Linux/PROCESSOR-SDK-AM335X: Azure IoT support
Part Number: PROCESSOR-SDK-AM335X
Tool/software: Linux
I need help with using azure-iot-sdk-c on the am335x. I am using am335x starter kit and i need to know how can i import library dependencies and header files for azure iot hub. I tried copying over the files to the filesystem but it couldn't boot up the device properly. Can someone point me to some materials or examples for working with Azure SDK on am335x.
    Thanks for your post. Customizing the SDK like this is beyond the scope of the support that we can offer. I will try to provide some guidance that I hope will help.
    We have a good training on this topic here:
    https://training.ti.com/customizing-yocto-for-production-series
    We use Yocto to build the SDK and it is the best way to do customizations like this. There appears to be a recipe for Azure here:
    https://layers.openembedded.org/layerindex/recipe/78209/
    So, you should be able to use Yocto to rebuild the SDK with the needed support. Here's another good reference for you:
    http://software-dl.ti.com/processor-sdk-linux/esd/docs/05_03_00_07/linux/Overview_Building_the_SDK.html
    This is really the extent of the help that we can offer. I hope this gets you off to a great start.
    Thanks.
    Thanks for the feedback. I had looked over the links you sent, it has helped me. After i run the initial bitbake build for am335x and tisdk-rootfs-image, i should add the meta-iot-cloud layer to the sources and the bblayer.conf file. Also, on their github link https://github.com/intel-iot-devkit/meta-iot-cloudTo build packages related to Microsoft Azure bitbake packagegroup-cloud-azure". Then, i should run this command. What should i expect after runnung this command. Would the azure sdk will be packaged with the image and the header files will be added to the usr/include/ folder?
    Vraj
  • Howdy,
    I've never run this recipe, but yes, that sounds like a reasonable expectation.
    Thanks.
  • Ok no problem, i just have one more question. I ran the bitbake build with -k for continuous build. I checked the deploy folder after it finished all the tasks. I got the uboot.img and MLO but i didnt get the tar file for the filesystem. I did get some errors. Could that be because of the errors?
  • Yes, probably so. Upon a successful build, you should have a few different filesystem images under the deploy/amxx-evm directory, along with kernel and device tree files.
    I hope this helps.
  • Hi, When i run the build, i stumble upon some errors and i don't understand how to fix them. I am attaching two files for the log file. Could you please help me how to fix them.
    DEBUG: Executing shell function do_compile
    NOTE: VERBOSE=1 cmake --build /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build -- -j 6
    /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -H/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0 -B/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build --check-build-system CMakeFiles/Makefile.cmake 0
    /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_progress_start /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/CMakeFiles /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/CMakeFiles/progress.marks
    make -f CMakeFiles/Makefile2 all
    make[1]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build'
    make -f common/CMakeFiles/pcl_common.dir/build.make common/CMakeFiles/pcl_common.dir/depend
    make -f octree/CMakeFiles/pcl_octree.dir/build.make octree/CMakeFiles/pcl_octree.dir/depend
    make -f io/CMakeFiles/pcl_io_ply.dir/build.make io/CMakeFiles/pcl_io_ply.dir/depend
    make -f io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/build.make io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/depend
    make[2]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build'
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build && /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0 /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/io/tools /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/io/tools /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/DependInfo.cmake --color=
    make[2]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build'
    make -f io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/build.make io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/build
    make[2]: Nothing to be done for 'io/tools/CMakeFiles/pcl_pcd_convert_NaN_nan.dir/build'.
