AM4377: Ethernet RMII send fails
Part Number: AM4377
The AM4377 uses the RMII interface to connect to the DP83848 and connects to the computer via a network cable (the network card is the Intel(R) PRO/1000 MT Dual Port Server Adapter).
See the accessories for hardware pin settings.
Pinmux settings:
static struct module_pin_mux rmii2_pin_mux[] = {
{OFFSET(gpmc_a0), MODE(3)| SLEWCTRL}, /* RMII2_TXEN:*/
{OFFSET(gpmc_a4), MODE(3)| SLEWCTRL}, /* RMII2_TXD1:*/
{OFFSET(gpmc_a5), MODE(3)| SLEWCTRL}, /* RMII2_TXD0:*/
{OFFSET(gpmc_a10), MODE(3) | SLEWCTRL | RXACTIVE}, /* RMII2_RXD1:*/
{OFFSET(gpmc_a11), MODE(3) | SLEWCTRL | RXACTIVE}, /* RMII2_RXD0:*/
{OFFSET(gpmc_wait0), MODE(3) | PULLUP_EN | RXACTIVE}, /* RMII2_CRS_DV:*/
{OFFSET(gpmc_wpn), MODE(3) | SLEWCTRL | RXACTIVE}, /* RMII2_RXER:*/
{OFFSET(mii1_col), MODE(1) | RXACTIVE}, /* RMII2_refclk:*/
{-1},mastermodule_c.pdf
At initialization, phy is only configured for auto-negotiation enable, others are default values. The mac of the 4377 is configured in RMII mode, and the clock is configured as "chip pin". After the mode is started, the link and auto-negotiation are normal and can be pinged.
[1] However, after the network cable is unplugged and plugged in, the sending direction is unreachable. The transmission interrupt is not increased. The tx_D0/D1 and tx_en pins are low, and the external clock is 50M ok. The current post-plugging process is to reconfigure an auto-negotiation and write Bit12 of the ctrl register, but the re-execution auto-negotiation should write bit12 or bit9 of the ctrl register?
12:AUTO-NEGOTIATION Strap, RW Auto-Negotiation Enable:
9:RESTART 0, RW/SC Restart Auto-Negotiation:
[2] When the board is connected to the computer of the windows system, the network cable is unplugged and cannot be sent. The result of replacing multiple computers is the same.However, when the board is connected to the computer of the linux system, the connection can be restored, and the two boards are directly connected, it can also be restored to normal (the board uses linux system). The difference is that the ARP packets sent by the computer received after plugging in the Internet cable are about 10 packets, but it will receive dozens of interrupts/packages when connected with Windows. I want to know if it is a hardware or software problem?
Is there a problem with the configuration of phy or mac? Which directions should I check?
Thank you!
  • Please post which Linux version you are using on the AM437x.
    Please complete this checklist and post the results here: processors.wiki.ti.com/.../5x_CPSW
  • d.slaves2=6;
    cpsw_phy_init:buscpsw,Addr0,devcpsw,if6;
    get phy by mask1!
    cpsw PHY: 0 not found
    Could not get PHY for cpsw: addr 0
    cpsw_phy_init:buscpsw,Addr1,devcpsw,if6;
    get phy by mask2!
    create phyid20005c90 cpsw addr1 if6!     -----------【addir=1,id is ok,and read phy reg is linked up】
    use generic phy!
    create phy cpsw(0)!
    cpsw connected to Generic PHY
    cpsw_phy_init:buscpsw,Addr4,devcpsw,if6;
    get phy by mask10!
    cpsw PHY: 4 not found
    Could not get PHY for cpsw: addr 4
    get phy by mask1!
    get phy by mask2!
    find phy cpsw!
    get phy by mask10!
    Initial value for argc=3
    Final value for argc=3
    cpsw, usb_ether
    initcall: 8080bebd (relocated to 9ff3debd)
    fdtdec_get_config_int: bootdelay
    ### main_loop entered: bootdelay=1
    CRSC># mdio read 0-7
    Reading from bus cpsw
    PHY at address 1:
    0 - 0x3100 --ok
    1 - 0x786d
    2 - 0x2000
    3 - 0x5c90
    4 - 0x1e1
    5 - 0xc1e1 --1 = Link Partner desires Next Page Transfer.
    6 - 0xf --1 = Link Partner does support Next Page
    7 - 0x2801
    【when plug in can be restored】:
    phy reg0~7= 1000(0) 786d(1) 2000(2) 5c90(3) 1e1(4) c1e1(5) d(6) 2801(7);
    phy reg0x10~0x1D= 4615(10) 1(11) 0(12) 0(13) 0(14) 0(15) 100(16) 21(17) 0(18) 8021(19) 904(1a) 0(1b) 0(1c) 6011(1d);
    rmii pinmux cfg:TXEN=3,TXD1=3,TXD0=3,RXD1=40003,
    RXD0=40003,CRS_DV=60003,RXER=40003,REFCLK=40001,MDIO_DATA=20000,MDIO_CLK=60000,;
    PHY 1 Transfer Mode : 100 Mbps Full Duplex.
    【when plug in can not be restored】:
    PHY 1 Auto-Negotiation Successful(c200).
    CPSW0 port1 phy dump:
    【ip is 192.168.1.236,when  plug in can not be restored】
    [root@PLT5-0:/root]# ifconfig
    en1 Link encap: Ethernet HWaddr: b0:d5:cc:75:56:26
    Dev: cpsw0 Ifidx: 2 DHCP: D4 D6 Spd: 100 Mbps
    inet addr: 192.168.1.236 netmask: 255.255.255.0
    gateway: 192.168.1.1 broadcast: 192.168.1.255
    inet6 addr: fe80::b2d5:ccff:fe75:5626 Scope:link
    UP BROADCAST RUNNING MULTICAST MTU:1500 METRIC:1
    tcp_ack_freq:2 tcp_wnd_size:65535
    RX ucast packets:149 nucast packets:0 dropped:0
    TX ucast packets:7 nucast packets:5 dropped:0
    RX bytes:16386 TX bytes:846
    lo0 Link encap: Local Loopback
    Dev: N/A Ifidx: 1 DHCP: D4 D6 Spd: N/A
    inet addr: 127.0.0.1 netmask: 255.0.0.0
    P-to-P: 127.0.0.1 broadcast: Non
    inet6 addr: ::1 Scope:loopback
    UP LOOPBACK RUNNING MTU:0 METRIC:1
    tcp_ack_freq:2 tcp_wnd_size:262140
    RX ucast packets:3 nucast packets:0 dropped:0
    TX ucast packets:3 nucast packets:0 dropped:0
    RX bytes:168 TX bytes:168
    dns0: 0.0.0.0
    dns1: 0.0.0.0
    default device is: en1
    list net interface: 2
    phy link err=0x7849,id=0x2000,5c90;     --------【this time pluged in】
    mac0 r L64: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 06 00 01 08 00 06 04 00 01 00 04 23 a7 22 f4 00 00 00 00 00 00 00 00 00 00 c0 a8 01 0c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00;
    mac0 r L82: 33 33 ff 98 91 99 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 18 3a ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 02 00 00 00 00 00 00 00 00 00 01 ff 98 91 99 87 00 fc 00 00 00;
    mac0 r L74: 33 33 00 00 00 02 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 10 3a ff fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02 85 00 47 9a 00 00;
    mac0 r L94: 33 33 00 00 00 16 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 24 00 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 00 00 16 3a 00 05 02 00 00;
    mac0 r L64: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 06 00 01 08 00 06 04 00 01 00 04 23 a7 22 f4 c0 a8 01 0c 00 00 00 00 00 00 c0 a8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00;
    PHY 1 Performing Auto-Negotiation...
    [ver2019.0328appM]��pltMain start!
    [ver2019.0328appM]:pltMain start!
    cpu2 hw init;
    AM437X_FlashInit 0 open...
    AM437X_UartInit 0 open...
    uart0 baud set...
    uart0 Set baud = 115200
    AM437X_UartInit 4 open...
    creat task t_uart4R;
    dma ER=14000a00,0,EER=28000500,0;
    ccReg:0;0;0;0;0;0;0;
    tcReg:0;0;0;0;0;0;0;
    RParam:chl=4,opt=0x8010a000,src=0x481a8000,dst=0x82e8a000,Acnt=1,Bcnt=10240,Ccnt1;
    srcBid=0,dstBid=1,srcCid=0,dstCid=1,link=0x4480,BcntRld=0;
    uart4 baud set...
    uart4 Set baud = 3000000
    set sio4 baud 3000000;
    AM437X_UartInit 1 open...
    creat task t_uart1R;
    RParam:chl=1,opt=0x8011d000,src=0x48022000,dst=0x82e8d000,Acnt=1,Bcnt=10240,Ccnt1;
    srcBid=0,dstBid=1,srcCid=0,dstCid=1,link=0x4420,BcntRld=0;
    uart1 baud set...
    uart1 Set baud = 3000000
    set sio1 baud 3000000;
    AM437X_UartInit 3 open...
    creat task t_uart3R;
    RParam:chl=3,opt=0x80108000,src=0x481a6000,dst=0x82e90000,Acnt=1,Bcnt=10240,Ccnt1;
    srcBid=0,dstBid=1,srcCid=0,dstCid=1,link=0x4460,BcntRld=0;
    uart3 baud set...
    uart3 Set baud = 3000000
    set sio3 baud 3000000;
    AM437X_TemprInit 0 open...
    AM437X_AdcInit open...
    gpio test:
    gpio0 open...
    gpio1 open...
    gpio2 open...
    gpio3 open...
    gpio4 open...
    gpio5 open...
    gpio6 open...
    gpio7 open...
    gpio9 open...
    failed to open /dev/gpiofd/85(9,0x55,0)=0xffffffff!
    gpio10 open...
    gpio11 open...
    gpio12 open...
    failed to open /dev/gpiofd/138(12,0x8a,0)=0xffffffff!
    gpio13 open...
    gpio14 open...
    gpio15 open...
