Other Parts Discussed in Thread: TRF7970A, AM3352, TPS65910
Dear TI Team,
On our custom board, we re checking our ethernet port configurations to find out what is causing a fail while getting an IP from a DHCP automatically. Currently we re giving an IP manuelly but this time we cannot ping any device in the same network. Below you can find the boot up logs. Can you pls. help to check them?
Log Snippet:
root@am335x-evmsk:~# reboot
Stopping Session c1 of user root.
Stopping NFS status monitor for NFSv2/3 locking....
Stopping User Manager for UID 0...
[ OK ] Stopped target Multi-User System.
Stopping Job spooling tools...
Stopping neard...
Stopping strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf...
Stopping System Logging Service...
Stopping uid-reader...
Stopping Periodic Command Scheduler...
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily rotation of log files.
Stopping thermal-zone-init.service...
Stopping Kernel Logging Service...
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping parse-ip.service...
Stopping raichu-start...
Stopping Hardware RNG Entropy Gatherer Daemon...
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped target System Time Synchronized.
Stopping mid-meter...
[ OK ] Stopped target Containers.
[ OK ] Stopped target Login Prompts.
Stopping Serial Getty on ttyS0...
Stopping Lightning Fast Webserver With Light System Requirements...
Stopping Getty on tty1...
Stopping D-Bus System Message Bus...
[ OK ] Stopped Job spooling tools.
[ OK ] Stopped Kernel Logging Service.
[ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
[ OK ] Stopped uid-reader.
[ OK ] Stopped strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped neard.
[ OK ] Stopped Periodic Command Scheduler.
[ OK ] Stopped Lightning Fast Webserver With Light System Requirements.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped NFS status monitor for NFSv2/3 locking..
[ OK ] Stopped mid-meter.
[ OK ] Stopped raichu-start.
[ OK ] Stopped thermal-zone-init.service.
[ OK ] Stopped parse-ip.service.
[ OK ] Stopped Session c1 of user root.
Stopping rng-tools.service...
Stopping HMI agent...
Stopping RPC Bind Service...
[ OK ] Stopped target Host and Network Name Lookups.
Stopping Network Name Resolution...
[ OK ] Removed slice User Slice of root.
Stopping Login Service...
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Removed slice system-getty.slice.
Stopping Permit User Sessions...
[ OK ] Stopped Login Service.
[ OK ] Stopped RPC Bind Service.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped HMI agent.
[ OK ] Stopped rng-tools.service.
[ OK ] Stopped Permit User Sessions.
Stopping thttpd.service...
Stopping busybox-udhcpd.service...
Stopping ui...
[ OK ] Stopped target Network.
Stopping Network Service...
[ OK ] Stopped thttpd.service.
[ OK ] Stopped ui.
[ OK ] Stopped Network Service.
[ OK ] Stopped busybox-udhcpd.service.
Stopping telnetd.service...
[ OK ] Stopped telnetd.service.
Stopping weston.service...
[ OK ] Stopped weston.service.
Stopping rc.pvr.service...
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped rc.pvr.service.
Stopping uim-sysfs.service...
[ OK ] Stopped uim-sysfs.service.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Sockets.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Closed Syslog Socket.
[ OK ] Closed dropbear.socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
Stopping Load/Save Random Seed...
Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Stopped Update is Completed.
[ OK ] Stopped Rebuild Hardware Database.
[ OK ] Stopped Rebuild Dynamic Linker Cache.
[ OK ] Stopped Rebuild Journal Catalog.
Stopping Network Time Synchronization...
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Removed slice system-systemd\x2dbacklight.slice.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting Temporary Directory (/tmp)...
Unmounting /run/user/0...
Unmounting /var/volatile...
Unmounting /run/media/mmcblk1p1...
Unmounting /media/ram...
[ OK ] Unmounted Temporary Directory (/tmp).
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /var/volatile.
[ OK ] Unmounted /run/media/mmcblk1p1.
[ OK ] Unmounted /media/ram.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped Create System Users.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Swap.
