CCS/DRA745: test load ddr test out, run error
Part Number: DRA745
Hi,expert,
I want to run DDR test software on J6 EVM. CCS show an error as below:
Cortex_M4_IPU1_C0: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence In Progress... <<<---
Cortex_M4_IPU1_C0: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence DONE! <<<---
Cortex_M4_IPU1_C1: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence In Progress... <<<---
Cortex_M4_IPU1_C1: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence DONE! <<<---
Cortex_M4_IPU2_C0: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence In Progress... <<<---
Cortex_M4_IPU2_C0: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence DONE! <<<---
Cortex_M4_IPU2_C1: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence In Progress... <<<---
Cortex_M4_IPU2_C1: GEL Output: --->>> DRA7xx Cortex M4 Startup Sequence DONE! <<<---
C66xx_DSP1: GEL Output: --->>> DRA7xx C66x DSP Startup Sequence In Progress... <<<---
C66xx_DSP1: GEL Output: --->>> DRA7xx C66x DSP Startup Sequence DONE! <<<---
C66xx_DSP2: GEL Output: --->>> DRA7xx C66x DSP Startup Sequence In Progress... <<<---
C66xx_DSP2: GEL Output: --->>> DRA7xx C66x DSP Startup Sequence DONE! <<<---
CortexA15_0: GEL Output: --->>> DRA7xx Cortex A15 Startup Sequence In Progress... <<<---
CortexA15_0: GEL Output: --->>> DRA7xx Cortex A15 Startup Sequence DONE! <<<---
CortexA15_1: GEL Output: --->>> DRA7xx Cortex A15 Startup Sequence In Progress... <<<---
CortexA15_1: GEL Output: --->>> DRA7xx Cortex A15 Startup Sequence DONE! <<<---
ARP32_EVE_1: GEL Output: --->>> Configuring EVE Memory Map <<<---
ARP32_EVE_1: GEL Output: --->>> EVE Memory Map Done! <<<---
ARP32_EVE_2: GEL Output: --->>> Configuring EVE Memory Map <<<---
ARP32_EVE_2: GEL Output: --->>> EVE Memory Map Done! <<<---
ARP32_EVE_3: GEL Output: --->>> Configuring EVE Memory Map <<<---
ARP32_EVE_3: GEL Output: --->>> EVE Memory Map Done! <<<---
ARP32_EVE_4: GEL Output: --->>> Configuring EVE Memory Map <<<---
ARP32_EVE_4: GEL Output: --->>> EVE Memory Map Done! <<<---
IcePick_D: GEL Output: Ipu RTOS is released from Wait-In-Reset.
IcePick_D: GEL Output: Ipu SIMCOP is released from Wait-In-Reset.
IcePick_D: GEL Output: IVAHD C66 is released from Wait-In-Reset.
IcePick_D: GEL Output: IVAHD ICONT1 is released from Wait-In-Reset.
IcePick_D: GEL Output: IVAHD ICONT2 is released from Wait-In-Reset.
CS_DAP_DebugSS: GEL Output: --->>> CONFIGURE DEBUG DPLL settings to 1.9 GHZs  <<<---
CS_DAP_DebugSS: GEL Output: > Setup DebugSS 1.9GHz in progress...
CS_DAP_DebugSS: GEL Output: < Done with Setup DebugSS Trace export clock (TPIU) to 97MHz
CS_DAP_DebugSS: GEL Output: < Done with Setup DebugSS PLL Clocking 1.9GHz
CS_DAP_DebugSS: GEL Output: < Done with Setup DebugSS ATB Clocking 380MHz
CS_DAP_DebugSS: GEL Output: --->>> TURNING ON L3_INSTR and L3_3 clocks required for debug instrumention <<<<<<----
CS_DAP_DebugSS: GEL Output: ---<<< L3 instrumentation clocks are enabled >>>> ---
CS_DAP_DebugSS: GEL Output: --->>> Mapping TIMER supsend sources to default cores <<<<<<----
CortexA15_0: GEL Output: --->>> IPU1SS Initialization is in progress ... <<<---
CS_DAP_PC: GEL Output: Cortex-A15 1 is not in WIR mode so nothing to do.
DRA7xx_MULTICORE_EnableAllCores() cannot be evaluated.
