I have been working on a program which had been working well, up to the point where I started adding the next functionality which is USB communications. The function Int enc_ent_num was woking properly. I have not looked at this function for some time until I needed it for the use of the USB section. Now as I start using it again, it locks up the system.
Attached files are the map of the link and a screen shot from the emulation.
After running emulation - the disassembly of the code show multiplications in setting variables to 0 and after passing these steps you can see that the values set to the variables are not 0. Any ideas of what might going on?
TMS320C6x Linker PC v6.1.17
>> Linked Fri Dec 03 15:58:25 2010
OUTPUT FILE NAME: <./Debug/DSP.out>
ENTRY POINT SYMBOL: "_c_int00" address: 1001b880
MEMORY CONFIGURATION
name origin length used unused attr fill
IROM_BOOT 00000000 00020000 00000000 00020000 RWIX
IROM_DSPLIB 00020000 0000c000 00000000 0000c000 RWIX
IROM_FASTRTS 0002c000 00004000 00000000 00004000 RWIX
IROM_BIOS 00030000 00030000 00000000 00030000 RWIX
IRAM_BOOT 10000000 00001000 000001a0 00000e60 RWIX
IRAM_STACK 10001000 00000800 00000800 00000000 RWIX
VECT 10001800 00000200 00000200 00000000 RWIX
IRAM 10001a00 0003e600 00021740 0001cec0 RWIX
BOOTSRAM 90000000 00012000 00000000 00012000 RWIX
STATICRAM 90040000 00020000 00000000 00020000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.TIBootStrap
* 0 10000000 000001a0
10000000 00000020 --HOLE-- [fill = 0]
10000020 00000120 TISecondaryBoot.obj (.TIBootStrap:_TISecondaryBoot_bootstart)
10000140 00000060 TISecondaryBoot.obj (.TIBootStrap:_TISecondaryBoot_fetchAis)
.stack 0 10001000 00000800 UNINITIALIZED
10001000 00000008 rts6700.lib : boot.obj (.stack)
10001008 000007f8 --HOLE--
VECTORS 0 10001800 00000200
10001800 00000200 Vectors.obj (VECTORS)
.TIBoot 0 10001a00 00000f88
10001a00 00000920 TISecondaryBoot.obj (.TIBoot:_TISecondaryBoot_parseAisStream)
10002320 00000260 TISecondaryBoot.obj (.TIBoot:_TISecondaryBoot_updateCRC)
10002580 00000220 bootdancfg.obj (.TIBoot:_TIBootPllCfg)
100027a0 000000e0 TISecondaryBoot.obj (.TIBoot:_TISecondaryBoot_setReg)
10002880 00000060 bootdancfg.obj (.TIBoot:_TIBootSetup)
100028e0 00000040 bootdancfg.obj (.TIBoot:_TIBootAsyncRamCfg)
10002920 00000040 TISecondaryBoot.obj (.TIBoot:_TISecondaryBoot_abort)
10002960 00000028 TISecondaryBoot.obj (.switch)
.pinit 0 10002988 00000008
10002988 00000004 applySystemPatch.obj (.pinit)
1000298c 00000004 --HOLE-- [fill = 0]
.bss 0 10002a00 00011580 UNINITIALIZED
10002a00 00011198 FFT.obj (.bss)
10013b98 00000068 --HOLE--
10013c00 00000380 TISecondaryBoot.obj (.bss:tiSbootBss)
.text 0 10013f80 0000c6e0
10013f80 00000680 Functions0764.obj (.text:_enc_ent_num)
10014600 00000680 appmain.obj (.text:_getcalinfo)