[ OK ] Reached target Shutdown.
[ 605.780258] watchdog: watchdog0: watchdog did not stop!
[ 605.792321] systemd-shutdow: 29 output lines suppressed due to ratelimiting
[ 605.839911] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 605.861132] systemd-journald[66]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 605.898661] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 605.925413] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 605.937609] systemd-shutdown[1]: Unmounting file systems.
[ 605.944177] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 605.983864] EXT4-fs (mmcblk1p2): re-mounted. Opts: data=ordered
[ 606.004712] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 606.014456] EXT4-fs (mmcblk1p2): re-mounted. Opts: data=ordered
[ 606.020592] systemd-shutdown[1]: All filesystems unmounted.
[ 606.026440] systemd-shutdown[1]: Deactivating swaps.
[ 606.031767] systemd-shutdown[1]: All swaps deactivated.
[ 606.037282] systemd-shutdown[1]: Detaching loop devices.
[ 606.077008] reboot: Restarting system
U-Boot SPL 2018.01-gcdb1cc0a9e (Jul 25 2019 - 13:34:26)
Trying to boot from MMC2
** Bad device mmc 0 **
Using default environment
U-Boot 2018.01-gcdb1cc0a9e (Jul 25 2019 - 13:34:26 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM-SK
DRAM: 256 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
<ethaddr> not set. Validating first E-fuse MAC
Net: cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
SD/MMC found on device 1
3981824 bytes read in 356 ms (10.7 MiB/s)
38289 bytes read in 15 ms (2.4 MiB/s)
Loading Device Tree to 8df02000, end 8df0e590 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.67-gd315a9bb00 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Thu Jul 18 07:43:10 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x8a800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=9062c132-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 197268K/262144K available (8192K kernel code, 320K rwdata, 2608K rodata, 1024K init, 278K bss, 15724K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB)
[ 0.000000] .data : 0xc0d00000 - 0xc0d50128 ( 321 kB)
[ 0.000000] .bss : 0xc0d50128 - 0xc0d959c4 ( 279 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000047] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000062] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000285] timer_probe: no matching timers found
[ 0.000545] Console: colour dummy device 80x30
[ 0.000582] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000592] This ensures that you still see kernel messages. Please
[ 0.000601] update your kernel commandline.
[ 0.000639] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.118791] pid_max: default: 32768 minimum: 301
[ 0.119041] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.119061] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.120049] CPU: Testing write buffer coherency: ok
[ 0.120964] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.121169] Hierarchical SRCU implementation.
[ 0.121628] EFI services will not be available.
[ 0.123459] devtmpfs: initialized
[ 0.134519] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[ 0.135109] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.135486] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.135525] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.140273] pinctrl core: initialized pinctrl subsystem
[ 0.141182] DMI not present or invalid.
[ 0.141686] NET: Registered protocol family 16
[ 0.144589] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.162850] omap_hwmod: debugss: _wait_target_disable failed
[ 0.217540] cpuidle: using governor ladder
[ 0.217591] cpuidle: using governor menu
[ 0.223461] OMAP GPIO hardware version 0.1
[ 0.238370] No ATAGs?
[ 0.238393] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.256172] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.257644] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe
[ 0.261896] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.262095] media: Linux media interface: v0.10
[ 0.262158] Linux video capture interface: v2.00
[ 0.262288] pps_core: LinuxPPS API ver. 1 registered
[ 0.262301] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.262330] PTP clock support registered
[ 0.262376] EDAC MC: Ver: 3.0.0
[ 0.262958] dmi: Firmware registration failed.
[ 0.263505] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.263964] Advanced Linux Sound Architecture Driver Initialized.
[ 0.265676] nfc: nfc_init: NFC Core ver 0.1
[ 0.265799] NET: Registered protocol family 39
[ 0.266263] clocksource: Switched to clocksource timer1
[ 0.277408] NET: Registered protocol family 2
[ 0.278371] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.278421] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.278459] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.278585] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.278612] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.278810] NET: Registered protocol family 1
[ 0.279357] RPC: Registered named UNIX socket transport module.
