Part Number: AM5718
Other Parts Discussed in Thread: AM5728
I am using AM5718 IDK EVM and ti-processor-sdk-linux-am57xx-evm-05.03.00.07.
I am carrying out the activity of booting EVM with minimum peripherals (UART3, eth0,I2c, QSPI1, MMC1.).My aim is to make sure that our custom board will boot with the given U-boot and kernel.
Pin-mux file used and the booting log are attached. pin-mux file extension i.e. 'am571x_minimal.pinmux' was changed to 'am571x_minimal.txt' as upload error occurred.
mux_data.h of U-boot was modified using the files generated with this pin-mux.
core_padconf_array_essential_am571x_idk[] and iodelay_cfg_entry iodelay_cfg_array_am571x_idk[] in mux_data.h of U-boot were modified.
Changes done in DTS are as follows
1. am571x-idk.dtsi
Disabled pruss1_eth,&pruss1_mdio in am571x-idk.dtsi.
2. am571x-idk-common.dtsi
Disabled &ipu1, &ipu2
3. am57xx-idk-common.dtsi
Disabled &pruss_soc_bus1, &pruss_soc_bus2.
Removed &cpsw_emac1, dual_emac in &mac
Removed dual_emac_res_vlan = <1>; in &cpsw_emac0
1)Why i'm getting the following error:
Card did not respond to voltage select!
invalid mmc device
(GPIO6_27 and GPIO6_28 corresponding to MMC card are enabled in the pin-mux)
Though this error is shown, EVM boots with the U-boot and kernel in SD-Card.
2) If I do not change the pin-mux of UART3, eth0,I2c, QSPI1, MMC1 etc. Can I make sure that my custom board will boot with this pin-mux, U-boot and kernel ?
3) Which all peripherals do I need to disable other than these in the DTS?
regards,
Anupama
U-Boot SPL 2018.01-00569-gfd38f5afef-dirty (Aug 05 2019 - 14:03:49)
DRA722-GP ES2.0
Trying to boot from MMC1
no pinctrl state for default mode
*** Warning - MMC init failed, using default environment
U-Boot 2018.01-00569-gfd38f5afef-dirty (Aug 05 2019 - 14:03:49 +0530)
CPU : DRA722-GP ES2.0
Model: TI AM5718 IDK
Board: AM571x IDK REV 1.3B
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
invalid mmc device
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Unable to read file boot.scr **
1490 bytes read in 3 ms (484.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
1 bytes read in 1 ms (1000 Bytes/s)
Already setup.
4022784 bytes read in 201 ms (19.1 MiB/s)
97048 bytes read in 18 ms (5.1 MiB/s)
Loading Device Tree to 8ffe5000, end 8ffffb17 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79-ge669d52447 (bcgi147@bcgi147-HP-Compaq-8200-Elite-MT-PC) (gcc version 7.2.1 20171011 (Linaro GC9
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5718 IDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000be400000
[ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[ 0.000000] DRA722 ES2.0
[ 0.000000] percpu: Embedded 15 pages/cpu @ef649000 s31372 r8192 d21876 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 210496
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=1a39f6e2-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 644580K/848896K available (8192K kernel code, 347K rwdata, 2564K rodata, 2048K init, 282K bss, 24092K reserve)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB)
[ 0.000000] .data : 0xc1000000 - 0xc1056e98 ( 348 kB)
[ 0.000000] .bss : 0xc1058000 - 0xc109ebe0 ( 283 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000345] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000353] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000806] Console: colour dummy device 80x30
[ 0.000824] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000831] This ensures that you still see kernel messages. Please
[ 0.000838] update your kernel commandline.
[ 0.000858] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000873] pid_max: default: 32768 minimum: 301
[ 0.000990] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001004] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001531] CPU: Testing write buffer coherency: ok
[ 0.001570] CPU0: Spectre v2: using ICIALLU workaround
[ 0.001768] /cpus/cpu@0 missing clock-frequency property
[ 0.001782] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039848] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059856] Hierarchical SRCU implementation.
[ 0.080041] EFI services will not be available.
[ 0.099915] smp: Bringing up secondary CPUs ...
[ 0.099926] smp: Brought up 1 node, 1 CPU
[ 0.099935] SMP: Total of 1 processors activated (12.29 BogoMIPS).
[ 0.099943] CPU: All CPU(s) started in HYP mode.