10014c80 00000580 Functions0764.obj (.text:_usb_send_measure)
10015200 00000580 dsp67x.lib : DSPF_dp_cfftr2.obj (.text)
10015780 000004e0 appmain.obj (.text:_getBP)
10015c60 00000440 Functions0764.obj (.text:_disp_num_dp)
100160a0 000003c0 Functions0764.obj (.text:_FFT_PP_dp)
10016460 000003a0 appmain.obj (.text:_write_EEPROMCALDAT)
10016800 00000380 appmain.obj (.text:_Timer1_ISR)
10016b80 00000360 Functions0764.obj (.text:_genppfact)
10016ee0 00000340 Functions0764.obj (.text:_processpol)
10017220 00000340 Functions0764.obj (.text:_setadd13_19)
10017560 00000340 Functions0764.obj (.text:_usb_send_block)
100178a0 00000320 fastmath67x.lib : logdp.obj (.text)
10017bc0 00000300 c672xSystemPatchV2_00_00.lib : patch.obj (.text)
10017ec0 00000300 fastmath67x.lib : atan2dp.obj (.text)
100181c0 000002a0 Functions0764.obj (.text:_usb_get_block)
10018460 00000280 appmain.obj (.text:_Process_FFT)
100186e0 00000260 Functions0764.obj (.text:_decode_enc)
10018940 00000260 Functions0764.obj (.text:_disp_text_str_EEPROM)
10018ba0 00000240 Functions0764.obj (.text:_ad9832)
10018de0 00000240 rts6700.lib : memcpy62.obj (.text:_memcpy)
10019020 00000240 Functions0764.obj (.text:_setprogosc)
10019260 00000220 appmain.obj (.text:_Revert)
10019480 00000200 Functions0764.obj (.text:_bit_rev_dp)
10019680 000001e0 Functions0764.obj (.text:_flattop)
10019860 000001e0 Functions0764.obj (.text:_gen_w_r2_dp)
10019a40 000001e0 Functions0764.obj (.text:_usb_link)
10019c20 000001e0 fastmath67x.lib : expdp.obj (.text)
10019e00 000001a0 : expsp.obj (.text)
10019fa0 000001a0 : logsp.obj (.text)
1001a140 000001a0 : powdp.obj (.text)
1001a2e0 00000180 : sindp.obj (.text)
1001a460 00000160 Functions0764.obj (.text:_setdac)
1001a5c0 00000160 Functions0764.obj (.text:_write_EEPROMDAT)
1001a720 00000160 Functions0764.obj (.text:_write_disp)
1001a880 00000160 fastmath67x.lib : powsp.obj (.text)
1001a9e0 00000140 rts6700.lib : strasg.obj (.text:__strasgi)
1001ab20 00000120 Functions0764.obj (.text:_CalcFreqBin_SetOsc)
1001ac40 00000120 rts6700.lib : autoinit.obj (.text:__auto_init)
1001ad60 00000120 : divi.obj (.text:__divi)
1001ae80 00000120 Functions0764.obj (.text:_delay)
1001afa0 00000120 rts6700.lib : exit.obj (.text:_exit)
1001b0c0 00000120 fastmath67x.lib : sinsp.obj (.text)
1001b1e0 00000100 Functions0764.obj (.text:_readadc)
1001b2e0 000000e0 fastmath67x.lib : sqrtdp.obj (.text)
1001b3c0 000000c0 rts6700.lib : divu.obj (.text:__divu)
1001b480 000000c0 Functions0764.obj (.text:_memsw)
1001b540 000000c0 Functions0764.obj (.text:_wait_enc_val)
1001b600 000000a0 rts6700.lib : fixfu.obj (.text:__fixfu)
1001b6a0 000000a0 Functions0764.obj (.text:_setpga)
1001b740 000000a0 fastmath67x.lib : recipdp.obj (.text)
1001b7e0 000000a0 : sqrtsp.obj (.text)
