Part Number: DRA745
Tool/software: Linux
Hi,expert
I use vsdk0305 to run vdrm.
In customer board:
stop kmscube and run kmscube, found below error: could you please help to check?
root@dra7xx-evm:/opt/vision_sdk# root@dra7xx-evm:/opt/vision_sdk# /etc/init.d/weston stop Stopping Weston Terminated root@dra7xx-evm:/opt/vision_sdk# /etc/init.d/[ 59.798957] random: nonblocking pool is initialized root@dra7xx-evm:/opt/vision_sdk# root@dra7xx-evm:/opt/vision_sdk# root@dra7xx-evm:/opt/vision_sdk# root@dra7xx-evm:/opt/vision_sdk# root@dra7xx-evm:/opt/vision_sdk# kmscube -d /dev/dri/card0 ### Display [0]: CRTC = 26, Connector = 24, format = 0x34325258 Mode chosen [640x1440] : Clock => 57096, Vertical refresh => 60, Type => 72 Horizontal => 640, 646, 647, 650, 0 Vertical => 1440, 1454, 1457, 1464, 0 ### Primary display => ConnectorId = 24, Resolution = 640x1440 loaded module : gbm_pvr.so found valid GBM backend : gbm_pvr.so PVR:(Error): OpenServices: PVRDRMOpenRender failed [0, ] PVR:(Error): PVRSRVConnect: Unable to open connection. [0, ] PVR:(Error): Couldn't connect to services [0, ] failed to initialize failed to initialize EGL
Fredy
