AM5728: DDR GEL file
Part Number: AM5728
I used the EMIF_RegisterConfiguration.xlsm for the change in the DDR gel file of the AM5728.
Please guide me what all the changes to be done in the DDR GEL file.send me the screen shot if available.
  • Hi Ashok,
    After the system level, board level, and DDR timing details have been populated in their corresponding worksheets, you can access the fifth worksheet, "Register Values (GEL_SBL)", to obtain the calculated register settings based on the your input.
    A "Register Values (GEL_SBL)" worksheet is provided in the event that you wish to integrate the EMIF configuration values into a custom GEL file.
    Note that the register values (GEL) are output for a single EMIF channel in the results section. If utilizing multiple EMIF channels with the same DDR memory width and type, the same settings should be applied to the other EMIF channel.
    Refer to the below user guide for details, section 2.2.4 Results– Register Values
    Pavel