    AM437X_AdcSelfTest:
    adc0 rev msg size=140:
    [0x0]= 0 10001 20002 30003 40004 50005 60006 70007
    [0x20]= 0 0 0 0 0 0 0 0
    [0x40]= d4e(1.497V) 10d51(1.498V) 209ca(1.101V) 309cb(1.101V) 40000 50000 60000 70000
    [0x60]= 0 0 0 0 0 0 0 0
    [0x80]= 6 0 8
    adc get volt test:
    volt(0~3)=0x5de(1.502V) 0x5da(1.498V) 0x44d(1.101V) 0x44f(1.103V)
    adc get tempr test:
    tempr=0x2e00(46.0��C);
    the offset is 0xe0000
    erase1
    0xe0000 BER64,0xf0000 SER,0xf1000 SER,0xf2000 SER,0xf3000 SER,0xf4000 SER,0xf5000 SER,
    erase2
    0xf5000 SER,0xf6000 SER,0xf7000 SER,0xf8000 SER,0xf9000 SER,0xfa000 SER,0xfb000 SER,0xfc000 SER,0xfd000 SER,0xfe000 SER,0xff000 SER,0x100000 SER,read1
    read2 0xf4f80
    write1 0xf4f80
    read1 0xf4f80
    write2
    read2
    test os flash:addr0xe0200,len13312;
    write and read:
    ers addr0xe0000(e3000),size0x4000;left=512,2560;
    mac0 r L158: 33 33 00 01 00 02 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 64 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 02 02 22 02 23 00 64;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 54 00 00 01 02 2d b1 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 55 00 00 01 02 2d b0 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 ea 03 00 00 00 01 04 00 00 00 ef ff ff fa 00 00 00 00 00 00;
    mac0 r L96: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 26 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 ff 5e 14 eb 00 26;
    mac0 r L76: 01 00 5e 00 00 fc 00 04 23 a7 22 f4 08 00 45 00 00 3a 55 56 00 00 01 11 c1 ac c0 a8 01 0c e0 00 00 fc c0 27 14 eb 00 26 1b b4 1d 9a 00 00 00 01 00 00 00 00 00 00 0c 78 38 30 31 30;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 57 00 00 01 11 b2 46 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 58 00 00 01 11 b2 45 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L66: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 30 55 59 00 00 01 02 2d a4 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 05 06 00 00 00 02 04 00 00 00 e0 00 00 fc 04 00 00 00 ef ff;
    mac0 r L114: 33 33 00 00 00 16 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 38 00 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 00 00 16 3a 00 05 02 00 00;
    0xe0000 SER,0xe1000 SER,0xe2000 SER,0xe3000 SER,0xe4000 SER,
    erase and read:
    mac0 r L90: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 20 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 f2 e1 14 eb 00 20;
    mac0 r L70: 01 00 5e 00 00 fc 00 04 23 a7 22 f4 08 00 45 00 00 34 55 5a 00 00 01 11 c1 ae c0 a8 01 0c e0 00 00 fc f3 9c 14 eb 00 20 3c ba b9 8b 00 00 00 01 00 00 00 00 00 00 06 69 73 61 74 61;
    0xe0000 SER,0xe1000 SER,0xe2000 SER,0xe3000 SER,0xe4000 SER,flash0 ers 0xe0000 size=16384:
    clkRate=1000;tick0=12601;pltPktBufInit ok,blkChlNum=53/83(12+12+10/40+9+10)start0x8063de04!
    can not open dir /var/log0=2 No such file or directory!
    c0logAdd0
    log file0 size init1=0B;
    log file0 size init2=0B;
    can not open dir /var/log1=2 No such file or directory!
    c1logAdd0
    log file1 size init1=0B;
    log file1 size init2=0B;
    can not open dir /var/log2=2 No such file or directory!
    c2logAdd0
    log file2 size init1=0B;
    log file2 size init2=0B;
    can not open dir /var/log3=2 No such file or directory!
    c3logAdd0
    log file3 size init1=0B;
    log file3 size init2=0B;
    pltMain pltSysLog ok!
    [c2]logW:T000031e8-APP0-0P1-0:
    [c2]logW:pltMain PL
    [c2]logW:T_SendMsgT
    [c2]logW:oLog ok!
    phy reg0~7= 1000(0) 786d(1) 2000(2) 5c90(3) 1e1(4) c1e1(5) f(6) 2801(7);
    [c2]logW:
    phy reg0x10~0x1D= 4015(10) 1(11) 2c00(12) 0(13) 0(14) 0(15) 100(16) 21(17) 0(18) 8021(19) 904(1a) 0(1b) 0(1c) 6011(1d);
    phy ctl=1000;
    mac t L60/60: ff ff ff ff ff ff b0 d5 cc 75 56 26 08 06 00 01 08 00 06 04 00 01 b0 d5 cc 75 56 26 c0 a8 01 eb 00 00 00 00 00 00 c0 a8 01 eb b9 8b 00 00 00 01 00 00 00 00 00 00 06 69 73 61 74 61;
    cpsw tx job done!
    netif en1 link up
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 5b 00 00 01 02 2d aa c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 fa 01 00 00 00 01 03 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 5c 00 00 01 02 2d a9 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 5e 00 00 40 11 a0 d3 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea e0 ed c4 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 5f 00 00 40 11 a0 d2 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 d8 ed c5 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 60 00 00 40 11 a0 d1 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea dc ed c6 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L96: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 26 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 fc 76 14 eb 00 26;
    mac0 r L76: 01 00 5e 00 00 fc 00 04 23 a7 22 f4 08 00 45 00 00 3a 55 61 00 00 01 11 c1 a1 c0 a8 01 0c e0 00 00 fc c1 58 14 eb 00 26 93 e5 a4 37 00 00 00 01 00 00 00 00 00 00 0c 78 38 30 31 30;
    mac t L86/86: 33 33 ff 75 56 26 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 20 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 02 00 00 00 00 00 00 00 00 00 01 ff 75 56 26 3a 00 05 02 00 00;
    mac t L78/78: 33 33 ff 75 56 26 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 18 3a ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 02 00 00 00 00 00 00 00 00 00 01 ff 75 56 26 87 00 51 1a 00 00;
    cpsw tx job done!
    mac t L62/62: 33 33 00 00 00 02 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 08 3a ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02 85 00 7b b8 00 00;
    cpsw tx job done!
    cpsw tx job done!
    cpsw tx job done!
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 63 00 00 01 02 2d a2 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 64 00 00 40 11 a0 cd c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea dc ed c6 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 65 00 00 40 11 a0 cc c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 d8 ed c5 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 66 00 00 40 11 a0 cb c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea e0 ed c4 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 67 00 00 01 11 b2 36 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 68 00 00 01 11 b2 35 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 69 00 00 01 11 b2 34 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 6a 00 00 40 11 a0 c7 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea e0 ed c4 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 6b 00 00 40 11 a0 c6 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 d8 ed c5 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 6c 00 00 40 11 a0 c5 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea dc ed c6 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac t L86/86: 33 33 ff 75 56 26 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 20 00 01 fe 80 00 00 00 00 00 00 b2 d5 cc ff fe 75 56 26 ff 02 00 00 00 00 00 00 00 00 00 01 ff 75 56 26 3a 00 05 02 00 00;
    cpsw tx job done!
    mac0 r L90: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 20 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 e3 4e 14 eb 00 20;
    mac0 r L70: 01 00 5e 00 00 fc 00 04 23 a7 22 f4 08 00 45 00 00 34 55 6d 00 00 01 11 c1 9b c0 a8 01 0c e0 00 00 fc d9 38 14 eb 00 20 e5 af 2a fa 00 00 00 01 00 00 00 00 00 00 06 69 73 61 74 61;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 6e 00 00 40 11 a0 d5 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 d1 ed c7 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 6f 00 00 40 11 a0 c2 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c eb dc ed c6 28 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 70 00 00 40 11 a0 c1 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 59 d8 ed c5 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 71 00 00 40 11 a0 c0 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c eb e0 ed c4 28 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    patrol zone <KERNEL-DATA> complete.
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 72 00 00 40 11 a0 d1 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 d1 ed c7 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 74 00 00 40 11 a0 bd c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a d2 ed ca 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 76 00 00 40 11 a0 cd c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 d1 ed c7 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 77 00 00 40 11 a0 ba c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a d2 ed ca 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 78 00 00 01 11 b2 25 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac t L70/70: 33 33 00 00 00 02 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 10 3a ff fe 80 00 00 00 00 00 00 b2 d5 cc ff fe 75 56 26 ff 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02 85 00 d4 4a 00 00;
    cpsw tx job done!
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 79 00 00 40 11 a0 ca c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 cd ed cb 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 7a 00 00 40 11 a0 b7 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a d2 ed ca 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 7b 00 00 40 11 a0 c8 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 cd ed cb 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 7c 00 00 40 11 a0 b5 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4b d2 ed ca 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 7d 00 00 40 11 a0 c6 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 cd ed cb 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 7e 00 00 40 11 a0 40 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 f0 11 02 ed ce c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L247: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 e5 55 7f 00 00 40 11 a0 2d c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 d1 5d c9 11 02 ed cf c0 a8 01 0c 00 8a 00 bb 00 00 20 46 49 44;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 80 00 00 40 11 a0 c3 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 c8 ed d0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 81 00 00 01 11 b2 1c c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 82 00 00 40 11 a0 c1 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 c8 ed d0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 83 00 00 40 11 a0 3b c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 eb 11 02 ed d3 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    patrol zone <EXT-DATA> complete.
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 84 00 00 40 11 a0 bf c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 c8 ed d0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    cpsw tx job done!
