SMPS6: supplied by VMAIN
    [ 0.643243] SMPS7: supplied by VMAIN
    [ 0.645414] SMPS8: supplied by VMAIN
    [ 0.646962] SMPS9: supplied by VMAIN
    [ 0.648226] LDO1: supplied by VMAIN
    [ 0.661810] LDO2: supplied by VMAIN
    [ 0.681677] LDO3: supplied by VMAIN
    [ 0.701679] LDO4: supplied by VMAIN
    [ 0.721711] LDO5: supplied by regulator-dummy
    [ 0.722673] LDO6: supplied by regulator-dummy
    [ 0.723661] LDO7: supplied by regulator-dummy
    [ 0.724639] LDO8: supplied by regulator-dummy
    [ 0.725615] LDO9: supplied by VMAIN
    [ 0.742076] LDOLN: supplied by VMAIN
    [ 0.761772] LDOUSB: supplied by VMAIN
    [ 0.785761] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [ 0.786496] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 200 kHz
    [ 0.787096] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 200 kHz
    [ 0.787333] media: Linux media interface: v0.10
    [ 0.787398] Linux video capture interface: v2.00
    [ 0.787522] pps_core: LinuxPPS API ver. 1 registered
    [ 0.787530] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.787554] PTP clock support registered
    [ 0.787591] EDAC MC: Ver: 3.0.0
    [ 0.787985] dmi: Firmware registration failed.
    [ 0.788554] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [ 0.788969] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [ 0.789531] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.790659] clocksource: Switched to clocksource arch_sys_counter
    [ 0.803854] NET: Registered protocol family 2
    [ 0.804699] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.804784] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
    [ 0.805035] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.805168] UDP hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.805221] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.805507] NET: Registered protocol family 1
    [ 0.826095] RPC: Registered named UNIX socket transport module.
    [ 0.826107] RPC: Registered udp transport module.
    [ 0.826116] RPC: Registered tcp transport module.
    [ 0.826125] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.827478] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [ 0.827824] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [ 0.829672] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [ 0.838005] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.838895] NFS: Registering the id_resolver key type
    [ 0.838928] Key type id_resolver registered
    [ 0.838938] Key type id_legacy registered
    [ 0.839010] ntfs: driver 2.1.32 [Flags: R/O].
    [ 0.841074] bounce: pool size: 64 pages
    [ 0.841128] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [ 0.841141] io scheduler noop registered
    [ 0.841151] io scheduler deadline registered
    [ 0.841309] io scheduler cfq registered (default)
    [ 0.841320] io scheduler mq-deadline registered
    [ 0.841330] io scheduler kyber registered
    [ 0.847989] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [ 0.852501] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
    [ 0.853052] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
    [ 0.853088] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000
    [ 0.853114] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000
    [ 1.850890] dra7-pcie 51000000.pcie: phy link never came up
    [ 1.851098] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [ 1.851117] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 1.851128] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
    [ 1.851139] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [ 1.851540] PCI: bus0: Fast back to back transfers disabled
    [ 1.851683] PCI: bus1: Fast back to back transfers enabled
    [ 1.851726] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
    [ 1.851746] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [ 1.852383] pcieport 0000:00:00.0: Signaling PME with IRQ 173
    [ 1.852679] pcieport 0000:00:00.0: AER enabled with IRQ 173
    [ 1.858535] V3_3D: supplied by smps9
    [ 1.858854] vtt_fixed: supplied by V3_3D
    [ 1.935919] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [ 1.940632] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
    [ 1.942488] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
