Part Number: AM5728
Hi, in PinMux if one pin's pull up/down is checked:
1. what's the value of this pull up/down resistor? What's the difference from the resistor calculated from "IN with pull down enabled" or "IIN with pull up enabled" in datasheet section 5.7?
2. when will those pull up/down resistor take effective? After POR or after software has configured that pin?
3. If one pin works as output, is that internal pull down/up resistor still exist?