1001b880 00000080 rts6700.lib : boot.obj (.text:_c_int00)
1001b900 00000080 Functions0764.obj (.text:_disp_text_char)
1001b980 00000080 Functions0764.obj (.text:_memsr)
1001ba00 00000080 Functions0764.obj (.text:_rfi)
1001ba80 00000080 Functions0764.obj (.text:_setdisppos)
1001bb00 00000080 fastmath67x.lib : divdp.obj (.text)
1001bb80 00000060 : divsp.obj (.text)
1001bbe0 00000040 rts6700.lib : args_main.obj (.text:__args_main)
1001bc20 00000020 : _lock.obj (.text:__nop)
1001bc40 00000020 : exit.obj (.text:_abort)
1001bc60 00004a00 appmain.obj (apptext:_main)
.const 0 10020660 00001f74
10020660 00000f9c c672xSystemPatchV2_00_00.lib : pdspFirmware_p0.pdsp.obj (.const)
100215fc 00000f9c : pdspFirmware_p1.pdsp.obj (.const)
10022598 00000020 DSPMAP.obj (.const)
100225b8 0000001c Functions0764.obj (.const:_$P$T0$1$0)
.cinit 0 100225d8 000006c4
100225d8 00000659 DSPMAP.obj (.cinit)
10022c31 00000007 --HOLE-- [fill = 0]
10022c38 0000002c rts6700.lib : exit.obj (.cinit)
10022c64 00000004 --HOLE-- [fill = 0]
10022c68 0000001c : _lock.obj (.cinit)
10022c84 00000004 --HOLE-- [fill = 0]
10022c88 0000000c : errno.obj (.cinit)
10022c94 00000004 --HOLE-- [fill = 0]
10022c98 00000004 (.pad.cinit) [fill = 0]
.data 0 10022ca0 000002a8
10022ca0 000000b8 fastmath67x.lib : expdp.obj (.data)
10022d58 00000080 : atan2dp.obj (.data)
10022dd8 00000078 : logdp.obj (.data)
10022e50 00000060 : sindp.obj (.data)
10022eb0 0000005c : expsp.obj (.data)
10022f0c 00000004 --HOLE-- [fill = 0]
10022f10 00000038 : logsp.obj (.data)
.far 0 10022f48 00000270 UNINITIALIZED
10022f48 00000191 DSPMAP.obj (.far)
100230d9 00000003 --HOLE--
100230dc 000000b8 appmain.obj (.far)
10023194 0000000c rts6700.lib : exit.obj (.far)
100231a0 00000009 TISecondaryBoot.obj (.far)
100231a9 00000003 --HOLE--
100231ac 00000008 rts6700.lib : _lock.obj (.far)
100231b4 00000004 : errno.obj (.far)
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address name
10002a00 $bss
10002a00 .bss
10022ca0 .data
10013f80 .text
1001bc40 C$$EXIT
10022f10 Logtable_asm
10022cc8 OneE2
10022d58 Vatndp
1000da08 _Ai
1000ba08 _Ar
10011a08 _Bi
1000fa08 _Br
100225b4 _Cal_Data
1001ab20 _CalcFreqBin_SetOsc
10015200 _DSPF_dp_cfftr2
10013b89 _EEdat
10022f50 _EMIF_A1CR
10022f48 _EMIF_ACCR
10022f4c _EMIF_SDCR
10009a08 _FFT_BIN
10007a08 _FFT_BUF
100160a0 _FFT_PP_dp
10022e50 _HPisdp
100230a0 _MC0_PDCLR
10023098 _MC0_PDIN
10023090 _MC0_PDIR
10023094 _MC0_PDOUT
1002309c _MC0_PDSET
1002308c _MC0_PFUNC
100230b8 _MC1_PDCLR
100230b0 _MC1_PDIN
100230a8 _MC1_PDIR
100230ac _MC1_PDOUT
100230b4 _MC1_PDSET
100230a4 _MC1_PFUNC
10018460 _Process_FFT
10004a00 _RAW_BUF
100230d8 _REF
10022f6c _RTI_CAFRC0
10022f80 _RTI_CAFRC1
10022f58 _RTI_CAPCTRL
10022f70 _RTI_CAUC0
10022f84 _RTI_CAUC1
10022fac _RTI_CLRINT
10022f88 _RTI_COMP0