    [ 3.027530] console [ttyS1] enabled
    [ 3.032783] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
    [ 3.044168] omap_rng 48090000.rng: Random Number Generator ver. 20
    [ 3.071753] brd: module loaded
    [ 3.086891] loop: module loaded
    [ 3.096719] m25p80 spi0.0: unrecognized JEDEC id bytes: ff, ff, ff
    [ 3.103888] libphy: Fixed MDIO Bus: probed
    [ 3.170704] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [ 3.178400] davinci_mdio 48485000.mdio: no live phy, scanning all
    [ 3.186022] davinci_mdio: probe of 48485000.mdio failed with error -5
    [ 3.193685] cpsw 48484000.ethernet: Detected MACID = 94:e3:6d:4a:fe:f2
    [ 3.200345] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [ 3.206733] cpsw 48484000.ethernet: ALE Table size 1024
    [ 3.211998] cpsw 48484000.ethernet: device node lookup for pps timer failed
    [ 3.219032] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [ 3.227377] cpsw 48484000.ethernet: cpsw: Detected MACID = 94:e3:6d:4a:fe:f3
    [ 3.236675] i2c /dev entries driver
    [ 3.241981] IR NEC protocol handler initialized
    [ 3.246536] IR RC5(x/sz) protocol handler initialized
    [ 3.251612] IR RC6 protocol handler initialized
    [ 3.256165] IR JVC protocol handler initialized
    [ 3.260715] IR Sony protocol handler initialized
    [ 3.265355] IR SANYO protocol handler initialized
    [ 3.270080] IR Sharp protocol handler initialized
    [ 3.274808] IR MCE Keyboard/mouse protocol handler initialized
    [ 3.280687] IR XMP protocol handler initialized
    [ 3.290948] sdhci: Secure Digital Host Controller Interface driver
    [ 3.297157] sdhci: Copyright(c) Pierre Ossman
    [ 3.302397] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 3.309721] sdhci-omap 4809c000.mmc: Got CD GPIO
    [ 3.315846] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
    [ 3.322497] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
    [ 3.392045] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
    [ 3.399789] sdhci-omap 480b4000.mmc: 480b4000.mmc supply vqmmc not found, using dummy regulator
    [ 3.460753] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
    [ 3.480063] NET: Registered protocol family 10
    [ 3.485923] Segment Routing with IPv6
    [ 3.489694] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [ 3.496365] NET: Registered protocol family 17
    [ 3.501318] Key type dns_resolver registered
    [ 3.505754] omap_voltage_late_init: Voltage driver support not added
    [ 3.512140] Power Management for TI OMAP4+ devices.
    [ 3.517362] Registering SWP/SWPB emulation handler
    [ 3.559750] dmm 4e000000.dmm: workaround for errata i878 in use
    [ 3.568274] dmm 4e000000.dmm: initialized all PAT entries
    [ 3.574937] hctosys: unable to open rtc device (rtc0)
    [ 3.581455] ALSA device list:
    [ 3.584440] No soundcards found.
    [ 3.589885] Waiting for root device PARTUUID=d117f98e-6f2c-d04b-a5b2-331a19f91cb2...
    [ 3.628475] mmc1: new DDR MMC card at address 0001
    [ 3.633831] mmcblk1: mmc1:0001 R1J56L 13.8 GiB
    [ 3.638633] mmcblk1boot0: mmc1:0001 R1J56L partition 1 16.0 MiB
    [ 3.644827] mmcblk1boot1: mmc1:0001 R1J56L partition 2 16.0 MiB
    [ 3.650995] mmcblk1rpmb: mmc1:0001 R1J56L partition 3 128 KiB
    [ 3.661020] mmcblk1: p1 p2
    [ 3.737264] EXT4-fs (mmcblk1p1): recovery complete
    [ 3.743155] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
    [ 3.751344] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [ 3.761515] devtmpfs: mounted
    [ 3.767378] Freeing unused kernel memory: 2048K
    [ 3.912015] systemd[1]: System time before build time, advancing clock.
    [ 3.944142] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -G)
    [ 3.965602] systemd[1]: Detected architecture arm.
    [ 4.001359] systemd[1]: Set hostname to <am57xx-evm>.
    [ 4.156181] systemd-gpt-auto-generator[105]: Failed to dissect: Input/output error
    [ 4.165340] systemd[101]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with error code 1.
    [ 4.356481] random: systemd: uninitialized urandom read (16 bytes read)
    [ 4.363616] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 4.400864] random: systemd: uninitialized urandom read (16 bytes read)
    [ 4.407554] systemd[1]: Reached target Remote File Systems.