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 8a 00 00 40 11 a0 34 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 ea 11 02 ed d4 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 8c 00 00 01 11 b2 11 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 8d 00 00 40 11 a0 31 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 e9 11 02 ed d5 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L64: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 06 00 01 08 00 06 04 00 01 00 04 23 a7 22 f4 c0 a8 01 0c 00 00 00 00 00 00 c0 a8 01 eb 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00;
    mac t L60/60: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 06 00 01 08 00 06 04 00 02 b0 d5 cc 75 56 26 c0 a8 01 eb 00 04 23 a7 22 f4 c0 a8 01 0c ed c6 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    cpsw tx job done!
    mac0 r L78: b0 d5 cc 75 56 26 00 04 23 a7 22 f4 08 00 45 00 00 3c 55 8e 00 00 40 01 a0 eb c0 a8 01 0c c0 a8 01 eb 08 00 39 1e 00 01 14 3d 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    mac t L74/74: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 00 45 00 00 3c 55 8e 00 00 ff 01 e1 ea c0 a8 01 eb c0 a8 01 0c 00 00 41 1e 00 01 14 3d 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    cpsw tx job done!
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 8f 00 00 40 11 a0 23 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb c9 c9 11 02 ed d6 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L78: b0 d5 cc 75 56 26 00 04 23 a7 22 f4 08 00 45 00 00 3c 55 90 00 00 40 01 a0 e9 c0 a8 01 0c c0 a8 01 eb 08 00 39 1d 00 01 14 3e 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    mac t L74/74: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 00 45 00 00 3c 55 90 00 00 ff 01 e1 e8 c0 a8 01 eb c0 a8 01 0c 00 00 41 1d 00 01 14 3e 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    cpsw tx job done!
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 91 00 00 01 11 b2 0c c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 92 00 00 40 11 a0 20 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb c9 c8 11 02 ed d7 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L78: b0 d5 cc 75 56 26 00 04 23 a7 22 f4 08 00 45 00 00 3c 55 93 00 00 40 01 a0 e6 c0 a8 01 0c c0 a8 01 eb 08 00 39 1c 00 01 14 3f 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    mac t L74/74: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 00 45 00 00 3c 55 93 00 00 ff 01 e1 e5 c0 a8 01 eb c0 a8 01 0c 00 00 41 1c 00 01 14 3f 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    cpsw tx job done!
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 94 00 00 40 11 a0 1e c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb c9 c7 11 02 ed d8 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L78: b0 d5 cc 75 56 26 00 04 23 a7 22 f4 08 00 45 00 00 3c 55 95 00 00 40 01 a0 e4 c0 a8 01 0c c0 a8 01 eb 08 00 39 1b 00 01 14 40 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    mac t L74/74: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 00 45 00 00 3c 55 95 00 00 ff 01 e1 e3 c0 a8 01 eb c0 a8 01 0c 00 00 41 1b 00 01 14 40 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 71 72;
    cpsw tx job done!
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 96 00 00 40 11 a0 1c c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb c9 c6 11 02 ed d9 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 97 00 00 01 11 b2 06 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 98 00 00 40 11 a0 99 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb c2 ed da 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 99 00 00 40 11 a0 98 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb c2 ed da 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 9a 00 00 40 11 a0 97 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb c2 ed da 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    wdg enable 0s!
    wdg write start!
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 9b 00 00 40 11 a0 96 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cc c2 ed da 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 9c 00 00 01 11 b2 01 c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 9d 00 00 40 11 a0 94 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 bf ed db 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 9e 00 00 40 11 a0 93 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 bf ed db 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 9f 00 00 40 11 a0 92 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 bf ed db 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 a0 00 00 40 11 a0 91 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 25 bf ed db 28 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 a1 00 00 01 11 b1 fc c0 a8 01 0c ef ff ff fa c0 2b 07 6c 00 8d df a3 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 a2 00 00 40 11 a0 1c c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 63 e3 11 02 ed dc c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 a3 00 00 40 11 a0 1b c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 2f df 11 02 ed dd c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L259: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 f1 55 a4 00 00 40 11 9f fc c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 dd 32 5b 11 02 ed de c0 a8 01 0c 00 8a 00 c7 00 00 20 46 49 44;
    [root@sylixos:/root]# phy link err=0x7849,id=0x2000,5c90;
    netif en1 link down
    phy reg0x10~0x1D= 4815(10) 1(11) 2c00(12) 0(13) 12(14) 0(15) 100(16) 21(17) 0(18) 8021(19) 904(1a) 0(1b) 0(1c) 6011(1d);
    phy ctl=1000;
    mac t L60/60: ff ff ff ff ff ff b0 d5 cc 75 56 26 08 06 00 01 08 00 06 04 00 01 b0 d5 cc 75 56 26 c0 a8 01 eb 00 00 00 00 00 00 c0 a8 01 eb 00 00 00 00 00 00 00 00 00 00 00 16 3a 00 05 02 00 00;
    cpsw tx job done!
    netif en1 link up
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 ad 00 00 01 02 2d 58 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 ae 00 00 01 02 2d 57 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 ea 03 00 00 00 01 04 00 00 00 ef ff ff fa 00 00 00 00 00 00;
    mac0 r L66: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 30 55 af 00 00 01 02 2d 4e c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 05 06 00 00 00 02 04 00 00 00 e0 00 00 fc 04 00 00 00 ef ff;
    mac0 r L90: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 20 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 ff e9 14 eb 00 20;
    mac0 r L70: 01 00 5e 00 00 fc 00 04 23 a7 22 f4 08 00 45 00 00 34 55 b0 00 00 01 11 c1 58 c0 a8 01 0c e0 00 00 fc ed 56 14 eb 00 20 aa 20 52 6b 00 00 00 01 00 00 00 00 00 00 06 69 73 61 74 61;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 b1 00 00 01 02 2d 54 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 fa 01 00 00 00 01 03 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 b2 00 00 01 02 2d 53 c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 b3 00 00 40 11 a0 7e c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b7 ed ed 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 b4 00 00 40 11 a0 7d c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 af ed ee 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 b5 00 00 40 11 a0 7c c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b3 ed ef 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L64: 01 00 5e 00 00 16 00 04 23 a7 22 f4 08 00 46 00 00 28 55 b6 00 00 01 02 2d 4f c0 a8 01 0c e0 00 00 16 94 04 00 00 22 00 f9 01 00 00 00 01 04 00 00 00 e0 00 00 fc 00 00 00 00 00 00;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 b7 00 00 01 11 b1 e6 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 b8 00 00 40 11 a0 79 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b3 ed ef 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 b9 00 00 40 11 a0 78 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 af ed ee 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 ba 00 00 40 11 a0 77 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b7 ed ed 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 bb 00 00 40 11 a0 76 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b7 ed ed 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 bc 00 00 40 11 a0 75 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 58 af ed ee 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 bd 00 00 40 11 a0 74 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c ea b3 ed ef 29 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L90: 33 33 00 01 00 03 00 04 23 a7 22 f4 86 dd 60 00 00 00 00 20 11 01 fe 80 00 00 00 00 00 00 74 8c ea 35 fd 98 91 99 ff 02 00 00 00 00 00 00 00 00 00 00 00 01 00 03 d0 6a 14 eb 00 20;
    mac0 r L70: cc cc cc cc cc cc cc cc cc cc cc cc cc cc 45 00 00 34 55 be 00 00 01 11 c1 4a c0 a8 01 0c e0 00 00 fc eb 9a 14 eb 00 20 0a fb f3 4c 00 00 00 01 00 00 00 00 00 00 06 69 73 61 74 61;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 c3 00 00 40 11 a0 6e c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c eb b7 ed ed 28 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 c4 00 00 40 11 a0 6d c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 59 af ed ee 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 c5 00 00 40 11 a0 6c c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c eb b3 ed ef 28 10 00 01 00 00 00 00 00 01 20 46 49 44 49 44;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 c6 00 00 40 11 a0 7d c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a8 ed f0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 c7 00 00 40 11 a0 6a c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a a9 ed f3 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 c8 00 00 40 11 a0 7b c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a8 ed f0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 ca 00 00 01 11 b1 d3 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 cb 00 00 01 11 b1 d2 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 cc 00 00 01 11 b1 d1 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 cd 00 00 40 11 a0 64 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a a9 ed f3 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 ce 00 00 40 11 a0 75 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a8 ed f0 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 cf 00 00 40 11 a0 62 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4a a9 ed f3 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 d0 00 00 40 11 a0 73 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a4 ed f4 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 d1 00 00 01 11 b1 cc c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 d2 00 00 40 11 a0 5f c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 4b a9 ed f3 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 d3 00 00 40 11 a0 70 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a4 ed f4 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac t L70/70: 33 33 00 00 00 02 b0 d5 cc 75 56 26 86 dd 60 00 00 00 00 10 3a ff fe 80 00 00 00 00 00 00 b2 d5 cc ff fe 75 56 26 patrol zone <KERNEL-DATA> complete.