    [  1%] Built target pcl_pcd_convert_NaN_nan
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build && /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0 /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/octree /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/octree/CMakeFiles/pcl_octree.dir/DependInfo.cmake --color=
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build && /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0 /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/io /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/io /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/io/CMakeFiles/pcl_io_ply.dir/DependInfo.cmake --color=
    make -f octree/CMakeFiles/pcl_octree.dir/build.make octree/CMakeFiles/pcl_octree.dir/build
    make -f io/CMakeFiles/pcl_io_ply.dir/build.make io/CMakeFiles/pcl_io_ply.dir/build
    [  1%] Building CXX object octree/CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/octree && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/src/octree_inst.cpp
    [  1%] Building CXX object io/CMakeFiles/pcl_io_ply.dir/src/ply/ply_parser.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/io && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/io/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_io_ply.dir/src/ply/ply_parser.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/io/src/ply/ply_parser.cpp
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build && /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0 /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common/CMakeFiles/pcl_common.dir/DependInfo.cmake --color=
    make -f common/CMakeFiles/pcl_common.dir/build.make common/CMakeFiles/pcl_common.dir/build
    [  1%] Building CXX object common/CMakeFiles/pcl_common.dir/src/pcl_base.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/pcl_base.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/pcl_base.cpp
    [  2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/poses_from_matches.cpp.o
    [  2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/projection_matrix.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/poses_from_matches.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/poses_from_matches.cpp
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/projection_matrix.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/projection_matrix.cpp
    [  2%] Building CXX object common/CMakeFiles/pcl_common.dir/src/time_trigger.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/time_trigger.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/time_trigger.cpp
    In file included from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3/Eigen/Core:276:0,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/include/pcl/octree/octree_nodes.h:49,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/include/pcl/octree/octree_base.h:45,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/include/pcl/octree/octree.h:43,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/octree/src/octree_inst.cpp:38:
    /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3/Eigen/src/Core/Functors.h:973:28: warning: ‘template<class _Operation> class std::binder2nd’ is deprecated [-Wdeprecated-declarations]
     struct functor_traits<std::binder2nd<T> >
    In file included from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_function.h:1127:0,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/string:48,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/locale_classes.h:40,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/ios_base.h:41,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/ios:42,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/istream:38,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/sstream:38,
                     from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/complex:45,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3/Eigen/Core:28,
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/backward/binders.h:143:11: note: declared here
         class binder2nd
    /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3/Eigen/src/Core/Functors.h:977:28: warning: ‘template<class _Operation> class std::binder1st’ is deprecated [-Wdeprecated-declarations]
     struct functor_traits<std::binder1st<T> >
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/backward/binders.h:108:11: note: declared here
         class binder1st
    [  3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/gaussian.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/gaussian.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/gaussian.cpp
    [  3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/colors.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/colors.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/colors.cpp
    [  3%] Building CXX object common/CMakeFiles/pcl_common.dir/src/bearing_angle_image.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/bearing_angle_image.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/bearing_angle_image.cpp
    arm-linux-gnueabihf-g++: internal compiler error: Killed (program cc1plus)
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <https://gcc.gnu.org/bugs/> for instructions.
    octree/CMakeFiles/pcl_octree.dir/build.make:65: recipe for target 'octree/CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o' failed