    [ 4.461758] random: systemd: uninitialized urandom read (16 bytes read)
    [ 4.468680] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [ 4.511154] systemd[1]: Listening on udev Control Socket.
    [ 4.541115] systemd[1]: Listening on Network Service Netlink Socket.
    [ 4.580980] systemd[1]: Listening on udev Kernel Socket.
    [ 4.991802] usbcore: registered new interface driver usbfs
    [ 4.999311] usbcore: registered new interface driver hub
    [ 5.004851] usbcore: registered new device driver usb
    [ 5.018849] usbcore: registered new interface driver usbserial
    [ 5.038878] usbcore: registered new interface driver ftdi_sio
    [ 5.047112] usbserial: USB Serial support registered for FTDI USB Serial Device
    [ OK ] Created slice User and Session Slice.[ 5.067126] EXT4-fs (mmcblk1p1): re-mounted. Opts: (null)
    [ 5.844463] systemd-journald[122]: Received request to flush runtime journal from PID 1
    [FAILED] Failed to start Update is Completed.
    See 'systemctl status systemd-update-done.service' for details.
    [ 8.809187] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
    [ 8.837399] remoteproc remoteproc0: 58820000.ipu is available
    [ 8.889543] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
    [ 8.935718] remoteproc remoteproc1: 55020000.ipu is available
    [ 8.972173] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
    [ 9.017407] remoteproc remoteproc2: 40800000.dsp is available
    [ 9.034952] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
    [ 9.054463] remoteproc remoteproc0: powering up 58820000.ipu
    [ 9.054478] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 6731716
    [ 9.054589] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
    [ 9.139745] remoteproc remoteproc3: 41000000.dsp is available
    [ 9.146060] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 9.146132] remoteproc remoteproc0: registered virtio0 (type 7)
    [ 9.146138] remoteproc remoteproc0: remote processor 58820000.ipu is now up
    [ 9.209353] remoteproc remoteproc1: powering up 55020000.ipu
    [ 9.209370] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747220
    [ 9.209448] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [ 9.251357] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    [ 9.536881] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 9.542843] remoteproc remoteproc1: registered virtio1 (type 7)
    [ 9.573350] remoteproc remoteproc1: remote processor 55020000.ipu is now up
    [ 9.734177] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
    [ 9.746366] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
    [ 9.857782] remoteproc remoteproc2: powering up 40800000.dsp
    [ 9.882606] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 20430560
    [ 9.978713] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [ 10.027816] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [ 10.056638] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [ 10.067175] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [ 10.095186] omap-des 480a5000.des: will run requests pump with realtime priority
    [ 10.284367] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ 10.293218] remoteproc remoteproc2: registered virtio2 (type 7)
    [ 10.310177] remoteproc remoteproc2: remote processor 40800000.dsp is now up
    [ 10.328220] remoteproc remoteproc3: powering up 41000000.dsp
    [ 10.328237] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 20430560
    [ 10.337320] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    [ 10.337359] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [ 10.337393] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [ 10.413086] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as rtc0
    [ 10.430215] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
    [ 10.432350] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
    [ 10.432368] virtio_rpmsg_bus virtio3: rpmsg host is online
    [ 10.432438] remoteproc remoteproc3: registered virtio3 (type 7)
    [ 10.432444] remoteproc remoteproc3: remote processor 41000000.dsp is now up
    [ 10.511677] omap_gpio 48057000.gpio: Could not set line 16 debounce to 20000 microseconds (-22)
    [ OK ] Reached target Timers.