[ 0.279375] RPC: Registered udp transport module.
[ 0.279385] RPC: Registered tcp transport module.
[ 0.279394] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.280540] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.280691] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.282604] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.288648] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.289613] NFS: Registering the id_resolver key type
[ 0.289674] Key type id_resolver registered
[ 0.289685] Key type id_legacy registered
[ 0.289745] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.292364] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.292392] io scheduler noop registered
[ 0.292403] io scheduler deadline registered
[ 0.292687] io scheduler cfq registered (default)
[ 0.292701] io scheduler mq-deadline registered
[ 0.292713] io scheduler kyber registered
[ 0.294678] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.363302] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.367431] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.005869] console [ttyS0] enabled
[ 1.010690] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.021287] omap_uart 48024000.serial: no wakeirq for uart2
[ 1.027336] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a OMAP UART2
[ 1.037319] omap_uart 481a6000.serial: no wakeirq for uart3
[ 1.043129] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a OMAP UART3
[ 1.054014] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 1.062766] panel panel: found backlight
[ 1.067226] OF: graph: no port node found in /ocp/lcdc@4830e000
[ 1.073442] OF: graph: no port node found in /ocp/lcdc@4830e000
[ 1.080043] OF: graph: no port node found in /ocp/lcdc@4830e000
[ 1.086003] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.092700] [drm] No driver support for vblank timestamp query.
[ 1.144312] Console: switching to colour frame buffer device 60x34
[ 1.167185] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.173477] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 1.195717] brd: module loaded
[ 1.207583] loop: module loaded
[ 1.215823] trf7970a spi1.0: spi1.0 supply vdd-io not found, using dummy regulator
[ 1.252377] libphy: Fixed MDIO Bus: probed
[ 1.258234] qcaspi spi0.0: ver=0.2.7-i, clkspeed=10000000, burst_len=5000, pluggable=0
[ 1.266324] qcaspi spi0.0: Using random MAC address: fa:3b:d5:77:e2:2a
[ 1.273027] qcaspi spi0.0: Invalid signature (0xFFFF)
[ 1.278203] qcaspi: probe of spi0.0 failed with error -14
[ 1.356301] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.364028] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[ 1.372721] libphy: 4a101000.mdio: probed
[ 1.376928] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ8041RNLI
[ 1.385937] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Micrel KSZ8041RNLI
[ 1.396161] cpsw 4a100000.ethernet: Detected MACID = 18:62:e4:e2:5c:b9
[ 1.403109] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 1.409604] cpsw 4a100000.ethernet: ALE Table size 1024
[ 1.414912] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[ 1.423990] i2c /dev entries driver
[ 1.428222] IR NEC protocol handler initialized
[ 1.432783] IR RC5(x/sz) protocol handler initialized
[ 1.437907] IR RC6 protocol handler initialized
[ 1.442479] IR JVC protocol handler initialized
[ 1.447050] IR Sony protocol handler initialized
[ 1.451687] IR SANYO protocol handler initialized
[ 1.456428] IR Sharp protocol handler initialized
[ 1.461162] IR MCE Keyboard/mouse protocol handler initialized
[ 1.467038] IR XMP protocol handler initialized
[ 1.473660] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.481180] sdhci: Secure Digital Host Controller Interface driver
[ 1.487460] sdhci: Copyright(c) Pierre Ossman
[ 1.494555] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.501374] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.511814] NET: Registered protocol family 10
[ 1.518204] Segment Routing with IPv6
[ 1.521991] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.529025] NET: Registered protocol family 17
[ 1.533840] Key type dns_resolver registered
[ 1.538563] omap_voltage_late_init: Voltage driver support not added
[ 1.576556] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.584752] vrtc: supplied by vbat
[ 1.592131] vio: supplied by vbat
[ 1.597156] vdd1: supplied by vbat
[ 1.602192] random: fast init done
[ 1.605983] vdd2: supplied by vbat
[ 1.612937] vdig1: supplied by vbat
[ 1.618017] vdig2: supplied by vbat
[ 1.623035] vpll: supplied by vbat
[ 1.628054] vdac: supplied by vbat
[ 1.632984] vaux1: supplied by vbat
[ 1.638054] vaux2: supplied by vbat
[ 1.643083] vaux33: supplied by vbat
[ 1.648227] vmmc: supplied by vbat
[ 1.653158] vbb: supplied by vbat
[ 1.658304] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.787751] hctosys: unable to open rtc device (rtc0)
[ 1.793875] lis3_reg: disabling
[ 1.800863] vwl1271: disabling
[ 1.804231] ALSA device list:
[ 1.807429] No soundcards found.