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 d4 00 00 40 11 9f ea c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 c7 11 02 ed f7 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L247: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 e5 55 d5 00 00 40 11 9f d7 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 d1 5d a0 11 02 ed f8 c0 a8 01 0c 00 8a 00 bb 00 00 20 46 49 44;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 d6 00 00 40 11 a0 6d c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 a4 ed f4 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 d7 00 00 01 11 b1 c6 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 d8 00 00 01 11 b1 c5 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 d9 00 00 40 11 a0 6a c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 9f ed f9 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 da 00 00 40 11 9f e4 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 c2 11 02 ed fc c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 db 00 00 40 11 a0 68 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 9f ed f9 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 dc 00 00 01 11 b1 c1 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L96: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 4e 55 dd 00 00 40 11 a0 66 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 3a 44 9f ed f9 01 10 00 01 00 00 00 00 00 00 20 45 4a 46 44 45;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 de 00 00 40 11 9f e0 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 c1 11 02 ed fd c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 df 00 00 40 11 9f df c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 56 c0 11 02 ed fe c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 e0 00 00 01 11 b1 bd c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 e1 00 00 40 11 9f d1 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb e1 54 11 02 ed ff c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 e2 00 00 40 11 9f d0 c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb e1 53 11 02 ee 00 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 e3 00 00 01 11 b1 ba c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 e4 00 00 40 11 9f ce c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb e1 52 11 02 ee 01 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L241: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 df 55 e5 00 00 40 11 9f cd c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 cb e1 51 11 02 ee 02 c0 a8 01 0c 00 8a 00 b5 00 00 20 46 49 44;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 e6 00 00 40 11 a0 4b c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb 99 ee 03 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 e7 00 00 01 11 b1 b6 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 e8 00 00 40 11 a0 49 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb 99 ee 03 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac t L60/60: 00 04 23 a7 22 f4 b0 d5 cc 75 56 26 08 06 00 01 08 00 06 04 00 02 b0 d5 cc 75 56 26 c0 a8 01 eb 00 04 23 a7 22 f4 c0 a8 01 0c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 ea 00 00 40 11 a0 47 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cb 99 ee 03 29 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 eb 00 00 40 11 a0 46 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c cc 99 ee 03 28 10 00 01 00 00 00 00 00 01 20 46 48 45 50 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 ec 00 00 40 11 a0 45 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 96 ee 04 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L179: 01 00 5e 7f ff fa 00 04 23 a7 22 f4 08 00 45 00 00 a1 55 ed 00 00 01 11 b1 b0 c0 a8 01 0c ef ff ff fa ef cc 07 6c 00 8d b0 02 4d 2d 53 45 41 52 43 48 20 2a 20 48 54 54 50 2f 31 2e;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 ee 00 00 40 11 a0 43 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 96 ee 04 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 f0 00 00 40 11 a0 41 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 24 96 ee 04 29 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L114: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 60 55 f1 00 00 40 11 a0 40 c0 a8 01 0c c0 a8 01 ff 00 89 00 89 00 4c 25 96 ee 04 28 10 00 01 00 00 00 00 00 01 20 41 42 41 43 46;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 f2 00 00 40 11 9f cc c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 63 ba 11 02 ee 05 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L229: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 d3 55 f3 00 00 40 11 9f cb c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 bf 2f b6 11 02 ee 06 c0 a8 01 0c 00 8a 00 a9 00 00 20 46 49 44;
    mac0 r L259: ff ff ff ff ff ff 00 04 23 a7 22 f4 08 00 45 00 00 f1 55 f4 00 00 40 11 9f ac c0 a8 01 0c c0 a8 01 ff 00 8a 00 8a 00 dd 32 32 11 02 ee 07 c0 a8 01 0c 00 8a 00 c7 00 00 20 46 49 44;
  • Hello, thanks for the above informaion, but could you please provide the information requested here as well:
    http://processors.wiki.ti.com/index.php/Ethernet_Triage_Checklist_for_AM3x/4x/5x_CPSW
    Please include the Linux version as requested.
    Thank you.
  •  thanks for your reply!
    1. In the kernel phase, the version that was changed on the basis of linux is used. The baseline number can not be found. Only the description on the code comment can be found in the attached figure:
    2.【uboot】version is: ti-processor-sdk-linux-am437x-evm-03.02.00.05-Linux-x86-Install.bin,Also made some modifications to the reference annex three c files:
     * Board functions for CRSCD AM437X based board
     * Copyright (C) 2018 crscd Ltd - http://www.crscd.com/
     * Author: xiaoyiping <xiaoyiping@crscd.com>
     * SPDX-License-Identifier:	GPL-2.0+
    #include <common.h>
    #include <i2c.h>
    #include <asm/errno.h>
    #include <spl.h>
    #include <usb.h>
    #include <asm/omap_sec_common.h>
    #include <asm/arch/clock.h>
    #include <asm/arch/sys_proto.h>
    #include <asm/arch/mux.h>
    #include <asm/arch/ddr_defs.h>
    #include <asm/arch/gpio.h>
    #include <asm/emif.h>
    #include "../common/board_detect.h"
    #include "board.h"
    #include <power/pmic.h>
    #include <power/tps65218.h>
    #include <power/tps62362.h>
    #include <miiphy.h>
    #include <cpsw.h>
    #include <linux/usb/gadget.h>
    #include <dwc3-uboot.h>
    #include <dwc3-omap-uboot.h>
    #include <ti-usb-phy-uboot.h>
    DECLARE_GLOBAL_DATA_PTR;
    static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; /*cpu��version��Ϣ��ַ*/
    /*add@20180308 for crsc ͬ��myir spl���߱��ļ���ע��spl��ش���*/
    #if 0
     * Read header information from EEPROM into global structure.
    #ifdef CONFIG_TI_I2C_BOARD_DETECT
    void do_board_detect(void)
    	if (ti_i2c_eeprom_am_get(-1, CONFIG_SYS_I2C_EEPROM_ADDR))
    		printf("ti_i2c_eeprom_init failed\n");
    #endif
    #ifndef CONFIG_SKIP_LOWLEVEL_INIT
    #define NUM_OPPS	6
    const struct dpll_params dpll_mpu[NUM_CRYSTAL_FREQ][NUM_OPPS] = {
    	{	/* 19.2 MHz */
    		{125, 3, 2, -1, -1, -1, -1},	/* OPP 50 */
    		{-1, -1, -1, -1, -1, -1, -1},	/* OPP RESERVED	*/
    		{125, 3, 1, -1, -1, -1, -1},	/* OPP 100 */
    		{150, 3, 1, -1, -1, -1, -1},	/* OPP 120 */
    		{125, 2, 1, -1, -1, -1, -1},	/* OPP TB */
    		{625, 11, 1, -1, -1, -1, -1}	/* OPP NT */
    	{	/* 24 MHz */
    		{300, 23, 1, -1, -1, -1, -1},	/* OPP 50 */
    		{600, 23, 1, -1, -1, -1, -1},	/* OPP 100 */
