Linux/AM5728: AM5728 issue with eMMC
Part Number: AM5728
Tool/software: Linux
We are working on custom board based on AM5728 . The board works fine with micro sd card loaded with all the linux SDK 03.02 . We wanted to copy it to eMMC and hence tried formatting it using fdisk.we observed the following errors.kindly help.
Messages on terminal of custom board 1:
root@am57xx-evm:~# fdisk /dev/mmcblk1
Welcome to fdisk (util-linux 2.27.1).
Changes will remain in memory only, until you decide to write them.[  340.491341] mmcblk1: error -110 sending status command, retrying
Be careful before using the write command.
[  340.507205] mmcblk1: error -110 sending status command, retrying
[  340.517452] mmcblk1: error -110 sending status command, aborting
[  340.523519] blk_update_request: 43 callbacks suppressed
[  340.528805] blk_update_request: I/O error, dev mmcblk1, sector 0
[  340.534933] mmcblk1: error -110 sending status command, retrying
[  340.541007] mmcblk1: error -110 sending status command, retrying
[  340.547048] mmcblk1: error -110 sending status command, aborting
[  340.553111] blk_update_request: I/O error, dev mmcblk1, sector 0
[  340.559177] Buffer I/O error on dev mmcblk1, logical block 0, async page read
dfisk: acnnot open /dev/mmcblk1 :Input/output error
orot@am57xx-evm:~#
Messages on terminal of custom board 2:
root@am57xx-evm:~# mkfs.vfat -F 32 -n "boot" /dev/mmcblk1p1
mkfs.fat 3.0.28 (2015-05-16)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
root@am57xx-evm:~# mkfs.ext3 -L "rootfs" /dev/mmcblk1p2
mke2fs 1.43-WIP (18-May-2015)
Discarding device blocks: done
Creating filesystem with 3586304 4k blocks and 897600 inodes
Filesystem UUID: 7f3e4b4c-699c-4750-bef3-29a3bd05b936
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: [  245.192608] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.202165] mmcblk1: error -5 transferring data, sector 15611920, nr 2560, cmd response 0x900, card status 0xc00
[  245.212528] blk_update_request: I/O error, dev mmcblk1, sector 15611920
[  245.220815] Buffer I/O error on dev mmcblk1p2, logical block 1933314, lost async page write
[  245.230044] blk_update_request: I/O error, dev mmcblk1, sector 15611928
[  245.236698] Buffer I/O error on dev mmcblk1p2, logical block 1933315, lost async page write
[  245.246759] blk_update_request: I/O error, dev mmcblk1, sector 15611936
[  245.254236] Buffer I/O error on dev mmcblk1p2, logical block 1933316, lost async page write
[  245.263680] blk_update_request: I/O error, dev mmcblk1, sector 15611944
[  245.271187] Buffer I/O error on dev mmcblk1p2, logical block 1933317, lost async page write
[  245.280510] blk_update_request: I/O error, dev mmcblk1, sector 15611952
[  245.287164] Buffer I/O error on dev mmcblk1p2, logical block 1933318, lost async page write
[  245.297275] blk_update_request: I/O error, dev mmcblk1, sector 15611960
[  245.304587] Buffer I/O error on dev mmcblk1p2, logical block 1933319, lost async page write
[  245.313699] blk_update_request: I/O error, dev mmcblk1, sector 15611968
[  245.321008] Buffer I/O error on dev mmcblk1p2, logical block 1933320, lost async page write
[  245.330302] blk_update_request: I/O error, dev mmcblk1, sector 15611976
[  245.336950] Buffer I/O error on dev mmcblk1p2, logical block 1933321, lost async page write
[  245.346652] blk_update_request: I/O error, dev mmcblk1, sector 15611984
[  245.353958] Buffer I/O error on dev mmcblk1p2, logical block 1933322, lost async page write
[  245.363040] blk_update_request: I/O error, dev mmcblk1, sector 15611992
[  245.370361] Buffer I/O error on dev mmcblk1p2, logical block 1933323, lost async page write
[  245.385384] mmcblk1: error -84 transferring data, sector 15614480, nr 1520, cmd response 0x900, card status 0xc00
[  245.398797] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.406592] mmcblk1: error -5 transferring data, sector 15874064, nr 2560, cmd response 0x900, card status 0xc00
[  245.423686] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.431494] mmcblk1: error -5 transferring data, sector 15876624, nr 1520, cmd response 0x900, card status 0xc00
[  245.473409] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.483007] mmcblk1: error -5 transferring data, sector 16136208, nr 2560, cmd response 0x900, card status 0xc00
[  245.500495] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.509485] mmcblk1: error -5 transferring data, sector 16138768, nr 1520, cmd response 0x900, card status 0x0