[ 0.099950] CPU: Virtualization extensions available.
[ 0.100376] devtmpfs: initialized
[ 0.117984] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.120057] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.120256] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.120273] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.124030] pinctrl core: initialized pinctrl subsystem
[ 0.124522] DMI not present or invalid.
[ 0.124778] NET: Registered protocol family 16
[ 0.130833] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.131676] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.326084] cpuidle: using governor ladder
[ 0.326118] cpuidle: using governor menu
[ 0.334494] OMAP GPIO hardware version 0.1
[ 0.361170] No ATAGs?
[ 0.361216] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.361229] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.361633] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.361644] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.362188] OMAP DMA hardware revision 0.0
[ 0.392340] edma 43300000.edma: memcpy is disabled
[ 0.395480] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.402264] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.405663] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.405870] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.406113] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.406357] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.406744] iommu: Adding device 40800000.dsp to group 0
[ 0.409136] palmas 0-0058: Irq flag is 0x00000004
[ 0.432246] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 0.433886] SMPS12: supplied by regulator-dummy
[ 0.435659] SMPS3: supplied by VMAIN
[ 0.437263] SMPS45: supplied by regulator-dummy
[ 0.439140] SMPS6: supplied by VMAIN
[ 0.440883] SMPS7: supplied by VMAIN
[ 0.442779] SMPS8: supplied by VMAIN
[ 0.444071] SMPS9: supplied by VMAIN
[ 0.445088] LDO1: supplied by VMAIN
[ 0.451126] random: fast init done
[ 0.451305] LDO2: supplied by VMAIN
[ 0.461158] LDO3: supplied by VMAIN
[ 0.471164] LDO4: supplied by VMAIN
[ 0.481167] LDO5: supplied by regulator-dummy
[ 0.481891] LDO6: supplied by regulator-dummy
[ 0.482607] LDO7: supplied by regulator-dummy
[ 0.483320] LDO8: supplied by regulator-dummy
[ 0.484047] LDO9: supplied by VMAIN
[ 0.491520] LDOLN: supplied by VMAIN
[ 0.501226] LDOUSB: supplied by VMAIN
[ 0.513962] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.514178] media: Linux media interface: v0.10
[ 0.514217] Linux video capture interface: v2.00
[ 0.514301] pps_core: LinuxPPS API ver. 1 registered
[ 0.514310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.514330] PTP clock support registered
[ 0.514356] EDAC MC: Ver: 3.0.0
[ 0.520690] dmi: Firmware registration failed.
[ 0.521114] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.521324] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.521665] Advanced Linux Sound Architecture Driver Initialized.
[ 0.530760] clocksource: Switched to clocksource arch_sys_counter
[ 0.538241] NET: Registered protocol family 2
[ 0.538776] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.538838] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.538964] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.539032] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.539069] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.539187] NET: Registered protocol family 1
[ 0.559541] RPC: Registered named UNIX socket transport module.
[ 0.559551] RPC: Registered udp transport module.
[ 0.559559] RPC: Registered tcp transport module.
[ 0.559566] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.560469] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.560596] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.561647] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.565719] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.576269] NFS: Registering the id_resolver key type
[ 0.576292] Key type id_resolver registered
[ 0.576300] Key type id_legacy registered
[ 0.576337] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.577979] bounce: pool size: 64 pages
[ 0.578029] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.578040] io scheduler noop registered
[ 0.578049] io scheduler deadline registered
[ 0.578139] io scheduler cfq registered (default)
[ 0.578149] io scheduler mq-deadline registered
[ 0.578157] io scheduler kyber registered
[ 0.582729] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.582881] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.582953] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 0.582964] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.595673] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[ 0.596060] OF: PCI: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 0.596094] OF: PCI: IO 0x20003000..0x20012fff -> 0x00000000