[ 1.811952] Waiting for root device PARTUUID=9062c132-02...
[ 1.861282] mmc1: new high speed MMC card at address 0001
[ 1.867513] mmcblk1: mmc1:0001 4FTE4R 3.64 GiB
[ 1.872321] mmcblk1boot0: mmc1:0001 4FTE4R partition 1 4.00 MiB
[ 1.878611] mmcblk1boot1: mmc1:0001 4FTE4R partition 2 4.00 MiB
[ 1.884775] mmcblk1rpmb: mmc1:0001 4FTE4R partition 3 512 KiB
[ 1.892042] mmcblk1: p1 p2
[ 1.916816] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.925076] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.933003] devtmpfs: mounted
[ 1.938161] Freeing unused kernel memory: 1024K
[ 2.148294] systemd[1]: System time before build time, advancing clock.
[ 2.205876] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
[ 2.228064] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.08!
[ 2.257471] systemd[1]: Set hostname to <am335x-evmsk>.
[ 2.594517] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service'
[ 2.626355] NOHZ: local_softirq_pending 40
[ 2.700458] systemd[1]: Configuration file /etc/systemd/system/uid-reader.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.717251] systemd[1]: Configuration file /etc/systemd/system/ui.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.787681] systemd[1]: Configuration file /etc/systemd/system/neard.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.804222] systemd[1]: Configuration file /etc/systemd/system/neard-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.821426] systemd[1]: Configuration file /etc/systemd/system/mid-meter.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.840689] systemd[1]: Configuration file /etc/systemd/system/locus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 2.963328] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Listening on Network Service Netlink Socket.
[ 3.042906] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Created slice System Slice.
[ 3.077491] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Created slice system-serial\x2dgetty.slice.
Mounting Kernel Debug File System...
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
Mounting POSIX Message Queue File System...
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Swap.
Mounting Temporary Directory (/tmp)...
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Syslog Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket.
Starting Journal Service...
Starting Load Kernel Modules...
Starting Remount Root and Kernel File Systems...
[ OK ] Reached target Remote File Systems.
[ 3.730825] cryptodev: loading out-of-tree module taints kernel.
[ OK ] Listening on udev Control Socket.
[ 3.807050] cryptodev: driver 1.9 loaded.
[ 3.819998] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Journal Service.
Starting Rebuild Hardware Database...
Starting Flush Journal to Persistent Storage...
Starting Create System Users...
Starting Apply Kernel Variables...
Mounting Kernel Configuration File System...
[ OK ] Started Create System Users.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ 4.417359] systemd-journald[68]: Received request to flush runtime journal from PID 1
Starting Create Static Device Nodes in /dev...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Mounting /media/ram...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Journal Catalog...
Starting Create Volatile Files and Directories...
Starting Rebuild Dynamic Linker Cache...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting udev Coldplug all Devices...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[ 9.821354] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ OK ] Found device /dev/ttyS0.
[ 10.008708] omap_rtc 44e3e000.rtc: already running
[ OK ] Started udev Coldplug all Devices.
[ 10.046882] omap_rtc 44e3e000.rtc: registered as rtc0
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Reached target System Initialization.
Starting Network Service...
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started System Logging Service.
[ OK ] Started uid-reader.
Starting neard...
[ OK ] Reached target Containers.
