Part Number: AM5728
Tool/software: Linux
Am trying to sharing data between PRU2 & DSP1 core using 32kB shared memory location.
Using debugger am able to send and receive data using shared memory between two cores.
But as I tried same application using remoteproc approach, In which application of both cores( DSP & PRU ) run from linux side. Am not able to get communicate between two cores using shared memory region (0x4B290000) .
Already define shared memory region in resource table used by remoteproc. Without defining shared memory region in rsc_table_vayu_dsp file getting following error :
omap-iommu 40d01000.mmu: iommu fault: da 0x4b290020 flags
but after defining shared memory location error gone but not able to see data send from PRU core on DSP core.
Also found below rsc_table_vayu_dsp code I modified
* Copyright (c) 2012-2014, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== rsc_table_vayu_dsp.h ========
* Define the resource table entries for all DSP cores. This will be
* incorporated into corresponding base images, and used by the remoteproc
* on the host-side to allocated/reserve resources.
#ifndef _RSC_TABLE_VAYU_DSP_H_
#define _RSC_TABLE_VAYU_DSP_H_
#include <rsc_types.c>
/* DSP Memory Map */
#define L4_DRA7XX_BASE 0x4A000000
#define L4_PERIPHERAL_L4CFG (L4_DRA7XX_BASE)
#define DSP_PERIPHERAL_L4CFG 0x4A000000
#define L4_PERIPHERAL_L4PER1 0x48000000
#define DSP_PERIPHERAL_L4PER1 0x48000000
#define L3_SharedMemAddr 0x4B200000
#define DSP_SharedMem 0x4B290000
#define L4_PERIPHERAL_L4PER2 0x48400000
#define DSP_PERIPHERAL_L4PER2 0x48400000
#define L4_PERIPHERAL_L4PER3 0x48800000
#define DSP_PERIPHERAL_L4PER3 0x48800000
#define L4_PERIPHERAL_L4EMU 0x54000000
#define DSP_PERIPHERAL_L4EMU 0x54000000
#define L3_PERIPHERAL_DMM 0x4E000000
#define DSP_PERIPHERAL_DMM 0x4E000000
#define L3_TILER_MODE_0_1 0x60000000
#define DSP_TILER_MODE_0_1 0x60000000
#define L3_TILER_MODE_2 0x70000000
#define DSP_TILER_MODE_2 0x70000000
#define L3_TILER_MODE_3 0x78000000
#define DSP_TILER_MODE_3 0x78000000
#define DSP_MEM_TEXT 0x95000000
/* Co-locate alongside TILER region for easier flushing */
#define DSP_MEM_IOBUFS 0x80000000
#define DSP_MEM_DATA 0x95100000
#define DSP_MEM_HEAP 0x95200000
#define DSP_MEM_IPC_DATA 0x9F000000
#define DSP_MEM_IPC_VRING 0xA0000000
#define DSP_MEM_RPMSG_VRING0 0xA0000000
#define DSP_MEM_RPMSG_VRING1 0xA0004000
#define DSP_MEM_VRING_BUFS0 0xA0040000
#define DSP_MEM_VRING_BUFS1 0xA0080000
#define DSP_MEM_IPC_VRING_SIZE SZ_1M
#define DSP_MEM_IPC_DATA_SIZE SZ_1M
#define DSP_MEM_TEXT_SIZE SZ_1M
#define DSP_MEM_DATA_SIZE SZ_1M
#define DSP_MEM_HEAP_SIZE (SZ_1M * 3)
#define DSP_MEM_IOBUFS_SIZE (SZ_1M * 90)
#define DSP_SharedMem_SIZE 0x500
* Assign fixed RAM addresses to facilitate a fixed MMU table.
/* See CMA BASE addresses in Linux side: arch/arm/mach-omap2/remoteproc.c */
/* Added to make DSP2 compatible application but now working with this */
#define VAYU_DSP_1
//#define VAYU_DSP_2
#if defined (VAYU_DSP_1)
#define PHYS_MEM_IPC_VRING 0x99000000
#elif defined (VAYU_DSP_2)
#define PHYS_MEM_IPC_VRING 0x9F000000
#endif
/* Need to be identical to that of IPU */
#define PHYS_MEM_IOBUFS 0xBA300000
* Sizes of the virtqueues (expressed in number of buffers supported,
* and must be power of 2)
#define DSP_RPMSG_VQ0_SIZE 256
#define DSP_RPMSG_VQ1_SIZE 256
/* flip up bits whose indices represent features we support */
#define RPMSG_DSP_C0_FEATURES 1
struct my_resource_table {
struct resource_table base;
UInt32 offset[18]; /* Should match 'num' in actual definition */
/* rpmsg vdev entry */
struct fw_rsc_vdev rpmsg_vdev;
struct fw_rsc_vdev_vring rpmsg_vring0;
struct fw_rsc_vdev_vring rpmsg_vring1;
/* text carveout entry */
struct fw_rsc_carveout text_cout;
/* data carveout entry */
struct fw_rsc_carveout data_cout;
