Part Number: TDA2EVM5777
Other Parts Discussed in Thread: TDA2, SYSBIOS
gmake -s sbl BOOTMODE=sd CORE=a15_0 SBL_BUILD_MODE=prod SBL_OPT_MODE=high EMIFMODE=SBLLIB_DUAL_EMIF_2X512MB OPPMODE=opp_nom
The above MLO gmake script configures the DMM and MA_MPU LISA_MAP_0 and LISA_MAP_1 registers with 0x80640300U. By updating that value to 0x80740300U would all cores have full access to the first 2GiB of DDR space in interleaved mode or is there anything else that would be necessary?
For the A15 to access the additional 2GiB space the A15 core needs to use a 40b address. Under Linux that requires enabling the ARM LPAE support. How does that translate to non-linux starterware software? How would the A15 cores access all 4GiB range and IPU/DSP cores access the 2GiB range in the same application app?