    		{720, 23, 1, -1, -1, -1, -1},	/* OPP 120 */
    		{800, 23, 1, -1, -1, -1, -1},	/* OPP TB */
    		{1000, 23, 1, -1, -1, -1, -1}	/* OPP NT */
    	{	/* 25 MHz */
    		{300, 24, 1, -1, -1, -1, -1},	/* OPP 50 */
    		{600, 24, 1, -1, -1, -1, -1},	/* OPP 100 */
    		{720, 24, 1, -1, -1, -1, -1},	/* OPP 120 */
    		{800, 24, 1, -1, -1, -1, -1},	/* OPP TB */
    		{1000, 24, 1, -1, -1, -1, -1}	/* OPP NT */
    	{	/* 26 MHz */
    		{300, 25, 1, -1, -1, -1, -1},	/* OPP 50 */
    		{600, 25, 1, -1, -1, -1, -1},	/* OPP 100 */
    		{720, 25, 1, -1, -1, -1, -1},	/* OPP 120 */
    		{800, 25, 1, -1, -1, -1, -1},	/* OPP TB */
    		{1000, 25, 1, -1, -1, -1, -1}	/* OPP NT */
    const struct dpll_params dpll_core[NUM_CRYSTAL_FREQ] = {
    		{625, 11, -1, -1, 10, 8, 4},	/* 19.2 MHz */
    		{1000, 23, -1, -1, 10, 8, 4},	/* 24 MHz */
    		{1000, 24, -1, -1, 10, 8, 4},	/* 25 MHz */
    		{1000, 25, -1, -1, 10, 8, 4}	/* 26 MHz */
    const struct dpll_params dpll_per[NUM_CRYSTAL_FREQ] = {
    		{400, 7, 5, -1, -1, -1, -1},	/* 19.2 MHz */
    		{400, 9, 5, -1, -1, -1, -1},	/* 24 MHz */
    		{384, 9, 5, -1, -1, -1, -1},	/* 25 MHz */
    		{480, 12, 5, -1, -1, -1, -1}	/* 26 MHz */
    const struct dpll_params epos_evm_dpll_ddr[NUM_CRYSTAL_FREQ] = {
    		{665, 47, 1, -1, 4, -1, -1}, /*19.2*/
    		{133, 11, 1, -1, 4, -1, -1}, /* 24 MHz */
    		{266, 24, 1, -1, 4, -1, -1}, /* 25 MHz */
    		{133, 12, 1, -1, 4, -1, -1}  /* 26 MHz */
    const struct dpll_params gp_evm_dpll_ddr = {
    		50, 2, 1, -1, 2, -1, -1};
    static const struct dpll_params idk_dpll_ddr = {
    	400, 23, 1, -1, 2, -1, -1
    static const u32 ext_phy_ctrl_const_base_lpddr2[] = {
    	0x00500050,
    	0x00350035,
    	0x00350035,
    	0x00350035,
    	0x00350035,
    	0x00350035,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x00000000,
    	0x40001000,
    	0x08102040
    const struct ctrl_ioregs ioregs_lpddr2 = {
    	.cm0ioctl		= LPDDR2_ADDRCTRL_IOCTRL_VALUE,
    	.cm1ioctl		= LPDDR2_ADDRCTRL_WD0_IOCTRL_VALUE,
    	.cm2ioctl		= LPDDR2_ADDRCTRL_WD1_IOCTRL_VALUE,
    	.dt0ioctl		= LPDDR2_DATA0_IOCTRL_VALUE,
    	.dt1ioctl		= LPDDR2_DATA0_IOCTRL_VALUE,
    	.dt2ioctrl		= LPDDR2_DATA0_IOCTRL_VALUE,
    	.dt3ioctrl		= LPDDR2_DATA0_IOCTRL_VALUE,
    	.emif_sdram_config_ext	= 0x1,
    const struct emif_regs emif_regs_lpddr2 = {
    	.sdram_config			= 0x808012BA,
    	.ref_ctrl			= 0x0000040D,
    	.sdram_tim1			= 0xEA86B411,
    	.sdram_tim2			= 0x103A094A,
    	.sdram_tim3			= 0x0F6BA37F,
    	.read_idle_ctrl			= 0x00050000,
    	.zq_config			= 0x50074BE4,
    	.temp_alert_config		= 0x0,
    	.emif_rd_wr_lvl_rmp_win		= 0x0,
    	.emif_rd_wr_lvl_rmp_ctl		= 0x0,
    	.emif_rd_wr_lvl_ctl		= 0x0,
    	.emif_ddr_phy_ctlr_1		= 0x0E284006,
    	.emif_rd_wr_exec_thresh		= 0x80000405,
    	.emif_ddr_ext_phy_ctrl_1	= 0x04010040,
    	.emif_ddr_ext_phy_ctrl_2	= 0x00500050,
    	.emif_ddr_ext_phy_ctrl_3	= 0x00500050,
    	.emif_ddr_ext_phy_ctrl_4	= 0x00500050,
    	.emif_ddr_ext_phy_ctrl_5	= 0x00500050,
    	.emif_prio_class_serv_map	= 0x80000001,
    	.emif_connect_id_serv_1_map	= 0x80000094,
    	.emif_connect_id_serv_2_map	= 0x00000000,
    	.emif_cos_config			= 0x000FFFFF
    const struct ctrl_ioregs ioregs_ddr3 = {
    	.cm0ioctl		= DDR3_ADDRCTRL_IOCTRL_VALUE,
    	.cm1ioctl		= DDR3_ADDRCTRL_WD0_IOCTRL_VALUE,
    	.cm2ioctl		= DDR3_ADDRCTRL_WD1_IOCTRL_VALUE,
    	.dt0ioctl		= DDR3_DATA0_IOCTRL_VALUE,
    	.dt1ioctl		= DDR3_DATA0_IOCTRL_VALUE,
    	.dt2ioctrl		= DDR3_DATA0_IOCTRL_VALUE,
    	.dt3ioctrl		= DDR3_DATA0_IOCTRL_VALUE,
    	.emif_sdram_config_ext	= 0xc163,
    const struct emif_regs ddr3_emif_regs_400Mhz = {
    	.sdram_config			= 0x638413B2,
    	.ref_ctrl			= 0x00000C30,
    	.sdram_tim1			= 0xEAAAD4DB,
    	.sdram_tim2			= 0x266B7FDA,
    	.sdram_tim3			= 0x107F8678,
    	.emif_ddr_phy_ctlr_1		= 0x0E004008,
    	.emif_ddr_ext_phy_ctrl_1	= 0x08020080,
    	.emif_ddr_ext_phy_ctrl_2	= 0x00400040,
    	.emif_ddr_ext_phy_ctrl_3	= 0x00400040,
    	.emif_ddr_ext_phy_ctrl_4	= 0x00400040,
    	.emif_ddr_ext_phy_ctrl_5	= 0x00400040,
    /* EMIF DDR3 Configurations are different for beta AM43X GP EVMs */
    const struct emif_regs ddr3_emif_regs_400Mhz_beta = {
    	.emif_ddr_ext_phy_ctrl_2	= 0x00000065,
    	.emif_ddr_ext_phy_ctrl_3	= 0x00000091,
    	.emif_ddr_ext_phy_ctrl_4	= 0x000000B5,
    	.emif_ddr_ext_phy_ctrl_5	= 0x000000E5,
    /* EMIF DDR3 Configurations are different for production AM43X GP EVMs */
    const struct emif_regs ddr3_emif_regs_400Mhz_production = {
    	.emif_ddr_ext_phy_ctrl_2	= 0x00000066,
    	.emif_ddr_ext_phy_ctrl_4	= 0x000000B9,
    	.emif_ddr_ext_phy_ctrl_5	= 0x000000E6,
    static const struct emif_regs ddr3_sk_emif_regs_400Mhz = {
    	.sdram_config			= 0x638413b2,
    	.sdram_config2			= 0x00000000,
    	.ref_ctrl			= 0x00000c30,
    	.sdram_tim1			= 0xeaaad4db,
    	.sdram_tim2			= 0x266b7fda,
    	.sdram_tim3			= 0x107f8678,
    	.zq_config			= 0x50074be4,
    	.emif_ddr_phy_ctlr_1		= 0x0e084008,
    	.emif_ddr_ext_phy_ctrl_2	= 0x89,
    	.emif_ddr_ext_phy_ctrl_3	= 0x90,
    	.emif_ddr_ext_phy_ctrl_4	= 0x8e,
    	.emif_ddr_ext_phy_ctrl_5	= 0x8d,
    	.emif_rd_wr_lvl_rmp_ctl		= 0x00000000,
    	.emif_rd_wr_lvl_ctl		= 0x00000000,
    	.emif_rd_wr_exec_thresh		= 0x80000000,
    static const struct emif_regs ddr3_idk_emif_regs_400Mhz = {
    	.sdram_config			= 0x61a11b32,
    	.temp_alert_config		= 0x00000000,
    	.emif_ddr_phy_ctlr_1		= 0x00008009,
    	.emif_ddr_ext_phy_ctrl_2	= 0x00000040,
    	.emif_ddr_ext_phy_ctrl_3	= 0x0000003e,
    	.emif_ddr_ext_phy_ctrl_4	= 0x00000051,
    	.emif_ddr_ext_phy_ctrl_5	= 0x00000051,
    	.emif_rd_wr_lvl_rmp_win		= 0x00000000,
    	.emif_rd_wr_exec_thresh		= 0x00000405,
    	.emif_prio_class_serv_map	= 0x00000000,
    	.emif_connect_id_serv_1_map	= 0x00000000,
    	.emif_cos_config		= 0x00ffffff
    void emif_get_ext_phy_ctrl_const_regs(const u32 **regs, u32 *size)
    	if (board_is_eposevm()) {
    		*regs = ext_phy_ctrl_const_base_lpddr2;
    		*size = ARRAY_SIZE(ext_phy_ctrl_const_base_lpddr2);
    	return;
     * get_sys_clk_index : returns the index of the sys_clk read from
     *			ctrl status register. This value is either
     *			read from efuse or sysboot pins.
    static u32 get_sys_clk_index(void)
    	struct ctrl_stat *ctrl = (struct ctrl_stat *)CTRL_BASE;
    	u32 ind = readl(&ctrl->statusreg), src;
    	src = (ind & CTRL_CRYSTAL_FREQ_SRC_MASK) >> CTRL_CRYSTAL_FREQ_SRC_SHIFT;
    	if (src == CTRL_CRYSTAL_FREQ_SRC_EFUSE) /* Value read from EFUSE */
    		return ((ind & CTRL_CRYSTAL_FREQ_SELECTION_MASK) >>
    			CTRL_CRYSTAL_FREQ_SELECTION_SHIFT);
    	else /* Value read from SYS BOOT pins */
    		return ((ind & CTRL_SYSBOOT_15_14_MASK) >>
    			CTRL_SYSBOOT_15_14_SHIFT);
    const struct dpll_params *get_dpll_ddr_params(void)
    	int ind = get_sys_clk_index();
    		return &epos_evm_dpll_ddr[ind];
    	else if (board_is_evm() || board_is_sk())
    		return &gp_evm_dpll_ddr;
    	else if (board_is_idk())
    		return &idk_dpll_ddr;
    	printf(" Board '%s' not supported\n", board_ti_get_name());
    	return NULL;
     * get_opp_offset:
     * Returns the index for safest OPP of the device to boot.
     * max_off:	Index of the MAX OPP in DEV ATTRIBUTE register.
     * min_off:	Index of the MIN OPP in DEV ATTRIBUTE register.
     * This data is read from dev_attribute register which is e-fused.
     * A'1' in bit indicates OPP disabled and not available, a '0' indicates
     * OPP available. Lowest OPP starts with min_off. So returning the
     * bit with rightmost '0'.