    [ 10.851137] omap_rtc 48838000.rtc: registered as rtc1
    [ 10.903833] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
    [ 10.959838] vpe 489d0000.vpe: Device registered as /dev/video0
    [ 11.129876] vip 48990000.vip: loading firmware vpdma-1b8.bin
    [ 11.160914] vip 48990000.vip: VPDMA firmware loaded
    [ 11.174228] SCSI subsystem initialized
    [ 11.298420] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [ 11.305308] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [ 11.314142] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [ 11.391431] scsi host0: ahci
    [ 11.440453] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 84
    [ 11.786465] ata1: SATA link down (SStatus 0 SControl 300)
    [ 12.090970] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [ 12.242831] CAN device driver interface
    [ 12.268940] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [ 12.361185] net eth1: initializing cpsw version 1.15 (0)
    [ 12.369528] libphy: PHY 48485000.mdio:01 not found
    [ OK [ 12.417114] net eth1: phy "48485000.mdio:01" not found on slave 1, err -19
    [ 12.434203] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [ 12.440900] omap-aes 4b500000.aes: will run requests pump with realtime priority
    [ 12.586559] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [ 12.640182] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=92)
    [ 12.641132] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [ 12.660784] omap-aes 4b700000.aes: will run requests pump with realtime priority
    [ 12.768130] net eth0: initializing cpsw version 1.15 (0)
    [ 12.838667] libphy: PHY 48485000.mdio:00 not found
    [ 12.951570] net eth0: phy "48485000.mdio:00" not found on slave 0, err -19
    [ 12.969596] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 13.016311] EXT4-fs (mmcblk1p2): recovery complete
    [ 13.023252] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 15.015208] NET: Registered protocol family 44
    [ 16.657160] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service dce-callback with src 1024 dst 101
    [ 16.697785] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 4
    [ 16.705745] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: probing service rpmsg-dce with src 1025 dst 102
    [ 16.778454] rpmsg_rpc virtio1.rpmsg-rpc.-1.102: published functions = 9
    [ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
    [ OK ] Started Enable and configure wl18xx bluetooth stack.
    [ OK ] Started Lightning Fast Webserver With Light System Requirements.
    [ 17.712603] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 17.718884] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [ 17.733684] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
    [ 17.762082] xhci-hcd xhci-hcd.0.auto: irq 181, io mem 0x48890000
    [ 17.768368] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 17.780775] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 17.794080] usb usb1: Product: xHCI Host Controller
    [ 17.799731] usb usb1: Manufacturer: Linux 4.14.79-rt47-ga72bf1418c xhci-hcd
    [ 17.817517] usb usb1: SerialNumber: xhci-hcd.0.auto
    [ 17.839549] hub 1-0:1.0: USB hub found
    [ 17.843372] hub 1-0:1.0: 1 port detected
    [ 17.847993] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 17.854953] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [ 17.862965] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [ 17.871710] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 17.881960] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [ 17.888930] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 17.896296] usb usb2: Product: xHCI Host Controller
    [ 17.901320] usb usb2: Manufacturer: Linux 4.14.79-rt47-ga72bf1418c xhci-hcd
    [ 17.908858] usb usb2: SerialNumber: xhci-hcd.0.auto
    [ 17.929519] hub 2-0:1.0: USB hub found
    [ 17.935470] hub 2-0:1.0: 1 port detected
    autoconf
    bash-dev
    bash
    binutils-dev
    binutils
    bison-dev
    bison
    cifs-utils
    cpio
    cpp-symlinks
    cpp
    dosfstools
    elfutils-dev
    elfutils
    findutils
    g++-symlinks
    g++
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbc6x
    gdbserver
    gettext
    glmark2
    gstreamer1.0-libav
    gzip
    hidapi
    libasm1
    libcairo-perf-utils
    libdw1
    libelf1
    libgdbm-compat4
    libgdbm-dev
    libgdbm4
    libgettextlib
    libgettextsrc
    libgmp10
    libidn11
    libmavconn
    libmpc3
    libmpfr4
    libreadline-dev
    libreadline7
    libunistring2
    m4-dev
    m4
    make
    mavlink
    mavros-extras
    mavros-msgs
    mavros
    nettle
    parted
    python3-pycairo
    socketcan-interface
    swig-dev
    swig
    which
    [ OK ] Created slice system-systemd\x2dcoredump.slice.
    [ OK ] Started Process Core Dump (PID 660/UID 0).
    [ OK ] Started Process Core Dump (PID 659/UID 0).
    [ 20.328393] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [ OK ] Started Process Core Dump (PID 853/UID 0).