10022f90 _RTI_COMP1
10022f98 _RTI_COMP2
10022fa0 _RTI_COMP3
10022f5c _RTI_COMPCTRL
10022f68 _RTI_CPUC0
10022f7c _RTI_CPUC1
10022fc4 _RTI_DWDCNTR
10022fb4 _RTI_DWDCTRL
10022fb8 _RTI_DWDPRLD
10022f60 _RTI_FRC0
10022f74 _RTI_FRC1
10022f54 _RTI_GCTRL
10022fb0 _RTI_INTFLAG
10022fa8 _RTI_SETINT
10022f64 _RTI_UC0
10022f78 _RTI_UC1
10022f8c _RTI_UDCP0
10022f94 _RTI_UDCP1
10022f9c _RTI_UDCP2
10022fa4 _RTI_UDCP3
10022fc0 _RTI_WDKEY
10022fbc _RTI_WDSTATUS
10019260 _Revert
100230c4 _SIP
10022ffc _SPI0_BUF
10023000 _SPI0_BUFs
10022ff4 _SPI0_DAT0
10022ff8 _SPI0_DAT1
1002300c _SPI0_DEF
10023008 _SPI0_DELAY
10023004 _SPI0_EMU
10022fd8 _SPI0_FLG
10023010 _SPI0_FMT0
10023014 _SPI0_FMT1
10023018 _SPI0_FMT2
1002301c _SPI0_FMT3
10022fc8 _SPI0_GCR0
10022fcc _SPI0_GCR1
10022fd0 _SPI0_INT0
10022fd4 _SPI0_LVL
10022fdc _SPI0_PC0
10022fe0 _SPI0_PC1
10022fe4 _SPI0_PC2
10022fe8 _SPI0_PC3
10022fec _SPI0_PC4
10022ff0 _SPI0_PC5
10023020 _SPI0_TGINTVECT0
10023024 _SPI0_TGINTVECT1
10023064 _SPI1_BUF
10023054 _SPI1_DAT0
10023058 _SPI1_DAT1
10023060 _SPI1_DAT1LW
1002305c _SPI1_DAT1UW
10023070 _SPI1_DEF
1002306c _SPI1_DELAY
10023068 _SPI1_EMU
10023038 _SPI1_FLG
10023074 _SPI1_FMT0
10023078 _SPI1_FMT1
1002307c _SPI1_FMT2
10023080 _SPI1_FMT3
10023028 _SPI1_GCR0
1002302c _SPI1_GCR1
10023030 _SPI1_INT0
10023034 _SPI1_LVL
1002303c _SPI1_PC0
10023040 _SPI1_PC1
10023044 _SPI1_PC2
10023048 _SPI1_PC3
1002304c _SPI1_PC4
10023050 _SPI1_PC5
10023084 _SPI1_TGINTVECT0
10023088 _SPI1_TGINTVECT1
10020660 _SarPdspFirmware0
100215fc _SarPdspFirmware1
10001a00 _TIBOOT_SEC_RUN_ADDR
00000f88 _TIBOOT_SEC_SIZE
100028e0 _TIBootAsyncRamCfg
10002580 _TIBootPllCfg
10002880 _TIBootSetup
10013e80 _TISecondaryBootStack
00000100 _TISecondaryBootStack_Size
10013c00 _TISecondaryBootStatus
10002920 _TISecondaryBoot_abort
10000020 _TISecondaryBoot_bootstart
10000140 _TISecondaryBoot_fetchAis
10001a00 _TISecondaryBoot_parseAisStream
100027a0 _TISecondaryBoot_setReg
10002320 _TISecondaryBoot_updateCRC
100231a8 _TISecondaryBootbootChar
100231a4 _TISecondaryBootbootPage
10002a00 _TWIDDLE
10016800 _Timer1_ISR
00000800 __STACK_SIZE
1002319c ___TI_enable_exit_profile_output
ffffffff ___TI_pprof_out_hndl
ffffffff ___TI_prof_data_size
ffffffff ___TI_prof_data_start
ffffffff ___binit__
10002a00 ___bss__
ffffffff ___c_args__
100225d8 ___cinit__
10022ca0 ___data__
10022f48 ___edata__
10013f80 ___end__
10020660 ___etext__
10002988 ___pinit__
10013f80 ___text__
1001bbe0 __args_main
1001ac40 __auto_init
10023194 __cleanup_ptr
1001bb00 __divd
1001bb80 __divf
1001ad60 __divi
1001b3c0 __divu
10023198 __dtors_ptr
1001b600 __fixfu
100231ac __lock
1001bc20 __nop
10001000 __stack
1001a9e0 __strasgi
100231b0 __unlock
1001bc40 _abort
10018ba0 _ad9832
100225a0 _analogch
10017bc0 _applySystemPatch
10017ec0 _atan