    static int get_opp_offset(int max_off, int min_off)
    	int opp, offset, i;
    	/* Bits 0:11 are defined to be the MPU_MAX_FREQ */
    	opp = readl(&ctrl->dev_attr) & ~0xFFFFF000;
    	for (i = max_off; i >= min_off; i--) {
    		offset = opp & (1 << i);
    		if (!offset)
    			return i;
    	return min_off;
    /*�Ƶ�spl.c�ˣ���am33xx���ã�ͬ����cm_t43��spl����*/
    const struct dpll_params *get_dpll_mpu_params(void)
    	int opp = get_opp_offset(DEV_ATTR_MAX_OFFSET, DEV_ATTR_MIN_OFFSET);
    	u32 ind = get_sys_clk_index();
    	return &dpll_mpu[ind][opp];
    const struct dpll_params *get_dpll_core_params(void)
    	return &dpll_core[ind];
    const struct dpll_params *get_dpll_per_params(void)
    	return &dpll_per[ind];
    void scale_vcores_generic(u32 m)
    	int mpu_vdd;
    	if (i2c_probe(TPS65218_CHIP_PM))
    		return;
    	switch (m) {
    	case 1000:
    		mpu_vdd = TPS65218_DCDC_VOLT_SEL_1330MV;
    		break;
    	case 800:
    		mpu_vdd = TPS65218_DCDC_VOLT_SEL_1260MV;
    		break;
    	case 720:
    		mpu_vdd = TPS65218_DCDC_VOLT_SEL_1200MV;
    		break;
    	case 600:
    		mpu_vdd = TPS65218_DCDC_VOLT_SEL_1100MV;
    		break;
    	case 300:
    		mpu_vdd = TPS65218_DCDC_VOLT_SEL_0950MV;
    		break;
    	default:
    		puts("Unknown MPU clock, not scaling\n");
    		return;
    	/* Set DCDC1 (CORE) voltage to 1.1V */
    	if (tps65218_voltage_update(TPS65218_DCDC1,
    				    TPS65218_DCDC_VOLT_SEL_1100MV)) {
    		printf("%s failure\n", __func__);
    		return;
    	/* Set DCDC2 (MPU) voltage */
    	if (tps65218_voltage_update(TPS65218_DCDC2, mpu_vdd)) {
    		return;
    void scale_vcores_idk(u32 m)
    	int mpu_vdd;
    	if (i2c_probe(TPS62362_I2C_ADDR))
    		return;
    	switch (m) {
    	case 1000:
    		mpu_vdd = TPS62362_DCDC_VOLT_SEL_1330MV;
    		break;
    	case 800:
    		mpu_vdd = TPS62362_DCDC_VOLT_SEL_1260MV;
    		break;
    	case 720:
    		mpu_vdd = TPS62362_DCDC_VOLT_SEL_1200MV;
    		break;
    	case 600:
    		mpu_vdd = TPS62362_DCDC_VOLT_SEL_1100MV;
    		break;
    	case 300:
    		break;
    	default:
    		return;
    	/* Set VDD_MPU voltage */
    	if (tps62362_voltage_update(TPS62362_SET3, mpu_vdd)) {
    		return;
    void gpi2c_init(void)
    	/* When needed to be invoked prior to BSS initialization */
    	static bool first_time = true;
    	if (first_time) {
    		enable_i2c0_pin_mux();
    		i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED,
    			 CONFIG_SYS_OMAP24_I2C_SLAVE);
    		first_time = false;
    void scale_vcores(void)
    	const struct dpll_params *mpu_params;
    	/* Ensure I2C is initialized for PMIC configuration */
    	gpi2c_init();
    	/* Get the frequency */
    	mpu_params = get_dpll_mpu_params();
    	if (board_is_idk())
    		scale_vcores_idk(mpu_params->m);
    	else
    		scale_vcores_generic(mpu_params->m);
    #endif
    #endif
    /*���ļ�����xxx�б��� ������Ҫ�Ƶ�mux.c��*/
    /*��2���ӿڷ�װ���armv7/am33xx���ṩ�ӿڡ�*/
    #if 0
    void set_uart_mux_conf(void)
    	enable_uart0_pin_mux();
    void set_mux_conf_regs(void)
    	enable_board_pin_mux();
    #endif
    #if 0
    #if 0
    static void enable_vtt_regulator(void)
    	u32 temp;
    	/* enable module */
    	writel(GPIO_CTRL_ENABLEMODULE, AM33XX_GPIO5_BASE + OMAP_GPIO_CTRL);
    	/* enable output for GPIO5_7 */
    	writel(GPIO_SETDATAOUT(7),
    	       AM33XX_GPIO5_BASE + OMAP_GPIO_SETDATAOUT);
    	temp = readl(AM33XX_GPIO5_BASE + OMAP_GPIO_OE);
    	temp = temp & ~(GPIO_OE_ENABLE(7));
    	writel(temp, AM33XX_GPIO5_BASE + OMAP_GPIO_OE);
    enum {
    	RTC_BOARD_EPOS = 1,
    	RTC_BOARD_EVM14,
    	RTC_BOARD_EVM12,
    	RTC_BOARD_GPEVM,
    	RTC_BOARD_SK,
     * In the rtc_only boot path we have the board type info in the rtc scratch pad
     * register hence we bypass the costly i2c reads to eeprom and directly program
     * the board name string
    void rtc_only_update_board_type(u32 btype)
    	const char *name = "";
    	const char *rev = "1.0";
    	switch (btype) {
    	case RTC_BOARD_EPOS:
    		name = "AM43EPOS";
    		break;
    	case RTC_BOARD_EVM14:
    		name = "AM43__GP";
    		rev = "1.4";
    		break;
    	case RTC_BOARD_EVM12:
    		name = "AM43__GP";
    		rev = "1.2";
    		break;
    	case RTC_BOARD_GPEVM:
    		name = "AM43__GP";
    		break;
    	case RTC_BOARD_SK:
    		name = "AM43__SK";
    		break;
    	ti_i2c_eeprom_am_set(name, rev);
    u32 rtc_only_get_board_type(void)
    		return RTC_BOARD_EPOS;
    	else if (board_is_evm_14_or_later())
    		return RTC_BOARD_EVM14;
    	else if (board_is_evm_12_or_later())
    		return RTC_BOARD_EVM12;
    	else if (board_is_gpevm())
    		return RTC_BOARD_GPEVM;
    	else if (board_is_sk())
    		return RTC_BOARD_SK;
    	return 0;
    void sdram_init(void)
    	 * EPOS EVM has 1GB LPDDR2 connected to EMIF.
    	 * GP EMV has 1GB DDR3 connected to EMIF
    	 * along with VTT regulator.
    		config_ddr(0, &ioregs_lpddr2, NULL, NULL, &emif_regs_lpddr2, 0);
    	} else if (board_is_evm_14_or_later()) {
    		enable_vtt_regulator();
    		config_ddr(0, &ioregs_ddr3, NULL, NULL,
    			   &ddr3_emif_regs_400Mhz_production, 0);
    	} else if (board_is_evm_12_or_later()) {
    			   &ddr3_emif_regs_400Mhz_beta, 0);
    	} else if (board_is_evm()) {
    			   &ddr3_emif_regs_400Mhz, 0);
    	} else if (board_is_sk()) {
    		config_ddr(400, &ioregs_ddr3, NULL, NULL,
    			   &ddr3_sk_emif_regs_400Mhz, 0);
    	} else if (board_is_idk()) {
    			   &ddr3_idk_emif_regs_400Mhz, 0);
    #endif
    #endif
    /* setup board specific PMIC */
    int power_init_board(void)
    	struct pmic *p;
    	uchar tps_status = 0;
        puts("PMIC:  TPS65218 skip!\n");
        return 0;
    /*add@20180308 for crsc ͬ��myir ʹ��65218��ԴоƬ*/
    #if 0
    		power_tps62362_init(I2C_PMIC);
    		p = pmic_get("TPS62362");
    		if (p && !pmic_probe(p))
    			puts("PMIC:  TPS62362\n");
    	} else
    #else
        if(board_is_crsc_c437x_idk())
    #endif
    		power_tps65218_init(I2C_PMIC);
    		p = pmic_get("TPS65218_PMIC");
    			puts("PMIC:  TPS65218\n");
    			/*begin:add@20180308 for crsc ͬ��myir*/
    			/* We don't care if fseal is locked, but we do need it set */
    			tps65218_lock_fseal();
    			tps65218_reg_read(TPS65218_STATUS, &tps_status);
    			if (!(tps_status & TPS65218_FSEAL))
    				printf("WARNING: RTC not backed by battery!\n");
    		    /*end:add@20180308 for crsc ͬ��myir*/
    	return 0;
    int board_init(void)
    	struct l3f_cfg_bwlimiter *bwlimiter = (struct l3f_cfg_bwlimiter *)L3F_CFG_BWLIMITER;
    	u32 mreqprio_0, mreqprio_1, modena_init0_bw_fractional,
    	    modena_init0_bw_integer, modena_init0_watermark_0;
    	gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
    	gpmc_init();
    	/* Clear all important bits for DSS errata that may need to be tweaked*/
    	mreqprio_0 = readl(&cdev->mreqprio_0) & MREQPRIO_0_SAB_INIT1_MASK &
    	                   MREQPRIO_0_SAB_INIT0_MASK;
    	mreqprio_1 = readl(&cdev->mreqprio_1) & MREQPRIO_1_DSS_MASK;
    	modena_init0_bw_fractional = readl(&bwlimiter->modena_init0_bw_fractional) &
    	                                   BW_LIMITER_BW_FRAC_MASK;
    	modena_init0_bw_integer = readl(&bwlimiter->modena_init0_bw_integer) &
    	                                BW_LIMITER_BW_INT_MASK;
    	modena_init0_watermark_0 = readl(&bwlimiter->modena_init0_watermark_0) &
    	                                 BW_LIMITER_BW_WATERMARK_MASK;
    	/* Setting MReq Priority of the DSS*/
    	mreqprio_0 |= 0x77;
    	 * Set L3 Fast Configuration Register
    	 * Limiting bandwith for ARM core to 700 MBPS
    	modena_init0_bw_fractional |= 0x10;
    	modena_init0_bw_integer |= 0x3;
    	writel(mreqprio_0, &cdev->mreqprio_0);
    	writel(mreqprio_1, &cdev->mreqprio_1);
    	writel(modena_init0_bw_fractional, &bwlimiter->modena_init0_bw_fractional);
    	writel(modena_init0_bw_integer, &bwlimiter->modena_init0_bw_integer);
    	writel(modena_init0_watermark_0, &bwlimiter->modena_init0_watermark_0);
    	return 0;
    #ifdef CONFIG_BOARD_LATE_INIT
    int board_late_init(void)
    #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
    	set_board_info_env("crsc_c437x_idk");
    	 * Default FIT boot on HS devices. Non FIT images are not allowed
    	 * on HS devices.
