Part Number: DRA77P
Other Parts Discussed in Thread: TPD12S015
Tool/software: Linux
We intent to use the lcd1 interface for hdmi on our custom board.
The block diagram of the circuit is as follows,
We have made required changes in the pin mux and added lcd node in the device tree.
* Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/dts-v1/;
#include "dra76x.dtsi"
#include "dra7-evm-common.dtsi"
#include "dra76x-mmc-iodelay.dtsi"
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/display/tda998x.h>
model = "TI DRA762 EVM";
compatible = "ti,dra76-evm", "ti,dra762", "ti,dra7";
aliases {
display0 = &hdmi0;
display1 = &lcd;
sound0 = &sound0;
sound1 = &hdmi;
rtc = &pcf85063;
memory@0 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x80000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ipu2_cma_pool: ipu2_cma@95800000 {
compatible = "shared-dma-pool";
reg = <0x0 0x95800000 0x0 0x3800000>;
reusable;
status = "okay";
dsp1_cma_pool: dsp1_cma@99000000 {
reg = <0x0 0x99000000 0x0 0x4000000>;
reusable;
status = "okay";
ipu1_cma_pool: ipu1_cma@9d000000 {
reg = <0x0 0x9d000000 0x0 0x2000000>;
reusable;
status = "okay";
dsp2_cma_pool: dsp2_cma@9f000000 {
reg = <0x0 0x9f000000 0x0 0x800000>;
reusable;
status = "okay";
vsys_12v0: fixedregulator-vsys12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "vsys_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_5v0: fixedregulator-vsys5v0 {
/* Output of Cntlr B of TPS43351-Q1 on dra76-evm */
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&vsys_12v0>;
regulator-boot-on;
vio_3v6: fixedregulator-vio_3v6 {
regulator-name = "vio_3v6";
regulator-min-microvolt = <3600000>;
regulator-max-microvolt = <3600000>;
vin-supply = <&vsys_5v0>;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output of Cntlr A of TPS43351-Q1 on dra76-evm */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vio_3v3: fixedregulator-vio_3v3 {
regulator-name = "vio_3v3";
vin-supply = <&vsys_3v3>;
regulator-boot-on;
vio_3v3_sd: fixedregulator-sd {
regulator-name = "vio_3v3_sd";
vin-supply = <&vio_3v3>;
enable-active-high;
gpio = <&gpio4 21 GPIO_ACTIVE_HIGH>;
vio_1v8: fixedregulator-vio_1v8 {
regulator-name = "vio_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vin-supply = <&smps5_reg>;
wlan_regulator: fixedregulator-wlan_regulator {
regulator-name = "wlan_regulator";
regulator-boot-on;
/*gpio = <&gpio3 29 GPIO_ACTIVE_HIGH>;
enable-active-high;*/
vmmcwl_fixed: fixedregulator-mmcwl {
regulator-name = "vmmcwl_fixed";
gpio = <&gpio5 8 0>; /* gpio5_8 */
startup-delay-us = <70000>;
enable-active-high;
vtt_fixed: fixedregulator-vtt {
regulator-name = "vtt_fixed";
regulator-min-microvolt = <1350000>;
regulator-max-microvolt = <1350000>;
regulator-boot-on;
aic_dvdd: fixedregulator-aic_dvdd {
/* TPS77018DBVT */
regulator-name = "aic_dvdd";
lcd: display {
* TODO: Not a DPI panel, but a dummy DSI video mode panel.
* This needs to be changed later when we can support DSI VM
* panels properly.