[  245.521960] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.531550] mmcblk1: error -5 transferring data, sector 16398352, nr 2560, cmd response 0x900, card status 0xc00
[  245.547911] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.557532] mmcblk1: error -5 transferring data, sector 16400912, nr 1520, cmd response 0x900, card status 0xc00
[  245.571177] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.580164] mmcblk1: error -5 transferring data, sector 16660496, nr 2560, cmd response 0x900, card status 0xc00
[  245.596619] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.606205] mmcblk1: error -5 transferring data, sector 16663056, nr 1520, cmd response 0x900, card status 0xc00
[  245.619589] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.627420] mmcblk1: error -5 transferring data, sector 16922640, nr 2560, cmd response 0x900, card status 0x0
[  245.644234] mmcblk1: error -84 transferring data, sector 16925200, nr 1520, cmd response 0x900, card status 0xc00
[  245.656371] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.665535] mmcblk1: error -5 transferring data, sector 17184784, nr 2560, cmd response 0x900, card status 0xc00
[  245.681164] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.689794] mmcblk1: error -5 transferring data, sector 17187344, nr 1520, cmd response 0x900, card status 0xc00
[  245.701850] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.710890] mmcblk1: error -5 transferring data, sector 17446928, nr 2560, cmd response 0x900, card status 0xc00
[  245.725990] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.735335] mmcblk1: error -5 transferring data, sector 17449488, nr 1520, cmd response 0x900, card status 0xc00
[  245.747485] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.756755] mmcblk1: error -5 transferring data, sector 17709072, nr 2560, cmd response 0x900, card status 0xc00
[  245.772914] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.781797] mmcblk1: error -5 transferring data, sector 17711632, nr 1520, cmd response 0x900, card status 0x0
[  245.793930] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.803213] mmcblk1: error -5 transferring data, sector 17971216, nr 2560, cmd response 0x900, card status 0xc00
done
[  245.819243] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.827057] mmcblk1: error -5 transferring data, sector 17973776, nr 1520, cmd response 0x900, card status 0xc00
[  245.840659] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.849265] mmcblk1: error -5 transferring data, sector 18233360, nr 2560, cmd response 0x900, card status 0xc00
[  245.864310] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.873424] mmcblk1: error -5 transferring data, sector 18235920, nr 1520, cmd response 0x900, card status 0xc00
[  245.885559] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.894835] mmcblk1: error -5 transferring data, sector 18495504, nr 2560, cmd response 0x900, card status 0xc00
Creating journal (32768 blocks): [  245.910680] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.920546] mmcblk1: error -5 transferring data, sector 18498064, nr 1520, cmd response 0x900, card status 0xc00
[  245.932636] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.941788] mmcblk1: error -5 transferring data, sector 18757648, nr 2560, cmd response 0x900, card status 0xc00
[  245.956886] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.966058] mmcblk1: error -5 transferring data, sector 18760208, nr 1520, cmd response 0x900, card status 0xc00
[  245.978691] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  245.986480] mmcblk1: error -5 transferring data, sector 19019792, nr 2560, cmd response 0x900, card status 0xc00
[  246.002938] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.011597] mmcblk1: error -5 transferring data, sector 19022352, nr 1520, cmd response 0x900, card status 0xc00
[  246.023745] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.032790] mmcblk1: error -5 transferring data, sector 19281936, nr 2560, cmd response 0x900, card status 0xc00
[  246.047903] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.057063] mmcblk1: error -5 transferring data, sector 19284496, nr 1520, cmd response 0x900, card status 0xc00
[  246.069745] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.077525] mmcblk1: error -5 transferring data, sector 19544080, nr 2560, cmd response 0x900, card status 0xc00
[  246.093918] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.102591] mmcblk1: error -5 transferring data, sector 19546640, nr 1520, cmd response 0x900, card status 0xc00