Could not write 0x4AE06510: target is not connected
	 at *((unsigned int *) ((cpu_num==1) ? (((0x4AE00000+0x6000)+0x500)+0x10) : (((0x4AE00000+0x6000)+0x700)+0x210)))=(unsigned int) 0x7 [DRA7xx_multicore_reset.gel:12]
	 at IPUSSClkEnable(1) [DRA7xx_multicore_reset.gel:324]
	 at IPU1SSClkEnable_API() [DRA7xx_multicore_reset.gel:292]
	 at DRA7xx_MULTICORE_EnableAllCores()CortexA15_0: GEL Output: --->>> DRA7xx Target Connect Sequence Begins ... <<<---
CortexA15_0: GEL Output: Core Reset has occurred.
CortexA15_0: GEL Output: 	--->>> DRA7xx PG2.0 GP device <<<---
CortexA15_0: GEL Output: 	--->>> The core is in non-SECURE state. <<<---
CortexA15_0: GEL Output: --->>> PRCM Clock Configuration for OPPNOM in progress... <<<---
CortexA15_0: GEL Output: 	Cortex A15 DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	Cortex A15 DPLL is already locked, now unlocking...
CortexA15_0: GEL Output: 	Cortex A15 DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	IVA DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	IVA DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	PER DPLL OPP 0 clock config in progress...
CortexA15_0: GEL Output: 	PER DPLL already locked, now unlocking
CortexA15_0: GEL Output: 	PER DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	CORE DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	CORE DPLL OPP  already locked, now unlocking....
CortexA15_0: GEL Output: 	CORE DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	ABE DPLL OPP 0 clock config in progress...
CortexA15_0: GEL Output: 	ABE DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	GMAC DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	GMAC DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	GPU DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	GPU DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	DSP DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	DSP DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	EVE DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	EVE DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: 	PCIE_REF DPLL OPP 0 clock config is in progress...
CortexA15_0: GEL Output: 	PCIE_REF DPLL OPP 0 is DONE!
CortexA15_0: GEL Output: --->>> PRCM Clock Configuration for OPP 0 is DONE! <<<---
CortexA15_0: GEL Output: --->>> PRCM Configuration for all modules in progress... <<<---
CortexA15_0: GEL Output: --->>> PRCM Configuration for all modules is DONE! <<<---
CortexA15_0: GEL Output: --->>> DDR3 Initialization is in progress ... <<<---
CortexA15_0: GEL Output: 	DDR DPLL clock config for 532MHz is in progress...
CortexA15_0: GEL Output: 	DDR DPLL clock config for 532MHz is in DONE!
CortexA15_0: GEL Output:        Launch full leveling
CortexA15_0: GEL Output:        Updating slave ratios in PHY_STATUSx registers
CortexA15_0: GEL Output:        as per HW leveling output
CortexA15_0: GEL Output:        HW leveling is now disabled. Using slave ratios from
CortexA15_0: GEL Output:        PHY_STATUSx registers
CortexA15_0: GEL Output:        Two EMIFs in interleaved mode - (1GB total)
CortexA15_0: GEL Output: --->>> DDR3 Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> DRA7xx Begin All Pad Configuration for Vision Platform <<<---
CortexA15_0: GEL Output: --->>> DRA7xx Begin All Pad Configuration for RGMII usage on EVM Platform <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx Begin GMAC_SW MDIO Pad Configuration <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx End GMAC_SW MDIO Pad Configuration <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx Begin GMAC_SW RGMII0 Pad Configuration <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx End GMAC_SW RGMII0 Pad Configuration <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx Begin GMAC_SW RGMII1 Pad Configuration <<<---
CortexA15_0: GEL Output: 	--->>> DRA7xx End GMAC_SW RGMII1 Pad Configuration <<<---
CortexA15_0: GEL Output: --->>> DRA7xx End All Pad Configuration for RGMII usage on EVM Platform <<<---
CortexA15_0: GEL Output: --->>> DRA7xx End All Pad Configuration for Vision Platform <<<---
CortexA15_0: GEL Output: --->>> DRA7xx Target Connect Sequence DONE !!!!!  <<<---
CortexA15_0: GEL Output: --->>> IPU1SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> IPU2SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: --->>> IPU2SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> DSP1SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: DEBUG: Clock is active ...