compatible = "osd,osd101t2045-53ts", "panel-dpi";
label = "lcd";
/*backlight = <&lcd_bl>;*/
panel-timing {
clock-frequency = <154000000>;
hactive = <1920>;
vactive = <1200>;
hfront-porch = <112>;
hback-porch = <32>;
hsync-len = <16>;
vfront-porch = <16>;
vback-porch = <16>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
port {
lcd_in: endpoint {
remote-endpoint = <&hdmi_0>;
hdmi0: connector {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&tpd12s015_out>;
tpd12s015: encoder {
compatible = "ti,tpd12s015";
gpios = <&gpio7 30 GPIO_ACTIVE_HIGH>, /* gpio7_30, CT CP HPD */
<&gpio7 31 GPIO_ACTIVE_HIGH>, /* gpio7_31, LS OE */
<&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tpd12s015_in: endpoint {
remote-endpoint = <&hdmi_out>;
port@1 {
reg = <1>;
tpd12s015_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
&i2c1 {
status = "okay";
clock-frequency = <400000>;
tps65917: tps65917@58 {
compatible = "ti,tps65917";
reg = <0x58>;
ti,system-power-controller;
ti,palmas-override-powerhold;
interrupt-controller;
#interrupt-cells = <2>;
tps65917_pmic {
compatible = "ti,tps65917-pmic";
smps12-in-supply = <&vsys_3v3>;
smps3-in-supply = <&vsys_3v3>;
smps4-in-supply = <&vsys_3v3>;
smps5-in-supply = <&vsys_3v3>;
ldo1-in-supply = <&vsys_3v3>;
ldo2-in-supply = <&vsys_3v3>;
ldo3-in-supply = <&vsys_5v0>;
ldo4-in-supply = <&vsys_5v0>;
ldo5-in-supply = <&vsys_3v3>;
tps65917_regulators: regulators {
smps12_reg: smps12 {
/* VDD_DSPEVE */
regulator-name = "smps12";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <1250000>;
regulator-boot-on;
smps3_reg: smps3 {
/* VDD_CORE */
regulator-name = "smps3";
regulator-boot-on;
smps4_reg: smps4 {
/* VDD_IVA */
regulator-name = "smps4";
regulator-boot-on;
smps5_reg: smps5 {
/* VDDS1V8 */
regulator-name = "smps5";
regulator-boot-on;
ldo1_reg: ldo1 {
/* LDO1_OUT --> VDA_PHY1_1V8 */
regulator-name = "ldo1";
regulator-boot-on;
regulator-allow-bypass;
ldo2_reg: ldo2 {
/* LDO2_OUT --> VDA_PHY2_1V8 */
regulator-name = "ldo2";
ldo3_reg: ldo3 {
/* VDA_USB_3V3 */
regulator-name = "ldo3";
regulator-boot-on;
ldo5_reg: ldo5 {
/* VDDA_1V8_PLL */
regulator-name = "ldo5";
regulator-boot-on;
ldo4_reg: ldo4 {
/* VDD_SDIO_DV */
regulator-name = "ldo4";
regulator-boot-on;
tps65917_power_button {
compatible = "ti,palmas-pwrbutton";
interrupt-parent = <&tps65917>;
interrupts = <1 IRQ_TYPE_NONE>;
wakeup-source;
ti,palmas-long-press-seconds = <6>;
lp87565: lp87565@60 {
compatible = "ti,lp87565-q1";
reg = <0x60>;
buck10-in-supply =<&vsys_3v3>;
buck23-in-supply =<&vsys_3v3>;
buck10_reg: buck10 {
/*VDD_MPU*/
regulator-name = "buck10";
regulator-boot-on;
buck23_reg: buck23 {
/* VDD_GPU*/
regulator-name = "buck23";
regulator-boot-on;
pcf_lcd: pcf8757@20 {
compatible = "ti,pcf8575", "nxp,pcf8575";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&gpio1>;
interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
status = "disabled";
pcf_gpio_21: pcf8757@21 {
reg = <0x21>;
gpio-controller;
#gpio-cells = <2>;
pcf_hdmi: pcf8575@26 {
reg = <0x26>;
gpio-controller;
#gpio-cells = <2>;
p1 {
/* vin6_sel_s0: high: VIN6, low: audio */
gpio-hog;
gpios = <1 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "vin6_sel_s0";