[  246.114668] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.123801] mmcblk1: error -5 transferring data, sector 19806224, nr 2560, cmd response 0x900, card status 0xc00
[  246.140058] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.147892] mmcblk1: error -5 transferring data, sector 19808784, nr 1520, cmd response 0x900, card status 0xc00
[  246.161285] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.169894] mmcblk1: error -5 transferring data, sector 20068368, nr 2560, cmd response 0x900, card status 0xc00
[  246.184969] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.194311] mmcblk1: error -5 transferring data, sector 20070928, nr 1520, cmd response 0x900, card status 0xc00
[  246.206389] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.215534] mmcblk1: error -5 transferring data, sector 20330512, nr 2560, cmd response 0x900, card status 0xc00
[  246.231390] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.240069] mmcblk1: error -5 transferring data, sector 20333072, nr 1520, cmd response 0x900, card status 0xc00
[  246.252129] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.261318] mmcblk1: error -5 transferring data, sector 20592656, nr 2560, cmd response 0x900, card status 0xc00
[  246.276461] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.285597] mmcblk1: error -5 transferring data, sector 20595216, nr 1520, cmd response 0x900, card status 0xc00
[  246.297649] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.306742] mmcblk1: error -5 transferring data, sector 20854800, nr 2560, cmd response 0x900, card status 0xc00
[  246.322556] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.331237] mmcblk1: error -5 transferring data, sector 20857360, nr 1520, cmd response 0x900, card status 0xc00
[  246.343996] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.353148] mmcblk1: error -5 transferring data, sector 21116944, nr 2560, cmd response 0x900, card status 0xc00
[  246.368862] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.376670] mmcblk1: error -5 transferring data, sector 21119504, nr 1520, cmd response 0x900, card status 0xc00
[  246.393568] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.401373] mmcblk1: error -5 transferring data, sector 21386104, nr 2560, cmd response 0x900, card status 0xc00
[  246.420869] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.429565] mmcblk1: error -5 transferring data, sector 21388664, nr 1520, cmd response 0x900, card status 0xc00
[  246.441638] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.450933] mmcblk1: error -5 transferring data, sector 21641232, nr 2560, cmd response 0x900, card status 0xc00
[  246.466108] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.475479] mmcblk1: error -5 transferring data, sector 21643792, nr 1520, cmd response 0x900, card status 0xc00
[  246.487559] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.495980] mmcblk1: error -5 transferring data, sector 21903376, nr 2560, cmd response 0x900, card status 0xc00
[  246.513591] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.522315] mmcblk1: error -5 transferring data, sector 21905936, nr 1520, cmd response 0x900, card status 0xc00
[  246.534349] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.542199] mmcblk1: error -5 transferring data, sector 22165520, nr 2560, cmd response 0x900, card status 0xc00
[  246.557506] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.565414] mmcblk1: error -5 transferring data, sector 22168080, nr 1520, cmd response 0x900, card status 0xc00
[  246.577543] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.585368] mmcblk1: error -5 transferring data, sector 22427664, nr 2560, cmd response 0x900, card status 0xc00
[  246.600523] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.608388] mmcblk1: error -5 transferring data, sector 22430224, nr 1520, cmd response 0x900, card status 0xc00
[  246.620452] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.628248] mmcblk1: error -5 transferring data, sector 22689808, nr 2560, cmd response 0x900, card status 0xc00
[  246.643388] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.651242] mmcblk1: error -5 transferring data, sector 22692368, nr 1520, cmd response 0x900, card status 0xc00
[  246.663324] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.671129] mmcblk1: error -5 transferring data, sector 22951952, nr 2560, cmd response 0x900, card status 0xc00