/* heap carveout entry */
struct fw_rsc_carveout heap_cout;
/* ipcdata carveout entry */
struct fw_rsc_carveout ipcdata_cout;
/* trace entry */
struct fw_rsc_trace trace;
/* devmem entry */
struct fw_rsc_devmem devmem0;
/* devmem entry */
struct fw_rsc_devmem devmem1;
/* devmem entry */
struct fw_rsc_devmem devmem2;
/* devmem entry */
struct fw_rsc_devmem devmem3;
/* devmem entry */
struct fw_rsc_devmem devmem4;
/* devmem entry */
struct fw_rsc_devmem devmem5;
/* devmem entry */
struct fw_rsc_devmem devmem6;
/* devmem entry */
struct fw_rsc_devmem devmem7;
/* devmem entry */
struct fw_rsc_devmem devmem8;
/* devmem entry */
struct fw_rsc_devmem devmem9;
/* devmem entry */
struct fw_rsc_devmem devmem10;
/* devmem entry */
struct fw_rsc_devmem devmem11;
extern char ti_trace_SysMin_Module_State_0_outbuf__A;
#define TRACEBUFADDR (UInt32)&ti_trace_SysMin_Module_State_0_outbuf__A
#pragma DATA_SECTION(ti_ipc_remoteproc_ResourceTable, ".resource_table")
#pragma DATA_ALIGN(ti_ipc_remoteproc_ResourceTable, 4096)
struct my_resource_table ti_ipc_remoteproc_ResourceTable = {
1, /* we're the first version that implements this */
18, /* number of entries in the table */
0, 0, /* reserved, must be zero */
/* offsets to entries */
offsetof(struct my_resource_table, rpmsg_vdev),
offsetof(struct my_resource_table, text_cout),
offsetof(struct my_resource_table, data_cout),
offsetof(struct my_resource_table, heap_cout),
offsetof(struct my_resource_table, ipcdata_cout),
offsetof(struct my_resource_table, trace),
offsetof(struct my_resource_table, devmem0),
offsetof(struct my_resource_table, devmem1),
offsetof(struct my_resource_table, devmem2),
offsetof(struct my_resource_table, devmem3),
offsetof(struct my_resource_table, devmem4),
offsetof(struct my_resource_table, devmem5),
offsetof(struct my_resource_table, devmem6),
offsetof(struct my_resource_table, devmem7),
offsetof(struct my_resource_table, devmem8),
offsetof(struct my_resource_table, devmem9),
offsetof(struct my_resource_table, devmem10),
offsetof(struct my_resource_table, devmem11),
TYPE_VDEV, VIRTIO_ID_RPMSG, 0,
RPMSG_DSP_C0_FEATURES, 0, 0, 0, 2, { 0, 0 },
/* no config data */
/* the two vrings */
{ DSP_MEM_RPMSG_VRING0, 4096, DSP_RPMSG_VQ0_SIZE, 1, 0 },
{ DSP_MEM_RPMSG_VRING1, 4096, DSP_RPMSG_VQ1_SIZE, 2, 0 },
TYPE_CARVEOUT,
DSP_MEM_TEXT, 0,
DSP_MEM_TEXT_SIZE, 0, 0, "DSP_MEM_TEXT",
TYPE_CARVEOUT,
DSP_MEM_DATA, 0,
DSP_MEM_DATA_SIZE, 0, 0, "DSP_MEM_DATA",
TYPE_CARVEOUT,
DSP_MEM_HEAP, 0,
DSP_MEM_HEAP_SIZE, 0, 0, "DSP_MEM_HEAP",
TYPE_CARVEOUT,
DSP_MEM_IPC_DATA, 0,
DSP_MEM_IPC_DATA_SIZE, 0, 0, "DSP_MEM_IPC_DATA",
TYPE_TRACE, TRACEBUFADDR, 0x8000, 0, "trace:dsp",
TYPE_DEVMEM,
DSP_MEM_IPC_VRING, PHYS_MEM_IPC_VRING,
DSP_MEM_IPC_VRING_SIZE, 0, 0, "DSP_MEM_IPC_VRING",
TYPE_DEVMEM,
DSP_MEM_IOBUFS, PHYS_MEM_IOBUFS,
DSP_MEM_IOBUFS_SIZE, 0, 0, "DSP_MEM_IOBUFS",
TYPE_DEVMEM,
DSP_TILER_MODE_0_1, L3_TILER_MODE_0_1,
SZ_256M, 0, 0, "DSP_TILER_MODE_0_1",
TYPE_DEVMEM,
DSP_TILER_MODE_2, L3_TILER_MODE_2,
SZ_128M, 0, 0, "DSP_TILER_MODE_2",
TYPE_DEVMEM,
DSP_TILER_MODE_3, L3_TILER_MODE_3,
SZ_128M, 0, 0, "DSP_TILER_MODE_3",
TYPE_DEVMEM,
DSP_PERIPHERAL_L4CFG, L4_PERIPHERAL_L4CFG,
SZ_16M, 0, 0, "DSP_PERIPHERAL_L4CFG",
TYPE_DEVMEM,
DSP_PERIPHERAL_L4PER1, L4_PERIPHERAL_L4PER1,
SZ_2M, 0, 0, "DSP_PERIPHERAL_L4PER1",
TYPE_DEVMEM,
DSP_PERIPHERAL_L4PER2, L4_PERIPHERAL_L4PER2,
SZ_4M, 0, 0, "DSP_PERIPHERAL_L4PER2",
TYPE_DEVMEM,
DSP_PERIPHERAL_L4PER3, L4_PERIPHERAL_L4PER3,
SZ_8M, 0, 0, "DSP_PERIPHERAL_L4PER3",
TYPE_DEVMEM,
DSP_PERIPHERAL_L4EMU, L4_PERIPHERAL_L4EMU,
SZ_16M, 0, 0, "DSP_PERIPHERAL_L4EMU",
TYPE_DEVMEM,
DSP_PERIPHERAL_DMM, L3_PERIPHERAL_DMM,
SZ_1M, 0, 0, "DSP_PERIPHERAL_DMM",
TYPE_DEVMEM,
DSP_SharedMem, L3_SharedMemAddr,
0x00001000, 0, 0, "DSP_SharedMem",
#endif /* _RSC_TABLE_VAYU_DSP_H_ */
Geek13