    make[2]: *** [octree/CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o] Error 4
    make[2]: *** Deleting file 'octree/CMakeFiles/pcl_octree.dir/src/octree_inst.cpp.o'
    CMakeFiles/Makefile2:175: recipe for target 'octree/CMakeFiles/pcl_octree.dir/all' failed
    make[1]: *** [octree/CMakeFiles/pcl_octree.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
    [  4%] Building CXX object common/CMakeFiles/pcl_common.dir/src/range_image.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/range_image.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/range_image.cpp
    [  4%] Building CXX object common/CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++  -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=  -ffloat-store  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -pthread -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/range_image_planar.cpp
    [  4%] Building C object common/CMakeFiles/pcl_common.dir/src/fft/kiss_fft.c.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=   -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/fft/kiss_fft.c.o   -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/fft/kiss_fft.c
    [  4%] Building C object common/CMakeFiles/pcl_common.dir/src/fft/kiss_fftr.c.o
    cd /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/common && /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc -DEIGEN_USE_NEW_STDVECTOR -DEIGEN_YES_I_KNOW_SPARSE_MODULE_IS_NOT_STABLE_YET -DPCLAPI_EXPORTS -Dqh_QHpointer -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include/eigen3 -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot/usr/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/recognition/include/pcl/recognition/3rdparty -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build/include -I/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0=/usr/src/debug/pcl/1.8.0-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot=   -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard  --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/recipe-sysroot -fopenmp -O2 -g -DNDEBUG -fPIC   -DBOOST_DISABLE_ASSERTS -DEIGEN_NO_DEBUG -o CMakeFiles/pcl_common.dir/src/fft/kiss_fftr.c.o   -c /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/fft/kiss_fftr.c
    {standard input}: Assembler messages:
    {standard input}:156760: Error: invalid operands (*UND* and .ARM.extab.text._ZN3pcl2io3ply10ply_parser19parse_list_propertyIhjEEbiRSiRKNS2_33list_property_begin_callback_typeIT_T0_E4typeERKNS2_35list_property_element_callback_typeIS6_S7_E4typeERKNS2_31list_property_end_callback_typeIS6_S7_E4typeE sections) for `-'
    {standard input}:156763: Error: invalid operands (*UND* and .ARM.extab.text._ZN3pcl2io3ply10ply_parser19parse_list_propertyIhjEEbiRSiRKNS2_33list_property_begin_callback_typeIT_T0_E4typeERKNS2_35list_property_element_callback_typeIS6_S7_E4typeERKNS2_31list_property_end_callback_typeIS6_S7_E4typeE sections) for `-'
    io/CMakeFiles/pcl_io_ply.dir/build.make:65: recipe for target 'io/CMakeFiles/pcl_io_ply.dir/src/ply/ply_parser.cpp.o' failed
    make[2]: *** [io/CMakeFiles/pcl_io_ply.dir/src/ply/ply_parser.cpp.o] Error 4
    CMakeFiles/Makefile2:234: recipe for target 'io/CMakeFiles/pcl_io_ply.dir/all' failed
    make[1]: *** [io/CMakeFiles/pcl_io_ply.dir/all] Error 2
    In file included from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/vector:69:0,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include/pcl/ModelCoefficients.h:4,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/include/pcl/common/eigen.h:56,
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/bearing_angle_image.cpp:43:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc: In member function ‘void std::vector<_Tp, _Alloc>::_M_fill_insert(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::size_type, const value_type&) [with _Tp = pcl::PointXYZRGBA; _Alloc = Eigen::aligned_allocator_indirection<pcl::PointXYZRGBA>]’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc:458:5: note: parameter passing for argument of type ‘std::vector<pcl::PointXYZRGBA, Eigen::aligned_allocator_indirection<pcl::PointXYZRGBA> >::iterator {aka __gnu_cxx::__normal_iterator<pcl::PointXYZRGBA*, std::vector<pcl::PointXYZRGBA, Eigen::aligned_allocator_indirection<pcl::PointXYZRGBA> > >}’ changed in GCC 7.1
    In file included from /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/vector:64:0,
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In member function ‘void pcl::BearingAngleImage::generateBAImage(pcl::PointCloud<pcl::PointXYZ>&)’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h:1087:16: note: parameter passing for argument of type ‘__gnu_cxx::__normal_iterator<pcl::PointXYZRGBA*, std::vector<pcl::PointXYZRGBA, Eigen::aligned_allocator_indirection<pcl::PointXYZRGBA> > >’ changed in GCC 7.1
      _M_fill_insert(begin() + __offset, __n, __x);
    common/CMakeFiles/pcl_common.dir/build.make:449: recipe for target 'common/CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o' failed
    make[2]: *** [common/CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o] Error 4
    make[2]: *** Deleting file 'common/CMakeFiles/pcl_common.dir/src/range_image_planar.cpp.o'
    make[2]: *** Waiting for unfinished jobs....