    [ OK ] Started Process Core Dump (PID 851/UID 0).
    [ 21.608018] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    _____ _____ _ _
    |___| |___|
    root@am57xx-evm:~#
    5.ethtool eth0
    Settings for eth0:
    Supports Wake-on: d
    Wake-on: d
    Link detected: no
    6. ethtool -S eth0
    root@am57xx-evm:~# ethtool -S eth0
    NIC statistics:
    Good Rx Frames: 0
    Broadcast Rx Frames: 0
    Multicast Rx Frames: 0
    Pause Rx Frames: 0
    Rx CRC Errors: 0
    Rx Align/Code Errors: 0
    Oversize Rx Frames: 0
    Rx Jabbers: 0
    Undersize (Short) Rx Frames: 0
    Rx Fragments: 0
    Rx Octets: 0
    Good Tx Frames: 0
    Broadcast Tx Frames: 0
    Multicast Tx Frames: 0
    Pause Tx Frames: 0
    Deferred Tx Frames: 0
    Collisions: 0
    Single Collision Tx Frames: 0
    Multiple Collision Tx Frames: 0
    Excessive Collisions: 0
    Late Collisions: 0
    Tx Underrun: 0
    Carrier Sense Errors: 0
    Tx Octets: 0
    Rx + Tx 64 Octet Frames: 0
    Rx + Tx 65-127 Octet Frames: 0
    Rx + Tx 128-255 Octet Frames: 0
    Rx + Tx 256-511 Octet Frames: 0
    Rx + Tx 512-1023 Octet Frames: 0
    Rx + Tx 1024-Up Octet Frames: 0
    Net Octets: 0
    Rx Start of Frame Overruns: 0
    Rx Middle of Frame Overruns: 0
    Rx DMA Overruns: 0
    Rx DMA chan 0: head_enqueue: 1
    Rx DMA chan 0: tail_enqueue: 127
    Rx DMA chan 0: pad_enqueue: 0
    Rx DMA chan 0: misqueued: 0
    Rx DMA chan 0: desc_alloc_fail: 0
    Rx DMA chan 0: pad_alloc_fail: 0
    Rx DMA chan 0: runt_receive_buf: 0
    Rx DMA chan 0: runt_transmit_bu: 0
    Rx DMA chan 0: empty_dequeue: 0
    Rx DMA chan 0: busy_dequeue: 0
    Rx DMA chan 0: good_dequeue: 0
    Rx DMA chan 0: requeue: 0
    Rx DMA chan 0: teardown_dequeue: 0
    Tx DMA chan 0: head_enqueue: 0
    Tx DMA chan 0: tail_enqueue: 0
    Tx DMA chan 0: pad_enqueue: 0
    Tx DMA chan 0: misqueued: 0
    Tx DMA chan 0: desc_alloc_fail: 0
    Tx DMA chan 0: pad_alloc_fail: 0
    Tx DMA chan 0: runt_receive_buf: 0
    Tx DMA chan 0: runt_transmit_bu: 0
    Tx DMA chan 0: empty_dequeue: 0
    Tx DMA chan 0: busy_dequeue: 0
    Tx DMA chan 0: good_dequeue: 0
    Tx DMA chan 0: requeue: 0
    Tx DMA chan 0: teardown_dequeue: 0
    7. ifconfig
    root@am57xx-evm:~# ifconfig
    eth0 Link encap:Ethernet HWaddr 94:E3:6D:4A:FE:F2
    inet addr:192.168.123.77 Bcast:192.168.123.255 Mask:255.255.255.0
    UP BROADCAST MULTICAST MTU:1500 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    Interrupt:89
    eth1 Link encap:Ethernet HWaddr 94:E3:6D:4A:FE:F3
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1%775872/128 Scope:Host
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:162 errors:0 dropped:0 overruns:0 frame:0
    TX packets:162 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:12300 (12.0 KiB) TX bytes:12300 (12.0 KiB)
  • I have solved this case.
    The MDIO probe is disconnected.
    This is a hardware problem.
    Other custom boards work well.
    Thank you.
