NAND bad block with uboot, url, file system
NAND flash will have bad blocks. I want to know how the BBT handle it with the interaction with uboot, url, file system.
URL, and uboot seems to be stored at specific locations. If these locations have bad blocks, will it still work? if not, how to solve it?
thanks in advance.
Tao
  • Tao,
    The RBL expects UBL at a certain location, normally the beginning of flash; this is where it starts looking for it, but if it does not find it there it keeps searching the next few blocks (5 I believe); therefore if you have a bad block, it should be able to recover.... UBL programs location where u-boot can be found, hence u-boot can be moved around.
  • I look at the document of NAND boot. Yes, the RBL search for Page 0 of Block i for magic number, if does not find it, go to search for Page 0 of Block i+1.
    But it does not solve my problem directly. Let me make it more clear in an example. Assume Block 1 and Block 2 are bad, and UBL is within a block size. Does it need to write UBL multiple times in different Blocks, like Block 1, 2, 3, 4, 5, etc?
    And the UBL also find U-boot at specific pre-determined locations, if the flash in that location is corrupted, how UBL load U-boot?
    thanks a lot.
    Tao