                     from /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/pcl-pcl-1.8.0/common/src/range_image.cpp:41:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc: In member function ‘void std::vector<_Tp, _Alloc>::_M_realloc_insert(std::vector<_Tp, _Alloc>::iterator, _Args&& ...) [with _Args = {const pcl::PointWithViewpoint&}; _Tp = pcl::PointWithViewpoint; _Alloc = Eigen::aligned_allocator_indirection<pcl::PointWithViewpoint>]’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc:394:7: note: parameter passing for argument of type ‘std::vector<pcl::PointWithViewpoint, Eigen::aligned_allocator_indirection<pcl::PointWithViewpoint> >::iterator {aka __gnu_cxx::__normal_iterator<pcl::PointWithViewpoint*, std::vector<pcl::PointWithViewpoint, Eigen::aligned_allocator_indirection<pcl::PointWithViewpoint> > >}’ changed in GCC 7.1
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In static member function ‘static void pcl::RangeImage::extractFarRanges(const pcl::PCLPointCloud2&, pcl::PointCloud<pcl::PointWithViewpoint>&)’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h:948:21: note: parameter passing for argument of type ‘__gnu_cxx::__normal_iterator<pcl::PointWithViewpoint*, std::vector<pcl::PointWithViewpoint, Eigen::aligned_allocator_indirection<pcl::PointWithViewpoint> > >’ changed in GCC 7.1
        _M_realloc_insert(end(), __x);
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc: In member function ‘void std::vector<_Tp, _Alloc>::_M_fill_insert(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::size_type, const value_type&) [with _Tp = pcl::PointWithRange; _Alloc = Eigen::aligned_allocator_indirection<pcl::PointWithRange>]’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/vector.tcc:458:5: note: parameter passing for argument of type ‘std::vector<pcl::PointWithRange, Eigen::aligned_allocator_indirection<pcl::PointWithRange> >::iterator {aka __gnu_cxx::__normal_iterator<pcl::PointWithRange*, std::vector<pcl::PointWithRange, Eigen::aligned_allocator_indirection<pcl::PointWithRange> > >}’ changed in GCC 7.1
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In member function ‘void pcl::RangeImage::cropImage(int, int, int, int, int)’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h:1087:16: note: parameter passing for argument of type ‘__gnu_cxx::__normal_iterator<pcl::PointWithRange*, std::vector<pcl::PointWithRange, Eigen::aligned_allocator_indirection<pcl::PointWithRange> > >’ changed in GCC 7.1
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In member function ‘virtual void pcl::RangeImage::getSubImage(int, int, int, int, int, pcl::RangeImage&) const’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In member function ‘virtual void pcl::RangeImage::getHalfImage(pcl::RangeImage&) const’:
    /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/7.2.1/bits/stl_vector.h: In member function ‘void pcl::RangeImage::createEmpty(float, float, const Affine3f&, pcl::RangeImage::CoordinateFrame, float, float)’:
    CMakeFiles/Makefile2:120: recipe for target 'common/CMakeFiles/pcl_common.dir/all' failed
    make[1]: *** [common/CMakeFiles/pcl_common.dir/all] Error 2
    make[1]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build'
    Makefile:143: recipe for target 'all' failed
    make: *** [all] Error 2
    WARNING: /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/temp/run.do_compile.11124:1 exit 2 from 'VERBOSE=1 cmake --build '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/build' -- -j 6'
    ERROR: Function failed: do_compile (log file is located at /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcl/1.8.0-r0/temp/log.do_compile.11124)
  • I also get this error too.
    DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'arm-32', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
    NOTE: make -j 6
    make  all-recursive
    make[1]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git'
    Making all in .
