Part Number: DRA745
The project develops H264 decoding based on test_qnx. How to compile test_qnx?
Part Number: DRA745
ti-glsdk_dra7xx-evm_7_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-linux-gnueabi/libdce/3.00.10.00-r0/git/test_qnx/dce_test
Hi guangyu li,
If you are using linux SDK, please use viddec3test sample application to decode the H264/mpeg2/mpeg4 streams.
dce_test is the sample application for QNX application.
You can get viddec3test here
ti-glsdk_dra7xx-evm_7_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/cortexa15t2hf-vfp-neon-3.14-linux-gnueabi/omapdrmtest/1.0.0-r10/git
RamPrasad
Hi RamPrasad
VIDDEC3_process how to save the data to the file, is there any related documentation and demo
Hi guangyu li,
viddec3test always posts the decoded data to display. If you want to save decoded data, you need to modify viddec3test to write to a file similar to dce_test
or
you can directly try gstreamer pipeline to decode and write to a file.
RamPrasad