    	if (get_device_type() == HS_DEVICE)
    		setenv("boot_fit", "1");
    #endif
    	return 0;
    #endif
    #ifdef CONFIG_USB_DWC3
    static struct dwc3_device usb_otg_ss1 = {
    	.maximum_speed = USB_SPEED_HIGH,
    	.base = USB_OTG_SS1_BASE,
    	.tx_fifo_resize = false,
    	.index = 0,
    static struct dwc3_omap_device usb_otg_ss1_glue = {
    	.base = (void *)USB_OTG_SS1_GLUE_BASE,
    	.utmi_mode = DWC3_OMAP_UTMI_MODE_SW,
    	.index = 0,
    static struct ti_usb_phy_device usb_phy1_device = {
    	.usb2_phy_power = (void *)USB2_PHY1_POWER,
    	.index = 0,
    static struct dwc3_device usb_otg_ss2 = {
    	.base = USB_OTG_SS2_BASE,
    	.index = 1,
    static struct dwc3_omap_device usb_otg_ss2_glue = {
    	.base = (void *)USB_OTG_SS2_GLUE_BASE,
    	.index = 1,
    static struct ti_usb_phy_device usb_phy2_device = {
    	.usb2_phy_power = (void *)USB2_PHY2_POWER,
    	.index = 1,
    int usb_gadget_handle_interrupts(int index)
    	u32 status;
    	status = dwc3_omap_uboot_interrupt_status(index);
    	if (status)
    		dwc3_uboot_handle_interrupt(index);
    	return 0;
    #endif /* CONFIG_USB_DWC3 */
    #if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP)
    int board_usb_init(int index, enum usb_init_type init)
    	enable_usb_clocks(index);
    	switch (index) {
    	case 0:
    		if (init == USB_INIT_DEVICE) {
    			usb_otg_ss1.dr_mode = USB_DR_MODE_PERIPHERAL;
    			usb_otg_ss1_glue.vbus_id_status = OMAP_DWC3_VBUS_VALID;
    			dwc3_omap_uboot_init(&usb_otg_ss1_glue);
    			ti_usb_phy_uboot_init(&usb_phy1_device);
    			dwc3_uboot_init(&usb_otg_ss1);
    		break;
    	case 1:
    			usb_otg_ss2.dr_mode = USB_DR_MODE_PERIPHERAL;
    			usb_otg_ss2_glue.vbus_id_status = OMAP_DWC3_VBUS_VALID;
    			ti_usb_phy_uboot_init(&usb_phy2_device);
    			dwc3_omap_uboot_init(&usb_otg_ss2_glue);
    			dwc3_uboot_init(&usb_otg_ss2);
    		break;
    	default:
    		printf("Invalid Controller Index\n");
    #endif
    	return 0;
    int board_usb_cleanup(int index, enum usb_init_type init)
    	switch (index) {
    	case 0:
    	case 1:
    			ti_usb_phy_uboot_exit(index);
    			dwc3_uboot_exit(index);
    			dwc3_omap_uboot_exit(index);
    		break;
    	default:
    #endif
    	disable_usb_clocks(index);
    	return 0;
    #endif /* defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) */
    #ifndef CONFIG_DM_ETH  /*crsc��ǰ�����ˣ��򲻱������²���*/
    #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \
    	(defined(CONFIG_SPL_ETH_SUPPORT) && defined(CONFIG_SPL_BUILD))
    static void cpsw_control(int enabled)
    	/* Additional controls can be added here */
    	return;
    /*add@20180308 for crsc ͬ��myir���Ӷ����ʼֵ*/
    static struct cpsw_slave_data cpsw_slaves[] = {
    		.slave_reg_ofs	= 0x208, /*CPSW_PORT 0x4A10_0100+108h: CPSW_PORT_P1_MAX_BLKS*/
    		.sliver_reg_ofs	= 0xd80, /*CPSW_SL1 0x4A10_0D80: Ethernet Sliver for Port 1*/
    		.phy_addr	= 0,
    		.phy_addr	= 1,
    		.phy_addr	= 4,
    		.slave_reg_ofs	= 0x308, /*CPSW_PORT 0x4A10_0100+208h: CPSW_PORT_P2_MAX_BLKS*/
    		.sliver_reg_ofs	= 0xdc0, /*CPSW_SL2 0x4A10_0DC0: Ethernet Sliver for Port 2*/
    		.phy_addr	= 0,
    		.phy_addr	= 1,
    		.phy_addr	= 4,
    static struct cpsw_platform_data cpsw_data = {
    	.mdio_base		= CPSW_MDIO_BASE,  /*CPSW_MDIO 0x4A10_1000*/
    	.cpsw_base		= CPSW_BASE,  /*0x4A10_0000*/
    	.mdio_div		= 0xff,
    	.channels		= 8,
    	.cpdma_reg_ofs	= 0x800,
    	.slaves			= 6, /*add@20180308 for crsc ͬ��myir��1��Ϊ6��ɨ����slave��ַ*/
    	.slave_data		= cpsw_slaves,
    	.ale_reg_ofs		= 0xd00,
    	.ale_entries		= 1024,
    	.host_port_reg_ofs	= 0x108,
    	.hw_stats_reg_ofs	= 0x900,
    	.bd_ram_ofs		    = 0x2000,
    	.mac_control		= (1 << 5),
    	.control		    = cpsw_control,
    	.host_port_num		= 0,
    	.version		    = CPSW_CTRL_VERSION_2,
    #endif
     * This function will:
     * Read the eFuse for MAC addresses, and set ethaddr/eth1addr/usbnet_devaddr
     * in the environment
     * Perform fixups to the PHY present on certain boards.  We only need this
     * function in:
     * - SPL with either CPSW or USB ethernet support
     * - Full U-Boot, with either CPSW or USB ethernet
     * Build in only these cases to avoid warnings about unused variables
     * when we build an SPL that has neither option but full U-Boot will.
    #if ((defined(CONFIG_SPL_ETH_SUPPORT) || \
    	defined(CONFIG_SPL_USBETH_SUPPORT)) && \
    	((defined(CONFIG_DRIVER_TI_CPSW) || \
    	  defined(CONFIG_USB_ETHER)) && !defined(CONFIG_SPL_BUILD))
    int board_eth_init(bd_t *bis)
    	int rv;
    	uint8_t mac_addr[6];
    	uint32_t mac_hi, mac_lo;
        /*crsc���� cpu2��Ҫ��ʼ��
        if (board_is_crsc_c437x_idk())
            puts("crsc_c437x not support eth!\n");
            return 0;
    	/* try reading mac address from efuse ��cpu�Ĵ�������macֵ*/
    	mac_lo = readl(&cdev->macid0l);
    	mac_hi = readl(&cdev->macid0h);
    	mac_addr[0] = mac_hi & 0xFF;
    	mac_addr[1] = (mac_hi & 0xFF00) >> 8;
    	mac_addr[2] = (mac_hi & 0xFF0000) >> 16;
    	mac_addr[3] = (mac_hi & 0xFF000000) >> 24;
    	mac_addr[4] = mac_lo & 0xFF;
    	mac_addr[5] = (mac_lo & 0xFF00) >> 8;
    	if (!getenv("ethaddr")) {
    		puts("<ethaddr> not set. Validating first E-fuse MAC\n");
    		if (is_valid_ethaddr(mac_addr))
    			eth_setenv_enetaddr("ethaddr", mac_addr);
    #ifndef CONFIG_SPL_BUILD
    	mac_lo = readl(&cdev->macid1l);
    	mac_hi = readl(&cdev->macid1h);
    	if (!getenv("eth1addr")) {
    			eth_setenv_enetaddr("eth1addr", mac_addr);
    #endif
    /*add@20180308 for crsc ͬ��myir ע��������֧*/
    #if 0
    		writel(RMII_MODE_ENABLE | RMII_CHIPCKL_ENABLE, &cdev->miisel);
    		cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RMII;
    		cpsw_slaves[0].phy_addr = 16;
    		writel(RGMII_MODE_ENABLE, &cdev->miisel);
    		cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RGMII;
    		cpsw_slaves[0].phy_addr = 4;
    		cpsw_slaves[1].phy_addr = 5;
    #else
    #endif
    		//writel(RGMII_MODE_ENABLE, &cdev->miisel);
    		/*RMIIѡ������CPU�IJο�ʱ��*/
            cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_RMII;
            cpsw_slaves[2].phy_if = PHY_INTERFACE_MODE_RMII;
    		cpsw_slaves[3].phy_if = PHY_INTERFACE_MODE_RMII;
            cpsw_slaves[4].phy_if = PHY_INTERFACE_MODE_RMII;
            cpsw_slaves[5].phy_if = PHY_INTERFACE_MODE_RMII;
    		/*cpsw_slaves[0].phy_addr = 4; ��0��Ϊ4����ע����*/
    #if 0
    	else {
    		cpsw_slaves[0].phy_addr = 0;
    #endif
    	rv = cpsw_register(&cpsw_data);
    	if (rv < 0) {
    		printf("Error %d registering CPSW switch\n", rv);
    		return rv;
    #endif
    #if defined(CONFIG_USB_ETHER) && \
    	(!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USBETH_SUPPORT))
    		eth_setenv_enetaddr("usbnet_devaddr", mac_addr);
    	rv = usb_eth_initialize(bis);
    	if (rv < 0)
    		printf("Error %d registering USB_ETHER\n", rv);
    #endif
    	return rv;
    #endif
    #endif
    /*add@20180308 for crsc ���ļ�����spl�б��룬��Ҫ���˺����Ƶ�spl.c��*/
    #if 0
    #ifdef CONFIG_SPL_LOAD_FIT
    int board_fit_config_name_match(const char *name)
    /*add@20180308 for crsc*/
    #if 0
    	if (board_is_evm() && !strcmp(name, "am437x-gp-evm"))
    		return 0;
    	else if (board_is_sk() && !strcmp(name, "am437x-sk-evm"))
    		return 0;
    	else if (board_is_eposevm() && !strcmp(name, "am43x-epos-evm"))
    		return 0;
    	else if (board_is_idk() && !strcmp(name, "am437x-idk-evm"))
    		return 0;
    	else
    		return -1;
    #else
        if (board_is_crsc_c437x_idk() && !strcmp(name, "crsc_c437x"))
            return 0;
        else
            return -1;
    #endif
    #endif
    #endif
    #ifdef CONFIG_TI_SECURE_DEVICE
    void board_fit_image_post_process(void **p_image, size_t *p_size)
    	secure_boot_verify_image(p_image, p_size);
    #endif
    2350.am43xx_evm.h
    CONFIG_ARM=y
    CONFIG_AM43XX=y
    CONFIG_CRSC_I2C_BOARD_DETECT=y
    CONFIG_TARGET_CRSC_C437X=y
    CONFIG_DM_SERIAL=y
    # CONFIG_DM_SPI=y
    # CONFIG_DM_SPI_FLASH=y
    CONFIG_DM_GPIO=y
    CONFIG_SPL_STACK_R_ADDR=0x82000000
    CONFIG_DEFAULT_DEVICE_TREE="crsc_c437x"
    CONFIG_SPL=y
    CONFIG_SPL_STACK_R=y
    CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1"
    CONFIG_HUSH_PARSER=y
    CONFIG_CMD_BOOTZ=y
    CONFIG_SYS_PROMPT="CRSC># "
    # CONFIG_CMD_IMLS is not set
    CONFIG_CMD_ASKENV=y
    # CONFIG_CMD_FLASH is not set
    CONFIG_CMD_MMC=y
    CONFIG_CMD_SF=y
    CONFIG_CMD_SPI=y
    CONFIG_CMD_I2C=y
    CONFIG_CMD_USB=y
    CONFIG_CMD_DFU=y
    CONFIG_CMD_GPIO=y
    # CONFIG_CMD_SETEXPR is not set
    CONFIG_OF_CONTROL=y
    CONFIG_DM=y
    CONFIG_DMA=y
    # CONFIG_DM_MMC=y
    CONFIG_CMD_DHCP=y
    CONFIG_CMD_MII=y
    CONFIG_CMD_PING=y
    CONFIG_CMD_EXT2=y
    CONFIG_CMD_EXT4=y
    CONFIG_CMD_EXT4_WRITE=y
    CONFIG_CMD_FAT=y
    CONFIG_CMD_FS_GENERIC=y
    CONFIG_SPI_FLASH=y
    CONFIG_SPI_FLASH_BAR=y
    CONFIG_SPI_FLASH_MACRONIX=y
    CONFIG_SYS_NS16550=y
    # CONFIG_TI_QSPI=y
    CONFIG_TIMER=y
    CONFIG_OMAP_TIMER=y
    CONFIG_USB=y
    CONFIG_USB_DWC3=y
    CONFIG_USB_DWC3_GADGET=y
    CONFIG_USB_DWC3_OMAP=y
    CONFIG_USB_DWC3_PHY_OMAP=y
    CONFIG_USB_GADGET=y
    CONFIG_FIT=y
    CONFIG_SPL_OF_LIBFDT=y
    CONFIG_SPL_LOAD_FIT=y
    CONFIG_OF_LIST="crsc_c437x"
    # CONFIG_DM_ETH=y
    CONFIG_DM_NAND=y
    CONFIG_USB_GADGET_DOWNLOAD=y
    CONFIG_G_DNL_MANUFACTURER="Texas Instruments"
    CONFIG_G_DNL_VENDOR_NUM=0x0403
    CONFIG_G_DNL_PRODUCT_NUM=0xbd00
    CONFIG_CMD_TIME=y
    # CONFIG_DM_I2C=y
    The debug is already on but not appearing in the startup print,davinci_mdio or cpsw 48484000.only this:
    cpsw_phy_init:buscpsw,Addr1,devcpsw,if6;
    get phy by mask2!