100180c4 _atan2
100180c4 _atan2dp
10017ec0 _atandp
10019480 _bit_rev_dp
1001b880 _c_int00
100230dc _calinfo
1001a2e0 _cos
1001a2e0 _cosdp
1001b0c0 _cosf
1001b0c0 _cossp
100186e0 _decode_enc
1001ae80 _delay
10015c60 _disp_num_dp
1001b900 _disp_text_char
10018940 _disp_text_str_EEPROM
10022598 _dispdat
1001bb00 _divdp
1001bb80 _divsp
1002259c _dspgpio
10013f80 _enc_ent_num
100231b4 _errno
1001afa0 _exit
10019c60 _exp
10019c44 _exp10
10019c44 _exp10dp
10019e30 _exp10f
10019e30 _exp10sp
10019c20 _exp2
10019c20 _exp2dp
10019e00 _exp2f
10019e00 _exp2sp
10019c60 _expdp
10019e60 _expf
10019e60 _expsp
10019680 _flattop
100230cc _freqbin
10019860 _gen_w_r2_dp
10016b80 _genppfact
10015780 _getBP
100230c8 _getbin
10014600 _getcalinfo
100230d6 _gpo
100225b0 _keyenc
100179e0 _log
10017940 _log10
10017940 _log10dp
10019fc0 _log10f
10019fc0 _log10sp
100178a0 _log2
100178a0 _log2dp
10019fa0 _log2f
10019fa0 _log2sp
100179e0 _logdp
10019fe0 _logf
10019fe0 _logsp
1001bc60 _main
10018de0 _memcpy
1001b980 _memsr
1001b480 _memsw
10022dd8 _nmnL2
100225a4 _pga_fs_disp
100230c0 _pgadat
10013a08 _poldat
1001a150 _pow
1001a150 _powdp
1001a880 _powf
1001a880 _powsp
10016ee0 _processpol
1001b1e0 _readadc
1001b740 _recip
1001b740 _recipdp
1001ba00 _rfi
10017220 _setadd13_19
1001a460 _setdac
1001ba80 _setdisppos
1001b6a0 _setpga
10019020 _setprogosc
100230d0 _sf
1001a2fc _sin
1001a2fc _sindp
1001b0d4 _sinf
1001b0d4 _sinsp
1001b2e0 _sqrt
1001b2e0 _sqrtdp
1001b7e0 _sqrtf
1001b7e0 _sqrtsp
100230bc _t51us
100181c0 _usb_get_block
10019a40 _usb_link
10017560 _usb_send_block
10014c80 _usb_send_measure
100225a8 _usbdat
100225ac _usbstrb
1001b540 _wait_enc_val
10016460 _write_EEPROMCALDAT
1001a5c0 _write_EEPROMDAT
1001a720 _write_disp
100230d4 _xmitf
ffffffff binit
100225d8 cinit
10022f48 edata
10013f80 end
10020660 etext
10022ee8 exp_ctable
10022eb0 exp_ktable
10002988 pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
address name
10001000 __stack
10002988 ___pinit__
10002988 pinit
10002a00 $bss
10002a00 .bss
10002a00 _TWIDDLE
10002a00 ___bss__
10004a00 _RAW_BUF
10007a08 _FFT_BUF
10009a08 _FFT_BIN
1000ba08 _Ar
1000da08 _Ai
1000fa08 _Br
10011a08 _Bi
10013a08 _poldat
10013b89 _EEdat
10013f80 .text
10013f80 ___end__
10013f80 ___text__
10013f80 end
10015780 _getBP
100160a0 _FFT_PP_dp
10016b80 _genppfact
100178a0 _log2
100178a0 _log2dp
10017940 _log10
10017940 _log10dp
100179e0 _log
100179e0 _logdp
10017ec0 _atan
10017ec0 _atandp
100180c4 _atan2
100180c4 _atan2dp
10018ba0 _ad9832
10018de0 _memcpy
10019260 _Revert
10019680 _flattop
10019a40 _usb_link
10019c20 _exp2
10019c20 _exp2dp
10019c44 _exp10
10019c44 _exp10dp
10019c60 _exp
10019c60 _expdp
10019e00 _exp2f
10019e00 _exp2sp
10019e30 _exp10f
10019e30 _exp10sp
10019e60 _expf
10019e60 _expsp
10019fa0 _log2f