tlv320aic3106: tlv320aic3106@19 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x19>;
adc-settle-ms = <40>;
ai3x-micbias-vg = <1>; /* 2.0V */
status = "okay";
/* Regulators */
AVDD-supply = <&vio_3v3>;
IOVDD-supply = <&vio_3v3>;
DRVDD-supply = <&vio_3v3>;
DVDD-supply = <&aic_dvdd>;
/****************************EEPROM*********************************/
eeprom: eeprom@50 {
compatible = "atmel,24c256";
reg = <0x50>;
/**********************Temp Sensor TMP102A*************************/
tmp102: tmp102@48 {
compatible = "ti,tmp102";
reg = <0x48>;
/* interrupt-parent = <&gpio2>;
interrupts = <16 IRQ_TYPE_LEVEL_LOW>;*/
#thermal-sensor-cells = <1>;
/******************************TDA1988 Display Interface******************************************/
&i2c3 {
disp_ser: serializer@0c {
compatible = "ti,ds90ub921q";
reg = <0x0c>;
#size-cells = <0>;
tda19988: tda19988 {
compatible = "nxp,tda998x";
reg = <0x70>;
/*pinctrl-names = "default", "off";
pinctrl-0 = <&nxp_hdmi_bonelt_pins>;
pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>;*/
/* Convert 24bit BGR to RGB, e.g. cross red and blue wiring */
video-ports = <0x230145>;
/*audio-ports = < TDA998x_I2S 0x03>; */
ports {
port@0 {
hdmi_0: endpoint@0 {
remote-endpoint = <&lcd_in>;
lanes = <0 1 2 3 4 5 6 7 8 9>;
/******************************RTC PCA85063 & ADC ADS1015******************************************/
&i2c4 {
status = "okay";
pcf85063: rtc@51 {
status = "okay";
compatible = "nxp,pcf85063";
reg = <0x51>;
#clock-cells = <0>;
/*quartz-load-femtofarads = <12500>;*/
ads1015@49 {
compatible = "ti,ads1015";
reg = <0x48>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ti,gain = <3>;
ti,datarate = <5>;
channel@1 {
reg = <1>;
ti,gain = <3>;
ti,datarate = <5>;
channel@2 {
reg = <2>;
ti,gain = <3>;
ti,datarate = <5>;
channel@3 {
reg = <3>;
ti,gain = <3>;
ti,datarate = <5>;
channel@4 {
reg = <4>;
ti,gain = <2>;
ti,datarate = <5>;
channel@5 {
reg = <5>;
ti,gain = <2>;
ti,datarate = <5>;
channel@6 {
reg = <6>;
ti,gain = <3>;
ti,datarate = <5>;
channel@7 {
reg = <7>;
ti,gain = <3>;
ti,datarate = <5>;
&i2c5 {
status = "okay";
ov10633@37 {
compatible = "ovti,ov10633";
reg = <0x37>;
clocks = <&clk_ov10633_fixed>;
clock-names = "xvclk";
mux-gpios = <&pcf_hdmi 2 GPIO_ACTIVE_HIGH>, /* VIN2_S0 */
<&pcf_hdmi 6 GPIO_ACTIVE_LOW>; /* VIN2_S2 */
port {
onboardLI: endpoint {
remote-endpoint = <&vin2a>;
hsync-active = <1>;
vsync-active = <1>;
pclk-sample = <0>;
gpio_csi2_adap: tca6416@20 {
status = "okay";
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
ov490@24 {
compatible = "ovti,ov490";
reg = <0x24>;
mux-gpios = <&gpio_csi2_adap 0 GPIO_ACTIVE_LOW>,
/* CSI2_SEL_I2C_CLK */
<&gpio_csi2_adap 1 GPIO_ACTIVE_HIGH>,
/* CSI2_SEL_REF_CLK */
<&gpio_csi2_adap 3 GPIO_ACTIVE_HIGH>,
/* CSI2_CAM0_RESETn */
<&gpio_csi2_adap 4 GPIO_ACTIVE_LOW>;
/* CSI2_CAM0_PWR_DWN */
port {
csi2_cam0: endpoint@0 {
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
remote-endpoint = <&csi2_phy0>;
&cpu0 {
vdd-supply = <&buck10_reg>;
&mmc1 {
status = "okay";
vmmc-supply = <&vio_3v3_sd>;
vmmc_aux-supply = <&ldo4_reg>;
bus-width = <4>;
* SDCD signal is not being used here - using the fact that GPIO mode
* is always hardwired.
cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>;
max-frequency = <192000000>;
pinctrl-names = "default", "hs";
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_hs>;
&mmc2 {
status = "okay";
vmmc-supply = <&vio_1v8>;
bus-width = <8>;
pinctrl-names = "default", "hs", "ddr_1_8v", "hs200_1_8v";
pinctrl-0 = <&mmc2_pins_default>;
/***********************Added for mmc3*******************************************************************/
&dra7_pmx_core {
mmc3_pins_default: mmc3_pins_default {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE0))
&mmc3{
status = "okay";
vmmc-supply = <&vio_3v3>;
/*vqmmc-supply = <&vio_1v8>;*/
vmmc_aux-supply = <&wlan_regulator>;
bus-width = <4>;
ti,non-removable;
max-frequency = <50000000>;
/*cap-sdio-irq;*/
cap-power-off-card;
keep-power-in-suspend;
/*enable-sdio-wakeup;*/
/*pinctrl-names = "default";
pinctrl-0 = <&mmc3_pins_default &mmc3_iodelay_manual1_conf>;
pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50";
pinctrl-1 = <&mmc3_pins_hs &mmc3_iodelay_manual1_conf>;
pinctrl-2 = <&mmc3_pins_sdr12 &mmc3_iodelay_manual1_conf>;
pinctrl-3 = <&mmc3_pins_sdr25 &mmc3_iodelay_manual1_conf>;
pinctrl-4 = <&mmc3_pins_sdr50 &mmc3_iodelay_manual1_conf>;*/
&mmc4 {
status = "okay";
vmmc-supply = <&vio_3v6>;
vqmmc-supply = <&vmmcwl_fixed>;
pinctrl-names = "default", "hs", "sdr12", "sdr25";
pinctrl-0 = <&mmc4_pins_hs &mmc4_iodelay_default_conf>;
pinctrl-1 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
pinctrl-2 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
pinctrl-3 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
/* No RTC on this device */
&rtc {
&mac {
status = "okay";
/*slaves = <1>;*/
dual_emac;
/*&cpsw_emac0 {
phy_id = <&davinci_mdio>, <2>;
phy-mode = "rgmii-id";
status="disabled";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
phy_id = <&davinci_mdio>, <3>;
status="okay";
dual_emac_res_vlan = <2>;
&davinci_mdio {
dp83867_0: ethernet-phy@2 {
reg = <2>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>;
ti,tx-internal-delay = <DP83867_RGMIIDCTL_250_PS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>;
ti,min-output-impedance;
ti,dp83867-rxctrl-strap-quirk;
dp83867_1: ethernet-phy@3 {
reg = <3>;
status = "okay";
&usb2_phy1 {
phy-supply = <&ldo3_reg>;
&usb2_phy2 {
&dss {
status = "ok";
vdda_video-supply = <&ldo5_reg>;
&hdmi {
status = "ok";
vdda-supply = <&ldo1_reg>;
port {
hdmi_out: endpoint {
remote-endpoint = <&tpd12s015_in>;
&qspi {
spi-max-frequency = <96000000>;
m25p80@0 {
&m_can0 {
status = "okay";
can-transceiver {
max-bitrate = <5000000>;
&cal {
status = "okay";
&csi2_0 {
csi2_phy0: endpoint@0 {
slave-mode;
remote-endpoint = <&csi2_cam0>;
&vin2a {
status = "okay";
endpoint@0 {
slave-mode;
remote-endpoint = <&onboardLI>;
&ipu2 {
status = "okay";
memory-region = <&ipu2_cma_pool>;
&ipu1 {
status = "okay";
memory-region = <&ipu1_cma_pool>;
&dsp1 {
status = "okay";
memory-region = <&dsp1_cma_pool>;
&dsp2 {
status = "okay";
memory-region = <&dsp2_cma_pool>;
&pcie2_phy {
status = "okay";
&pcie1_rc {
num-lanes = <2>;
phys = <&pcie1_phy>, <&pcie2_phy>;
phy-names = "pcie-phy0", "pcie-phy1";
&pcie1_ep {
num-lanes = <2>;
/************************USB 3 & 4 ULPI Interface*****************************************/
&omap_dwc3_3 {
status = "okay";
snps,dis_u3_susphy_quirk;
snps,dis_u2_susphy_quirk;
&usb3 {
dr_mode = "host";
snps,hsphy_interface = "ulpi";
status = "okay";
cs-gpios = <&gpio5 16 GPIO_ACTIVE_HIGH>;
tx-fifo-resize;
phy {
compatible = "ti,tusb1210";
&omap_dwc3_4 {
status = "okay";
&usb4 {
dr_mode = "host";
status = "okay";
cs-gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>;
tx-fifo-resize;
phy {
&extcon_usb1 {
compatible = "linux,extcon-usb-gpio";
vbus-gpio = <&gpio6 12 GPIO_ACTIVE_HIGH>;
id-gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>;
/*&extcon_usb2 {
vbus-gpio = <&pcf_lcd 15 GPIO_ACTIVE_HIGH>;
We needed some guidance in device tree for bringing up the hdmi interface from lcd1 port.
Padmesh