[  246.686246] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.694084] mmcblk1: error -5 transferring data, sector 22954512, nr 1520, cmd response 0x900, card status 0xc00
[  246.706219] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.714059] mmcblk1: error -5 transferring data, sector 23214096, nr 2560, cmd response 0x900, card status 0xc00
[  246.729460] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.737296] mmcblk1: error -5 transferring data, sector 23216656, nr 1520, cmd response 0x900, card status 0xc00
[  246.749442] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.757218] mmcblk1: error -5 transferring data, sector 23476240, nr 2560, cmd response 0x900, card status 0xc00
[  246.772424] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.780285] mmcblk1: error -5 transferring data, sector 23478800, nr 1520, cmd response 0x900, card status 0xc00
[  246.792355] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.800183] mmcblk1: error -5 transferring data, sector 23738384, nr 2560, cmd response 0x900, card status 0xc00
[  246.815466] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.823385] mmcblk1: error -5 transferring data, sector 23740944, nr 1520, cmd response 0x900, card status 0xc00
[  246.835697] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.843558] mmcblk1: error -5 transferring data, sector 24000528, nr 2560, cmd response 0x900, card status 0xc00
[  246.858996] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.866847] mmcblk1: error -5 transferring data, sector 24003088, nr 1520, cmd response 0x900, card status 0xc00
[  246.879132] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.886919] mmcblk1: error -5 transferring data, sector 24262672, nr 2560, cmd response 0x900, card status 0xc00
[  246.902054] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.909917] mmcblk1: error -5 transferring data, sector 24265232, nr 1520, cmd response 0x900, card status 0xc00
[  246.921988] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.929791] mmcblk1: error -5 transferring data, sector 24524816, nr 2560, cmd response 0x900, card status 0xc00
[  246.944909] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.952747] mmcblk1: error -5 transferring data, sector 24527376, nr 1520, cmd response 0x900, card status 0xc00
[  246.964812] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.972610] mmcblk1: error -5 transferring data, sector 24786960, nr 2560, cmd response 0x900, card status 0xc00
[  246.987744] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  246.995573] mmcblk1: error -5 transferring data, sector 24789520, nr 1520, cmd response 0x900, card status 0xc00
[  247.007629] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.015461] mmcblk1: error -5 transferring data, sector 25049104, nr 2560, cmd response 0x900, card status 0xc00
[  247.030642] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.038561] mmcblk1: error -5 transferring data, sector 25051664, nr 1520, cmd response 0x900, card status 0xc00
[  247.050600] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.058446] mmcblk1: error -5 transferring data, sector 25311248, nr 2560, cmd response 0x900, card status 0xc00
[  247.073580] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.081436] mmcblk1: error -5 transferring data, sector 25313808, nr 1520, cmd response 0x900, card status 0xc00
[  247.093664] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.101465] mmcblk1: error -5 transferring data, sector 25573392, nr 2560, cmd response 0x900, card status 0xc00
[  247.116563] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.124398] mmcblk1: error -5 transferring data, sector 25575952, nr 1520, cmd response 0x900, card status 0xc00
[  247.136461] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.144267] mmcblk1: error -5 transferring data, sector 25835536, nr 2560, cmd response 0x900, card status 0xc00
[  247.159599] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.167414] mmcblk1: error -5 transferring data, sector 25838096, nr 1520, cmd response 0x900, card status 0xc00
[  247.179578] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.187362] mmcblk1: error -5 transferring data, sector 26097680, nr 2560, cmd response 0x900, card status 0xc00
[  247.202505] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.210358] mmcblk1: error -5 transferring data, sector 26100240, nr 1520, cmd response 0x900, card status 0xc00