Starting Print notice about GPLv3 packages...
Starting RPC Bind Service...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon u[ 11.132122] omap_hwmod: pruss: _wait_target_ready failed: -16
sing ipsec.conf.
[ OK ] Started Periodic Command Scheduler.
[ 11.327362] pruss-soc-bus 4a326004.pruss-soc-bus: use pm_runtime_put_sync_suspend() in driver?
[ OK ] Started Job spooling tools.
[ 11.466637] pruss-soc-bus 4a326004.pruss-soc-bus: couldn't enable module
[ 11.474833] pruss-soc-bus: probe of 4a326004.pruss-soc-bus failed with error -16
[ 11.660485] remoteproc remoteproc0: wkup_m3 is available
[ 11.709783] random: crng init done
[ 11.709794] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 11.875618] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 11.928353] PM: Cannot get wkup_m3_ipc handle
[ 11.929754] remoteproc remoteproc0: powering up wkup_m3
[ 11.968503] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224672
[ 11.968775] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 11.968799] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
Starting Login Service...
[ OK ] Started D-Bus System Message Bus.
[ 12.497103] PM: bootloader does not support rtc-only!
[ 12.502703] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 12.599279] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 12.744829] NET: Registered protocol family 15
[ 12.754488] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1
[ OK ] Started Kernel Logging Service.
Starting uim-sysfs.service...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ 14.281122] net eth0: initializing cpsw version 1.12 (0)
[ OK ] Started Network Service.
[ OK ] Started neard.
[ OK ] Started RPC Bind Service.
[ 14.576936] Micrel KSZ8041RNLI 4a101000.mdio:00: attached PHY driver [Micrel KSZ8041RNLI] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 14.740257] Initializing XFRM netlink socket
[ 14.899551] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.338457] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 16.808391] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 16.902544] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting neard-setup...
[ OK ] Reached target Network.
Starting Permit User Sessions...
Starting Enable and configure wl18xx bluetooth stack...
Starting Network Name Resolution...
Starting Lightning Fast Webserver With Light System Requirements...
Starting raichu-start...
[ OK ] Started Permit User Sessions.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
Starting Load/Save RF Kill Switch Status...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Network Name Resolution.
[ 20.674278] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified
[ 20.806749] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input0
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ 22.525820] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 22.677908] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 22.738859] usbcore: registered new interface driver usbfs
[ 22.738921] usbcore: registered new interface driver hub
[ 22.739069] usbcore: registered new device driver usb
[ 23.067440] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 23.150107] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 23.239631] hub 1-0:1.0: USB hub found
[ 23.297526] hub 1-0:1.0: 1 port detected
[ 23.424324] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 23.491862] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[ 23.578659] hub 2-0:1.0: USB hub found
[ 23.626485] hub 2-0:1.0: 1 port detected
[ 23.836479] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 24.059937] hub 1-1:1.0: USB hub found
[ 24.087512] hub 1-1:1.0: 4 ports detected
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evmsk ttyS0
Arago 2018.08 am335x-evmsk ttyS0
am335x-evmsk login: ***************************************************************
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
binutils
cifs-utils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
gstreamer1.0-libav
gzip
hidapi
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm4
libgettextlib
libgettextsrc
libgmp10
libidn11
libmpc3
libmpfr4
libreadline-dev
libreadline7
libunistring2
m4-dev
m4
make
nettle
python3-pycairo
which
zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
root[ 28.892627] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
root@am335x-evmsk:~#ifconfig
th0 Link encap:Ethernet HWaddr 18:62:E4:E2:5C:B9
inet6 addr: fe80::1a62:e4ff:fee2:5cb9%763612/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:227 errors:0 dropped:0 overruns:0 frame:0
TX packets:415 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:18048 (17.6 KiB) TX bytes:41074 (40.1 KiB)
Interrupt:49
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%763612/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:339 errors:0 dropped:0 overruns:0 frame:0
TX packets:339 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:27304 (26.6 KiB) TX bytes:27304 (26.6 KiB)
Zafer Çalışkan