    make[2]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git'
    make[2]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git'
    Making all in src
    make[2]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git/src'
    make  all-am
    make[3]: Entering directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git/src'
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=link arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -version-info 14:0:0 -export-dynamic -no-undefined -Wl,--version-script=./libprotobuf-lite.map -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -Wl,-rpath-link,/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu -o libprotobuf-lite.la -rpath /usr/lib google/protobuf/stubs/atomicops_internals_x86_gcc.lo google/protobuf/stubs/atomicops_internals_x86_msvc.lo google/protobuf/stubs/bytestream.lo google/protobuf/stubs/common.lo google/protobuf/stubs/int128.lo google/protobuf/stubs/io_win32.lo google/protobuf/stubs/once.lo google/protobuf/stubs/status.lo google/protobuf/stubs/statusor.lo google/protobuf/stubs/stringpiece.lo google/protobuf/stubs/stringprintf.lo google/protobuf/stubs/structurally_valid.lo google/protobuf/stubs/strutil.lo google/protobuf/stubs/time.lo google/protobuf/arena.lo google/protobuf/arenastring.lo google/protobuf/extension_set.lo google/protobuf/generated_message_util.lo google/protobuf/generated_message_table_driven_lite.lo google/protobuf/message_lite.lo google/protobuf/repeated_field.lo google/protobuf/wire_format_lite.lo google/protobuf/io/coded_stream.lo google/protobuf/io/zero_copy_stream.lo google/protobuf/io/zero_copy_stream_impl_lite.lo -lpthread -lz
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=compile arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I..   -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -c -o google/protobuf/descriptor.lo google/protobuf/descriptor.cc
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=compile arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I..   -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -c -o google/protobuf/compiler/parser.lo google/protobuf/compiler/parser.cc
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=compile arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I..   -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -c -o google/protobuf/util/field_mask_util.lo google/protobuf/util/field_mask_util.cc
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=compile arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I..   -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -c -o google/protobuf/util/internal/datapiece.lo google/protobuf/util/internal/datapiece.cc
    ../arm-linux-gnueabi-libtool  --tag=CXX   --mode=compile arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I..   -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare  -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot=  -c -o google/protobuf/util/internal/default_value_objectwriter.lo google/protobuf/util/internal/default_value_objectwriter.cc
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/descriptor.cc  -fPIC -DPIC -o google/protobuf/.libs/descriptor.o
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/compiler/parser.cc  -fPIC -DPIC -o google/protobuf/compiler/.libs/parser.o
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/util/internal/default_value_objectwriter.cc  -fPIC -DPIC -o google/protobuf/util/internal/.libs/default_value_objectwriter.o
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/util/internal/datapiece.cc  -fPIC -DPIC -o google/protobuf/util/internal/.libs/datapiece.o
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/util/field_mask_util.cc  -fPIC -DPIC -o google/protobuf/util/.libs/field_mask_util.o
    arm-linux-gnueabihf-g++: error trying to exec '/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/as': execv: Cannot allocate memory
    virtual memory exhausted: Cannot allocate memory
    Makefile:4099: recipe for target 'google/protobuf/util/field_mask_util.lo' failed
    make[3]: *** [google/protobuf/util/field_mask_util.lo] Error 1
    make[3]: *** Waiting for unfinished jobs....
    arm-linux-gnueabi-libtool: link: arm-linux-gnueabihf-g++  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot  -fPIC -DPIC -shared -nostdlib /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot/usr/lib/crti.o /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/crtbeginS.o  google/protobuf/stubs/.libs/atomicops_internals_x86_gcc.o google/protobuf/stubs/.libs/atomicops_internals_x86_msvc.o google/protobuf/stubs/.libs/bytestream.o google/protobuf/stubs/.libs/common.o google/protobuf/stubs/.libs/int128.o google/protobuf/stubs/.libs/io_win32.o google/protobuf/stubs/.libs/once.o google/protobuf/stubs/.libs/status.o google/protobuf/stubs/.libs/statusor.o google/protobuf/stubs/.libs/stringpiece.o google/protobuf/stubs/.libs/stringprintf.o google/protobuf/stubs/.libs/structurally_valid.o google/protobuf/stubs/.libs/strutil.o