[  247.222412] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.230229] mmcblk1: error -5 transferring data, sector 26359824, nr 2560, cmd response 0x900, card status 0xc00
[  247.245334] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.253178] mmcblk1: error -5 transferring data, sector 26362384, nr 1520, cmd response 0x900, card status 0xc00
[  247.265273] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.273069] mmcblk1: error -5 transferring data, sector 26621968, nr 2560, cmd response 0x900, card status 0xc00
[  247.288212] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.296019] mmcblk1: error -5 transferring data, sector 26624528, nr 1520, cmd response 0x900, card status 0xc00
[  247.308178] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.315956] mmcblk1: error -5 transferring data, sector 26884112, nr 2560, cmd response 0x900, card status 0xc00
[  247.331133] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.338974] mmcblk1: error -5 transferring data, sector 26886672, nr 1520, cmd response 0x900, card status 0xc00
[  247.351761] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.359583] mmcblk1: error -5 transferring data, sector 27146256, nr 2560, cmd response 0x900, card status 0xc00
[  247.374662] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.382503] mmcblk1: error -5 transferring data, sector 27148816, nr 1520, cmd response 0x900, card status 0xc00
[  247.394532] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.402362] mmcblk1: error -5 transferring data, sector 27408400, nr 2560, cmd response 0x900, card status 0xc00
[  247.417491] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.425330] mmcblk1: error -5 transferring data, sector 27410960, nr 1520, cmd response 0x900, card status 0xc00
[  247.437396] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.445201] mmcblk1: error -5 transferring data, sector 27670544, nr 2560, cmd response 0x900, card status 0xc00
[  247.460477] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.468324] mmcblk1: error -5 transferring data, sector 27673104, nr 1520, cmd response 0x900, card status 0xc00
[  247.480444] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.488252] mmcblk1: error -5 transferring data, sector 27932688, nr 2560, cmd response 0x900, card status 0xc00
[  247.503360] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.511218] mmcblk1: error -5 transferring data, sector 27935248, nr 1520, cmd response 0x900, card status 0xc00
[  247.523268] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.531067] mmcblk1: error -5 transferring data, sector 28194832, nr 2560, cmd response 0x900, card status 0xc00
[  247.546214] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.554049] mmcblk1: error -5 transferring data, sector 28197392, nr 1520, cmd response 0x900, card status 0xc00
[  247.566129] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.573970] mmcblk1: error -5 transferring data, sector 28456976, nr 2560, cmd response 0x900, card status 0xc00
[  247.589186] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.596990] mmcblk1: error -5 transferring data, sector 145424, nr 2560, cmd response 0x900, card status 0xc00
[  247.611977] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.619809] mmcblk1: error -5 transferring data, sector 147984, nr 2560, cmd response 0x900, card status 0xc00
[  247.634726] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.642473] mmcblk1: error -5 transferring data, sector 150544, nr 1880, cmd response 0x900, card status 0xc00
[  247.655132] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.662997] mmcblk1: error -5 transferring data, sector 152440, nr 8, cmd response 0x900, card status 0xc00
[  247.672909] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.680738] mmcblk1: error -5 transferring data, sector 156520, nr 2560, cmd response 0x900, card status 0xc00
[  247.695675] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.703517] mmcblk1: error -5 transferring data, sector 159080, nr 2560, cmd response 0x900, card status 0xc00
[  247.718523] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.726271] mmcblk1: error -5 transferring data, sector 161640, nr 2560, cmd response 0x900, card status 0xc00
[  247.741284] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.749147] mmcblk1: error -5 transferring data, sector 164200, nr 664, cmd response 0x900, card status 0xc00
[  247.759734] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.767547] mmcblk1: error -5 transferring data, sector 164872, nr 2560, cmd response 0x900, card status 0xc00