10019fa0 _log2sp
10019fc0 _log10f
10019fc0 _log10sp
10019fe0 _logf
10019fe0 _logsp
1001a150 _pow
1001a150 _powdp
1001a2e0 _cos
1001a2e0 _cosdp
1001a2fc _sin
1001a2fc _sindp
1001a460 _setdac
1001a880 _powf
1001a880 _powsp
1001a9e0 __strasgi
1001ad60 __divi
1001ae80 _delay
1001afa0 _exit
1001b0c0 _cosf
1001b0c0 _cossp
1001b0d4 _sinf
1001b0d4 _sinsp
1001b1e0 _readadc
1001b2e0 _sqrt
1001b2e0 _sqrtdp
1001b3c0 __divu
1001b480 _memsw
1001b600 __fixfu
1001b6a0 _setpga
1001b740 _recip
1001b740 _recipdp
1001b7e0 _sqrtf
1001b7e0 _sqrtsp
1001b880 _c_int00
1001b980 _memsr
1001ba00 _rfi
1001bb00 __divd
1001bb00 _divdp
1001bb80 __divf
1001bb80 _divsp
1001bc20 __nop
1001bc40 C$$EXIT
1001bc40 _abort
1001bc60 _main
10020660 ___etext__
10020660 etext
10022598 _dispdat
1002259c _dspgpio
100225a0 _analogch
100225a8 _usbdat
100225ac _usbstrb
100225b0 _keyenc
100225b4 _Cal_Data
100225d8 ___cinit__
100225d8 cinit
10022ca0 .data
10022ca0 ___data__
10022cc8 OneE2
10022d58 Vatndp
10022dd8 _nmnL2
10022e50 _HPisdp
10022eb0 exp_ktable
10022ee8 exp_ctable
10022f48 _EMIF_ACCR
10022f48 ___edata__
10022f48 edata
10022f4c _EMIF_SDCR
10022f50 _EMIF_A1CR
10022f54 _RTI_GCTRL
10022f60 _RTI_FRC0
10022f64 _RTI_UC0
10022f68 _RTI_CPUC0
10022f70 _RTI_CAUC0
10022f74 _RTI_FRC1
10022f78 _RTI_UC1
10022f7c _RTI_CPUC1
10022f84 _RTI_CAUC1
10022f88 _RTI_COMP0
10022f8c _RTI_UDCP0
10022f90 _RTI_COMP1
10022f94 _RTI_UDCP1
10022f98 _RTI_COMP2
10022f9c _RTI_UDCP2
10022fa0 _RTI_COMP3
10022fa4 _RTI_UDCP3
10022fc0 _RTI_WDKEY
10022fc8 _SPI0_GCR0
10022fcc _SPI0_GCR1
10022fd0 _SPI0_INT0
10022fd4 _SPI0_LVL
10022fd8 _SPI0_FLG
10022fdc _SPI0_PC0
10022fe0 _SPI0_PC1
10022fe4 _SPI0_PC2
10022fe8 _SPI0_PC3
10022fec _SPI0_PC4
10022ff0 _SPI0_PC5
10022ff4 _SPI0_DAT0
10022ff8 _SPI0_DAT1
10022ffc _SPI0_BUF
10023000 _SPI0_BUFs
10023004 _SPI0_EMU
1002300c _SPI0_DEF
10023010 _SPI0_FMT0
10023014 _SPI0_FMT1
10023018 _SPI0_FMT2
1002301c _SPI0_FMT3
10023028 _SPI1_GCR0
1002302c _SPI1_GCR1
10023030 _SPI1_INT0
10023034 _SPI1_LVL
10023038 _SPI1_FLG
1002303c _SPI1_PC0
10023040 _SPI1_PC1
10023044 _SPI1_PC2
10023048 _SPI1_PC3
1002304c _SPI1_PC4
10023050 _SPI1_PC5
10023054 _SPI1_DAT0
10023058 _SPI1_DAT1
10023064 _SPI1_BUF
10023068 _SPI1_EMU
10023070 _SPI1_DEF
10023074 _SPI1_FMT0
10023078 _SPI1_FMT1
1002307c _SPI1_FMT2
10023080 _SPI1_FMT3
1002308c _MC0_PFUNC
10023090 _MC0_PDIR
10023094 _MC0_PDOUT
10023098 _MC0_PDIN
1002309c _MC0_PDSET
100230a0 _MC0_PDCLR
100230a4 _MC1_PFUNC
100230a8 _MC1_PDIR
100230ac _MC1_PDOUT
100230b0 _MC1_PDIN
100230b4 _MC1_PDSET
100230b8 _MC1_PDCLR
100230bc _t51us
100230c0 _pgadat
100230c4 _SIP
100230c8 _getbin
100230cc _freqbin
100230d0 _sf
100230d4 _xmitf
100230d6 _gpo
100230d8 _REF
100230dc _calinfo
100231ac __lock
100231b0 __unlock
100231b4 _errno
ffffffff ___binit__
ffffffff binit
[278 symbols]