google/protobuf/stubs/.libs/time.o google/protobuf/.libs/arena.o google/protobuf/.libs/arenastring.o google/protobuf/.libs/extension_set.o google/protobuf/.libs/generated_message_util.o google/protobuf/.libs/generated_message_table_driven_lite.o google/protobuf/.libs/message_lite.o google/protobuf/.libs/repeated_field.o google/protobuf/.libs/wire_format_lite.o google/protobuf/io/.libs/coded_stream.o google/protobuf/io/.libs/zero_copy_stream.o google/protobuf/io/.libs/zero_copy_stream_impl_lite.o   -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -lpthread -lz -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1 -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc -L/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/lib -L/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot/lib -L/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot/usr/lib -lstdc++ -lm -lc -lgcc_s /home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/crtendS.o /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot/usr/lib/crtn.o  -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -pthread -O2 -g -Wl,--version-script=./libprotobuf-lite.map -Wl,-rpath-link -Wl,/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib -Wl,-O1 -Wl,--hash-style=gnu   -pthread -Wl,-soname -Wl,libprotobuf-lite.so.14 -o .libs/libprotobuf-lite.so.14.0.0
    arm-linux-gnueabi-libtool: link: (cd ".libs" && rm -f "libprotobuf-lite.so.14" && ln -s "libprotobuf-lite.so.14.0.0" "libprotobuf-lite.so.14")
    arm-linux-gnueabi-libtool: link: (cd ".libs" && rm -f "libprotobuf-lite.so" && ln -s "libprotobuf-lite.so.14.0.0" "libprotobuf-lite.so")
    arm-linux-gnueabi-libtool: link: arm-linux-gnueabihf-ar cru .libs/libprotobuf-lite.a  google/protobuf/stubs/atomicops_internals_x86_gcc.o google/protobuf/stubs/atomicops_internals_x86_msvc.o google/protobuf/stubs/bytestream.o google/protobuf/stubs/common.o google/protobuf/stubs/int128.o google/protobuf/stubs/io_win32.o google/protobuf/stubs/once.o google/protobuf/stubs/status.o google/protobuf/stubs/statusor.o google/protobuf/stubs/stringpiece.o google/protobuf/stubs/stringprintf.o google/protobuf/stubs/structurally_valid.o google/protobuf/stubs/strutil.o google/protobuf/stubs/time.o google/protobuf/arena.o google/protobuf/arenastring.o google/protobuf/extension_set.o google/protobuf/generated_message_util.o google/protobuf/generated_message_table_driven_lite.o google/protobuf/message_lite.o google/protobuf/repeated_field.o google/protobuf/wire_format_lite.o google/protobuf/io/coded_stream.o google/protobuf/io/zero_copy_stream.o google/protobuf/io/zero_copy_stream_impl_lite.o
    arm-linux-gnueabi-libtool: link: arm-linux-gnueabihf-ranlib .libs/libprotobuf-lite.a
    ../arm-linux-gnueabi-libtool: fork: Cannot allocate memory
    Makefile:2247: recipe for target 'libprotobuf-lite.la' failed
    make[3]: *** [libprotobuf-lite.la] Error 254
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/util/internal/default_value_objectwriter.cc -o google/protobuf/util/internal/default_value_objectwriter.o >/dev/null 2>&1
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/util/internal/datapiece.cc -o google/protobuf/util/internal/datapiece.o >/dev/null 2>&1
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/compiler/parser.cc -o google/protobuf/compiler/parser.o >/dev/null 2>&1
    arm-linux-gnueabi-libtool: compile:  arm-linux-gnueabihf-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard --sysroot=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot -DHAVE_CONFIG_H -I. -I.. -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -pthread -DHAVE_PTHREAD=1 -DHAVE_ZLIB=1 -Wall -Wno-sign-compare -isystem/home/vraj/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0=/usr/src/debug/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0 -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/recipe-sysroot= -c google/protobuf/descriptor.cc -o google/protobuf/descriptor.o >/dev/null 2>&1
    make[3]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git/src'
    Makefile:2092: recipe for target 'all' failed
    make[2]: *** [all] Error 2
    make[2]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git/src'
    Makefile:1481: recipe for target 'all-recursive' failed
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory '/home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/git'
    Makefile:1388: recipe for target 'all' failed
    ERROR: oe_runmake failed
    WARNING: /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/temp/run.do_compile.17030:1 exit 1 from 'exit 1'
    ERROR: Function failed: do_compile (log file is located at /home/vraj/arago-azure-sdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/protobuf/3.4.1+gitAUTOINC+b04e5cba35-r0/temp/log.do_compile.17030)
  • I"m sorry, as I mentioned above, adding azure to the TI SDK is beyond the scope of the support that we provide. I'm sorry, I've never run this and I don't have any experience with it and won't be able to help.