[  247.782583] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.790437] mmcblk1: error -5 transferring data, sector 167432, nr 2560, cmd response 0x900, card status 0xc00
[  247.805457] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.813339] mmcblk1: error -5 transferring data, sector 169992, nr 2560, cmd response 0x900, card status 0xc00
[  247.828347] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  247.836133] mmcblk1: error -5 transferring data, sector 172552, nr 2560, cmd response 0x900, card status 0xc00
[  248.281134] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.294035] mmcblk1: error -5 transferring data, sector 200712, nr 2560, cmd response 0x900, card status 0xc00
[  248.312596] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.322487] mmcblk1: error -5 transferring data, sector 203272, nr 2560, cmd response 0x900, card status 0xc00
[  248.342588] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.350611] mmcblk1: error -5 transferring data, sector 205832, nr 2560, cmd response 0x900, card status 0xc00
[  248.372085] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.381027] mmcblk1: error -5 transferring data, sector 208392, nr 2560, cmd response 0x900, card status 0xc00
[  248.399188] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.407030] mmcblk1: error -5 transferring data, sector 210952, nr 2560, cmd response 0x900, card status 0xc00
[  248.425259] mmcblk1: error -84 transferring data, sector 213512, nr 2560, cmd response 0x900, card status 0x0
[  248.442571] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.452771] mmcblk1: error -5 transferring data, sector 216072, nr 2560, cmd response 0x900, card status 0xc00
[  248.471450] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.483177] mmcblk1: error -5 transferring data, sector 218632, nr 2560, cmd response 0x900, card status 0xc00
[  248.503363] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.511176] mmcblk1: error -5 transferring data, sector 221192, nr 2560, cmd response 0x900, card status 0xc00
[  248.533105] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.542185] mmcblk1: error -5 transferring data, sector 223752, nr 2560, cmd response 0x900, card status 0xc00
[  248.559351] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.567253] mmcblk1: error -5 transferring data, sector 226312, nr 2560, cmd response 0x900, card status 0xc00
[  248.585256] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.594221] mmcblk1: error -5 transferring data, sector 228872, nr 2560, cmd response 0x900, card status 0xc00
[  248.611491] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.620411] mmcblk1: error -5 transferring data, sector 231432, nr 2560, cmd response 0x900, card status 0xc00
[  248.636703] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.646209] mmcblk1: error -5 transferring data, sector 233992, nr 2560, cmd response 0x900, card status 0xc00
[  248.672197] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.680053] mmcblk1: error -5 transferring data, sector 236552, nr 2128, cmd response 0x900, card status 0xc00
[  248.701442] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.709274] mmcblk1: error -5 transferring data, sector 238680, nr 2560, cmd response 0x900, card status 0xc00
[  248.729575] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.737334] mmcblk1: error -5 transferring data, sector 241240, nr 2560, cmd response 0x900, card status 0xc00
[  248.755085] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.764156] mmcblk1: error -5 transferring data, sector 243800, nr 2560, cmd response 0x900, card status 0xc00
[  248.780823] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.788828] mmcblk1: error -5 transferring data, sector 246360, nr 2560, cmd response 0x900, card status 0xc00
[  248.805307] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.813344] mmcblk1: error -5 transferring data, sector 248920, nr 2560, cmd response 0x900, card status 0xc00
done
Writing superblocks and filesystem accounting information: [  248.830257] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.838216] mmcblk1: error -5 transferring data, sector 251480, nr 2560, cmd response 0x900, card status 0xc00
[  248.853511] omap_hsmmc 480b4000.mmc: ADMA err: ST_FDS, erroneous desc at 0x00000000
[  248.861327] mmcblk1: error -5 transferring data, sector 254040, nr 2560, cmd response 0x900, card status 0xc00
[  251.478434] VFS: Dirty inode writeback failed for block device mmcblk1p2 (err=-5).
done