[ 0.596122] OF: PCI: MEM 0x20013000..0x2fffffff -> 0x20013000
[ 1.596376] dra7-pcie 51000000.pcie: phy link never came up
[ 1.596506] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.596520] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.596532] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.596542] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.596854] PCI: bus0: Fast back to back transfers disabled
[ 1.596948] PCI: bus1: Fast back to back transfers enabled
[ 1.596986] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[ 1.597005] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.597328] pcieport 0000:00:00.0: Signaling PME with IRQ 170
[ 1.597456] pcieport 0000:00:00.0: AER enabled with IRQ 170
[ 1.600408] V3_3D: supplied by smps9
[ 1.600693] vtt_fixed: supplied by V3_3D
[ 1.643199] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.645957] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
[ 2.680604] console [ttyS2] enabled
[ 2.686009] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 2.693112] DSS: OMAP DSS rev 6.1
[ 2.698088] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 2.706581] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 2.726546] brd: module loaded
[ 2.735072] loop: module loaded
[ 2.742306] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[ 2.747351] 7 ofpart partitions found on MTD device spi0.0
[ 2.752942] Creating 7 MTD partitions on "spi0.0":
[ 2.757756] 0x000000000000-0x000000040000 : "QSPI.SPL"
[ 2.763621] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[ 2.769667] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[ 2.776342] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[ 2.782736] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[ 2.789798] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[ 2.795851] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[ 2.802929] libphy: Fixed MDIO Bus: probed
[ 2.860797] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 2.868492] davinci_mdio 48485000.mdio: detected phy mask fffffffc
[ 2.889287] libphy: 48485000.mdio: probed
[ 2.893375] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[ 2.903112] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 2.913577] cpsw 48484000.ethernet: No slave[1] phy_id, phy-handle, or fixed-link property
[ 2.921951] cpsw 48484000.ethernet: Detected MACID = 44:ea:d8:17:d8:d6
[ 2.928563] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 2.934986] cpsw 48484000.ethernet: ALE Table size 1024
[ 2.940244] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 2.947285] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.955690] i2c /dev entries driver new :)
[ 2.960510] IR NEC protocol handler initialized
[ 2.965089] IR RC5(x/sz) protocol handler initialized
[ 2.970160] IR RC6 protocol handler initialized
[ 2.974721] IR JVC protocol handler initialized
[ 2.979268] IR Sony protocol handler initialized
[ 2.984114] IR SANYO protocol handler initialized
[ 2.988836] IR Sharp protocol handler initialized
[ 2.993574] IR MCE Keyboard/mouse protocol handler initialized
[ 2.999429] IR XMP protocol handler initialized
[ 3.009487] sdhci: Secure Digital Host Controller Interface driver
[ 3.015800] sdhci: Copyright(c) Pierre Ossman
[ 3.021289] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.027701] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 3.033120] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 3.039763] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 3.100981] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 3.147902] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.157908] mmc0: new high speed SDHC card at address 59b4
[ 3.163796] mmcblk0: mmc0:59b4 USD 14.9 GiB
[ 3.169686] mmcblk0: p1 p2
[ 3.172516] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 3.173555] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.183147] NET: Registered protocol family 10
[ 3.194176] Segment Routing with IPv6
[ 3.194218] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.194518] NET: Registered protocol family 17
[ 3.194659] Key type dns_resolver registered
[ 3.194743] omap_voltage_late_init: Voltage driver support not added
[ 3.194745] Power Management for TI OMAP4+ devices.
[ 3.194937] Registering SWP/SWPB emulation handler
[ 3.238967] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.249536] dmm 4e000000.dmm: initialized all PAT entries
[ 3.256622] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.263403] [drm] No driver support for vblank timestamp query.
[ 3.269470] [drm] Cannot find any crtc or sizes
[ 3.277989] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 3.285522] hctosys: unable to open rtc device (rtc0)
[ 3.291227] ALSA device list:
[ 3.294205] No soundcards found.