    create phyid20005c90 cpsw addr1 if6!
    use generic phy!
    create phy cpsw(0)!
    cpsw connected to Generic PHY
    --Is it because uboot's modification is not correct? If we can debug ok in the boot phase, Then that it is not a hardware problem.
    3.The phy link is ok in both the uboot and kernel phases,and No Ethernet traffic until the PHY is reporting a link detection.
    3.1 【ethtool eth0】 :
    1)auto negotiation enabled on both ends of the link,The PC's Network card has also been set to auto-negotiation mode.
    2)the link speeds is 100 Mbps.The PC's Network card rate query is also 100M.
    3)Full Duplex mode is correct.
    CRSC># mdio read 0-7 (----when uboot)
    Reading from bus cpsw
    PHY at address 1:
    0 - 0x3100 --ok
    1 - 0x786d
    2 - 0x2000
    3 - 0x5c90
    4 - 0x1e1
    5 - 0xc1e1 --1 = Link Partner desires Next Page Transfer.
    6 - 0xf --1 = Link Partner does support Next Page
    7 - 0x2801
    PHY 1 Auto-Negotiation Successful(c200). (----when kernel)
    CPSW0 port1 phy dump:
    phy reg0~7= 1000(0) 786d(1) 2000(2) 5c90(3) 1e1(4) c1e1(5) d(6) 2801(7);
    phy reg0x10~0x1D= 4615(10) 1(11) 0(12) 0(13) 0(14) 0(15) 100(16) 21(17) 0(18) 8021(19) 904(1a) 0(1b) 0(1c) 6011(1d);
    rmii pinmux cfg:TXEN=3,TXD1=3,TXD0=3,RXD1=40003,RXD0=40003,CRS_DV=60003,RXER=40003,REFCLK=40001,MDIO_DATA=20000,MDIO_CLK=60000,;
    PHY 1 Transfer Mode : 100 Mbps Full Duplex.
    PC side settings::
    Description: Intel(R) PRO/1000 MT Dual Port Server Adapter
    Physical Address: ?00-04-23-A7-22-F5
    DHCP enabled: No
    IPv4 address: 192.168.1.11
    IPv4 subnet mask: 255.255.255.0
    IPv4 default gateway: 192.168.1.1
    IPv4 DNS server:
    IPv4 WINS server:
    NetBIOS over Tcpip: Yes is enabled
    3.2 【ethtool -S eth0】 :
    RX Checksum errors :
    RX Overrun errors :
    RX Start of Frame errors :
    【ifconfig】Details in the last reply
    Is the link up? --yes
    Is there an IP address? --yes
    Is the interface reporting data being received or transmitted?
    -- Normal at startup, error after insertion or removal for 5 hours, the problem occurs,there is increase in reception but no transmission count
    【Network view】
    1)Use Wireshark from the windows pc, when startup can capture packets both from PC and from AM4377
    When the problem occurs,can not capture packets from AM4377;can capture packets from PC;
    if the Linux PC is used,There is no problem when it is placed for 12 hours or the cable is plugged in.
    2)Use windows pc,After starting the kernel,Start a ping,ARP packets will show up in Wireshark.
    After placing for 5 hours or plugging in the network cable, ARP packets from AM4377 are not received on the pc.
    【Performance】
    When startup testing the interface with iperf, Function is normal。When the problem occurs,AM4377 can not send。
    【information requested】
    1)The kernel uses the modified linux version and does not support version query.
    [root@os:/root]# uname -a  command not found.
    2)uboot use ti-processor-sdk-linux-am437x-evm-03.02.00.05-Linux-x86-Install.bin;but the kernel does not use the TI SDK.
    3)Custom board,There is no device tree source file,The pin connection of the hardware between AM4377 and phy refers to the attached picture at the first reply.
    4)Console log of the boot process that includes U-Boot Refer to the attachment
    uboot_eth_err.txt
    5)ethtool: does not support this cmd.
    [root@os:/root]# ethtool
    sh: command not found.
    6)ifconfig :Refer to the description of the previous reply
  • Additional information:
    RX Overrun errors :
    CRSC># md 4a100900 ----when uboot
    4a100900: 00000000 00000000 00000000 00000000 ................
    4a100910: 00000000 00000000 00000000 00000000 ................
    4a100920: 00000000 00000000 00000000 00000000 ................
    4a100930: 00000000 00000000 00000000 00000000 ................
    4a100940: 00000000 00000000 00000000 00000000 ................
    4a100950: 00000000 00000000 00000000 00000000 ................
    4a100960: 00000000 00000000 00000000 00000000 ................
    4a100970: 00000000 00000000 00000000 00000000 ................
    4a100980: 00000000 00000000 00000000 00000000 ................
    ##Normal at startup ----when kernel
    phy reg0x10~0x1D= 15(10) 1(11) 2c00(12) 0(13) 0(14) 0(15) 100(16) 21(17) 0(18) 8021(19) 904(1a) 0(1b) 0(1c) 6011(1d);
    CPSW_STATS: ----from 4a100900
    [0]=0, 0, 0, 0, 0, 0, 0, 0,
    [20]=0, 0, 0, 0, 0, 1, 1, 0,
    [40]=0, 0, 0, 0, 0, 0, 0, 0,
    [60]=0, 64, 1, 0, 0, 0, 0, 0,
    [80]=64, 0, 0, 0, ;
    netif en1 link up
    bspModuleInit init ok!
    ##error after insertion ----when kernel
    CPSW_STATS:
    [0]=113, 64, 45, 0, 0, 0, 0, 0,
    [20]=0, 0, 0, 0, 12428, 14, 2, 7,
    [60]=0, 1078, 29, 74, 24, 0, 0, 0,
    [80]=13506, 27, 0, 0, ;
    netif en1 link up
  • more information when kernel:
    【Because the kernel version of Linux is uncertain, we can also analyze the configuration under uboot first. If uboot can work normally, it can be explained that the kernel software is causing problems.】
    【Read status once per second before and after plugging】
    phy reg0x10~0x1D= 615(10) 1(11) 0(12) 0(13) 0(14) 0(15) 100(16) 21(17)
    CPSW_STATS:
    [0]=14996, 14834, 51, 0, 0, 0, 0, 0,
    [20]=0, 0, 0, 0, 969729, 12938, 2, 7,
    [40]=0, 1068, 515, 515, 0, 0, 0, 0,
    [60]=0, 829432, 27627, 260, 42, 5, 0, 0,
    [80]=1816143, 14802, 0, 0, ;
    phy link err=0x7849,id=0x2000,5c90; ----【Normal running, at this time, pull the network cable】
    netif en1 link down
    PHY 1 Performing Auto-Negotiation... ----【Plug in the Internet cable at this time and start auto-negotiation.】
    phy reg0x10~0x1D= 815(10) 1(11) 2c00(12) 0(13) 10(14) 0(15) 100(16) 21(17)
    CPSW_STATS:
    [0]=15002, 14836, 55, 0, 0, 0, 0, 0,
    [20]=0, 0, 0, 0, 970201, 12938, 2, 7,
    [60]=0, 829432, 27629, 264, 42, 5, 0, 0,
    [80]=1816615, 14808, 0, 0, ;
    phy ctl=1000;
    PHY 1 Auto-Negotiation Successful(c167). ----【Auto-negotiation completed】
    CPSW_STATS:
    netif en1 link up
    CPSW_STATS:
    [20]=0, 0, 0, 0, 970201, 12939, 3, 7,
    [60]=0, 829496, 27630, 264, 42, 5, 0, 0, ----【At this point, the ping packet is blocked, the transmission is increased, and it will not change in the future.】
    [80]=1816679, 14808, 0, 0, ;
    CPSW_STATS:
    [0]=15015, 14841, 63, 0, 0, 0, 0, 0,
    [20]=0, 0, 0, 0, 971482, 12939, 3, 7,
    [60]=0, 829496, 27635, 270, 44, 5, 0, 0,
    [80]=1817960, 14821, 0, 0, ;
    This thread seems to same as this one.
    I suggest closing this one for the time being, we can come back to this one if the other thread does not satisfy this thread.
    Schuyler