CortexA15_0: GEL Output: DEBUG: Checking for data integrity in DSPSS L2RAM ...
CortexA15_0: GEL Output: DEBUG: Data integrity check in GEM L2RAM is sucessful!
CortexA15_0: GEL Output: --->>> DSP1SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> DSP2SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: --->>> DSP2SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> EVE1SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: DEBUG: Resetting EVE MMU ...
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 1: 0x00000000 --> 0x40500000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 2: 0x80000000 --> 0x80000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 3: 0x81000000 --> 0x81000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 4: 0x82000000 --> 0x82000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 5: 0x83000000 --> 0x83000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 6: 0x84000000 --> 0x84000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 7: 0x85000000 --> 0x85000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 8: 0x86000000 --> 0x86000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 9: 0x87000000 --> 0x87000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 10: 0x40000000 --> 0x40000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 11: 0x4A000000 --> 0x4A000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 12: 0x45000000 --> 0x45000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 13: 0x48000000 --> 0x48000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE1 MMU0 TLB entry 14: 0x42000000 --> 0x42000000
CortexA15_0: GEL Output: --->>> EVE1SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> EVE2SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 1: 0x00000000 --> 0x40500000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 2: 0x80000000 --> 0x80000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 3: 0x81000000 --> 0x81000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 4: 0x82000000 --> 0x82000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 5: 0x83000000 --> 0x83000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 6: 0x84000000 --> 0x84000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 7: 0x85000000 --> 0x85000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 8: 0x86000000 --> 0x86000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 9: 0x87000000 --> 0x87000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 10: 0x40000000 --> 0x40000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 11: 0x4A000000 --> 0x4A000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 12: 0x45000000 --> 0x45000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 13: 0x48000000 --> 0x48000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE2 MMU0 TLB entry 14: 0x42000000 --> 0x42000000
CortexA15_0: GEL Output: --->>> EVE2SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> EVE3SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 1: 0x00000000 --> 0x40500000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 2: 0x80000000 --> 0x80000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 3: 0x81000000 --> 0x81000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 4: 0x82000000 --> 0x82000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 5: 0x83000000 --> 0x83000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 6: 0x84000000 --> 0x84000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 7: 0x85000000 --> 0x85000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 8: 0x86000000 --> 0x86000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 9: 0x87000000 --> 0x87000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 10: 0x40000000 --> 0x40000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 11: 0x4A000000 --> 0x4A000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 12: 0x45000000 --> 0x45000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 13: 0x48000000 --> 0x48000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE3 MMU0 TLB entry 14: 0x42000000 --> 0x42000000
CortexA15_0: GEL Output: --->>> EVE3SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> EVE4SS Initialization is in progress ... <<<---
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 1: 0x00000000 --> 0x40500000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 2: 0x80000000 --> 0x80000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 3: 0x81000000 --> 0x81000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 4: 0x82000000 --> 0x82000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 5: 0x83000000 --> 0x83000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 6: 0x84000000 --> 0x84000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 7: 0x85000000 --> 0x85000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 8: 0x86000000 --> 0x86000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 9: 0x87000000 --> 0x87000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 10: 0x40000000 --> 0x40000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 11: 0x4A000000 --> 0x4A000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 12: 0x45000000 --> 0x45000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 13: 0x48000000 --> 0x48000000
CortexA15_0: GEL Output: DEBUG: Configuring EVE4 MMU0 TLB entry 14: 0x42000000 --> 0x42000000
CortexA15_0: GEL Output: --->>> EVE4SS Initialization is DONE! <<<---
CortexA15_0: GEL Output: --->>> IVAHD Initialization is in progress ... <<<---
CortexA15_0: GEL Output: --->>> IVAHD Initialization is DONE! ... <<<---
CortexA15_0: GEL Output: --->>> PRUSS 1 and 2 Initialization is in progress ... <<<---
CortexA15_0: GEL Output: --->>> PRUSS 1 and 2 Initialization is in complete ... <<<---
Cortex_M4_IPU1_C0: Can't Run Target CPU: (Error -1268 @ 0x1090001) Device is locked up in Hard Fault or in NMI. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 8.2.0.00004)
Could you help to check ?
Br, Widic