[ 3.360038] ti-iodelay 4844a000.padconf: Set reg 0x18c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.369071] ti-iodelay 4844a000.padconf: Set reg 0x1a4 Delay(a: 119 g: 0), Elements(C=0 F=3)0x29003
[ 3.378259] ti-iodelay 4844a000.padconf: Set reg 0x1b0 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.387279] ti-iodelay 4844a000.padconf: Set reg 0x1bc Delay(a: 18 g: 0), Elements(C=0 F=0)0x29000
[ 3.396386] ti-iodelay 4844a000.padconf: Set reg 0x1c8 Delay(a: 894 g: 0), Elements(C=1 F=11)0x2902b
[ 3.405575] ti-iodelay 4844a000.padconf: Set reg 0x1d4 Delay(a: 30 g: 0), Elements(C=0 F=0)0x29000
[ 3.414687] ti-iodelay 4844a000.padconf: Set reg 0x1e0 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.423711] ti-iodelay 4844a000.padconf: Set reg 0x1ec Delay(a: 23 g: 0), Elements(C=0 F=0)0x29000
[ 3.432827] ti-iodelay 4844a000.padconf: Set reg 0x1f8 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.441842] ti-iodelay 4844a000.padconf: Set reg 0x360 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.450868] ti-iodelay 4844a000.padconf: Set reg 0x194 Delay(a: 152 g: 0), Elements(C=0 F=4)0x29004
[ 3.460048] ti-iodelay 4844a000.padconf: Set reg 0x1ac Delay(a: 206 g: 0), Elements(C=0 F=5)0x29005
[ 3.469236] ti-iodelay 4844a000.padconf: Set reg 0x1b8 Delay(a: 78 g: 0), Elements(C=0 F=2)0x29002
[ 3.478337] ti-iodelay 4844a000.padconf: Set reg 0x1c4 Delay(a: 2 g: 0), Elements(C=0 F=0)0x29000
[ 3.487353] ti-iodelay 4844a000.padconf: Set reg 0x1d0 Delay(a: 266 g: 0), Elements(C=0 F=7)0x29007
[ 3.496541] ti-iodelay 4844a000.padconf: Set reg 0x1dc Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.505564] ti-iodelay 4844a000.padconf: Set reg 0x1e8 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.514583] ti-iodelay 4844a000.padconf: Set reg 0x1f4 Delay(a: 43 g: 0), Elements(C=0 F=1)0x29001
[ 3.523683] ti-iodelay 4844a000.padconf: Set reg 0x200 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.532610] ti-iodelay 4844a000.padconf: Set reg 0x368 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.541632] ti-iodelay 4844a000.padconf: Set reg 0x190 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.550633] ti-iodelay 4844a000.padconf: Set reg 0x1a8 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.559644] ti-iodelay 4844a000.padconf: Set reg 0x1b4 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.568661] ti-iodelay 4844a000.padconf: Set reg 0x1c0 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.577679] ti-iodelay 4844a000.padconf: Set reg 0x1d8 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.586701] ti-iodelay 4844a000.padconf: Set reg 0x1e4 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.595628] ti-iodelay 4844a000.padconf: Set reg 0x1f0 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.604678] ti-iodelay 4844a000.padconf: Set reg 0x1fc Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.613605] ti-iodelay 4844a000.padconf: Set reg 0x364 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[ 3.625110] mmc1: new DDR MMC card at address 0001
[ 3.630256] mmcblk1: mmc1:0001 R1J56L 13.8 GiB
[ 3.635038] mmcblk1boot0: mmc1:0001 R1J56L partition 1 4.00 MiB
[ 3.641099] mmcblk1boot1: mmc1:0001 R1J56L partition 2 4.00 MiB
[ 3.647239] mmcblk1rpmb: mmc1:0001 R1J56L partition 3 128 KiB
[ 3.653609] mmcblk1: p1 p2
[ 3.757893] EXT4-fs (mmcblk0p2): recovery complete
[ 3.766125] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.774302] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.784576] devtmpfs: mounted
[ 3.788412] Freeing unused kernel memory: 2048K
[ 4.118636] systemd[1]: System time before build time, advancing clock.
[ 4.170025] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPT)
[ 4.191250] systemd[1]: Detected architecture arm.
Welcome to Arago 2018.10!
[ 4.232675] systemd[1]: Set hostname to <am57xx-evm>.
[ 4.320816] [drm] Cannot find any crtc or sizes
[ 4.637149] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.645152] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.680874] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.689601] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.721150] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.728232] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.825980] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.867789] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 4.901374] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.930955] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Reached target Slices.
Mounting Kernel Debug File System...
Mounting POSIX Message Queue File System...
Mounting Temporary Directory (/tmp)...
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Socket.
Starting Create list of required st��…ce nodes for the current kernel...
Starting Load Kernel Modules...
Starting Journal Service...
[ 5.452610] cryptodev: loading out-of-tree module taints kernel.
Starting Remount Root and Kernel File Systems...
[ OK ] Mounted Kernel Debug File System.
[ 5.486062] cryptodev: driver 1.9 loaded.
[ OK ] Mounted POSIX Message Queue File System.
[ 5.515246] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta��…vice nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
Starting Rebuild Hardware Database...
Starting Create System Users...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Create System Users.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
[ 5.928492] systemd-journald[79]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
Starting Rebuild Journal Catalog...
Starting Load/Save Random Seed...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Rebuild Dynamic Linker Cache.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting Update is Completed...
Starting udev Coldplug all Devices...
[ OK ] Started Update is Completed.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ 8.925102] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 9.030673] remoteproc remoteproc0: 40800000.dsp is available
Starting Network Service...
[ OK ] Listening on D-Bus System Message Bus Socket.[ 9.064448] remoteproc remoteproc0: Direct firmware load for dra7-dsp1-fw.x2
[ 9.089725] remoteproc remoteproc0: powering up 40800000.dsp
[ 9.105018] remoteproc remoteproc0: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[ 9.105026] remoteproc remoteproc0: request_firmware failed: -2
Starting Docker Socket for the API.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Started Network Service.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Found device /dev/ttyS2.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Login Service...
[ OK ] Started System Logging Service.
[ OK ] Started D-Bus System Message Bus.
[ OK ] Reached target Containers.
[ 9.620135] ov2659 0-0030: Sensor detection failed (3030, 0)
[ 9.629194] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 9.637777] omap-des 480a5000.des: will run requests pump with realtime priority
[ 9.765269] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659038@58:tps659038_rtc as r0
[ 9.925066] omap_gpio 4805b000.gpio: Could not set line 7 debounce to 20000 microseconds (-22)
[ 10.242830] omap_rtc 48838000.rtc: registered as rtc1
Starting uim-sysfs.service...
[ 10.348383] net eth0: initializing cpsw version 1.15 (0)
[ OK ] Started Kernel Logging Service.
[ OK ] Reached target Network.
Starting Permit User Sessions...
Starting Enable and configure wl18xx bluetooth stack...
Starting DNS forwarder and DHCP server...
Starting Wait for Network to be Configured...
[ 10.505671] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 10.525039] Micrel KSZ9031 Gigabit PHY 48485000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485)
[ 10.525149] libphy: PHY not found
[ 10.525154] net eth0: phy "" not found on slave 1, err -19
[ 10.537167] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.541173] vpe 489d0000.vpe: Device registered as /dev/video0
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ OK ] Started Permit User Sessions.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ 11.603406] vip 48970000.vip: loading firmware vpdma-1b8.bin
[ 11.630820] vip 48970000.vip: VPDMA firmware loaded
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started DNS forwarder and DHCP server.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Started Login Service.
[ OK ] Started uim-sysfs.service.
Starting telnetd.service...
[ 12.168603] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 12.227397] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 12.284200] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 12.324640] SCSI subsystem initialized
[ 12.418802] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 12.418822] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 12.418829] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 12.431016] scsi host0: ahci
[ 12.431205] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 80
[ 12.449956] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 12.452776] CAN device driver interface
[ 12.474837] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=88)
[ 12.475221] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 12.533497] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 12.537827] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 12.561178] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 12.566923] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 12.761797] ata1: SATA link down (SStatus 0 SControl 300)
[ 13.015767] omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
[ 13.015773] omap-hdmi-audio omap-hdmi-audio.0.auto: ASoC: no DMI vendor name!
[ OK ] Started telnetd.service.
[ 13.689469] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 13.710859] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Starting thttpd.service...
[ OK ] Started thttpd.service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ 15.428295] usbcore: registered new interface driver usbfs
[ 15.460701] usbcore: registered new interface driver hub
[ 15.506118] usbcore: registered new device driver usb
[ 15.554044] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 15.559576] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 15.599047] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[ 15.622638] xhci-hcd xhci-hcd.1.auto: irq 177, io mem 0x48890000
[ 15.642645] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 15.649509] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 15.672940] usb usb1: Product: xHCI Host Controller
[ 15.677839] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 xhci-hcd
[ 15.703134] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 15.713391] hub 1-0:1.0: USB hub found
[ 15.725203] hub 1-0:1.0: 1 port detected
[ OK ] Reached target Sound Card.
[ 15.738821] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 15.745157] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 15.755316] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 15.775291] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 15.785409] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 15.793189] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 15.800443] usb usb2: Product: xHCI Host Controller
[ 15.806655] usb usb2: Manufacturer: Linux 4.14.79-ge669d52447 xhci-hcd
[ 15.814003] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 15.819853] hub 2-0:1.0: USB hub found
[ 15.825967] hub 2-0:1.0: 1 port detected
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am57xx-evm ttyS2
Arago 2018.10 am57xx-evm ttyS2
am57xx-evm login:
